commit d0b4d64aadb9f4a90669848de9ef3819050a98cd upstream.
Commit 85ff6acb075a484780b3d763fdf41596d8fc0970 (xen/granttable: Grant
tables V2 implementation) changed the GREFS_PER_GRANT_FRAME macro from
a constant to a conditional expression. The expression depends on
grant_table_version being appropriately set. Unfortunately, at init
time grant_table_version will be 0. The GREFS_PER_GRANT_FRAME
conditional expression checks for "grant_table_version == 1", and
therefore returns the number of grant references per frame for v2.
This causes gnttab_init() to allocate fewer pages for gnttab_list, as
a frame can old half the number of v2 entries than v1 entries. After
gnttab_resume() is called, grant_table_version is appropriately
set. nr_init_grefs will then be miscalculated and gnttab_free_count
will hold a value larger than the actual number of free gref entries.
If a guest is heavily utilizing improperly initialized v1 grant
tables, memory corruption can occur. One common manifestation is
corruption of the vmalloc list, resulting in a poisoned pointer
derefrence when accessing /proc/meminfo or /proc/vmallocinfo:
[ 40.770064] BUG: unable to handle kernel paging request at 0000200200001407
[ 40.770083] IP: [<ffffffff811a6fb0>] get_vmalloc_info+0x70/0x110
[ 40.770102] PGD 0
[ 40.770107] Oops: 0000 [#1] SMP
[ 40.770114] CPU 10
This patch introduces a static variable, grefs_per_grant_frame, to
cache the calculated value. gnttab_init() now calls
gnttab_request_version() early so that grant_table_version and
grefs_per_grant_frame can be appropriately set. A few BUG_ON()s have
been added to prevent this type of bug from reoccurring in the future.
Signed-off-by: Matt Wilson <msw@amazon.com>
Reviewed-and-Tested-by: Steven Noonan <snoonan@amazon.com>
Acked-by: Ian Campbell <Ian.Campbell@citrix.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Annie Li <annie.li@oracle.com>
Cc: xen-devel@lists.xen.org
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 772aebcefeff310f80e32b874988af0076cb799d upstream.
exit_idle() should be called after irq_enter(), otherwise it throws:
[ INFO: suspicious RCU usage. ]
3.6.5 #1 Not tainted
include/linux/rcupdate.h:725 rcu_read_lock() used illegally while idle!
RCU used illegally from idle CPU!
rcu_scheduler_active = 1, debug_locks = 1
RCU used illegally from extended quiescent state!
1 lock held by swapper/0/0:
#0: (rcu_read_lock){......}, at: [<ffffffff810e9fe0>] __atomic_notifier_call_chain+0x0/0x140
stack backtrace:
Pid: 0, comm: swapper/0 Not tainted 3.6.5 #1
Call Trace:
<IRQ> [<ffffffff811259a2>] lockdep_rcu_suspicious+0xe2/0x130
[<ffffffff810ea10c>] __atomic_notifier_call_chain+0x12c/0x140
[<ffffffff810e9fe0>] ? atomic_notifier_chain_unregister+0x90/0x90
[<ffffffff811216cd>] ? trace_hardirqs_off+0xd/0x10
[<ffffffff810ea136>] atomic_notifier_call_chain+0x16/0x20
[<ffffffff810777c3>] exit_idle+0x43/0x50
[<ffffffff81568865>] xen_evtchn_do_upcall+0x25/0x50
[<ffffffff81aa690e>] xen_do_hypervisor_callback+0x1e/0x30
<EOI> [<ffffffff810013aa>] ? hypercall_page+0x3aa/0x1000
[<ffffffff81061540>] ? xen_safe_halt+0x10/0x20
[<ffffffff81075cfa>] ? default_idle+0xba/0x570
[<ffffffff810778af>] ? cpu_idle+0xdf/0x140
[<ffffffff81a4d881>] ? rest_init+0x135/0x144
[<ffffffff81a4d74c>] ? csum_partial_copy_generic+0x16c/0x16c
[<ffffffff82520c45>] ? start_kernel+0x3db/0x3e8
[<ffffffff8252066a>] ? repair_env_string+0x5a/0x5a
[<ffffffff82520356>] ? x86_64_start_reservations+0x131/0x135
[<ffffffff82524aca>] ? xen_start_kernel+0x465/0x46
Git commit 98ad1cc14a5c4fd658f9d72c6ba5c86dfd3ce0d5
Author: Frederic Weisbecker <fweisbec@gmail.com>
Date: Fri Oct 7 18:22:09 2011 +0200
x86: Call idle notifier after irq_enter()
did this, but it missed the Xen code.
Signed-off-by: Mojiong Qiu <mjqiu@tencent.com>
commit a67baeb77375199bbd842fa308cb565164dd1f19 upstream.
map->kmap_ops allocated in gntdev_alloc_map() wasn't freed by
gntdev_put_map().
Add a gntdev_free_map() helper function to free everything allocated
by gntdev_alloc_map().
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
commit 2fc136eecd0c647a6b13fcd00d0c41a1a28f35a5 upstream.
If the caller passes a valid kmap_op to m2p_add_override, we use
kmap_op->dev_bus_addr to store the original mfn, but dev_bus_addr is
part of the interface with Xen and if we are batching the hypercalls it
might not have been written by the hypervisor yet. That means that later
on Xen will write to it and we'll think that the original mfn is
actually what Xen has written to it.
Rather than "stealing" struct members from kmap_op, keep using
page->index to store the original mfn and add another parameter to
m2p_remove_override to get the corresponding kmap_op instead.
It is now responsibility of the caller to keep track of which kmap_op
corresponds to a particular page in the m2p_override (gntdev, the only
user of this interface that passes a valid kmap_op, is already doing that).
Reported-and-Tested-By: Sander Eikelenboom <linux@eikelenboom.it>
Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
commit 80ba77dfbce85f2d1be54847de3c866de1b18a9a upstream.
When we do FLR and save PCI config we did it in the wrong order.
The end result was that if a PCI device was unbind from
its driver, then binded to xen-pciback, and then back to its
driver we would get:
> lspci -s 04:00.0
04:00.0 Ethernet controller: Intel Corporation 82574L Gigabit Network Connection
13:42:12 # 4 :~/
> echo "0000:04:00.0" > /sys/bus/pci/drivers/pciback/unbind
> modprobe e1000e
e1000e: Intel(R) PRO/1000 Network Driver - 2.0.0-k
e1000e: Copyright(c) 1999 - 2012 Intel Corporation.
e1000e 0000:04:00.0: Disabling ASPM L0s L1
e1000e 0000:04:00.0: enabling device (0000 -> 0002)
xen: registering gsi 48 triggering 0 polarity 1
Already setup the GSI :48
e1000e 0000:04:00.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
e1000e: probe of 0000:04:00.0 failed with error -2
This fixes it by first saving the PCI configuration space, then
doing the FLR.
Reported-by: Ren, Yongjie <yongjie.ren@intel.com>
Reported-and-Tested-by: Tobias Geiger <tobias.geiger@vido.info>
commit b5031ed1be0aa419250557123633453753181643 upstream.
When running 32-bit pvops-dom0 and a driver tries to allocate a coherent
DMA-memory the xen swiotlb-implementation returned memory beyond 4GB.
The underlaying reason is that if the supplied driver passes in a
DMA_BIT_MASK(64) ( hwdev->coherent_dma_mask is set to 0xffffffffffffffff)
our dma_mask will be u64 set to 0xffffffffffffffff even if we set it to
DMA_BIT_MASK(32) previously. Meaning we do not reset the upper bits.
By using the dma_alloc_coherent_mask function - it does the proper casting
and we get 0xfffffffff.
This caused not working sound on a system with 4 GB and a 64-bit
compatible sound-card with sets the DMA-mask to 64bit.
On bare-metal and the forward-ported xen-dom0 patches from OpenSuse a coherent
DMA-memory is always allocated inside the 32-bit address-range by calling
dma_alloc_coherent_mask.
This patch adds the same functionality to xen swiotlb and is a rebase of the
original patch from Ronny Hegewald which never got upstream b/c the
underlaying reason was not understood until now.
The original email with the original patch is in:
http://old-list-archives.xen.org/archives/html/xen-devel/2010-02/msg00038.html
the original thread from where the discussion started is in:
http://old-list-archives.xen.org/archives/html/xen-devel/2010-01/msg00928.html
Signed-off-by: Ronny Hegewald <ronny.hegewald@online.de>
Signed-off-by: Stefano Panella <stefano.panella@citrix.com>
Acked-By: David Vrabel <david.vrabel@citrix.com>
commit 68c2c39a76b094e9b2773e5846424ea674bf2c46 upstream.
PV on HVM guests map GSIs into event channels. At restore time the
event channels are resumed by restore_pirqs.
Device drivers might try to register the same GSI again through ACPI at
restore time, but the GSI has already been mapped and bound by
restore_pirqs. This patch detects these situations and avoids
mapping the same GSI multiple times.
Without this patch we get:
(XEN) irq.c:2235: dom4: pirq 23 or emuirq 28 already mapped
and waste a pirq.
Fit it into 80 columns so that it is readable in menuconfig.
We did a similar check for the P-states but did not do it for
the C-states. What we want to do is ignore cases where the DSDT
has definition for sixteen CPUs, but the machine only has eight
CPUs and we get:
xen-acpi-processor: (CX): Hypervisor error (-22) for ACPI CPU14
Reported-by: Tobias Geiger <tobias.geiger@vido.info>
In pirq_check_eoi_map use the pirq number rather than the Linux irq
number to check whether an eoi is needed in the pirq_eoi_map.
The reason is that the irq number is not always identical to the
pirq number so if we wrongly use the irq number to check the
pirq_eoi_map we are going to check for the wrong pirq to EOI.
As a consequence some interrupts might not be EOI'ed by the
guest correctly.
[v1: Added some extra wording to git commit]
linux/drivers/xen/manage.c: In function 'do_suspend':
linux/drivers/xen/manage.c:160:5: warning: 'si.cancelled' may be used uninitialized in this function
A rather annoying and common case is when booting a PVonHVM guest
and exposing the PV KBD and PV VFB - as broken toolstacks don't
always initialize the backends correctly.
Normally The HVM guest is using the VGA driver and the emulated
keyboard for this (though upstream version of QEMU implements
PV KBD, but still uses a VGA driver). We provide a very basic
two-stage wait mechanism - where we wait for 30 seconds for all
devices, and then for 270 for all them except the two mentioned.
That allows us to wait for the essential devices, like network
or disk for the full 6 minutes.
To trigger this, put this in your guest config:
vfb = [ 'vnc=1, vnclisten=0.0.0.0 ,vncunused=1']
instead of this:
vnc=1
vnclisten="0.0.0.0"
CC: stable@kernel.org
Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
[v3: Split delay in non-essential (30 seconds) and essential
devices per Ian and Stefano suggestion]
[v4: Added comments per Stefano suggestion]
stable/for-linus-3.4
* commit 'c104f1fa1ecf4ee0fc06e31b1f77630b2551be81': (14566 commits)
cpufreq: OMAP: fix build errors: depends on ARCH_OMAP2PLUS
sparc64: Eliminate obsolete __handle_softirq() function
sparc64: Fix bootup crash on sun4v.
kconfig: delete last traces of __enabled_ from autoconf.h
Revert "kconfig: fix __enabled_ macros definition for invisible and un-selected symbols"
kconfig: fix IS_ENABLED to not require all options to be defined
irq_domain: fix type mismatch in debugfs output format
staging: android: fix mem leaks in __persistent_ram_init()
staging: vt6656: Don't leak memory in drivers/staging/vt6656/ioctl.c::private_ioctl()
staging: iio: hmc5843: Fix crash in probe function.
panic: fix stack dump print on direct call to panic()
drivers/rtc/rtc-pl031.c: enable clock on all ST variants
Revert "mm: vmscan: fix misused nr_reclaimed in shrink_mem_cgroup_zone()"
hugetlb: fix race condition in hugetlb_fault()
drivers/rtc/rtc-twl.c: use static register while reading time
drivers/rtc/rtc-s3c.c: add placeholder for driver private data
drivers/rtc/rtc-s3c.c: fix compilation error
MAINTAINERS: add PCDP console maintainer
memcg: do not open code accesses to res_counter members
drivers/rtc/rtc-efi.c: fix section mismatch warning
Since we are using the m2p_override we do have struct pages
corresponding to the user vma mmap'ed by gntdev.
Removing the VM_PFNMAP flag makes get_user_pages work on that vma.
An example test case would be using a Xen userspace block backend
(QDISK) on a file on NFS using O_DIRECT.
Jump to the label ini_nomem as done on the failure of the page allocations
above.
The code at ini_nomem is modified to accommodate different return values.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen
Pull xen fixes from Konrad Rzeszutek Wilk:
"Two fixes for regressions:
* one is a workaround that will be removed in v3.5 with proper fix in
the tip/x86 tree,
* the other is to fix drivers to load on PV (a previous patch made
them only load in PVonHVM mode).
The rest are just minor fixes in the various drivers and some cleanup
in the core code."
* tag 'stable/for-linus-3.4-rc1-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen/pcifront: avoid pci_frontend_enable_msix() falsely returning success
xen/pciback: fix XEN_PCI_OP_enable_msix result
xen/smp: Remove unnecessary call to smp_processor_id()
xen/x86: Workaround 'x86/ioapic: Add register level checks to detect bogus io-apic entries'
xen: only check xen_platform_pci_unplug if hvm
Prior to 2.6.19 and as of 2.6.31, pci_enable_msix() can return a
positive value to indicate the number of vectors (less than the amount
requested) that can be set up for a given device. Returning this as an
operation value (secondary result) is fine, but (primary) operation
results are expected to be negative (error) or zero (success) according
to the protocol. With the frontend fixed to match the XenoLinux
behavior, the backend can now validly return zero (success) here,
passing the upper limit on the number of vectors in op->value.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
git://git.linaro.org/people/mszyprowski/linux-dma-mapping
Pull DMA mapping branch from Marek Szyprowski:
"Short summary for the whole series:
A few limitations have been identified in the current dma-mapping
design and its implementations for various architectures. There exist
more than one function for allocating and freeing the buffers:
currently these 3 are used dma_{alloc, free}_coherent,
dma_{alloc,free}_writecombine, dma_{alloc,free}_noncoherent.
For most of the systems these calls are almost equivalent and can be
interchanged. For others, especially the truly non-coherent ones
(like ARM), the difference can be easily noticed in overall driver
performance. Sadly not all architectures provide implementations for
all of them, so the drivers might need to be adapted and cannot be
easily shared between different architectures. The provided patches
unify all these functions and hide the differences under the already
existing dma attributes concept. The thread with more references is
available here:
http://www.spinics.net/lists/linux-sh/msg09777.html
These patches are also a prerequisite for unifying DMA-mapping
implementation on ARM architecture with the common one provided by
dma_map_ops structure and extending it with IOMMU support. More
information is available in the following thread:
http://thread.gmane.org/gmane.linux.kernel.cross-arch/12819
More works on dma-mapping framework are planned, especially in the
area of buffer sharing and managing the shared mappings (together with
the recently introduced dma_buf interface: commit d15bd7ee445d
"dma-buf: Introduce dma buffer sharing mechanism").
The patches in the current set introduce a new alloc/free methods
(with support for memory attributes) in dma_map_ops structure, which
will later replace dma_alloc_coherent and dma_alloc_writecombine
functions."
People finally started piping up with support for merging this, so I'm
merging it as the last of the pending stuff from the merge window.
Looks like pohmelfs is going to wait for 3.5 and more external support
for merging.
* 'for-linus' of git://git.linaro.org/people/mszyprowski/linux-dma-mapping:
common: DMA-mapping: add NON-CONSISTENT attribute
common: DMA-mapping: add WRITE_COMBINE attribute
common: dma-mapping: introduce mmap method
common: dma-mapping: remove old alloc_coherent and free_coherent methods
Hexagon: adapt for dma_map_ops changes
Unicore32: adapt for dma_map_ops changes
Microblaze: adapt for dma_map_ops changes
SH: adapt for dma_map_ops changes
Alpha: adapt for dma_map_ops changes
SPARC: adapt for dma_map_ops changes
PowerPC: adapt for dma_map_ops changes
MIPS: adapt for dma_map_ops changes
X86 & IA64: adapt for dma_map_ops changes
common: dma-mapping: introduce generic alloc() and free() methods
Adapt core x86 and IA64 architecture code for dma_map_ops changes: replace
alloc/free_coherent with generic alloc/free methods.
Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com>
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
[removed swiotlb related changes and replaced it with wrappers,
merged with IA64 patch to avoid inter-patch dependences in intel-iommu code]
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Acked-by: Tony Luck <tony.luck@intel.com>
Pull more xen updates from Konrad Rzeszutek Wilk:
"One tiny feature that accidentally got lost in the initial git pull:
* Add fast-EOI acking of interrupts (clear a bit instead of
hypercall)
And bug-fixes:
* Fix CPU bring-up code missing a call to notify other subsystems.
* Fix reading /sys/hypervisor even if PVonHVM drivers are not loaded.
* In Xen ACPI processor driver: remove too verbose WARN messages, fix
up the Kconfig dependency to be a module by default, and add
dependency on CPU_FREQ.
* Disable CPU frequency drivers from loading when booting under Xen
(as we want the Xen ACPI processor to be used instead).
* Cleanups in tmem code."
* tag 'stable/for-linus-3.4-tag-two' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen/acpi: Fix Kconfig dependency on CPU_FREQ
xen: initialize platform-pci even if xen_emul_unplug=never
xen/smp: Fix bringup bug in AP code.
xen/acpi: Remove the WARN's as they just create noise.
xen/tmem: cleanup
xen: support pirq_eoi_map
xen/acpi-processor: Do not depend on CPU frequency scaling drivers.
xen/cpufreq: Disable the cpu frequency scaling drivers from loading.
provide disable_cpufreq() function to disable the API.
The functions: "acpi_processor_*" sound like they depend on CONFIG_ACPI_PROCESSOR
but in reality they are exposed when CONFIG_CPU_FREQ=[y|m]. As such
update the Kconfig to have this dependency and fix compile issues:
ERROR: "acpi_processor_unregister_performance" [drivers/xen/xen-acpi-processor.ko] undefined!
ERROR: "acpi_processor_notify_smm" [drivers/xen/xen-acpi-processor.ko] undefined!
ERROR: "acpi_processor_register_performance" [drivers/xen/xen-acpi-processor.ko] undefined!
ERROR: "acpi_processor_preregister_performance" [drivers/xen/xen-acpi-processor.ko] undefined!
Note: We still need the CONFIG_ACPI
Reported-by: Randy Dunlap <rdunlap@xenotime.net>
Pull xen updates from Konrad Rzeszutek Wilk:
"which has three neat features:
- PV multiconsole support, so that there can be hvc1, hvc2, etc; This
can be used in HVM and in PV mode.
- P-state and C-state power management driver that uploads said power
management data to the hypervisor. It also inhibits cpufreq
scaling drivers to load so that only the hypervisor can make power
management decisions - fixing a weird perf bug.
There is one thing in the Kconfig that you won't like: "default y
if (X86_ACPI_CPUFREQ = y || X86_POWERNOW_K8 = y)" (note, that it
all depends on CONFIG_XEN which depends on CONFIG_PARAVIRT which by
default is off). I've a fix to convert that boolean expression
into "default m" which I am going to post after the cpufreq git
pull - as the two patches to make this work depend on a fix in Dave
Jones's tree.
- Function Level Reset (FLR) support in the Xen PCI backend.
Fixes:
- Kconfig dependencies for Xen PV keyboard and video
- Compile warnings and constify fixes
- Change over to use percpu_xxx instead of this_cpu_xxx"
Fix up trivial conflicts in drivers/tty/hvc/hvc_xen.c due to changes to
a removed commit.
* tag 'stable/for-linus-3.4-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen kconfig: relax INPUT_XEN_KBDDEV_FRONTEND deps
xen/acpi-processor: C and P-state driver that uploads said data to hypervisor.
xen: constify all instances of "struct attribute_group"
xen/xenbus: ignore console/0
hvc_xen: introduce HVC_XEN_FRONTEND
hvc_xen: implement multiconsole support
hvc_xen: support PV on HVM consoles
xenbus: don't free other end details too early
xen/enlighten: Expose MWAIT and MWAIT_LEAF if hypervisor OKs it.
xen/setup/pm/acpi: Remove the call to boot_option_idle_override.
xenbus: address compiler warnings
xen: use this_cpu_xxx replace percpu_xxx funcs
xen/pciback: Support pci_reset_function, aka FLR or D3 support.
pci: Introduce __pci_reset_function_locked to be used when holding device_lock.
xen: Utilize the restore_msi_irqs hook.
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/mm
Pull cleancache changes from Konrad Rzeszutek Wilk:
"This has some patches for the cleancache API that should have been
submitted a _long_ time ago. They are basically cleanups:
- rename of flush to invalidate
- moving reporting of statistics into debugfs
- use __read_mostly as necessary.
Oh, and also the MAINTAINERS file change. The files (except the
MAINTAINERS file) have been in #linux-next for months now. The late
addition of MAINTAINERS file is a brain-fart on my side - didn't
realize I needed that just until I was typing this up - and I based
that patch on v3.3 - so the tree is on top of v3.3."
* tag 'stable/for-linus-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/mm:
MAINTAINERS: Adding cleancache API to the list.
mm: cleancache: Use __read_mostly as appropiate.
mm: cleancache: report statistics via debugfs instead of sysfs.
mm: zcache/tmem/cleancache: s/flush/invalidate/
mm: cleancache: s/flush/invalidate/
When xen_emul_unplug=never is specified on kernel command line
reading files from /sys/hypervisor is broken (returns -EBUSY).
It is caused by xen_bus dependency on platform-pci and
platform-pci isn't initialized when xen_emul_unplug=never is
specified.
Fix it by allowing platform-pci to ignore xen_emul_unplug=never,
and do not intialize xen_[blk|net]front instead.
Signed-off-by: Igor Mammedov <imammedo@redhat.com>
When booting the kernel under machines that do not have P-states
we would end up with:
WARNING: at drivers/xen/xen-acpi-processor.c:504
xen_acpi_processor_init+0x286/0
x2e0()
Hardware name: ProLiant BL460c G6
Modules linked in:
Pid: 1, comm: swapper Not tainted 2.6.39-200.0.3.el5uek #1
Call Trace:
[<ffffffff8191d056>] ? xen_acpi_processor_init+0x286/0x2e0
[<ffffffff81068300>] warn_slowpath_common+0x90/0xc0
[<ffffffff8191cdd0>] ? check_acpi_ids+0x1e0/0x1e0
[<ffffffff8106834a>] warn_slowpath_null+0x1a/0x20
[<ffffffff8191d056>] xen_acpi_processor_init+0x286/0x2e0
[<ffffffff81002168>] do_one_initcall+0xe8/0x130
.. snip..
Which is OK - the machines do not have P-states, so we fail to register
to process the _PXX states. But there is no need to WARN the user
of it.
Oracle BZ# 13871288
Use 'bool' for boolean variables. Do proper section placement.
Eliminate an unnecessary export.
Acked-by: Dan Magenheimer <dan.magenheimer@oracle.com>
The pirq_eoi_map is a bitmap offered by Xen to check which pirqs need to
be EOI'd without having to issue an hypercall every time.
We use PHYSDEVOP_pirq_eoi_gmfn_v2 to map the bitmap, then if we
succeed we use pirq_eoi_map to check whether pirqs need eoi.
Changes in v3:
- explicitly use PHYSDEVOP_pirq_eoi_gmfn_v2 rather than
PHYSDEVOP_pirq_eoi_gmfn;
- introduce pirq_check_eoi_map, a function to check if a pirq needs an
eoi using the map;
-rename pirq_needs_eoi into pirq_needs_eoi_flag;
- introduce a function pointer called pirq_needs_eoi that is going to be
set to the right implementation depending on the availability of
PHYSDEVOP_pirq_eoi_gmfn_v2.
With patch "xen/cpufreq: Disable the cpu frequency scaling drivers
from loading." we do not have to worry about said drivers loading
themselves before the xen-acpi-processor driver. Hence we can remove
the default selection (=y if CPU frequency drivers were built-in, or
=m if CPU frequency drivers were built as modules), and just
select =m for the default case.
* stable/cleancache.v13:
This driver solves three problems:
1). Parse and upload ACPI0007 (or PROCESSOR_TYPE) information to the
hypervisor - aka P-states (cpufreq data).
2). Upload the the Cx state information (cpuidle data).
3). Inhibit CPU frequency scaling drivers from loading.
The reason for wanting to solve 1) and 2) is such that the Xen hypervisor
is the only one that knows the CPU usage of different guests and can
make the proper decision of when to put CPUs and packages in proper states.
Unfortunately the hypervisor has no support to parse ACPI DSDT tables, hence it
needs help from the initial domain to provide this information. The reason
for 3) is that we do not want the initial domain to change P-states while the
hypervisor is doing it as well - it causes rather some funny cases of P-states
transitions.
For this to work, the driver parses the Power Management data and uploads said
information to the Xen hypervisor. It also calls acpi_processor_notify_smm()
to inhibit the other CPU frequency scaling drivers from being loaded.
Everything revolves around the 'struct acpi_processor' structure which
gets updated during the bootup cycle in different stages. At the startup, when
the ACPI parser starts, the C-state information is processed (processor_idle)
and saved in said structure as 'power' element. Later on, the CPU frequency
scaling driver (powernow-k8 or acpi_cpufreq), would call the the
acpi_processor_* (processor_perflib functions) to parse P-states information
and populate in the said structure the 'performance' element.
Since we do not want the CPU frequency scaling drivers from loading
we have to call the acpi_processor_* functions to parse the P-states and
call "acpi_processor_notify_smm" to stop them from loading.
There is also one oddity in this driver which is that under Xen, the
physical online CPU count can be different from the virtual online CPU count.
Meaning that the macros 'for_[online|possible]_cpu' would process only
up to virtual online CPU count. We on the other hand want to process
the full amount of physical CPUs. For that, the driver checks if the ACPI IDs
count is different from the APIC ID count - which can happen if the user
choose to use dom0_max_vcpu argument. In such a case a backup of the PM
structure is used and uploaded to the hypervisor.
[v1-v2: Initial RFC implementations that were posted]
[v3: Changed the name to passthru suggested by Pasi Kärkkäinen <pasik@iki.fi>]
[v4: Added vCPU != pCPU support - aka dom0_max_vcpus support]
[v5: Cleaned up the driver, fix bug under Athlon XP]
[v6: Changed the driver to a CPU frequency governor]
[v7: Jan Beulich <jbeulich@suse.com> suggestion to make it a cpufreq scaling driver
made me rework it as driver that inhibits cpufreq scaling driver]
[v8: Per Jan's review comments, fixed up the driver]
[v9: Allow to continue even if acpi_processor_preregister_perf.. fails]
The functions these get passed to have been taking pointers to const
since at least 2.6.16.
Unfortunately xend creates a bogus console/0 frotend/backend entry pair
on xenstore that console backends cannot properly cope with.
Any guest behavior that is not completely ignoring console/0 is going
to either cause problems with xenconsoled or qemu.
Returning 0 or -ENODEV from xencons_probe is not enough because it is
going to cause the frontend state to become 4 or 6 respectively.
The best possible thing we can do here is just ignore the entry from
xenbus_probe_frontend.
The individual drivers' remove functions could legitimately attempt to
access this information (for logging messages if nothing else). Note
that I did not in fact observe a problem anywhere, but I came across
this while looking into the reasons for what turned out to need the
fix at https://lkml.org/lkml/2012/3/5/336 to vsprintf().
* pm-sleep:
PM / Freezer: Remove references to TIF_FREEZE in comments
PM / Sleep: Add more wakeup source initialization routines
PM / Hibernate: Enable usermodehelpers in hibernate() error path
PM / Sleep: Make __pm_stay_awake() delete wakeup source timers
PM / Sleep: Fix race conditions related to wakeup source timer function
PM / Sleep: Fix possible infinite loop during wakeup source destruction
PM / Hibernate: print physical addresses consistently with other parts of kernel
PM: Add comment describing relationships between PM callbacks to pm.h
PM / Sleep: Drop suspend_stats_update()
PM / Sleep: Make enter_state() in kernel/power/suspend.c static
PM / Sleep: Unify kerneldoc comments in kernel/power/suspend.c
PM / Sleep: Remove unnecessary label from suspend_freeze_processes()
PM / Sleep: Do not check wakeup too often in try_to_freeze_tasks()
PM / Sleep: Initialize wakeup source locks in wakeup_source_add()
PM / Hibernate: Refactor and simplify freezer_test_done
PM / Hibernate: Thaw kernel threads in hibernation_snapshot() in error/test path
PM / Freezer / Docs: Document the beauty of freeze/thaw semantics
PM / Suspend: Avoid code duplication in suspend statistics update
PM / Sleep: Introduce generic callbacks for new device PM phases
PM / Sleep: Introduce "late suspend" and "early resume" of devices
- casting pointers to integer types of different size is being warned on
- an uninitialized variable warning occurred on certain gcc versions
So far only the watch path was checked to be zero terminated, while
the watch token was merely assumed to be.
.. as the rest of the kernel is using that format.
Suggested-by: Марк Коренберг <socketpair@gmail.com>
When the initial domain starts, it prints (depending on the
amount of CPUs) a slew of
XENBUS: Unable to read cpu state
which provide no useful information - as the error is a valid
issue - but not on the initial domain. The reason is that the
XenStore is not accessible at that time (it is after all the
first guest) so the CPU hotplug watch cannot parse "availability/cpu"
attribute.
The current device suspend/resume phases during system-wide power
transitions appear to be insufficient for some platforms that want
to use the same callback routines for saving device states and
related operations during runtime suspend/resume as well as during
system suspend/resume. In principle, they could point their
.suspend_noirq() and .resume_noirq() to the same callback routines
as their .runtime_suspend() and .runtime_resume(), respectively,
but at least some of them require device interrupts to be enabled
while the code in those routines is running.
It also makes sense to have device suspend-resume callbacks that will
be executed with runtime PM disabled and with device interrupts
enabled in case someone needs to run some special code in that
context during system-wide power transitions.
Apart from this, .suspend_noirq() and .resume_noirq() were introduced
as a workaround for drivers using shared interrupts and failing to
prevent their interrupt handlers from accessing suspended hardware.
It appears to be better not to use them for other porposes, or we may
have to deal with some serious confusion (which seems to be happening
already).
For the above reasons, introduce new device suspend/resume phases,
"late suspend" and "early resume" (and analogously for hibernation)
whose callback will be executed with runtime PM disabled and with
device interrupts enabled and whose callback pointers generally may
point to runtime suspend/resume routines.
Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Reviewed-by: Kevin Hilman <khilman@ti.com>
As proper scaffolding for supporting error status is not yet
implemented.
BUG: unable to handle kernel NULL pointer dereference at 0000000000000400
IP: [<ffffffff81375ae9>] gnttab_end_foreign_access_ref_v2+0x29/0x40
PGD 32aa3067 PUD 32a87067 PMD 0
Oops: 0000 [#1] PREEMPT SMP
CPU 0
Modules linked in: sg sr_mod cdrom ata_generic ata_piix libata scsi_mod xen_blkfront xen_netfront fb_sys_fops sysimgblt sysfillrect syscopyarea xen_kbdfront
cmd
Pid: 2307, comm: ip Not tainted 3.3.0-rc1 #1 Xen HVM domU
RIP: 0010:[<ffffffff81375ae9>] [<ffffffff81375ae9>] gnttab_end_foreign_access_ref_v2+0x29/0x40
RSP: 0018:ffff88003be03d38 EFLAGS: 00010206
RAX: 0000000000000000 RBX: ffff880033210640 RCX: 0000000000000040
RDX: 0000000000002000 RSI: 0000000000000000 RDI: 0000000000000200
RBP: ffff88003be03d38 R08: 0000000000000101 R09: 0000000000000000
R10: dead000000100100 R11: 0000000000000000 R12: ffff88003be03e48
R13: 0000000000000001 R14: ffff880039461c00 R15: 0000000000000200
FS: 00007fb1f84ec700(0000) GS:ffff88003be00000(0000) knlGS:0000000000000000
Complete the renaming from "flush" to "invalidate" across
both tmem frontends (cleancache and frontswap) and both tmem backends
(Xen and zcache), as required by akpm.
This change is completely cosmetic.
[v10: no change]
[v9: akpm@linux-foundation.org: change "flush" to "invalidate", part 3]
Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com>
Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Jan Beulich <JBeulich@novell.com>
Acked-by: Seth Jennings <sjenning@linux.vnet.ibm.com>
Cc: Nitin Gupta <ngupta@vflare.org>
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: Chris Mason <chris.mason@oracle.com>
Cc: Rik Riel <riel@redhat.com>
[v11: Remove the frontswap part]
Fix these warnings:
drivers/xen/biomerge.c:14:1: warning: data definition has no type or storage class [enabled by default]
drivers/xen/biomerge.c:14:1: warning: type defaults to 'int' in declaration of 'EXPORT_SYMBOL' [-Wimplicit-int]
drivers/xen/biomerge.c:14:1: warning: parameter names (without types) in function declaration [enabled by default]
And this build error:
ERROR: "xen_biovec_phys_mergeable" [drivers/block/nvme.ko] undefined!
* git://git.infradead.org/users/willy/linux-nvme: (105 commits)
NVMe: Set number of queues correctly
NVMe: Version 0.8
NVMe: Set queue flags correctly
NVMe: Simplify nvme_unmap_user_pages
NVMe: Mark the end of the sg list
NVMe: Fix DMA mapping for admin commands
NVMe: Rename IO_TIMEOUT to NVME_IO_TIMEOUT
NVMe: Merge the nvme_bio and nvme_prp data structures
NVMe: Change nvme_completion_fn to take a dev
NVMe: Change get_nvmeq to take a dev instead of a namespace
NVMe: Simplify completion handling
NVMe: Update Identify Controller data structure
NVMe: Implement doorbell stride capability
NVMe: Version 0.7
NVMe: Don't probe namespace 0
Fix calculation of number of pages in a PRP List
NVMe: Create nvme_identify and nvme_get_features functions
NVMe: Fix memory leak in nvme_dev_add()
NVMe: Fix calls to dma_unmap_sg
NVMe: Correct sg list setup in nvme_map_user_pages
* 'stable/for-linus-fixes-3.3' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen/balloon: Move the registration from device to subsystem.
module_param(bool) used to counter-intuitively take an int. In
fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy
trick.
It's time to remove the int/unsigned int option. For this version
it'll simply give a warning, but it'll break next kernel version.
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
We use the __pci_reset_function_locked to perform the action.
Also on attaching ("bind") and detaching ("unbind") we save and
restore the configuration states. When the device is disconnected
from a guest we use the "pci_reset_function" to also reset the
device before being passed to another guest.
With git commit 070680218379e15c1901f4bf21b98e3cbf12b527
"xen-balloon: convert sysdev_class to a regular subsystem" we would
end up with the attributes being put in:
/sys/devices/xen_memory0/target_kb
instead of
/sys/devices/system/xen_memory/xen_memory0/target_kb
Making the tools inable to deflate the kernel to make more space
for launching another guest and printing:
Error: Failed to query current memory allocation of dom0
Reported-by: Sander Eikelenboom <linux@eikelenboom.it>
Suggested-by: Kay Sievers <kay.sievers@vrfy.org>
* commit '070680218379e15c1901f4bf21b98e3cbf12b527': (50 commits)
clocksource: convert sysdev_class to a regular subsystem
ibm_rtl: convert sysdev_class to a regular subsystem
edac: convert sysdev_class to a regular subsystem
rtmutex-tester: convert sysdev_class to a regular subsystem
driver-core: implement 'sysdev' functionality for regular devices and buses
kref: fix up the kfree build problems
kref: Remove the memory barriers
kref: Implement kref_put in terms of kref_sub
kref: Inline all functions
Drivers: hv: Get rid of an unnecessary check in hv.c
Drivers: hv: Make the vmbus driver unloadable
Drivers: hv: Fix a memory leak
Documentation: Update stable address
MAINTAINERS: stable: Update address
w1: add fast search for single slave bus
driver-core: skip uevent generation when nobody is listening
drivers: hv: Don't OOPS when you cannot init vmbus
firmware: google: fix gsmi.c build warning
drivers_base: make argument to platform_device_register_full const
* 'drm-core-next' of git://people.freedesktop.org/~airlied/linux: (307 commits)
drm/nouveau/pm: fix build with HWMON off
gma500: silence gcc warnings in mid_get_vbt_data()
drm/ttm: fix condition (and vs or)
drm/radeon: double lock typo in radeon_vm_bo_rmv()
drm/radeon: use after free in radeon_vm_bo_add()
drm/sis|via: don't return stack garbage from free_mem ioctl
drm/radeon/kms: remove pointless CS flags priority struct
drm/radeon/kms: check if vm is supported in VA ioctl
drm: introduce drm_can_sleep and use in intel/radeon drivers. (v2)
radeon: Fix disabling PCI bus mastering on big endian hosts.
ttm: fix agp since ttm tt rework
agp: Fix multi-line warning message whitespace
drm/ttm/dma: Fix accounting error when calling ttm_mem_global_free_page and don't try to free freed pages.
drm/ttm/dma: Only call set_pages_array_wb when the page is not in WB pool.
drm/radeon/kms: sync across multiple rings when doing bo moves v3
drm/radeon/kms: Add support for multi-ring sync in CS ioctl (v2)
drm/radeon: GPU virtual memory support v22
drm: make DRM_UNLOCKED ioctls with their own mutex
drm: no need to hold global mutex for static data
drm/radeon/benchmark: common modes sweep ignores 640x480@32
Fix up trivial conflicts in radeon/evergreen.c and vmwgfx/vmwgfx_kms.c
* 'stable/for-linus-3.3' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: (37 commits)
xen/pciback: Expand the warning message to include domain id.
xen/pciback: Fix "device has been assigned to X domain!" warning
xen/pciback: Move the PCI_DEV_FLAGS_ASSIGNED ops to the "[un|]bind"
xen/xenbus: don't reimplement kvasprintf via a fixed size buffer
xenbus: maximum buffer size is XENSTORE_PAYLOAD_MAX
xen/xenbus: Reject replies with payload > XENSTORE_PAYLOAD_MAX.
Xen: consolidate and simplify struct xenbus_driver instantiation
xen-gntalloc: introduce missing kfree
xen/xenbus: Fix compile error - missing header for xen_initial_domain()
xen/netback: Enable netback on HVM guests
xen/grant-table: Support mappings required by blkback
xenbus: Use grant-table wrapper functions
xenbus: Support HVM backends
xen/xenbus-frontend: Fix compile error with randconfig
xen/xenbus-frontend: Make error message more clear
xen/privcmd: Remove unused support for arch specific privcmp mmap
xen: Add xenbus_backend device
xen: Add xenbus device driver
xen: Add privcmd device driver
xen/gntalloc: fix reference counts on multi-page mappings
