commit b16c02fbfb963fa2941b7517ebf1f8a21946775e upstream.
Add device ids to pl2303 for the Hewlett-Packard HP POS pole displays:
LD960: 03f0:0B39
LCM220: 03f0:3139
LCM960: 03f0:3239
[ Johan: fix indentation and sort PIDs numerically ]
Signed-off-by: Aaron Sanders <aaron.sanders@hp.com>
Signed-off-by: Johan Hovold <jhovold@gmail.com>
commit 4f2fe2d27472f4a5dbd875888af4fc5175f3fdc5 upstream.
To avoid memory fetch underflows with larger USB transfers, Tegra SoCs
need txfill_tuning's txfifothresh register field set to a non-default
value. Add a custom reset override in order to set this up.
These values are recommended practice for all Tegra chips. However,
I've only noticed practical problems when not setting them this way on
systems using Tegra124. Hence, CC: stable only for recent kernels which
actually support Tegra124.
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Tested-by: Alexandre Courbot <acourbot@nvidia.com>
commit 9ba71705706aa83bcd7f9b74ae2d167da934c951 upstream.
The Tegra124 clock driver currently provides 3 clocks that don't actually
exist; 2 for NAND and one for UART5/UARTE. Delete these.
commit 1f81b6d22a5980955b01e08cf27fb745dc9b686f upstream.
We have observed a rare cycle state desync bug after Set TR Dequeue
Pointer commands on Intel LynxPoint xHCs (resulting in an endpoint that
doesn't fetch new TRBs and thus an unresponsive USB device). It always
triggers when a previous Set TR Dequeue Pointer command has set the
pointer to the final Link TRB of a segment, and then another URB gets
enqueued and cancelled again before it can be completed. Further
investigation showed that the xHC had returned the Link TRB in the TRB
Pointer field of the Transfer Event (CC == Stopped -- Length Invalid),
but when xhci_find_new_dequeue_state() later accesses the Endpoint
Context's TR Dequeue Pointer field it is set to the first TRB of the
next segment.
The driver expects those two values to be the same in this situation,
and uses the cycle state of the latter together with the address of the
former. This should be fine according to the XHCI specification, since
the endpoint ring should be stopped when returning the Transfer Event
and thus should not advance over the Link TRB before it gets restarted.
However, real-world XHCI implementations apparently don't really care
that much about these details, so the driver should follow a more
defensive approach to try to work around HC spec violations.
This patch removes the stopped_trb variable that had been used to store
the TRB Pointer from the last Transfer Event of a stopped TRB. Instead,
xhci_find_new_dequeue_state() now relies only on the Endpoint Context,
requiring a small amount of additional processing to find the virtual
address corresponding to the TR Dequeue Pointer. Some other parts of the
function were slightly rearranged to better fit into this model.
This patch should be backported to kernels as old as 2.6.31 that contain
the commit ae636747146ea97efa18e04576acd3416e2514f5 "USB: xhci: URB
cancellation support."
Signed-off-by: Julius Werner <jwerner@chromium.org>
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
commit 238e14055da87d0d012257788e39fe0df3a82226 upstream.
If parent device does not have of_node set the s2mps11_clk_parse_dt()
returned NULL. This NULL was later passed to of_clk_add_provider() which
dereferenced it in pr_debug() call.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Signed-off-by: Mike Turquette <mturquette@linaro.org>
commit 03e7848a64ed535a30f5d7fc6dede2d5a6a2534b upstream.
This patch fixes a bug where outstanding RDMA_READs with WRITE_PENDING
status require an extra target_put_sess_cmd() in isert_put_cmd() code
when called from isert_cq_tx_comp_err() + isert_cq_drain_comp_llist()
context during session shutdown.
The extra kref PUT is required so that transport_generic_free_cmd()
invokes the last target_put_sess_cmd() -> target_release_cmd_kref(),
which will complete(&se_cmd->cmd_wait_comp) the outstanding se_cmd
descriptor with WRITE_PENDING status, and awake the completion in
target_wait_for_sess_cmds() to invoke TFO->release_cmd().
The bug was manifesting itself in target_wait_for_sess_cmds() where
a se_cmd descriptor with WRITE_PENDING status would end up sleeping
indefinately.
Acked-by: Sagi Grimberg <sagig@mellanox.com>
Cc: Or Gerlitz <ogerlitz@mellanox.com>
commit f46d6a8a01d6bbd83a97140f30a72a89b038807b upstream.
This patch changes isert_conn_create_fastreg_pool() to follow
logic in iscsi_target_locate_portal() for determining how many
FRMR descriptors to allocate based upon the number of possible
per-session command slots that are available.
This addresses an OOPs in isert_reg_rdma() where due to the
use of ISCSI_DEF_XMIT_CMDS_MAX could end up returning a bogus
fast_reg_descriptor when the number of active tags exceeded
the original hardcoded max.
Note this also includes moving isert_conn_create_fastreg_pool()
from isert_connect_request() to isert_put_login_tx() before
posting the final Login Response PDU in order to determine the
se_nacl->queue_depth (eg: number of tags) per session the target
will be enforcing.
v2 changes:
- Move isert_conn->conn_fr_pool list_head init into
isert_conn_request()
v3 changes:
- Drop unnecessary list_empty() check in isert_reg_rdma()
(Sagi)
Cc: Sagi Grimberg <sagig@mellanox.com>
commit 5eb9291c36c7d71d7c6c832d5a4f551eb8ac015d upstream.
This patch fixes 2 issues in the fast completion path:
1) Possible double completions / double dma_unmap_sg() calls due to lack
of atomicity in the check and subsequent dereference of the upper layer
callback function. Fixed with cmpxchg before unmap and callback.
2) Regression in unaligned IO constraining workaround for p420m devices.
Fixed by checking if IO is unaligned and using proper semaphore if so.
Signed-off-by: Sam Bradshaw <sbradshaw@micron.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
commit 368c89d7ac70f937c93cd6f3b65bcfdfb3ba794f upstream.
If the buffers are unmapped after completing a request, then stale data
might be in the request.
Signed-off-by: Felipe Franciosi <felipe@paradoxo.org>
commit 1044b1bb9278f2e656a1a7b63dc24a59506540aa upstream.
We need to set the queue bounce limit during the device initialization to
prevent excessive bouncing on 32 bit architectures.
commit 6aec044cc2f5670cf3b143c151c8be846499bd15 upstream.
When a driver doesn't have pre_reset, post_reset, or reset_resume
methods, the USB core unbinds that driver when its device undergoes a
reset or a reset-resume, and then rebinds it afterward.
The existing straightforward implementation can lead to problems,
because each interface gets unbound and rebound before the next
interface is handled. If a driver claims additional interfaces, the
claim may fail because the old binding instance may still own the
additional interface when the new instance tries to claim it.
This patch fixes the problem by first unbinding all the interfaces
that are marked (i.e., their needs_binding flag is set) and then
rebinding all of them.
The patch also makes the helper functions in driver.c a little more
uniform and adjusts some out-of-date comments.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Reported-and-tested-by: "Poulain, Loic" <loic.poulain@intel.com>
commit a31a942a148e0083ce560ffeb54fb60e06ab7201 upstream.
Tests have shown that when a power-up transition is followed by other
PHY operations too quickly, the USB port appears dead. Waiting 1ms fixes
this problem.
Signed-off-by: Daniel Mack <zonque@gmail.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
commit ead5178bf442dbae4008ee54bf4f66a1f6a317c9 upstream.
Add new ulpi IDs which are available on Xilinx Zynq boards.
commit f76a1cbed18c86e2d192455f0daebb48458965f3 upstream.
Commit 3e6c6f630a5282df8f3393a59f10eb9c56536d23 ("Delay creation of
khcvd thread") moved the call of hvc_init from being a device_initcall
into hvc_alloc, and used a non-null hvc_driver as indication of whether
hvc_init had already been called.
The problem with this is that hvc_driver is only assigned a value
at the bottom of hvc_init, and so there is a window where multiple
hvc_alloc calls can be in progress at the same time and hence try
and call hvc_init multiple times. Previously the use of device_init
guaranteed that hvc_init was only called once.
This manifests itself as sporadic instances of two hvc_init calls
racing each other, and with the loser of the race getting -EBUSY
from tty_register_driver() and hence that virtual console fails:
Couldn't register hvc console driver
virtio-ports vport0p1: error -16 allocating hvc for port
Here we add an atomic_t to guarantee we'll never run hvc_init twice.
Fixes: 3e6c6f630a52 ("Delay creation of khcvd thread")
Reported-by: Jim Somerville <Jim.Somerville@windriver.com>
Tested-by: Jim Somerville <Jim.Somerville@windriver.com>
commit 3063a12be2b07c64e9802708a19489342e64c1a3 upstream.
commi 30a70b0 (usb: musb: fix obex in g_nokia.ko
causing kernel panic) removed phy_power_on()
and phy_power_off() calls from runtime PM callbacks
but it failed to note that the driver depended
on pm_runtime_get_sync() calls to power up the PHY,
thus leaving some platforms without any means to
have a working PHY.
Fix that by enabling the phy during omap2430_musb_init()
and killing it in omap2430_musb_exit().
Fixes: 30a70b0 (usb: musb: fix obex in g_nokia.ko causing kernel panic)
Cc: Pali Rohár <pali.rohar@gmail.com>
Cc: Ivaylo Dimitrov <ivo.g.dimitrov.75@gmail.com>
Reported-by: Michael Scott <hashcode0f@gmail.com>
Tested-by: Michael Scott <hashcode0f@gmail.com>
Tested-by: Stefan Roese <sr@denx.de>
Reported-by: Rabin Vincent <rabin@rab.in>
commit eee3f15d5f1f4f0c283dd4db67dc1b874a2852d1 upstream.
instead of relying on the otg pointer, which
can be NULL in certain cases, we can use the
gadget and host pointers we already hold inside
struct musb.
Tested-by: Tony Lindgren <tony@atomide.com>
commit 610183051d8f9421f138c4203ca894387f9f8839 upstream.
commit 388e5c5 (usb: dwc3: remove dwc3 dependency
on host AND gadget.) created the possibility for
host-only and peripheral-only dwc3 builds but
left a possible randconfig build error when host-only
builds are selected.
Reported-by: Jim Davis <jim.epost@gmail.com>
commit 06f9b6e59661cee510b04513b13ea7927727d758 upstream.
Around DWC USB3 2.30a release another bit has been added to the
Device-Specific Event (DEVT) Event Information (EvtInfo) bitfield.
Because of that, what used to be 8 bits long, has become 9 bits long.
Per dwc3 2.30a+ spec in the Device-Specific Event (DEVT), the field of
Event Information Bits(EvtInfo) uses [24:16] bits, and it has 9 bits
not 8 bits. And the following reserved field uses [31:25] bits not
[31:24] bits, and it has 7 bits.
So in dwc3_event_devt, the bit mask should be:
event_info [24:16] 9 bits
reserved31_25 [31:25] 7 bits
This patch makes sure that newer core releases will work fine with
Linux and that we will decode the event information properly on new
core releases.
[ balbi@ti.com : improve commit log a bit ]
Signed-off-by: Huang Rui <ray.huang@amd.com>
commit 61f0319193c44adbbada920162d880b1fdb3aeb3 upstream.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
commit 8b57b9669aa884ac75b8d09c251d6b1755533c15 upstream.
Commit 3fdfedaaa "[media] omap3isp: preview: Lower the crop margins"
accidentally changed the previewer's cropping, causing the previewer
to miss four pixels on each line, thus corrupting the final image.
Restored the removed setting.
Signed-off-by: Florian Vaussard <florian.vaussard@epfl.ch>
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
commit 30d652823de5fd7907d40e969a2d8e23938d8d03 upstream.
Do not attempt to reload the tuner modules when resuming after a suspend.
This triggers a WARN_ON in kernel/kmod.c:148 __request_module.
This fixes https://bugzilla.kernel.org/show_bug.cgi?id=69581.
This has always been wrong, but it was never noticed until the WARN_ON
was added in 3.9.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
commit 3ec40dcfb413214b2874aec858870502b61c2202 upstream.
Pointer to device state has been moved to different location during
some change. PCTV 290e LNA function still uses old pointer, carried
over FE priv, and it crash.
Reported-by: Janne Kujanpää <jikuja@iki.fi>
Signed-off-by: Antti Palosaari <crope@iki.fi>
commit 3c8023a782964c72574ad8268ba0ea4e2d9772fc upstream.
The m88rs2000 frontend is always auto inversion.
Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
commit 01ae3b51af7144ea29eb28ba718b65ad59ab9493 upstream.
dev->adev.users always needs to be increased when snd_em28xx_capture_open() is
called and succeeds.
Signed-off-by: Frank Schäfer <fschaefer.oss@googlemail.com>
commit 8272d0a0c0d374a01721e579df6e8add5577132b upstream.
Add m88rs2000_get_tune_settings, min delay of 2000 ms on symbol
rate more than 3000000 and delay of 3000ms less than this.
Adding min delay prevents crashing the frontend on continuous
transponder scans. Other dvb_frontend_tune_settings remain as default.
This makes very little time difference to good channel scans, but slows down
the set frontend where lock can never be achieved i.e. DVB-S2.
commit bc826d6e39fe5f09cbadf8723e9183e6331b586f upstream.
The wrong ioctl numbers were used due to a copy-and-paste error.
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
commit c4885ada88e4331f8ac56d14296d0058359db2d7 upstream.
I completely forgot to add them when I made this module. Loading this module
without it will taint the kernel, which is not intended.
commit 7d3477d801808a5037a511cf5a5aae5718e7ecce upstream.
If no driver takeover the atmel_lcdfb, the lcd won't be in a working state
since atmel_lcdfb_set_par() will never be called. Enabling a driver which does,
like fbcon, will call the function and put atmel_lcdfb in a working state.
Fixes: b985172b328a (video: atmel_lcdfb: add device tree suport)
Signed-off-by: Antoine Ténart <antoine.tenart@free-electrons.com>
Reported-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
commit b1e43f232698274871e1358c276d7b0242a7d607 upstream.
The UVC specification uses alternate setting selection to notify devices
of stream start/stop. This breaks when using bulk-based devices, as the
video streaming interface has a single alternate setting in that case,
making video stream start and video stream stop events to appear
identical to the device. Bulk-based devices are thus not well supported
by UVC.
The webcam built in the Asus Zenbook UX302LA ignores the set interface
request and will keep the video stream enabled when the driver tries to
stop it. If USB autosuspend is enabled the device will then be suspended
and will crash, requiring a cold reboot.
USB trace capture showed that Windows sends a CLEAR_FEATURE(HALT)
request to the bulk endpoint when stopping the stream instead of
selecting alternate setting 0. The camera then behaves correctly, and
thus seems to require that behaviour.
Replace selection of alternate setting 0 with clearing of the endpoint
halt feature at video stream stop for bulk-based devices. Let's refrain
from blaming Microsoft this time, as it's not clear whether this
Windows-specific but USB-compliant behaviour was specifically developed
to handle bulkd-based UVC devices, or if the camera just took advantage
of it.
Signed-off-by: Oleksij Rempel <linux@rempel-privat.de>
commit 01bb59ebffdec314da8da66266edf29529372f9b upstream.
When CONFIG_PCI and CONFIG_PM are not selected, xhci.c gets this
warning:
drivers/usb/host/xhci.c:409:13: warning: ‘xhci_msix_sync_irqs’ defined
but not used [-Wunused-function]
Instead of creating nested #ifdefs, this patch fixes it by defining the
xHCI PCI stubs as inline.
This warning has been in since 3.2 kernel and was
caused by commit 421aa841a134f6a743111cf44d0c6d3b45e3cf8c
"usb/xhci: hide MSI code behind PCI bars", but wasn't noticed
until 3.13 when a configuration with these options was tried
Signed-off-by: David Cohen <david.a.cohen@linux.intel.com>
commit 6db249ebefc6bf5c39f35dfaacc046d8ad3ffd70 upstream.
After suspend another Renesas PCI-X USB 3.0 card doesn't work.
[root@fedora-20 ~]# lspci -vmnnd 1912:
Device: 03:00.0
Class: USB controller [0c03]
Vendor: Renesas Technology Corp. [1912]
Device: uPD720202 USB 3.0 Host Controller [0015]
SVendor: Renesas Technology Corp. [1912]
SDevice: uPD720202 USB 3.0 Host Controller [0015]
Rev: 02
ProgIf: 30
This patch should be applied to stable kernel 3.14 that contain
the commit 1aa9578c1a9450fb21501c4f549f5b1edb557e6d
"xhci: Fix resume issues on Renesas chips in Samsung laptops"
Reported-and-tested-by: Anatoly Kharchenko <rfr-bugs@yandex.ru>
Reference: http://redmine.russianfedora.pro/issues/1315
Signed-off-by: Igor Gnatenko <i.gnatenko.brain@gmail.com>
commit c09ec25d3684cad74d851c0f028a495999591279 upstream.
The same issue like with Panther Point chipsets. If the USB ports are
switched to xHCI on shutdown, the xHCI host will send a spurious interrupt,
which will wake the system. Some BIOS have work around for this, but not all.
One example is Compulab's mini-desktop, the Intense-PC2.
The bug can be avoided if the USB ports are switched back to EHCI on
shutdown.
This patch should be backported to stable kernels as old as 3.12,
that contain the commit 638298dc66ea36623dbc2757a24fc2c4ab41b016
"xhci: Fix spurious wakeups after S5 on Haswell"
Signed-off-by: Denis Turischev <denis@compulab.co.il>
commit bcffae7708eb8352f44dc510b326541fe43a02a4 upstream.
xHCI driver has its own pci probe function that will call usb_hcd_pci_probe
to register its usb-2 bus, and then continue to manually register the
usb-3 bus. usb_hcd_pci_probe does a pm_runtime_put_noidle at the end and
might thus trigger a runtime suspend before the usb-3 bus is ready.
Prevent the runtime suspend by increasing the usage count in the
beginning of xhci_pci_probe, and decrease it once the usb-3 bus is
ready.
xhci-platform driver is not using usb_hcd_pci_probe to set up
busses and should not need to have it's usage count increased during probe.
Acked-by: Dan Williams <dan.j.williams@intel.com>
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
commit 9c1b70361e0b38e4acb8e62b54da66538cb77ff2 upstream.
It was impossible to enumerate on a SuperSpeed (XHCI) host
with alternate setting = 1 due to the wrongly set 'bMaxBurst'
field in the SuperSpeed Endpoint Companion descriptor.
Testcase:
<host> modprobe -r usbtest; modprobe usbtest alt=1
<device> modprobe g_zero
plug device to SuperSpeed port on the host.
Without this patch the host always complains like so
"usb 12-2: Not enough bandwidth for new device state.
usb 12-2: Not enough bandwidth for altsetting 1"
Bug was introduced by commit cf9a08ae in v3.9
Fixes: cf9a08ae5aec (usb: gadget: convert source sink and loopback to
new function interface)
Reviewed-by: Felipe Balbi <balbi@ti.com>
Acked-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Roger Quadros <rogerq@ti.com>
commit d8eb6c653ef6b323d630de3c5685478469e248bc upstream.
commit 511f3c5 (usb: gadget: udc-core: fix a regression during gadget driver
unbinding) introduced a crash when DEBUG is enabled.
The debug trace in the atmel_usba_stop function made the assumption that the
driver pointer passed in parameter was not NULL, but since the commit above,
such assumption was no longer always true.
This commit now uses the driver pointer stored in udc which fixes this
issue.
[ balbi@ti.com : improved commit log a bit ]
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
commit aba37fd975f0dd58e025c99c2a79b61b20190831 upstream.
This makes sure that the name coming out of configfs cannot be used
accidentally as a format string.
commit c39b06951f1dc2e384650288676c5b7dcc0ec92c upstream.
Loading cursors to the LCD controller's SRAM can be corrupted when the
configured pixel clock is relatively slow. This seems to be caused
when we write back-to-back to the SRAM registers.
There doesn't appear to be any status register we can read to check
when an access has completed.
Inserting a dummy read between the writes appears to fix the problem.
commit 47514c996fac5e6f13ef3a4c5e23f1c5cffabb7b upstream.
We're currently passing the file handle for the root file system to
efi_file_read() and efi_file_close(), instead of the file handle for the
file we wish to read/close.
While this has worked up until now, it seems that it has only been by
pure luck. Olivier explains,
"The issue is the UEFI Fat driver might return the same function for
'fh->read()' and 'h->read()'. While in our case it does not work with
a different implementation of EFI_SIMPLE_FILE_SYSTEM_PROTOCOL. In our
case, we return a different pointer when reading a directory and
reading a file."
Fixing this actually clears up the two functions because we can drop one
of the arguments, and instead only pass a file 'handle' argument.
Reported-by: Olivier Martin <olivier.martin@arm.com>
Reviewed-by: Olivier Martin <olivier.martin@arm.com>
Reviewed-by: Mark Rutland <mark.rutland@arm.com>
Cc: Leif Lindholm <leif.lindholm@linaro.org>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
commit 03367ef5ea811475187a0732aada068919e14d61 upstream.
Only ws2012r2 hosts support the ability to reconnect to the host on VMBUS. This functionality
is needed by kexec in Linux. To use this functionality we need to negotiate version 3.0 of the
VMBUS protocol.
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
commit 2c42be2dd4f6586728dba5c4e197afd5cfaded78 upstream.
ft_del_tpg checks tpg->tport is set before unlinking the tpg from the
tport when the tpg is being removed. Set this pointer in ft_tport_create,
or the unlinking won't happen in ft_del_tpg and tport->tpg will reference
a deleted object.
This patch sets tpg->tport in ft_tport_create, because that's what
ft_del_tpg checks, and is the only way to get back to the tport to
clear tport->tpg.
The bug was occuring when:
- lport created, tport (our per-lport, per-provider context) is
allocated.
tport->tpg = NULL
- tpg created
- a PRLI is received. ft_tport_create is called, tpg is found and
tport->tpg is set
- tpg removed. ft_tpg is freed in ft_del_tpg. Since tpg->tport was not
set, tport->tpg is not cleared and points at freed memory
- Future calls to ft_tport_create return tport via first conditional,
instead of searching for new tpg by calling ft_lport_find_tpg.
tport->tpg is still invalid, and will access freed memory.
see https://bugzilla.redhat.com/show_bug.cgi?id=1071340
Signed-off-by: Andy Grover <agrover@redhat.com>
commit d84287bcfe624697cd4f3c1df746beb53b86d9c4 upstream.
This patch fixes a double free bug during IBLOCK backend shutdown
where bioset_integrity_free() was incorrectly called ahead of
bioset_free(), who is already making the same call directly.
This bug was introduced with commit ecebbf6cc, and will end up
triggering a general protection fault in iblock_free_device()
Reviewed-by: Sagi Grimberg <sagig@mellanox.com>
Cc: Martin K. Petersen <martin.petersen@oracle.com>
Cc: Quinn Tran <quinn.tran@qlogic.com>
Cc: Giridhar Malavali <giridhar.malavali@qlogic.com>
commit a1e1774c6dfa3a524dd8df51ca95185fe5ef3247 upstream.
When compiled with CONFIG_DEBUG_SG set, uninitialized SGL leads
to BUG() in compare_and_write_callback().
Signed-off-by: Martin Svec <martin.svec@zoner.cz>
commit 9d2e59f2a778328a41771fe9a0098dadbc4314ba upstream.
Ram disk is allocating 8x more space than required for diff data.
For large RAM disk test, there is small potential for memory
starvation.
(Use block_size when calculating total_sg_needed - sagi + nab)
Signed-off-by: Giridhar Malavali <giridhar.malavali@qlogic.com>
Signed-off-by: Quinn Tran <quinn.tran@qlogic.com>
commit d444edc679e7713412f243b792b1f964e5cff1e1 upstream.
This patch fixes a long-standing bug in iscsit_build_conn_drop_async_message()
where during ERL=2 connection recovery, a bogus conn_p pointer could
end up being used to send the ISCSI_OP_ASYNC_EVENT + DROPPING_CONNECTION
notifying the initiator that cmd->logout_cid has failed.
The bug was manifesting itself as an OOPs in iscsit_allocate_cmd() with
a bogus conn_p pointer in iscsit_build_conn_drop_async_message().
Reported-by: Arshad Hussain <arshad.hussain@calsoftinc.com>
Reported-by: santosh kulkarni <santosh.kulkarni@calsoftinc.com>
commit e2c70425f05219b142b3a8a9489a622c736db39d upstream.
The original code always set the upper 32 bits to zero because it was
doing a shift of the wrong variable.
Fixes: 1a4f550a09f8 ('[SCSI] arcmsr: 1.20.00.15: add SATA RAID plus other fixes')
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit b2a72ec32d0f499aaadf41264232517a12326df0 upstream.
qla2x00_mem_alloc() returns 1 on success and -ENOMEM on failure. On the
one hand the caller assumes non-zero is success but on the other hand
the caller also assumes that it returns an error code.
I've fixed it to return zero on success and a negative error code on
failure. This matches the documentation as well.
[jejb: checkpatch fix]
Fixes: e315cd28b9ef ('[SCSI] qla2xxx: Code changes for qla data structure refactoring')
Acked-by: Saurav Kashyap <saurav.kashyap@qlogic.com>
commit b076808051f2c80d38e03fb2f1294f525c7a446d upstream.
The code was incorrectly using sg_dma_address() and
sg_dma_len() instead of ib_sg_dma_address() and
ib_sg_dma_len().
This prevents srpt from functioning with the
Intel HCA and indeed will corrupt memory
badly.
Cc: Bart Van Assche <bvanassche@acm.org>
Reviewed-by: Dennis Dalessandro <dennis.dalessandro@intel.com>
Tested-by: Vinod Kumar <vinod.kumar@intel.com>
Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com>
commit b2853fd6c2d0f383dbdf7427e263eb576a633867 upstream.
The code that resolves the passive side source MAC within the rdma_cm
connection request handler was both redundant and buggy, so remove it.
It was redundant since later, when an RC QP is modified to RTR state,
the resolution will take place in the ib_core module. It was buggy
because this callback also deals with UD SIDR exchange, for which we
incorrectly looked at the REQ member of the CM event and dereferenced
a random value.
Fixes: dd5f03beb4f7 ("IB/core: Ethernet L2 attributes in verbs/cm structures")
Signed-off-by: Moni Shoua <monis@mellanox.com>
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
commit 37a967651caf99dd267017023737bd442f5acb3d upstream.
Commit c804f07248895ff9c moved qib_assign_ctxt() to
do_qib_user_sdma_queue_create() but dropped the braces
around the statements.
This was spotted by coccicheck (coccinelle/spatch):
$ make C=2 CHECK=scripts/coccicheck drivers/infiniband/hw/qib/
CHECK drivers/infiniband/hw/qib/qib_file_ops.c
drivers/infiniband/hw/qib/qib_file_ops.c:1583:2-23: code aligned with following code on line 1587
This patch adds braces back.
Link: http://marc.info/?i=cover.1394485254.git.ydroneaud@opteya.com
Cc: Mike Marciniszyn <mike.marciniszyn@intel.com>
Cc: infinipath@intel.com
Cc: Julia Lawall <julia.lawall@lip6.fr>
Cc: cocci@systeme.lip6.fr
Signed-off-by: Yann Droneaud <ydroneaud@opteya.com>
Tested-by: Mike Marciniszyn <mike.marciniszyn@intel.com>
Acked-by: Mike Marciniszyn <mike.marciniszyn@intel.com>
commit f8b6c47a44c063062317646683a73371c24c69ee upstream.
The debugfs init code was incorrectly called before the idr mechanism
is used to get the unit number, so the dd->unit hasn't been
initialized. This caused the unit relative directory creation to fail
after the first.
This patch moves the init for the debugfs stuff until after all of the
failures and after the unit number has been determined.
A bug in unwind code in qib_alloc_devdata() is also fixed.
