patch 459ad68893a84fb0881e57919340b97edbbc3dc7 in mainline.
Spurious NCQ completion detection implemented in ahci was incorrect.
On AHCI receving and processing FISes and raising interrupts are not
interlocked and spurious interrupts are expected.
For example, if an interrupt occurs while interrupt handler is running
and the running interrupt handler handles the event the new IRQ
indicated, after IRQ handler finishes, it will be executed again
because IRQ pending bit is set by the new interrupt but there won't be
anything to process.
Please read the following message for more information.
http://article.gmane.org/gmane.linux.ide/26012
This patch...
* Removes all spurious IRQ whining from ahci. Spurious NCQ completion
detection was completely wrong. Spurious D2H Register FIS taught us
that some early drives send spurious D2H Register FIS with I bit set
while NCQ commands are in progress but none of recent drives does
that and even the ones which show such behavior can do NCQ fine.
* Kills all NCQ blacklist entries which were added because of spurious
NCQ completions. I tracked down each commit and verified all
removed ones are actually added because of spurious completions.
WD740ADFD-00NLR1 wasn't deleted but moved upward because the drive
not only had spurious NCQ completions but also is slow on sequential
data transfers if NCQ is enabled.
Maxtor 7V300F0 was added by 0e3dbc01d53940fe10e5a5cfec15ede3e929c918
from Alan Cox. I can only find evidences that the drive only had
troubles with spuruious completions by searching the mailing list.
This entry needs to be verified and removed if it doesn't have other
NCQ related problems.
Signed-off-by: Tejun Heo <htejun@gmail.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
[ATM]: [he] initialize lock and tasklet earlier
[ Upstream commit: 8a8037ac9dbe4eb20ce50aa20244faf77444f4a3 ]
if you are lucky (unlucky?) enough to have shared interrupts, the
interrupt handler can be called before the tasklet and lock are ready
for use.
Signed-off-by: chas williams <chas@cmf.nrl.navy.mil>
patch b64d70825abbf706bbe80be1b11b09514b71f45e in mainline.
The code in fb_ddc_read() is said to be based on the implementation of the
radeon driver:
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=fc5891c8a3ba284f13994d7bc1f1bfa8283982de
However, comparing the old radeon driver code with the new fb_ddc code
reveals some differences. Most notably, the I2C bus lines are held at the
end of the function, while the original code was releasing them (as the
comment above correctly says.)
There are a few other differences, which appear to be responsible for read
failures on my system. While tracing low-level I2C code in i2c-algo-bit, I
noticed that the initial attempt to read the EDID always failed. It takes
one retry for the read to succeed. As we are about to remove this
automatic retry property from i2c-algo-bit, reading the EDID would really
fail.
As a summary, the I2C lines quirk which is supposedly needed to read EDID
on some older monitors is currently breaking the (first) read on all other
monitors (and might not even work with older ones - did anyone try since
October 2006?)
After applying the patch below, which makes the code in fb_ddc_read()
really similar to what the radeon driver used to have, the first EDID read
succeeds again.
On top of that, as it appears that this code has been broken for one year
now and nobody seems to have complained, I'm curious if it makes sense to
keep this quirk in place. It makes the code more complex and slower just
for the sake of monitors which I guess nobody uses anymore. Can't we just
get rid of it?
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Tested-by: Roger Leigh <rleigh@whinlatter.ukfsn.org>
Tested-by: Michael Buesch <mb@bu3sch.de>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
patch 9e555930bd873d238f5f7b9d76d3bf31e6e3ce93 in mainline.
Fix a long boot delay in the forcedeth driver. During initialization, the
timeout for the handshake between mgmt unit and driver can be very long.
The patch reduces the timeout by eliminating a extra loop around the
timeout logic.
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=9308
Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com>
Cc: Alex Howells <astinus@gentoo.org>
patch 490dde8990c55662596a4be71b5070bd7d382d4a in mainline.
This patch adds new device ids and features for mcp79 devices into the
forcedeth driver.
index 92ce2e3..f9ba0ac 100644
patch eafe1aa37e6ec2d56f14732b5240c4dd09f0613a in mainline.
Fix possible memory overrun issue in the isdn ioctl code. Found by ADLAB
<adlab@venustech.com.cn>
Signed-off-by: Karsten Keil <kkeil@suse.de>
Cc: ADLAB <adlab@venustech.com.cn>
patch 0f13864e5b24d9cbe18d125d41bfa4b726a82e40 in mainline.
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=9416
patch 1cb52658b4f5b10a9e91f8e1c21ca2bcc1b9a3ca in mainline.
A recent patch added software synchronization during EHCI startup,
so ports aren't switched away from the companion controllers after
resets have started. This patch adds a short delay letting hardware
finish that port switching before any new resets begin ... so both
ends of that hardware race window are closed.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Cc: Dave Miller <davem@davemloft.net>
Cc: Dely Sy <dely.l.sy@intel.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
patch 5cf1973a44bd298e3cfce6f6af8faa8c9d0a6d55 in mainline
to make HAL like the microtek driver's devices the parent must be
correctly set.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
commit 5d0360ee96a5ef953dbea45873c2a8c87e77d59b upstream.
We have seen ramdisk based install systems, where some pages of mapped
libraries and programs were suddendly zeroed under memory pressure. This
should not happen, as the ramdisk avoids freeing its pages by keeping
them dirty all the time.
It turns out that there is a case, where the VM makes a ramdisk page
clean, without telling the ramdisk driver. On memory pressure
shrink_zone runs and it starts to run shrink_active_list. There is a
check for buffer_heads_over_limit, and if true, pagevec_strip is called.
pagevec_strip calls try_to_release_page. If the mapping has no
releasepage callback, try_to_free_buffers is called. try_to_free_buffers
has now a special logic for some file systems to make a dirty page
clean, if all buffers are clean. Thats what happened in our test case.
The simplest solution is to provide a noop-releasepage callback for the
ramdisk driver. This avoids try_to_free_buffers for ramdisk pages.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Acked-by: Nick Piggin <npiggin@suse.de>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
atl1: disable broken 64-bit DMA
[ Upstream commit: 5f08e46b621a769e52a9545a23ab1d5fb2aec1d4 ]
The L1 network chip can DMA to 64-bit addresses, but multiple descriptor
rings share a single register for the high 32 bits of their address, so
only a single, aligned, 4 GB physical address range can be used at a time.
As a result, we need to confine the driver to a 32-bit DMA mask, otherwise
we see occasional data corruption errors in systems containing 4 or more
gigabytes of RAM.
Signed-off-by: Luca Tettamanti <kronos.it@gmail.com>
Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net>
Acked-by: Chris Snook <csnook@redhat.com>
patch 8b925a3dd8a4d7451092cb9aa11da727ba69e0f0 in mainline.
Recent (i.e. 2005 and later) Sony Vaio laptops have names beginning
with VGN rather than PCG. Update the eeprom driver so that it
recognizes these.
Why this matters: the eeprom driver hides private data from the
EEPROMs it recognizes as Vaio EEPROMs (passwords, serial number...) so
if the driver fails to recognize a Vaio EEPROM as such, the private
data is exposed to the world.
patch 0f2cbd38aa377e30df3b7602abed69464d1970aa in mainline.
The sysfs interface to DMI data takes care to not make the system
serial number and UUID world-readable, presumably due to privacy
concerns. For consistency, we should not let the eeprom driver
export these same strings to the world on Sony Vaio laptops.
Instead, only make them readable by root, as we already do for BIOS
passwords.
patch be8a1f7cd4501c3b4b32543577a33aee6d2193ac in mainline.
Turns out we don't actually check the status to see if there was a
device out there to talk to, just if we had a timeout when doing so.
Add the proper check, so we don't falsly think there are devices
on the bus that are not there, etc.
patch 0c824b51b338c808de650b440ba5f9f4a725f7fc in mainline.
The patch described by the following excerpt from ChangeLog-2.6.22 makes
it impossible to use UDMA on a Tyan S2707 motherboard (SvrWks CSB5):
commit 2d5eaa6dd744a641e75503232a01f52d0768884c
Author: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Date: Thu May 10 00:01:08 2007 +0200
ide: rework the code for selecting the best DMA transfer mode (v3)
This one-line patch against 2.6.23 fixes the problem.
Signed-off-by: Tony Battersby <tonyb@cybernetics.com>
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
patch 9713d9e650045f7f2afd81d58a068827be306993 in mainline.
This fix the same issue which was debbuged for the C4 controller for the B1
versions.
The capilib_ function modify or traverse a linked list without locking.
This patch extends the existing locking to the calls of these function to
prevent access to a list which is in the middle of a modification.
patch 1ccfd63367c1a6aaf8b33943f18856dde85f2f0b in mainline.
The patch
- Includes the call to capilib_data_b3_req in the spinlock. This routine
in turn calls the offending mq_enqueue routine that triggered the
freeze if not locked. This should also fix other indicators of
incosistent capilib_msgidqueue list, that trigger messages like:
Oct 5 03:05:57 BERL0 kernel: kcapi: msgid 3019 ncci 0x30301 not on queue
that we saw several times a day (usually several in a row).
- Fixes all occurrences of c4_dispatch_tx to be called with active
spinlock, there were some instances where no lock was active. Mostly
these are in very infrequently called routines, so the additional
performance penalty is minimal.
Signed-off-by: Rainer Brestan <rainer.brestan@frequentis.com>
Signed-off-by: Ralf Schlatterbeck <rsc@runtux.com>
patch 32fe01985aa2cb2562f6fc171e526e279abe10db in mainline.
This patch (as999) fixes a problem that sometimes shows up when host
controller driver modules are loaded in the wrong order. If ehci-hcd
happens to initialize an EHCI controller while the companion OHCI or
UHCI controller is in the middle of a port reset, the reset can fail
and the companion may get very confused. The patch adds an
rw-semaphore and uses it to keep EHCI initialization and port resets
mutually exclusive.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Acked-by: David Brownell <david-b@pacbell.net>
Cc: Dely L Sy <dely.l.sy@intel.com>
patch acd2a847e7fee7df11817f67dba75a2802793e5d in mainline.
USB: usbserial - fix potential deadlock between write() and IRQ
usb_serial_generic_write() doesn't disable interrupts when taking port->lock,
and could therefore deadlock with usb_serial_generic_read_bulk_callback()
being called from interrupt, taking the same lock. Fix it.
Acked-by: Larry Finger <larry.finger@lwfinger.net>
Cc: Marcin Slusarz <marcin.slusarz@gmail.com>
Backport of a patch by Alan Cox <alan@lxorguk.ukuu.org.uk> in the kernel tree
with commit 94d0f7eac77a84da2cee41b8038796891f75f09e
Original comments:
USB: kobil_sct: Rework driver
No hardware but this driver is currently totally broken so we can't make
it much worse. Remove all tbe broken invalid termios handling and replace
it with a proper set_termios method.
Frank's comments:
Without this patch the userspace libct (to access the cardreader)
segfaults.
Signed-off-by: Frank Seidel <fseidel@suse.de>
patch 0fec02c93f60fb44ba3a24a0d3e4a52521d34d3f in mainline.
avoid buffer overflow when returning sense data.
With current adapter firmware the driver is working but future firmware
updates may return sense data larger than 96 bytes, causing overflow on
scp->sense_buffer and a kernel crash.
This fix should be backported to earlier kernels.
Signed-off-by: HighPoint Linux Team <linux@highpoint-tech.com>
Signed-off-by: James Bottomley <James.Bottomley@steeleye.com>
Acked-by: Matthew Wilcox <willy@linux.intel.com>
patch a7475906bc496456ded9e4b062f94067fb93057a in mainline.
pci_enable_msi() replaces the INTx irq number in pci_dev->irq with the
new MSI irq number.
The forcedeth driver did not update the copy in netdevice->irq and
parts of the driver used the stale copy.
See bugzilla.kernel.org, bug 9047.
The patch
- updates netdevice->irq
- replaces all accesses to netdevice->irq with pci_dev->irq.
The patch is against 2.6.23.1. IMHO suitable for both 2.6.23 and 2.6.24
Signed-off-by: Manfred Spraul <manfred@colorfullife.com>
patch fcac03abd325e4f7a4cc8fe05fea2793b1c8eb75 in mainline
Process persistent exception store metadata IOs in a separate thread.
A snapshot may become invalid while inside generic_make_request().
A synchronous write is then needed to update the metadata while still
inside that function. Since the introduction of
md-dm-reduce-stack-usage-with-stacked-block-devices.patch this has to
be performed by a separate thread to avoid deadlock.
Signed-off-by: Milan Broz <mbroz@redhat.com>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
Cc: Chuck Ebbert <cebbert@redhat.com>
Upstream as cbfb50e6e2e9c580848c0f51d37c24cdfb1cb704
Commit 9ead190b ("IB/uverbs: Don't serialize with ib_uverbs_idr_mutex")
rewrote how userspace objects are looked up in the uverbs module's
idrs, and introduced a severe bug in the process: there is no checking
that an operation is being performed by the right process any more.
Fix this by adding the missing check of uobj->context in __idr_get_uobj().
Apparently everyone is being very careful to only touch their own
objects, because this bug was introduced in June 2006 in 2.6.18, and
has gone undetected until now.
Signed-off-by: Roland Dreier <rolandd@cisco.com>
This is upstream as 54583bf4efda79388fc13163e35c016c8bc5de81
Oops...
Signed-off-by: Dave Airlie <airlied@linux.ie>
Already in Linus' tree:
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=d58df9cd788e6fb4962e1c8d5ba7b8b95d639a44
The bank switching code assumes that the bank selector is set to 0
when the driver is loaded. This might not be the case. This is exactly
the same bug as was fixed in the w83627ehf driver two months ago:
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commit;h=0956895aa6f8dc6a33210967252fd7787652537d
In practice, this bug was causing the sensor thermal types to be
improperly reported for my W83627THF the first time I was loading the
w83627hf driver. From the driver history, I'd say that it has been
broken since September 2005 (when we stopped resetting the chip by
default at driver load.)
Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=c09c5184a26158da32801e89d5849d774605f0dd
We need to read the fan clock dividers at initialization time,
otherwise the code in store_fan_min() may use uninitialized values.
That's pretty much the same bug and same fix as for the w83627ehf
driver last month.
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=889af3d5d9586db795a06c619e416b4baee11da8
A stupid bit shifting bug caused the VID value to be always exported
even when the hardware is configured for something different.
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=b965d4b7f614522170af6a7e450be0333792ccd2
Missing parentheses in the definition of FAN_FROM_REG cause a
division by zero for a specific register value.
Acked-by: Hans de Goede <j.w.r.degoede@hhs.nl>
Based on cb50f548c0ee9b2aac39743fc4021a7188825a98 in mainline
[PATCH] V4L: ivtv: fix udma yuv bug
Using udma yuv causes the driver to become locked into that mode. This
prevents use of the mpeg decoder & non-udma yuv output.
This patch clears the operating mode when the device is closed.
Signed-off-by: Ian Armstrong <ian@iarmst.demon.co.uk>
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
patch f662fe5a0b144efadbfc00e8040e603ec318746e in mainline.
dm9601: Fix receive MTU
dm9601 didn't take the ethernet header into account when calculating
RX MTU, causing packets bigger than 1486 to fail.
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
This episode illustrates how an overused warning can train people to
ignore that warning, which winds up hiding bugs.
The warning
drivers/net/natsemi.c: In function ‘natsemi_remove1’:
drivers/net/natsemi.c:3222: warning: ignoring return value of
‘device_create_file’, declared with attribute warn_unused_result
is oft-ignored, even though at close inspection one notices this occurs
in the /remove/ function, not normally where creation occurs. A quick
s/create/remove/ and we are fixed, with the warning gone.
Cc: Karsten Keil <kkeil@suse.de>
Fix panic in run_timer_softirq right after "modprobe -r firewire-ohci"
if a FireWire disk was attached and firewire-sbp2 loaded.
Same as commit 8a2d9ed3210464d22fccb9834970629c1c36fa36.
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
based on patch 8362cd413e8116306fafbaf414f0419db0595142 in mainline.
domain->header.len is le16 and has just been assigned
cpu_to_le16(arithmetical expression). And all fields of adapter->logmsg
are __le32; not a single 16-bit among them...
That's incremental to the previous one
Signed-off-by: Dan Williams <dcbw@redhat.com>
patch 5707708111ca6c4e9a1160acffdc98a98d95e462 in mainline.
wep->keytype[] is u8
changeset 162f6690a65075b49f242d3c8cdb5caaa959a060 in mainline.
TCP V4 sequence numbers are 32bits, and RFC 793 assumed a 250 KHz clock.
In order to follow network speed increase, we can use a faster clock, but
we should limit this clock so that the delay between two rollovers is
greater than MSL (TCP Maximum Segment Lifetime : 2 minutes)
Choosing a 64 nsec clock should be OK, since the rollovers occur every
274 seconds.
Problem spotted by Denys Fedoryshchenko
[ This bug was introduced by f85958151900f9d30fa5ff941b0ce71eaa45a7de ]
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
changeset ff4abd6cfacf0bb23a077f615d3a5cd17359db1b in mainline.
The ESP scsi driver does not initialize the host controller
instance early enough, so the messages in the log confuse
users.
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
changeset b04e7bdb984e3b7f62fb7f44146a529f88cc7639 from mainline.
device_suspend() calls ACPI suspend functions, which seems to have undesired
side effects on lower idle C-states. It took me some time to realize that
especially the VAIO BIOSes (both Andrews jinxed UP and my elfstruck SMP one)
show this effect. I'm quite sure that other bug reports against suspend/resume
about turning the system into a brick have the same root cause.
After fishing in the dark for quite some time, I realized that removing the ACPI
processor module before suspend (this removes the lower C-state functionality)
made the problem disappear. Interestingly enough the propability of having a
bricked box is influenced by various factors (interrupts, size of the ram image,
...). Even adding a bunch of printks in the wrong places made the problem go
away. The previous periodic tick implementation simply pampered over the
problem, which explains why the dyntick / clockevents changes made this more
prominent.
We avoid complex functionality during the boot process and we have to do the
same during suspend/resume. It is a similar scenario and equaly fragile.
Add suspend / resume functions to the ACPI processor code and disable the lower
idle C-states across suspend/resume. Fall back to the default idle
implementation (halt) instead.
Tested-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Len Brown <lenb@kernel.org>
Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
In Linus tree already:
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commit;h=939bc4943d0483961edc45b63a7d27b4ffe547e3
This fixes a bug in the way i2c-algo-bit handles I2C_M_RECV_LEN,
used to implement i2c_smbus_read_block_data(). Previously, in the
absence of PEC (rarely used!) it would NAK the "length" byte:
S addr Rd [A] [length] NA
That prevents the subsequent data bytes from being read:
S addr Rd [A] [length] { A [data] }* NA
The primary fix just reorders two code blocks, so the length used
in the "should I NAK now?" check incorporates the data which it
just read from the slave device.
However, that move also highlighted other fault handling glitches.
This fixes those by abstracting the RX path ack/nak logic, so it
can be used in more than one location.
commit 45dfd5b5dd20f17fe23dafc5cfe921474d27f849 from upstream
Signed-off-by: Michal Schmidt <mschmidt@redhat.com>
Update the libata drive blacklists to the latest in 2.6.23-rc8.
Signed-off-by: Chuck Ebbert <cebbert@redhat.com>
Cc: Jeff Garzik <jeff@garzik.org>
Already upstream.
After resume, driver has reset the chip so the current state
of transmit checksum offload state machine and DMA state machine
will be undefined.
The fix is to set the state so that first Tx will set MSS and offset
values.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
Already upstream.
The length check for truncated frames was not correctly handling
the case where VLAN acceleration had already read the tag.
Also, the Yukon EX has some features that use high bit of status
as security tag.
Signed-off-by: Pierre-Yves Ritschard <pyr@spootnik.org>
This is the 2.6.22 version of a regression fix that is already
in 2.6.23. Change the watchdog timer form 10 per second all the time,
to 1 per second and only if interface is up.
commit 2302827c95fe0f441025acd5133e532d2eef322b from upstream
Domain Validation in the SPI transport class is failing on boxes with
damaged cables (and failing to the extent that the box hangs). The
problem is that the first test it does is a cable integrity test for
wide transfers and if this fails, it turns the wide bit off. The
problem is that the next set of tests it does turns wide back on
again, with the result that it runs through the entirety of DV with a
known bad setting and then hangs the system.
The attached patch fixes the problem by physically nailing the wide
setting to what it deduces it should be for the whole of Domain
Validation.
port of 3f7086978fc0193eff24a77d8b57ac4debc088fa from mainline.
A crash upon booting that is caused by bcm43xx has been reported [1] and
found to be due to a work queue being reinitialized while work on that
queue is still pending. This fix modifies the shutdown of work queues and
prevents periodic work from being requeued during shutdown. With this patch,
no more crashes on reboot were observed by the original reporter. I do not
get that particular failure on my system; however, when running a large
number of ifdown/ifup sequences, my system would kernel panic with the
'caps lock' light blinking at roughly a 1 Hz rate. In addition, there were
infrequent failures in the firmware that resulted in 'IRQ READY TIMEOUT'
errors. With this patch, no more of the first type of failure occur, and
incidence of the second type is greatly reduced.
[1] http://bugzilla.kernel.org/show_bug.cgi?id=8937
Acked-by: Michael Buesch <mb@bu3sch.de>
commit ba685fb2abd71162bea6895a99449c1071b01402 in mainline.
As noticed by Chuck Ebbert, commit c5e3ae8823693b260ce1f217adca8add1bc0b3de
introduced a copy-paste typo, as realtek phy is 0x732 and not 0x1c1. Obvious
fix below suggested by Ayaz Abdulla.
Signed-off-by: Willy Tarreau <w@1wt.eu>
Cc: Ayaz Abdulla <aabdulla@nvidia.com>
Initialization of ohci1394 was broken according to one reporter if the
driver was statically linked, i.e. not built as loadable module. Dmesg:
PCI: Device 0000:02:07.0 not available because of resource collisions
ohci1394: Failed to enable OHCI hardware.
This was reported for a Toshiba Satellite 5100-503. The cause is commit
8df4083c5291b3647e0381d3c69ab2196f5dd3b7 in Linux 2.6.19-rc1 which only
served purposes of early remote debugging via FireWire. This
functionality is better provided by the currently out-of-tree driver
ohci1394_earlyinit. Reversal of the commit was OK'd by Andi Kleen.
Same as pre-2.6.23 commit be7963b7e7f08a149e247c0bf29a4abd174e0929.
regression)
Minor regression since 2.6.22-rc1: If the experimental firewire-ohci
driver instead of ohci1394 was loaded, iBook G3 and older PowerBooks
refused to suspend.
Same as commit 5511142870046a7bed947d51ec9b320856ee120a plus format
string touch-ups from 8a8cea2734808522f02941ea16125810ee42c9c7,
"firewire: missing newline in printk". Original patch description:
Fixes (papers over) "Sleep problems with kernels >= 2.6.21 on powerpc",
http://lkml.org/lkml/2007/8/25/155. The issue is that the FireWire
controller's pci_dev.current_state of iBook G3 and presumably older
PowerBooks is still in PCI_UNKNOWN instead of PCI_D0 when the firewire
driver's .suspend method is called.
Like it was suggested earlier in http://lkml.org/lkml/2006/10/24/13, we
do not fail .suspend anymore if pci_set_power_state failed.
commit 3558c9b3232b5f0fd9f32043a191eca20fca64c6 in mainline.
sparc32:
drivers/block/DAC960.c: In function 'DAC960_V1_EnableMemoryMailboxInterface':
drivers/block/DAC960.c:1168: error: 'DMA_32BIT_MASK' undeclared (first use in this function)
drivers/block/DAC960.c:1168: error: (Each undeclared identifier is reported only
Cc: <dac@conglom-o.org>
Cc: Alessandro Polverini <alex@nibbles.it>
Cc: Matthew Wilcox <matthew@wil.cx>
