commit 2a1b7e575b80ceb19ea50bfa86ce0053ea57181d upstream.
I may have an explanation for the LSI 1068 HBA hangs provoked by ATA
pass-through commands, in particular by smartctl.
First, my version of the symptoms. On an LSI SAS1068E B3 HBA running
01.29.00.00 firmware, with SATA disks, and with smartd running, I'm seeing
occasional task, bus, and host resets, some of which lead to hard faults of
the HBA requiring a reboot. Abusively looping the smartctl command,
# while true; do smartctl -a /dev/sdb > /dev/null; done
dramatically increases the frequency of these failures to nearly one per
minute. A high IO load through the HBA while looping smartctl seems to
improve the chance of a full scsi host reset or a non-recoverable hang.
I reduced what smartctl was doing down to a simple test case which
causes the hang with a single IO when pointed at the sd interface. See
the code at the bottom of this e-mail. It uses an SG_IO ioctl to issue
a single pass-through ATA identify device command. If the buffer
userspace gives for the read data has certain alignments, the task is
issued to the HBA but the HBA fails to respond. If run against the sg
interface, neither the test code nor smartctl causes a hang.
sd and sg handle the SG_IO ioctl slightly differently. Unless you
specifically set a flag to do direct IO, sg passes a buffer of its own,
which is page-aligned, to the block layer and later copies the result
into the userspace buffer regardless of its alignment. sd, on the other
hand, always does direct IO unless the userspace buffer fails an
alignment test at block/blk-map.c line 57, in which case a page-aligned
buffer is created and used for the transfer.
The alignment test currently checks for word-alignment, the default
setup by scsi_lib.c; therefore, userspace buffers of almost any
alignment are given directly to the HBA as DMA targets. The LSI 1068
hardware doesn't seem to like at least a couple of the alignments which
cross a page boundary (see the test code below). Curiously, many
page-boundary-crossing alignments do work just fine.
So, either the hardware has an bug handling certain alignments or the
hardware has a stricter alignment requirement than the driver is
advertising. If stricter alignment is required, then in no case should
misaligned buffers from userspace be allowed through without being
bounced or at least causing an error to be returned.
It seems the mptsas driver could use blk_queue_dma_alignment() to advertise
a stricter alignment requirement. If it does, sd does the right thing and
bounces misaligned buffers (see block/blk-map.c line 57). The following
patch to 2.6.34-rc5 makes my symptoms go away. I'm sure this is the wrong
place for this code, but it gets my idea across.
Acked-by: "Desai Kashyap" <Kashyap.Desai@lsi.com>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
commit 94ae4976e253757e9b03a44d27d41b20f1829d80 upstream.
This patch (as1458) fixes a problem affecting ultra-reliable systems:
When hardware failover of an EHCI controller occurs, the data
structures do not get released correctly. This is because the routine
responsible for removing unused QHs from the async schedule assumes
the controller is running properly (the frame counter is used in
determining how long the QH has been idle) -- but when a failover
causes the controller to be electronically disconnected from the PCI
bus, obviously it stops running.
The solution is simple: Allow scan_async() to remove a QH from the
async schedule if it has been idle for long enough _or_ if the
controller is stopped.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Reported-and-Tested-by: Dan Duval <dan.duval@stratus.com>
commit 14ddc3188d50855ae2a419a6aced995e2834e5d4 upstream.
Don't allow everybody to change video settings.
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Acked-by: Luca Risolia <luca.risolia@studio.unibo.it>
commit 49d50fb1c28738ef6bad0c2b87d5355a1653fed5 upstream.
Don't allow everybogy to write to NVRAM.
Cc: Andy Sharp <andy.sharp@onstor.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
commit 1309d7afbed112f0e8e90be9af975550caa0076b upstream.
This patch fixes information leakage to the userspace by initializing
the data buffer to zero.
Reported-by: Peter Huewe <huewe.external@infineon.com>
Signed-off-by: Peter Huewe <huewe.external@infineon.com>
Signed-off-by: Marcel Selhorst <m.selhorst@sirrix.com>
[ Also removed the silly "* sizeof(u8)". If that isn't 1, we have way
deeper problems than a simple multiplication can fix. - Linus ]
commit 63a8588debd4dc72becb9e27add9343c76301c7d upstream.
Just adding the vendor details makes it work fine.
Signed-off-by: Marc-Antoine Perennou <Marc-Antoine@Perennou.com>
Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
commit 877a55979c189c590e819a61cbbe2b7947875f17 upstream.
enclosure page 7 gives us the "pretty" names of the enclosure slots.
Without a page 7, we can still use the enclosure code as long as we
make up numeric names for the slots. Unfortunately, the current code
fails to add any devices because the check for page 10 is in the wrong
place if we have no page 7. Fix it so that devices show up even if
the enclosure has no page 7.
commit 1ddd5049545e0aa1a0ed19bca4d9c9c3ce1ac8a2 upstream.
Under certain workloads a command may seem to get lost. IOW, the Smart Array
thinks all commands have been completed but we still have commands in our
completion queue. This may lead to system instability, filesystems going
read-only, or even panics depending on the affected filesystem. We add an
extra read to force the write to complete.
Testing shows this extra read avoids the problem.
Signed-off-by: Mike Miller <mike.miller@hp.com>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
commit cda6587c21a887254c8ed4b58da8fcc4040ab557 upstream.
Rmmod myri10ge crash at free_netdev() -> netif_napi_del(), because napi
structures are already deallocated. To fix call netif_napi_del() before
kfree() at myri10ge_free_slices().
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
commit dd65c736d1b5312c80c88a64bf521db4959eded5 upstream.
The dcdbas driver can do an I/O write to cause a SMI to occur. The SMI handler
looks at certain registers and memory locations, so the SMI needs to happen
immediately. On some systems I/O writes are posted, though, causing the SMI to
happen well after the "outb" occurred, which causes random failures. Following
the "outb" with an "inb" forces the write to go through even if it is posted.
Signed-off-by: Stuart Hayes <stuart_hayes@yahoo.com>
Acked-by: Doug Warzecha <douglas_warzecha@dell.com>
Cc: Chuck Ebbert <cebbert@redhat.com>
commit 8c3c283e6bf463ab498d6e7823aff6c4762314b6 upstream.
A virtualized display device is usually viewed with the vncviewer
application, either by 'xm vnc domU' or with vncviewer localhost:port.
vncviewer and the RFB protocol provides absolute coordinates to the
virtual display. These coordinates are either passed through to a PV
guest or converted to relative coordinates for a HVM guest.
A PV guest receives these coordinates and passes them to the kernels
evdev driver. There it can be picked up by applications such as the
xorg-input drivers. Using absolute coordinates avoids issues such as
guest mouse pointer not tracking host mouse pointer due to wrong mouse
acceleration settings in the guests X display.
Advertise either absolute or relative coordinates to the input system
and the evdev driver, depending on what dom0 provides. The xorg-input
driver prefers relative coordinates even if a devices provides both.
Signed-off-by: Olaf Hering <olaf@aepfle.de>
Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
commit 7e7797e7f6f7bfab73fca02c65e40eaa5bb9000c upstream.
Fix potential null-pointer exception on disconnect introduced by commit
11ea859d64b69a747d6b060b9ed1520eab1161fe (USB: additional power savings
for cdc-acm devices that support remote wakeup).
Only access acm->dev after making sure it is non-null in control urb
completion handler.
Signed-off-by: Johan Hovold <jhovold@gmail.com>
commit adaa3c6342b249548ea830fe8e02aa5b45be8688 upstream.
My testprog do a lot of bitbang - after hours i got following warning and my machine lockups:
WARNING: at /build/buildd/linux-2.6.38/lib/kref.c:34
After debugging uss720 driver i discovered that the completion callback was called before
usb_submit_urb returns. The callback frees the request structure that is krefed on return by
usb_submit_urb.
Signed-off-by: Peter Holik <peter@holik.at>
Acked-by: Thomas Sailer <t.sailer@alumni.ethz.ch>
commit b5a3b3d985493c173925907adfebf3edab236fe7 upstream.
This patch (as1453) fixes a long-standing bug in the ehci-hcd driver.
There is no need to set the Halt bit in the overlay region for an
unlinked or blocked QH. Contrary to what the comment says, setting
the Halt bit does not cause the QH to be patched later; that decision
(made in qh_refresh()) depends only on whether the QH is currently
pointing to a valid qTD. Likewise, setting the Halt bit does not
prevent completions from activating the QH while it is "stopped"; they
are prevented by the fact that qh_completions() temporarily changes
qh->qh_state to QH_STATE_COMPLETING.
On the other hand, there are circumstances in which the QH will be
reactivated _without_ being patched; this happens after an URB beyond
the head of the queue is unlinked. Setting the Halt bit will then
cause the hardware to see the QH with both the Active and Halt bits
set, an invalid combination that will prevent the queue from
advancing and may even crash some controllers.
Apparently the only reason this hasn't been reported before is that
unlinking URBs from the middle of a running queue is quite uncommon.
However Test 17, recently added to the usbtest driver, does exactly
this, and it confirms the presence of the bug.
In short, there is no reason to set the Halt bit for an unlinked or
blocked QH, and there is a very good reason not to set it. Therefore
the code that sets it is removed.
Tested-by: Andiry Xu <andiry.xu@amd.com>
CC: David Brownell <david-b@pacbell.net>
commit d6244bc0ed0c52a795e6f4dcab3886daf3e74fac upstream.
Use mask 0x10 for "soft cursor" detection on in function tile_cursor.
(Tile Blitting Operation in framebuffer console).
The old mask 0x01 for vc_cursor_type detects CUR_NONE, CUR_LOWER_THIRD
and every second mode value as "software cursor". This hides the cursor
for these modes (cursor.mode = 0). But, only CUR_NONE or "software cursor"
should hide the cursor.
See also 0x10 in functions add_softcursor, bit_cursor and cw_cursor.
Signed-off-by: Henry Nestler <henry.nestler@gmail.com>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
commit bc10f96757bd6ab3721510df8defa8f21c32f974 upstream.
Remove the call to tty_ldisc_flush() from the RESULT_NO_CARRIER
branch of isdn_tty_modem_result(), as already proposed in commit
00409bb045887ec5e7b9e351bc080c38ab6bfd33.
This avoids a "sleeping function called from invalid context" BUG
when the hardware driver calls the statcallb() callback with
command==ISDN_STAT_DHUP in atomic context, which in turn calls
isdn_tty_modem_result(RESULT_NO_CARRIER, ~), and from there,
tty_ldisc_flush() which may sleep.
Signed-off-by: Tilman Schmidt <tilman@imap.cc>
commit 87e3dc3855430bd254370afc79f2ed92250f5b7c upstream.
Some broken BIOSes on ICH4 chipset report an ACPI region which is in
conflict with legacy IDE ports when ACPI is disabled. Even though the
regions overlap, IDE ports are working correctly (we cannot find out
the decoding rules on chipsets).
So the only problem is the reported region itself, if we don't reserve
the region in the quirk everything works as expected.
This patch avoids reserving any quirk regions below PCIBIOS_MIN_IO
which is 0x1000. Some regions might be (and are by a fast google
query) below this border, but the only difference is that they won't
be reserved anymore. They should still work though the same as before.
The conflicts look like (1f.0 is bridge, 1f.1 is IDE ctrl):
pci 0000:00:1f.1: address space collision: [io 0x0170-0x0177] conflicts with 0000:00:1f.0 [io 0x0100-0x017f]
At 0x0100 a 128 bytes long ACPI region is reported in the quirk for
ICH4. ata_piix then fails to find disks because the IDE legacy ports
are zeroed:
ata_piix 0000:00:1f.1: device not available (can't reserve [io 0x0000-0x0007])
References: https://bugzilla.novell.com/show_bug.cgi?id=558740
Cc: Bjorn Helgaas <bjorn.helgaas@hp.com>
Cc: Thomas Renninger <trenn@suse.de>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
commit cdb9755849fbaf2bb9c0a009ba5baa817a0f152d upstream.
Per ICH4 and ICH6 specs, ACPI and GPIO regions are valid iff ACPI_EN
and GPIO_EN bits are set to 1. Add checks for these bits into the
quirks prior to the region creation.
While at it, name the constants by macros.
commit d0781383038e983a63843a9a6a067ed781db89c1 upstream.
I picked up a new DAK-780EX(professional digitl reverb/mix system),
which use CH341T chipset to communication with computer on 3/2011
and the CH341T's vendor code is 1a86
Looking up the CH341T's vendor and product id's I see:
1a86 QinHeng Electronics
5523 CH341 in serial mode, usb to serial port converter
CH341T,CH341 are the products of the same company, maybe
have some common hardware, and I test the ch341.c works
well with CH341T
commit 29963437a48475036353b95ab142bf199adb909e upstream.
When processing a SIDR REQ, the ib_cm allocates a new cm_id. The
refcount of the cm_id is initialized to 1. However, cm_process_work
will decrement the refcount after invoking all callbacks. The result
is that the cm_id will end up with refcount set to 0 by the end of the
sidr req handler.
If a user tries to destroy the cm_id, the destruction will proceed,
under the incorrect assumption that no other threads are referencing
the cm_id. This can lead to a crash when the cm callback thread tries
to access the cm_id.
This problem was noticed as part of a larger investigation with kernel
crashes in the rdma_cm when running on a real time OS.
Signed-off-by: Sean Hefty <sean.hefty@intel.com>
Acked-by: Doug Ledford <dledford@redhat.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
commit 25ae21a10112875763c18b385624df713a288a05 upstream.
Doug Ledford and Red Hat reported a crash when running the rdma_cm on
a real-time OS. The crash has the following call trace:
cm_process_work
cma_req_handler
cma_disable_callback
rdma_create_id
kzalloc
init_completion
cma_get_net_info
cma_save_net_info
cma_any_addr
cma_zero_addr
rdma_translate_ip
rdma_copy_addr
cma_acquire_dev
rdma_addr_get_sgid
ib_find_cached_gid
cma_attach_to_dev
ucma_event_handler
kzalloc
ib_copy_ah_attr_to_user
cma_comp
[ preempted ]
cma_write
copy_from_user
ucma_destroy_id
copy_from_user
_ucma_find_context
ucma_put_ctx
ucma_free_ctx
rdma_destroy_id
cma_exch
cma_cancel_operation
rdma_node_get_transport
rt_mutex_slowunlock
bad_area_nosemaphore
oops_enter
They were able to reproduce the crash multiple times with the
following details:
Crash seems to always happen on the:
mutex_unlock(&conn_id->handler_mutex);
as conn_id looks to have been freed during this code path.
An examination of the code shows that a race exists in the request
handlers. When a new connection request is received, the rdma_cm
allocates a new connection identifier. This identifier has a single
reference count on it. If a user calls rdma_destroy_id() from another
thread after receiving a callback, rdma_destroy_id will proceed to
destroy the id and free the associated memory. However, the request
handlers may still be in the process of running. When control returns
to the request handlers, they can attempt to access the newly created
identifiers.
Fix this by holding a reference on the newly created rdma_cm_id until
the request handler is through accessing it.
commit 64a3903d0885879ba8706a8bcf71c5e3e7664db2 upstream.
This patch adds an updated SATA RAID DeviceID for the Intel Patsburg PCH.
Signed-off-by: Seth Heasley <seth.heasley@intel.com>
Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
commit a4a461a6df6c0481d5a3d61660ed97f5b539cf16 upstream.
This patch adds the AHCI-mode SATA DeviceID for the Intel DH89xxCC PCH.
commit 992b3fb9b5391bc4de5b42bb810dc6dd583a6c4a upstream.
This patch adds the Intel Patsburg (PCH) SATA AHCI and RAID Controller
DeviceIDs.
commit 5623cab83ea61e0420f2064216d83eab067a24c6 upstream.
commit c1f57d9b9846e7366c328f916d1a82d03ba4312c upstream.
Add device IDS for Ibex Peak SATA AHCI Controllers
Signed-off-by: Jaroslav Kysela <jkysela@redhat.com>
Signed-off-by: David Milburn <dmilburn@redhat.com>
commit f08dc1ac6b15c681f4643d8da1700e06c3855608 upstream.
ata_qc_complete() contains special handling for certain commands. For
example, it schedules EH for device revalidation after certain
configurations are changed. These shouldn't be applied to EH
commands but they were.
In most cases, it doesn't cause an actual problem because EH doesn't
issue any command which would trigger special handling; however, ACPI
can issue such commands via _GTF which can cause weird interactions.
Restructure ata_qc_complete() such that EH commands are always passed
on to __ata_qc_complete().
stable: Please apply to -stable only after 2.6.38 is released.
Reported-by: Kyle McMartin <kyle@mcmartin.ca>
commit d9ebaa45472c92704f4814682eec21455edcfa1f upstream.
This avoids a possible race leading to trying to dereference NULL.
Acked-by: Jean Delvare <khali@linux-fr.org>
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
commit b652277b09d3d030cb074cc6a98ba80b34244c03 upstream.
The "ct" variable should be an unsigned int. Both struct kbdiacrs
->kb_cnt and struct kbd_data ->accent_table_size are unsigned ints.
Making it signed causes a problem in KBDIACRUC because the user could
set the signed bit and cause a buffer overflow.
commit 3ed780117dbe5acb64280d218f0347f238dafed0 upstream.
If the iowarrior devices in this case statement support more than 8 bytes
per report, it is possible to write past the end of a kernel heap allocation.
This will probably never be possible, but change the allocation to be more
defensive anyway.
Signed-off-by: Kees Cook <kees.cook@canonical.com>
Acked-by: Brandon Philips <bphilips@suse.de>
commit ba04c7c93bbcb48ce880cf75b6e9dffcd79d4c7b upstream.
For some time is known that ASPM is causing troubles on r8169, i.e. make
device randomly stop working without any errors in dmesg.
Currently Tomi Leppikangas reports that system with r8169 device hangs
with MCE errors when ASPM is enabled:
https://bugzilla.redhat.com/show_bug.cgi?id=642861#c4
Lets disable ASPM for r8169 devices at all, to avoid problems with
r8169 PCIe devices at least for some users.
Reported-by: Tomi Leppikangas <tomi.leppikangas@gmail.com>
commit bc505f373979692d51a86d40925f77a8b09d17b9 upstream.
As all virtio devices perform DMA, we
must enable bus mastering for them to be
spec compliant.
This patch fixes hotplug of virtio devices
with Linux guests and qemu 0.11-0.12.
Tested-by: Alexander Graf <agraf@suse.de>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Cc: maximilian attems <max@stro.at>
commit 9063f1f15eec35e5fd608879cef8be5728f2d12a upstream.
Call input_set_abs_params instead of manually setting absbit only.
This fixes this oops:
Unable to handle kernel NULL pointer dereference at virtual address 00000024
Internal error: Oops: 41b67017 [#1]
CPU: 0 Not tainted (2.6.37 #4)
pc : [<c016d1fc>] lr : [<00000000>] psr: 20000093
sp : c19e5f30 ip : c19e5e6c fp : c19e5f58
r10: 00000000 r9 : c19e4000 r8 : 00000003
r7 : 000001e4 r6 : 00000001 r5 : c1854400 r4 : 00000003
r3 : 00000018 r2 : 00000018 r1 : 00000018 r0 : c185447c
Flags: nzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: c1b6717f Table: c1b6717f DAC: 00000017
Stack: (0xc19e5f30 to 0xc19e6000)
5f20: 00000003 00000003 c1854400 00000013
5f40: 00000001 000001e4 000001c5 c19e5f80 c19e5f5c c016d5e8 c016cf5c 000001e4
5f60: c1854400 c18b5860 00000000 00000171 000001e4 c19e5fc4 c19e5f84 c01559a4
5f80: c016d584 c18b5868 00000000 c1bb5c40 c0035afc c18b5868 c18b5868 c1a55d54
5fa0: c18b5860 c0155750 00000013 00000000 00000000 00000000 c19e5ff4 c19e5fc8
5fc0: c0050174 c015575c 00000000 c18b5860 00000000 c19e5fd4 c19e5fd4 c1a55d54
5fe0: c00500f0 c003b464 00000000 c19e5ff8 c003b464 c00500fc 04000400 04000400
Backtrace:
Function entered at [<c016cf50>] from [<c016d5e8>]
Function entered at [<c016d578>] from [<c01559a4>]
r8:000001e4 r7:00000171 r6:00000000 r5:c18b5860 r4:c1854400
Function entered at [<c0155750>] from [<c0050174>]
Function entered at [<c00500f0>] from [<c003b464>]
r6:c003b464 r5:c00500f0 r4:c1a55d54
Code: e59520fc e1a03286 e0433186 e0822003 (e592000c)
>>PC; c016d1fc <input_handle_event+2ac/5a0> <=====
Trace; c016cf50 <input_handle_event+0/5a0>
Trace; c016d5e8 <input_event+70/88>
Trace; c016d578 <input_event+0/88>
Trace; c01559a4 <ucb1x00_thread+254/2dc>
Trace; c0155750 <ucb1x00_thread+0/2dc>
Trace; c0050174 <kthread+84/8c>
Trace; c00500f0 <kthread+0/8c>
Trace; c003b464 <do_exit+0/624>
Signed-off-by: Jochen Friedrich <jochen@scram.de>
commit 8f5f02c460b7ca74ce55ce126ce0c1e58a3f923d upstream.
'mdp' devices are md devices with preallocated device numbers
for partitions. As such it is possible to mknod and open a partition
before opening the whole device.
this causes md_probe() to be called with a device number of a
partition, which in-turn calls mddev_find with such a number.
However mddev_find expects the number of a 'whole device' and
does the wrong thing with partition numbers.
So add code to mddev_find to remove the 'partition' part of
a device number and just work with the 'whole device'.
This patch addresses https://bugzilla.kernel.org/show_bug.cgi?id=28652
Reported-by: hkmaly@bigfoot.com
Signed-off-by: NeilBrown <neilb@suse.de>
commit b193b412e62b134adf69af286c7e7f8e99259350 upstream.
Cancel idle timer in musb_platform_exit.
The idle timer could trigger after clock had been disabled leading to
kernel panic when MUSB_DEVCTL is accessed in musb_do_idle on 2.6.37.
The fault below is no longer triggered on 2.6.38-rc4 (clock is disabled
later, and only if compiled as a module, and the offending memory access
has moved) but the timer should be cancelled nonetheless.
Rebooting... musb_hdrc musb_hdrc: remove, state 4
usb usb1: USB disconnect, address 1
musb_hdrc musb_hdrc: USB bus 1 deregistered
Unhandled fault: external abort on non-linefetch (0x1028) at 0xfa0ab060
Internal error: : 1028 [#1] PREEMPT
last sysfs file: /sys/kernel/uevent_seqnum
Modules linked in:
CPU: 0 Not tainted (2.6.37+ #6)
PC is at musb_do_idle+0x24/0x138
LR is at musb_do_idle+0x18/0x138
pc : [<c02377d8>] lr : [<c02377cc>] psr: 80000193
sp : cf2bdd80 ip : cf2bdd80 fp : c048a20c
r10: c048a60c r9 : c048a40c r8 : cf85e110
r7 : cf2bc000 r6 : 40000113 r5 : c0489800 r4 : cf85e110
r3 : 00000004 r2 : 00000006 r1 : fa0ab000 r0 : cf8a7000
Flags: Nzcv IRQs off FIQs on Mode SVC_32 ISA ARM Segment user
Control: 10c5387d Table: 8faac019 DAC: 00000015
Process reboot (pid: 769, stack limit = 0xcf2bc2f0)
Stack: (0xcf2bdd80 to 0xcf2be000)
dd80: 00000103 c0489800 c02377b4 c005fa34 00000555 c0071a8c c04a3858 cf2bdda8
dda0: 00000555 c048a00c cf2bdda8 cf2bdda8 1838beb0 00000103 00000004 cf2bc000
ddc0: 00000001 00000001 c04896c8 0000000a 00000000 c005ac14 00000001 c003f32c
dde0: 00000000 00000025 00000000 cf2bc000 00000002 00000001 cf2bc000 00000000
de00: 00000001 c005ad08 cf2bc000 c002e07c c03ec039 ffffffff fa200000 c0033608
de20: 00000001 00000000 cf852c14 cf81f200 c045b714 c045b708 cf2bc000 c04a37e8
de40: c0033c04 cf2bc000 00000000 00000001 cf2bde68 cf2bde68 c01c3abc c004f7d8
de60: 60000013 ffffffff c0033c04 00000000 01234567 fee1dead 00000000 c006627c
de80: 00000001 c00662c8 28121969 c00663ec cfa38c40 cf9f6a00 cf2bded0 cf9f6a0c
dea0: 00000000 cf92f000 00008914 c02cd284 c04a55c8 c028b398 c00715c0 becf24a8
dec0: 30687465 00000000 00000000 00000000 00000002 1301a8c0 00000000 00000000
dee0: 00000002 1301a8c0 00000000 00000000 c0450494 cf527920 00011f10 cf2bdf08
df00: 00011f10 cf2bdf10 00011f10 cf2bdf18 c00f0b44 c004f7e8 cf2bdf18 cf2bdf18
df20: 00011f10 cf2bdf30 00011f10 cf2bdf38 cf401300 cf486100 00000008 c00d2b28
df40: 00011f10 cf401300 00200200 c00d3388 00011f10 cfb63a88 cfb63a80 c00c2f08
df60: 00000000 00000000 cfb63a80 00000000 cf0a3480 00000006 c0033c04 cfb63a80
df80: 00000000 c00c0104 00000003 cf0a3480 cfb63a80 00000000 00000001 00000004
dfa0: 00000058 c0033a80 00000000 00000001 fee1dead 28121969 01234567 00000000
dfc0: 00000000 00000001 00000004 00000058 00000001 00000001 00000000 00000001
dfe0: 4024d200 becf2cb0 00009210 4024d218 60000010 fee1dead 00000000 00000000
[<c02377d8>] (musb_do_idle+0x24/0x138) from [<c005fa34>] (run_timer_softirq+0x1a8/0x26)
[<c005fa34>] (run_timer_softirq+0x1a8/0x26c) from [<c005ac14>] (__do_softirq+0x88/0x13)
[<c005ac14>] (__do_softirq+0x88/0x138) from [<c005ad08>] (irq_exit+0x44/0x98)
[<c005ad08>] (irq_exit+0x44/0x98) from [<c002e07c>] (asm_do_IRQ+0x7c/0xa0)
[<c002e07c>] (asm_do_IRQ+0x7c/0xa0) from [<c0033608>] (__irq_svc+0x48/0xa8)
Exception stack(0xcf2bde20 to 0xcf2bde68)
[<c0033608>] (__irq_svc+0x48/0xa8) from [<c004f7d8>] (sub_preempt_count+0x0/0xb8)
Code: ebf86030 e5940098 e594108c e5902010 (e5d13060)
---[ end trace 3689c0d808f9bf7c ]---
Kernel panic - not syncing: Fatal exception in interrupt
Signed-off-by: Felipe Balbi <balbi@ti.com>
commit 8a6a142c1286797978e4db266d22875a5f424897 upstream.
Don't allow everybody to change WMI settings.
commit b80b168f918bba4b847e884492415546b340e19d upstream.
Don't allow everybody to write to hardware registers.
[wt: also fixed permission on interface]
commit 8040835760adf0ef66876c063d47f79f015fb55d upstream.
Don't allow everybody to change ACPI settings. The comment says that it
is done deliberatelly, however, the comment before disp_proc_write()
says that at least one of these setting is experimental.
commit 2400982a2e8a8e4e95f0a0e1517bbe63cc88038f upstream.
Commit e3c92215198cb6aa00ad38db2780faa6b72e0a3f ("[media] radio-aimslab.c: Fix
gcc 4.5+ bug") removed the include, but introduced new callers of msleep():
| drivers/media/radio/radio-aimslab.c: In function ‘rt_decvol’:
| drivers/media/radio/radio-aimslab.c:76: error: implicit declaration of function ‘msleep’
Cc: dann frazier <dannf@debian.org>
commit 5528d17de1cf1462f285c40ccaf8e0d0e4c64dc0 upstream.
If the mirror log fails when the handle_errors option was not selected
and there is no remaining valid mirror leg, writes return success even
though they weren't actually written to any device. This patch
completes them with EIO instead.
This code path is taken:
do_writes:
bio_list_merge(&ms->failures, &sync);
do_failures:
if (!get_valid_mirror(ms)) (false)
else if (errors_handled(ms)) (false)
else bio_endio(bio, 0);
The logic in do_failures is based on presuming that the write was already
tried: if it succeeded at least on one leg (without handle_errors) it
is reported as success.
Reference: https://bugzilla.redhat.com/show_bug.cgi?id=555197
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
commit 40f08a724fcc21285cf3a75aec957aef908605c6 upstream.
Abusing irq stats in a driver for counting interrupts is a horrible
idea and not safe with shared interrupts. Replace it by a local
interrupt counter.
Noticed by the attempt to remove the irq stats export.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
commit cb26a24ee9706473f31d34cc259f4dcf45cd0644 upstream.
info->num comes from the user. It's type int. If the user passes
in a negative value that would cause memory corruption.
commit 252a52aa4fa22a668f019e55b3aac3ff71ec1c29 upstream.
The PKT_CTRL_CMD_STATUS device ioctl retrieves a pointer to a
pktcdvd_device from the global pkt_devs array. The index into this
array is provided directly by the user and is a signed integer, so the
comparison to ensure that it falls within the bounds of this array will
fail when provided with a negative index.
This can be used to read arbitrary kernel memory or cause a crash due to
an invalid pointer dereference. This can be exploited by users with
permission to open /dev/pktcdvd/control (on many distributions, this is
readable by group "cdrom").
Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com>
[ Rather than add a cast, just make the function take the right type -Linus ]
commit c4ff4b829ef9e6353c0b133b7adb564a68054979 upstream.
If duration variable value is 0 at this point, it's because
chip->vendor.duration wasn't filled by tpm_get_timeouts() yet.
This patch sets then the lowest timeout just to give enough
time for tpm_get_timeouts() to further succeed.
This fix avoids long boot times in case another entity attempts
to send commands to the TPM when the TPM isn't accessible.
Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
Signed-off-by: James Morris <jmorris@namei.org>
commit bf572541ab44240163eaa2d486b06f306a31d45a upstream.
Commit 1a855a0606 (2.6.37-rc4) fixed a problem where devices were
re-added when they shouldn't be but caused a regression in a less
common case that means sometimes devices cannot be re-added when they
should be.
In particular, when re-adding a device to an array without metadata
we should always access the device, but after the above commit we
didn't.
This patch sets the In_sync flag in that case so that the re-add
succeeds.
This patch is suitable for any -stable kernel to which 1a855a0606 was
applied.
commit 4e5518ca53be29c1ec3c00089c97bef36bfed515 upstream.
pcmcia_request_irq() and pcmcia_enable_device() are intended
to be called from process context (first function allocate memory
with GFP_KERNEL, second take a mutex). We can not take spin lock
and call them.
It's safe to move spin lock after pcmcia_enable_device() as we
still hold off IRQ until dev->base_addr is 0 and driver will
not proceed with interrupts when is not ready.
Patch resolves:
https://bugzilla.redhat.com/show_bug.cgi?id=643758
Reported-and-tested-by: rbugz@biobind.com
commit 96a3e79edff6f41b0f115a82f1a39d66218077a7 upstream.
Added 0x0307 device id to support Motorola cables to the pl2303 usb
serial driver. This cable has a modified chip that is a pl2303, but
declares itself as 0307. Fixed by adding the right device id to the
supported devices list, assigning it the code labeled
PL2303_PRODUCT_ID_MOTOROLA.
Signed-off-by: Dario Lombardo <dario.lombardo@libero.it>
commit 18344a1cd5889d48dac67229fcf024ed300030d5 upstream.
I tried a magnetic stripe reader
(http://www.kimaldi.com/kimaldi_eng/productos/lectores_de_tarjetas/lectores_tarjeta_chip_y_dni/lector_hibrido_uniform_hcr_331)
and I see that it is interfaced with a PL2303. I wrote a patch to use
your driver which simply adds the product ID for the device and it
seems working fine.
commit d0694e2aeb815042aa0f3e5036728b3db4446f1d upstream.
Unbreak Billionton CF bluetooth card. This actually fixes a regression
on zaurus.
Signed-off-by: Pavel Machek <pavel@ucw.cz>
commit f8313ef1f448006207f12c107123522c8bc00f15 upstream.
i8042 controller present in Dell Vostro V13 errorneously signals spurious
timeouts.
Introduce i8042.notimeout parameter for ignoring i8042-signalled timeouts
and apply this quirk automatically for Dell Vostro V13, based on DMI match.
In addition to that, this machine also needs to be added to nomux blacklist.
Cc: Tim Gardner <tcanonical@tpi.com>
