path: root/drivers
2010-02-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/anholt/drm-intel * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/anholt/drm-intel: drm/i915: hold ref on flip object until it completes drm/i915: Fix crash while aborting hibernation drm/i915: Correctly return -ENOMEM on allocation failure in cmdbuf ioctls. drm/i915: fix pipe source image setting in flip command drm/i915: fix flip done interrupt on Ironlake drm/i915: untangle page flip completion drm/i915: handle FBC and self-refresh better drm/i915: Increase fb alignment to 64k drm/i915: Update write_domains on active list after flush. drm/i915: Rework DPLL calculation parameters for Ironlake
2010-02-12regulator/lp3971: vol_map out of bounds in lp3971_{ldo,dcdc}_set_voltage()Roel Kluin
After `for (val = LDO_VOL_MIN_IDX; val <= LDO_VOL_MAX_IDX; val++)', if no break occurs, val reaches LDO_VOL_MIN_IDX + 1, which is out of bounds for ldo45_voltage_map[] and ldo123_voltage_map[]. Similarly BUCK_TARGET_VOL_MAX_IDX + 1 is out of bounds for buck_voltage_map[]. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-02-12regulator: Fix display of null constraints for regulatorsMark Brown
If the regulator constraints are empty and there is no voltage reported then nothing will be added to the text displayed for the constraints, leading to random stack data being printed. This is unlikely to happen for practical regulators since most will at least report a voltage but should still be fixed. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-02-11Merge branch 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bpLinus Torvalds
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp: amd64_edac: Do not falsely trigger kerneloops
2010-02-11Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: cciss: Make cciss_seq_show handle holes in the h->drv[] array cfq-iosched: split seeky coop queues after one slice
2010-02-11Merge git://git.infradead.org/users/cbou/battery-2.6.33Linus Torvalds
* git://git.infradead.org/users/cbou/battery-2.6.33: wm97xx_battery: Handle missing platform data gracefully
2010-02-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: [SCSI] qla2xxx: Obtain proper host structure during response-queue processing. [SCSI] compat_ioct: fix bsg SG_IO [SCSI] qla2xxx: make msix interrupt handler safe for irq [SCSI] zfcp: Report FC BSG errors in correct field [SCSI] mptfusion : mptscsih_abort return value should be SUCCESS instead of value 0.
2010-02-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: psmouse - make sure we don't schedule reconnects after cleanup
2010-02-11Merge branch 'drm-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (30 commits) vgaarb: fix incorrect dereference of userspace pointer. drm/radeon/kms: retry auxch on 0x20 timeout value. drm/radeon: Skip dma copy test in benchmark if card doesn't have dma engine. drm/vmwgfx: Fix a circular locking dependency bug. drm/vmwgfx: Drop scanout flag compat and add execbuf ioctl parameter members. Bumps major. drm/vmwgfx: Report propper framebuffer_{max|min}_{width|height} drm/vmwgfx: Update the user-space interface. drm/radeon/kms: fix screen clearing before fbcon. nouveau: fix state detection with switchable graphics drm/nouveau: move dereferences after null checks drm/nv50: make the pgraph irq handler loop like the pre-nv50 version drm/nv50: delete ramfc object after disabling fifo, not before drm/nv50: avoid unloading pgraph context when ctxprog is running drm/nv50: align size of buffer object to the right boundaries. drm/nv50: disregard dac outputs in nv50_sor_dpms() drm/nv50: prevent multiple init tables being parsed at the same time drm/nouveau: make dp auxch xfer len check for reads only drm/nv40: make INIT_COMPUTE_MEM a NOP, just like nv50 drm/nouveau: Add proper vgaarb support. drm/nouveau: Fix fbcon on mixed pre-NV50 + NV50 multicard. ...
2010-02-11Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: drivers/dma: Correct NULL test async-tx: fix buffer submission error handling in ipu_idma.c dmaengine: correct onstack wait_queue_head declaration ioat: fix infinite timeout checking in ioat2_quiesce dmaengine: fix memleak in dma_async_device_unregister
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: RDMA/cm: Revert association of an RDMA device when binding to loopback
2010-02-11Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, apic: Don't use logical-flat mode when CPU hotplug may exceed 8 CPUs x86-32: Make AT_VECTOR_SIZE_ARCH=2 x86/agp: Fix amd64-agp module initialization regression x86, doc: Fix minor spelling error in arch/x86/mm/gup.c
2010-02-11edac: mpc85xx fix build regression by removing unused debug codePeter Tyser
Some unused, unsupported debug code existed in the mpc85xx EDAC driver that resulted in a build failure when CONFIG_EDAC_DEBUG was defined: drivers/edac/mpc85xx_edac.c: In function 'mpc85xx_mc_err_probe': drivers/edac/mpc85xx_edac.c:1031: error: implicit declaration of function 'edac_mc_register_mcidev_debug' drivers/edac/mpc85xx_edac.c:1031: error: 'debug_attr' undeclared (first use in this function) drivers/edac/mpc85xx_edac.c:1031: error: (Each undeclared identifier is reported only once drivers/edac/mpc85xx_edac.c:1031: error: for each function it appears in.) Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Doug Thompson <dougthompson@xmission.com Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-11edac: mpc85xx fix bad page calculationPeter Tyser
Commit b4846251727a38a7f248e41308c060995371dd05 ("edac: mpc85xx add mpc83xx support") accidentally broke how a chip select's first and last page addresses are calculated. The page addresses are being shifted too far right by PAGE_SHIFT. This results in errors such as: EDAC MPC85xx MC1: Err addr: 0x003075c0 EDAC MPC85xx MC1: PFN: 0x00000307 EDAC MPC85xx MC1: PFN out of range! EDAC MC1: INTERNAL ERROR: row out of range (4 >= 4) EDAC MC1: CE - no information available: INTERNAL ERROR The vaule of PAGE_SHIFT is already being taken into consideration during the calculation of the 'start' and 'end' variables, thus it is not necessary to account for it again when setting a chip select's first and last page address. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Cc: Ira W. Snyder <iws@ovro.caltech.edu> Cc: Kumar Gala <galak@gate.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-11mmc_test: block addressed cardsJohan Kristell
This patch fixes a bug in the multiblock write tests where the written data is read back for verifying one block at a time. The tests in mmc_test assumes that all cards are byte addressable. This will cause the multi block write tests to fail, leading the user of the mmc_test driver thinking there is something wrong with the sdhci driver they are testing. The start address for the block is calculated as: blocknum * 512. For block addressable cards the blocknum alone should be used. Signed-off-by: Johan Kristell <johan.kristell@axis.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-11tpm_infineon: fix suspend/resume handler for pnp_driverMarcel Selhorst
When suspending, tpm_infineon calls the generic suspend function of the TPM framework. However, the TPM framework does not return and the system hangs upon suspend. When sending the necessary command "TPM_SaveState" directly within the driver, suspending and resuming works fine. Signed-off-by: Marcel Selhorst <m.selhorst@sirrix.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Debora Velarde <debora@linux.vnet.ibm.com> Cc: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Cc: <stable@kernel.org> [2.6.32.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-11amd64_edac: Do not falsely trigger kerneloopsBorislav Petkov
An unfortunate "WARNING" in the message amd64_edac dumps when the system doesn't support DRAM ECC or ECC checking is not enabled in the BIOS used to trigger kerneloops which qualified the message as an OOPS thus misleading the users. See, e.g. https://bugs.launchpad.net/ubuntu/+source/linux/+bug/422536 http://bugzilla.kernel.org/show_bug.cgi?id=15238 Downgrade the message level to KERN_NOTICE and fix the formulation. Cc: stable@kernel.org # .32.x Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Acked-by: Doug Thompson <dougthompson@xmission.com>
2010-02-11vgaarb: fix incorrect dereference of userspace pointer.Andy Getzendanner
This patch corrects a userspace pointer dereference in the VGA arbiter in 2.6.32.1. copy_from_user() is used at line 822 to copy the contents of buf into kbuf, but a call to strncmp() on line 964 uses buf rather than kbuf. This problem led to a GPF in strncmp() when X was started on my x86_32 systems. X triggered the behavior with a write of "target PCI:0000:01:00.0" to /dev/vga_arbiter. The patch has been tested against 2.6.32.1 and observed to correct the GPF observed when starting X or manually writing the string "target PCI:0000:01:00.0" to /dev/vga_arbiter. Signed-off-by: Andy Getzendanner <james.getzendanner@students.olin.edu> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-02-11Merge branch 'drm-radeon-linus' of ../drm-nextDave Airlie
* 'drm-radeon-linus' of ../drm-next: drm/radeon/kms: retry auxch on 0x20 timeout value. drm/radeon: Skip dma copy test in benchmark if card doesn't have dma engine. drm/radeon/kms: fix screen clearing before fbcon. drm/radeon/kms: add quirk for VGA without DDC on rv730 XFX card. drm/radeon/kms: don't crash if no DDC bus on VGA/DVI connector. drm/radeon/kms: change Kconfig text to reflect the new option. drm/radeon/kms: suspend and resume audio stuff
2010-02-11drm/radeon/kms: retry auxch on 0x20 timeout value.Dave Airlie
ATOM appears to return 0x20 which seems to mean some sort of timeout. retry the transaction up to 10 times before failing, this makes DP->VGA convertor we bought work at least a bit more predictably. Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-02-11drm/radeon: Skip dma copy test in benchmark if card doesn't have dma engine.Pauli Nieminen
radeon_copy_dma is only available for r200 or newer cards. Call to radeon_copy_dma would result to NULL pointer dereference if benchmarking asic without dma engine. Signed-off-by: Pauli Nieminen <suokkos@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-02-11Merge remote branch 'nouveau/for-airlied' of nouveau-2.6Dave Airlie
* 'nouveau/for-airlied' of /home/airlied/kernel/drm-next: nouveau: fix state detection with switchable graphics drm/nouveau: move dereferences after null checks drm/nv50: make the pgraph irq handler loop like the pre-nv50 version drm/nv50: delete ramfc object after disabling fifo, not before drm/nv50: avoid unloading pgraph context when ctxprog is running drm/nv50: align size of buffer object to the right boundaries. drm/nv50: disregard dac outputs in nv50_sor_dpms() drm/nv50: prevent multiple init tables being parsed at the same time drm/nouveau: make dp auxch xfer len check for reads only drm/nv40: make INIT_COMPUTE_MEM a NOP, just like nv50 drm/nouveau: Add proper vgaarb support. drm/nouveau: Fix fbcon on mixed pre-NV50 + NV50 multicard. drivers/gpu/drm/nouveau/nouveau_grctx.c: correct NULL test drm/nouveau: call ttm_bo_wait with the bo lock held to prevent hang drm/nouveau: Fixup semaphores on pre-nv50 cards. drm/nouveau: Add getparam to get available PGRAPH units. drm/nouveau: Add module options to disable acceleration. drm/nouveau: fix non-vram notifier blocks
2010-02-11drm/vmwgfx: Fix a circular locking dependency bug.Thomas Hellstrom
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-02-11drm/vmwgfx: Drop scanout flag compat and add execbuf ioctl parameter ↵Jakob Bornecrantz
members. Bumps major. Even if this bumps the version to 1 it does not mean the driver is out of staging. From what we know this is the last backwards incompatible change to the driver. Signed-off-by: Jakob Bornecrantz <jakob@vmware.com> Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-02-11drm/vmwgfx: Report propper framebuffer_{max|min}_{width|height}Jakob Bornecrantz
Signed-off-by: Jakob Bornecrantz <jakob@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-02-11drm/vmwgfx: Update the user-space interface.Thomas Hellstrom
When time-based throttling is implemented, we need to bump minor. When the old way of detecting scanout is removed, we need to bump major. In the meantime, this change should not break existing user-space. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Jakob Bornecrantz <jakob@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-02-10drm/i915: hold ref on flip object until it completesJesse Barnes
This will prevent things from falling over if the user frees the flip buffer before we complete the flip, since we'll hold an internal reference. Reported-by: Kristian Høgsberg <krh@bitplanet.net> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Eric Anholt <eric@anholt.net>
2010-02-10drm/i915: Fix crash while aborting hibernationRafael J. Wysocki
Commit cbda12d77ea590082edb6d30bd342a67ebc459e0 (drm/i915: implement new pm ops for i915) introduced the problem that if s2disk hibernation is aborted, the system will crash, because i915_pm_freeze() does nothing, while it should at least reverse some operations carried out by i915_suspend(). Fix this issue by splitting the i915 suspend into a freeze part a suspend part, where the latter is not executed before creating a hibernation image, and the i915 resume into a "low-level" resume part and a thaw part, where the former is not executed after the image has been created. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Tested-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Signed-off-by: Eric Anholt <eric@anholt.net>
2010-02-11drm/radeon/kms: fix screen clearing before fbcon.Dave Airlie
This memset_io was added to debug something way back and got left behind, memset the fb to black so the borders don't be all white. Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-02-11nouveau: fix state detection with switchable graphicsMatthew Garrett
Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2010-02-11drm/nouveau: move dereferences after null checksMarcin Slusarz
Reported-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Signed-off-by: Maarten Maathuis <madman2003@gmail.com> Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2010-02-10drm/i915: Correctly return -ENOMEM on allocation failure in cmdbuf ioctls.Owain Ainsworth
Signed-off-by: Owain G. Ainsworth <oga@openbsd.org> Signed-off-by: Eric Anholt <eric@anholt.net>
2010-02-10drm/i915: fix pipe source image setting in flip commandZhenyu Wang
The MI_DISPLAY_FLIP command needs to be set the same pipe source image like in pipe source register, e.g source image size minus one. This fixes screen corrupt issue on Ironlake. Signed-off-by: Zhenyu Wang <zhenyuw@linux.intel.com> Signed-off-by: Eric Anholt <eric@anholt.net>
2010-02-10drm/i915: fix flip done interrupt on IronlakeZhenyu Wang
On Ironlake plane flip interrupt means flip done event already, the behavior is not like old chips, and perform like other usual interrupt. So only need to handle flip done event when receiving that interrupt. Signed-off-by: Zhenyu Wang <zhenyuw@linux.intel.com> Signed-off-by: Eric Anholt <eric@anholt.net>
2010-02-10drm/i915: untangle page flip completionJesse Barnes
When a new page flip is requested, we need to both queue an unpin for the current framebuffer, and also increment the flip pending count on the newly submitted buffer. At flip finish time, we need to unpin the old fb and decrement the flip pending count on the new buffer. The old code was conflating the two, and led to hangs when new direct rendered apps were started, replacing the existing frame buffer. This patch splits out the buffers and prevents the hangs. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Reviewed-by: Kristian Høgsberg <krh@bitplanet.net> Signed-off-by: Eric Anholt <eric@anholt.net>
2010-02-10drm/i915: handle FBC and self-refresh betterJesse Barnes
On 945, we need to avoid entering self-refresh if the compressor is busy, or we may cause display FIFO underruns leading to ugly flicker. Fixes fdo bug #24314, kernel bug #15043. Tested-by: Alexander Lam <lambchop468@gmail.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Tested-by: Julien Cristau <jcristau@debian.org> (fd.o #25371) Cc: stable@kernel.org Signed-off-by: Eric Anholt <eric@anholt.net>
2010-02-10drm/i915: Increase fb alignment to 64kChris Wilson
An untiled framebuffer must be aligned to 64k. This is normally handled by intel_pin_and_fence_fb_obj(), but the intelfb_create() likes to be different and do the pinning itself. However, it aligns the buffer object incorrectly for pre-i965 chipsets causing a PGTBL_ERR when it is installed onto the output. Fixes: KMS error message while initializing modesetting - render error detected: EIR: 0x10 [i915] http://bugs.freedesktop.org/show_bug.cgi?id=22936 Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: stable@kernel.org Signed-off-by: Eric Anholt <eric@anholt.net>
2010-02-10drm/i915: Update write_domains on active list after flush.Daniel Vetter
Before changing the status of a buffer with a pending write we will await upon a new flush for that buffer. So we can take advantage of any flushes posted whilst the buffer is active and pending processing by the GPU, by clearing its write_domain and updating its last_rendering_seqno -- thus saving a potential flush in deep queues and improves flushing behaviour upon eviction for both GTT space and fences. In order to reduce the time spent searching the active list for matching write_domains, we move those to a separate list whose elements are the buffers belong to the active/flushing list with pending writes. Orignal patch by Chris Wilson <chris@chris-wilson.co.uk>, forward-ported by me. In addition to better performance, this also fixes a real bug. Before this changes, i915_gem_evict_everything didn't work as advertised. When the gpu was actually busy and processing request, the flush and subsequent wait would not move active and dirty buffers to the inactive list, but just to the flushing list. Which triggered the BUG_ON at the end of this function. With the more tight dirty buffer tracking, all currently busy and dirty buffers get moved to the inactive list by one i915_gem_flush operation. I've left the BUG_ON I've used to prove this in there. References: Bug 25911 - 2.10.0 causes kernel oops and system hangs http://bugs.freedesktop.org/show_bug.cgi?id=25911 Bug 26101 - [i915] xf86-video-intel 2.10.0 (and git) triggers kernel oops within seconds after login http://bugs.freedesktop.org/show_bug.cgi?id=26101 Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Tested-by: Adam Lantos <hege@playma.org> Cc: stable@kernel.org Signed-off-by: Eric Anholt <eric@anholt.net>
2010-02-10drm/i915: Rework DPLL calculation parameters for IronlakeZhenyu Wang
Got Ironlake DPLL parameter table, which reflects the hardware optimized values. So this one trys to list DPLL parameters for different output types, should potential fix clock issue seen on new Arrandale CPUs. This fixes DPLL setting failure on one 1920x1080 dual channel LVDS for Ironlake. Test has also been made on LVDS panels with smaller size and CRT/HDMI/DP ports for different monitors on their all supported modes. Update: - Change name of double LVDS to dual LVDS. - Fix SSC 120M reference clock to use the right range. Cc: CSJ <changsijay@gmail.com> Signed-off-by: Zhenyu Wang <zhenyuw@linux.intel.com> Signed-off-by: Eric Anholt <eric@anholt.net>
2010-02-10RDMA/cm: Revert association of an RDMA device when binding to loopbackSean Hefty
Revert the following change from commit 6f8372b6 ("RDMA/cm: fix loopback address support") The defined behavior of rdma_bind_addr is to associate an RDMA device with an rdma_cm_id, as long as the user specified a non- zero address. (ie they weren't just trying to reserve a port) Currently, if the loopback address is passed to rdma_bind_addr, no device is associated with the rdma_cm_id. Fix this. It turns out that important apps such as Open MPI depend on rdma_bind_addr() NOT associating any RDMA device when binding to a loopback address. Open MPI is being updated to deal with this, but at least until a new Open MPI release is available, maintain the previous behavior: allow rdma_bind_addr() to succeed, but do not bind to a device. Signed-off-by: Sean Hefty <sean.hefty@intel.com> Acked-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-02-10drivers/dma: Correct NULL testJulia Lawall
cohd_fin has already been verified not to be NULL, so the argument to BUG_ON cannot be true. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ expression *x; expression e; identifier l; @@ if (x == NULL || ...) { ... when forall return ...; } ... when != goto l; when != x = e when != &x *x == NULL // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-02-10async-tx: fix buffer submission error handling in ipu_idma.cGuennadi Liakhovetski
If submitting new buffer failed, a wrong descriptor gets completed and it doesn't check, if a callback is at all defined, which can lead to an Oops. Fix these bugs and make ipu_update_channel_buffer() void, because it never fails. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-02-10Merge branch 'i2c-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: i2c-tiny-usb: Fix on big-endian systems
2010-02-10Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: [S390] Fix struct _lowcore layout. [S390] qdio: prevent call trace if CHPID is offline [S390] qdio: continue polling for buffer state ERROR
2010-02-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (29 commits) drivers/net: Correct NULL test MAINTAINERS: networking drivers - Add git net-next tree net/sched: Fix module name in Kconfig cxgb3: fix GRO checksum check dst: call cond_resched() in dst_gc_task() netfilter: nf_conntrack: fix hash resizing with namespaces netfilter: xtables: compat out of scope fix netfilter: nf_conntrack: restrict runtime expect hashsize modifications netfilter: nf_conntrack: per netns nf_conntrack_cachep netfilter: nf_conntrack: fix memory corruption with multiple namespaces Bluetooth: Keep a copy of each HID device's report descriptor pktgen: Fix freezing problem igb: make certain to reassign legacy interrupt vectors after reset irda: add missing BKL in irnet_ppp ioctl irda: unbalanced lock_kernel in irnet_ppp ixgbe: Fix return of invalid txq ixgbe: Fix ixgbe_tx_map error path netxen: protect resource cleanup by rtnl lock netxen: fix tx timeout recovery for NX2031 chip Bluetooth: Enter active mode before establishing a SCO link. ...
2010-02-09Merge branch 'for-linus' of git://neil.brown.name/mdLinus Torvalds
* 'for-linus' of git://neil.brown.name/md: md: fix some lockdep issues between md and sysfs. md: fix 'degraded' calculation when starting a reshape.
2010-02-10md: fix some lockdep issues between md and sysfs.NeilBrown
====== This fix is related to http://bugzilla.kernel.org/show_bug.cgi?id=15142 but does not address that exact issue. ====== sysfs does like attributes being removed while they are being accessed (i.e. read or written) and waits for the access to complete. As accessing some md attributes takes the same lock that is held while removing those attributes a deadlock can occur. This patch addresses 3 issues in md that could lead to this deadlock. Two relate to calling flush_scheduled_work while the lock is held. This is probably a bad idea in general and as we use schedule_work to delete various sysfs objects it is particularly bad. In one case flush_scheduled_work is called from md_alloc (called by md_probe) called from do_md_run which holds the lock. This call is only present to ensure that ->gendisk is set. However we can be sure that gendisk is always set (though possibly we couldn't when that code was originally written. This is because do_md_run is called in three different contexts: 1/ from md_ioctl. This requires that md_open has succeeded, and it fails if ->gendisk is not set. 2/ from writing a sysfs attribute. This can only happen if the mddev has been registered in sysfs which happens in md_alloc after ->gendisk has been set. 3/ from autorun_array which is only called by autorun_devices, which checks for ->gendisk to be set before calling autorun_array. So the call to md_probe in do_md_run can be removed, and the check on ->gendisk can also go. In the other case flush_scheduled_work is being called in do_md_stop, purportedly to wait for all md_delayed_delete calls (which delete the component rdevs) to complete. However there really isn't any need to wait for them - they have already been disconnected in all important ways. The third issue is that raid5->stop() removes some attribute names while the lock is held. There is already some infrastructure in place to delay attribute removal until after the lock is released (using schedule_work). So extend that infrastructure to remove the raid5_attrs_group. This does not address all lockdep issues related to the sysfs "s_active" lock. The rest can be address by splitting that lockdep context between symlinks and non-symlinks which hopefully will happen. Signed-off-by: NeilBrown <neilb@suse.de>
2010-02-10drm/nv50: make the pgraph irq handler loop like the pre-nv50 versionMaarten Maathuis
Unset the bit that indicates that a ctxprog can continue at the end. Signed-off-by: Maarten Maathuis <madman2003@gmail.com> Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2010-02-10drm/nv50: delete ramfc object after disabling fifo, not beforeMaarten Maathuis
ramfc is zero'ed upon destruction, so it's safer to do things in the right order. Signed-off-by: Maarten Maathuis <madman2003@gmail.com> Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2010-02-10drm/nv50: avoid unloading pgraph context when ctxprog is runningMaarten Maathuis
- We need to disable pgraph fifo access before checking the current channel, otherwise we could still hit a running ctxprog. - The writes to 0x400500 are already handled by pgraph->fifo_access and are therefore redundant, moreover pgraph fifo access should not be reenabled before current context is set as invalid. So remove them altogether. Signed-off-by: Maarten Maathuis <madman2003@gmail.com> Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
