path: root/drivers
2011-05-25vmscan: change shrinker API by passing shrink_control structYing Han
Change each shrinker's API by consolidating the existing parameters into shrink_control struct. This will simplify any further features added w/o touching each file of shrinker. [akpm@linux-foundation.org: fix build] [akpm@linux-foundation.org: fix warning] [kosaki.motohiro@jp.fujitsu.com: fix up new shrinker API] [akpm@linux-foundation.org: fix xfs warning] [akpm@linux-foundation.org: update gfs2] Signed-off-by: Ying Han <yinghan@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Minchan Kim <minchan.kim@gmail.com> Acked-by: Pavel Emelyanov <xemul@openvz.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Acked-by: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: per-node vmstat: show proper vmstatsKOSAKI Motohiro
commit 2ac390370a ("writeback: add /sys/devices/system/node/<node>/vmstat") added vmstat entry. But strangely it only show nr_written and nr_dirtied. # cat /sys/devices/system/node/node20/vmstat nr_written 0 nr_dirtied 0 Of course, It's not adequate. With this patch, the vmstat show all vm stastics as /proc/vmstat. # cat /sys/devices/system/node/node0/vmstat nr_free_pages 899224 nr_inactive_anon 201 nr_active_anon 17380 nr_inactive_file 31572 nr_active_file 28277 nr_unevictable 0 nr_mlock 0 nr_anon_pages 17321 nr_mapped 8640 nr_file_pages 60107 nr_dirty 33 nr_writeback 0 nr_slab_reclaimable 6850 nr_slab_unreclaimable 7604 nr_page_table_pages 3105 nr_kernel_stack 175 nr_unstable 0 nr_bounce 0 nr_vmscan_write 0 nr_writeback_temp 0 nr_isolated_anon 0 nr_isolated_file 0 nr_shmem 260 nr_dirtied 1050 nr_written 938 numa_hit 962872 numa_miss 0 numa_foreign 0 numa_interleave 8617 numa_local 962872 numa_other 0 nr_anon_transparent_hugepages 0 [akpm@linux-foundation.org: no externs in .c files] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Michael Rubin <mrubin@google.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Acked-by: David Rientjes <rientjes@google.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25arch, mm: filter disallowed nodes from arch specific show_mem functionsDavid Rientjes
Architectures that implement their own show_mem() function did not pass the filter argument to show_free_areas() to appropriately avoid emitting the state of nodes that are disallowed in the current context. This patch now passes the filter argument to show_free_areas() so those nodes are now avoided. This patch also removes the show_free_areas() wrapper around __show_free_areas() and converts existing callers to pass an empty filter. ia64 emits additional information for each node, so skip_free_areas_zone() must be made global to filter disallowed nodes and it is converted to use a nid argument rather than a zone for this use case. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Helge Deller <deller@gmx.de> Cc: James Bottomley <jejb@parisc-linux.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25drivers/video/backlight/adp5520_bl.c: check strict_strtoul() return valueLiu Yuan
It should check if strict_strtoul() succeeds. [akpm@linux-foundation.org: don't override strict_strtoul() return value] Signed-off-by: Liu Yuan <tailai.ly@taobao.com> Acked-by: Michael Hennerich <michael.hennerich@analog.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-24Merge branch 'for-linus/2640/i2c' of git://git.fluff.org/bjdooks/linuxLinus Torvalds
* 'for-linus/2640/i2c' of git://git.fluff.org/bjdooks/linux: (21 commits) mach-ux500: set proper I2C platform data from MOP500s i2c-nomadik: break out single messsage transmission i2c-nomadik: reset the hw after status check i2c-nomadik: remove the unnecessary delay i2c-nomadik: change the TX and RX threshold i2c-nomadik: add code to retry on timeout failure i2c-nomadik: use pm_runtime API i2c-nomadik: print abort cause only on abort tag i2c-nomadik: correct adapter timeout initialization i2c-nomadik: remove the redundant error message i2c-nomadik: corrrect returned error numbers i2c-nomadik: fix speed enumerator i2c-nomadik: make i2c timeout specific per i2c bus i2c-nomadik: add regulator support i2c: i2c-sh_mobile bus speed platform data V2 i2c: i2c-sh_mobile clock string removal i2c-eg20t: Support new device ML7223 IOH i2c: tegra: Add de-bounce cycles. i2c: tegra: fix repeated start handling i2c: tegra: recover from spurious interrupt storm ...
2011-05-25Merge branches 'for-2639/i2c-eg20t', 'for-2639/i2c-shmobile', ↵Ben Dooks
'for-2639/i2c-tegra' and 'for-2639/i2c-nomadik2' into for-linus/2640/i2c
2011-05-25i2c-nomadik: break out single messsage transmissionLinus Walleij
Reduce code size in the message transfer function by factoring out a single-message transfer function. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-05-25i2c-nomadik: reset the hw after status checkVirupax Sadashivpetimath
In case of I2C timeout, reset the HW only after the HW status is read, otherwise the staus will be lost. Signed-off-by: Virupax Sadashivpetimath <virupax.sadashivpetimath@stericsson.com> Reviewed-by: Jonas Aberg <jonas.aberg@stericsson.com> Reviewed-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-05-25i2c-nomadik: remove the unnecessary delayVirupax Sadashivpetimath
The delay in the driver seems to be not needed, so remove it. Signed-off-by: Virupax Sadashivpetimath <virupax.sadashivpetimath@stericsson.com> Reviewed-by: Markus Grape <markus.grape@stericsson.com> Tested-by: Per Persson <per.xb.persson@stericsson.com> Tested-by: Chethan Krishna N <chethan.krishna@stericsson.com> Reviewed-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-05-25i2c-nomadik: change the TX and RX thresholdVirupax Sadashivpetimath
1) Increase RX FIFO threshold so that there is a reduction in the number of interrupts handled to complete a transaction. 2) Fill TX FIFO in the write function. Signed-off-by: Virupax Sadashivpetimath <virupax.sadashivpetimath@stericsson.com> Reviewed-by: Jonas Aberg <jonas.aberg@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-05-25i2c-nomadik: add code to retry on timeout failureVirupax Sadashivpetimath
It is seen that i2c-nomadik controller randomly stops generating the interrupts leading to a i2c timeout. As a workaround to this problem, add retries to the on going transfer on failure. Signed-off-by: Virupax Sadashivpetimath <virupax.sadashivpetimath@stericsson.com> Reviewed-by: Jonas ABERG <jonas.aberg@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-05-25i2c-nomadik: use pm_runtime APIRabin Vincent
Use the pm_runtime API for pins control. Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Reviewed-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Reviewed-by: Jonas Aberg <jonas.aberg@stericsson.com> [deleted some surplus runtime PM code] Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-05-25i2c-nomadik: print abort cause only on abort tagVirupax Sadashivpetimath
Modify the code to: 1)Print the cause of i2c failure only if the status is set to ABORT. 2)Print slave address on send/receive fail, will help in which slave failed. Signed-off-by: Virupax Sadashivpetimath <virupax.sadashivpetimath@stericsson.com> Reviewed-by: Jonas Aberg <jonas.aberg@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-05-25i2c-nomadik: correct adapter timeout initializationVirupax Sadashivpetimath
Correct the incorrect initialization of adapter timeout not to be in milliseconds, as it needs to be done in jiffies. Signed-off-by: Virupax Sadashivpetimath <virupax.sadashivpetimath@stericsson.com> Reviewed-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-05-25i2c-nomadik: remove the redundant error messagesrinidhi kasagar
The abort cause string itself is an error, so remove the redundant explicit error message. Signed-off-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Reviewed-by: Jonas Aberg <jonas.aberg@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-05-25i2c-nomadik: corrrect returned error numbersVirupax Sadashivpetimath
The code was returning bad error numbers or just -1 in some cases. Signed-off-by: Virupax Sadashivpetimath <virupax.sadashivpetimath@stericsson.com> Reviewed-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-05-25i2c-nomadik: make i2c timeout specific per i2c busVirupax Sadashivpetimath
Add option to have different i2c timeout delay for different i2c buses specified in platform data. Default to the old value unless specified. Signed-off-by: Virupax Sadashivpetimath <virupax.sadashivpetimath@stericsson.com> Reviewed-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-05-25i2c-nomadik: add regulator supportJonas Aberg
This on-chip I2C controller needs to fetch the regulator representing its voltage domain so that it won't be switched off. Signed-off-by: Jonas Aberg <jonas.aberg@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-05-24Merge branch 'i2c-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: i2c-parport: Various cleanups i2c-i801: Don't depend on other kernel driver config options i2c-i801: Check for vendor Fujitsu before probing for apanel i2c-i801: Don't probe for slaves on IDF channels i2c-i801: SMBus patch for Intel Panther Point DeviceIDs i2c/writing-clients: Fix foo_driver.id_table
2011-05-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: pcmcia: Make struct pcmcia_device_id const, sound drivers edition staging: pcmcia: Convert pcmcia_device_id declarations to const pcmcia: Convert pcmcia_device_id declarations to const pcmcia: Make declaration and uses of struct pcmcia_device_id const pcmcia/sa1100: put sa11x0_pcmcia_hw_init[] to .devinit.data
2011-05-24Merge branch 'drm-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (169 commits) drivers/gpu/drm/radeon/atom.c: fix warning drm/radeon/kms: bump kms version number drm/radeon/kms: properly set num banks for fusion asics drm/radeon/kms/atom: move dig phy init out of modesetting drm/radeon/kms/cayman: fix typo in register mask drm/radeon/kms: fix typo in spread spectrum code drm/radeon/kms: fix tile_config value reported to userspace on cayman. drm/radeon/kms: fix incorrect comparison in cayman setup code. drm/radeon/kms: add wait idle ioctl for eg->cayman drm/radeon/cayman: setup hdp to invalidate and flush when asked drm/radeon/evergreen/btc/fusion: setup hdp to invalidate and flush when asked agp/uninorth: Fix lockups with radeon KMS and >1x. drm/radeon/kms: the SS_Id field in the LCD table if for LVDS only drm/radeon/kms: properly set the CLK_REF bit for DCE3 devices drm/radeon/kms: fixup eDP connector handling drm/radeon/kms: bail early for eDP in hotplug callback drm/radeon/kms: simplify hotplug handler logic drm/radeon/kms: rewrite DP handling drm/radeon/kms/atom: add support for setting DP panel mode drm/radeon/kms: atombios.h updates for DP panel mode ...
2011-05-24Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: (29 commits) [S390] cpu hotplug: fix external interrupt subclass mask handling [S390] oprofile: dont access lowcore [S390] oprofile: add missing irq stats counter [S390] Ignore sendmmsg system call note wired up warning [S390] s390,oprofile: fix compile error for !CONFIG_SMP [S390] s390,oprofile: fix alert counter increment [S390] Remove unused includes in process.c [S390] get CPC image name [S390] sclp: event buffer dissection [S390] chsc: process channel-path-availability information [S390] refactor page table functions for better pgste support [S390] merge page_test_dirty and page_clear_dirty [S390] qdio: prevent compile warning [S390] sclp: remove unnecessary sendmask check [S390] convert old cpumask API into new one [S390] pfault: cleanup code [S390] pfault: cpu hotplug vs missing completion interrupts [S390] smp: add __noreturn attribute to cpu_die() [S390] percpu: implement arch specific irqsafe_cpu_ops [S390] vdso: disable gcov profiling ...
2011-05-24i2c-parport: Various cleanupsJean Delvare
* Fix white space. * Rename labels to something meaningful. * Prefix defines with PORT_ to avoid collision with macros from <linux/parport.h>. * Add const markers where possible. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-05-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (40 commits) Input: ADP5589 - new driver for I2C Keypad Decoder and I/O Expander Input: tsc2007 - add X, Y and Z fuzz factors to platform data Input: tsc2007 - add poll_period parameter to platform data Input: tsc2007 - add poll_delay parameter to platform data Input: tsc2007 - add max_rt parameter to platform data Input: tsc2007 - debounce pressure measurement Input: ad714x - fix captouch wheel option algorithm Input: ad714x - allow platform code to specify irqflags Input: ad714x - fix threshold and completion interrupt masks Input: ad714x - fix up input configuration Input: elantech - remove support for proprietary X driver Input: elantech - report multitouch with proper ABS_MT messages Input: elantech - export pressure and width when supported Input: elantech - describe further the protocol Input: atmel_tsadcc - correct call to input_free_device Input: add driver FSL MPR121 capacitive touch sensor Input: remove useless synchronize_rcu() calls Input: ads7846 - fix gpio_pendown configuration Input: ads7846 - add possibility to use external vref on ads7846 Input: rotary-encoder - add support for half-period encoders ...
2011-05-24i2c-i801: Don't depend on other kernel driver config optionsJean Delvare
Don't let other driver config options influence us, as it makes the code more complex and fragile for a small benefit. There's nothing wrong with instantiating I2C devices even if they don't have a driver. And we're talking about 835 extra bytes in the binary on x86-64, that's hardly worth arguing about. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: David Woodhouse <david.woodhouse@intel.com> Cc: Hans de Goede <hdegoede@redhat.com>
2011-05-24i2c-i801: Check for vendor Fujitsu before probing for apanelJean Delvare
Scanning the BIOS memory for the apanel information is costly, so avoid doing it on non-Fujitsu machines. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-05-24i2c-i801: Don't probe for slaves on IDF channelsJean Delvare
I don't know if Fujitsu is ever going to produce Patsburg-based machines, but if they do, I'd rather not probe the secondary (IDF) SMBus channels. At least not until we have a good reason for doing so. On a side note, I'm not even sure if it is right to enable detection of HWMON and DDC devices on the IDF channels. Time will tell... Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Hans de Goede <hdegoede@redhat.com> Acked-by: David Woodhouse <David.Woodhouse@intel.com>
2011-05-24i2c-i801: SMBus patch for Intel Panther Point DeviceIDsSeth Heasley
This patch adds the SMBus controller DeviceID for the Intel Panther Point PCH. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-05-24Merge branch 'linux-next' of git://git.infradead.org/ubi-2.6Linus Torvalds
* 'linux-next' of git://git.infradead.org/ubi-2.6: UBI: switch to dynamic printks UBI: turn some macros into static inline UBI: improve checking in debugging prints UBI: fix typo in a message UBI: fix minor stylistic issues UBI: use __packed instead of __attribute__((packed)) UBI: cleanup comments around volume properties UBI: re-name set volume properties ioctl UBI: make the control character device non-seekable
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu: (22 commits) m68knommu: Use generic show_interrupts() coldfire_qspi compile fix m68k: merge the mmu and non-mmu versions of sys_m68k.c m68knommu: use asm-generic/bitops/ext2-atomic.h m68knommu: Remove obsolete #include <linux/sys.h> m68k: merge mmu and non-mmu versions of asm-offsets.c m68k: merge non-mmu and mmu versions of m68k_ksyms.c m68knommu: remove un-needed exporting of COLDFIRE symbols m68knommu: move EXPORT of kernel_thread to function definition m68knommu: move EXPORT of local checksumming functions to definitions m68knommu: move EXPORT of dump_fpu to function definition m68knommu: clean up mm/init_no.c m68k: merge the mmu and non-mmu mm/Makefile m68k: mv kmap_mm.c to kmap.c m68knommu: remove stubs for __ioremap() and iounmap() m68knommu: remove unused kernel_set_cachemode() m68k: let Makefile sort out compiling mmu and non-mmu lib/checksum.c m68k: remove duplicate memcpy() implementation m68k: remove duplicate memset() implementation m68k: remove duplicate memmove() implementation ...
2011-05-24Merge branch 'next' into for-linusDmitry Torokhov
2011-05-24coldfire_qspi compile fixSteven King
The m68k/m68knommu merge broke the qspi build. Signed-off-by: Steven King <sfking@fdwdc.com> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-05-23Merge branch 'sh-latest' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6 * 'sh-latest' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (23 commits) sh: Ignore R_SH_NONE module relocations. SH: SE7751: Fix pcibios_map_platform_irq prototype. sh: remove warning and warning_symbol from struct stacktrace_ops sh: wire up sys_sendmmsg. clocksource: sh_tmu: Runtime PM support clocksource: sh_tmu: __clocksource_updatefreq_hz() update clocksource: sh_cmt: Runtime PM support clocksource: sh_cmt: __clocksource_updatefreq_hz() update dmaengine: shdma: synchronize RCU before freeing, simplify spinlock dmaengine: shdma: add runtime- and system-level power management dmaengine: shdma: fix locking sh: sh-sci: sh7377 and sh73a0 build fixes sh: cosmetic improvement: use an existing pointer serial: sh-sci: suspend/resume wakeup support V2 serial: sh-sci: Runtime PM support sh: select IRQ_FORCED_THREADING. sh: intc: Set virtual IRQs as nothread. sh: fixup fpu.o compile order i2c: add a module alias to the sh-mobile driver ALSA: add a module alias to the FSI driver ...
2011-05-23Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (247 commits) [media] gspca - sunplus: Fix some warnings and simplify code [media] gspca: Fix some warnings tied to 'no debug' [media] gspca: Unset debug by default [media] gspca - cpia1: Remove a bad conditional compilation instruction [media] gspca - main: Remove USB traces [media] gspca - main: Version change to 2.13 [media] gspca - stk014 / t613: Accept the index 0 in querymenu [media] gspca - kinect: Remove __devinitdata [media] gspca - cpia1: Fix some warnings [media] video/Kconfig: Fix mis-classified devices [media] support for medion dvb stick 1660:1921 [media] tm6000: fix uninitialized field, change prink to dprintk [media] cx231xx: Add support for Iconbit U100 [media] saa7134 add new TV cards [media] Use a more consistent value for RC repeat period [media] cx18: Move spinlock and vb_type initialisation into stream_init [media] tm6000: remove tm6010 sif audio start and stop [media] tm6000: remove unused exports [media] tm6000: add pts logging [media] tm6000: change from ioctl to unlocked_ioctl ...
2011-05-23hwmon: (coretemp) Add comments describing the handling of HT CPUsGuenter Roeck
The coretemp driver provides a single set of device attributes for each physical core of a HT CPU to avoid duplicate sensors. This functionality was introduced with commit d883b9f09772 ("hwmon: (coretemp) Skip duplicate CPU entries"). Commit e40cc4bdfd4b ("x86/hwmon: register alternate sibling upon CPU removal") extends this functionality to register the HT sibling of a CPU which is taken offline, to ensure that sensor attributes are provided if at least one HT sibling of a core is online. Add comments into the code describing the functionality in some more detail. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Durgadoss R <durgadoss.r@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-24drivers/gpu/drm/radeon/atom.c: fix warningAndrew Morton
udelay() doesn't like 8-bit arguments: drivers/gpu/drm/radeon/atom.c: In function 'atom_op_delay': drivers/gpu/drm/radeon/atom.c:653: warning: comparison is always false due to limited range of data type while we're there, use msleep() rather than open-coding it. Cc: David Airlie <airlied@linux.ie> Reviewed-by: Alex Deucher <alexdeucher@gmail.com> Cc: Matt Turner <mattst88@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-05-24drm/radeon/kms: bump kms version numberAlex Deucher
- proper bank size for fusion for 2D tiling. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-05-24drm/radeon/kms: properly set num banks for fusion asicsAlex Deucher
Needed by userspace for 2D tiled buffer alignment Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-05-24drm/radeon/kms/atom: move dig phy init out of modesettingAlex Deucher
It only needs to be called once at startup, not for every modeset. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-05-24drm/radeon/kms/cayman: fix typo in register maskAlex Deucher
Noticed by Droste on IRC. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-05-24drm/radeon/kms: fix typo in spread spectrum codeAlex Deucher
2011-05-23Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (27 commits) PCI: Don't use dmi_name_in_vendors in quirk PCI: remove unused AER functions PCI/sysfs: move bus cpuaffinity to class dev_attrs PCI: add rescan to /sys/.../pci_bus/.../ PCI: update bridge resources to get more big ranges when allocating space (again) KVM: Use pci_store/load_saved_state() around VM device usage PCI: Add interfaces to store and load the device saved state PCI: Track the size of each saved capability data area PCI/e1000e: Add and use pci_disable_link_state_locked() x86/PCI: derive pcibios_last_bus from ACPI MCFG PCI: add latency tolerance reporting enable/disable support PCI: add OBFF enable/disable support PCI: add ID-based ordering enable/disable support PCI hotplug: acpiphp: assume device is in state D0 after powering on a slot. PCI: Set PCIE maxpayload for card during hotplug insertion PCI/ACPI: Report _OSC control mask returned on failure to get control x86/PCI: irq and pci_ids patch for Intel Panther Point DeviceIDs PCI: handle positive error codes PCI: check pci_vpd_pci22_wait() return PCI: Use ICH6_GPIO_EN in ich6_lpc_acpi_gpio ... Fix up trivial conflicts in include/linux/pci_ids.h: commit a6e5e2be4461 moved the intel SMBUS ID definitons to the i2c-i801.c driver.
2011-05-23Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (137 commits) ARM: bcmring: convert to use sp804 clockevents ARM: bcmring: convert to sp804 clocksource ARM: 6912/1: bcmring: Add clkdev table in init_early clockevents: ARM sp804: obtain sp804 timer rate via clks clockevents: ARM sp804: allow clockevent name to be specified clocksource: ARM sp804: obtain sp804 timer rate via clks clocksource: ARM sp804: allow clocksource name to be specified clocksource: convert OMAP1 to 32-bit down counting clocksource clocksource: convert MXS timrotv2 to 32-bit down counting clocksource clocksource: convert SPEAr platforms 16-bit up counting clocksource clocksource: convert Integrator/AP 16-bit down counting clocksource clocksource: convert W90x900 24-bit down counting clocksource clocksource: convert ARM 32-bit down counting clocksources clocksource: convert ARM 32-bit up counting clocksources clocksource: add common mmio clocksource ARM: update sa1100 to reflect PXA updates ARM: omap1: convert to using readl/writel instead of volatile struct ARM: omap1: delete useless interrupt handler ARM: s5p: consolidate selection of timer register ARM: 6939/1: fix missing 'cpu_relax()' declaration ...
2011-05-23Merge branch 'staging-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6 * 'staging-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: (970 commits) staging: usbip: replace usbip_u{dbg,err,info} and printk with dev_ and pr_ staging:iio: Trivial kconfig reorganization and uniformity improvements. staging:iio:documenation partial update. staging:iio: use pollfunc allocation helpers in remaining drivers. staging:iio:max1363 misc cleanups and use of for_each_bit_set to simplify event code spitting out. staging:iio: implement an iio_info structure to take some of the constant elements out of iio_dev. staging:iio:meter:ade7758: Use private data space from iio_allocate_device staging:iio:accel:lis3l02dq make write_reg_8 take value not a pointer to value. staging:iio: ring core cleanups + check if read_last available in lis3l02dq staging:iio:core cleanup: squash tiny wrappers and use dev_set_name to handle creation of event interface name. staging:iio: poll func allocation clean up. staging:iio:ad7780 trivial unused header cleanup. staging:iio:adc: AD7780: Use private data space from iio_allocate_device + trivial fixes staging:iio:adc:AD7780: Convert to new channel registration method staging:iio:adc: AD7606: Drop dev_data in favour of iio_priv() staging:iio:adc: AD7606: Consitently use indio_dev staging:iio: Rip out helper for software rings. staging:iio:adc:AD7298: Use private data space from iio_allocate_device staging:iio: rationalization of different buffer implementation hooks. staging:iio:imu:adis16400 avoid allocating rx, tx, and state separately from iio_dev. ... Fix up trivial conflicts in - drivers/staging/intel_sst/intelmid.c: patches applied in both branches - drivers/staging/rt2860/common/cmm_data_{pci,usb}.c: removed vs spelling - drivers/staging/usbip/vhci_sysfs.c: trivial header file inclusion
2011-05-23Merge branch 'usb-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6 * 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (205 commits) USB: EHCI: Remove SPARC_LEON {read,write}_be definitions from ehci.h USB: UHCI: Support big endian GRUSBHC HC sparc: add {read,write}*_be routines USB: UHCI: Add support for big endian descriptors USB: UHCI: Use ACCESS_ONCE rather than using a full compiler barrier USB: UHCI: Add support for big endian mmio usb-storage: Correct adjust_quirks to include latest flags usb/isp1760: Fix possible unlink problems usb/isp1760: Move function isp1760_endpoint_disable() within file. USB: remove remaining usages of hcd->state from usbcore and fix regression usb: musb: ux500: add configuration and build options for ux500 dma usb: musb: ux500: add dma glue layer for ux500 usb: musb: ux500: add dma name for ux500 usb: musb: ux500: add ux500 specific code for gadget side usb: musb: fix compile error usb-storage: fix up the unusual_realtek device list USB: gadget: f_audio: Fix invalid dereference of initdata EHCI: don't rescan interrupt QHs needlessly OHCI: fix regression caused by nVidia shutdown workaround USB: OTG: msm: Free VCCCX regulator even if we can't set the voltage ...
2011-05-23Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (48 commits) serial: 8250_pci: add support for Cronyx Omega PCI multiserial board. tty/serial: Fix break handling for PORT_TEGRA tty/serial: Add explicit PORT_TEGRA type n_tracerouter and n_tracesink ldisc additions. Intel PTI implementaiton of MIPI 1149.7. Kernel documentation for the PTI feature. export kernel call get_task_comm(). tty: Remove to support serial for S5P6442 pch_phub: Support new device ML7223 8250_pci: Add support for the Digi/IBM PCIe 2-port Adapter ASoC: Update cx20442 for TTY API change pch_uart: Support new device ML7223 IOH parport: Use request_muxed_region for IT87 probe and lock tty/serial: add support for Xilinx PS UART n_gsm: Use print_hex_dump_bytes drivers/tty/moxa.c: Put correct tty value TTY: tty_io, annotate locking functions TTY: serial_core, remove superfluous set_task_state TTY: serial_core, remove invalid test Char: moxa, fix locking in moxa_write ... Fix up trivial conflicts in drivers/bluetooth/hci_ldisc.c and drivers/tty/serial/Makefile. I did the hci_ldisc thing as an evil merge, cleaning things up.
2011-05-23hwmon: (coretemp) Fix compile error if CONFIG_SMP is not definedGuenter Roeck
cpu_sibling_mask() is not defined unless CONFIG_SMP is defined, so it must not be used directly in the code without ifdef protection. To solve the problem and avoid ifdefs in the code, define for_each_sibling() and use it instead. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Durgadoss R <durgadoss.r@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-23Merge branch 'devel-stable' into for-linusRussell King
Conflicts: arch/arm/Kconfig arch/arm/mach-ns9xxx/include/mach/uncompress.h
2011-05-23Merge branches 'consolidate', 'ep93xx', 'fixes', 'misc', 'mmci', 'remove' ↵Russell King
and 'spear' into for-linus
2011-05-23Merge branches 'consolidate-clksrc', 'consolidate-flash', ↵Russell King
'consolidate-generic', 'consolidate-smp', 'consolidate-stmp' and 'consolidate-zones' into consolidate
