path: root/drivers/zorro
2018-05-30zorro: Set up z->dev.dma_mask for the DMA APIMichael Schmitz
[ Upstream commit 55496d3fe2acd1a365c43cbd613a20ecd4d74395 ] The generic DMA API uses dev->dma_mask to check the DMA addressable memory bitmask, and warns if no mask is set or even allocated. Set z->dev.dma_coherent_mask on Zorro bus scan, and make z->dev.dma_mask to point to z->dev.dma_coherent_mask so device drivers that need DMA have everything set up to avoid warnings from dma_alloc_coherent(). Drivers can still use dma_set_mask_and_coherent() to explicitly set their DMA bit mask. Signed-off-by: Michael Schmitz <schmitzmic@gmail.com> [geert: Handle Zorro II with 24-bit address space] Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-17zorro: stop creating attributes by handDmitry Torokhov
Instead of creating attributes one by one, define attribute_group array and attach it to bus->dev_groups, so that all needed attributes are created automatically when a new device is registered on the bus. Also switch to using standard DEVICE_ATTR_RO() macros. Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-24Replace <asm/uaccess.h> with <linux/uaccess.h> globallyLinus Torvalds
This was entirely automated, using the script by Al: PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>' sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \ $(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h) to do the replacement at the end of the merge window. Requested-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-25zorro: Use kobj_to_dev()Geliang Tang
Use kobj_to_dev() instead of open-coding it. Signed-off-by: Geliang Tang <geliangtang@163.com> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2014-10-20zorro: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-07-11zorro: Use ARRAY_SIZEHimangi Saraogi
ARRAY_SIZE is more concise to use when the size of an array is divided by the size of its type or the size of its first element. The Coccinelle semantic patch that makes this change is as follows: // <smpl> @@ type T; T[] E; @@ - (sizeof(E)/sizeof(T)) + ARRAY_SIZE(E) // </smpl> Signed-off-by: Himangi Saraogi <himangi774@gmail.com> [Geert: Also convert the MANUF definition] Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2013-11-26zorro/UAPI: Use proper types (endianness/size) in <linux/zorro.h>Geert Uytterhoeven
Fix member definitions for non-native userspace handling: - All multi-byte values are big-endian, hence use __be*, - All pointers are 32-bit pointers under AmigaOS, but unused (except for cd_BoardAddr) under Linux, hence use __be32. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2013-11-26zorro: Let the driver core handle device enumerationGeert Uytterhoeven
Filling in dev_name of the Zorro bus type and dev.id of each device allows the driver core to enumerate devices, so we don't have to do that ourselves. This changes the names of devices in sysfs from "%02x" to "zorro%u". Note that filling in dev.id is also needed to support MFD Zorro devices. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2013-11-26zorro: Refactor conditional handling of Zorro device name databaseGeert Uytterhoeven
Using an empty static inline function in the CONFIG_ZORRO_NAMES=n case allows to drop compilation of names.c. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2013-11-26zorro: Don't fill in dummy names in zorro_name_device()Geert Uytterhoeven
If the device is not found in the database, it's not needed to fill in a dummy name. The caller of zorro_name_device() has already taken care of that to support CONFIG_ZORRO_NAMES=n. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2013-11-26zorro: Do not allocate zorro_autocon[] staticallyGeert Uytterhoeven
Currently the array of Zorro devices is allocated statically, wasting up to 4.5 KiB when running an Amiga or multi-platform kernel on a machine with no or a handful of Zorro expansion cards. Convert it to conditional dynamic memory allocation to fix this. amiga_parse_bootinfo() still needs to store some information about the detected Zorro devices, at a time even the bootmem allocator is not yet available. This is now handled using a much smaller array (typically less than 0.5 KiB), which is __initdata and thus freed later. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2013-06-29zorro: switch to fixed_size_llseek()Al Viro
2013-05-01proc: Supply PDE attribute setting accessor functionsDavid Howells
Supply accessor functions to set attributes in proc_dir_entry structs. The following are supplied: proc_set_size() and proc_set_user(). Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> cc: linuxppc-dev@lists.ozlabs.org cc: linux-media@vger.kernel.org cc: netdev@vger.kernel.org cc: linux-wireless@vger.kernel.org cc: linux-pci@vger.kernel.org cc: netfilter-devel@vger.kernel.org cc: alsa-devel@alsa-project.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-09procfs: new helper - PDE_DATA(inode)Al Viro
The only part of proc_dir_entry the code outside of fs/proc really cares about is PDE(inode)->data. Provide a helper for that; static inline for now, eventually will be moved to fs/proc, along with the knowledge of struct proc_dir_entry layout. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-22new helper: file_inode(file)Al Viro
2013-01-03Drivers: zorro: remove CONFIG_HOTPLUG usageGreg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option, so remove it from the zorro-driver.c file. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-15zorro: Remove unused zorro_bus.devicesGeert Uytterhoeven
2012-01-02misc latin1 to utf8 conversionsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-10-31drivers/zorro: Add export.h to proc.cPaul Gortmaker
To fix what used to be the implicit presence of the macros EXPORT_SYMBOL and THIS_MODULE, via module.h being everywhere. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-24zorro: Fix four checkpatch warningsJim Rotmalm
zorro-driver.c: fix four checkpatch warnings of: WARNING: EXPORT_SYMBOL(foo); should immediately follow its function/variable I had a cat. The cat was mine. His name was Zorro. Amiga is fine. Signed-off-by: Jim Rotmalm <jim.rotmalm@gmail.com> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-09-22zorro: Defer device_register() until all devices have been identifiedGeert Uytterhoeven
As the Amiga Zorro II address space is limited to 8.5 MiB and Zorro devices can contain only one BAR, several Amiga Zorro II expansion boards (mainly graphics cards) contain multiple Zorro devices: a small one for the control registers and one (or more) for the graphics memory. The conversion of cirrusfb to the new driver framework introduced a regression: the driver contains a zorro_driver for the first Zorro device, and uses the (old) zorro_find_device() call to find the second Zorro device. However, as the Zorro core calls device_register() as soon as a Zorro device is identified, it may not have identified the second Zorro device belonging to the same physical Zorro expansion card. Hence cirrusfb could no longer find the second part of the Picasso II graphics card, causing a NULL pointer dereference. Defer the registration of Zorro devices with the driver framework until all Zorro devices have been identified to fix this. Note that the alternative solution (modifying cirrusfb to register a zorro_driver for all Zorro devices belonging to a graphics card, instead of only for the first one, and adding a synchronization mechanism to defer initialization until all have been found), is not an option, as on some cards one device may be optional (e.g. the second bank of 2 MiB of graphics memory on the Picasso IV in Zorro II mode). Reported-by: Ingo Jürgensmann <ij@2011.bluespice.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-17BKL: remove extraneous #include <smp_lock.h>Arnd Bergmann
The big kernel lock has been removed from all these files at some point, leaving only the #include. Remove this too as a cleanup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-22zorro: Fix device_register() error handlingVasiliy Kulikov
If device_register() fails then call put_device(). See comment to device_register. Signed-off-by: Vasiliy Kulikov <segooon@gmail.com> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2010-08-09zorro: Fix reading of proc/bus/zorro/* in small chunksGeert Uytterhoeven
proc_bus_zorro_read() didn't take into account the current file position, hence it always read from the start of the ConfigDev. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2010-08-09zorro: BKL removalGeert Uytterhoeven
Remove BKL use from proc_bus_zorro_lseek(), like was done for proc_bus_pci_lseek() a long time ago. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Arnd Bergmann <arnd@arndb.de>
2010-05-21sysfs: add struct file* to bin_attr callbacksChris Wright
This allows bin_attr->read,write,mmap callbacks to check file specific data (such as inode owner) as part of any privilege validation. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-17m68k: amiga - Zorro host bridge platform device conversionGeert Uytterhoeven
2010-05-17m68k: amiga - Zorro bus modalias supportGeert Uytterhoeven
Add Amiga Zorro bus modalias and uevent support Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2010-02-15tree-wide: fix typos "ass?o[sc]iac?te" -> "associate" in commentsUwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-06m68k: don't export static inline functionsStephen Rothwell
These now cause errors due to changes present in linux-next: (__ksymtab_sorted+0x1258): undefined reference to `dio_dev_driver' (__ksymtab_sorted+0x4d48): undefined reference to `zorro_dev_driver' Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2009-03-24zorro: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
2009-01-12m68k: zorro - Use %pR to print resourcesGeert Uytterhoeven
2009-01-12m68k: zorro - Kill warn_unused_result warningsGeert Uytterhoeven
warning: ignoring return value of 'device_register', declared with attribute warn_unused_result warning: ignoring return value of 'device_create_file', declared with attribute warn_unused_result Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2009-01-12m68k: zorro - Add devlist.h and gen-devlist to .gitignoreKars de Jong
drivers/zorro/.gitignore: Added devlist.h and gen-devlist to .gitignore file because they shouldn't be tracked. Signed-off-by: Kars de Jong <jongk@linux-m68k.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2008-07-24move memory_read_from_buffer() from fs.h to string.hAkinobu Mita
James Bottomley warns that inclusion of linux/fs.h in a low level driver was always a danger signal. This patch moves memory_read_from_buffer() from fs.h to string.h and fixes includes in existing memory_read_from_buffer() users. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: James Bottomley <James.Bottomley@hansenpartnership.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Bob Moore <robert.moore@intel.com> Cc: Thomas Renninger <trenn@suse.de> Cc: Len Brown <lenb@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-20zorro: use memory_read_from_bufferakinobu.mita@gmail.com
zorro: use memory_read_from_buffer Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-20ZORRO: Replace deprecated __initcall with equivalent device_initcall.Robert P. J. Day
ZORRO: Replace deprecated __initcall with equivalent device_initcall. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-20m68k: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29zorro: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Add correct ->owner to proc_fops to fix reading/module unloading race. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: switch /proc/bus/zorro/devices to seq_file interfaceAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Cc: Josef Sipek <jsipek@fsl.cs.sunysb.edu> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: remove proc_busAlexey Dobriyan
Remove proc_bus export and variable itself. Using pathnames works fine and is slightly more understandable and greppable. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-26Amiga zorro bus: Add missing zorro_device_remove()Geert Uytterhoeven
Amiga zorro bus: Add missing zorro_device_remove(). Without this ifconfig and /proc/net/dev oops after unloading a Zorro network device driver module. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Convert files to UTF-8 and some cleanupsJan Engelhardt
* Convert files to UTF-8. * Also correct some people's names (one example is Eißfeldt, which was found in a source file. Given that the author used an ß at all in a source file indicates that the real name has in fact a 'ß' and not an 'ss', which is commonly used as a substitute for 'ß' when limited to 7bit.) * Correct town names (Goettingen -> Göttingen) * Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313) Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-08-22zorro: Make sysfs config attribute read-onlyGeert Uytterhoeven
zorro: Make the sysfs `config' attribute read-only, as you cannot write to it (there's no .write function neither). Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-11sysfs: add parameter "struct bin_attribute *" in .read/.write methods for ↵Zhang Rui
sysfs binary attributes Well, first of all, I don't want to change so many files either. What I do: Adding a new parameter "struct bin_attribute *" in the .read/.write methods for the sysfs binary attributes. In fact, only the four lines change in fs/sysfs/bin.c and include/linux/sysfs.h do the real work. But I have to update all the files that use binary attributes to make them compatible with the new .read and .write methods. I'm not sure if I missed any. :( Why I do this: For a sysfs attribute, we can get a pointer pointing to the struct attribute in the .show/.store method, while we can't do this for the binary attributes. I don't know why this is different, but this does make it not so handy to use the binary attributes as the regular ones. So I think this patch is reasonable. :) Who benefits from it: The patch that exposes ACPI tables in sysfs requires such an improvement. All the table binary attributes share the same .read method. Parameter "struct bin_attribute *" is used to get the table signature and instance number which are used to distinguish different ACPI table binary attributes. Without this parameter, we need to offer different .read methods for different ACPI table binary attributes. This is impossible as there are various ACPI tables on different platforms, and we don't know what they are until they are loaded. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-11sysfs: kill unnecessary attribute->ownerTejun Heo
sysfs is now completely out of driver/module lifetime game. After deletion, a sysfs node doesn't access anything outside sysfs proper, so there's no reason to hold onto the attribute owners. Note that often the wrong modules were accounted for as owners leading to accessing removed modules. This patch kills now unnecessary attribute->owner. Note that with this change, userland holding a sysfs node does not prevent the backing module from being unloaded. For more info regarding lifetime rule cleanup, please read the following message. http://article.gmane.org/gmane.linux.kernel/510293 (tweaked by Greg to not delete the field just yet, to make it easier to merge things properly.) Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-04Amiga Zorro bus: kill resource_size_t warningsGeert Uytterhoeven
Kill resource_size_t warnings by casting resource_size_t to unsigned long when formatting Zorro bus resources, as they are always 32-bit. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct file_operations const 6Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] struct path: convert zorroJosef Sipek
