This patch is against 4.9. It does not apply to master due to a large
rework of ion in 4.12 which removed the affected functions altogther.
4c23cbff073f3b9b ("staging: android: ion: Remove import interface")
Userspace can cause the kref to handles to increment
arbitrarily high. Ensure it does not overflow.
Signed-off-by: Daniel Rosenberg <drosen@google.com>
commit 8f3fafc9c2f0ece10832c25f7ffcb07c97a32ad4 upstream.
Like d88b6d04: "cdrom: information leak in cdrom_ioctl_media_changed()"
There is another cast from unsigned long to int which causes
a bounds check to fail with specially crafted input. The value is
then used as an index in the slot array in cdrom_slot_status().
Signed-off-by: Scott Bauer <scott.bauer@intel.com>
Signed-off-by: Scott Bauer <sbauer@plzdonthack.me>
Cc: stable@vger.kernel.org
channels
commit a427503edaaed9b75ed9746a654cece7e93e60a8 upstream.
If an iio channel defines a basic property, there are duplicate entries
in /sys/class/power/*/uevent.
So add a check to avoid duplicates. Since all channels may be duplicates,
we have to modify the related error check.
Signed-off-by: H. Nikolaus Schaller <hns@goldelico.com>
Fixes: e60fea794e6e ("power: battery: Generic battery driver using IIO")
Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
properties
commit 932d47448c3caa0fa99e84d7f5bc302aa286efd8 upstream.
We did have sporadic problems in the pinctrl framework during boot
where a pin group name unexpectedly became NULL leading to a NULL
dereference in strcmp.
Detailled analysis of the failing cases did reveal that there were
two devm allocated objects close to each other. The second one was
the affected group_desc in pinmux and the first one was the
psy_desc->properties buffer of the gab driver.
Review of the gab code showed that the address calculation for
one memcpy() is wrong. It does
properties + sizeof(type) * index
but C is defined to do the index multiplication already for
pointer + integer additions. Hence the factor was applied twice
and the memcpy() does write outside of the properties buffer.
Sometimes it happened to be the pinctrl and triggered the strcmp(NULL).
Anyways, it is overkill to use a memcpy() here instead of a simple
assignment, which is easier to read and has less risk for wrong
address calculations. So we change code to a simple assignment.
If we initialize the index to the first free location, we can even
remove the local variable 'properties'.
This bug seems to exist right from the beginning in 3.7-rc1 in
commit e60fea794e6e ("power: battery: Generic battery driver using IIO")
commit 5e2e2f9f76e157063a656351728703cb02b068f1 upstream.
"count" needs to be signed for the error handling to work. I made "i"
signed as well so they match.
Fixes: 02113ba93ea4 (PM / clk: Add support for obtaining clocks from device-tree)
Cc: 4.6+ <stable@vger.kernel.org> # 4.6+
commit a64ad008980c65d38e6cf6858429c78e6b740c41 upstream.
Register, shift and mask were wrong according to datasheet.
Fixes: 115510053e5e ("clk: rockchip: add clock controller for the RK3399")
Signed-off-by: Alberto Panizzo <alberto@amarulasolutions.com>
Signed-off-by: Anthony Brandon <anthony@amarulasolutions.com>
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
commit 26abc916a898d34c5ad159315a2f683def3c5555 upstream.
The problem is that iscsi_login_zero_tsih_s1 sets conn->sess early in
iscsi_login_set_conn_values. If the function fails later like when we
alloc the idr it does kfree(sess) and leaves the conn->sess pointer set.
iscsi_login_zero_tsih_s1 then returns -Exyz and we then call
iscsi_target_login_sess_out and access the freed memory.
This patch has iscsi_login_zero_tsih_s1 either completely setup the
session or completely tear it down, so later in
iscsi_target_login_sess_out we can just check for it being set to the
connection.
Fixes: 0957627a9960 ("iscsi-target: Fix sess allocation leak in...")
Signed-off-by: Mike Christie <mchristi@redhat.com>
Acked-by: Martin K. Petersen <martin.petersen@oracle.com>
Signed-off-by: Matthew Wilcox <willy@infradead.org>
commit 0ee223b2e1f67cb2de9c0e3247c510d846e74d63 upstream.
A long time ago the unfortunate decision was taken to add a self-deletion
attribute to the sysfs SCSI device directory. That decision was unfortunate
because self-deletion is really tricky. We can't drop that attribute
because widely used user space software depends on it, namely the
rescan-scsi-bus.sh script. Hence this patch that avoids that writing into
that attribute triggers a deadlock. See also commit 7973cbd9fbd9 ("[PATCH]
add sysfs attributes to scan and delete scsi_devices").
This patch avoids that self-removal triggers the following deadlock:
WARNING: possible circular locking dependency detected
4.18.0-rc2-dbg+ #5 Not tainted
modprobe/6539 is trying to acquire lock:
000000008323c4cd (kn->count#202){++++}, at: kernfs_remove_by_name_ns+0x45/0x90
but task is already holding lock:
00000000a6ec2c69 (&shost->scan_mutex){+.+.}, at: scsi_remove_host+0x21/0x150 [scsi_mod]
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #1 (&shost->scan_mutex){+.+.}:
__mutex_lock+0xfe/0xc70
mutex_lock_nested+0x1b/0x20
scsi_remove_device+0x26/0x40 [scsi_mod]
sdev_store_delete+0x27/0x30 [scsi_mod]
dev_attr_store+0x3e/0x50
sysfs_kf_write+0x87/0xa0
kernfs_fop_write+0x190/0x230
__vfs_write+0xd2/0x3b0
vfs_write+0x101/0x270
ksys_write+0xab/0x120
__x64_sys_write+0x43/0x50
do_syscall_64+0x77/0x230
entry_SYSCALL_64_after_hwframe+0x49/0xbe
-> #0 (kn->count#202){++++}:
lock_acquire+0xd2/0x260
__kernfs_remove+0x424/0x4a0
remove_files.isra.1+0x3a/0x90
sysfs_remove_group+0x5c/0xc0
sysfs_remove_groups+0x39/0x60
device_remove_attrs+0x82/0xb0
device_del+0x251/0x580
__scsi_remove_device+0x19f/0x1d0 [scsi_mod]
scsi_forget_host+0x37/0xb0 [scsi_mod]
scsi_remove_host+0x9b/0x150 [scsi_mod]
sdebug_driver_remove+0x4b/0x150 [scsi_debug]
device_release_driver_internal+0x241/0x360
device_release_driver+0x12/0x20
bus_remove_device+0x1bc/0x290
device_del+0x259/0x580
device_unregister+0x1a/0x70
sdebug_remove_adapter+0x8b/0xf0 [scsi_debug]
scsi_debug_exit+0x76/0xe8 [scsi_debug]
__x64_sys_delete_module+0x1c1/0x280
Possible unsafe locking scenario:
CPU0 CPU1
lock(&shost->scan_mutex);
lock(kn->count#202);
*** DEADLOCK ***
2 locks held by modprobe/6539:
#0: 00000000efaf9298 (&dev->mutex){....}, at: device_release_driver_internal+0x68/0x360
#1: 00000000a6ec2c69 (&shost->scan_mutex){+.+.}, at: scsi_remove_host+0x21/0x150 [scsi_mod]
stack backtrace:
CPU: 10 PID: 6539 Comm: modprobe Not tainted 4.18.0-rc2-dbg+ #5
Hardware name: QEMU Standard PC (Q35 + ICH9, 2009), BIOS 1.0.0-prebuilt.qemu-project.org 04/01/2014
Call Trace:
dump_stack+0xa4/0xf5
print_circular_bug.isra.34+0x213/0x221
__lock_acquire+0x1a7e/0x1b50
See also https://www.mail-archive.com/linux-scsi@vger.kernel.org/msg54525.html.
Fixes: ac0ece9174ac ("scsi: use device_remove_file_self() instead of device_schedule_callback()")
Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com>
Acked-by: Tejun Heo <tj@kernel.org>
Cc: Johannes Thumshirn <jthumshirn@suse.de>
Cc: <stable@vger.kernel.org>
commit 64e03ff72623b8c2ea89ca3cb660094e019ed4ae upstream.
When allocating a new AOB fails, handle_outbound() is still capable of
transmitting the selected buffer (just without async completion).
But if a previous transfer on this queue slot used async completion, its
sbal_state flags field is still set to QDIO_OUTBUF_STATE_FLAG_PENDING.
So when the upper layer driver sees this stale flag, it expects an async
completion that never happens.
Fix this by unconditionally clearing the flags field.
Fixes: 104ea556ee7f ("qdio: support asynchronous delivery of storage blocks")
Cc: <stable@vger.kernel.org> #v3.2+
Signed-off-by: Julian Wiedmann <jwi@linux.ibm.com>
commit 19da44cd33a3a6ff7c97fff0189999ff15b241e4 upstream.
The info->groups[] array is allocated in imx1_pinctrl_parse_dt(). It
has info->ngroups elements. Thus the > here should be >= to prevent
reading one element beyond the end of the array.
Fixes: 30612cd90005 ("pinctrl: imx1 core driver")
Reviewed-by: Uwe Kleine-König <u.kleine-könig@pengutronix.de>
Acked-by: Dong Aisheng <Aisheng.dong@nxp.com>
commit 2aa650d1950fce94f696ebd7db30b8830c2c946f upstream.
strncpy might not NUL-terminate the string, if the name equals the buffer size.
Use strlcpy instead.
Signed-off-by: Michael Buesch <m@bues.ch>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
commit 4d77a89e3924b12f4a5628b21237e57ab4703866 upstream.
commit 09a00abe3a9941c2715ca83eb88172cd2f54d8fd upstream.
We must use kzalloc when allocating the fb_deferred_io structure.
Otherwise, the field first_io is undefined and it causes a crash.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
commit 542bb9788a1f485eb1a2229178f665d8ea166156 upstream.
Allocations larger than PAGE_ALLOC_COSTLY_ORDER are unreliable and they
may fail anytime. This patch fixes the udl kms driver so that when a large
alloactions fails, it tries to do multiple smaller allocations.
commit 8456b99c16d193c4c3b7df305cf431e027f0189c upstream.
If we leave urbs around, it causes not only leak, but also memory
corruption. This patch fixes the function udl_free_urb_list, so that it
always waits for all urbs that are in progress.
This patch is 4.9.y only. Kernels 4.12 and later are unaffected, since
all the underlying ion_handle infrastructure has been ripped out.
The ION_IOC_{MAP,SHARE} ioctls drop and reacquire client->lock several
times while operating on one of the client's ion_handles. This creates
windows where userspace can call ION_IOC_FREE on the same client with
the same handle, and effectively make the kernel drop its own reference.
For example:
- thread A: ION_IOC_ALLOC creates an ion_handle with refcount 1
- thread A: starts ION_IOC_MAP and increments the refcount to 2
- thread B: ION_IOC_FREE decrements the refcount to 1
- thread B: ION_IOC_FREE decrements the refcount to 0 and frees the
handle
- thread A: continues ION_IOC_MAP with a dangling ion_handle * to
freed memory
Fix this by holding client->lock for the duration of
ION_IOC_{MAP,SHARE}, preventing the concurrent ION_IOC_FREE. Also
remove ion_handle_get_by_id(), since there's literally no way to use it
safely.
Cc: stable@vger.kernel.org # v4.11-
Signed-off-by: Greg Hackmann <ghackmann@google.com>
commit a103af1b64d74853a5e08ca6c86aeb0e5c6ca4f1 upstream.
MEI enables writes of complete messages only
while read can be performed in parts, hence
write should not update the file offset to
not break interleaving partial reads with writes.
Signed-off-by: Alexander Usyskin <alexander.usyskin@intel.com>
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
[ Upstream commit e95153b64d03c2b6e8d62e51bdcc33fcad6e0856 ]
Commands that are reset are returned with status
SAM_STAT_COMMAND_TERMINATED. PVSCSI currently returns DID_OK |
SAM_STAT_COMMAND_TERMINATED which fails the command. Instead, set hostbyte
to DID_RESET to allow upper layers to retry.
Tested by copying a large file between two pvscsi disks on same adapter
while performing a bus reset at 1-second intervals. Before fix, commands
sometimes fail with DID_OK. After fix, commands observed to fail with
DID_RESET.
Signed-off-by: Jim Gill <jgill@vmware.com>
[ Upstream commit 1550ec458e0cf1a40a170ab1f4c46e3f52860f65 ]
When receiving a LOGO request we forget to clear the FC_RP_STARTED flag
before starting the rport delete routine.
As the started flag was not cleared, we're not deleting the rport but
waiting for a restart and thus are keeping the reference count of the rdata
object at 1.
This leads to the following kmemleak report:
unreferenced object 0xffff88006542aa00 (size 512):
comm "kworker/0:2", pid 24, jiffies 4294899222 (age 226.880s)
hex dump (first 32 bytes):
68 96 fe 65 00 88 ff ff 00 00 00 00 00 00 00 00 h..e............
01 00 00 00 08 00 00 00 02 c5 45 24 ac b8 00 10 ..........E$....
backtrace:
[<(____ptrval____)>] fcoe_ctlr_vn_add.isra.5+0x7f/0x770 [libfcoe]
[<(____ptrval____)>] fcoe_ctlr_vn_recv+0x12af/0x27f0 [libfcoe]
[<(____ptrval____)>] fcoe_ctlr_recv_work+0xd01/0x32f0 [libfcoe]
[<(____ptrval____)>] process_one_work+0x7ff/0x1420
[<(____ptrval____)>] worker_thread+0x87/0xef0
[<(____ptrval____)>] kthread+0x2db/0x390
[<(____ptrval____)>] ret_from_fork+0x35/0x40
[<(____ptrval____)>] 0xffffffffffffffff
Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de>
Reported-by: ard <ard@kwaak.net>
Reviewed-by: Hannes Reinecke <hare@suse.com>
[ Upstream commit 63d0e3dffda311e77b9a8c500d59084e960a824a ]
Drop the frames in the ELS LOGO error path instead of just returning an
error.
This fixes the following kmemleak report:
unreferenced object 0xffff880064cb1000 (size 424):
comm "kworker/0:2", pid 24, jiffies 4294904293 (age 68.504s)
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<(____ptrval____)>] _fc_frame_alloc+0x2c/0x180 [libfc]
[<(____ptrval____)>] fc_lport_enter_logo+0x106/0x360 [libfc]
[<(____ptrval____)>] fc_fabric_logoff+0x8c/0xc0 [libfc]
[<(____ptrval____)>] fcoe_if_destroy+0x79/0x3b0 [fcoe]
[<(____ptrval____)>] fcoe_destroy_work+0xd2/0x170 [fcoe]
which can be triggered by issuing
echo eth0 > /sys/bus/fcoe/ctlr_destroy
[ Upstream commit afb41bb039656f0cecb54eeb8b2e2088201295f5 ]
Current value for a target abort error is 0x010, however, this value
should in fact be 0x002. As it stands, the range of error is 0..7 so
it is currently never being detected. This bug has been in the driver
since the early 2.6.12 days (or before).
Detected by CoverityScan, CID#744290 ("Logically dead code")
[ Upstream commit ab123fe071c9aa9680ecd62eb080eb26cff4892c ]
When driver gets notification for mtu change, driver does not handle it for
all RQs. It handles only RQ[0].
Fix is to use enic_change_mtu() interface to change mtu for vf.
Signed-off-by: Govindarajulu Varadarajan <gvaradar@cisco.com>
[ Upstream commit 03bc7cab7d7218088412a75e141696a89059ab00 ]
If the registration fails then mdio_unregister is called.
However at unbind the unregister ia attempted again resulting
in the below crash
[ 73.544038] kernel BUG at drivers/net/phy/mdio_bus.c:415!
[ 73.549362] Internal error: Oops - BUG: 0 [#1] SMP
[ 73.554127] Modules linked in:
[ 73.557168] CPU: 0 PID: 2249 Comm: sh Not tainted 4.14.0 #183
[ 73.562895] Hardware name: xlnx,zynqmp (DT)
[ 73.567062] task: ffffffc879e41180 task.stack: ffffff800cbe0000
[ 73.572973] PC is at mdiobus_unregister+0x84/0x88
[ 73.577656] LR is at axienet_mdio_teardown+0x18/0x30
[ 73.582601] pc : [<ffffff80085fa4cc>] lr : [<ffffff8008616858>]
pstate: 20000145
[ 73.589981] sp : ffffff800cbe3c30
[ 73.593277] x29: ffffff800cbe3c30 x28: ffffffc879e41180
[ 73.598573] x27: ffffff8008a21000 x26: 0000000000000040
[ 73.603868] x25: 0000000000000124 x24: ffffffc879efe920
[ 73.609164] x23: 0000000000000060 x22: ffffffc879e02000
[ 73.614459] x21: ffffffc879e02800 x20: ffffffc87b0b8870
[ 73.619754] x19: ffffffc879e02800 x18: 000000000000025d
[ 73.625050] x17: 0000007f9a719ad0 x16: ffffff8008195bd8
[ 73.630345] x15: 0000007f9a6b3d00 x14: 0000000000000010
[ 73.635640] x13: 74656e7265687465 x12: 0000000000000030
[ 73.640935] x11: 0000000000000030 x10: 0101010101010101
[ 73.646231] x9 : 241f394f42533300 x8 : ffffffc8799f6e98
[ 73.651526] x7 : ffffffc8799f6f18 x6 : ffffffc87b0ba318
[ 73.656822] x5 : ffffffc87b0ba498 x4 : 0000000000000000
[ 73.662117] x3 : 0000000000000000 x2 : 0000000000000008
[ 73.667412] x1 : 0000000000000004 x0 : ffffffc8799f4000
[ 73.672708] Process sh (pid: 2249, stack limit = 0xffffff800cbe0000)
Fix the same by making the bus NULL on unregister.
Signed-off-by: Shubhrajyoti Datta <shubhrajyoti.datta@xilinx.com>
[ Upstream commit f25e1392fdb556290957142ac2da33a02cbff403 ]
The original mapping for the DW5821e was done using a development
version of the firmware. Confirmed with the vendor that the final
USB layout ends up exposing the QMI control/data ports in USB
config #1, interface #0, not in interface #1 (which is now a HID
interface).
T: Bus=01 Lev=03 Prnt=04 Port=00 Cnt=01 Dev#= 16 Spd=480 MxCh= 0
D: Ver= 2.10 Cls=ef(misc ) Sub=02 Prot=01 MxPS=64 #Cfgs= 2
P: Vendor=413c ProdID=81d7 Rev=03.18
S: Manufacturer=DELL
S: Product=DW5821e Snapdragon X20 LTE
S: SerialNumber=0123456789ABCDEF
C: #Ifs= 6 Cfg#= 1 Atr=a0 MxPwr=500mA
I: If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=qmi_wwan
I: If#= 1 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=00 Prot=00 Driver=usbhid
I: If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
I: If#= 3 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
I: If#= 4 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
I: If#= 5 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=option
Fixes: e7e197edd09c25 ("qmi_wwan: add support for the Dell Wireless 5821e module")
Signed-off-by: Aleksander Morgado <aleksander@aleksander.es>
Acked-by: Bjørn Mork <bjorn@mork.no>
[ Upstream commit ae2dcb28c24794a87e424a726a1cf1a61980f52d ]
Rx hash/filter table configuration uses rss_conf_obj to configure filters
in the hardware. This object is initialized only when the interface is
brought up.
This patch adds driver changes to configure rss params only when the device
is in opened state. In port disabled case, the config will be cached in the
driver structure which will be applied in the successive load path.
Please consider applying it to 'net' branch.
Signed-off-by: Sudarsana Reddy Kalluru <Sudarsana.Kalluru@cavium.com>
[ Upstream commit 0894da849f145af51bde88a6b84f95b9c9e0bc66 ]
Including asm/cacheflush.h first results in the following build error
when trying to build sparc32:allmodconfig, because 'struct page' has not
been declared, and the function declaration ends up creating a separate
(private) declaration of struct page (as a result of function arguments
being in the scope of the function declaration and definition, not in
global scope).
The C scoping rules do not just affect variable visibility, they also
affect type declaration visibility.
The end result is that when the actual call site is seen in
<linux/highmem.h>, the 'struct page' type in the caller is not the same
'struct page' that the function was declared with, resulting in:
In file included from arch/sparc/include/asm/page.h:10:0,
from drivers/staging/media/omap4iss/iss_video.c:15:
include/linux/highmem.h: In function 'clear_user_highpage':
include/linux/highmem.h:137:31: error:
passing argument 1 of 'sparc_flush_page_to_ram' from incompatible
pointer type
Include generic includes files first to fix the problem.
Fixes: fc96d58c10162 ("[media] v4l: omap4iss: Add support for OMAP4 camera interface - Video devices")
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Randy Dunlap <rdunlap@infradead.org>
[ Added explanation of C scope rules - Linus ]
[ Upstream commit cc8de9a68599b261244ea453b38678229f06ada7 ]
If CLKH is set to 0 I2C clock is not generated at all, so avoid this value
and stretch the clock in this case.
Signed-off-by: Alexander Sverdlin <alexander.sverdlin@nokia.com>
Acked-by: Sekhar Nori <nsekhar@ti.com>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
[ Upstream commit b5c1a23b17e563b656cc9bb76ce5323b997d90e8 ]
of_iomap() can return NULL so that return needs to be checked and NULL
treated as failure. While at it also take care of the missing
of_node_put() in the error path.
Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org>
Fixes: commit afa17a500a36 ("net/can: add driver for mscan family & mpc52xx_mscan")
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
[ Upstream commit c9ce1fa1c24b08e13c2a3b5b1f94a19c9eaa982c ]
Prevent drivers from building on PPC32 if they use isa_bus_to_virt(),
isa_virt_to_bus(), or isa_page_to_bus(), which are not available and
thus cause build errors.
../drivers/net/ethernet/3com/3c515.c: In function 'corkscrew_open':
../drivers/net/ethernet/3com/3c515.c:824:9: error: implicit declaration of function 'isa_virt_to_bus'; did you mean 'virt_to_bus'? [-Werror=implicit-function-declaration]
../drivers/net/ethernet/amd/lance.c: In function 'lance_rx':
../drivers/net/ethernet/amd/lance.c:1203:23: error: implicit declaration of function 'isa_bus_to_virt'; did you mean 'bus_to_virt'? [-Werror=implicit-function-declaration]
../drivers/net/ethernet/amd/ni65.c: In function 'ni65_init_lance':
../drivers/net/ethernet/amd/ni65.c:585:20: error: implicit declaration of function 'isa_virt_to_bus'; did you mean 'virt_to_bus'? [-Werror=implicit-function-declaration]
../drivers/net/ethernet/cirrus/cs89x0.c: In function 'net_open':
../drivers/net/ethernet/cirrus/cs89x0.c:897:20: error: implicit declaration of function 'isa_virt_to_bus'; did you mean 'virt_to_bus'? [-Werror=implicit-function-declaration]
Suggested-by: Michael Ellerman <mpe@ellerman.id.au>
[ Upstream commit 6e56830776828d8ca9897fc4429eeab47c3bb432 ]
Got crash report with following backtrace:
BUG: unable to handle kernel paging request at ffff8801869daffe
RIP: 0010:[<ffffffff816429c4>] [<ffffffff816429c4>] ip6_finish_output2+0x394/0x4c0
RSP: 0018:ffff880186c83a98 EFLAGS: 00010283
RAX: ffff8801869db00e ...
[<ffffffff81644cdc>] ip6_finish_output+0x8c/0xf0
[<ffffffff81644d97>] ip6_output+0x57/0x100
[<ffffffff81643dc9>] ip6_forward+0x4b9/0x840
[<ffffffff81645566>] ip6_rcv_finish+0x66/0xc0
[<ffffffff81645db9>] ipv6_rcv+0x319/0x530
[<ffffffff815892ac>] netif_receive_skb+0x1c/0x70
[<ffffffffc0060bec>] atl1c_clean+0x1ec/0x310 [atl1c]
The bad access is in neigh_hh_output(), at skb->data - 16 (HH_DATA_MOD).
atl1c driver provided skb with no headroom, so 14 bytes (ethernet
header) got pulled, but then 16 are copied.
Reserve NET_SKB_PAD bytes headroom, like netdev_alloc_skb().
Compile tested only; I lack hardware.
Fixes: 7b7017642199 ("atl1c: Fix misuse of netdev_alloc_skb in refilling rx ring")
Reviewed-by: Eric Dumazet <edumazet@google.com>
[ Upstream commit 25c020a90919632b3425c19dc09188d56b9ed59a ]
FW hsi contains 256 approximation buckets which are split in ramrod into
eight u32 values, but driver is using eight 'unsigned long' variables.
This patch fixes the mcast logic by making the API utilize u32.
Fixes: 83aeb933 ("qed*: Trivial modifications")
Signed-off-by: Ariel Elior <ariel.elior@cavium.com>
Signed-off-by: Michal Kalderon <Michal.Kalderon@cavium.com>
[ Upstream commit 58874c7b246109d8efb2b0099d1aa296d6bfc3fa ]
There's a possible race where driver can read link status in mid-transition
and see that virtual-link is up yet speed is 0. Since in this
mid-transition we're guaranteed to see a mailbox from MFW soon, we can
afford to treat this as link down.
Fixes: cc875c2e ("qed: Add link support")
[ Upstream commit eec24f2a0d4dc3b1d95a3ccd2feb523ede3ba775 ]
The list [1] of commits doing endianness fixes in USB subsystem is long
due to below quote from USB spec Revision 2.0 from April 27, 2000:
8.1 Byte/Bit Ordering
Multiple byte fields in standard descriptors, requests, and responses
are interpreted as and moved over the bus in little-endian order, i.e.
LSB to MSB.
This commit belongs to the same family.
[1] Example of endianness fixes in USB subsystem:
commit 14e1d56cbea6 ("usb: gadget: f_uac2: endianness fixes.")
commit 42370b821168 ("usb: gadget: f_uac1: endianness fixes.")
commit 63afd5cc7877 ("USB: chaoskey: fix Alea quirk on big-endian hosts")
commit 74098c4ac782 ("usb: gadget: acm: fix endianness in notifications")
commit cdd7928df0d2 ("ACM gadget: fix endianness in notifications")
commit 323ece54e076 ("cdc-wdm: fix endianness bug in debug statements")
commit e102609f1072 ("usb: gadget: uvc: Fix endianness mismatches")
list goes on
Fixes: 132fcb460839 ("usb: gadget: Add Audio Class 2.0 Driver")
Signed-off-by: Eugeniu Rosca <erosca@de.adit-jv.com>
Reviewed-by: Ruslan Bilovol <ruslan.bilovol@gmail.com>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
[ Upstream commit a39ba90a1cc7010edb0a7132e1b67f3d80b994e9 ]
Fix build errors when built for PPC64:
These variables are only used on PPC32 so they don't need to be
initialized for PPC64.
../drivers/usb/phy/phy-fsl-usb.c: In function 'usb_otg_start':
../drivers/usb/phy/phy-fsl-usb.c:865:3: error: '_fsl_readl' undeclared (first use in this function); did you mean 'fsl_readl'?
_fsl_readl = _fsl_readl_be;
../drivers/usb/phy/phy-fsl-usb.c:865:16: error: '_fsl_readl_be' undeclared (first use in this function); did you mean 'fsl_readl'?
../drivers/usb/phy/phy-fsl-usb.c:866:3: error: '_fsl_writel' undeclared (first use in this function); did you mean 'fsl_writel'?
_fsl_writel = _fsl_writel_be;
../drivers/usb/phy/phy-fsl-usb.c:866:17: error: '_fsl_writel_be' undeclared (first use in this function); did you mean 'fsl_writel'?
../drivers/usb/phy/phy-fsl-usb.c:868:16: error: '_fsl_readl_le' undeclared (first use in this function); did you mean 'fsl_readl'?
_fsl_readl = _fsl_readl_le;
../drivers/usb/phy/phy-fsl-usb.c:869:17: error: '_fsl_writel_le' undeclared (first use in this function); did you mean 'fsl_writel'?
_fsl_writel = _fsl_writel_le;
and the sysfs "show" function return type should be ssize_t, not int:
../drivers/usb/phy/phy-fsl-usb.c:1042:49: error: initialization of 'ssize_t (*)(struct device *, struct device_attribute *, char *)' {aka 'long int (*)(struct device *, struct device_attribute *, char *)'} from incompatible pointer type 'int (*)(struct device *, struct device_attribute *, char *)' [-Werror=incompatible-pointer-types]
static DEVICE_ATTR(fsl_usb2_otg_state, S_IRUGO, show_fsl_usb2_otg_state, NULL);
Cc: Felipe Balbi <balbi@kernel.org>
Cc: linux-usb@vger.kernel.org
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: linuxppc-dev@lists.ozlabs.org
r8a66597_queue()
[ Upstream commit f36b507c14c4b6e634463a610294e9cb0065c8ea ]
The driver may sleep in an interrupt handler.
The function call path (from bottom to top) in Linux-4.16.7 is:
[FUNC] r8a66597_queue(GFP_KERNEL)
drivers/usb/gadget/udc/r8a66597-udc.c, 1193:
r8a66597_queue in get_status
drivers/usb/gadget/udc/r8a66597-udc.c, 1301:
get_status in setup_packet
drivers/usb/gadget/udc/r8a66597-udc.c, 1381:
setup_packet in irq_control_stage
drivers/usb/gadget/udc/r8a66597-udc.c, 1508:
irq_control_stage in r8a66597_irq (interrupt handler)
To fix this bug, GFP_KERNEL is replaced with GFP_ATOMIC.
This bug is found by my static analysis tool (DSAC-2) and checked by
my code review.
Signed-off-by: Jia-Ju Bai <baijiaju1990@gmail.com>
init_controller()
[ Upstream commit 0602088b10a7c0b4e044a810678ef93d7cc5bf48 ]
The driver may sleep with holding a spinlock.
The function call paths (from bottom to top) in Linux-4.16.7 are:
[FUNC] msleep
drivers/usb/gadget/udc/r8a66597-udc.c, 839:
msleep in init_controller
drivers/usb/gadget/udc/r8a66597-udc.c, 96:
init_controller in r8a66597_usb_disconnect
drivers/usb/gadget/udc/r8a66597-udc.c, 93:
spin_lock in r8a66597_usb_disconnect
[FUNC] msleep
drivers/usb/gadget/udc/r8a66597-udc.c, 835:
To fix these bugs, msleep() is replaced with mdelay().
my code review.
[ Upstream commit c80d673b91a6c81d765864e10f2b15110ee900ad ]
If the second LVDS channel has been disabled in the DT when using dual-channel
mode we should not print a warning.
Signed-off-by: Lucas Stach <l.stach@pengutronix.de>
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
[ Upstream commit b58262396fabd43dc869b576e3defdd23b32fe94 ]
The LVDS signal integrity is only guaranteed when the correct enable
sequence (first IPU DI, then LDB) is used. If the LDB display output was
active before the imx-drm driver is loaded (like when a bootsplash was
active) the DI will be disabled by the full IPU reset we do when loading
the driver. The LDB control registers are not part of the IPU range and
thus will remain unchanged.
This leads to the LDB still being active when the DI is getting enabled,
effectively reversing the required enable sequence. Fix this by also
disabling the LDB on driver bind.
[ Upstream commit a17037e7d59075053b522048742a08ac9500bde8 ]
In iscsi_check_tmf_restrictions() task->hdr is dereferenced to print the
opcode, it is possible that task->hdr is NULL.
There are two cases based on opcode argument:
1. ISCSI_OP_SCSI_CMD - In this case alloc_pdu() is called
after iscsi_check_tmf_restrictions()
iscsi_prep_scsi_cmd_pdu() -> iscsi_check_tmf_restrictions() -> alloc_pdu().
Transport drivers allocate memory for iSCSI hdr in alloc_pdu() and assign
it to task->hdr. In case of TMF task->hdr will be NULL resulting in NULL
pointer dereference.
2. ISCSI_OP_SCSI_DATA_OUT - In this case transport driver can free the
memory for iSCSI hdr after transmitting the pdu so task->hdr can be NULL or
invalid.
This patch fixes this issue by removing task->hdr->opcode from the printk
statement.
Signed-off-by: Varun Prakash <varun@chelsio.com>
[ Upstream commit 5f3417569165a8ee57654217f73e0160312f409c ]
The bridge loses its hw state when the cable is unplugged. If we detect
this case in the hpd handler, reset its state.
Reported-by: Rob Clark <robdclark@gmail.com>
Tested-by: Rob Clark <robdclark@gmail.com>
Reviewed-by: Archit Taneja <architt@codeaurora.org>
Signed-off-by: Sean Paul <seanpaul@chromium.org>
Link: https://patchwork.freedesktop.org/patch/msgid/20180703165648.120401-1-seanpaul@chromium.org
commit bed4ff1ed4d8f2ef5007c5c6ae1b29c5677a3632 upstream.
This fixes a race condition, where the DMAEN bit ends up being set after
I2C slave has transmitted a byte following the dummy read. When that
happens, an interrupt is generated instead, and no DMA request is generated
to kickstart the DMA read, and a timeout happens after DMA_TIMEOUT (1 sec).
Fixed by setting the DMAEN bit before the dummy read.
Signed-off-by: Esben Haabendal <eha@deif.com>
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Cc: stable@kernel.org
commit 1204e35bedf4e5015cda559ed8c84789a6dae24e upstream.
Commit b440bde74f04 ("PCI: Add pci_ignore_hotplug() to ignore hotplug
events for a device") iterates over the devices on a hotplug port's
subordinate bus in pciehp's IRQ handler without acquiring pci_bus_sem.
It is thus possible for a user to cause a crash by concurrently
manipulating the device list, e.g. by disabling slot power via sysfs
on a different CPU or by initiating a remove/rescan via sysfs.
This can't be fixed by acquiring pci_bus_sem because it may sleep.
The simplest fix is to avoid the list iteration altogether and just
check the ignore_hotplug flag on the port itself. This works because
pci_ignore_hotplug() sets the flag both on the device as well as on its
parent bridge.
We do lose the ability to print the name of the device blocking hotplug
in the debug message, but that's probably bearable.
Fixes: b440bde74f04 ("PCI: Add pci_ignore_hotplug() to ignore hotplug events for a device")
Signed-off-by: Lukas Wunner <lukas@wunner.de>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
commit 281e878eab191cce4259abbbf1a0322e3adae02c upstream.
When pciehp is unbound (e.g. on unplug of a Thunderbolt device), the
hotplug_slot struct is deregistered and thus freed before freeing the
IRQ. The IRQ handler and the work items it schedules print the slot
name referenced from the freed structure in various informational and
debug log messages, each time resulting in a quadruple dereference of
freed pointers (hotplug_slot -> pci_slot -> kobject -> name).
At best the slot name is logged as "(null)", at worst kernel memory is
exposed in logs or the driver crashes:
pciehp 0000:10:00.0:pcie204: Slot((null)): Card not present
An attacker may provoke the bug by unplugging multiple devices on a
Thunderbolt daisy chain at once. Unplugging can also be simulated by
powering down slots via sysfs. The bug is particularly easy to trigger
in poll mode.
It has been present since the driver's introduction in 2004:
https://git.kernel.org/tglx/history/c/c16b4b14d980
Fix by rearranging teardown such that the IRQ is freed first. Run the
work items queued by the IRQ handler to completion before freeing the
hotplug_slot struct by draining the work queue from the ->release_slot
callback which is invoked by pci_hp_deregister().
Cc: stable@vger.kernel.org # v2.6.4
commit 3dbe97efe8bf450b183d6dee2305cbc032e6b8a4 upstream.
PCIe r4.0, sec 9.3.5.4, "Device Control Register", shows both
Max_Payload_Size (MPS) and Max_Read_request_Size (MRRS) to be 'RsvdP' for
VFs. Just prior to the table it states:
"PF and VF functionality is defined in Section 7.5.3.4 except where
noted in Table 9-16. For VF fields marked 'RsvdP', the PF setting
applies to the VF."
All of which implies that with respect to Max_Payload_Size Supported
(MPSS), MPS, and MRRS values, we should not be paying any attention to the
VF's fields, but rather only to the PF's. Only looking at the PF's fields
also logically makes sense as it's the sole physical interface to the PCIe
bus.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=200527
Fixes: 27d868b5e6cf ("PCI: Set MPS to match upstream bridge")
Signed-off-by: Myron Stowe <myron.stowe@redhat.com>
Cc: stable@vger.kernel.org # 4.3+
Cc: Keith Busch <keith.busch@intel.com>
Cc: Sinan Kaya <okaya@kernel.org>
Cc: Dongdong Liu <liudongdong3@huawei.com>
Cc: Jon Mason <jdmason@kudzu.us>
commit 4ce6435820d1f1cc2c2788e232735eb244bcc8a3 upstream.
If addition of sysfs files fails on registration of a hotplug slot, the
struct pci_slot as well as the entry in the slot_list is leaked. The
issue has been present since the hotplug core was introduced in 2002:
https://git.kernel.org/tglx/history/c/a8a2069f432c
Perhaps the idea was that even though sysfs addition fails, the slot
should still be usable. But that's not how drivers use the interface,
they abort probe if a non-zero value is returned.
Cc: stable@vger.kernel.org # v2.4.15+
Cc: Greg Kroah-Hartman <greg@kroah.com>
[ Upstream commit 50973993260a6934f0a00da53d9b746cfbea89ab ]
In cases the probing fails the log level of the messages should
be an error.
Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com>
[ Upstream commit 711c62dfa6bdb4326ca6c587f295ea5c4f7269de ]
In case the SPI thread is not running, a simple reset of sync
state won't fix the transmit timeout. We also need to wake up the kernel
thread.
Fixes: ed7d42e24eff ("net: qca_spi: fix transmit queue timeout handling")
[ Upstream commit b2bab426dc715de147f8039a3fccff27d795f4eb ]
As long as the synchronization with the QCA7000 isn't finished, we
cannot accept packets from the upper layers. So let the SPI thread
enable the TX queue after sync and avoid unwanted packet drop.
Fixes: 291ab06ecf67 ("net: qualcomm: new Ethernet over SPI driver for QCA7000")
[ Upstream commit 0018b265adf7e251f90d3ca1c7c0e32e2a0ad262 ]
When testing the R-Car PCIe driver on the Condor board, if the PCIe PHY
driver was left disabled, the kernel crashed with this BUG:
kernel BUG at lib/ioremap.c:72!
Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
Modules linked in:
CPU: 0 PID: 39 Comm: kworker/0:1 Not tainted 4.17.0-dirty #1092
Hardware name: Renesas Condor board based on r8a77980 (DT)
Workqueue: events deferred_probe_work_func
pstate: 80000005 (Nzcv daif -PAN -UAO)
pc : ioremap_page_range+0x370/0x3c8
lr : ioremap_page_range+0x40/0x3c8
sp : ffff000008da39e0
x29: ffff000008da39e0 x28: 00e8000000000f07
x27: ffff7dfffee00000 x26: 0140000000000000
x25: ffff7dfffef00000 x24: 00000000000fe100
x23: ffff80007b906000 x22: ffff000008ab8000
x21: ffff000008bb1d58 x20: ffff7dfffef00000
x19: ffff800009c30fb8 x18: 0000000000000001
x17: 00000000000152d0 x16: 00000000014012d0
x15: 0000000000000000 x14: 0720072007200720
x13: 0720072007200720 x12: 0720072007200720
x11: 0720072007300730 x10: 00000000000000ae
x9 : 0000000000000000 x8 : ffff7dffff000000
x7 : 0000000000000000 x6 : 0000000000000100
x5 : 0000000000000000 x4 : 000000007b906000
x3 : ffff80007c61a880 x2 : ffff7dfffeefffff
x1 : 0000000040000000 x0 : 00e80000fe100f07
Process kworker/0:1 (pid: 39, stack limit = 0x (ptrval))
Call trace:
pci_remap_iospace+0x7c/0xac
pci_parse_request_of_pci_ranges+0x13c/0x190
rcar_pcie_probe+0x4c/0xb04
platform_drv_probe+0x50/0xbc
driver_probe_device+0x21c/0x308
__device_attach_driver+0x98/0xc8
bus_for_each_drv+0x54/0x94
__device_attach+0xc4/0x12c
device_initial_probe+0x10/0x18
bus_probe_device+0x90/0x98
deferred_probe_work_func+0xb0/0x150
process_one_work+0x12c/0x29c
worker_thread+0x200/0x3fc
kthread+0x108/0x134
ret_from_fork+0x10/0x18
Code: f9004ba2 54000080 aa0003fb 17ffff48 (d4210000)
It turned out that pci_remap_iospace() wasn't undone when the driver's
probe failed, and since devm_phy_optional_get() returned -EPROBE_DEFER,
the probe was retried, finally causing the BUG due to trying to remap
already remapped pages.
The Versatile PCI controller driver has the same issue.
Replace pci_remap_iospace() with the devm_ managed version to fix the bug.
Fixes: b7e78170efd4 ("PCI: versatile: Add DT-based ARM Versatile PB PCIe host driver")
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
[lorenzo.pieralisi@arm.com: updated the commit log]
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
commit a5fb9fb023a1435f2b42bccd7f547560f3a21dc3 upstream.
Modules linked in:
Call trace:
kthread+0x108/0x134
Introduce the devm_pci_remap_iospace() managed API and replace the
pci_remap_iospace() call with it to fix the bug.
Fixes: dbf9826d5797 ("PCI: generic: Convert to DT resource parsing API")
[lorenzo.pieralisi@arm.com: split commit/updated the commit log]
