Signed-off-by: Russell Robinson Jr <rrobinson@phytec.com>
Signed-off-by: Serah Peterson <speterson@phytec.com>
This reverts commit 453d0753de3538f439083dfac4070bb682954e6e.
This commit caused issues with the serial driver.
Signed-off-by: Alison Wang <b18965@freescale.com>
ehci changes are currently only used with phyCORE-Vybrid (pcm052)
Allows the NAND to properly probe if cmdline partitioning
is not specified. Otherwise, it will fail silently.
From Singh Pradip-B09147. Integrate by Jason Jin
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
Add driver support for ADC Vybrid.
Signed-off-by: Wang Xiaojun <b41435@freescale.com>
Toggle PHYPWD.PWD after set PORTSC.SUSP with 8ms to trigger
the LS_SE0/LS_EOP append flag after resume within UTM block.
Signed-off-by: Jingchang Lu <b35083@freescale.com>
Handle usb suspend/resume, currently the BSP doesn't
support usb plug/unplug wakeup.
The ASRC driver supports stereo audio streams resample,
the ASRCK1 serial clock using audio external clock source
can not support 44.1K sample rate due to divider and
prescaler restriction.
Update power management part for DSPI driver.
Fix layers blending and reinitialization issue for DCU driver.
Update power management part for DCU driver.
Port the L2 switch driver from CF platform for Vybridi plaform.
This driver usually should work together with the RSTP demo
applications provided by fsl.
Add second FEC support for Vybrid.
Add watchdog driver support for Vybrid.
Add hardware flow control support,
Add transmit DMA support,
Add FIFO operation support,
Add MSB/LSB on data support,
Add 9-bits MARK/SPACE support.
Add Quad SPI driver support for Vybrid.
Xiaochun Li <b41219@freescale.com>
Add Compaq touch screen interface for nano-x.
Nano-x work with touch screen driver via Compaq touch
screen event format, this patch could add the support
above mouse device.
Add touch screen driver support for Vybird.
Update dspi driver support for Vybrid after debugging on board.
Signed-off-by: Jason Jin <jason.jin@freescale.com>
This patch enable the ADMA2 function for the SDHC module used
on Faraday board. Please note that the ADMA address should be 16
bytes aligned other than 4 byte in the spec.
This patch also increased the SDHC module frequency to 200MHz.
Only disable the high-speed device disconnection detction for
level-1 device, or the connection detecting would fail.
If framebuffer console support is enabled, blanking the screen will
occur after a long time. To avoid it, the option for disabling blanking
is added.
This patch is to update Edma driver after debugging on board.
mainly, fixed the bug that resulting the request source of DMA1 overflow
Signed-off-by: Xiaochun Li <b41219@freescale.com>
The call trace introduced by the card interrupt. This patch try to fix
this by disabling the card interrupt.
This patch is to tests eDMA driver.
a simple memory to memory transfer with a 32 bit
source and destination transfer size that generates
an interrupt when the transfer is complete.
Detection of high-speed USB device disconnection should be enable
on connection and disable on disconnection.
Add dspi driver support for Faraday.
Add dcu driver support for Faraday.
The penguin logo could be shown correctly and the microwindows
application was also tested.
Add NFC driver support for Faraday.
Add the I2C controller support for Faraday.
Enable the I2C0 for Faraday. There are some different with I.MX
for I2C controller, The i2c enable bit is invert with i.mx and the
interrupt clear is w1c on Faraday but w0c on i.mx
As there are more than one devices on the bus, the drive strength
is set to 50ohm, otherwise, some device can not be found.
Add EDMA driver support for MVF.
can use the "Always enable" model and DMA request sources
from DMA1.
Add esdhc controller support for MVF.
The wp_pin for esdhc should be disabled.
Add FEC driver support for MVF.
Update the phyid for micrel ksz8041 phy.
There are several version sz8041 with different phyid. Those id:
0x00221510, 0x00221512, 0x00221513 were found on different version
SER board. So change the mask to 0x00fffff0 to fit the different version.
Add basic UART and console support for MVF.
Update the fsl copyright of gpu kernel driver to 2012
Signed-off-by: Huang Loren <b02279@freescale.com>
Merge 4.6.5 p1 kernel part code.
Signed-off-by: Loren Huang <b02279@freescale.com>
Acked-by: Lily Zhang
- Do not call hcd core adjust wakeup flag code. It may change
wakeup flag, and cause port change detect(PCD) enable setting change.
- For ID wakeup, it should not call host's fsl_usb_recover_hcd at ID interrupt.
The coming ID switch event will resume host.
- Do not need enable wakeup interrupt for host at platform driver resume
routine, it may introduce unnessary wakeup interrupt during bus resume.
The wakeup will be enabled again when usb host goes to controller again
due to autosuspend.
- When there is no gadget enabled, the otg port is still at host mode with
interrupt enabled, so when male Micro-B to female A-type cable with
usb device plugs in, there will be PCD interrupt before hcd core leaves
suspend mode.
Signed-off-by: Peter Chen <peter.chen@freescale.com>
