Bug 1034241
Change-Id: I5607d53cf0bdd25c5e2b8447cd7e676b64cd32a2
Signed-off-by: Manoj Gangwal <mgangwal@nvidia.com>
Reviewed-on: http://git-master/r/125169
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
A handle's usecount used to be incremented once during the mmap ioctl,
and decremented when the mapping is closed by the kernel. However, that
fails if a mapping cloned, for example if the mapping was split due to
a munmap, or (presumably) during fork, as the decrement will then happen
for each cloned mapping.
Therefore increment the usecount when a mapping is opened.
Also fix a BUG_ON() that would have caught this bug, if it wouldn't
have done the check by checking if the unsigned usecount field is
less than zero.
Bug 1033981
Change-Id: I72ac9361a19e44f91ffd6b1126f4632e0f7b6726
Signed-off-by: Tuomas Tynkkynen <ttynkkynen@nvidia.com>
Reviewed-on: http://git-master/r/123710
GVS: Gerrit_Virtual_Submit
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
|kernel BUG at kernel/rtmutex.c:724!
|[<c029599c>] (rt_spin_lock_slowlock+0x108/0x2bc) from [<c01c2330>] (defer_bh+0x1c/0xb4)
|[<c01c2330>] (defer_bh+0x1c/0xb4) from [<c01c3afc>] (rx_complete+0x14c/0x194)
|[<c01c3afc>] (rx_complete+0x14c/0x194) from [<c01cac88>] (usb_hcd_giveback_urb+0xa0/0xf0)
|[<c01cac88>] (usb_hcd_giveback_urb+0xa0/0xf0) from [<c01e1ff4>] (musb_giveback+0x34/0x40)
|[<c01e1ff4>] (musb_giveback+0x34/0x40) from [<c01e2b1c>] (musb_advance_schedule+0xb4/0x1c0)
|[<c01e2b1c>] (musb_advance_schedule+0xb4/0x1c0) from [<c01e2ca8>] (musb_cleanup_urb.isra.9+0x80/0x8c)
|[<c01e2ca8>] (musb_cleanup_urb.isra.9+0x80/0x8c) from [<c01e2ed0>] (musb_urb_dequeue+0xec/0x108)
|[<c01e2ed0>] (musb_urb_dequeue+0xec/0x108) from [<c01cbb90>] (unlink1+0xbc/0xcc)
|[<c01cbb90>] (unlink1+0xbc/0xcc) from [<c01cc2ec>] (usb_hcd_unlink_urb+0x54/0xa8)
|[<c01cc2ec>] (usb_hcd_unlink_urb+0x54/0xa8) from [<c01c2a84>] (unlink_urbs.isra.17+0x2c/0x58)
|[<c01c2a84>] (unlink_urbs.isra.17+0x2c/0x58) from [<c01c2b44>] (usbnet_terminate_urbs+0x94/0x10c)
|[<c01c2b44>] (usbnet_terminate_urbs+0x94/0x10c) from [<c01c2d68>] (usbnet_stop+0x100/0x15c)
|[<c01c2d68>] (usbnet_stop+0x100/0x15c) from [<c020f718>] (__dev_close_many+0x94/0xc8)
defer_bh() takes the lock which is hold during unlink_urbs(). The safe
walk suggest that the skb will be removed from the list and this is done
by defer_bh() so it seems to be okay to drop the lock here.
Reported-by: AnÃbal Almeida Pinto <anibal.pinto@efacec.com>
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Acked-by: Oliver Neukum <oliver@neukum.org>
(cherry picked from commit 4231d47e6fe69f061f96c98c30eaf9fb4c14b96d)
net/usbnet: reserve headroom on rx skbs
network drivers should reserve some headroom on incoming skbs so that we
dont need expensive reallocations, eg forwarding packets in tunnels.
This NET_SKB_PAD padding is done in various helpers, like
__netdev_alloc_skb_ip_align() in this patch, combining NET_SKB_PAD and
NET_IP_ALIGN magic.
Cc: Oliver Neukum <oneukum@suse.de>
Acked-by: Oliver Neukum <oneukum@suse.de>
(cherry picked from commit 7bdd402706cf26bfef9050dfee3f229b7f33ee4f)
usbnet: use netif_tx_wake_queue instead of netif_start_queue
If host is going to autosuspend function with two interfaces and
if IP packet has arrived in-between of two usbnet_suspend() callbacks,
i.e usbnet_resume() is called in-between, tx data flow is stopped.
When autosuspend timer expires and device is put to autosuspend
again, tx queue is waked up and data can be sent again.
This behavior might be repeated several times in a row.
Tested on Intel/ARM.
Reviewed-by: Sjur Brændeland <sjur.brandeland@stericsson.com>
Tested-by: Dmitry Tarnyagin <dmitry.tarnyagin@stericsson.com>
Signed-off-by: Alexey Orishko <alexey.orishko@stericsson.com>
(cherry picked from commit 1aa9bc5b2f4cf8c48944fb9a607bf1dd674e2c10)
usbnet: increase URB reference count before usb_unlink_urb
Commit 4231d47e6fe69f061f96c98c30eaf9fb4c14b96d(net/usbnet: avoid
recursive locking in usbnet_stop()) fixes the recursive locking
problem by releasing the skb queue lock, but it makes usb_unlink_urb
racing with defer_bh, and the URB to being unlinked may be freed before
or during calling usb_unlink_urb, so use-after-free problem may be
triggerd inside usb_unlink_urb.
The patch fixes the use-after-free problem by increasing URB
reference count with skb queue lock held before calling
usb_unlink_urb, so the URB won't be freed until return from
usb_unlink_urb.
Reported-by: Dave Jones <davej@redhat.com>
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
(cherry picked from commit 0956a8c20b23d429e79ff86d4325583fc06f9eb4)
usbnet: don't clear urb->dev in tx_complete
URB unlinking is always racing with its completion and tx_complete
may be called before or during running usb_unlink_urb, so tx_complete
must not clear urb->dev since it will be used in unlink path,
otherwise invalid memory accesses or usb device leak may be caused
(cherry picked from commit 5d5440a835710d09f0ef18da5000541ec98b537a)
usbnet: consider device busy at each recieved packet
usbnet should centrally handle busy reporting in the rx path
so subdrivers need not worry. This hurts use cases which do
rx only or predominantly.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
(cherry picked from commit 8a78335442cea429afb2b964318b6e257448ea00)
usbnet: fix leak of transfer buffer of dev->interrupt
The transfer buffer of dev->interrupt is allocated in .probe path,
but not freed in .disconnet path, so mark the interrupt URB as
URB_FREE_BUFFER to free the buffer when the URB is destroyed.
(cherry picked from commit 267a83e8e00dc5a878b24c39883643c20a8b1482)
Bug 1036768
Change-Id: I5d6620c8ff4e6cef52c3f467fb2196658c4d47b1
Signed-off-by: Steve Lin <stlin@nvidia.com>
Reviewed-on: http://git-master/r/125338
Process wait list when removing a waiter. This clears the interrupt
once it is no longer needed.
Bug 1031724
Change-Id: Ifb46672f70c8bbd6359d0a8aeaac0d718a5394b2
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/125230
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
Update framebuffer's modelist after we changed it's fb_var_screeninfo.
This makes sure the framebuffer console can be inited successfully.
During framebuffer console init, it'll check whether the var info of
the framebuffer is consistent with the modelist.
Unsuccessful init of framebuffer console driver makes VT driver
doesn't work in right way.
Bug 996992
Signed-off-by: Mark Zhang <markz@nvidia.com>
Change-Id: I96a1db1f389be75dcba48b20447cf1510ad3768b
Reviewed-on: http://git-master/r/107866
Reviewed-by: Shashank Sharma <shashanks@nvidia.com>
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Added support for GCOV code coverage for GPIO
Signed-off-by: Sumit Sharma <sumsharma@nvidia.com>
Change-Id: I407433db690696644aa67dffc0de8bc03c624b54
Reviewed-on: http://git-master/r/125183
Bug 1024886
Resolved compilation error for unused code.
Signed-off-by: Nagaraja Kolur <nkolur@nvidia.com>
Change-Id: I9167d8129a9cba0fc6cb203180e07192d66db439
Reviewed-on: http://git-master/r/120581
Reviewed-by: Nagaraj Kolur <nkolur@nvidia.com>
Tested-by: Nagaraj Kolur <nkolur@nvidia.com>
Reviewed-by: Vijaya Bhaskar <vbhaskar@nvidia.com>
Reviewed-by: Wahed Syed <wsyed@nvidia.com>
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
NACK interrupt is generated before I2C controller generates the STOP
condition on bus. Because of this reset of controller is happening
before I2C controller could complete STOP condition. So wait for some
time before resetting the controller so that STOP condition has
delivered properly on bus.
Added delay of 2 clock period before resetting the controller in case of
NACK error.
Signed-off-by: Alok Chauhan <alokc@nvidia.com>
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Taken change from mainline commit.
Change-Id: Id089aae313614e58ec6da36eda4ff2d87c5cddc3
Reviewed-on: http://git-master/r/125148
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
nvhost_3dctx_alloc_common correctly checks the return value of an
allocator function, and attempts to perform cleanup. However, this
particular allocation API returns ERR_PTR values in case of failure,
which then gets passed to the deallocation function, causing a crash.
Also, the return value of that allocator API is checked with IS_ERR
in some places, and with IS_ERR_OR_NULL in others. For consistency
and avoiding surprises if the allocation implementation changes,
use IS_ERR_OR_NULL in all places.
Bug 1035878
Change-Id: I65ce97e11f9712b2e9630b38183f6e70bc14b254
Reviewed-on: http://git-master/r/124657
Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
nvhost_module_remove_client assumes that a client structure
to be freed exists in the linked list. However, if an allocation fails
in nvhost_module_add_client, no client structure is allocated, and
during cleanup, nvhost_module_remove_client would then attempt
to free an invalid pointer.
Bug 1034729
Change-Id: Ie1a641071b86f8246951e9be824a6003f14b04b6
Reviewed-on: http://git-master/r/124096
Add slew rate support for AR0832 focuser.
bug 1028733
Change-Id: I4fd0245fad7f7c820fc30a7c4bfc970d52903da6
Signed-off-by: Naren Bhat <nbhat@nvidia.com>
Reviewed-on: http://git-master/r/124695
Reviewed-by: Frank Chen <frankc@nvidia.com>
The CONFIG_PM doesn't actually enable any of the PM callbacks, it
only allows to enable CONFIG_PM_SLEEP and CONFIG_PM_RUNTIME.
This means if CONFIG_PM is used to protect system sleep callbacks
then it may end up unreferenced if only runtime PM is enabled.
Hence protecting sleep callbacks with CONFIG_PM_SLEEP.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Change-Id: I090e167c1de8f254a278e9e3b511292cfbc5f250
Reviewed-on: http://git-master/r/124872
Reviewed-by: Simone Willett <swillett@nvidia.com>
Describe the fast and div clock part of structure and prints
better error message when any failure occurs in enabling clocks.
Change-Id: I72f66b5f8cbefbe8b2c6b8c7150edff3ee2244b4
Reviewed-on: http://git-master/r/124873
Declare the iomap address to __iomem type.
Change-Id: Ic855834f6e7fd417e4c2fd0415a6195655d3ed60
Reviewed-on: http://git-master/r/124874
Tegra20 i2c controller does not support the continue transfer
which implements the I2C_M_NOSTART functionality of i2c
protocol mangling.
Removing the I2C_M_NOSTART functionality support for Tegra20.
Reviewed-by: Wolfram Sang <w.sang@pengutronix.de>
Cherry-picked from mainline
72dedc2fb12ff31cc2da977d0c40c3ac58f554cf
Change-Id: I461342749a834ff2eae056f1c6616a8d7693a32c
Reviewed-on: http://git-master/r/124875
bug 1021221
Change-Id: Ifbe007de5bdeafaa15a0b3f2a138086045eba160
Signed-off-by: Raghavendra VK <rvk@nvidia.com>
Reviewed-on: http://git-master/r/118179
(cherry picked from commit 74be8d4e7210d7bcea0d55565a7cbb06d6cc960e)
Reviewed-on: http://git-master/r/121087
Reviewed-by: Robert Morell <rmorell@nvidia.com>
do_heap_alloc locates a suitable free block from a nvmap heap given a
size and alignment. Unfortunately, if a heap block happens to be
smaller than the alignment passed to the function, an integer overflow
will occur, and a block that's too small gets accidentally returned.
Bug 1032642
Change-Id: Ic650c520409134d753e968f62f144ddeb065ccc7
Reviewed-on: http://git-master/r/123076
In rpm_suspend, when suspend fail,
before going to reschedule another autosuspend,
wake_up_all is required to avoid remote wakeup
issues.
Bug 1026169
Bug 1027598
Bug 1032565
Change-Id: Ieaf9282dae59b2cb343bf01aa2ba837a8cdc39c7
Signed-off-by: BH Hsieh <bhsieh@nvidia.com>
Reviewed-on: http://git-master/r/122978
Reviewed-by: Neil Patel <neilp@nvidia.com>
Tested-by: Neil Patel <neilp@nvidia.com>
Tested-by: Steve Lin <stlin@nvidia.com>
Reviewed-by: Steve Lin <stlin@nvidia.com>
Sometimes USB connect and disconnect events is not detected properly. The
OTG irq handler is using a workqueue which has no protection for multiple
incoming event handling.
This patch adds mutex to protect the workqueue for USB connection
handling.
BUG 968345
Change-Id: If1c6fec4231dd0dc918f7f278e0a1d7667782917
Signed-off-by: Xin Xie <xxie@nvidia.com>
Reviewed-on: http://git-master/r/122308
Reviewed-by: Rakesh Bodla <rbodla@nvidia.com>
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
Current Tegra UDC driver share same IRQ with OTG driver, and it will call
bus_resume() even if there is no UDC IRQ pending.
This patch will check UDC IRQ source and will not cause bus resume if no
IRQ pending for UDC driver.
BUG 1015685
Change-Id: Ifc5634ae5d1f7f1435c64bc527ab2e9fb8d0e36b
Reviewed-on: http://git-master/r/121896
Enable the USB charging based on the USB charging spec 1.2. Now we can
detect:
1. SDP (stanardard downstream port)
2. CDP (charging downstream port)
3. DCP (dedicated charging port)
4. None (no cable connected)
5. Non-standard charger
For some non-standard charger, we cannot detect it as DCP device.
If we find a charger detected as USB device but no EP0 packet recieved
with 1s, we then decided this is 1A charger.
bug 968345
Change-Id: I804f90ea6e4794da8f52b1c3ebd694828d99f40e
Reviewed-on: http://git-master/r/120218
Check return code for set_page_array_* calls.
Change-Id: Ie62ac78b82321939d5bd9d2a636d72dadea50d28
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/123544
Increase max packet size and clean up timing logic so we can better
recover from not getting an interrupt in time for a SOF.
Bug 1026047
Signed-off-by: Mike Lockwood <lockwood@google.com>
(cherry picked from commit 3d2096a7959d023bc31a3cf934c3d425de01c94f)
Signed-off-by: Rakesh Bodla <rbodla@nvidia.com>
Change-Id: I0a0a6f448e71e4a0c478bb44cadc54fa021e13e4
Reviewed-on: http://git-master/r/123344
This driver presents a standard USB audio class interface to the host
and an ALSA PCM device to userspace
Bug 1026047
(cherry picked from commit a23ff394752015a233dd3b27b05c9d913cbf5536)
Change-Id: I4054e09888f17d9cdfcfd4a3d430ca5cfb3fd9fa
Reviewed-on: http://git-master/r/123343
Bug 1026047
(cherry picked from commit 7a3d01af4f04950a86a18f5a439f1802d8093650)
drivers/usb/gadget/f_accessory.c
Change-Id: I30bc02a1bcf636967d56370db83578f49f0e7514
Reviewed-on: http://git-master/r/123342
The control request will be used by the host to enable/disable USB audio
and the ioctl will be used by userspace to read the audio mode
Bug 1026047
(cherry picked from commit 3e1ff6142761eef148c667e540381d1fbc437d4f)
Change-Id: I5f449de230ca8f44e2dae30a0f87772310b68f20
Reviewed-on: http://git-master/r/123341
bug 1033234
Change-Id: I67a28113fbf0a2461886658322f9106d17a69f23
Signed-off-by: Kerwin Wan <kerwinw@nvidia.com>
Reviewed-on: http://git-master/r/123301
Reviewed-by: Chandler Zhang <chazhang@nvidia.com>
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
nvmap_map_into_caller_ptr takes a memory handle from usermode
and adds a memory mapping for the handle. However, the handle
is not checked for being allocated. An unallocated handle
would cause a kernel panic later on from a NULL dereference.
Change-Id: I73987b097a0c843b913660445e8bd1b4755dac61
Reviewed-on: http://git-master/r/119689
The direction apis and irq_set_wake() support the
configuration of pins in gpio mode and hence it
is not require to export the apis for gpio_enable()/
gpio_disable().
Hiding these api.
Change-Id: I5493e4f270df85da21afb6500ac841f4fa4b522a
Reviewed-on: http://git-master/r/119616
Currently dr_controller_run() is called only during otg state
change.
When we unload a gadget driver, for example g_mass_storage
gadget driver, dr_controller_stop() is called but when it is
loaded back dr_controller_run() won't get called becasue of the
if condition failure. i.e
if (!udc->transceiver) {
dr_controller_run(udc);
So when the gadget driver is loaded for the second time
without removing the cable (i.e without otg state change),
the device won't get enumerated on the host because DR
IRQs are not enabled.
This CL fixes the above issue.
Bug 1012787
Signed-off-by: Preetham Chandru <pchandru@nvidia.com>
Change-Id: Ia127630e24dbe4c1e418163c2b858efb3baa8e45
Reviewed-on: http://git-master/r/114592
Due to issues with rcu notifiers on secureos, modifying dc flip
notifications to use a simple callback instead.
Bug 1028850
Change-Id: Iebf2a6d64d7316e3df2b88444201f9f9a29698c5
Signed-off-by: Ilan Aelion <iaelion@nvidia.com>
Reviewed-on: http://git-master/r/123103
Reviewed-by: Nitin Kumbhar <nkumbhar@nvidia.com>
When 3D register is read, and we need to do a context switch, the old
context reference is incremented, but it never gets decremented. Fix
by using nvhost_job_get_hwctx() to acquire the reference.
Bug 1031746
Change-Id: Ic72637cb2399f960e2297733bfe45e585a8ec180
Reviewed-on: http://git-master/r/123678
Reviewed-by: Arto Merilainen <amerilainen@nvidia.com>
Add support to alloc zeroed pages for user space alloc requests. Also
define a config option to force userspace allocation requests to be
zeroed.
Change-Id: I75d3b2bc36e808f1470b423578ec4cba99e0f967
Signed-off-by: Alex Waterman <alexw@nvidia.com>
Reviewed-on: http://git-master/r/122549
host1x interrupts have been left on at suspend due to using wrong
constant for the interrupt register. Disable host1x interrupts at
suspend.
Change-Id: I915fc4e663e6ad90fccacff6fb223c5080e21fcd
Reviewed-on: http://git-master/r/123055
Reviewed-by: Andrew Howe <ahowe@nvidia.com>
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
BUG 1015045
Change-Id: Id9ac783365f08787638edc057d55f29c9a0e46eb
Reviewed-on: http://git-master/r/122310
After the charging completed, TPS80031 can re-enable the charging if it
sense the voltage dropping (120mV below target). Current drive does not
handle this event and causing the charging forever stopped.
This patch will check the above re-charging happens in the charging WDT
handler, and will ack WDT in order to continue charging.
BUG 1015045
Change-Id: Ia0a53d29cd0e73e7ebcd53f8176c8ef81b6c6090
Reviewed-on: http://git-master/r/122309
Perform throughput notifications to clients on work queue rather than
synchronously to dc flip notifications.
Bug 1028850
Change-Id: Ib9446a4ab87a476230a90a1f23c260bcf98e01dc
(cherry picked from commit f48bec5168232d7a50ecfb193146a4be214af3d7)
Reviewed-on: http://git-master/r/#change,122160
Reviewed-on: http://git-master/r/123102
Lock was missing around one state set, so we add it here.
Bug 1024031
Change-Id: Iab013fff7e8519e8bcc91e84a5ca7cd6e6e783da
Signed-off-by: Matt Wagner <mwagner@nvidia.com>
Reviewed-on: http://git-master/r/122802
When tegra-otg suspends with charger cable connected, the charger
state and type should not be changed, neither should the charger
callback be executed.
SMB349 has a debounce delay of ~20ms +/- 3 after cable is unpluged
and will stop all I2C functions for 2.3ms when getting reset to POR.
Add 50ms' delay before reading charger status to avoid I2C error and
make sure we get the right charger state.
Bug 1024735
Change-Id: I1667b23df768b46b524c6578c4bee09e131d9f96
Signed-off-by: Allen Yu <alleny@nvidia.com>
Reviewed-on: http://git-master/r/120905
nvhost context related functions were in init section, even though
they are called from non-init functions.
Bug 1022681
Change-Id: Ie85e9dd3f19873aec4153e34c7bffa19f40d37fa
Reviewed-on: http://git-master/r/120884
add compilation flag to treat warnings as errors
handle error of variable declaration
bug 949219
Change-Id: Iac05d4d0e4c4cbf39a534b7aee32c0dac57ae49d
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
Reviewed-on: http://git-master/r/118027
Reviewed-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-by: Sri Krishna Chowdary <schowdary@nvidia.com>
Reviewed-by: Manoj Chourasia <mchourasia@nvidia.com>
-add compilation flag to treat warning as error
bug 949219
Change-Id: I3f7f557099b0473883e0b959b65eb8f17ed30978
Reviewed-on: http://git-master/r/118008
nvmap_pin_ids accepts a list of handles to pin, which are passed
directly from usermode when called from nvmap_ioctl_pinop.
However, if invalid handles are passed in, the function might
still access them as valid handles, and cause a crash.
Bug 1023954
Change-Id: I6b98a2ef448bb496be7d569ddd4fb516fc399cba
Reviewed-on: http://git-master/r/119667
Give ownership of the DMA buffer back to the processor first and
then free the buffer. Otherwise processor won't be able to
access the dma mapped buffers and this would lead to slab
corruption.
When the DMA buffer is freed without a call to dma_sync_single_for_cpu(),
the kernel won't be able to set the buffer as POISON FREE and when we
acquire this memory back again the kernel will start printing slab
corruption output as the memory is not set to POISON FREE
Bug 1017884
Bug 1018161
Reviewed-on: http://git-master/r/#change,122151
Signed-off-by: Preetham Chandru R <pchandru@nvidia.com>
Change-Id: I00d6cb185cd2314cccb56f968eb0a05288588c13
Reviewed-on: http://git-master/r/122390
hsic_unregister is being called multiple times
during two step enumeration process of xmm.
In failure cases when enumeration does not
complete properly, kernel panic is seen because
of extra unregister-ehci device.
Bug 1016593
Change-Id: Ibaeb20ed0dab0e906741fdfad78f7d89a3672f60
Signed-off-by: Vinayak Pane <vpane@nvidia.com>
Reviewed-on: http://git-master/r/116626
issue a warning on flip events less than 1 microsecond apart.
Bug 1027664
Bug 1028850
Reviewed-on: http://git-master/r/121810
(cherry picked from commit 6c0e907b437765fb9f7093599911b71a836d49a6)
Change-Id: Ie15256e35475d345b2ebe6ddb637ccc181fcb61e
Reviewed-on: http://git-master/r/122326
Reviewed-by: Donghan Ryu <dryu@nvidia.com>
Tested-by: Donghan Ryu <dryu@nvidia.com>
Invalidate the FDC before submitting the context
save pushbuffer to ensure cache coherency across
both GPU cores.
Bug 1020291
Reviewed-on: http://git-master/r/121945
(cherry picked from commit cef956d07ec717f4714f5101805bbe2f0f149e71)
Change-Id: I43ffee6a77122b4f2fe17f063dc6756c501e59c7
Reviewed-on: http://git-master/r/122323
usb_put_hcd calls hcd_release which frees up memory allocated
for hcd. As iounmap is called after usb_put_hcd and it is trying
to access hcd->regs, getting warning messages during unload of
USB. Hence fixing it.
bug 1023362
Change-Id: Ic339395edad9a76a9eeae290eff3517d2c714477
Signed-off-by: Venu Byravarasu <vbyravarasu@nvidia.com>
Reviewed-on: http://git-master/r/122088
Reviewed-by: Krishna Yarlagadda <kyarlagadda@nvidia.com>
Tested-by: Krishna Yarlagadda <kyarlagadda@nvidia.com>
Device disconnect during resume might fail if notification
clients for this device removal are not ready.
Disconnecting device after the resume is complete.
Bug 1024496
Change-Id: Ia806e177d2dd2b1b43d3fea7a4af45f0d4a93cd4
Signed-off-by: Krishna Yarlagadda <kyarlagadda@nvidia.com>
Reviewed-on: http://git-master/r/122079
Fixing the potential compilation this is
currently masked as CONFIG_USB_OTG_UTILS
is enabled.
Change-Id: Ie10e5fc252156b8b904d387d87a11136fcc3f4c1
Reviewed-on: http://git-master/r/122043
