path: root/drivers
2012-04-15Merge commit 'v3.4-rc3' into rt-3.4-rc3-rt4v3.4-rc3-rt4Clark Williams
2012-04-15Merge branch 'fixes' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: "Nothing too disasterous, the biggest thing being the removal of the regulator support for vcore in the AMBA driver; only one SoC was using this and it got broken during the last merge window, which then started causing problems for other people. Mutual agreement was reached for it to be removed." * 'fixes' of git://git.linaro.org/people/rmk/linux-arm: ARM: 7386/1: jump_label: fixup for rename to static_key ARM: 7384/1: ThumbEE: Disable userspace TEEHBR access for !CONFIG_ARM_THUMBEE ARM: 7382/1: mm: truncate memory banks to fit in 4GB space for classic MMU ARM: 7359/2: smp_twd: Only wait for reprogramming on active cpus ARM: 7383/1: nommu: populate vectors page from paging_init ARM: 7381/1: nommu: fix typo in mm/Kconfig ARM: 7380/1: DT: do not add a zero-sized memory property ARM: 7379/1: DT: fix atags_to_fdt() second call site ARM: 7366/3: amba: Remove AMBA level regulator support ARM: 7377/1: vic: re-read status register before dispatching each IRQ handler ARM: 7368/1: fault.c: correct how the tsk->[maj|min]_flt gets incremented
2012-04-15PCI: Fix regression in pci_restore_state(), v3Rafael J. Wysocki
Commit 26f41062f28d ("PCI: check for pci bar restore completion and retry") attempted to address problems with PCI BAR restoration on systems where FLR had not been completed before pci_restore_state() was called, but it did that in an utterly wrong way. First off, instead of retrying the writes for the BAR registers only, it did that for all of the PCI config space of the device, including the status register (whose value after the write quite obviously need not be the same as the written one). Second, it added arbitrary delay to pci_restore_state() even for systems where the PCI config space restoration was successful at first attempt. Finally, the mdelay(10) it added to every iteration of the writing loop was way too much of a delay for any reasonable device. All of this actually caused resume failures for some devices on Mikko's system. To fix the regression, make pci_restore_state() only retry the writes for BAR registers and only wait if the first read from the register doesn't return the written value. Additionaly, make it wait for 1 ms, instead of 10 ms, after every failing attempt to write into config space. Reported-by: Mikko Vinni <mmvinni@yahoo.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-15Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull "ARM: a few more SoC fixes for 3.4-rc" from Olof Johansson: - A handful of warning and build fixes for Qualcomm MSM - Build/warning and bug fixes for Samsung Exynos - A fix from Rob Herring that removes misplaced interrupt-parent properties from a few device trees - A fix to OMAP dealing with cpufreq build errors, removing some of the offending code since it was redundant anyway * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: OMAP: clock: cleanup CPUfreq leftovers, fix build errors ARM: dts: remove blank interrupt-parent properties ARM: EXYNOS: Fix Kconfig dependencies for device tree enabled machine files ARM: EXYNOS: Remove broken config values for touchscren for NURI board ARM: EXYNOS: set fix xusbxti clock for NURI and Universal210 boards ARM: EXYNOS: fix regulator name for NURI board ARM: SAMSUNG: make SAMSUNG_PM_DEBUG select DEBUG_LL ARM: msm: Fix section mismatches in proc_comm.c video: msm: Fix section mismatches in mddi.c arm: msm: trout: fix compile failure arm: msm: halibut: remove unneeded fixup ARM: EXYNOS: Add PDMA and MDMA physical base address defines ARM: S5PV210: Fix compiler warning in dma.c file ARM: EXYNOS: Fix compile error in exynos5250-cpufreq.c ARM: EXYNOS: Add missing definition for IRQ_I2S0 ARM: S5PV210: fix unused LDO supply field from wm8994_pdata
2012-04-15SCSI: Fix error handling when no ULD is attachedMartin K. Petersen
Commit 18a4d0a22ed6 ("[SCSI] Handle disk devices which can not process medium access commands") introduced a bug in which we would attempt to dereference the scsi driver even when the device had no ULD attached. Ensure that a driver is registered and make the driver accessor function more resilient to errors during device discovery. Reported-by: Elric Fu <elricfu1@gmail.com> Reported-by: Bart Van Assche <bvanassche@acm.org> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-13Merge tag 'fbdev-fixes-for-3.4-1' of git://github.com/schandinat/linux-2.6Linus Torvalds
Pull fbdev fixes from Florian Tobias Schandinat: - a compile fix for au1*fb - a fix to make kyrofb usable on x86_64 - a fix for uvesafb to prevent an oops due to NX-protection "The fix for kyrofb is a bit large but it's just replacing "unsigned long" by "u32" for 64 bit compatibility." * tag 'fbdev-fixes-for-3.4-1' of git://github.com/schandinat/linux-2.6: video:uvesafb: Fix oops that uvesafb try to execute NX-protected page fbdev: fix au1*fb builds kyrofb: fix on x86_64
2012-04-13Merge branch 'for-3.4/drivers' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block driver bits from Jens Axboe: - A series of fixes for mtip32xx. Most from Asai at Micron, but also one from Greg, getting rid of the dependency on PCIE_HOTPLUG. - A few bug fixes for xen-blkfront, and blkback. - A virtio-blk fix for Vivek, making resize actually work. - Two fixes from Stephen, making larger transfers possible on cciss. This is needed for tape drive support. * 'for-3.4/drivers' of git://git.kernel.dk/linux-block: block: mtip32xx: remove HOTPLUG_PCI_PCIE dependancy mtip32xx: dump tagmap on failure mtip32xx: fix handling of commands in various scenarios mtip32xx: Shorten macro names mtip32xx: misc changes mtip32xx: Add new sysfs entry 'status' mtip32xx: make setting comp_time as common mtip32xx: Add new bitwise flag 'dd_flag' mtip32xx: fix error handling in mtip_init() virtio-blk: Call revalidate_disk() upon online disk resize xen/blkback: Make optional features be really optional. xen/blkback: Squash the discard support for 'file' and 'phy' type. mtip32xx: fix incorrect value set for drv_cleanup_done, and re-initialize and start port in mtip_restart_port() cciss: Fix scsi tape io with more than 255 scatter gather elements cciss: Initialize scsi host max_sectors for tape drive support xen-blkfront: make blkif_io_lock spinlock per-device xen/blkfront: don't put bdev right after getting it xen-blkfront: use bitmap_set() and bitmap_clear() xen/blkback: Enable blkback on HVM guests xen/blkback: use grant-table.c hypercall wrappers
2012-04-13cpufreq: OMAP: fix build errors: depends on ARCH_OMAP2PLUSKevin Hilman
The OMAP driver needs a 'depends on ARCH_OMAP2PLUS' since it only builds for OMAP2+ platforms. This 'depends on' was in the original patch from Russell King, but was erroneously removed by me when making this option user-selectable in commit b09db45c (cpufreq: OMAP driver depends CPUfreq tables.) This patch remedies that. Apologies to Russell King for breaking his originally working patch. Also, thanks to Grazvydas Ignotas for reporting the same problem. Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Grazvydas Ignotas <notasas@gmail.com> Signed-off-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-13Merge tag 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging Pull hwmon patches from Guenter Roeck: "Fix build warnings in four drivers" * tag 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: hwmon: (pmbus_core) Fix compiler warning hwmon: (smsc47m1) Fix compiler warning hwmon: (acpi_power_meter) Fix compiler warning seen in some configurations hwmon: (smsc47b397) Fix compiler warning
2012-04-13Merge tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
Pull GPIO bug fixes from Grant Likely: "Miscellaneous bug fixes to GPIO drivers and for a corner case in the gpio device tree parsing code." * tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux-2.6: gpio/exynos: Fix compiler warning in gpio-samsung.c file gpio: Fix range check in of_gpio_simple_xlate() gpio: Fix uninitialized variable bit in adp5588_irq_handler gpio/sodaville: Convert sodaville driver to new irqdomain API
2012-04-13Merge tag 'spi-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
Pull SPI bug fixes from Grant Likely: "Miscellaneous driver bug fixes. No major changes in this branch." * tag 'spi-for-linus' of git://git.secretlab.ca/git/linux-2.6: spi/imx: prevent NULL pointer dereference in spi_imx_probe() spi/imx: mark base member in spi_imx_data as __iomem spi/mpc83xx: fix NULL pdata dereference bug spi/davinci: Fix DMA API usage in davinci spi/pL022: include types.h to remove compilation warnings
2012-04-13video: msm: Fix section mismatches in mddi.cDavid Brown
The change commit 461cbe77d0a4f887c33a3a95ea68a7daf23b4302 Author: Gregory Bean <gbean@codeaurora.org> Date: Wed Jul 28 10:22:13 2010 -0700 video: msm: Fix section mismatch in mddi.c. fixes a section mismatch between the board file and the driver's probe function, however, it misses the additional mismatches between the probe function and some routines it calls. Fix these up as well. Signed-off-by: David Brown <davidb@codeaurora.org>
2012-04-13kconfig-disable-a-few-options-rt.patchThomas Gleixner
Disable stuff which is known to have issues on RT Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-13dm: Make rt awareThomas Gleixner
Use the BUG_ON_NORT variant for the irq_disabled() checks. RT has interrupts legitimately enabled here as we cant deadlock against the irq thread due to the "sleeping spinlocks" conversion. Reported-by: Luis Claudio R. Goncalves <lclaudio@uudg.org> Cc: stable-rt@vger.kernel.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-13scsi-fcoe-rt-aware.patchThomas Gleixner
2012-04-13sysrq: Allow immediate Magic SysRq output for PREEMPT_RT_FULLFrank Rowand
Add a CONFIG option to allow the output from Magic SysRq to be output immediately, even if this causes large latencies. If PREEMPT_RT_FULL, printk() will not try to acquire the console lock when interrupts or preemption are disabled. If the console lock is not acquired the printk() output will be buffered, but will not be output immediately. Some drivers call into the Magic SysRq code with interrupts or preemption disabled, so the output of Magic SysRq will be buffered instead of printing immediately if this option is not selected. Even with this option selected, Magic SysRq output will be delayed if the attempt to acquire the console lock fails. Signed-off-by: Frank Rowand <frank.rowand@am.sony.com> Link: http://lkml.kernel.org/r/4E7CEF60.5020508@am.sony.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-13kgdb/serial: Short term workaroundJason Wessel
On 07/27/2011 04:37 PM, Thomas Gleixner wrote: > - KGDB (not yet disabled) is reportedly unusable on -rt right now due > to missing hacks in the console locking which I dropped on purpose. > To work around this in the short term you can use this patch, in addition to the clocksource watchdog patch that Thomas brewed up. Comments are welcome of course. Ultimately the right solution is to change separation between the console and the HW to have a polled mode + work queue so as not to introduce any kind of latency. Thanks, Jason.
2012-04-13ARM: at91: tclib: Default to tclib timer for RTThomas Gleixner
RT is not too happy about the shared timer interrupt in AT91 devices. Default to tclib timer for RT. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-13rt: Improve the serial console PASS_LIMITIngo Molnar
Beyond the warning: drivers/tty/serial/8250/8250.c:1613:6: warning: unused variable ‘pass_counter’ [-Wunused-variable] the solution of just looping infinitely was ugly - up it to 1 million to give it a chance to continue in some really ugly situation. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-13drivers-tty-fix-omap-lock-crap.patchThomas Gleixner
2012-04-13serial: 8250: Call flush_to_ldisc when the irq is threadedIngo Molnar
2012-04-13serial: 8250: Clean up the locking for -rtIngo Molnar
2012-04-13md: raid5: Make raid5_percpu handling RT awareThomas Gleixner
__raid_run_ops() disables preemption with get_cpu() around the access to the raid5_percpu variables. That causes scheduling while atomic spews on RT. Serialize the access to the percpu data with a lock and keep the code preemptible. Reported-by: Udo van den Heuvel <udovdh@xs4all.nl> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Udo van den Heuvel <udovdh@xs4all.nl>
2012-04-13USB: Fix the mouse problem when copying large amounts of dataWu Zhangjin
When copying large amounts of data between the USB storage devices and the hard disk, the USB mouse will not work, this patch fixes it. [NOTE: This problem have been found in the Loongson family machines, not sure whether it is producible on other platforms] Signed-off-by: Hu Hongbing <huhb@lemote.com> Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com>
2012-04-13drivers: net: gianfar: Make RT awareThomas Gleixner
The adjust_link() disables interrupts before taking the queue locks. On RT those locks are converted to "sleeping" locks and therefor the local_irq_save/restore must be converted to local_irq_save/restore_nort. Reported-by: Xianghua Xiao <xiaoxianghua@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Xianghua Xiao <xiaoxianghua@gmail.com>
2012-04-13drivers/net: vortex fix locking issuesSteven Rostedt
Argh, cut and paste wasn't enough... Use this patch instead. It needs an irq disable. But, believe it or not, on SMP this is actually better. If the irq is shared (as it is in Mark's case), we don't stop the irq of other devices from being handled on another CPU (unfortunately for Mark, he pinned all interrupts to one CPU). Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> drivers/net/ethernet/3com/3c59x.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-04-13drivers/net: fix livelock issuesThomas Gleixner
Preempt-RT runs into a live lock issue with the NETDEV_TX_LOCKED micro optimization. The reason is that the softirq thread is rescheduling itself on that return value. Depending on priorities it starts to monoplize the CPU and livelock on UP systems. Remove it. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-13tty: Do not disable interrupts in put_ldisc on -rtThomas Gleixner
Fixes the following on PREEMPT_RT: BUG: sleeping function called from invalid context at kernel/rtmutex.c:684 in_atomic(): 0, irqs_disabled(): 1, pid: 9116, name: sshd Pid: 9116, comm: sshd Not tainted 2.6.31-rc6-rt2 #6 Call Trace: [<ffffffff81034a4f>] __might_sleep+0xec/0xee [<ffffffff812fbc6d>] rt_spin_lock+0x34/0x75 [ffffffff81064a83>] atomic_dec_and_spin_lock+0x36/0x54 [<ffffffff811df7c7>] put_ldisc+0x57/0xa6 [<ffffffff811dfb87>] tty_ldisc_hangup+0xe7/0x19f [<ffffffff811d9224>] do_tty_hangup+0xff/0x319 [<ffffffff811d9453>] tty_vhangup+0x15/0x17 [<ffffffff811e1263>] pty_close+0x127/0x12b [<ffffffff811dac41>] tty_release_dev+0x1ad/0x4c0 .... Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-13usb: Use local_irq_*_nort() variantsSteven Rostedt
[ tglx: Now that irqf_disabled is dead we should kill that ] Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-13input: gameport: Do not disable interrupts on PREEMPT_RTIngo Molnar
Use the _nort() primitives. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-13infiniband: Mellanox IB driver patch use _nort() primitivesSven-Thorsten Dietrich
Fixes in_atomic stack-dump, when Mellanox module is loaded into the RT Kernel. Michael S. Tsirkin <mst@dev.mellanox.co.il> sayeth: "Basically, if you just make spin_lock_irqsave (and spin_lock_irq) not disable interrupts for non-raw spinlocks, I think all of infiniband will be fine without changes." Signed-off-by: Sven-Thorsten Dietrich <sven@thebigcorporation.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-13ide: Do not disable interrupts for PREEMPT-RTIngo Molnar
Use the local_irq_*_nort variants. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-13ata: Do not disable interrupts in ide code for preempt-rtSteven Rostedt
Use the local_irq_*_nort variants. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-13hwlatdetect.patchCarsten Emde
Jon Masters developed this wonderful SMI detector. For details please consult Documentation/hwlat_detector.txt. It could be ported to Linux 3.0 RT without any major change. Signed-off-by: Carsten Emde <C.Emde@osadl.org>
2012-04-13pci: Use __wake_up_all_locked pci_unblock_user_cfg_access()Thomas Gleixner
The waitqueue is protected by the pci_lock, so we can just avoid to lock the waitqueue lock itself. That prevents the might_sleep()/scheduling while atomic problem on RT Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: stable-rt@vger.kernel.org
2012-04-13locking-various-init-fixes.patchThomas Gleixner
2012-04-13of-convert-devtree-lock.patchThomas Gleixner
2012-04-13OF: Fixup resursive locking code pathsThomas Gleixner
There is no real reason to use a rwlock for devtree_lock. It even could be a mutex, but unfortunately it's locked from cpu hotplug pathes which can't schedule :( So it needs to become a raw lock on rt as well. devtree_lock would be the only user of a raw_rw_lock, so we are better of cleaning the recursive locking pathes which allows us to convert devtree_lock to a read_lock. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-13drivers: net: at91_ether: Make mdio protection -rt safeThomas Gleixner
Neither the phy interrupt nor the timer callback which updates the link status in absense of a phy interrupt are taking lp->lock which serializes the MDIO access. This works on mainline as at91 is an UP machine. On preempt-rt the timer callback can run even in the spin_lock_irq(&lp->lock) protected code pathes because spin_lock_irq is neither disabling interrupts nor disabling preemption. Fix this by adding proper locking to at91ether_phy_interrupt() and at91_check_ether() which serializes the access on -rt. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-13drivers: net: ehea: Make rx irq handler non-threaded (IRQF_NO_THREAD)Darren Hart
The underlying hardware is edge triggered but presented by XICS as level triggered. The edge triggered interrupts are not reissued after masking. This is not a problem in mainline which does not mask the interrupt (relying on the EOI mechanism instead). The threaded interrupts in PREEMPT_RT do mask the interrupt, and can lose interrupts that occurred while masked, resulting in a hung ethernet interface. The receive handler simply calls napi_schedule(), as such, there is no significant additional overhead in making this non-threaded, since we either wakeup the threaded irq handler to call napi_schedule(), or just call napi_schedule() directly to wakeup the softirqs. As the receive handler is lockless, there is no need to convert any of the ehea spinlock_t's to raw_spinlock_t's. Without this patch, a simple scp file copy loop would fail quickly (usually seconds). We have over two hours of sustained scp activity with the patch applied. Credit goes to Will Schmidt for lots of instrumentation and tracing which clarified the scenario and to Thomas Gleixner for the incredibly simple solution. Signed-off-by: Darren Hart <dvhltc@us.ibm.com> Acked-by: Will Schmidt <will_schmidt@vnet.ibm.com> Cc: Jan-Bernd Themann <themann@de.ibm.com> Cc: Nivedita Singhvi <niv@us.ibm.com> Cc: Brian King <bjking1@us.ibm.com> Cc: Michael Ellerman <ellerman@au1.ibm.com> Cc: Doug Maxey <doug.maxey@us.ibm.com> LKML-Reference: <4BF30793.5070300@us.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-13drivers/net: Use disable_irq_nosync() in 8139tooIngo Molnar
Use disable_irq_nosync() instead of disable_irq() as this might be called in atomic context with netpoll. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-13drivers/net: tulip_remove_one needs to call pci_disable_device()Ingo Molnar
Otherwise the device is not completely shut down. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-13clocksource: TCLIB: Allow higher clock rates for clock eventsBenedikt Spranger
As default the TCLIB uses the 32KiHz base clock rate for clock events. Add a compile time selection to allow higher clock resulution. Signed-off-by: Benedikt Spranger <b.spranger@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-13drivers: random: Reduce preempt disabled regionIngo Molnar
No need to keep preemption disabled across the whole function. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-13intel_idle: Convert i7300_idle_lock to raw spinlockMike Galbraith
24 core Intel box's first exposure to 3.0.12-rt30-rc3 didn't go well. [ 27.104159] i7300_idle: loaded v1.55 [ 27.104192] BUG: scheduling while atomic: swapper/2/0/0x00000002 [ 27.104309] Pid: 0, comm: swapper/2 Tainted: G N 3.0.12-rt30-rc3-rt #1 [ 27.104317] Call Trace: [ 27.104338] [<ffffffff810046a5>] dump_trace+0x85/0x2e0 [ 27.104372] [<ffffffff8144eb00>] thread_return+0x12b/0x30b [ 27.104381] [<ffffffff8144f1b9>] schedule+0x29/0xb0 [ 27.104389] [<ffffffff814506e5>] rt_spin_lock_slowlock+0xc5/0x240 [ 27.104401] [<ffffffffa01f818f>] i7300_idle_notifier+0x3f/0x360 [i7300_idle] [ 27.104415] [<ffffffff814546c7>] notifier_call_chain+0x37/0x70 [ 27.104426] [<ffffffff81454748>] __atomic_notifier_call_chain+0x48/0x70 [ 27.104439] [<ffffffff81001a39>] cpu_idle+0x89/0xb0 [ 27.104449] bad: scheduling from the idle thread! Signed-off-by: Mike Galbraith <efault@gmx.de> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1323258522.5057.73.camel@marge.simson.net Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-13ARM: 7366/3: amba: Remove AMBA level regulator supportMark Brown
The AMBA bus regulator support is being used to model on/off switches for power domains which isn't terribly idiomatic for modern kernels with the generic power domain code and creates integration problems on platforms which don't use regulators for their power domains as it's hard to tell the difference between a regulator that is needed but failed to be provided and one that isn't supposed to be there (though DT does make that easier). Platforms that wish to use the regulator API to manage their power domains can indirect via the power domain interface. This feature is only used with the vape supply of the db8500 PRCMU driver which supplies the UARTs and MMC controllers, none of which have support for managing vcore at runtime in mainline (only pl022 SPI controller does). Update that supply to have an always_on constraint until the power domain support for the system is updated so that it is enabled for these users, this is likely to have no impact on practical systems as probably at least one of these devices will be active and cause AMBA to hold the supply on anyway. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Tested-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-04-12Merge tag 'srpt-srq-type' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband Pull infiniband fix from Roland Dreier: "Add a fix for a bug hit by Alexey Shvetsov in ib_srtp that hits on non-mlx4 hardware." * tag 'srpt-srq-type' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: IB/srpt: Set srq_type to IB_SRQT_BASIC
2012-04-12Merge tag 'usb-3.4-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB fixes from Greg KH: "Here are a number of fixes for the USB core and drivers for 3.4-rc2 Lots of tiny xhci fixes here, a few usb-serial driver fixes and new device ids, and a smattering of other minor fixes in different USB drivers. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" * tag 'usb-3.4-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (30 commits) USB: update usbtmc api documentation xHCI: Correct the #define XHCI_LEGACY_DISABLE_SMI xHCI: use gfp flags from caller instead of GFP_ATOMIC xHCI: add XHCI_RESET_ON_RESUME quirk for VIA xHCI host USB: fix bug of device descriptor got from superspeed device xhci: Fix register save/restore order. xhci: Restore event ring dequeue pointer on resume. xhci: Don't write zeroed pointers to xHC registers. xhci: Warn when hosts don't halt. xhci: don't re-enable IE constantly usb: xhci: fix section mismatch in linux-next xHCI: correct to print the true HSEE of USBCMD USB: serial: fix race between probe and open UHCI: hub_status_data should indicate if ports are resuming EHCI: keep track of ports being resumed and indicate in hub_status_data USB: fix race between root-hub suspend and remote wakeup USB: sierra: add support for Sierra Wireless MC7710 USB: ftdi_sio: fix race condition in TIOCMIWAIT, and abort of TIOCMIWAIT when the device is removed USB: ftdi_sio: fix status line change handling for TIOCMIWAIT and TIOCGICOUNT USB: don't ignore suspend errors for root hubs ...
2012-04-12Merge tag 'tty-3.4-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty and serial fixes from Greg KH: "Here are some tty and serial fixes for 3.4-rc2. Most important here is the pl011 fix, which has been reported by about 100 different people, which means more people use it than I expected :) There are also some 8250 driver reverts due to some problems reported by them. And other minor fixes as well. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" * tag 'tty-3.4-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: pch_uart: Add Kontron COMe-mTT10 uart clock quirk pch_uart: Fix MSI setting issue serial/8250_pci: add a "force background timer" flag and use it for the "kt" serial port Revert "serial/8250_pci: setup-quirk workaround for the kt serial controller" Revert "serial/8250_pci: init-quirk msi support for kt serial controller" tty/serial/omap: console can only be built-in serial: samsung: fix omission initialize ulcon in reset port fn() printk(): add KERN_CONT where needed in hpet and vt code tty/serial: atmel_serial: fix RS485 half-duplex problem tty: serial: altera_uart: Check for NULL platform_data in probe. isdn/gigaset: use gig_dbg() for debugging output omap-serial: Fix the error handling in the omap_serial probe serial: PL011: move interrupt clearing
2012-04-12Merge tag 'staging-3.4-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging tree fixes from Greg KH: "Here are a number of bugfixes for the drivers/staging/ portion of the kernel that have been reported recently. Nothing major here, with maybe the exception of the ramster code can now be built so it is enabled in the build again, and lots of memory leaks that people like to have fixed on their systems. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" * tag 'staging-3.4-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: staging: android: fix mem leaks in __persistent_ram_init() staging: vt6656: Don't leak memory in drivers/staging/vt6656/ioctl.c::private_ioctl() staging: iio: hmc5843: Fix crash in probe function. staging/xgifb: fix display on XGI Volari Z11m cards Staging: android: timed_gpio: Fix resource leak in timed_gpio_probe error paths android: make persistent_ram based drivers depend on HAVE_MEMBLOCK staging: iio: ak8975: Remove i2c client data corruption staging: drm/omap: move where DMM driver is registered staging: zsmalloc: fix memory leak Staging: rts_pstor: off by one in for loop staging: ozwpan: Added new maintainer for ozwpan staging:rts_pstor:Avoid "Bad target number" message when probing driver staging:rts_pstor:Fix possible panic by NULL pointer dereference Staging: vt6655-6: check keysize before memcpy() staging/media/as102: Don't call release_firmware() on uninitialized variable staging:iio:core add missing increment of loop index in iio_map_array_unregister() staging: ramster: unbreak my heart staging/vme: Fix module parameters staging: sep: Fix sign of error
