Allow in-place crypto operations. Also remove the coherent user flag
(we use it automagically now), and by default use the user written
key rather then the HW hidden key - this makes crypto just work without
any special considerations, and thats OK, since its our only usage
model.
Signed-off-by: Jordan Crouse <jordan.crouse@amd.com>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
hiddev_release()
USB HID: hiddev - fix race between hiddev_send_event() and hiddev_release()
There is a small race window in which hiddev_release() could corrupt the
list that is being processed for new event in hiddev_send_event().
Synchronize the operations over this list.
If the device fails during module startup for some reason like unsupported chip
version then the driver would crash dereferencing a null pointer, on shutdown
or suspend/resume.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
If device fails during module startup for some reason (like unsupported chip
version) then driver would crash dereferencing a null pointer, on shutdown
or suspend/resume.
The driver is not ready to support 88e8071 chip, it requires several
more changes (not done yet). If this chip is present, system will hang on boot.
It looks like the problems of Gigabyte 88E8056 are unique to that chip
motherboard and maybe fixable by EEPROM update.
The 'compatible' property can be SUNW,sun4v-console as
well as 'qcn'.
Fix a rather obvious error that Patrick found in the setup routines. Need to
set the proper address space in the ACPI case.
Signed-off-by: Corey Minyard <minyard@acm.org>
Cc: Patrick Schoeller <Patrick.Schoeller@hp.com>
connected to mptspi driver
Patch for: http://bugzilla.kernel.org/show_bug.cgi?id=8426
A recent code cleanup that moved code from mptscsih to mptspi inadvertently
change the order some code was called. This caused a massive slowdown (of
150x to 300x) on the CD/DVD drive on the high-end HP Integrity servers.
Signed-off-by: Doug Chapman <doug.chapman@hp.com>
Cc: <Eric.Moore@lsil.com>
Cc: James Bottomley <James.Bottomley@steeleye.com>
MSI doesn't work on RS400-200 and RS480 requiring pci=nomsi kernel boot
parameter for ahci to work. This patch renames quirk_svw_msi() to
quirk_disable_all_msi() and use it to disable MSI on those chips.
http://thread.gmane.org/gmane.linux.ide/17820
http://thread.gmane.org/gmane.linux.ide/17516
https://bugzilla.novell.com/show_bug.cgi?id=263893
Signed-off-by: Tejun Heo <htejun@gmail.com>
Cc: Matí-as Alejandro Torres <torresmat@gmail.com>
Cc: Greg K-H <greg@kroah.com>
Cc: Jeff Garzik <jeff@garzik.org>
Currently, devt_attr for the "dev" file is freed immediately on device
removal, but if the "dev" sysfs file is open when a device is removed,
sysfs will access its attribute structure for further access including
close resulting in jumping to garbled address. Fix it by postponing
freeing devt_attr to device release time.
Note that devt_attr for class_device is already freed on release.
This bug is reported by Chris Rankin as bugzilla bug#8198.
Cc: Chris Rankin <rankincj@yahoo.com>
through md/raid1 to a filesystem.
When a raid1 has only one working drive, we want read error to
propagate up to the filesystem as there is no point failing the last
drive in an array.
Currently the code perform this check is racy. If a write and a read
a both submitted to a device on a 2-drive raid1, and the write fails
followed by the read failing, the read will see that there is only one
working drive and will pass the failure up, even though the one
working drive is actually the *other* one.
So, tighten up the locking.
Signed-off-by: Neil Brown <neilb@suse.de>
Get rid of the CONFIG_NETPOLL_RX option completely since all the
dependencies have been removed long ago...
Acked-by: Jeff Garzik <jgarzik@pobox.com>
Acked-by: Matt Mackall <mpm@selenic.com>
Update version to 1.5.8.1.
Signed-off-by: Michael Chan <mchan@broadcom.com>
This is needed to save the MSI state which will be lost during
suspend.
The device may be in D3hot state and should not allow MII register
access.
Remove the check for skb->len greater than MTU when doing TSO. When
the destination has a smaller MSS than the source, a TSO packet may
be smaller than the MTU at the source and we still need to process it
as a TSO packet.
Thanks to Brian Ristuccia <bristuccia@starentnetworks.com> for
reporting the problem.
Update version to 3.75.1.
The reset was added a while back so that ASF could re-init whatever
MAC address it wanted to use after the MAC address was changed.
Instead of resetting, we can just keep MAC address 1 unchanged during
MAC address changes if MAC address 1 is different from MAC address 0.
This fixes 2 problems:
1. Bonding calls set_mac_address in contexts that cannot sleep.
It no longer sleeps with the chip reset removed.
2. When ASF shares the same MAC address as the NIC, it needs to
always do that even when the MAC address is changed.
1. Remove the check for skb->len greater than MTU when doing TSO.
When the destination has a smaller MSS than the source, a TSO packet
may be smaller than the MTU and we still need to process it as a TSO
packet.
2. On 5705A3 devices with TSO enabled, the DMA engine can hang due to a
hardware bug. This patch avoids the hanging condition by reducing the
DMA burst size.
Signed-off-by: Matt Carlson <mcarlson@broadcom.com>
Wake On Lan works correctly on Yukon-FE and other variants.
By default, the skge driver now enables wake on magic and wake on PHY.
This is a bad default (bug), wake on PHY means machine will never shutdown
if connected to a switch.
For some reason, sata_via is missing PM hooks. Add them. Spotted by
Jeroen Janssen <jeroen.janssen@gmail.com>.
Cc: Jeroen Janssen <jeroen.janssen@gmail.com>
If you have a controller with one channel disabled and unmapped the new
iomap code blindly tries to iomap unconfigured BARs. Later on the code
does the right thing and checks for unmapped bars but it is done in the
wrong order
Reorder the checks and make the iomap conditional
Tejun: I think the code below is now correct but would appreciate you
giving it a review.
Signed-off-by: Alan Cox <alan@redhat.com>
Acked-by: Tejun Heo <htejun@gmail.com>
As part of the device initialisation cxacru_atm_start starts
a rearming status polling task, which is cancelled in
cxacru_unbind. Failure to ever start the task means an
infinite loop occurs trying to cancel it.
Possible reasons for not starting the polling task:
* Firmware files missing
* Device initialisation fails
* User unplugs device or unloads module
Effect:
* Infinite loop in khubd trying to add/remove the device (or rmmod if timed right)
Signed-off-by: Simon Arlott <simon@fire.lp0.eu>
Up through 2.6.20 we cleared the FADT.CSTATE_CONTROL field
for FADT versions before r3, because it made no sense
for that reserved field to be set for pre-ACPI 2.0 systems.
It turns out that not clearing this field exposes
Linux to SMM BIOS failures, so do the same in 2.6.21.
http://bugzilla.kernel.org/show_bug.cgi?id=8346
Signed-off-by: Len Brown <len.brown@intel.com>
the patch below fixes compilation breakage of smc911x driver when ENABLE_SMC_DEBUG_PKTS equals to 1.
Signed-off-by: Vitaly Wool <vitalywool@gmail.com>
Just found a hole in my last patch. It was reported to me that shortly after we
integrated this patch. The report was of an oops that took place inside of
netif_rx when using the sis900 driver. Looking at my origional patch I noted
that there was a spot between the new skb_alloc and the refill_rx_ring label
where skb got reassigned to the pointer currently held in the rx_ring for the
purposes of receiveing the frame. The result of this is however that the buffer
that gets passed to netif_rx (if it is called), then gets placed right back into
the rx_ring. So if you receive frames fast enough the skb being processed by
the network stack can get corrupted. The reporter is testing out the fix I've
written for this below (I'm not near my hardware at the moment to test myself),
but I wanted to post it for review ASAP. I'll post test results when I hear
them, but I think this is a pretty straightforward fix. It just uses a separate
pointer to do the rx operation, so that we don't improperly reassign the pointer
that we use to refill the rx ring.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
* master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6:
[PARPORT] SUNBPP: Fix OOPS when debugging is enabled.
[SPARC] openprom: Switch to ref counting PCI API
The packet driver is assuming (reasonably) that the (undocumented)
request.errors is an errno. But it is in fact some mysterious bitfield. When
things go wrong we return weird positive numbers to the VFS as pointers and it
goes oops.
Thanks to William Heimbigner for reporting and diagnosis.
(It doesn't oops, but this driver still doesn't work for William)
Cc: William Heimbigner <icxcnika@mar.tar.cc>
Cc: Peter Osterlund <petero2@telia.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6:
[BNX2]: Fix occasional NETDEV WATCHDOG on 5709.
[IPV6]: Disallow RH0 by default.
[XFRM]: beet: fix pseudo header length value
[TCP]: Congestion control initialization.
Tweak a register setting to prevent the tx mailbox from halting.
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
* 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6:
drivers/net/hamradio/baycom_ser_fdx build fix
usb-net/pegasus: fix pegasus carrier detection
sis900: Allocate rx replacement buffer before rx operation
[netdrvr] depca: handle platform_device_add() failure
sparc64:
drivers/net/hamradio/baycom_ser_fdx.c: In function `ser12_open':
drivers/net/hamradio/baycom_ser_fdx.c:417: error: `NR_IRQS' undeclared (first us
e in this function)
drivers/net/hamradio/baycom_ser_fdx.c:417: error: (Each undeclared identifier is
reported only once
drivers/net/hamradio/baycom_ser_fdx.c:417: error: for each function it appears i
n.)
Cc: Folkert van Heusden <folkert@vanheusden.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Broken by 4a1728a28a193aa388900714bbb1f375e08a6d8e which switched the
return semantics of read_mii_word() but didn't fix usage of
read_mii_word() to conform to the new semantics.
Setting carrier to off based on the NO_CARRIER flag is also incorrect as
that flag only triggers on TX failure and therefore isn't correct when
no frames are being transmitted. Since there is already a 2*HZ MII
carrier check going on, defer to that.
Add a TRUST_LINK_STATUS feature flag for adapters where the LINK_STATUS
flag is actually correct, and use that rather than the NO_CARRIER flag.
Signed-off-by: Dan Williams <dcbw@redhat.com>
The sis900 driver appears to have a bug in which the receive routine
passes the skbuff holding the received frame to the network stack before
refilling the buffer in the rx ring. If a new skbuff cannot be allocated, the
driver simply leaves a hole in the rx ring, which causes the driver to stop
receiving frames and become non-recoverable without an rmmod/insmod according to
reporters. This patch reverses that order, attempting to allocate a replacement
buffer first, and receiving the new frame only if one can be allocated. If no
skbuff can be allocated, the current skbuf in the rx ring is recycled, dropping
the current frame, but keeping the NIC operational.
The following patch fixes a kernel bug in depca_platform_probe().
We don't use a dynamic pointer for pldev->dev.platform_data, so it seems
that the correct way to proceed if platform_device_add(pldev) fails is
to explicitly set the pldev->dev.platform_data pointer to NULL, before
calling the platform_device_put(pldev), or it will be kfree'ed by
platform_device_release().
* master.kernel.org:/pub/scm/linux/kernel/git/bart/ide-2.6:
Revert "adjust legacy IDE resource setting (v2)"
serial8250_interrupt()
Commit 40b36daa introduced possibility that serial8250_backup_timeout() ->
serial8250_handle_port() locks port.lock without disabling irqs, thus
allowing deadlock against interrupt handler (port.lock is acquired in
serial8250_interrupt()).
Spotted by lockdep.
Cc: Dave Jones <davej@codemonkey.org.uk>
Cc: Alex Williamson <alex.williamson@hp.com>
Two functions are called from __devinit context, but they are marked as
__init. Fix this.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
On ia64, kernel headers define REGION_OFFSET so we can't use that.
Reported by Andrew Morton.
Acked-by: David Hubbard <david.c.hubbard@gmail.com>
irq values are u32, not u8. Large irq numbers will be truncated,
free_irq may free a different irq.
Remove incorrectly sized struct member and use the one from pci_dev.
Signed-off-by: Olaf Hering <olaf@aepfle.de>
Use relative time, not absolute. Discovered by Jung-Ik (John) Lee
<jilee@google.com>.
Cc: Jung-Ik (John) Lee <jilee@google.com>
Acked-by: Len Brown <lenb@kernel.org>
Signed-off-by: Miguel Ojeda Sandonis <maxextreme@gmail.com>
Cc: "Antonino A. Daplas" <adaplas@gmail.com>
pcd_lock and pf_spin_lock are passed to blk_init_queue() which, seeing them
as valid lock pointer, sets it as ->queue_lock.
The problem is that pcd_lock and pf_spin_lock aren't initialized anywhere.
Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru>
There was schedule() missing in the TIOCMIWAIT ioctl. Solve it by moving
the code to the wait_event_interruptible.
Cc: Jan Yenya Kasprzak <kas@fi.muni.cz>
Cc: Jan "Yenya" Kasprzak <kas@fi.muni.cz>
Signed-off-by: Jan "Yenya" Kasprzak <kas@fi.muni.cz>
Acked-by: Jiri Slaby <jirislaby@gmail.com>
Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
I encountered the following kernel panic. The cause of this problem was
NULL pointer access in check_modem_status() in 8250.c. I confirmed this
problem is fixed by the attached patch, but I don't know this is the
correct fix.
sadc[4378]: NaT consumption 2216203124768 [1]
Modules linked in: binfmt_misc dm_mirror dm_mod thermal processor fan
container button sg e100 eepro100 mii ehci_hcd ohci_hcd
Pid: 4378, CPU 0, comm: sadc
psr : 00001210085a2010 ifs : 8000000000000289 ip : [<a000000100482071>]
Not tainted
ip is at check_modem_status+0xf1/0x360
Call Trace:
[<a000000100013940>] show_stack+0x40/0xa0
[<a0000001000145a0>] show_regs+0x840/0x880
[<a0000001000368e0>] die+0x1c0/0x2c0
[<a000000100036a30>] die_if_kernel+0x50/0x80
[<a000000100037c40>] ia64_fault+0x11e0/0x1300
[<a00000010000bdc0>] ia64_leave_kernel+0x0/0x280
[<a000000100482070>] check_modem_status+0xf0/0x360
[<a000000100482300>] serial8250_get_mctrl+0x20/0xa0
[<a000000100478170>] uart_read_proc+0x250/0x860
[<a0000001001c16d0>] proc_file_read+0x1d0/0x4c0
[<a0000001001394b0>] vfs_read+0x1b0/0x300
[<a000000100139cd0>] sys_read+0x70/0xe0
[<a00000010000bc20>] ia64_ret_from_syscall+0x0/0x20
[<a000000000010620>] __kernel_syscall_via_break+0x0/0x20
Fix the possible NULL pointer access in check_modem_status() in 8250.c. The
check_modem_status() would access 'info' member of uart_port structure, but it
is not initialized before uart_open() is called. The check_modem_status() can
be called through /proc/tty/driver/serial before uart_open() is called.
Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com>
Signed-off-by: Taku Izumi <izumi2005@soft.fujitsu.com>
Cc: <stable@kernel.org>
The debugging code would dereference __iomem pointers instead
of going through sbus_{read,write}{b,w,l}().
