path: root/drivers
2010-09-11Merge branch 'pm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'pm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: PM / Hibernate: Avoid hitting OOM during preallocation of memory PM QoS: Correct pr_debug() misuse and improve parameter checks PM: Prevent waiting forever on asynchronous resume after failing suspend
2010-09-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: [SCSI] fix use-after-free in scsi_init_io() [SCSI] sd: fix medium-removal bug [SCSI] qla2xxx: Update version number to 8.03.04-k0. [SCSI] qla2xxx: Check for empty slot in request queue before posting Command type 6 request. [SCSI] qla2xxx: Cover UNDERRUN case where SCSI status is set. [SCSI] qla2xxx: Correctly set fw hung and complete only waiting mbx. [SCSI] qla2xxx: Reset seconds_since_last_heartbeat correctly. [SCSI] qla2xxx: make rport deletions explicit during vport removal [SCSI] qla2xxx: Fix vport delete issues [SCSI] sd, sym53c8xx: Remove warnings after vsprintf %pV introducation. [SCSI] Fix warning: zero-length gnu_printf format string [SCSI] hpsa: disable doorbell reset on reset_devices [SCSI] be2iscsi: Fix for Login failure [SCSI] fix bio.bi_rw handling
2010-09-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (28 commits) ipheth: remove incorrect devtype to WWAN MAINTAINERS: Add CAIF sctp: fix test for end of loop KS8851: Correct RX packet allocation udp: add rehash on connect() net: blackhole route should always be recalculated ipv4: Suppress lockdep-RCU false positive in FIB trie (3) niu: Fix kernel buffer overflow for ETHTOOL_GRXCLSRLALL ipvs: fix active FTP gro: Re-fix different skb headrooms via-velocity: Turn scatter-gather support back off. ipv4: Fix reverse path filtering with multipath routing. UNIX: Do not loop forever at unix_autobind(). PATCH: b44 Handle RX FIFO overflow better (simplified) irda: off by one 3c59x: Fix deadlock in vortex_error() netfilter: discard overlapping IPv6 fragment ipv6: discard overlapping fragment net: fix tx queue selection for bridged devices implementing select_queue bonding: Fix jiffies overflow problems (again) ... Fix up trivial conflicts due to the same cgroup API thinko fix going through both Andrew and the networking tree. However, there were small differences between the two, with Andrew's version generally being the nicer one, and the one I merged first. So pick that one. Conflicts in: include/linux/cgroup.h and kernel/cgroup.c
2010-09-10Merge branch 'drm-intel-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ickle/drm-intel * 'drm-intel-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/ickle/drm-intel: drm/i915: don't enable self-refresh on Ironlake drm/i915: Double check that the wait_request is not pending before warning Revert "drm/i915: Warn if we run out of FIFO space for a mode" Revert "drm/i915: Allow LVDS on pipe A on gen4+" Revert "drm/i915: Enable RC6 on Ironlake."
2010-09-10Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: block: Range check cpu in blk_cpu_to_group scatterlist: prevent invalid free when alloc fails writeback: Fix lost wake-up shutting down writeback thread writeback: do not lose wakeup events when forking bdi threads cciss: fix reporting of max queue depth since init block: switch s390 tape_block and mg_disk to elevator_change() block: add function call to switch the IO scheduler from a driver fs/bio-integrity.c: return -ENOMEM on kmalloc failure bio-integrity.c: remove dependency on __GFP_NOFAIL BLOCK: fix bio.bi_rw handling block: put dev->kobj in blk_register_queue fail path cciss: handle allocation failure cfq-iosched: Documentation help for new tunables cfq-iosched: blktrace print per slice sector stats cfq-iosched: Implement tunable group_idle cfq-iosched: Do group share accounting in IOPS when slice_idle=0 cfq-iosched: Do not idle if slice_idle=0 cciss: disable doorbell reset on reset_devices blkio: Fix return code for mkdir calls
2010-09-10drm/i915: don't enable self-refresh on IronlakeJesse Barnes
We don't know how to enable it safely, especially as outputs turn on and off. When disabling LP1 we also need to make sure LP2 and 3 are already disabled. Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=29173 Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=29082 Reported-by: Chris Lord <chris@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Tested-by: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: stable@kernel.org Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2010-09-09Merge branch 'vhost-net' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost
2010-09-09ipheth: remove incorrect devtype to WWANDan Williams
The 'wwan' devtype is meant for devices that require preconfiguration and *every* time setup before the ethernet interface can be used, like cellular modems which require a series of setup commands on serial ports or other mechanisms before the ethernet interface will handle packets. As ipheth only requires one-per-hotplug pairing setup with no preconfiguration (like APN, phone #, etc) and the network interface is usable at any time after that initial setup, remove the incorrect devtype wwan. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-09Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: libata-sff: Reenable Port Multiplier after libata-sff remodeling. libata: skip EH autopsy and recovery during suspend ahci: AHCI and RAID mode SATA patch for Intel Patsburg DeviceIDs ata_piix: IDE Mode SATA patch for Intel Patsburg DeviceIDs libata,pata_via: revert ata_wait_idle() removal from ata_sff/via_tf_load() ahci: fix hang on failed softreset pata_artop: Fix device ID parity check
2010-09-09libata-sff: Reenable Port Multiplier after libata-sff remodeling.Gwendal Grignou
Keep track of the link on the which the current request is in progress. It allows support of links behind port multiplier. Not all libata-sff is PMP compliant. Code for native BMDMA controller does not take in accound PMP. Tested on Marvell 7042 and Sil7526. Signed-off-by: Gwendal Grignou <gwendal@google.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-09-09libata: skip EH autopsy and recovery during suspendTejun Heo
For some mysterious reason, certain hardware reacts badly to usual EH actions while the system is going for suspend. As the devices won't be needed until the system is resumed, ask EH to skip usual autopsy and recovery and proceed directly to suspend. Signed-off-by: Tejun Heo <tj@kernel.org> Tested-by: Stephan Diestelhorst <stephan.diestelhorst@amd.com> Cc: stable@kernel.org Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-09-09ahci: AHCI and RAID mode SATA patch for Intel Patsburg DeviceIDsSeth Heasley
This patch adds the Intel Patsburg (PCH) SATA AHCI and RAID Controller DeviceIDs. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-09-09ata_piix: IDE Mode SATA patch for Intel Patsburg DeviceIDsSeth Heasley
This patch adds the Intel Patsburg (PCH) IDE mode SATA Controller DeviceIDs. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-09-09libata,pata_via: revert ata_wait_idle() removal from ata_sff/via_tf_load()Tejun Heo
Commit 978c0666 (libata: Remove excess delay in the tf_load path) removed ata_wait_idle() from ata_sff_tf_load() and via_tf_load(). This caused obscure detection problems in sata_sil. https://bugzilla.kernel.org/show_bug.cgi?id=16606 The commit was pure performance optimization. Revert it for now. Reported-by: Dieter Plaetinck <dieter@plaetinck.be> Reported-by: Jan Beulich <JBeulich@novell.com> Bisected-by: gianluca <gianluca@sottospazio.it> Cc: stable@kernel.org Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-09-09drivers/rtc/rtc-pl031.c: do not mark PL031 IRQ as sharedLinus Walleij
It was a mistake to mark the PL031 IRQ as shared (for the U8500), we misread the datasheet. Get rid of this. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Cc: Jonas Aberg <jonas.aberg@stericsson.com> Cc: Mian Yousaf Kaukab <mian.yousaf.kaukab@stericsson.com> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-09gpio: sx150x: correct and refine reset-on-probe behaviorGregory Bean
Replace the arbitrary software-reset call from the device-probe method, because: - It is defective. To work correctly, it should be two byte writes, not a single word write. As it stands, it does nothing. - Some devices with sx150x expanders installed have their NRESET pins ganged on the same line, so resetting one causes the others to reset - not a nice thing to do arbitrarily! - The probe, usually taking place at boot, implies a recent hard-reset, so a software reset at this point is just a waste of energy anyway. Therefore, make it optional, defaulting to off, as this will match the common case of probing at powerup and also matches the current broken no-op behavior. Signed-off-by: Gregory Bean <gbean@codeaurora.org> Reviewed-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-09rtc: m41t80: do not use rtc_valid_tm in m41t80_rtc_read_alarmAtsushi Nemoto
Commit b485fe5ea ("rtc/m41t80: use rtc_valid_tm() to check returned tm") added rtc_valid_tm to m41t80_rtc_read_alarm() but it was wrong while the t->time does not contain complete date/time. This patch also fixes a warning: warning: passing argument 1 of 'rtc_valid_tm' from incompatible pointer type Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-09drivers/mmc/host/imxmmc.c: adjust confusing if indentationJulia Lawall
Move the second if (reg & ...) test into the branch indicated by its indentation. The test was previously always executed after the if containing that branch, but it was always false unless the if branch was taken. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r disable braces4@ position p1,p2; statement S1,S2; @@ ( if (...) { ... } | if (...) S1@p1 S2@p2 ) @script:python@ p1 << r.p1; p2 << r.p2; @@ if (p1[0].column == p2[0].column): cocci.print_main("branch",p1) cocci.print_secs("after",p2) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Chris Ball <cjb@laptop.org> Cc: Pavel Pisa <ppisa@pikron.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-09omap hsmmc: fix a racing case between kmmcd and omap_hsmmc_suspendEthan Du
If suspend called when kmmcd is doing host->ops->disable, as kmmcd already increased host->en_dis_recurs to 1, the mmc_host_enable in suspend function will return directly without increase the nesting_cnt, which will cause the followed register access carried out to the disabled host. mmc_suspend_host will enable host itself. No need to enable host before it. Also works on kmmcd will get flushed in mmc_suspend_host, enable host after it will be safe. So make the mmc_host_enable after it. [cjb: rebase against current Linus] Signed-off-by: Ethan <ethan.too@gmail.com> Signed-off-by: Chris Ball <cjb@laptop.org> Acked-by: Adrian Hunter <adrian.hunter@nokia.com> Acked-by: Madhusudhan Chikkature <madhu.cr@ti.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-09mmc: at91_mci: add missing linux/highmem.h includeMarc Kleine-Budde
Fix the following error: at91_mci.c: In function 'at91_mci_sg_to_dma': at91_mci.c:236: error: implicit declaration of function 'kmap_atomic' at91_mci.c:236: error: 'KM_BIO_SRC_IRQ' undeclared (first use in this function) at91_mci.c:236: error: (Each undeclared identifier is reported only once at91_mci.c:236: error: for each function it appears in.) at91_mci.c:236: warning: assignment makes pointer from integer without a cast at91_mci.c:252: error: implicit declaration of function 'kunmap_atomic' at91_mci.c: In function 'at91_mci_post_dma_read': at91_mci.c:302: error: 'KM_BIO_SRC_IRQ' undeclared (first use in this function) at91_mci.c:302: warning: assignment makes pointer from integer without a cast at91_mci.c:317: error: implicit declaration of function 'flush_kernel_dcache_page' Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: Chris Ball <cjb@laptop.org> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Andrew Victor <avictor.za@gmail.com> Cc: Wolfgang Muees <wolfgang.mues@auerswald.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-09omap_hsmmc: remove unused local `state'Sergio Aguirre
This fixes the following warning: drivers/mmc/host/omap_hsmmc.c: In function 'omap_hsmmc_suspend': drivers/mmc/host/omap_hsmmc.c:2275: warning: unused variable 'state' Introduced by commit ID: commit 1a13f8fa76c880be41d6b1e6a2b44404bcbfdf9e Author: Matt Fleming <matt@console-pimps.org> Date: Wed May 26 14:42:08 2010 -0700 mmc: remove the "state" argument to mmc_suspend_host() The unique usage of this var was removed there, and missed removing the respective declaration aswell. Signed-off-by: Sergio Aguirre <saaguirre@ti.com> Signed-off-by: Chris Ball <cjb@laptop.org> Acked-by: Matt Fleming <matt@console-pimps.org> Cc: Madhusudhan Chikkature <madhu.cr@ti.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-09ARM: SAMSUNG: MMC: fix build error when both DMA and PIO mode selectedJiri Pinkava
[cjb: fix line-wrapped patch] Signed-off-by: Jiri Pinkava <jiri.pinkava@vscht.cz> Signed-off-by: Chris Ball <cjb@laptop.org> Cc: Matt Fleming <matt@console-pimps.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ben Dooks <ben-linux@fluff.org> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-09mmc: fix the use of kunmap_atomic() in tmio_mmc.hGuennadi Liakhovetski
kunmap_atomic() takes the cookie, returned by the kmap_atomic() as its argument and not the page address, used as an argument to kmap_atomic(). This patch fixes the compile error: In file included from drivers/mmc/host/tmio_mmc.c:37: drivers/mmc/host/tmio_mmc.h: In function 'tmio_mmc_kunmap_atomic': drivers/mmc/host/tmio_mmc.h:192: error: negative width in bit-field '<anonymous>' Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Eric Miao <eric.y.miao@gmail.com> Tested-by: Magnus Damm <damm@opensource.se> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-09tmio_mmc: don't clear unhandled pending interruptsYusuke Goda
Previously, it was possible for ack_mmc_irqs() to clear pending interrupt bits in the CTL_STATUS register, even though the interrupt handler had not been called. This was because of a race that existed when doing a read-modify-write sequence on CTL_STATUS. After the read step in this sequence, if an interrupt occurred (causing one of the bits in CTL_STATUS to be set) the write step would inadvertently clear it. Observed with the TMIO_STAT_RXRDY bit together with CMD53 on AR6002 and BCM4318 SDIO cards in polled mode. This patch eliminates this race by only writing to CTL_STATUS and clearing the interrupts that were passed as an argument to ack_mmc_irqs()." [matt@console-pimps.org: rewrote changelog] Signed-off-by: Yusuke Goda <yusuke.goda.sx@renesas.com> Acked-by: Magnus Damm <damm@opensource.se>" Tested-by: Arnd Hannemann <arnd@arndnet.de>" Acked-by: Ian Molton <ian@mnementh.co.uk> Cc: Matt Fleming <matt@console-pimps.org> Cc: Samuel Ortiz <sameo@linux.intel.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: <linux-mmc@vger.kernel.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-09hp_accel: add quirks for HP ProBook 532x and HP Mini 5102Takashi Iwai
Added missing axis-mapping for HP ProBook 532x and HP Mini 5102. Signed-off-by: Takashi Iwai <tiwai@suse.de> Cc: Eric Piel <eric.piel@tremplin-utc.net> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-09rtc-bfin: fix state restoration when resumingMike Frysinger
Much (but not all) of the RTC state is kept in the RTC peripheral which has its own power domain. Periodically (1 HZ), that state is synced from one power domain to the other (peripheral->core). When we are resuming, we need to wait for the sync to occur so that we don't get a mismatch of reading undefined state in the rest of the driver. Further, once the externally maintained bits have been synced back into the core, we then need to restore the bits maintained in the core. In our particular case, that is just the write completion interrupt bit. If we don't do any of this, working with the RTC causes ~5 second delays from time to time after waking up due to the write completion interrupt never firing. Reported-by: Michael Dean <mdean@aeronix.com> Reported-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-09rtc-bfin: fix inverted logic in suspend pathMike Frysinger
The int_clear helper takes a bitmask of interrupts to keep, not to disable. When suspending without wakeup enabled, we want to disable all interrupts, so use 0 (keep none) instead of -1 (keep all). Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-09mmc: avoid getting CID on SDIO-only cardsDavid Vrabel
The introduction of support for SD combo cards breaks the initialization of all CSR SDIO chips. The GO_IDLE (CMD0) in mmc_sd_get_cid() causes CSR chips to be reset (this is non-standard behavior). When initializing an SDIO card check for a combo card by using the memory present bit in the R4 response to IO_SEND_OP_COND (CMD5). This avoids the call to mmc_sd_get_cid() on an SDIO-only card. Signed-off-by: David Vrabel <david.vrabel@csr.com> Acked-by: Michal Mirolaw <mirq-linux@rere.qmqm.pl> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-09Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: (30 commits) ARM: Update mach-types ARM: Partially revert "Auto calculate ZRELADDR and provide option for exceptions" ARM: Ensure PTE modifications via dma_alloc_coherent are visible ARM: 6359/1: ep93xx: move clock initialization earlier Revert "[ARM] pxa: remove now unnecessary dma_needs_bounce()" ARM: 6352/1: perf: fix event validation ARM: 6344/1: Mark CPU_32v6K as depended on CPU_V7 ARM: 6343/1: wire up fanotify and prlimit64 syscalls on ARM ARM: 6330/1: perf: reword comments relating to perf_event_do_pending ARM: pxa168fb: fix section mismatch ARM: pxa: Make id const in pwm_probe() ARM: pxa: fix CI_HSYNC and CI_VSYNC MFP defines for pxa300 ARM: pxa: remove __init from cpufreq_driver->init() ARM: imx: set cache line size to 64 bytes for i.MX5 mx5/clock: fix clear bit fields issue in _clk_ccgr_disable function mxc/tzic: add base address when accessing TZIC registers ARM: mach-shmobile: ap4evb: fix write protect for SDHI1 ARM: mach-shmobile: ap4evb: modify FSI2 ID ARM: mach-shmobile: do not enable the PLLC2 clock on init ARM: mach-shmobile: Clock framework comment fix ...
2010-09-09Merge branch 'origin'Russell King
2010-09-09ahci: fix hang on failed softresetTejun Heo
ahci_do_softreset() compared the current time and deadline in reverse when calculating timeout for SRST issue. The result is that if @deadline is in future, SRST is issued with 0 timeout, which hasn't caused any problem because it later waits for DRDY with the correct timeout. If deadline is already exceeded by the time SRST is about to be issued, the timeout calculation underflows and if the device doesn't respond, timeout doesn't trigger for a _very_ long time. Reverse the incorrect comparison order. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Anssi Hannula <anssi.hannula@iki.fi> Tested-by: Gwendal Grignou <gwendal@google.com> Cc: stable@kernel.org Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-09-09pata_artop: Fix device ID parity checkJean Delvare
x % 1 always evaluates to 0, which clearly isn't the intent. The author probably had "% 2" or "& 1" in mind, and mispelled it. Signed-off-by: Jean Delvare <jdelvare@suse.de> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Alan Cox <alan@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-09-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: RDMA/nes: Fix hang with modified FIN handling on A0 cards RDMA/nes: Change state to closing after FIN RDMA/nes: Fix double CLOSE event indication crash RDMA/nes: Write correct register write to set TX pause param RDMA/cxgb3: Don't exceed the max HW CQ depth
2010-09-09[SCSI] fix use-after-free in scsi_init_io()James Bottomley
we're using a pointer through a freed command to reset the request, which has shown up as an oops with slab poisoning: Reported-by: Tejun Heo <tj@kernel.org> Reported-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-09-09drm/i915: Double check that the wait_request is not pending before warningChris Wilson
If we are busy, then we may have woken up the wait_request handler but not yet serviced it before the hang check fires. So in hang check, double check that the i915_gem_do_wait_request() is still pending the wake-up before declaring all hope lost. Fixes regression with e78d73b16bcde921c9cf458d2e4de8e4fc2518f3. Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=30073 Reported-and-tested-by: Sitsofe Wheeler <sitsofe@yahoo.com> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2010-09-08Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
2010-09-08KS8851: Correct RX packet allocationEric Dumazet
Use netdev_alloc_skb_ip_align() helper and do correct allocation Tested-by: Abraham Arce <x0066660@ti.com> Signed-off-by: Abraham Arce <x0066660@ti.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-09PM: Prevent waiting forever on asynchronous resume after failing suspendColin Cross
During suspend, the power.completion is expected to be set when a device has not yet started suspending. Set it on init to fix a corner case where a device is resumed when its parent has never suspended. Consider three drivers, A, B, and C. The parent of A is C, and C has async_suspend set. On boot, C->power.completion is initialized to 0. During the first suspend: suspend_devices_and_enter(...) dpm_resume(...) device_suspend(A) device_suspend(B) returns error, aborts suspend dpm_resume_end(...) dpm_resume(...) device_resume(A) dpm_wait(A->parent == C) wait_for_completion(C->power.completion) The wait_for_completion will never complete, because complete_all(C->power.completion) will only be called from device_suspend(C) or device_resume(C), neither of which is called if suspend is aborted before C. After a successful suspend->resume cycle, where B doesn't abort suspend, C->power.completion is left in the completed state by the call to device_resume(C), and the same call path will work if B aborts suspend. Signed-off-by: Colin Cross <ccross@android.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-09-08Merge branches 'cxgb3' and 'nes' into for-linusRoland Dreier
2010-09-08RDMA/nes: Fix hang with modified FIN handling on A0 cardsFaisal Latif
Changing state to CLOSING when FIN is received causes A0 cards to hang. Fix this by checking for A0 cards in FIN handling. Signed-off-by: Faisal Latif <faisal.latif@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-09-08RDMA/nes: Change state to closing after FINFaisal Latif
When the driver receives an AE for FIN received, it closes the connection without changing the state of the connection in the hardware to closing. By changing the state to closing, hardware will do a normal close sequence. Signed-off-by: Faisal Latif <faisal.latif@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-09-08RDMA/nes: Fix double CLOSE event indication crashFaisal Latif
During a stress testing in a large cluster, multiple close event are detected and BUG() is hit in the iWARP core. The cause is that the active node gave up while waiting for an MPA response from the peer and tried to close the connection by sending RST. The passive node driver receives the RST but is waiting for MPA response from the user. When the MPA accept is received, the driver offloads the connection and sends a CLOSE event. The driver gets an AE indicating RESET received and also sends a CLOSE event, hitting a BUG(). Fix this by correcting RESET handling and sending CLOSE events. Signed-off-by: Faisal Latif <faisal.latif@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-09-08RDMA/nes: Write correct register write to set TX pause paramChien Tung
Setting TX pause param writes to the wrong register location causing the adapter to hang. Correct the define used to write the reigster. Addresses: https://bugs.openfabrics.org/show_bug.cgi?id=2116 Reported-by: Shiri Franchi <shirif@voltaire.com> Signed-off-by: Chien Tung <chien.tin.tung@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-09-08niu: Fix kernel buffer overflow for ETHTOOL_GRXCLSRLALLBen Hutchings
niu_get_ethtool_tcam_all() assumes that its output buffer is the right size, and warns before returning if it is not. However, the output buffer size is under user control and ETHTOOL_GRXCLSRLALL is an unprivileged ethtool command. Therefore this is at least a local denial-of-service vulnerability. Change it to check before writing each entry and to return an error if the buffer is already full. Compile-tested only. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: i8042 - fix device removal on unload Input: bcm5974 - adjust major/minor to scale Input: MT - initialize slots to unused Input: use PIT_TICK_RATE in vt beep ioctl Input: wacom - fix mousewheel handling for old wacom tablets
2010-09-08Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf, x86: Try to handle unknown nmis with an enabled PMU perf, x86: Fix handle_irq return values perf, x86: Fix accidentally ack'ing a second event on intel perf counter oprofile, x86: fix init_sysfs() function stub lockup_detector: Sync touch_*_watchdog back to old semantics tracing: Fix a race in function profile oprofile, x86: fix init_sysfs error handling perf_events: Fix time tracking for events with pid != -1 and cpu != -1 perf: Initialize callchains roots's childen hits oprofile: fix crash when accessing freed task structs
2010-09-08Revert "drm/i915: Warn if we run out of FIFO space for a mode"Chris Wilson
This reverts commit b9421ae8f30958deea98d71477b4a77a066856b4. This warning was so prelevant, even for apparently working machines, that it was just causing fear, anxiety and panic. The root cause still remains, so we will add some better debugging when we focus on fixing it. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=17021 Reported-by: Maciej Rutecki <maciej.rutecki@gmail.com> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2010-09-08Revert "drm/i915: Allow LVDS on pipe A on gen4+"Chris Wilson
This reverts commit 0f3ee801b332d6ff22285386675fe5aaedf035c3. Enabling LVDS on pipe A was causing excessive wakeups on otherwise idle systems due to i915 interrupts. So restrict the LVDS to pipe B once more, whilst the issue is properly diagnosed. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=16307 Reported-and-tested-by: Enrico Bandiello <enban@postal.uv.es> Poked-by: Florian Mickler <florian@mickler.org> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Adam Jackson <ajax@redhat.com> Cc: stable@kernel.org
2010-09-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: bus speed strings should be const PCI hotplug: Fix build with CONFIG_ACPI unset PCI: PCIe: Remove the port driver module exit routine PCI: PCIe: Move PCIe PME code to the pcie directory PCI: PCIe: Disable PCIe port services during port initialization PCI: PCIe: Ask BIOS for control of all native services at once ACPI/PCI: Negotiate _OSC control bits before requesting them ACPI/PCI: Do not preserve _OSC control bits returned by a query ACPI/PCI: Make acpi_pci_query_osc() return control bits ACPI/PCI: Reorder checks in acpi_pci_osc_control_set() PCI: PCIe: Introduce commad line switch for disabling port services PCI: PCIe AER: Introduce pci_aer_available() x86/PCI: only define pci_domain_nr if PCI and PCI_DOMAINS are set PCI: provide stub pci_domain_nr function for !CONFIG_PCI configs
2010-09-07Merge branch 'for-linus' of git://neil.brown.name/mdLinus Torvalds
* 'for-linus' of git://neil.brown.name/md: md: resolve confusion of MD_CHANGE_CLEAN md: don't clear MD_CHANGE_CLEAN in md_update_sb() for external arrays Move .gitignore from drivers/md to lib/raid6
