[ Upstream commit 3745488e9d599916a0b40d45d3f30e3d4720288e ]
altera_get_note is called from altera_init, where key is kzalloc(33).
When the allocation functions are annotated to allow the compiler to see
the sizes of objects, and with FORTIFY_SOURCE, we see:
In file included from drivers/misc/altera-stapl/altera.c:14:0:
In function ‘strlcpy’,
inlined from ‘altera_init’ at drivers/misc/altera-stapl/altera.c:2189:5:
include/linux/string.h:378:4: error: call to ‘__write_overflow’ declared with attribute error: detected write beyond size of object passed as 1st parameter
__write_overflow();
That refers to this code in altera_get_note:
if (key != NULL)
strlcpy(key, &p[note_strings +
get_unaligned_be32(
&p[note_table + (8 * i)])],
length);
The error triggers because the length of 'key' is 33, but the copy
uses length supplied as the 'length' parameter, which is always
256. Split the size parameter into key_len and val_len, and use the
appropriate length depending on what is being copied.
Detected by compiler error, only compile-tested.
Cc: "Igor M. Liplianin" <liplianin@netup.ru>
Signed-off-by: Daniel Axtens <dja@axtens.net>
Link: https://lore.kernel.org/r/20200120074344.504-2-dja@axtens.net
Link: https://lore.kernel.org/r/202002251042.D898E67AC@keescook
[ Upstream commit c0fd99d659ba5582e09625c7a985d63fc2ca74b5 ]
Writing to the built-in strings arrays doesn't work if driver is loaded
as kernel module. This is also considered as a bad pattern. Fix this by
adding a call to clk_get() with legacy clock name. This fixes following
kernel oops if driver is loaded as module:
Unable to handle kernel paging request at virtual address bf047978
pgd = (ptrval)
[bf047978] *pgd=59344811, *pte=5903c6df, *ppte=5903c65f
Internal error: Oops: 80f [#1] SMP ARM
Modules linked in: mc exynosdrm(+) analogix_dp rtc_s3c exynos_ppmu i2c_gpio
CPU: 1 PID: 212 Comm: systemd-udevd Not tainted 5.6.0-rc2-next-20200219 #326
videodev: Linux video capture interface: v2.00
Hardware name: Samsung Exynos (Flattened Device Tree)
PC is at exynos_dsi_probe+0x1f0/0x384 [exynosdrm]
LR is at exynos_dsi_probe+0x1dc/0x384 [exynosdrm]
Process systemd-udevd (pid: 212, stack limit = 0x(ptrval))
[<bf03cf14>] (exynos_dsi_probe [exynosdrm]) from [<c09b1ca0>] (platform_drv_probe+0x6c/0xa4)
[<c09b1ca0>] (platform_drv_probe) from [<c09afcb8>] (really_probe+0x210/0x350)
[<c09afcb8>] (really_probe) from [<c09aff74>] (driver_probe_device+0x60/0x1a0)
[<c09aff74>] (driver_probe_device) from [<c09b0254>] (device_driver_attach+0x58/0x60)
[<c09b0254>] (device_driver_attach) from [<c09b02dc>] (__driver_attach+0x80/0xbc)
[<c09b02dc>] (__driver_attach) from [<c09ade00>] (bus_for_each_dev+0x68/0xb4)
[<c09ade00>] (bus_for_each_dev) from [<c09aefd8>] (bus_add_driver+0x130/0x1e8)
[<c09aefd8>] (bus_add_driver) from [<c09b0d64>] (driver_register+0x78/0x110)
[<c09b0d64>] (driver_register) from [<bf038558>] (exynos_drm_init+0xe8/0x11c [exynosdrm])
[<bf038558>] (exynos_drm_init [exynosdrm]) from [<c0302fa8>] (do_one_initcall+0x50/0x220)
[<c0302fa8>] (do_one_initcall) from [<c03dd02c>] (do_init_module+0x60/0x210)
[<c03dd02c>] (do_init_module) from [<c03dbf44>] (load_module+0x1c0c/0x2310)
[<c03dbf44>] (load_module) from [<c03dc85c>] (sys_finit_module+0xac/0xbc)
[<c03dc85c>] (sys_finit_module) from [<c0301000>] (ret_fast_syscall+0x0/0x54)
Exception stack(0xd979bfa8 to 0xd979bff0)
---[ end trace db16efe05faab470 ]---
Reviewed-by: Andrzej Hajda <a.hajda@samsung.com>
Signed-off-by: Inki Dae <inki.dae@samsung.com>
[ Upstream commit 0a9d1e3f3f038785ebc72d53f1c409d07f6b4ff5 ]
Properly propagate error value from devm_regulator_bulk_get() and don't
confuse user with meaningless warning about failure in getting regulators
in case of deferred probe.
Reviewed-by: Krzysztof Kozlowski <krzk@kernel.org>
[ Upstream commit 5dd8304981ecffa77bb72b1c57c4be5dfe6cfae9 ]
In the public interface for chipselect, there is always an entry
commented as "Dummy generic FIFO entry" pushed down to the fifo right
after the activate/deactivate command. The dummy entry is 0x0,
irregardless if the intention was to activate or deactive the cs. This
causes the cs line to glitch rather than beeing activated in the case
when there was an activate command.
This has been observed on oscilloscope, and have caused problems for at
least one specific flash device type connected to the qspi port. After
the change the glitch is gone and cs goes active when intended.
The reason why this worked before (except for the glitch) was because
when sending the actual data, the CS bits are once again set. Since
most flashes uses mode 0, there is always a half clk period anyway for
cs to clk active setup time. If someone would rely on timing from a
chip_select call to a transfer_one, it would fail though.
It is unknown why the dummy entry was there in the first place, git log
seems to be of no help in this case. The reference manual gives no
indication of the necessity of this. In fact the lower 8 bits are a
setup (or hold in case of deactivate) time expressed in cycles. So this
should not be needed to fulfill any setup/hold timings.
Signed-off-by: Thommy Jakobsson <thommyj@gmail.com>
Reviewed-by: Naga Sureshkumar Relli <naga.sureshkumar.relli@xilinx.com>
Link: https://lore.kernel.org/r/20200224162643.29102-1-thommyj@gmail.com
Signed-off-by: Mark Brown <broonie@kernel.org>
[ Upstream commit 136b5cd2e2f97581ae560cff0db2a3b5369112da ]
spi_qup_suspend() will cause synchronous external abort when
runtime suspend is enabled and applied, as it tries to
access SPI controller register while clock is already disabled
in spi_qup_pm_suspend_runtime().
Signed-off-by: Yuji sasaki <sasakiy@chromium.org>
Signed-off-by: Vinod Koul <vkoul@kernel.org>
Link: https://lore.kernel.org/r/20200214074340.2286170-1-vkoul@kernel.org
This is the 4.4.217 stable release
[ Upstream commit 44343418d0f2f623cb9da6f5000df793131cbe3b ]
The KS8851 requires that packet RX and TX are mutually exclusive.
Currently, the driver hopes to achieve this by disabling interrupt
from the card by writing the card registers and by disabling the
interrupt on the interrupt controller. This however is racy on SMP.
Replace this approach by expanding the spinlock used around the
ks_start_xmit() TX path to ks_irq() RX path to assure true mutual
exclusion and remove the interrupt enabling/disabling, which is
now not needed anymore. Furthermore, disable interrupts also in
ks_net_stop(), which was missing before.
Note that a massive improvement here would be to re-use the KS8851
driver approach, which is to move the TX path into a worker thread,
interrupt handling to threaded interrupt, and synchronize everything
with mutexes, but that would be a much bigger rework, for a separate
patch.
Cc: Lukas Wunner <lukas@wunner.de>
Cc: Petr Stetiar <ynezz@true.cz>
Cc: YueHaibing <yuehaibing@huawei.com>
commit d6c066fda90d578aacdf19771a027ed484a79825 upstream.
Add a sanity check to efivar_store_raw() the same way
efivar_{attr,size,data}_read() and efivar_show_raw() have it.
Signed-off-by: Vladis Dronov <vdronov@redhat.com>
Signed-off-by: Ard Biesheuvel <ardb@kernel.org>
Cc: <stable@vger.kernel.org>
Link: https://lore.kernel.org/r/20200305084041.24053-3-vdronov@redhat.com
Link: https://lore.kernel.org/r/20200308080859.21568-25-ardb@kernel.org
commit 1e58252e334dc3f3756f424a157d1b7484464c40 upstream.
mwifiex_process_tdls_action_frame() without checking
the incoming tdls infomation element's vality before use it,
this may cause multi heap buffer overflows.
Fix them by putting vality check before use it.
IE is TLV struct, but ht_cap and ht_oper aren’t TLV struct.
the origin marvell driver code is wrong:
memcpy(&sta_ptr->tdls_cap.ht_oper, pos,....
memcpy((u8 *)&sta_ptr->tdls_cap.ht_capb, pos,...
Fix the bug by changing pos(the address of IE) to
pos+2 ( the address of IE value ).
Signed-off-by: qize wang <wangqize888888888@gmail.com>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
Signed-off-by: Matthias Maennich <maennich@google.com>
commit da72a379b2ec0bad3eb265787f7008bead0b040c upstream.
VMD subdevices are created with a PCI domain ID of 0x10000 or
higher.
These subdevices are also handled like all other PCI devices by
dmar_pci_bus_notifier().
However, when dmar_alloc_pci_notify_info() take records of such devices,
it will truncate the domain ID to a u16 value (in info->seg).
The device at (e.g.) 10000:00:02.0 is then treated by the DMAR code as if
it is 0000:00:02.0.
In the unlucky event that a real device also exists at 0000:00:02.0 and
also has a device-specific entry in the DMAR table,
dmar_insert_dev_scope() will crash on:
BUG_ON(i >= devices_cnt);
That's basically a sanity check that only one PCI device matches a
single DMAR entry; in this case we seem to have two matching devices.
Fix this by ignoring devices that have a domain number higher than
what can be looked up in the DMAR table.
This problem was carefully diagnosed by Jian-Hong Pan.
Signed-off-by: Lu Baolu <baolu.lu@linux.intel.com>
Signed-off-by: Daniel Drake <drake@endlessm.com>
Fixes: 59ce0515cdaf3 ("iommu/vt-d: Update DRHD/RMRR/ATSR device scope caches when PCI hotplug happens")
Signed-off-by: Joerg Roedel <jroedel@suse.de>
commit b0bb0c22c4db623f2e7b1a471596fbf1c22c6dc5 upstream.
When base address in RHSA structure doesn't match base address in
each DRHD structure, the base address in last DRHD is printed out.
This doesn't make sense when there are multiple DRHD units, fix it
by printing the buggy RHSA's base address.
Signed-off-by: Zhenzhong Duan <zhenzhong.duan@gmail.com>
Fixes: fd0c8894893cb ("intel-iommu: Set a more specific taint flag for invalid BIOS DMAR tables")
commit 77a1bce84bba01f3f143d77127b72e872b573795 upstream.
intel_iommu_iova_to_phys() has a bug when it translates an IOVA for a huge
page onto its corresponding physical address. This commit fixes the bug by
accomodating the level of page entry for the IOVA and adds IOVA's lower
address to the physical address.
Acked-by: Lu Baolu <baolu.lu@linux.intel.com>
Reviewed-by: Moritz Fischer <mdf@kernel.org>
Signed-off-by: Yonghyun Hwang <yonghyun@google.com>
Fixes: 3871794642579 ("VT-d: Changes to support KVM")
commit 59833696442c674acbbd297772ba89e7ad8c753d upstream.
Quoting from the comment describing the WARN functions in
include/asm-generic/bug.h:
* WARN(), WARN_ON(), WARN_ON_ONCE, and so on can be used to report
* significant kernel issues that need prompt attention if they should ever
* appear at runtime.
* Do not use these macros when checking for invalid external inputs
The (buggy) firmware tables which the dmar code was calling WARN_TAINT
for really are invalid external inputs. They are not under the kernel's
control and the issues in them cannot be fixed by a kernel update.
So logging a backtrace, which invites bug reports to be filed about this,
is not helpful.
Some distros, e.g. Fedora, have tools watching for the kernel backtraces
logged by the WARN macros and offer the user an option to file a bug for
this when these are encountered. The WARN_TAINT in warn_invalid_dmar()
+ another iommu WARN_TAINT, addressed in another patch, have lead to over
a 100 bugs being filed this way.
This commit replaces the WARN_TAINT("...") calls, with
pr_warn(FW_BUG "...") + add_taint(TAINT_FIRMWARE_WORKAROUND, ...) calls
avoiding the backtrace and thus also avoiding bug-reports being filed
about this against the kernel.
Fixes: fd0c8894893c ("intel-iommu: Set a more specific taint flag for invalid BIOS DMAR tables")
Fixes: e625b4a95d50 ("iommu/vt-d: Parse ANDD records")
Cc: stable@vger.kernel.org
Link: https://lore.kernel.org/r/20200309140138.3753-2-hdegoede@redhat.com
BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1564895
commit 286d3250c9d6437340203fb64938bea344729a0e upstream.
There is a race and a buffer overflow corrupting a kernel memory while
reading an EFI variable with a size more than 1024 bytes via the older
sysfs method. This happens because accessing struct efi_variable in
efivar_{attr,size,data}_read() and friends is not protected from
a concurrent access leading to a kernel memory corruption and, at best,
to a crash. The race scenario is the following:
CPU0: CPU1:
efivar_attr_read()
var->DataSize = 1024;
efivar_entry_get(... &var->DataSize)
down_interruptible(&efivars_lock)
efivar_attr_read() // same EFI var
virt_efi_get_variable()
// returns EFI_BUFFER_TOO_SMALL but
// var->DataSize is set to a real
// var size more than 1024 bytes
up(&efivars_lock)
// called with var->DataSize set
// to a real var size, returns
// successfully and overwrites
// a 1024-bytes kernel buffer
up(&efivars_lock)
This can be reproduced by concurrent reading of an EFI variable which size
is more than 1024 bytes:
ts# for cpu in $(seq 0 $(nproc --ignore=1)); do ( taskset -c $cpu \
cat /sys/firmware/efi/vars/KEKDefault*/size & ) ; done
Fix this by using a local variable for a var's data buffer size so it
does not get overwritten.
Fixes: e14ab23dde12b80d ("efivars: efivar_entry API")
Reported-by: Bob Sanders <bob.sanders@hpe.com> and the LTP testsuite
Link: https://lore.kernel.org/r/20200305084041.24053-2-vdronov@redhat.com
Link: https://lore.kernel.org/r/20200308080859.21568-24-ardb@kernel.org
commit d785476c608c621b345dd9396e8b21e90375cb0e upstream.
Variable grph_obj_type is being assigned twice, one of these is
redundant so remove it.
Addresses-Coverity: ("Evaluation order violation")
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Cc: <nobuhiro1.iwamatsu@toshiba.co.jp>
add_taint
commit 81ee85d0462410de8eeeec1b9761941fd6ed8c7b upstream.
is not helpful.
Fixes: 556ab45f9a77 ("ioat2: catch and recover from broken vtd configurations v6")
Link: https://lore.kernel.org/r/20200309182510.373875-1-hdegoede@redhat.com
BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=701847
commit b7469e83d2add567e4e0b063963db185f3167cea upstream.
Similar to commit 38f88c454042 ("bonding/alb: properly access headers
in bond_alb_xmit()"), we need to make sure arp header was pulled
in skb->head before blindly accessing it in rlb_arp_xmit().
Remove arp_pkt() private helper, since it is more readable/obvious
to have the following construct back to back :
if (!pskb_network_may_pull(skb, sizeof(*arp)))
return NULL;
arp = (struct arp_pkt *)skb_network_header(skb);
syzbot reported :
BUG: KMSAN: uninit-value in bond_slave_has_mac_rx include/net/bonding.h:704 [inline]
BUG: KMSAN: uninit-value in rlb_arp_xmit drivers/net/bonding/bond_alb.c:662 [inline]
BUG: KMSAN: uninit-value in bond_alb_xmit+0x575/0x25e0 drivers/net/bonding/bond_alb.c:1477
CPU: 0 PID: 12743 Comm: syz-executor.4 Not tainted 5.6.0-rc2-syzkaller #0
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x1c9/0x220 lib/dump_stack.c:118
kmsan_report+0xf7/0x1e0 mm/kmsan/kmsan_report.c:118
__msan_warning+0x58/0xa0 mm/kmsan/kmsan_instr.c:215
__bond_start_xmit drivers/net/bonding/bond_main.c:4257 [inline]
bond_start_xmit+0x85d/0x2f70 drivers/net/bonding/bond_main.c:4282
__netdev_start_xmit include/linux/netdevice.h:4524 [inline]
netdev_start_xmit include/linux/netdevice.h:4538 [inline]
xmit_one net/core/dev.c:3470 [inline]
dev_hard_start_xmit+0x531/0xab0 net/core/dev.c:3486
__dev_queue_xmit+0x37de/0x4220 net/core/dev.c:4063
dev_queue_xmit+0x4b/0x60 net/core/dev.c:4096
packet_snd net/packet/af_packet.c:2967 [inline]
packet_sendmsg+0x8347/0x93b0 net/packet/af_packet.c:2992
sock_sendmsg_nosec net/socket.c:652 [inline]
sock_sendmsg net/socket.c:672 [inline]
__sys_sendto+0xc1b/0xc50 net/socket.c:1998
__do_sys_sendto net/socket.c:2010 [inline]
__se_sys_sendto+0x107/0x130 net/socket.c:2006
__x64_sys_sendto+0x6e/0x90 net/socket.c:2006
do_syscall_64+0xb8/0x160 arch/x86/entry/common.c:296
entry_SYSCALL_64_after_hwframe+0x44/0xa9
RIP: 0033:0x45c479
Code: ad b6 fb ff c3 66 2e 0f 1f 84 00 00 00 00 00 66 90 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 0f 83 7b b6 fb ff c3 66 2e 0f 1f 84 00 00 00 00
RSP: 002b:00007fc77ffbbc78 EFLAGS: 00000246 ORIG_RAX: 000000000000002c
RAX: ffffffffffffffda RBX: 00007fc77ffbc6d4 RCX: 000000000045c479
RDX: 000000000000000e RSI: 00000000200004c0 RDI: 0000000000000003
RBP: 000000000076bf20 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 00000000ffffffff
R13: 0000000000000a04 R14: 00000000004cc7b0 R15: 000000000076bf2c
Uninit was created at:
kmsan_save_stack_with_flags mm/kmsan/kmsan.c:144 [inline]
kmsan_internal_poison_shadow+0x66/0xd0 mm/kmsan/kmsan.c:127
kmsan_slab_alloc+0x8a/0xe0 mm/kmsan/kmsan_hooks.c:82
slab_alloc_node mm/slub.c:2793 [inline]
__kmalloc_node_track_caller+0xb40/0x1200 mm/slub.c:4401
__kmalloc_reserve net/core/skbuff.c:142 [inline]
__alloc_skb+0x2fd/0xac0 net/core/skbuff.c:210
alloc_skb include/linux/skbuff.h:1051 [inline]
alloc_skb_with_frags+0x18c/0xa70 net/core/skbuff.c:5766
sock_alloc_send_pskb+0xada/0xc60 net/core/sock.c:2242
packet_alloc_skb net/packet/af_packet.c:2815 [inline]
packet_snd net/packet/af_packet.c:2910 [inline]
packet_sendmsg+0x66a0/0x93b0 net/packet/af_packet.c:2992
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Reported-by: syzbot <syzkaller@googlegroups.com>
Cc: Jay Vosburgh <j.vosburgh@gmail.com>
Cc: Veaceslav Falico <vfalico@gmail.com>
Cc: Andy Gospodarek <andy@greyhouse.net>
[ Upstream commit 110a40dfb708fe940a3f3704d470e431c368d256 ]
Before accessing various fields in IPV4 network header
and TCP header, make sure the packet :
- Has IP version 4 (ip->version == 4)
- Has not a silly network length (ip->ihl >= 5)
- Is big enough to hold network and transport headers
- Has not a silly TCP header size (th->doff >= sizeof(struct tcphdr) / 4)
syzbot reported :
BUG: KMSAN: uninit-value in slhc_compress+0x5b9/0x2e60 drivers/net/slip/slhc.c:270
CPU: 0 PID: 11728 Comm: syz-executor231 Not tainted 5.6.0-rc2-syzkaller #0
Call Trace:
ppp_send_frame drivers/net/ppp/ppp_generic.c:1637 [inline]
__ppp_xmit_process+0x1902/0x2970 drivers/net/ppp/ppp_generic.c:1495
ppp_xmit_process+0x147/0x2f0 drivers/net/ppp/ppp_generic.c:1516
ppp_write+0x6bb/0x790 drivers/net/ppp/ppp_generic.c:512
do_loop_readv_writev fs/read_write.c:717 [inline]
do_iter_write+0x812/0xdc0 fs/read_write.c:1000
compat_writev+0x2df/0x5a0 fs/read_write.c:1351
do_compat_pwritev64 fs/read_write.c:1400 [inline]
__do_compat_sys_pwritev fs/read_write.c:1420 [inline]
__se_compat_sys_pwritev fs/read_write.c:1414 [inline]
__ia32_compat_sys_pwritev+0x349/0x3f0 fs/read_write.c:1414
do_syscall_32_irqs_on arch/x86/entry/common.c:339 [inline]
do_fast_syscall_32+0x3c7/0x6e0 arch/x86/entry/common.c:410
entry_SYSENTER_compat+0x68/0x77 arch/x86/entry/entry_64_compat.S:139
RIP: 0023:0xf7f7cd99
Code: 90 e8 0b 00 00 00 f3 90 0f ae e8 eb f9 8d 74 26 00 89 3c 24 c3 90 90 90 90 90 90 90 90 90 90 90 90 51 52 55 89 e5 0f 34 cd 80 <5d> 5a 59 c3 90 90 90 90 eb 0d 90 90 90 90 90 90 90 90 90 90 90 90
RSP: 002b:00000000ffdb84ac EFLAGS: 00000217 ORIG_RAX: 000000000000014e
RAX: ffffffffffffffda RBX: 0000000000000003 RCX: 00000000200001c0
RDX: 0000000000000001 RSI: 0000000000000000 RDI: 0000000000000003
RBP: 0000000040047459 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000000
R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
ppp_write+0x115/0x790 drivers/net/ppp/ppp_generic.c:500
Fixes: b5451d783ade ("slip: Move the SLIP drivers")
[ Upstream commit ab14961d10d02d20767612c78ce148f6eb85bd58 ]
fec_enet_set_coalesce() validates the previously set params
and if they are within range proceeds to apply the new ones.
The new ones, however, are not validated. This seems backwards,
probably a copy-paste error?
Compile tested only.
Fixes: d851b47b22fc ("net: fec: add interrupt coalescence feature support")
Signed-off-by: Jakub Kicinski <kuba@kernel.org>
Acked-by: Fugang Duan <fugang.duan@nxp.com>
[ Upstream commit ce9a4186f9ac475c415ffd20348176a4ea366670 ]
The Rx bound multicast packets are deferred to a workqueue and
macvlan can also suffer from the same attack that was discovered
by Syzbot for IPvlan. This solution is not as effective as in
IPvlan. IPvlan defers all (Tx and Rx) multicast packet processing
to a workqueue while macvlan does this way only for the Rx. This
fix should address the Rx codition to certain extent.
Tx is still suseptible. Tx multicast processing happens when
.ndo_start_xmit is called, hence we cannot add cond_resched().
However, it's not that severe since the user which is generating
/ flooding will be affected the most.
Fixes: 412ca1550cbe ("macvlan: Move broadcasts into a work queue")
Signed-off-by: Mahesh Bandewar <maheshb@google.com>
[ Upstream commit ad8192767c9f9cf97da57b9ffcea70fb100febef ]
IPvlan in L3 mode discards outbound multicast packets but performs
the check before ensuring the ether-header is set or not. This is
an error that Eric found through code browsing.
Fixes: 2ad7bf363841 (“ipvlan: Initial check-in of the IPVLAN driver.”)
Reported-by: Eric Dumazet <edumazet@google.com>
[ Upstream commit afe207d80a61e4d6e7cfa0611a4af46d0ba95628 ]
Commit e18b353f102e ("ipvlan: add cond_resched_rcu() while
processing muticast backlog") added a cond_resched_rcu() in a loop
using rcu protection to iterate over slaves.
This is breaking rcu rules, so lets instead use cond_resched()
at a point we can reschedule
Fixes: e18b353f102e ("ipvlan: add cond_resched_rcu() while processing muticast backlog")
Cc: Mahesh Bandewar <maheshb@google.com>
commit cccc200fcaf04cff4342036a72e51d6adf6c98c1 upstream.
Currently, if IPv6 is enabled on top of an ipvlan device in l3
mode, the following warning message:
Dropped {multi|broad}cast of type= [86dd]
is emitted every time that a RS is generated and dmseg is soon
filled with irrelevant messages. Replace pr_warn with pr_debug,
to preserve debuggability, without scaring the sysadmin.
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
[ Upstream commit 63aae7b17344d4b08a7d05cb07044de4c0f9dcc6 ]
There is a problem when ipvlan slaves are created on a master device that
is a vmxnet3 device (ipvlan in VMware guests). The vmxnet3 driver does not
support unicast address filtering. When an ipvlan device is brought up in
ipvlan_open(), the ipvlan driver calls dev_uc_add() to add the hardware
address of the vmxnet3 master device to the unicast address list of the
master device, phy_dev->uc. This inevitably leads to the vmxnet3 master
device being forced into promiscuous mode by __dev_set_rx_mode().
Promiscuous mode is switched on the master despite the fact that there is
still only one hardware address that the master device should use for
filtering in order for the ipvlan device to be able to receive packets.
The comment above struct net_device describes the uc_promisc member as a
"counter, that indicates, that promiscuous mode has been enabled due to
the need to listen to additional unicast addresses in a device that does
not implement ndo_set_rx_mode()". Moreover, the design of ipvlan
guarantees that only the hardware address of a master device,
phy_dev->dev_addr, will be used to transmit and receive all packets from
its ipvlan slaves. Thus, the unicast address list of the master device
should not be modified by ipvlan_open() and ipvlan_stop() in order to make
ipvlan a workable option on masters that do not support unicast address
filtering.
Fixes: 2ad7bf3638411 ("ipvlan: Initial check-in of the IPVLAN driver")
Reported-by: Per Sundstrom <per.sundstrom@redqube.se>
Signed-off-by: Jiri Wiesner <jwiesner@suse.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
Acked-by: Mahesh Bandewar <maheshb@google.com>
[ Upstream commit e18b353f102e371580f3f01dd47567a25acc3c1d ]
If there are substantial number of slaves created as simulated by
Syzbot, the backlog processing could take much longer and result
into the issue found in the Syzbot report.
INFO: rcu_sched detected stalls on CPUs/tasks:
(detected by 1, t=10502 jiffies, g=5049, c=5048, q=752)
All QSes seen, last rcu_sched kthread activity 10502 (4294965563-4294955061), jiffies_till_next_fqs=1, root ->qsmask 0x0
syz-executor.1 R running task on cpu 1 10984 11210 3866 0x30020008 179034491270
Call Trace:
<IRQ>
[<ffffffff81497163>] _sched_show_task kernel/sched/core.c:8063 [inline]
[<ffffffff81497163>] _sched_show_task.cold+0x2fd/0x392 kernel/sched/core.c:8030
[<ffffffff8146a91b>] sched_show_task+0xb/0x10 kernel/sched/core.c:8073
[<ffffffff815c931b>] print_other_cpu_stall kernel/rcu/tree.c:1577 [inline]
[<ffffffff815c931b>] check_cpu_stall kernel/rcu/tree.c:1695 [inline]
[<ffffffff815c931b>] __rcu_pending kernel/rcu/tree.c:3478 [inline]
[<ffffffff815c931b>] rcu_pending kernel/rcu/tree.c:3540 [inline]
[<ffffffff815c931b>] rcu_check_callbacks.cold+0xbb4/0xc29 kernel/rcu/tree.c:2876
[<ffffffff815e3962>] update_process_times+0x32/0x80 kernel/time/timer.c:1635
[<ffffffff816164f0>] tick_sched_handle+0xa0/0x180 kernel/time/tick-sched.c:161
[<ffffffff81616ae4>] tick_sched_timer+0x44/0x130 kernel/time/tick-sched.c:1193
[<ffffffff815e75f7>] __run_hrtimer kernel/time/hrtimer.c:1393 [inline]
[<ffffffff815e75f7>] __hrtimer_run_queues+0x307/0xd90 kernel/time/hrtimer.c:1455
[<ffffffff815e90ea>] hrtimer_interrupt+0x2ea/0x730 kernel/time/hrtimer.c:1513
[<ffffffff844050f4>] local_apic_timer_interrupt arch/x86/kernel/apic/apic.c:1031 [inline]
[<ffffffff844050f4>] smp_apic_timer_interrupt+0x144/0x5e0 arch/x86/kernel/apic/apic.c:1056
[<ffffffff84401cbe>] apic_timer_interrupt+0x8e/0xa0 arch/x86/entry/entry_64.S:778
RIP: 0010:do_raw_read_lock+0x22/0x80 kernel/locking/spinlock_debug.c:153
RSP: 0018:ffff8801dad07ab8 EFLAGS: 00000a02 ORIG_RAX: ffffffffffffff12
RAX: 0000000000000000 RBX: ffff8801c4135680 RCX: 0000000000000000
RDX: 1ffff10038826afe RSI: ffff88019d816bb8 RDI: ffff8801c41357f0
RBP: ffff8801dad07ac0 R08: 0000000000004b15 R09: 0000000000310273
R10: ffff88019d816bb8 R11: 0000000000000001 R12: ffff8801c41357e8
R13: 0000000000000000 R14: ffff8801cfb19850 R15: ffff8801cfb198b0
[<ffffffff8101460e>] __raw_read_lock_bh include/linux/rwlock_api_smp.h:177 [inline]
[<ffffffff8101460e>] _raw_read_lock_bh+0x3e/0x50 kernel/locking/spinlock.c:240
[<ffffffff840d78ca>] ipv6_chk_mcast_addr+0x11a/0x6f0 net/ipv6/mcast.c:1006
[<ffffffff84023439>] ip6_mc_input+0x319/0x8e0 net/ipv6/ip6_input.c:482
[<ffffffff840211c8>] dst_input include/net/dst.h:449 [inline]
[<ffffffff840211c8>] ip6_rcv_finish+0x408/0x610 net/ipv6/ip6_input.c:78
[<ffffffff840214de>] NF_HOOK include/linux/netfilter.h:292 [inline]
[<ffffffff840214de>] NF_HOOK include/linux/netfilter.h:286 [inline]
[<ffffffff840214de>] ipv6_rcv+0x10e/0x420 net/ipv6/ip6_input.c:278
[<ffffffff83a29efa>] __netif_receive_skb_one_core+0x12a/0x1f0 net/core/dev.c:5303
[<ffffffff83a2a15c>] __netif_receive_skb+0x2c/0x1b0 net/core/dev.c:5417
[<ffffffff83a2f536>] process_backlog+0x216/0x6c0 net/core/dev.c:6243
[<ffffffff83a30d1b>] napi_poll net/core/dev.c:6680 [inline]
[<ffffffff83a30d1b>] net_rx_action+0x47b/0xfb0 net/core/dev.c:6748
[<ffffffff846002c8>] __do_softirq+0x2c8/0x99a kernel/softirq.c:317
[<ffffffff813e656a>] invoke_softirq kernel/softirq.c:399 [inline]
[<ffffffff813e656a>] irq_exit+0x16a/0x1a0 kernel/softirq.c:439
[<ffffffff84405115>] exiting_irq arch/x86/include/asm/apic.h:561 [inline]
[<ffffffff84405115>] smp_apic_timer_interrupt+0x165/0x5e0 arch/x86/kernel/apic/apic.c:1058
</IRQ>
RIP: 0010:__sanitizer_cov_trace_pc+0x26/0x50 kernel/kcov.c:102
RSP: 0018:ffff880196033bd8 EFLAGS: 00000246 ORIG_RAX: ffffffffffffff12
RAX: ffff88019d8161c0 RBX: 00000000ffffffff RCX: ffffc90003501000
RDX: 0000000000000002 RSI: ffffffff816236d1 RDI: 0000000000000005
RBP: ffff880196033bd8 R08: ffff88019d8161c0 R09: 0000000000000000
R10: 1ffff10032c067f0 R11: 0000000000000000 R12: 0000000000000000
R13: 0000000000000080 R14: 0000000000000000 R15: 0000000000000000
[<ffffffff816236d1>] do_futex+0x151/0x1d50 kernel/futex.c:3548
[<ffffffff816260f0>] C_SYSC_futex kernel/futex_compat.c:201 [inline]
[<ffffffff816260f0>] compat_SyS_futex+0x270/0x3b0 kernel/futex_compat.c:175
[<ffffffff8101da17>] do_syscall_32_irqs_on arch/x86/entry/common.c:353 [inline]
[<ffffffff8101da17>] do_fast_syscall_32+0x357/0xe1c arch/x86/entry/common.c:415
[<ffffffff84401a9b>] entry_SYSENTER_compat+0x8b/0x9d arch/x86/entry/entry_64_compat.S:139
RIP: 0023:0xf7f23c69
RSP: 002b:00000000f5d1f12c EFLAGS: 00000282 ORIG_RAX: 00000000000000f0
RAX: ffffffffffffffda RBX: 000000000816af88 RCX: 0000000000000080
RDX: 0000000000000000 RSI: 0000000000000000 RDI: 000000000816af8c
RBP: 00000000f5d1f228 R08: 0000000000000000 R09: 0000000000000000
rcu_sched kthread starved for 10502 jiffies! g5049 c5048 f0x2 RCU_GP_WAIT_FQS(3) ->state=0x0 ->cpu=1
rcu_sched R running task on cpu 1 13048 8 2 0x90000000 179099587640
Call Trace:
[<ffffffff8147321f>] context_switch+0x60f/0xa60 kernel/sched/core.c:3209
[<ffffffff8100095a>] __schedule+0x5aa/0x1da0 kernel/sched/core.c:3934
[<ffffffff810021df>] schedule+0x8f/0x1b0 kernel/sched/core.c:4011
[<ffffffff8101116d>] schedule_timeout+0x50d/0xee0 kernel/time/timer.c:1803
[<ffffffff815c13f1>] rcu_gp_kthread+0xda1/0x3b50 kernel/rcu/tree.c:2327
[<ffffffff8144b318>] kthread+0x348/0x420 kernel/kthread.c:246
[<ffffffff84400266>] ret_from_fork+0x56/0x70 arch/x86/entry/entry_64.S:393
Fixes: ba35f8588f47 (“ipvlan: Defer multicast / broadcast processing to a work-queue”)
[ Upstream commit 669fcd7795900cd1880237cbbb57a7db66cb9ac8 ]
Add missing attribute validation for TEAM_ATTR_OPTION_ARRAY_INDEX
to the netlink policy.
Fixes: b13033262d24 ("team: introduce array options")
Reviewed-by: Jiri Pirko <jiri@mellanox.com>
[ Upstream commit dd25cb272ccce4db67dc8509278229099e4f5e99 ]
Add missing attribute validation for TEAM_ATTR_OPTION_PORT_IFINDEX
Fixes: 80f7c6683fe0 ("team: add support for per-port options")
[ Upstream commit a9b952d267e59a3b405e644930f46d252cea7122 ]
MTU changes may affect the number of IRQs so we must call
bnxt_close_nic()/bnxt_open_nic() with the irq_re_init parameter
set to true. The reason is that a larger MTU may require
aggregation rings not needed with smaller MTU. We may not be
able to allocate the required number of aggregation rings and
so we reduce the number of channels which will change the number
of IRQs. Without this patch, it may crash eventually in
pci_disable_msix() when the IRQs are not properly unwound.
Fixes: c0c050c58d84 ("bnxt_en: New Broadcom ethernet driver.")
Signed-off-by: Vasundhara Volam <vasundhara-v.volam@broadcom.com>
Signed-off-by: Michael Chan <michael.chan@broadcom.com>
[ Upstream commit d64c7a08034b32c285e576208ae44fc3ba3fa7df ]
Dell USB Type C docking WD19/WD19DC attaches additional peripherals as:
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/6p, 5000M
|__ Port 1: Dev 11, If 0, Class=Hub, Driver=hub/4p, 5000M
|__ Port 3: Dev 12, If 0, Class=Hub, Driver=hub/4p, 5000M
|__ Port 4: Dev 13, If 0, Class=Vendor Specific Class,
Driver=r8152, 5000M
where usb 2-1-3 is a hub connecting all USB Type-A/C ports on the dock.
When hotplugging such dock with additional usb devices already attached on
it, the probing process may reset usb 2.1 port, therefore r8152 ethernet
device is also reset. However, during r8152 device init there are several
for-loops that, when it's unable to retrieve hardware registers due to
being disconnected from USB, may take up to 14 seconds each in practice,
and that has to be completed before USB may re-enumerate devices on the
bus. As a result, devices attached to the dock will only be available
after nearly 1 minute after the dock was plugged in:
[ 216.388290] [250] r8152 2-1.4:1.0: usb_probe_interface
[ 216.388292] [250] r8152 2-1.4:1.0: usb_probe_interface - got id
[ 258.830410] r8152 2-1.4:1.0 (unnamed net_device) (uninitialized): PHY not ready
[ 258.830460] r8152 2-1.4:1.0 (unnamed net_device) (uninitialized): Invalid header when reading pass-thru MAC addr
[ 258.830464] r8152 2-1.4:1.0 (unnamed net_device) (uninitialized): Get ether addr fail
This happens in, for example, r8153_init:
static int generic_ocp_read(struct r8152 *tp, u16 index, u16 size,
void *data, u16 type)
if (test_bit(RTL8152_UNPLUG, &tp->flags))
return -ENODEV;
static u16 ocp_read_word(struct r8152 *tp, u16 type, u16 index)
u32 data;
generic_ocp_read(tp, index, sizeof(tmp), &tmp, type | byen);
data = __le32_to_cpu(tmp);
return (u16)data;
static void r8153_init(struct r8152 *tp)
return;
for (i = 0; i < 500; i++) {
if (ocp_read_word(tp, MCU_TYPE_PLA, PLA_BOOT_CTRL) &
AUTOLOAD_DONE)
break;
msleep(20);
Since ocp_read_word() doesn't check the return status of
generic_ocp_read(), and the only exit condition for the loop is to have
a match in the returned value, such loops will only ends after exceeding
its maximum runs when the device has been marked as disconnected, which
takes 500 * 20ms = 10 seconds in theory, 14 in practice.
To solve this long latency another test to RTL8152_UNPLUG flag should be
added after those 20ms sleep to skip unnecessary loops, so that the device
probe can complete early and proceed to parent port reset/reprobe process.
This can be reproduced on all kernel versions up to latest v5.6-rc2, but
after v5.5-rc7 the reproduce rate is dramatically lowered to 1/30 or less
while it was around 1/2.
Signed-off-by: You-Sheng Yang <vicamo.yang@canonical.com>
commit 7cdf6a0aae1cccf5167f3f04ecddcf648b78e289 upstream.
The crash can be reproduced by running the lvm2 testsuite test
lvconvert-thin-external-cache.sh for several minutes, e.g.:
while :; do make check T=shell/lvconvert-thin-external-cache.sh; done
The crash happens in this call chain:
do_waker -> policy_tick -> smq_tick -> end_hotspot_period -> clear_bitset
-> memset -> __memset -- which accesses an invalid pointer in the vmalloc
area.
The work entry on the workqueue is executed even after the bitmap was
freed. The problem is that cancel_delayed_work doesn't wait for the
running work item to finish, so the work item can continue running and
re-submitting itself even after cache_postsuspend. In order to make sure
that the work item won't be running, we must use cancel_delayed_work_sync.
Also, change flush_workqueue to drain_workqueue, so that if some work item
submits itself or another work item, we are properly waiting for both of
them.
Fixes: c6b4fcbad044 ("dm: add cache target")
Cc: stable@vger.kernel.org # v3.9
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
commit 36d5d22090d13fd3a7a8c9663a711cbe6970aac8 upstream.
The caller is already holding the lock so this will deadlock.
Fixes: 0b58828c923e ("DMAENGINE: COH 901 318 remove irq counting")
Link: https://lore.kernel.org/r/20200217144050.3i4ymbytogod4ijn@kili.mountain
commit 44f2f882909fedfc3a56e4b90026910456019743 upstream.
This is only called from adt7462_update_device(). The caller expects it
to return zero on error. I fixed a similar issue earlier in commit
a4bf06d58f21 ("hwmon: (adt7462) ADT7462_REG_VOLT_MAX() should return 0")
but I missed this one.
Fixes: c0b4e3ab0c76 ("adt7462: new hwmon driver")
Reviewed-by: Darrick J. Wong <darrick.wong@oracle.com>
Link: https://lore.kernel.org/r/20200303101608.kqjwfcazu2ylhi2a@kili.mountain
commit c14dfddbd869bf0c2bafb7ef260c41d9cebbcfec upstream.
The algorithm pre-allocates a cm_id since allocation cannot be done while
holding the cm.lock spinlock, however it doesn't free it on one error
path, leading to a memory leak.
Fixes: 067b171b8679 ("IB/cm: Share listening CM IDs")
Link: https://lore.kernel.org/r/20200221152023.GA8680@ziepe.ca
Signed-off-by: Jason Gunthorpe <jgg@mellanox.com>
commit 810dbc69087b08fd53e1cdd6c709f385bc2921ad upstream.
The dealloc_work_entries() function must update the work_free_list pointer
while freeing its entries, since potentially called again on same list. A
second iteration of the work list caused system crash. This happens, if
work allocation fails during cma_iw_listen() and free_cm_id() tries to
free the list again during cleanup.
Fixes: 922a8e9fb2e0 ("RDMA: iWARP Connection Manager.")
Link: https://lore.kernel.org/r/20200302181614.17042-1-bmt@zurich.ibm.com
Reported-by: syzbot+cb0c054eabfba4342146@syzkaller.appspotmail.com
Signed-off-by: Bernard Metzler <bmt@zurich.ibm.com>
Reviewed-by: Jason Gunthorpe <jgg@mellanox.com>
commit c33ee1301c393a241d6424e36eff1071811b1064 upstream.
The interrupt handler puts a half-completed DMA descriptor on a free list
and then schedules tasklet to process bottom half of the descriptor that
executes client's callback, this creates possibility to pick up the busy
descriptor from the free list. Thus, let's disallow descriptor's re-use
until it is fully processed.
Signed-off-by: Dmitry Osipenko <digetx@gmail.com>
Acked-by: Jon Hunter <jonathanh@nvidia.com>
Link: https://lore.kernel.org/r/20200209163356.6439-3-digetx@gmail.com
commit 94788af4ed039476ff3527b0e6a12c1dc42cb022 upstream.
I was doing some experiments with I2C and noticed that Tegra APB DMA
driver crashes sometime after I2C DMA transfer termination. The crash
happens because tegra_dma_terminate_all() bails out immediately if pending
list is empty, and thus, it doesn't release the half-completed descriptors
which are getting re-used before ISR tasklet kicks-in.
tegra-i2c 7000c400.i2c: DMA transfer timeout
elants_i2c 0-0010: elants_i2c_irq: failed to read data: -110
WARNING: CPU: 0 PID: 142 at lib/list_debug.c:45 __list_del_entry_valid+0x45/0xac
list_del corruption, ddbaac44->next is LIST_POISON1 (00000100)
Modules linked in:
CPU: 0 PID: 142 Comm: kworker/0:2 Not tainted 5.5.0-rc2-next-20191220-00175-gc3605715758d-dirty #538
Hardware name: NVIDIA Tegra SoC (Flattened Device Tree)
Workqueue: events_freezable_power_ thermal_zone_device_check
[<c010e5c5>] (unwind_backtrace) from [<c010a1c5>] (show_stack+0x11/0x14)
[<c010a1c5>] (show_stack) from [<c0973925>] (dump_stack+0x85/0x94)
[<c0973925>] (dump_stack) from [<c011f529>] (__warn+0xc1/0xc4)
[<c011f529>] (__warn) from [<c011f7e9>] (warn_slowpath_fmt+0x61/0x78)
[<c011f7e9>] (warn_slowpath_fmt) from [<c042497d>] (__list_del_entry_valid+0x45/0xac)
[<c042497d>] (__list_del_entry_valid) from [<c047a87f>] (tegra_dma_tasklet+0x5b/0x154)
[<c047a87f>] (tegra_dma_tasklet) from [<c0124799>] (tasklet_action_common.constprop.0+0x41/0x7c)
[<c0124799>] (tasklet_action_common.constprop.0) from [<c01022ab>] (__do_softirq+0xd3/0x2a8)
[<c01022ab>] (__do_softirq) from [<c0124683>] (irq_exit+0x7b/0x98)
[<c0124683>] (irq_exit) from [<c0168c19>] (__handle_domain_irq+0x45/0x80)
[<c0168c19>] (__handle_domain_irq) from [<c043e429>] (gic_handle_irq+0x45/0x7c)
[<c043e429>] (gic_handle_irq) from [<c0101aa5>] (__irq_svc+0x65/0x94)
Exception stack(0xde2ebb90 to 0xde2ebbd8)
Link: https://lore.kernel.org/r/20200209163356.6439-2-digetx@gmail.com
commit e8c75a30a23c6ba63f4ef6895cbf41fd42f21aa2 upstream.
sel_lock cannot nest in the console lock. Thanks to syzkaller, the
kernel states firmly:
> WARNING: possible circular locking dependency detected
> 5.6.0-rc3-syzkaller #0 Not tainted
> syz-executor.4/20336 is trying to acquire lock:
> ffff8880a2e952a0 (&tty->termios_rwsem){++++}, at: tty_unthrottle+0x22/0x100 drivers/tty/tty_ioctl.c:136
> but task is already holding lock:
> ffffffff89462e70 (sel_lock){+.+.}, at: paste_selection+0x118/0x470 drivers/tty/vt/selection.c:374
> which lock already depends on the new lock.
> the existing dependency chain (in reverse order) is:
> -> #2 (sel_lock){+.+.}:
> mutex_lock_nested+0x1b/0x30 kernel/locking/mutex.c:1118
> set_selection_kernel+0x3b8/0x18a0 drivers/tty/vt/selection.c:217
> set_selection_user+0x63/0x80 drivers/tty/vt/selection.c:181
> tioclinux+0x103/0x530 drivers/tty/vt/vt.c:3050
> vt_ioctl+0x3f1/0x3a30 drivers/tty/vt/vt_ioctl.c:364
This is ioctl(TIOCL_SETSEL).
Locks held on the path: console_lock -> sel_lock
> -> #1 (console_lock){+.+.}:
> console_lock+0x46/0x70 kernel/printk/printk.c:2289
> con_flush_chars+0x50/0x650 drivers/tty/vt/vt.c:3223
> n_tty_write+0xeae/0x1200 drivers/tty/n_tty.c:2350
> do_tty_write drivers/tty/tty_io.c:962 [inline]
> tty_write+0x5a1/0x950 drivers/tty/tty_io.c:1046
This is write().
Locks held on the path: termios_rwsem -> console_lock
> -> #0 (&tty->termios_rwsem){++++}:
> down_write+0x57/0x140 kernel/locking/rwsem.c:1534
> mkiss_receive_buf+0x12aa/0x1340 drivers/net/hamradio/mkiss.c:902
> tty_ldisc_receive_buf+0x12f/0x170 drivers/tty/tty_buffer.c:465
> paste_selection+0x346/0x470 drivers/tty/vt/selection.c:389
> tioclinux+0x121/0x530 drivers/tty/vt/vt.c:3055
This is ioctl(TIOCL_PASTESEL).
Locks held on the path: sel_lock -> termios_rwsem
> other info that might help us debug this:
> Chain exists of:
> &tty->termios_rwsem --> console_lock --> sel_lock
Clearly. From the above, we have:
Fix this by reversing the console_lock -> sel_lock dependency in
ioctl(TIOCL_SETSEL). First, lock sel_lock, then console_lock.
Reported-by: syzbot+26183d9746e62da329b8@syzkaller.appspotmail.com
Fixes: 07e6124a1a46 ("vt: selection, close sel_buffer race")
Cc: stable <stable@vger.kernel.org>
Link: https://lore.kernel.org/r/20200228115406.5735-2-jslaby@suse.cz
commit 4b70dd57a15d2f4685ac6e38056bad93e81e982f upstream.
We need to nest the console lock in sel_lock, so we have to push it down
a bit. Fortunately, the callers of set_selection_* just lock the console
lock around the function call. So moving it down is easy.
In the next patch, we switch the order.
Link: https://lore.kernel.org/r/20200228115406.5735-1-jslaby@suse.cz
commit 07e6124a1a46b4b5a9b3cacc0c306b50da87abf5 upstream.
syzkaller reported this UAF:
BUG: KASAN: use-after-free in n_tty_receive_buf_common+0x2481/0x2940 drivers/tty/n_tty.c:1741
Read of size 1 at addr ffff8880089e40e9 by task syz-executor.1/13184
CPU: 0 PID: 13184 Comm: syz-executor.1 Not tainted 5.4.7 #1
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.12.0-1 04/01/2014
Call Trace:
kasan_report+0xe/0x20 mm/kasan/common.c:634
tty_ldisc_receive_buf+0xac/0x190 drivers/tty/tty_buffer.c:461
paste_selection+0x297/0x400 drivers/tty/vt/selection.c:372
tioclinux+0x20d/0x4e0 drivers/tty/vt/vt.c:3044
vt_ioctl+0x1bcf/0x28d0 drivers/tty/vt/vt_ioctl.c:364
tty_ioctl+0x525/0x15a0 drivers/tty/tty_io.c:2657
vfs_ioctl fs/ioctl.c:47 [inline]
It is due to a race between parallel paste_selection (TIOCL_PASTESEL)
and set_selection_user (TIOCL_SETSEL) invocations. One uses sel_buffer,
while the other frees it and reallocates a new one for another
selection. Add a mutex to close this race.
The mutex takes care properly of sel_buffer and sel_buffer_lth only. The
other selection global variables (like sel_start, sel_end, and sel_cons)
are protected only in set_selection_user. The other functions need quite
some more work to close the races of the variables there. This is going
to happen later.
This likely fixes (I am unsure as there is no reproducer provided) bug
206361 too. It was marked as CVE-2020-8648.
Reported-by: syzbot+59997e8d5cbdc486e6f6@syzkaller.appspotmail.com
References: https://bugzilla.kernel.org/show_bug.cgi?id=206361
Link: https://lore.kernel.org/r/20200210081131.23572-2-jslaby@suse.cz
commit 513dc792d6060d5ef572e43852683097a8420f56 upstream.
When syzkaller tests, there is a UAF:
BUG: KASan: use after free in vgacon_invert_region+0x9d/0x110 at addr
ffff880000100000
Read of size 2 by task syz-executor.1/16489
page:ffffea0000004000 count:0 mapcount:-127 mapping: (null)
index:0x0
page flags: 0xfffff00000000()
page dumped because: kasan: bad access detected
CPU: 1 PID: 16489 Comm: syz-executor.1 Not tainted
rel-1.9.3-0-ge2fc41e-prebuilt.qemu-project.org 04/01/2014
Call Trace:
[<ffffffffb119f309>] dump_stack+0x1e/0x20
[<ffffffffb04af957>] kasan_report+0x577/0x950
[<ffffffffb04ae652>] __asan_load2+0x62/0x80
[<ffffffffb090f26d>] vgacon_invert_region+0x9d/0x110
[<ffffffffb0a39d95>] invert_screen+0xe5/0x470
[<ffffffffb0a21dcb>] set_selection+0x44b/0x12f0
[<ffffffffb0a3bfae>] tioclinux+0xee/0x490
[<ffffffffb0a1d114>] vt_ioctl+0xff4/0x2670
[<ffffffffb0a0089a>] tty_ioctl+0x46a/0x1a10
[<ffffffffb052db3d>] do_vfs_ioctl+0x5bd/0xc40
[<ffffffffb052e2f2>] SyS_ioctl+0x132/0x170
[<ffffffffb11c9b1b>] system_call_fastpath+0x22/0x27
Memory state around the buggy address:
ffff8800000fff00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00
ffff8800000fff80: 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00
>ffff880000100000: ff ff ff ff ff ff ff ff ff ff ff ff ff
ff ff ff
It can be reproduce in the linux mainline by the program:
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <fcntl.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <sys/ioctl.h>
#include <linux/vt.h>
struct tiocl_selection {
unsigned short xs; /* X start */
unsigned short ys; /* Y start */
unsigned short xe; /* X end */
unsigned short ye; /* Y end */
unsigned short sel_mode; /* selection mode */
#define TIOCL_SETSEL 2
struct tiocl {
unsigned char type;
unsigned char pad;
struct tiocl_selection sel;
int main()
int fd = 0;
const char *dev = "/dev/char/4:1";
struct vt_consize v = {0};
struct tiocl tioc = {0};
fd = open(dev, O_RDWR, 0);
v.v_rows = 3346;
ioctl(fd, VT_RESIZEX, &v);
tioc.type = TIOCL_SETSEL;
ioctl(fd, TIOCLINUX, &tioc);
return 0;
When resize the screen, update the 'vc->vc_size_row' to the new_row_size,
but when 'set_origin' in 'vgacon_set_origin', vgacon use 'vga_vram_base'
for 'vc_origin' and 'vc_visible_origin', not 'vc_screenbuf'. It maybe
smaller than 'vc_screenbuf'. When TIOCLINUX, use the new_row_size to calc
the offset, it maybe larger than the vga_vram_size in vgacon driver, then
bad access.
Also, if set an larger screenbuf firstly, then set an more larger
screenbuf, when copy old_origin to new_origin, a bad access may happen.
So, If the screen size larger than vga_vram, resize screen should be
failed. This alse fix CVE-2020-8649 and CVE-2020-8647.
Linus pointed out that overflow checking seems absent. We're saved by
the existing bounds checks in vc_do_resize() with rather strict
limits:
if (cols > VC_RESIZE_MAXCOL || lines > VC_RESIZE_MAXROW)
return -EINVAL;
Fixes: 0aec4867dca14 ("[PATCH] SVGATextMode fix")
Reference: CVE-2020-8647 and CVE-2020-8649
Signed-off-by: Zhang Xiaoxu <zhangxiaoxu5@huawei.com>
[danvet: augment commit message to point out overflow safety]
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Link: https://patchwork.freedesktop.org/patch/msgid/20200304022429.37738-1-zhangxiaoxu5@huawei.com
commit 1f8b39bc99a31759e97a0428a5c3f64802c1e61d upstream.
Reviewing a fresh portion of coverity defects in USB core
(specifically CID 1458999), Alan Stern noted below in [1]:
On Tue, Feb 25, 2020 at 02:39:23PM -0500, Alan Stern wrote:
> A revised search finds line 997 in drivers/usb/core/hub.c and lines
> 216, 269 in drivers/usb/core/port.c. (I didn't try looking in any
> other directories.) AFAICT all three of these should check the
> return value, although a error message in the kernel log probably
> isn't needed.
Factor out the usb_port_runtime_{resume,suspend}() changes into a
standalone patch to allow conflict-free porting on top of stable v3.9+.
[1] https://lore.kernel.org/lkml/Pine.LNX.4.44L0.2002251419120.1485-100000@iolanthe.rowland.org
Fixes: 971fcd492cebf5 ("usb: add runtime pm support for usb port device")
Cc: stable@vger.kernel.org # v3.9+
Suggested-by: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Eugeniu Rosca <erosca@de.adit-jv.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Link: https://lore.kernel.org/r/20200226175036.14946-3-erosca@de.adit-jv.com
commit 60e3f6e4ac5b0fda43dad01c32e09409ec710045 upstream.
> isn't needed.
Factor out the usb_remove_device() change into a standalone patch to
allow conflict-free integration on top of the earliest stable branches.
Fixes: 253e05724f9230 ("USB: add a "remove hardware" sysfs attribute")
Cc: stable@vger.kernel.org # v2.6.33+
Link: https://lore.kernel.org/r/20200226175036.14946-2-erosca@de.adit-jv.com
commit b96ed52d781a2026d0c0daa5787c6f3d45415862 upstream.
LPM on the device appears to cause xHCI host controllers to claim
that there isn't enough bandwidth to support additional devices.
Signed-off-by: Dan Lazewatsky <dlaz@chromium.org>
Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.com>
Link: https://lore.kernel.org/r/20200226143438.1445-1-gustavo.padovan@collabora.com
commit 86d92f5465958752481269348d474414dccb1552 upstream.
Current driver has 240 (USB2.0) and 2048 (USB3.0) as max_sectors,
e.g., /sys/bus/scsi/devices/0:0:0:0/max_sectors
If data access times out, driver error handling will issue a port
reset.
Sometimes Samsung Fit (090C:1000) flash disk will not respond to
later Set Address or Get Descriptor command.
Adding this quirk to limit max_sectors to 64 sectors to avoid issue
occurring.
Signed-off-by: Jim Lin <jilin@nvidia.com>
Link: https://lore.kernel.org/r/1583158895-31342-1-git-send-email-jilin@nvidia.com
[ Upstream commit 8b101a5e14f2161869636ff9cb4907b7749dc0c2 ]
if seq_file .next fuction does not change position index,
read after some lseek can generate unexpected output.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=206283
Link: https://lore.kernel.org/r/d44c53a7-9bc1-15c7-6d4a-0c10cb9dffce@virtuozzo.com
Reviewed-by: Cornelia Huck <cohuck@redhat.com>
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Signed-off-by: Vasily Averin <vvs@virtuozzo.com>
Signed-off-by: Vasily Gorbik <gor@linux.ibm.com>
[ Upstream commit e9a0e65eda3f78d0b04ec6136c591c000cbc3b76 ]
The da9062 hw has a minimum ping cool down phase of at least 200ms. The
driver takes that into account by setting the min_hw_heartbeat_ms to
300ms and the core guarantees that the hw limit is observed for the
ping() calls. But the core can't guarantee the required minimum ping
cool down phase if a stop() command is send immediately after the ping()
command. So it is not allowed to ping the watchdog within the stop()
command as the driver does. Remove the ping can be done without doubts
because the watchdog gets disabled anyway and a (re)start resets the
watchdog counter too.
Signed-off-by: Marco Felsch <m.felsch@pengutronix.de>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Link: https://lore.kernel.org/r/20200120091729.16256-1-m.felsch@pengutronix.de
[groeck: Updated description]
Signed-off-by: Wim Van Sebroeck <wim@linux-watchdog.org>
[ Upstream commit 58292104832fef6cb4a89f736012c0e0724c3442 ]
The Micrel KSZ8851-16MLLI datasheet DS00002357B page 12 states that
BE[3:0] signals are active high. This contradicts the measurements
of the behavior of the actual chip, where these signals behave as
active low. For example, to read the CIDER register, the bus must
expose 0xc0c0 during the address phase, which means BE[3:0]=4'b1100.
[ Upstream commit edacb098ea9c31589276152f09b4439052c0f2b1 ]
The packet data written to and read from Micrel KSZ8851-16MLLI must be
byte-swapped in 16-bit mode, add this byte-swapping.
[ Upstream commit 69233bba6543a37755158ca3382765387b8078df ]
This driver is mixing 8-bit and 16-bit bus accessors for reasons unknown,
however the speculation is that this was some sort of attempt to support
the 8-bit bus mode.
As per the KS8851-16MLL documentation, all two registers accessed via the
8-bit accessors are internally 16-bit registers, so reading them using
16-bit accessors is fine. The KS_CCR read can be converted to 16-bit read
outright, as it is already a concatenation of two 8-bit reads of that
register. The KS_RXQCR accesses are 8-bit only, however writing the top
8 bits of the register is OK as well, since the driver caches the entire
16-bit register value anyway.
Finally, the driver is not used by any hardware in the kernel right now.
The only hardware available to me is one with 16-bit bus, so I have no
way to test the 8-bit bus mode, however it is unlikely this ever really
worked anyway. If the 8-bit bus mode is ever required, it can be easily
added by adjusting the 16-bit accessors to do 2 consecutive accesses,
which is how this should have been done from the beginning.
[ Upstream commit a1028dcfd0dd97884072288d0c8ed7f30399b528 ]
Save pll state before dsi host is powered off. Without this change
some register values gets resetted.
Signed-off-by: Harigovindan P <harigovi@codeaurora.org>
Signed-off-by: Rob Clark <robdclark@chromium.org>
