The i8042 driver fails detection of the AUX port with some chips,
because they apparently do not change the I8042_CTR_AUXDIS bit
immediately. This is known to affect at least HP500/HP510 notebooks,
consequently the built-in touchpad will not work. The patch will simply
reread the value until it gets the expected value or a retry limit is
hit, without touching other workaround code in the same area.
Signed-off-by: Roland Scheidegger <sroland@tungstengraphics.com>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
The Linux kernel ignored the PROM's serial settings (115200,n,8,1 in
my case). This was because mode_prop remained "ttyX-mode" (expected:
"ttya-mode") due to the constness of string literals when used with
"char *". Since there is no "ttyX-mode" property in the PROM, Linux
always used the default 9600.
[ Investigation of the suncore.s assembler reveals that gcc optimizied
away the stores, yet did not emit a warning, which is a pretty
anti-social thing to do and is the only reason this bug lived for
so long -DaveM ]
Signed-off-by: Jan Engelhardt <jengelh@gmx.de>
Revert changeset
http://linuxtv.org/hg/v4l-dvb?cmd=changeset;node=e7c424bbf9aa;style=gitweb
Petri Helin found that this changeset broke tuning:
'Well, after going through the changes that might have had effect on
tuning, I found out the one which had caused this problem. I do not know
the actual reason behind the change, but the changelog says that it
was meant to "Fix TD1316 tuner for DVBC". But at least in my case it
seams to have broken the tuner instead.'
Signed-off-by: Oliver Endriss <o.endriss@gmx.de>
Thanks-to: Petri Helin <phelin@googlemail.com>
Acked-by: e9hack <e9hack@googlemail.com>
Acked-by: Thomas Kaiser <linux-dvb@kaiser-linux.li>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Acked-by: Michael Krufky <mkrufky@linuxtv.org>
Use relative time, not absolute. Discovered by Jung-Ik (John) Lee
<jilee@google.com>.
Cc: Jung-Ik (John) Lee <jilee@google.com>
Acked-by: Len Brown <lenb@kernel.org>
Currently, devt_attr for the "dev" file is freed immediately on device
removal, but if the "dev" sysfs file is open when a device is removed,
sysfs will access its attribute structure for further access including
close resulting in jumping to garbled address. Fix it by postponing
freeing devt_attr to device release time.
Note that devt_attr for class_device is already freed on release.
This bug is reported by Chris Rankin as bugzilla bug#8198.
Signed-off-by: Tejun Heo <htejun@gmail.com>
Cc: Chris Rankin <rankincj@yahoo.com>
For some reason, sata_via is missing PM hooks. Add them. Spotted by
Jeroen Janssen <jeroen.janssen@gmail.com>.
Cc: Jeroen Janssen <jeroen.janssen@gmail.com>
the patch below fixes compilation breakage of smc911x driver when ENABLE_SMC_DEBUG_PKTS equals to 1.
Signed-off-by: Vitaly Wool <vitalywool@gmail.com>
Add data from zero-entropy random_writes directly to output pools to
avoid accounting difficulties on machines without entropy sources.
Tested on lguest with all entropy sources disabled.
Signed-off-by: Matt Mackall <mpm@selenic.com>
Acked-by: "Theodore Ts'o" <tytso@mit.edu>
Fix cast error in entropy extraction.
Add comments explaining the magic 16.
Remove extra confusing loop variable.
Allow in-place crypto operations. Also remove the coherent user flag
(we use it automagically now), and by default use the user written
key rather then the HW hidden key - this makes crypto just work without
any special considerations, and thats OK, since its our only usage
model.
Signed-off-by: Jordan Crouse <jordan.crouse@amd.com>
Revert "adjust legacy IDE resource setting (v2)"
This reverts commit ed8ccee0918ad063a4741c0656fda783e02df627.
It causes hang on boot for some users and we don't yet know why:
http://bugzilla.kernel.org/show_bug.cgi?id=7562
http://lkml.org/lkml/2007/4/20/404
http://lkml.org/lkml/2007/3/25/113
Just reverse it for 2.6.21-final, having broken X server is somehow
better than unbootable system.
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Cc: Chuck Ebbert <cebbert@redhat.com>
[AGPGART] intel_agp: fix G965 GTT size detect
On G965, I810_PGETBL_CTL is a mmio offset, but we wrongly take it
as pci config space offset in detecting GTT size. This one line patch
fixs this.
Signed-off-by: Wang Zhenyu <zhenyu.z.wang@intel.com>
Signed-off-by: Dave Jones <davej@redhat.com>
Users have been complaining about the w83627ehf driver flooding their
logs with debug messages like:
w83627ehf 9191-0a10: Increasing fan 4 clock divider from 64 to 128
or:
w83627ehf 9191-0290: Increasing fan 4 clock divider from 4 to 8
The reason is that we failed to actually write the LSB of the encoded
clock divider value for that fan, causing the next read to report the
same old value again and again.
Additionally, the fan number was improperly reported, making the bug
harder to find.
I encountered the following kernel panic. The cause of this problem was
NULL pointer access in check_modem_status() in 8250.c. I confirmed this
problem is fixed by the attached patch, but I don't know this is the
correct fix.
sadc[4378]: NaT consumption 2216203124768 [1]
Modules linked in: binfmt_misc dm_mirror dm_mod thermal processor fan
container button sg e100 eepro100 mii ehci_hcd ohci_hcd
Pid: 4378, CPU 0, comm: sadc
psr : 00001210085a2010 ifs : 8000000000000289 ip : [<a000000100482071>]
Not tainted
ip is at check_modem_status+0xf1/0x360
unat: 0000000000000000 pfs : 0000000000000289 rsc : 0000000000000003
rnat: 800000000000cc18 bsps: 0000000000000000 pr : 0000000000aa6a99
ldrs: 0000000000000000 ccv : 0000000000000000 fpsr: 0009804c8a70033f
csd : 0000000000000000 ssd : 0000000000000000
b0 : a000000100481fb0 b6 : a0000001004822e0 b7 : a000000100477f20
f6 : 1003e2222222222222222 f7 : 0ffdba200000000000000
f8 : 100018000000000000000 f9 : 10002a000000000000000
f10 : 0fffdccccccccc8c00000 f11 : 1003e0000000000000000
r1 : a000000100b9af40 r2 : 0000000000000008 r3 : a000000100ad4e21
r8 : 00000000000000bb r9 : 0000000000000001 r10 : 0000000000000000
r11 : a000000100ad4d58 r12 : e0000000037b7df0 r13 : e0000000037b0000
r14 : 0000000000000001 r15 : 0000000000000018 r16 : a000000100ad4d6c
r17 : 0000000000000000 r18 : 0000000000000000 r19 : 0000000000000000
r20 : a00000010099bc88 r21 : 00000000000000bb r22 : 00000000000000bb
r23 : c003fffffc0ff3fe r24 : c003fffffc000000 r25 : 00000000000ff3fe
r26 : a0000001009b7ad0 r27 : 0000000000000001 r28 : a0000001009b7ad8
r29 : 0000000000000000 r30 : a0000001009b7ad0 r31 : a0000001009b7ad0
Call Trace:
[<a000000100013940>] show_stack+0x40/0xa0
sp=e0000000037b7810 bsp=e0000000037b1118
[<a0000001000145a0>] show_regs+0x840/0x880
sp=e0000000037b79e0 bsp=e0000000037b10c0
[<a0000001000368e0>] die+0x1c0/0x2c0
sp=e0000000037b79e0 bsp=e0000000037b1078
[<a000000100036a30>] die_if_kernel+0x50/0x80
sp=e0000000037b7a00 bsp=e0000000037b1048
[<a000000100037c40>] ia64_fault+0x11e0/0x1300
sp=e0000000037b7a00 bsp=e0000000037b0fe8
[<a00000010000bdc0>] ia64_leave_kernel+0x0/0x280
sp=e0000000037b7c20 bsp=e0000000037b0fe8
[<a000000100482070>] check_modem_status+0xf0/0x360
sp=e0000000037b7df0 bsp=e0000000037b0fa0
[<a000000100482300>] serial8250_get_mctrl+0x20/0xa0
sp=e0000000037b7df0 bsp=e0000000037b0f80
[<a000000100478170>] uart_read_proc+0x250/0x860
sp=e0000000037b7df0 bsp=e0000000037b0ee0
[<a0000001001c16d0>] proc_file_read+0x1d0/0x4c0
sp=e0000000037b7e10 bsp=e0000000037b0e80
[<a0000001001394b0>] vfs_read+0x1b0/0x300
sp=e0000000037b7e20 bsp=e0000000037b0e30
[<a000000100139cd0>] sys_read+0x70/0xe0
sp=e0000000037b7e20 bsp=e0000000037b0db0
[<a00000010000bc20>] ia64_ret_from_syscall+0x0/0x20
sp=e0000000037b7e30 bsp=e0000000037b0db0
[<a000000000010620>] __kernel_syscall_via_break+0x0/0x20
sp=e0000000037b8000 bsp=e0000000037b0db0
Fix the possible NULL pointer access in check_modem_status() in 8250.c. The
check_modem_status() would access 'info' member of uart_port structure, but it
is not initialized before uart_open() is called. The check_modem_status() can
be called through /proc/tty/driver/serial before uart_open() is called.
Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com>
Signed-off-by: Taku Izumi <izumi2005@soft.fujitsu.com>
While digging through my MAP_FIXED changes, I found that rather obvious
bug in /dev/mem mmap implementation for nommu archs. get_unmapped_area()
is expected to return an address, not a pfn.
Acked-By: David Howells <dhowells@redhat.com>
3w-xxxx emulates a REQUEST_SENSE response by simply returning nothing.
Unfortunately, it's assuming that the REQUEST_SENSE command is
implemented with use_sg == 0, which is no longer the case. The oops
occurs because it's clearing the scatterlist in request_buffer instead
of the memory region.
This is fixed by using tw_transfer_internal() to transfer correctly to
the scatterlist.
Acked-by: adam radford <aradford@gmail.com>
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
[PATCH] vt: fix potential race in VT_WAITACTIVE handler
On a multiprocessor machine the VT_WAITACTIVE ioctl call may return 0 if
fg_console has already been updated in redraw_screen() but the console
switch itself hasn't been completed. Fix this by checking fg_console in
vt_waitactive() with the console sem held.
Signed-off-by: Michal Januszewski <spock@gentoo.org>
Acked-by: Antonino Daplas <adaplas@pol.net>
[SCSI] QLOGICPTI: Do not unmap DMA unless we actually mapped something.
We only map DMA when cmd->request_bufflen is non-zero for non-sg
buffers, we thus should make the same check when unmapping.
Based upon a report from Pasi Pirhonen.
PAGE_MASK is an unsigned long, so using it to mask physical addresses on
i386 (which are 64-bit wide) leads to truncation. This can result in
page->private of unrelated memory pages being modified, with disasterous
results.
Fix by not using PAGE_MASK for physical addresses; instead calculate
the correct value directly from PAGE_SIZE. Also fix a similar BUG_ON().
Signed-off-by: Avi Kivity <avi@qumranet.com>
KVM shadow page tables are always in pae mode, regardless of the guest
setting. This means that a guest pde (mapping 4MB of memory) is mapped
to two shadow pdes (mapping 2MB each).
When the guest writes to a pte or pde, we intercept the write and emulate it.
We also remove any shadowed mappings corresponding to the write. Since the
mmu did not account for the doubling in the number of pdes, it removed the
wrong entry, resulting in a mismatch between shadow page tables and guest
page tables, followed shortly by guest memory corruption.
This patch fixes the problem by detecting the special case of writing to
a non-pae pde and adjusting the address and number of shadow pdes zapped
accordingly.
HID: zeroing of bytes in output fields is bogus
This patch removes bogus zeroing of unused bits in output reports,
introduced in Simon's patch in commit d4ae650a.
According to the specification, any sane device should not care
about values of unused bits.
What is worse, the zeroing is done in a way which is broken and
might clear certain bits in output reports which are actually
_used_ - a device that has multiple fields with one value of
the size 1 bit each might serve as an example of why this is
bogus - the second call of hid_output_report() would clear the
first bit of report, which has already been set up previously.
This patch will break LEDs on SpaceNavigator, because this device
is broken and takes into account the bits which it shouldn't touch.
The quirk for this particular device will be provided in a separate
patch.
In mthca_arbel_fmr_unmap(), the high bits of the key are masked off.
This gets rid of the effect of adjust_key(), which makes sure that
bits 3 and 23 of the key are equal when the Sinai throughput
optimization is enabled, and so it may happen that an FMR will end up
with bits 3 and 23 in the key being different. This causes data
corruption, because when enabling the throughput optimization, the
driver promises the HCA firmware that bits 3 and 23 of all memory keys
will always be equal.
Fix by re-applying adjust_key() after masking the key.
Thanks to Or Gerlitz for reproducing the problem, and Ariel Shahar for
help in debug.
Signed-off-by: Michael S. Tsirkin <mst@dev.mellanox.co.il>
Signed-off-by: Roland Dreier <rolandd@cisco.com>
Update libata drive blacklist to the latest from 2.6.21
Removes one duplicate entry from blacklist table, adds several
entries for drives with broken NCQ.
[diff between 2.6.20 and 2.6.21-rc6, with one entry removed
that required new libata features]
Signed-off-by: Chuck Ebbert <cebbert@redhat.com>
libata: Clear tf before doing request sense (take 3)
patch 2/4:
Clear tf before doing request sense.
This fixes the AOpen 56X/AKH timeout problem.
(http://bugzilla.kernel.org/show_bug.cgi?id=8244)
Signed-off-by: Albert Lee <albertcc@tw.ibm.com>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
2.6.21 fix lba48 bug in libata fill_result_tf()
Current 2.6.21 libata does the following:
void ata_tf_read(struct ata_port *ap, struct ata_taskfile *tf)
struct ata_ioports *ioaddr = &ap->ioaddr;
tf->command = ata_check_status(ap);
if (tf->flags & ATA_TFLAG_LBA48) {
iowrite8(tf->ctl | ATA_HOB, ioaddr->ctl_addr);
tf->hob_feature = ioread8(ioaddr->error_addr);
static void fill_result_tf(struct ata_queued_cmd *qc)
struct ata_port *ap = qc->ap;
ap->ops->tf_read(ap, &qc->result_tf);
qc->result_tf.flags = qc->tf.flags;
Based on this, those last two statements fill_result_tf()
appear to me to be in the wrong order, in that the tf->flags
are uninitialized at the point where tf_read() is invoked.
So for lba48 commands, tf_read() won't be reading back the
full lba48 register contents..
Correct?
This patch corrects fill_result_tf() so that the flags
get copied to result_tf before they are used by tf_read().
Signed-off-by: Mark Lord <mlord@pobox.com>
ahci.c: walkaround for SB600 SATA internal error issue
There is a HW issue in ATI SB600 SATA that PxSERR.E should not be
set on some conditions, for example, when there is no media in SATA
CD/DVD drive or media is not ready, AHCI controller fails to execute
ATAPI commands and reports PORT_IRQ_TF_ERR, but ATI SB600 SATA
controller sets PxSERR.E at the
same time, which is not necessary.
This patch is just to ignore the INTERNAL ERROR in such case.
Without this patch, ahci error handler will report many errors as
below:
----------- cut from dmesg -----------
ata9: soft resetting port
ata9: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
ata9.00: configured for UDMA/33
ata9: EH complete
ata9.00: exception Emask 0x40 SAct 0x0 SErr 0x800 action 0x2
ata9.00: (irq_stat 0x40000001)
ata9.00: cmd a0/00:00:00:00:20/00:00:00:00:00/a0 tag 0 cdb 0x0 data 0
res 51/24:03:00:00:20/00:00:00:00:00/a0 Emask 0x40 (internal error)
ata9: EH complete
ata9.00: cmd a0/01:00:00:00:00/00:00:00:00:00/a0 tag 0 cdb 0x43 data 12 in
res 51/24:03:00:00:00/00:00:00:00:00/a0 Emask 0x40 (internal error)
-------- end cut ---------
Signed-off-by: Conke Hu <conke.hu@amd.com>
libata bugfix: preserve LBA bit for HDIO_DRIVE_TASK
Preserve the LBA bit in the DevSel/Head register for HDIO_DRIVE_TASK.
ide: use correct IDE error recovery
IDE error recovery is using IDLE IMMEDIATE if the drive is busy or has DRQ set.
This violates the ATA spec (can only send IDLEÃ IMMEDIATE when drive is not
busy) and really hoses up some drives (modern drives will not be able to
recover using this error handling). The correct thing to do is issue a SRST
followed by a SET FEATURES command. This is what Western Digital recommends
for error recovery and what Western Digital says Windows does. à Ità also does
not violate the ATA spec as far as I can tell.
Bart:
* port the patch over the current tree
* undo the recalibration code removal
* send SET FEATURES command after checking for good drive status
* don't check whether the current request is of REQ_TYPE_ATA_{CMD,TASK}
type because we need to send SET FEATURES before handling any requests
* some pre-ATA4 drives require INITIALIZE DEVICE PARAMETERS command before
other commands (except IDENTIFY) so send SET FEATURES only if there are
no pending drive->special requests
* update comments and patch description
* any bugs introduced by this patch are mine and not Suleiman's :-)
Signed-off-by: Suleiman Souhlal <suleiman@google.com>
Acked-by: Alan Cox <alan@redhat.com>
[SCSI]: Fix scsi_send_eh_cmnd scatterlist handling
This fixes a regression caused by commit:
2dc611de5a3fd955cd0298c50691d4c05046db97
The sense buffer code in scsi_send_eh_cmnd was changed to use
alloc_page() and a scatter list, but the sense data copy was not
updated to match so what we actually get in the sense buffer is total
grabage starting with the kernel address of the struct page we got.
Basically the stack frame of scsi_send_eh_cmd() is what ends up
in the sense buffer.
Depending upon how pointers look on a given platform, you can
end up getting sr_ioctl.c errors when you mount a cdrom. If
the CDROM gives a check condition for GPCMD_GET_CONFIGURATION issued
by drivers/cdrom/cdrom.c:cdrom_mmc_profile(), sr_ioctl will
spit out this error message in sr_do_ioctl() with the way pointers
are on sparc64:
default:
printk(KERN_ERR "%s: CDROM (ioctl) error, command: ", cd->cdi.name);
__scsi_print_command(cgc->cmd);
scsi_print_sense_hdr("sr", &sshdr);
err = -EIO;
This is the error Tom Callaway reported in:
http://marc.info/?l=linux-sparc&m=117407453208101&w=2
Anyways, fix this by using page_address(sgl.page) which is OK
because we know this is low-mem due to GFP_ATOMIC.
Acked-by: Christoph Hellwig <hch@lst.de>
[IFB]: Fix crash on input device removal
The input_device pointer is not refcounted, which means the device may
disappear while packets are queued, causing a crash when ifb passes packets
with a stale skb->dev pointer to netif_rx().
Fix by storing the interface index instead and do a lookup where neccessary.
Acked-by: Jamal Hadi Salim <hadi@cyberus.ca>
Your usual dont-flush_scheduled_work-with-RTNL-held stuff.
It is a bit different here since the thread runs permanently
or is only occasionally kicked for recovery depending on the
hardware revision.
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
Cc: Ben Greear <greearb@candelatech.com>
If 'num_pages' were ever 1 more than a multiple of 8 (32bit platforms)
for of 16 (64 bit platforms). filemap_attr would be allocated one
'unsigned long' shorter than required. We need a round-up in there.
Signed-off-by: Neil Brown <neilb@suse.de>
HID: Do not discard truncated input reports
Truncated reports should not be discarded since it prevents buggy
devices from communicating with userspace.
Prior to the regession introduced in 2.6.20, a shorter-than-expected
report in hid_input_report() was passed thru after having the missing
bytes cleared. This behavior was established over a few patches in the
2.6.early-teens days, including commit
cd6104572bca9e4afe0dcdb8ecd65ef90b01297b.
This patch restores the previous behavior and fixes the regression.
Signed-off-by: Adam Kropelin <akropel1@rochester.rr.com>
DVB: pluto2: fix incorrect TSCR register setting
The ADEF bits in the TSCR register have different meanings in read
and write mode. For this reason ADEF has to be reset on every
read-modify-write operation.
This patch introduces a special write function for this register, which
takes care of it.
Thanks to Holger Magnussen for pointing my nose at this problem.
(cherry picked from commit 1489f90a49f0603a393e1800d729050f6e332bec)
Signed-off-by: Andreas Oberritter <obi@linuxtv.org>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
DVB: tda10086: fix DiSEqC message length
Setting the message length to zero means to send one byte, so you need a
subtraction instead of an addition.
(cherry picked from commit d420cb44693b8370cbf06c3e31b4b5dec66c9f86)
The workaround Yukon EC-U wasn't comparing with correct
version and wasn't doing correct setup. Without it, 88e8056
throws all sorts of errors.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
Some of these chips are disabled until clock is enabled.
This fixes:
http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=404107
Driver needs to turn off carrier when down.
Driver needs to turn off carrier when down, otherwise it can
confuse bonding and bridging and looks like carrier is on immediately
when it is brought back up.
This adds working recovery from transmit timeouts. Previous code
didn't do enough to truly reset chip.
It is a backport of the 2.6.21 code.
Commit d720bc4b8fc5d6d179ef094908d4fbb5e436ffad partially removed a private
implementation of baud speed decoding. However it doesn't seem to be
complete: after the speed is decoded, it is still being used as an index to
a local speed table (array overrun, no doubt).
This was found by Graham Murray who noticed it caused a 2.6.19 regression
with the SX driver: https://bugs.gentoo.org/170554
Signed-off-by: Daniel Drake <dsd@gentoo.org>
Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
[libata] sata_mv: Fix 50xx irq mask
IRQ mask bits assumed a 60xx or newer generation chip, which is very
wrong for the 50xx series. Luckily both generations shared the per-port
interrupt mask bits, leaving only the "misc chip features" bits to be
completely mismatched.
Fix 50xx by ensuring we only program bits that exist.
[libata] sata_mv: don't touch reserved bits in EDMA config register
The code in mv_edma_cfg() reflected its 60xx origins, by doing things
[slightly] incorrectly on the older 50xx and newer 6042/7042 chips.
Clean up the EDMA configuration setup such that, each chip family
carefully initializes its own EDMA setup.
libata bugfix: HDIO_DRIVE_TASK
I was trying to use HDIO_DRIVE_TASK for something today,
and discovered that the libata implementation does not copy
over the upper four LBA bits from args[6].
This is serious, as any tools using this ioctl would have their
commands applied to the wrong sectors on the drive, possibly resulting
in disk corruption.
Ideally, newer apps should use SG_IO/ATA_16 directly,
avoiding this bug. But with libata poised to displace drivers/ide,
better compatibility here is a must.
This patch fixes libata to use the upper four LBA bits passed
in from the ioctl.
The original drivers/ide implementation copies over all bits
except for the master/slave select bit. With this patch,
libata will copy only the four high-order LBA bits,
just in case there are assumptions elsewhere in libata (?).
libata: clear TF before IDENTIFYing
Some devices chock if Feature is not clear when IDENTIFY is issued.
Set ATA_TFLAG_ISADDR | ATA_TFLAG_DEVICE for IDENTIFY such that whole
TF is cleared when reading ID data.
Kudos to Art Haas for testing various futile patches over several
months and Mark Lord for pointing out the fix.
Cc: Art Haas <ahaas@airmail.net>
Cc: Mark Lord <mlord@pobox.com>
"ide: fix drive side 80c cable check, take 2" patch from Tejun Heo (commit
fab59375b9543f84d1714f7dd00f5d11e531bd3e) fixed 80c bit test (bit13 of word93)
but we also need to fix master/slave IDENTIFY order (slave device should be
probed first in order to make it release PDIAG- signal) and we should also
check for pre-ATA3 slave devices (which may not release PDIAG- signal).
Unfortunately the fact that IDE driver doesn't reset devices itself helps
only a bit as it seems that some BIOS-es reset ATA devices after programming
the chipset, some BIOS-es can be set to not probe/configure selected devices,
there may be no BIOS in case of add-on cards etc.
Since we are quite late in the release cycle and the required changes will
affect a lot of systems just revert the fix for now.
[ Please also see libata commit f31f0cc2f0b7527072d94d02da332d9bb8d7d94c. ]
I2O subsystem has been broken in mainstream several months ago (after
2.6.18). Commit 4aff5e2333c9a1609662f2091f55c3f6fffdad36 from Jens
Axboe split struct request ->flags into two parts: cmd_type and
cmd_flags.
In i2o layer this patch has replaced flag REQ_SPECIAL by the according
cmd_type. However i2o has used REQ_SPECIAL not as command type but as
driver-specific flag for the debug purposes. As result all i2o requests
have type "special" now, are not processed to the hardware and fail with
I/O error:
i2o/hda:<3>Buffer I/O error on device i2o/hda, logical block 0
unable to read partition table
block-osm: device added (TID: 207): i2o/hda
The following patch removes the extra debug checks without any drawbacks and
restores the normal driver's work.
Signed-off-by: Vasily Averin <vvs@sw.ru>
Acked-by: Markus Lidel <Markus.Lidel@shadowconnect.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
jmicron: make ide jmicron driver play nice with libata ones
When libata is configured, the device is configured such that SATA and
PATA ports live in separate functions with different programming
interfaces. pata_jmicron and ide jmicron drivers can drive only the
PATA part.
This patch makes jmicron match PCI class code such that it doesn't
attach itself to the SATA part preventing the proper ahci driver from
attaching.
This change is suggested by Bartlomiej.
Cc: Jeff Garzik <jeff@garzik.org>
Cc: justin@jmicron.com
dvb-core: fix several locking related problems
Fix several instances of dvb-core functions using mutex_lock_interruptible
and returning -ERESTARTSYS where the calling function will either never
retry or never check the return value.
These cause a race condition with dvb_dmxdev_filter_free and
dvb_dvr_release, both of which are filesystem release functions whose
return value is ignored and will never be retried. When this happens it
becomes impossible to open dvr0 again (-EBUSY) since it has not been
released properly.
(cherry picked from commit c278850206fd9df0bb62a72ca0b277fe20c5a452)
Signed-off-by: Simon Arlott <simon@fire.lp0.eu>
Acked-By: Johannes Stezenbach <js@linuxtv.org>
DVB: isl6421: don't reference freed memory
After freeing a block there should be no reference to this block.
(cherry picked from commit 09d4895488d4df5c58b739573846f514ceabc911)
Signed-off-by: Thomas Viehweger <Thomas.Viehweger@marconi.com>
