commit 7c0411d2fabc2e2702c9871ffb603e251158b317 upstream.
We have that bug for years and some users report side effects when fixing it on older hardware.
So revert it for VM_CONTEXT0_PAGE_TABLE_END_ADDR, but keep it for VM 1-15.
Signed-off-by: Christian König <christian.koenig@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 607d48063512707a414e346972e2210dc71ab491 upstream.
The mapping range is inclusive between starting and ending addresses.
commit b9a5e5e18fbf223502c0b2264c15024e393da928 upstream.
Since acpi_reserve_resources() is defined as a device_initcall(),
there's no guarantee that it will be executed in the right order
with respect to the rest of the ACPI initialization code. On some
systems this leads to breakage if, for example, the address range
that should be reserved for the ACPI fixed registers is given to
the PCI host bridge instead if the race is won by the wrong code
path.
Fix this by turning acpi_reserve_resources() into a void function
and calling it directly from within the ACPI initialization sequence.
Reported-and-tested-by: George McCollister <george.mccollister@gmail.com>
Link: http://marc.info/?t=143092384600002&r=1&w=2
commit 74856fbf441929918c49ff262ace9835048e4e6a upstream.
256 bytes per sector support has been broken since 2.6.X,
and no-one stepped up to fix this.
So disable support for it.
Signed-off-by: Mark Hounschell <dmarkh@cfl.rr.com>
Signed-off-by: Hannes Reinecke <hare@suse.de>
Signed-off-by: James Bottomley <JBottomley@Odin.com>
commit dc45708ca9988656d706940df5fd102672c5de92 upstream.
Set the SRB flags correctly when there is no data transfer. Without this
change some IHV drivers will fail valid commands such as TEST_UNIT_READY.
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
Reviewed-by: Long Li <longli@microsoft.com>
commit 3c0213d17a09601e0c6c0ae0e27caf70d988290f upstream.
When the v3 hardware sees more than one finger, it uses the semi-mt
protocol to report the touches. However, it currently works when
num_fingers is 0, 1 or 2, but when it is 3 and above, it sends only 1
finger as if num_fingers was 1.
This confuses userspace which knows how to deal with extra fingers
when all the slots are used, but not when some are missing.
Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=90101
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
commit 414b7e3b9ce8b0577f613e656fdbc36b34b444dd upstream.
The USB mini-driver in rtlwifi, which is used by rtl8192cu, issues a call to
usb_control_msg() with a timeout value of 0. In some instances where the
interface is shutting down, this infinite wait results in a CPU deadlock. A
one second timeout fixes this problem without affecting any normal operations.
This bug is reported at https://bugzilla.novell.com/show_bug.cgi?id=927786.
Reported-by: Bernhard Wiedemann <bwiedemann@suse.com>
Tested-by: Bernhard Wiedemann <bwiedemann@suse.com>
Cc: Bernhard Wiedemann <bwiedemann@suse.com>
Cc: Takashi Iwai<tiwai@suse.com>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
commit a81157768a00e8cf8a7b43b5ea5cac931262374f upstream.
The variable "sector" in "raid0_make_request()" was improperly updated
by a call to "sector_div()" which modifies its first argument in place.
Commit 47d68979cc968535cb87f3e5f2e6a3533ea48fbd restored this variable
after the call for later re-use. Unfortunetly the restore was done after
the referenced variable "bio" was advanced. This lead to the original
value and the restored value being different. Here we move this line to
the proper place.
One observed side effect of this bug was discarding a file though
unlinking would cause an unrelated file's contents to be discarded.
Signed-off-by: NeilBrown <neilb@suse.de>
Fixes: 47d68979cc96 ("md/raid0: fix bug with chunksize not a power of 2.")
URL: https://bugzilla.kernel.org/show_bug.cgi?id=98501
commit 6e9eac2dcee5e19f125967dd2be3e36558c42fff upstream.
If any memory allocation in resize_stripes fails we will return
-ENOMEM, but in some cases we update conf->pool_size anyway.
This means that if we try again, the allocations will be assumed
to be larger than they are, and badness results.
So only update pool_size if there is no error.
This bug was introduced in 2.6.17 and the patch is suitable for
-stable.
Fixes: ad01c9e3752f ("[PATCH] md: Allow stripes to be expanded in preparation for expanding an array")
Commit 178c2490b99f898efc06d1ad75cadc84f13021a6 ("thermal: step_wise:
cdev only needs update on a new target state") broke driver acerhdf.
That driver abused the step_wise thermal governor until the bang_bang
governor was available, and the optimization broke this usage model.
Kernels v3.12 to v3.18 are affected. In v3.19 the acerhdf driver was
switched to the bang_bang governor and that solved the problem.
For kernels v3.12 to v3.17, the bang_bang governor isn't available
yet so the easiest fix is to revert the optimization.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Reported-by: Dieter Jurzitza (https://bugzilla.opensuse.org/show_bug.cgi?id=925961)
Tested-by: Peter Feuerer <peter@piie.net>
Tested-by: Dieter Jurzitza
commit f230e8ffc03f17bd9d6b90ea890b8252a8cc1821 upstream.
This patch fixes an inverted return value of the gpio get_direction
function.
The wrong value causes the direction sysfs entry and GPIO debugfs file
to indicate incorrect GPIO direction settings. In some cases it also
prevents setting GPIO output values.
The problem is also present in all other stable kernel versions since
linux-3.12.
Reported-by: Jochen Henneberg <jh@henneberg-systemdesign.com>
Signed-off-by: Michael Brunner <michael.brunner@kontron.com>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
commit ea345c145ff23197eab34d0c4d0c8a93d7bea8c6 upstream.
Add the USB Id to link the D-Link DWA 130 USB Wifi adapter
to the rt2830 driver.
Signed-off-by: Scott Branden <sbranden@broadcom.com>
Signed-off-by: Pieter Truter <ptruter@broadcom.com>
Cc: Larry Finger <Larry.Finger@lwfinger.net>
commit 09c5b4803a80a5451d950d6a539d2eb311dc0fb1 upstream.
When the LPM policy is set to ATA_LPM_MAX_POWER, the device might
generate a spurious PHY event that cuases errors on the link.
Ignore this event if it occured within 10s after the policy change.
The timeout was chosen observing that on a Dell XPS13 9333 these
spurious events can occur up to roughly 6s after the policy change.
Link: http://lkml.kernel.org/g/3352987.ugV1Ipy7Z5@xps13
Signed-off-by: Gabriele Mazzotta <gabriele.mzt@gmail.com>
commit 8393b811f38acdf7fd8da2028708edad3e68ce1f upstream.
This is a preparation commit that will allow to add other criteria
according to which PHY events should be dropped.
commit 8f9cfeed3eae86c70d3b04445a6f2036b27b6304 upstream.
when gsmtty_remove put dlci, it will cause memory leak if dlci->port's refcount is zero.
So we do the cleanup work in .cleanup callback instead.
dlci will be last put in two call chains.
1) gsmld_close -> gsm_cleanup_mux -> gsm_dlci_release -> dlci_put
2) gsmld_remove -> dlci_put
so there is a race. the memory leak depends on the race.
In call chain 2. we hit the memory leak. below comment tells.
release_tty -> tty_driver_remove_tty -> gsmtty_remove -> dlci_put -> tty_port_destructor (WARN_ON(port->itty) and return directly)
tty->port->itty = NULL;
tty_kref_put ---> release_one_tty -> gsmtty_cleanup (added by our patch)
So our patch fix the memory leak by doing the cleanup work after tty core did.
Signed-off-by: Pan Xinhui <xinhuix.pan@intel.com>
Fixes: dfabf7ffa30585
Acked-by: Jiri Slaby <jslaby@suse.cz>
commit 60c8f783a18feb95ad967c87e9660caf09fb4700 upstream.
clkdiv is declared as an u32 but it can be set to a negative value
causing a huge divisor value. Change its type to int to avoid this case.
Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
commit 903124fe1aa284f61745a9dd4fbfa0184e569fff upstream.
memset() to 0 interfaces array before reusing
usb_configuration structure.
This commit fix bug:
ln -s functions/acm.1 configs/c.1
ln -s functions/acm.2 configs/c.1
ln -s functions/acm.3 configs/c.1
echo "UDC name" > UDC
echo "" > UDC
rm configs/c.1/acm.*
rmdir functions/*
mkdir functions/ecm.usb0
ln -s functions/ecm.usb0 configs/c.1
[ 82.220969] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[ 82.229009] pgd = c0004000
[ 82.231698] [00000000] *pgd=00000000
[ 82.235260] Internal error: Oops: 17 [#1] PREEMPT SMP ARM
[ 82.240638] Modules linked in:
[ 82.243681] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.0.0-rc2 #39
[ 82.249926] Hardware name: SAMSUNG EXYNOS (Flattened Device Tree)
[ 82.256003] task: c07cd2f0 ti: c07c8000 task.ti: c07c8000
[ 82.261393] PC is at composite_setup+0xe3c/0x1674
[ 82.266073] LR is at composite_setup+0xf20/0x1674
[ 82.270760] pc : [<c03510d4>] lr : [<c03511b8>] psr: 600001d3
[ 82.270760] sp : c07c9df0 ip : c0806448 fp : ed8c9c9c
[ 82.282216] r10: 00000001 r9 : 00000000 r8 : edaae918
[ 82.287425] r7 : ed551cc0 r6 : 00007fff r5 : 00000000 r4 : ed799634
[ 82.293934] r3 : 00000003 r2 : 00010002 r1 : edaae918 r0 : 0000002e
[ 82.300446] Flags: nZCv IRQs off FIQs off Mode SVC_32 ISA ARM Segment kernel
[ 82.307910] Control: 10c5387d Table: 6bc1804a DAC: 00000015
[ 82.313638] Process swapper/0 (pid: 0, stack limit = 0xc07c8210)
[ 82.319627] Stack: (0xc07c9df0 to 0xc07ca000)
[ 82.323969] 9de0: 00000000 c06e65f4 00000000 c07c9f68
[ 82.332130] 9e00: 00000067 c07c59ac 000003f7 edaae918 ed8c9c98 ed799690 eca2f140 200001d3
[ 82.340289] 9e20: ee79a2d8 c07c9e88 c07c5304 ffff55db 00010002 edaae810 edaae860 eda96d50
[ 82.348448] 9e40: 00000009 ee264510 00000007 c07ca444 edaae860 c0340890 c0827a40 ffff55e0
[ 82.356607] 9e60: c0827a40 eda96e40 ee264510 edaae810 00000000 edaae860 00000007 c07ca444
[ 82.364766] 9e80: edaae860 c0354170 c03407dc c033db4c edaae810 00000000 00000000 00000010
[ 82.372925] 9ea0: 00000032 c0341670 00000000 00000000 00000001 eda96e00 00000000 00000000
[ 82.381084] 9ec0: 00000000 00000032 c0803a23 ee1aa840 00000001 c005d54c 249e2450 00000000
[ 82.389244] 9ee0: 200001d3 ee1aa840 ee1aa8a0 ed84f4c0 00000000 c07c9f68 00000067 c07c59ac
[ 82.397403] 9f00: 00000000 c005d688 ee1aa840 ee1aa8a0 c07db4b4 c006009c 00000032 00000000
[ 82.405562] 9f20: 00000001 c005ce20 c07c59ac c005cf34 f002000c c07ca780 c07c9f68 00000057
[ 82.413722] 9f40: f0020000 413fc090 00000001 c00086b4 c000f804 60000053 ffffffff c07c9f9c
[ 82.421880] 9f60: c0803a20 c0011fc0 00000000 00000000 c07c9fb8 c001bee0 c07ca4f0 c057004c
[ 82.430040] 9f80: c07ca4fc c0803a20 c0803a20 413fc090 00000001 00000000 01000000 c07c9fb0
[ 82.438199] 9fa0: c000f800 c000f804 60000053 ffffffff 00000000 c0050e70 c0803bc0 c0783bd8
[ 82.446358] 9fc0: ffffffff ffffffff c0783664 00000000 00000000 c07b13e8 00000000 c0803e54
[ 82.454517] 9fe0: c07ca480 c07b13e4 c07ce40c 4000406a 00000000 40008074 00000000 00000000
[ 82.462689] [<c03510d4>] (composite_setup) from [<c0340890>] (s3c_hsotg_complete_setup+0xb4/0x418)
[ 82.471626] [<c0340890>] (s3c_hsotg_complete_setup) from [<c0354170>] (usb_gadget_giveback_request+0xc/0x10)
[ 82.481429] [<c0354170>] (usb_gadget_giveback_request) from [<c033db4c>] (s3c_hsotg_complete_request+0xcc/0x12c)
[ 82.491583] [<c033db4c>] (s3c_hsotg_complete_request) from [<c0341670>] (s3c_hsotg_irq+0x4fc/0x558)
[ 82.500614] [<c0341670>] (s3c_hsotg_irq) from [<c005d54c>] (handle_irq_event_percpu+0x50/0x150)
[ 82.509291] [<c005d54c>] (handle_irq_event_percpu) from [<c005d688>] (handle_irq_event+0x3c/0x5c)
[ 82.518145] [<c005d688>] (handle_irq_event) from [<c006009c>] (handle_fasteoi_irq+0xd4/0x18c)
[ 82.526650] [<c006009c>] (handle_fasteoi_irq) from [<c005ce20>] (generic_handle_irq+0x20/0x30)
[ 82.535242] [<c005ce20>] (generic_handle_irq) from [<c005cf34>] (__handle_domain_irq+0x6c/0xdc)
[ 82.543923] [<c005cf34>] (__handle_domain_irq) from [<c00086b4>] (gic_handle_irq+0x2c/0x6c)
[ 82.552256] [<c00086b4>] (gic_handle_irq) from [<c0011fc0>] (__irq_svc+0x40/0x74)
[ 82.559716] Exception stack(0xc07c9f68 to 0xc07c9fb0)
[ 82.564753] 9f60: 00000000 00000000 c07c9fb8 c001bee0 c07ca4f0 c057004c
[ 82.572913] 9f80: c07ca4fc c0803a20 c0803a20 413fc090 00000001 00000000 01000000 c07c9fb0
[ 82.581069] 9fa0: c000f800 c000f804 60000053 ffffffff
[ 82.586113] [<c0011fc0>] (__irq_svc) from [<c000f804>] (arch_cpu_idle+0x30/0x3c)
[ 82.593491] [<c000f804>] (arch_cpu_idle) from [<c0050e70>] (cpu_startup_entry+0x128/0x1a4)
[ 82.601740] [<c0050e70>] (cpu_startup_entry) from [<c0783bd8>] (start_kernel+0x350/0x3bc)
[ 82.609890] Code: 0a000002 e3530005 05975010 15975008 (e5953000)
[ 82.615965] ---[ end trace f57d5f599a5f1bfa ]---
Most of kernel code assume that interface array in
struct usb_configuration is NULL terminated.
When gadget is composed with configfs configuration
structure may be reused for different functions set.
This bug happens because purge_configs_funcs() sets
only next_interface_id to 0. Interface array still
contains pointers to already freed interfaces. If in
second try we add less interfaces than earlier we
may access unallocated memory when trying to get
interface descriptors.
Signed-off-by: Krzysztof Opasiak <k.opasiak@samsung.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
commit 172115090f5e739660b97694618a2ba86457063a upstream.
Without this flag some versions of these enclosures do not work.
Reported-and-tested-by: Christian Schaller <cschalle@redhat.com>
commit c735ed74d83f8ecb45c4c4c95a16853c9c3c8157 upstream.
Added the USB serial console device ID for KCF Technologies PRN device
which has a USB port for its serial console.
Signed-off-by: Mark Edwards <sonofaforester@gmail.com>
Signed-off-by: Johan Hovold <johan@kernel.org>
commit 48ef23a4f686b1e4519d4193c20d26834ff810ff upstream.
This phone is already supported by the visor driver.
Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com>
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
commit 82ee3aeb9295c5fc37fd2ddf20f13ac2b40ec97d upstream.
Samsung has just released a portable USB3 SSD, coming in a very small
and nice form factor. It's USB ID is 04e8:8001, which unfortunately is
already used by the Palm Visor driver for the Samsung I330 phone cradle.
Having pl2303 or visor pick up this device ID results in conflicts with
the usb-storage driver, which handles the newly released portable USB3
SSD.
To work around this conflict, I've dug up a mailing list post [1] from a
long time ago, in which a user posts the full USB descriptor
information. The most specific value in this appears to be the interface
class, which has value 255 (0xff). Since usb-storage requires an
interface class of 0x8, I believe it's correct to disambiguate the two
devices by matching on 0xff inside visor.
[1] http://permalink.gmane.org/gmane.linux.usb.user/4264
commit 948fa13504f80b9765d2b753691ab94c83a10341 upstream.
If the xHCI host controller has died (ie, device removed) or suffered
other serious fatal error (STS_FATAL), then xhci_irq should handle this
condition with IRQ_HANDLED instead of -ESHUTDOWN.
Signed-off-by: Joe Lawrence <joe.lawrence@stratus.com>
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
commit 18cc2f4cbbaf825a4fedcf2d60fd388d291e0a38 upstream.
Our event ring consists of only one segment, and we risk filling
the event ring in case we get isoc transfers with short intervals
such as webcams that fill a TD every microframe (125us)
With 64 TRB segment size one usb camera could fill the event ring in 8ms.
A setup with several cameras and other devices can fill up the
event ring as it is shared between all devices.
This has occurred when uvcvideo queues 5 * 32TD URBs which then
get cancelled when the video mode changes. The cancelled URBs are returned
in the xhci interrupt context and blocks the interrupt handler from
handling the new events.
A full event ring will block xhci from scheduling traffic and affect all
devices conneted to the xhci, will see errors such as Missed Service
Intervals for isoc devices, and and Split transaction errors for LS/FS
interrupt devices.
Increasing the TRB_PER_SEGMENT will also increase the default endpoint ring
size, which is welcome as for most isoc transfer we had to dynamically
expand the endpoint ring anyway to be able to queue the 5 * 32TDs uvcvideo
queues.
The default size used to be 64 TRBs per segment
commit d104d0152a97fade389f47635b73a9ccc7295d0b upstream.
Isoc TDs usually consist of one TRB, sometimes two. When all goes well we
receive only one success event for a TD, and move the dequeue pointer to
the next TD.
This fails if the TD consists of two TRBs and we get a transfer error
on the first TRB, we will then see two events for that TD.
Fix this by making sure the event we get is for the last TRB in that TD
before moving the dequeue pointer to the next TD. This will resolve some
of the uvc and dvb issues with the
"ERROR Transfer event TRB DMA ptr not part of current TD" error message
commit 5a7125c64def3b21f8147eca8b54949a60963942 upstream.
See https://bugzilla.redhat.com/show_bug.cgi?id=1025672
We need to put() the reference to the scsi host that we got in
pscsi_configure_device(). In VIRTUAL_HOST mode it is associated with
the dev_virt, not the hba_virt.
Signed-off-by: Andy Grover <agrover@redhat.com>
commit 892c89d5d7ffd1bb794fe54d86c0eef18d215fab upstream.
Fix regression introduced by commit <29ef8a53542a>. After it writing
AT commands to /dev/GCT-ATM0 is unsuccessful (no echo, no response)
and dmesg show "gdmtty: invalid payload : 1 16 f011".
Before that commit value of dummy_cnt was only a padding size. After using
ALIGN() this value is increased by its first argument. So the following
usage of this variable needs correction.
Signed-off-by: Sławomir Demeszko <s.demeszko@wireless-instruments.com>
commit 1b63bf617206ff35b93c57c67bbe067ac735a85a upstream.
The following error message is seen when loading the nct6775 driver
with DEBUG_LOCK_ALLOC enabled.
BUG: key ffff88040b2f0030 not in .data!
WARNING: CPU: 0 PID: 186 at kernel/locking/lockdep.c:2988
lockdep_init_map+0x469/0x630()
DEBUG_LOCKS_WARN_ON(1)
Caused by a missing call to sysfs_attr_init() when initializing
sysfs attributes.
Reported-by: Alexey Orishko <alexey.orishko@gmail.com>
Reviewed-by: Jean Delvare <jdelvare@suse.de>
commit adba657533bdd255f7b78bc8a324091f46b294cd upstream.
When configured via device tree, the associated iio device needs to be
measuring voltage for the conversion to resistance to be correct.
Return -EINVAL if that is not the case.
Signed-off-by: Chris Lesiak <chris.lesiak@licor.com>
commit 77bb3dfdc0d554befad58fdefbc41be5bc3ed38a upstream.
A non-percpu VIRQ (e.g., VIRQ_CONSOLE) may be freed on a different
VCPU than it is bound to. This can result in a race between
handle_percpu_irq() and removing the action in __free_irq() because
handle_percpu_irq() does not take desc->lock. The interrupt handler
sees a NULL action and oopses.
Only use the percpu chip/handler for per-CPU VIRQs (like VIRQ_TIMER).
# cat /proc/interrupts | grep virq
40: 87246 0 xen-percpu-virq timer0
44: 0 0 xen-percpu-virq debug0
47: 0 20995 xen-percpu-virq timer1
51: 0 0 xen-percpu-virq debug1
69: 0 0 xen-dyn-virq xen-pcpu
74: 0 0 xen-dyn-virq mce
75: 29 0 xen-dyn-virq hvc_console
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
commit 83a35114d0e4583e6b0ca39502e68b6a92e2910c upstream.
This bug has been there since day 1; addresses in the top guest physical
page weren't considered valid. You could map that page (the check in
check_gpte() is correct), but if a guest tried to put a pagetable there
we'd check that address manually when walking it, and kill the guest.
commit 9493c2422cae272d6f1f567cbb424195defe4176 upstream.
Remove 2 redundant extern inline functions: qla8044_set_qsnt_ready() and
qla8044_need_reset_handler(). At present, within upstream next kernel
source code, they are only used within "drivers/scsi/qla2xxx/qla_nx2.c".
The related error and warnings (with allmodconfig under tile):
CC [M] drivers/scsi/qla2xxx/qla_nx2.o
drivers/scsi/qla2xxx/qla_nx2.c:1633:1: error: static declaration of 'qla8044_need_reset_handler' follows non-static declaration
qla8044_need_reset_handler(struct scsi_qla_host *vha)
In file included from drivers/scsi/qla2xxx/qla_def.h:3706:0,
from drivers/scsi/qla2xxx/qla_nx2.c:11:
drivers/scsi/qla2xxx/qla_gbl.h:756:20: note: previous declaration of 'qla8044_need_reset_handler' was here
extern inline void qla8044_need_reset_handler(struct scsi_qla_host *vha);
drivers/scsi/qla2xxx/qla_gbl.h:756:20: warning: inline function 'qla8044_need_reset_handler' declared but never defined
make[3]: *** [drivers/scsi/qla2xxx/qla_nx2.o] Error 1
make[2]: *** [drivers/scsi/qla2xxx] Error 2
make[1]: *** [drivers/scsi] Error 2
make: *** [drivers] Error 2
CC [M] drivers/scsi/qla2xxx/qla_tmpl.o
from drivers/scsi/qla2xxx/qla_tmpl.c:7:
drivers/scsi/qla2xxx/qla_gbl.h:755:20: warning: inline function 'qla8044_set_qsnt_ready' declared but never defined
extern inline void qla8044_set_qsnt_ready(struct scsi_qla_host *vha);
Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com>
Acked-by: Saurav Kashyap <saurav.kashyap@qlogic.com>
commit 62ec95f86d2850b7ce6d73fb236a6fcf48411aea upstream.
rtllib_probe_req is defined as "static inline" in rtllib_softmac.c however it
is declared differently as "extern inline" in rtllib_softmac.h. Since it isn't
used outside of the scope of rtllib_softmac, it makes sense to remove the
incorrect declaration.
Signed-off-by: Behan Webster <behanw@converseincode.com>
Suggested-by: Arnd Bergmann <arnd@arndb.de>
commit 0c9f3a65c5eb7fe1fc611a22eb8a8b71ea865998 upstream.
The rtl8712 driver has an 'extern inline' function that contains an
'if', which causes lots of warnings with CONFIG_PROFILE_ALL_BRANCHES
overriding the definition of 'if':
drivers/staging/rtl8712/ieee80211.h:759:229: warning: '______f' is static but declared in inline function 'ieee80211_get_hdrlen' which is not static [enabled by default]
This changes the driver to use 'static inline' instead, which happens
to be the correct annotation anyway.
Cc: Florian Schilhabel <florian.c.schilhabel@googlemail.com>
commit 6d91857d4826b382b3fd4fad95f52713be646f96 upstream.
With compilers which follow the C99 standard (like modern versions of gcc and
clang), "extern inline" does the opposite thing from older versions of gcc
(emits code for an externally linkable version of the inline function).
"static inline" does the intended behavior in all cases instead.
Patch not upstream as this driver is deleted there.
Fix up some "extern inline" functions as they break the build when using
a "modern" complier (i.e. gcc5).
commit 1d0a0b2f6df2bf2643fadc990eb143361eca6ada upstream.
ACPICA commit b60612373a4ef63b64a57c124576d7ddb6d8efb6
For physical addresses, since the address may exceed 32-bit address range
after calculation, we should use 0x%8.8X%8.8X instead of ACPI_PRINTF_UINT
and ACPI_FORMAT_UINT64() instead of
ACPI_FORMAT_NATIVE_UINT()/ACPI_FORMAT_TO_UINT().
This patch also removes above replaced macros as there are no users.
This is a preparation to switch acpi_physical_address to 64-bit on 32-bit
kernel builds.
Link: https://github.com/acpica/acpica/commit/b6061237
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
Signed-off-by: Bob Moore <robert.moore@intel.com>
Signed-off-by: Dirk Behme <dirk.behme@gmail.com>
Signed-off-by: George G. Davis <george_davis@mentor.com>
commit cc2080b0e5a7c6c33ef5e9ffccbc2b8f6f861393 upstream.
ACPICA commit 7f06739db43a85083a70371c14141008f20b2198
after calculation, we should use %8.8X%8.8X (see ACPI_FORMAT_UINT64()) to
convert the %p formats.
kernel builds.
Link: https://github.com/acpica/acpica/commit/7f06739d
[gdavis: Apply changes to drivers/acpi/acpica/{tbutils,tbxfload}.c]
ACPI_PHYSADDR_TO_PTR()/ACPI_PTR_TO_PHYSADDR().
commit 6d3fd3cc33d50e4c0d0c0bd172de02caaec3127c upstream.
ACPICA commit 154f6d074dd38d6ebc0467ad454454e6c5c9ecdf
There are code pieces converting pointers using "(acpi_physical_address) x"
or "ACPI_CAST_PTR (t, x)" formats, this patch cleans up them.
Known issues:
1. Cleanup of "(ACPI_PHYSICAL_ADDRRESS) x" for a table field
For the conversions around the table fields, it is better to fix it with
alignment also fixed. So this patch doesn't modify such code. There
should be no functional problem by leaving them unchanged.
Link: https://github.com/acpica/acpica/commit/154f6d07
commit f254e3c57b9d952e987502aefa0804c177dd2503 upstream.
ACPICA commit 7d9fd64397d7c38899d3dc497525f6e6b044e0e3
OSPMs like Linux expect an acpi_physical_address returning value from
acpi_find_root_pointer(). This triggers warnings if sizeof (acpi_size) doesn't
equal to sizeof (acpi_physical_address):
drivers/acpi/osl.c:275:3: warning: passing argument 1 of 'acpi_find_root_pointer' from incompatible pointer type [enabled by default]
In file included from include/acpi/acpi.h:64:0,
from include/linux/acpi.h:36,
from drivers/acpi/osl.c:41:
include/acpi/acpixf.h:433:1: note: expected 'acpi_size *' but argument is of type 'acpi_physical_address *'
This patch corrects acpi_find_root_pointer().
Link: https://github.com/acpica/acpica/commit/7d9fd643
commit bad4371d87d1d1ed1aecd9c9cc21c41ac3f289c8 upstream.
f9fd54f22e ("mmc: sh_mmcif: Use msecs_to_jiffies() for host->timeout")
changed the timeout value from 1000 jiffies to 1s. In the case where
HZ is 1000 the values are the same. However, for smaller HZ values the
timeout is now smaller, 1s instead of 10s in the case of HZ=100.
Since the timeout occurs in spite of a normal data transfer a timeout of
10s seems more appropriate. This restores the previous timeout in the
case where HZ=100 and results in an increase over the previous timeout
for larger values of HZ.
Fixes: f9fd54f22e ("mmc: sh_mmcif: Use msecs_to_jiffies() for host->timeout")
Signed-off-by: Takeshi Kihara <takeshi.kihara.df@renesas.com>
[horms: rewrote changelog to refer to HZ]
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Signed-off-by: Yoshihiro Kaneko <ykaneko0929@gmail.com>
commit 184af16b09360d6273fd6160e6ff7f8e2482ef23 upstream.
The PM_RESTORE_PREPARE is not handled now in mmc_pm_notify(),
as result mmc_rescan() could be scheduled and executed at
late hibernation restore stages when MMC device is suspended
already - which, in turn, will lead to system crash on TI dra7-evm board:
WARNING: CPU: 0 PID: 3188 at drivers/bus/omap_l3_noc.c:148 l3_interrupt_handler+0x258/0x374()
44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER1_P3 (Idle): Data Access in User mode during Functional access
Hence, add missed PM_RESTORE_PREPARE PM event in mmc_pm_notify().
Fixes: 4c2ef25fe0b8 (mmc: fix all hangs related to mmc/sd card...)
Signed-off-by: Grygorii Strashko <Grygorii.Strashko@linaro.org>
commit 4e93b9a6abc0d028daf3c8a00cb77b679d8a4df4 upstream.
During kernel boot, it will try to read some logical sectors
of each block device node for the possible partition table.
But since RPMB partition is special and can not be accessed
by normal eMMC read / write CMDs, it will cause below error
messages during kernel boot:
mmc0: Got data interrupt 0x00000002 even though no data operation was in progress.
mmcblk0rpmb: error -110 transferring data, sector 0, nr 32, cmd response 0x900, card status 0xb00
mmcblk0rpmb: retrying using single block read
mmcblk0rpmb: timed out sending r/w cmd command, card status 0x400900
end_request: I/O error, dev mmcblk0rpmb, sector 0
Buffer I/O error on device mmcblk0rpmb, logical block 0
end_request: I/O error, dev mmcblk0rpmb, sector 8
Buffer I/O error on device mmcblk0rpmb, logical block 1
end_request: I/O error, dev mmcblk0rpmb, sector 16
Buffer I/O error on device mmcblk0rpmb, logical block 2
end_request: I/O error, dev mmcblk0rpmb, sector 24
Buffer I/O error on device mmcblk0rpmb, logical block 3
This patch will discard the access request in eMMC queue if
it is RPMB partition access request. By this way, it avoids
trigger above error messages.
Fixes: 090d25fe224c ("mmc: core: Expose access to RPMB partition")
Signed-off-by: Yunpeng Gao <yunpeng.gao@intel.com>
Signed-off-by: Chuanxiao Dong <chuanxiao.dong@intel.com>
Tested-by: Michael Shigorin <mike@altlinux.org>
commit c5272a28566b00cce79127ad382406e0a8650690 upstream.
Way back, when the world was a simpler place and there was no war, no
evil, and no kernel bugs, there was just a single pinctrl lock. That
was how the world was when (57291ce pinctrl: core device tree mapping
table parsing support) was written. In that case, there were
instances where the pinctrl mutex was already held when
pinctrl_register_map() was called, hence a "locked" parameter was
passed to the function to indicate that the mutex was already locked
(so we shouldn't lock it again).
A few years ago in (42fed7b pinctrl: move subsystem mutex to
pinctrl_dev struct), we switched to a separate pinctrl_maps_mutex.
...but (oops) we forgot to re-think about the whole "locked" parameter
for pinctrl_register_map(). Basically the "locked" parameter appears
to still refer to whether the bigger pinctrl_dev mutex is locked, but
we're using it to skip locks of our (now separate) pinctrl_maps_mutex.
That's kind of a bad thing(TM). Probably nobody noticed because most
of the calls to pinctrl_register_map happen at boot time and we've got
synchronous device probing. ...and even cases where we're
asynchronous don't end up actually hitting the race too often. ...but
after banging my head against the wall for a bug that reproduced 1 out
of 1000 reboots and lots of looking through kgdb, I finally noticed
this.
Anyway, we can now safely remove the "locked" parameter and go back to
a war-free, evil-free, and kernel-bug-free world.
Fixes: 42fed7ba44e4 ("pinctrl: move subsystem mutex to pinctrl_dev struct")
Signed-off-by: Doug Anderson <dianders@chromium.org>
commit d52cdfa4a0c6406bbfb33206341eaf1fb1555994 upstream.
MPEG 2/4 are only supported since UVD3.
commit a1b403da70e038ca6c6c6fe434d1d873546873a3 upstream.
Invalid messages can crash the hw otherwise.
commit 013ead48a843442e63b9426e3bd5df18ca5d054a upstream.
Hardware doesn't seem to work correctly, just block userspace in this case.
v2: add missing defines
Bugs: https://bugs.freedesktop.org/show_bug.cgi?id=85320
commit 3916e3fd81021fb795bfbdb17f375b6b3685bced upstream.
Single channel LVDS maxes out at 112 MHz. The 15" pre-retina models
shipped with 1440x900 (106 MHz) by default or 1680x1050 (119 MHz)
as a BTO option, both versions used dual channel LVDS even though
the smaller one would have fit into a single channel.
Notes:
Bug report showing that the MacBookPro8,2 with 1440x900 uses dual
channel LVDS (this lead to it being hardcoded in intel_lvds.c by
Daniel Vetter with commit 618563e3945b9d0864154bab3c607865b557cecc):
https://bugzilla.kernel.org/show_bug.cgi?id=42842
If i915.lvds_channel_mode=2 is missing even though the machine needs
it, every other vertical line is white and consequently, only the left
half of the screen is visible (verified by myself on a MacBookPro9,1).
Forum posting concerning a MacBookPro6,2 with 1440x900, author is
using i915.lvds_channel_mode=2 on the kernel command line, proving
that the machine uses dual channels:
https://bbs.archlinux.org/viewtopic.php?id=185770
Chi Mei N154C6-L04 with 1440x900 is a replacement panel for all
MacBook Pro "A1286" models, and that model number encompasses the
MacBookPro6,2 / 8,2 / 9,1. Page 17 of the panel's datasheet shows it's
driven with dual channel LVDS:
http://www.ebay.com/itm/-/400690878560
http://www.everymac.com/ultimate-mac-lookup/?search_keywords=A1286
http://www.taopanel.com/chimei/datasheet/N154C6-L04.pdf
Those three 15" models, MacBookPro6,2 / 8,2 / 9,1, are the only ones
with i915 graphics and dual channel LVDS, so that list should be
complete. And the 8,2 is already in intel_lvds.c.
Possible motivation to use dual channel LVDS even on the 1440x900
models: Reduce the number of different parts, i.e. use identical logic
boards and display cabling on both versions and the only differing
component is the panel.
Signed-off-by: Lukas Wunner <lukas@wunner.de>
Acked-by: Jani Nikula <jani.nikula@intel.com>
[Jani: included notes in the commit message for posterity]
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
commit c0403ec0bb5a8c5b267fb7e16021bec0b17e4964 upstream.
This reverts Linux 4.1-rc1 commit 0618764cb25f6fa9fb31152995de42a8a0496475.
The problem which that commit attempts to fix actually lies in the
Freescale CAAM crypto driver not dm-crypt.
dm-crypt uses CRYPTO_TFM_REQ_MAY_BACKLOG. This means the the crypto
driver should internally backlog requests which arrive when the queue is
full and process them later. Until the crypto hw's queue becomes full,
the driver returns -EINPROGRESS. When the crypto hw's queue if full,
the driver returns -EBUSY, and if CRYPTO_TFM_REQ_MAY_BACKLOG is set, is
expected to backlog the request and process it when the hardware has
queue space. At the point when the driver takes the request from the
backlog and starts processing it, it calls the completion function with
a status of -EINPROGRESS. The completion function is called (for a
second time, in the case of backlogged requests) with a status/err of 0
when a request is done.
Crypto drivers for hardware without hardware queueing use the helpers,
crypto_init_queue(), crypto_enqueue_request(), crypto_dequeue_request()
and crypto_get_backlog() helpers to implement this behaviour correctly,
while others implement this behaviour without these helpers (ccp, for
example).
dm-crypt (before the patch that needs reverting) uses this API
correctly. It queues up as many requests as the hw queues will allow
(i.e. as long as it gets back -EINPROGRESS from the request function).
Then, when it sees at least one backlogged request (gets -EBUSY), it
waits till that backlogged request is handled (completion gets called
with -EINPROGRESS), and then continues. The references to
af_alg_wait_for_completion() and af_alg_complete() in that commit's
commit message are irrelevant because those functions only handle one
request at a time, unlink dm-crypt.
The problem is that the Freescale CAAM driver, which that commit
describes as having being tested with, fails to implement the
backlogging behaviour correctly. In cam_jr_enqueue(), if the hardware
queue is full, it simply returns -EBUSY without backlogging the request.
What the observed deadlock was is not described in the commit message
but it is obviously the wait_for_completion() in crypto_convert() where
dm-crypto would wait for the completion being called with -EINPROGRESS
in the case of backlogged requests. This completion will never be
completed due to the bug in the CAAM driver.
Commit 0618764cb25 incorrectly made dm-crypt wait for every request,
even when the driver/hardware queues are not full, which means that
dm-crypt will never see -EBUSY. This means that that commit will cause
a performance regression on all crypto drivers which implement the API
correctly.
Revert it. Correct backlog handling should be implemented in the CAAM
driver instead.
Cc'ing stable purely because commit 0618764cb25 did. If for some reason
a stable@ kernel did pick up commit 0618764cb25 it should get reverted.
Signed-off-by: Rabin Vincent <rabin.vincent@axis.com>
Reviewed-by: Horia Geanta <horia.geanta@freescale.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
__startup_pirq()
commit 16e6bd5970c88a2ac018b84a5f1dd5c2ff1fdf2c upstream.
.. because bind_evtchn_to_cpu(evtchn, cpu) will map evtchn to
'info' and pass 'info' down to xen_evtchn_port_bind_to_cpu().
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Tested-by: Annie Li <annie.li@oracle.com>
commit b9d934f27c91b878c4b2e64299d6e419a4022f8d upstream.
After a resume the hypervisor/tools may change console event
channel number. We should re-query it.
