path: root/drivers
2006-12-31[SPARC64]: Fix of_iounmap() region release.David S. Miller
We need to pass in the resource otherwise we cannot release the region properly. We must know whether it is an I/O or MEM resource. Spotted by Eric Brower. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: ieee1394: sbp2: fix bogus dma mapping ieee1394: sbp2: pass REQUEST_SENSE through to the target
2006-12-30[PATCH] kvm: fix GFP_KERNEL allocation in atomic section in ↵Ingo Molnar
kvm_dev_ioctl_create_vcpu() fix an GFP_KERNEL allocation in atomic section: kvm_dev_ioctl_create_vcpu() called kvm_mmu_init(), which calls alloc_pages(), while holding the vcpu. The fix is to set up the MMU state in two phases: kvm_mmu_create() and kvm_mmu_setup(). (NOTE: free_vcpus does an kvm_mmu_destroy() call so there's no need for any extra teardown branch on allocation/init failure here.) Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Avi Kivity <avi@qumranet.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30[PATCH] KVM: Fix oops on oomAvi Kivity
__free_page() doesn't like a NULL argument, so check before calling it. A NULL can only happen if memory is exhausted during allocation of a memory slot. Signed-off-by: Avi Kivity <avi@qumranet.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30[PATCH] KVM: Rename some msrsNguyen Anh Quynh
No need to append _MSR to msr names, a prefix should suffice. Signed-off-by: Nguyen Anh Quynh <aquynh@gmail.com> Signed-off-by: Avi Kivity <avi@qumranet.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30[PATCH] KVM: More msr miseryAvi Kivity
These msrs are referenced by benchmarking software when pretending to be an Intel cpu. Signed-off-by: Avi Kivity <avi@qumranet.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30[PATCH] KVM: Move common msr handling to arch independent codeAvi Kivity
2006-12-30[PATCH] KVM: Implement a few system configuration msrsAvi Kivity
Resolves sourceforge bug 1622229 (guest crashes running benchmark software). Signed-off-by: Avi Kivity <avi@qumranet.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30[PATCH] KVM: Initialize kvm_arch_ops on unloadYoshimi Ichiyanagi
The latest version of kvm doesn't initialize kvm_arch_ops in kvm_init(), which causes an error with the following sequence. 1. Load the supported arch's module. 2. Load the unsupported arch's module.$B!!(B(loading error) 3. Unload the unsupported arch's module. You'll get the following error message after step 3. "BUG: unable to handle to handle kernel paging request at virtual address xxxxxxxx" The problem here is that the unsupported arch's module overwrites kvm_arch_ops of the supported arch's module at step 2. This patch initializes kvm_arch_ops upon loading architecture specific kvm module, and prevents overwriting kvm_arch_ops when kvm_arch_ops is already set correctly. Signed-off-by: Avi Kivity <avi@qumranet.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30[PATCH] KVM: Simplify is_long_mode()Avi Kivity
Instead of doing tricky stuff with the arch dependent virtualization registers, take a peek at the guest's efer. This simlifies some code, and fixes some confusion in the mmu branch. Signed-off-by: Avi Kivity <avi@qumranet.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30[PATCH] KVM: Use boot_cpu_data instead of current_cpu_dataAvi Kivity
current_cpu_data invokes smp_processor_id(), which is inadvisable when preemption is enabled. Switch to boot_cpu_data instead. Resolves sourceforge bug 1621401. Signed-off-by: Avi Kivity <avi@qumranet.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30[PATCH] PIIX/SLC90E66: PIO mode fallback fixSergei Shtylyov
The fallback to PIO mode in the hwif->dma_check() handler doesn't work in the Intel PIIX and SMsC SLC90E66 IDE drivers because: - config_drive_for_dma() calls the hwif->speedproc() handler with a wrong mode number (unbiased by XFER_PIO_0) in case of the PIO fallback; - hwif->tuneproc() handler doesn't really set the drive's own speed (this is not fixed as yet). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30[PATCH] PIIX: remove check for broken MW DMA mode 0Sergei Shtylyov
There's no need to check in piix_config_drive_for_dma() for broken MW DMA mode 0 as this mode is not supported by the driver (it sets hwif->mwdma_mask to 0x6), and hence can't be selected by ide_dma_speed(). (Alan sayeth "Probably right but if not you've got a subtle corruptor. Should at least stick a BUG_ON mode 0 setting right close when the mode is set.") Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30[PATCH] spi_s3c24xx_gpio: use right headerArnaud Patard (Rtp
Russel King recently reminded us that one shouldn't use asm/arch/hardware.h but one should use asm/hardware.h. Unfortunately, the spi_s3c24xx_gpio driver is using the wrong header. This patch is fixing that. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30[PATCH] SPI/MTD: mtd_dataflash oops preventionDavid Brownell
Return a fault code if the Dataflash driver runs into a "no device present" error when the MISO line has a pulldown (it currently expects a pullup), so that rmmod won't oops. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30[PATCH] m25p80 build fixes (with MTD debug)David Brownell
Fix build issues that show up with the m25p80 SPI flash driver when building with MTD debug enabled. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30[PATCH] SPI: define null tx_buf to mean "shift out zeroes"David Brownell
Some issues were recently turned up with the current specification of what it means for spi_transfer.tx_buf to be null, as part of transfers which are (from the SPI protocol driver perspective) pure reads. Specifically, that it seems better to change the TX behaviour there from "undefined" to "will shift zeroes". This lets protocol drivers (like the ads7846 driver) depend on that behavior. It's what most controller drivers in the tree are already doing (with one exception and one case of driver wanting-to-oops), it's what Microwire hardware will necessarily be doing, and it removes an issue whereby certain security audits would need to define such a value anyway as part of removing covert channels. This patch changes the specification to require shifting zeroes, and updates all currently merged SPI controller drivers to do so. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30[PATCH] cciss: build with PROC_FS=nRandy Dunlap
RAID_UNKNOWN is used even when PROC_FS=n, so move it outside of the CONFIG_PROC_FS block. drivers/block/cciss.c:1910: error: 'RAID_UNKNOWN' undeclared (first use in this function) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: <mike.miller@hp.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30[PATCH] Fix compilation of via-pmu-backlightAndreas Schwab
Signed-off-by: Andreas Schwab <schwab@suse.de> Cc: "Yu, Luming" <luming.yu@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30[PATCH] Char: isicom, eliminate spinlock recursionJiri Slaby
Many spinlock recursion was in the isicom driver. Eliminate it. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30[PATCH] make fn_keys work again on power/macbooksSoeren Sonnenburg
The apple fn keys don't work anymore with 2.6.20-rc1. The reason is that USB_HID_POWERBOOK appears in several files although USB_HIDINPUT_POWERBOOK is the thing to be used. The patch fixes this. Cc: Greg KH <greg@kroah.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30[PATCH] IB/mthca: Fix FMR breakage caused by kmemdup() conversionMichael S. Tsirkin
Commit bed8bdfd ("IB: kmemdup() cleanup") introduced one bad conversion to kmemdup() in mthca_alloc_fmr(), where the structure allocated and the structure copied are not the same size. Revert this back to the original kmalloc()/memcpy() code. Reported-by: Dotan Barak <dotanb@mellanox.co.il>. Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il> Signed-off-by: Roland Dreier <roland@digitalvampire.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30[PATCH] Char: mxser, fix oops when removing openedJiri Slaby
tty_driver->owner is not set, so if somebody remove mxser_module, it might oops (and doesn't tell the user: no way, it's in use). Set the .owner value. Cc: <osv@javad.com> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30[PATCH] pci/probe: fix macro that confuses kernel-docRandy Dunlap
Don't have macros between a function's kernel-doc block and the function definition. This is not valid for kernel-doc. Warning(/var/linsrc/linux-2.6.20-rc1-git8//drivers/pci/probe.c:653): No description found for parameter 'IORESOURCE_PCI_FIXED' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30[PATCH] powerpc iseries link error in allmodconfigJudith Lebzelter
Choose rpa_vscsi.c over iseries_vscsi.c when building both pseries and iseries. This fixes a link error. Signed-off-by: Judith Lebzelter <judith@osdl.org> Acked-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30[PATCH] Fix IPMI watchdog set_param_str() using kstrdupSebastien Dugué
set_param_str() cannot use kstrdup() to duplicate the parameter. That's fine when the driver is compiled as a module but it sure is not when built into the kernel as the kernel parameters are parsed before the kmalloc slabs are setup. Signed-off-by: Sebastien Dugué <sebastien.dugue@bull.net> Acked-by: Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30ieee1394: sbp2: fix bogus dma mappingStefan Richter
Need to use a PCI device, not a FireWire host device. Problem found by Andreas Schwab, mistake pointed out by Benjamin Herrenschmidt. http://ozlabs.org/pipermail/linuxppc-dev/2006-December/029595.html Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Tested-by: Andreas Schwab <schwab@suse.de>
2006-12-30ieee1394: sbp2: pass REQUEST_SENSE through to the targetStefan Richter
Delete some incorrect code, left over from the initial driver submission in March 2001. SBP-2 targets should provide sense data via the SBP-2 status block (autosense). We have to pass the REQUEST_SENSE command through to targets which don't implement autosense, if there are any, and to accomodate application clients which use this command. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2006-12-29Merge branch 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6: [S390] cio: fix stsch_reset. [S390] Change max. buffer size for monwriter device.
2006-12-29Merge branch 'master' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/mchehab/v4l-dvb * 'master' of master.kernel.org:/pub/scm/linux/kernel/git/mchehab/v4l-dvb: (28 commits) V4L/DVB (5010): Cx88: Fix leadtek_eeprom tagging V4L/DVB (5012): Usbvision fix: It was using "&&" instead "&" V4L/DVB (5001): Add two required headers on kernel 2.6.20-rc1 V4L/DVB (5014): Allyesconfig build fixes on some non x86 arch V4L/DVB (4997): Bttv: delete duplicated ioremap() V4L/DVB (4996): Msp3400: fix kthread_run error check V4L/DVB (4995): Vivi: fix kthread_run() error check V4L/DVB (4994): Vivi: fix use after free in list_for_each() V4L/DVB (4992): Fix typo in saa7134-dvb.c V4L/DVB (4991): Cafe_ccic.c: fix NULL dereference V4L/DVB (4990): Cpia2/cpia2_usb.c: fix error-path leak V4L/DVB (4988): Cx2341x audio_properties is an u16, not u8 V4L/DVB (4984): LOG_STATUS should show the real temporal filter value. V4L/DVB (4983): Force temporal filter to 0 when scaling to prevent ghosting. V4L/DVB (4982): Fix broken audio mode handling for line-in in msp3400. V4L/DVB (4980): Fixes bug 7267: PAL/60 is not working V4L/DVB (4979): Fixes compilation when CONFIG_V4L1_COMPAT is not selected V4L/DVB (4973): Dvb-core: fix printk type warning V4L/DVB (4972): Dvb-core: fix bug in CRC-32 checking on 64-bit systems V4L/DVB (4970): Usbvision memory fixes ...
2006-12-29Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: (42 commits) r8169: extraneous Cmd{Tx/Rx}Enb write forcedeth: modified comment header NetXen: Reducing ring sizes for IOMMU issue. NetXen: Fix for PPC machines. NetXen: work queue fixes. NetXen: Link status message correction for quad port cards. NetXen: Multiple adapter fix. NetXen: Using correct CHECKSUM flag. NetXen: driver reload fix for newer firmware. NetXen: Adding new device ids. PHY probe not working properly for ibm_emac (PPC4xx) ep93xx: some minor cleanups to the ep93xx eth driver sky2: phy power down needs PCI config write enabled sky2: power management/MSI workaround sky2: dual port NAPI problem via-velocity uses INET interfaces e1000: Do not truncate TSO TCP header with 82544 workaround myri10ge: handle failures in suspend and resume myri10ge: no need to save MSI and PCIe state in the driver myri10ge: make msi configurable at runtime through sysfs ...
2006-12-28[S390] cio: fix stsch_reset.Michael Holzheu
Copy inline assembly of stsch and add "memory" to clobber list in order to prevent gcc from optimizing away the checking of the global variable "pgm_check_occured". Signed-off-by: Michael Holzheu <holzheu@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-28[S390] Change max. buffer size for monwriter device.Melissa Howland
Reduce the max. buffer size for the monwriter device to prevent a possible problem with the z/VM monitor service. Signed-off-by: Melissa Howland <melissah@us.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-27V4L/DVB (5010): Cx88: Fix leadtek_eeprom taggingJean Delvare
reference to .init.text: from .text between 'cx88_card_setup' (at offset 0x68c) and 'cx88_risc_field' Caused by leadtek_eeprom() being declared __devinit and called from a non-devinit context. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-27V4L/DVB (5012): Usbvision fix: It was using "&&" instead "&"Alexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-27V4L/DVB (5001): Add two required headers on kernel 2.6.20-rc1Mauro Carvalho Chehab
include/media/ir-common.h:78: error: field 'work' has incomplete type drivers/media/common/ir-functions.c: In function 'ir_rc5_timer_end': drivers/media/common/ir-functions.c:301: error: 'jiffies' undeclared (first use in this function) drivers/media/common/ir-functions.c:301: error: (Each undeclared identifier is reported only once) drivers/media/common/ir-functions.c:301: error: for each function it appears in.) drivers/media/common/ir-functions.c:347: error: 'HZ' undeclared (first use in this function) Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-27V4L/DVB (5014): Allyesconfig build fixes on some non x86 archDavid Brownell
- CAFE_CCIC needs to depend on PCI, else "allyesconfig" breaks on systems without PCI - em28xx-video can't udelay(2500) else "allyesconfig" breaks on systems that refuse to spin that long (I saw it on ARM) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-27V4L/DVB (4997): Bttv: delete duplicated ioremap()Akinobu Mita
ioremap() is called twice to same resource. The returen value of first one is not error-checked. second one is complely ignored. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-27V4L/DVB (4996): Msp3400: fix kthread_run error checkAkinobu Mita
The return value of kthread_run() should be checked by IS_ERR(). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-27V4L/DVB (4995): Vivi: fix kthread_run() error checkAkinobu Mita
2006-12-27V4L/DVB (4994): Vivi: fix use after free in list_for_each()Akinobu Mita
Freeing data including list_head in list_for_each() is not safe. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-27V4L/DVB (4992): Fix typo in saa7134-dvb.cStephan Berberig
Fix a typo (use_frontent -> use_frontend) in saa7134-dvb.c. Signed-off-by: Stephan Berberig <s.berberig@arcor.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-27V4L/DVB (4991): Cafe_ccic.c: fix NULL dereferenceAdrian Bunk
We shouldn't dereference "cam" when we already know it's NULL. Spotted by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-27V4L/DVB (4990): Cpia2/cpia2_usb.c: fix error-path leakAmit Choudhary
Free previously allocated memory (in array elements) if kmalloc() returns NULL in submit_urbs(). Signed-off-by: Amit Choudhary <amit2030@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-27V4L/DVB (4984): LOG_STATUS should show the real temporal filter value.Hans Verkuil
The temporal filter is forced off when scaling. The VIDIOC_LOG_STATUS handler still showed the old temporal filter. It is now consistent with the real temporal filter value. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-27V4L/DVB (4983): Force temporal filter to 0 when scaling to prevent ghosting.Hans Verkuil
Change the code to unconditionally turn off the temporal filter when scaling. If the window is not full screen the filter will introduce a nasty ghosting effect. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-27V4L/DVB (4982): Fix broken audio mode handling for line-in in msp3400.Hans Verkuil
The wrong matrix was used when an external input was selected instead of the tuner input. The rxsubchans field was also not initialized to STEREO for an external input. And finally the msp34xxg_detect_stereo() should not try to detect stereo for an external input, that code is for the tuner input only. Together these bugs made it hit 'n miss whether you ever got stereo out of the msp3400 for an external input. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-27V4L/DVB (4980): Fixes bug 7267: PAL/60 is not workingMauro Carvalho Chehab
On cx88 driver, sampling rate should be at chroma subcarrier freq (FSC). However, driver were programming wrong values for PAL/60, PAL/Nc and NTSC 4.43. This patch do the proper calculation. It also calculates htotal, hdelay and hactive constants, according with the sampling rate. It is tested with PAL/60 by Piotr Maksymuk and Olivier. Also tested with the already-supported standards. Test is still required for PAL/Nc. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-27V4L/DVB (4979): Fixes compilation when CONFIG_V4L1_COMPAT is not selectedDwaine Garden
- SYSFS: Replaced all to_video_device(cd), video_device_create_file, video_device_remove_file and add the proper checks at create_file - Converted old norm values to V4L2 ones. - Robustness on sysfs hue/contrast/saturation queries. Additional check in order to return 0 if the driver is not opened. - Whitespace cleanups in usbvision-cards.c This patch merges two fixes by Thierry MERLE and Mauro Chehab, and adds additional checks. Signed-off-by: Dwaine Garden<DwaineGarden@rogers.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-27V4L/DVB (4973): Dvb-core: fix printk type warningMichael Krufky
dvb_net.c: In function 'dvb_net_ule': dvb_net.c:628: warning: format '%#lx' expects type 'long unsigned int', but argument 3 has type 'u32' dvb_net.c:628: warning: format '%#lx' expects type 'long unsigned int', but argument 4 has type 'u32' Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
