path: root/drivers
2013-01-04drm/radeon: fix DMA CS parser for r6xx linear copy packetAlex Deucher
Was using the r7xx format. Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2013-01-04drm/radeon: split r6xx and r7xx copy_dma functionsAlex Deucher
- r6xx actually uses a slightly different packet format, although both formats seem to work ok. - r7xx doesn't have the count multiple of 2 limitation. Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2013-01-04drm/nouveau: fix init with agpgart-uninorthAaro Koskinen
Check that the AGP aperture can be mapped. This follows a similar change done for Radeon (commit 365048ff, drm/radeon: AGP memory is only I/O if the aperture can be mapped by the CPU.). The patch fixes the following error seen on G5 iMac: nouveau E[ DRM] failed to create kernel channel, -12 Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=58806 Cc: stable@vger.kernel.org Reviewed-by: Michel Dänzer <michel@daenzer.net> Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-01-04drm: nouveau: Fix build warning seen if HWMON is undefinedGuenter Roeck
Fix: nouveau_pm.c: In function ‘nouveau_hwmon_init’: nouveau_pm.c:703:24: warning: unused variable ‘therm’ [-Wunused-variable] Introduced by commit 095f979a (drm/nouveau/pm: fix build with HWMON off) which fixed a build error but introduced a build warning. Cc: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-01-03drm/radeon: switch to a finer grained reset for SI (v2)Alex Deucher
No change in functionality as we currently set all the reset flags. v2: fix typo Reviewed-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2013-01-03drm/radeon: switch to a finer grained reset for cayman/TNAlex Deucher
No change in functionality as we currently set all the reset flags. Reviewed-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2013-01-03drm/radeon: switch to a finer grained reset for evergreenAlex Deucher
2013-01-03drm/radeon: switch to a finer grained reset for r6xx/7xxAlex Deucher
2013-01-03drm/radeon: add GPU reset flagsAlex Deucher
The idea here is to move to a finer grained reset. In some cases we may not need reset every block, and in other cases we may not need to re-init the entire asic. Reviewed-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2013-01-03drm/radeon: fix typo in evergreen dma fenceAlex Deucher
SRBM write packet takes DW aligned registers. Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2013-01-03drm/radeon: Properly handle DDC probe for DP bridgesNiels Ole Salscheider
DDC information can be accessed using AUX CH Fixes failure to probe monitors on some systems with DP bridge chips. agd5f: minor fixes Signed-off-by: Niels Ole Salscheider <niels_ole@salscheider-online.de> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org
2013-01-03drm/radeon: reset dma engine on gpu reset (v2)Jerome Glisse
This try to reset the dma engine when performing gpu reset. Hopefully bringing back the gpu dma engine in sane state. v2: agd5f: fix dma reset on cayman/TN, add support for SI Signed-off-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2013-01-03drm/radeon: print dma status reg on lockup (v2)Jerome Glisse
To help debug dma related lockup. v2: agd5f: update SI as well Signed-off-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2013-01-03drm/radeon: improve ring debugfs printingJerome Glisse
Print 32dword before last know rptr as problem most likely comes from previous command. Also small cosmetic change to the printing. Signed-off-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2013-01-03drm/radeon: add debugfs file for dma ringsJerome Glisse
2013-01-03drm/radeon/r6xx: fix DMA engine for ttm bo transfersAlex Deucher
count must be a multiple of 2. Fixes crashes on R6xx chips reported by a number of people. Cc: Borislav Petkov <bp@alien8.de> Cc: Markus Trippelsdorf <markus@trippelsdorf.de> Reviewed-by: Jerome Glisse <jglisse@redhat.com> Tested-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2013-01-03drm/radeon: add connector table for Mac G4 SilverAlex Deucher
Apple cards do not provide data tables in the vbios so we have to hard code the connector parameters in the driver. Reported-by: Albrecht Dreß <albrecht.dress@arcor.de> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org
2012-12-30Revert "drm: tegra: protect DC register access with mutex"Dave Airlie
This reverts commit 83c0bcb694be31dcd6c04bdd935b96a95a0af548. Lucas pointed out this was a mistake, and I missed the discussion, so just revert it out to save a rebase. Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-12-30drm: tegra: program only one window during modesetLucas Stach
The intention is to program exactly WIN_A, not WIN_A and possibly others. Signed-off-by: Lucas Stach <dev@lynxeye.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-12-30drm: tegra: clean out old gem prototypesLucas Stach
There is no gem.c anymore, those functions are implemented by the drm_cma_helpers now. Signed-off-by: Lucas Stach <dev@lynxeye.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-12-30drm: tegra: remove redundant tegra2_tmds_config entryLucas Stach
The 720p and 1080p entries are completely redundant, as we are matching the table entries against <=pclk. Also generalize the comment, as we are using those table entries even when driving other modes than the standard TV ones. Signed-off-by: Lucas Stach <dev@lynxeye.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-12-30drm: tegra: protect DC register access with mutexLucas Stach
Window properties are programmed through a shared aperture and have to happen atomically. Also we do the read-update-write dance on some of the shared regs. To make sure that different functions don't stumble over each other protect the register access with a mutex. Signed-off-by: Lucas Stach <dev@lynxeye.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-12-30drm: tegra: don't leave clients host1x member uninitializedLucas Stach
No real problem for now, as nothing is using this, but leaving it unitialized is asking for trouble later on. Signed-off-by: Lucas Stach <dev@lynxeye.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-12-30drm: tegra: fix front_porch <-> back_porch mixupLucas Stach
Fixes wrong picture offset observed when using HDMI output with a Technisat HD TV. Signed-off-by: Lucas Stach <dev@lynxeye.de> Acked-by: Mark Zhang <markz@nvidia.com> Tested-by: Mark Zhang <markz@nvidia.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-12-30Merge branch 'drm-intel-fixes' of ↵Dave Airlie
git://people.freedesktop.org/~danvet/drm-intel into drm-next Some fixes for 3.8: - Watermark fixups from Chris Wilson (4 pieces). - 2 snb workarounds, seem to be recently added to our internal DB. - workaround for the infamous i830/i845 hang, seems now finally solid! Based on Chris' fix for SNA, now also for UXA/mesa&old SNA. - Some more fixlets for shrinker-pulls-the-rug issues (Chris&me). - Fix dma-buf flags when exporting (you). - Disable the VGA plane if it's enabled on lid open - similar fix in spirit to the one I've sent you last weeek, BIOS' really like to mess with the display when closing the lid (awesome debug work from Krzysztof Mazur). * 'drm-intel-fixes' of git://people.freedesktop.org/~danvet/drm-intel: drm/i915: disable shrinker lock stealing for create_mmap_offset drm/i915: optionally disable shrinker lock stealing drm/i915: fix flags in dma buf exporting i915: ensure that VGA plane is disabled drm/i915: Preallocate the drm_mm_node prior to manipulating the GTT drm_mm manager drm: Export routines for inserting preallocated nodes into the mm manager drm/i915: don't disable disconnected outputs drm/i915: Implement workaround for broken CS tlb on i830/845 drm/i915: Implement WaSetupGtModeTdRowDispatch drm/i915: Implement WaDisableHiZPlanesWhenMSAAEnabled drm/i915: Prefer CRTC 'active' rather than 'enabled' during WM computations drm/i915: Clear self-refresh watermarks when disabled drm/i915: Double the cursor self-refresh latency on Valleyview drm/i915: Fixup cursor latency used for IVB lp3 watermarks
2012-12-30Merge branch 'drm-fixes-3.8' of git://people.freedesktop.org/~agd5f/linux ↵Dave Airlie
into drm-next Misc fixes for reset and new packets for userspace usage. * 'drm-fixes-3.8' of git://people.freedesktop.org/~agd5f/linux: drm/radeon: add WAIT_UNTIL to evergreen VM safe reg list drm/radeon: add support for MEM_WRITE packet drm/radeon: restore modeset late in GPU reset path drm/radeon: avoid deadlock in pm path when waiting for fence drm/radeon: don't leave fence blocked process on failed GPU reset
2012-12-23drm/nve0/graph: fix fuc, and enable acceleration on all known chipsetsBen Skeggs
Also adds GK106 to chipsets known by ucode. Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2012-12-23drm/nvc0/graph: fix fuc, and enable acceleration on GF119Ben Skeggs
2012-12-23drm/nouveau/bios: cache ramcfg strap on later chipsetsBen Skeggs
This fixes suspend/resume on at least Quadro 400. Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2012-12-23drm/nouveau/mxm: silence output if no bios dataBen Skeggs
2012-12-23drm/nouveau/bios: parse/display extra version componentBen Skeggs
2012-12-23drm/nouveau/bios: implement opcode 0xa9Ben Skeggs
2012-12-23drm/nouveau/bios: update gpio parsing apis to match current designBen Skeggs
2012-12-23drm/nouveau: initial support for GK106Ben Skeggs
Modesetting seems to work alright, as does graphics (using binary driver fuc from nve7...). Lots to be done no doubt, but this'll get an image on the screen for people. Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2012-12-21Merge git://www.linux-watchdog.org/linux-watchdogLinus Torvalds
Pull watchdog updates from Wim Van Sebroeck: "This includes some fixes and code improvements (like clk_prepare_enable and clk_disable_unprepare), conversion from the omap_wdt and twl4030_wdt drivers to the watchdog framework, addition of the SB8x0 chipset support and the DA9055 Watchdog driver and some OF support for the davinci_wdt driver." * git://www.linux-watchdog.org/linux-watchdog: (22 commits) watchdog: mei: avoid oops in watchdog unregister code path watchdog: Orion: Fix possible null-deference in orion_wdt_probe watchdog: sp5100_tco: Add SB8x0 chipset support watchdog: davinci_wdt: add OF support watchdog: da9052: Fix invalid free of devm_ allocated data watchdog: twl4030_wdt: Change TWL4030_MODULE_PM_RECEIVER to TWL_MODULE_PM_RECEIVER watchdog: remove depends on CONFIG_EXPERIMENTAL watchdog: Convert dev_printk(KERN_<LEVEL> to dev_<level>( watchdog: DA9055 Watchdog driver watchdog: omap_wdt: eliminate goto watchdog: omap_wdt: delete redundant platform_set_drvdata() calls watchdog: omap_wdt: convert to devm_ functions watchdog: omap_wdt: convert to new watchdog core watchdog: WatchDog Timer Driver Core: fix comment watchdog: s3c2410_wdt: use clk_prepare_enable and clk_disable_unprepare watchdog: imx2_wdt: Select the driver via ARCH_MXC watchdog: cpu5wdt.c: add missing del_timer call watchdog: hpwdt.c: Increase version string watchdog: Convert twl4030_wdt to watchdog core davinci_wdt: preparation for switch to common clock framework ...
2012-12-21Merge tag 'dm-3.8-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm Pull dm update from Alasdair G Kergon: "Miscellaneous device-mapper fixes, cleanups and performance improvements. Of particular note: - Disable broken WRITE SAME support in all targets except linear and striped. Use it when kcopyd is zeroing blocks. - Remove several mempools from targets by moving the data into the bio's new front_pad area(which dm calls 'per_bio_data'). - Fix a race in thin provisioning if discards are misused. - Prevent userspace from interfering with the ioctl parameters and use kmalloc for the data buffer if it's small instead of vmalloc. - Throttle some annoying error messages when I/O fails." * tag 'dm-3.8-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm: (36 commits) dm stripe: add WRITE SAME support dm: remove map_info dm snapshot: do not use map_context dm thin: dont use map_context dm raid1: dont use map_context dm flakey: dont use map_context dm raid1: rename read_record to bio_record dm: move target request nr to dm_target_io dm snapshot: use per_bio_data dm verity: use per_bio_data dm raid1: use per_bio_data dm: introduce per_bio_data dm kcopyd: add WRITE SAME support to dm_kcopyd_zero dm linear: add WRITE SAME support dm: add WRITE SAME support dm: prepare to support WRITE SAME dm ioctl: use kmalloc if possible dm ioctl: remove PF_MEMALLOC dm persistent data: improve improve space map block alloc failure message dm thin: use DMERR_LIMIT for errors ...
2012-12-21Merge tag 'rdma-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband Pull more infiniband changes from Roland Dreier: "Second batch of InfiniBand/RDMA changes for 3.8: - cxgb4 changes to fix lookup engine hash collisions - mlx4 changes to make flow steering usable - fix to IPoIB to avoid pinning dst reference for too long" * tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: RDMA/cxgb4: Fix bug for active and passive LE hash collision path RDMA/cxgb4: Fix LE hash collision bug for passive open connection RDMA/cxgb4: Fix LE hash collision bug for active open connection mlx4_core: Allow choosing flow steering mode mlx4_core: Adjustments to Flow Steering activation logic for SR-IOV mlx4_core: Fix error flow in the flow steering wrapper mlx4_core: Add QPN enforcement for flow steering rules set by VFs cxgb4: Add LE hash collision bug fix path in LLD driver cxgb4: Add T4 filter support IPoIB: Call skb_dst_drop() once skb is enqueued for sending
2012-12-21dm stripe: add WRITE SAME supportMike Snitzer
Rename stripe_map_discard to stripe_map_range and reuse it for WRITE SAME bio processing. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-12-21dm: remove map_infoMikulas Patocka
This patch removes map_info from bio-based device mapper targets. map_info is still used for request-based targets. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-12-21dm snapshot: do not use map_contextMikulas Patocka
Eliminate struct map_info from dm-snap. map_info->ptr was used in dm-snap to indicate if the bio was tracked. If map_info->ptr was non-NULL, the bio was linked in tracked_chunk_hash. This patch removes the use of map_info->ptr. We determine if the bio was tracked based on hlist_unhashed(&c->node). If hlist_unhashed is true, the bio is not tracked, if it is false, the bio is tracked. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-12-21dm thin: dont use map_contextMikulas Patocka
This patch removes endio_hook_pool from dm-thin and uses per-bio data instead. This patch removes any use of map_info in preparation for the next patch that removes map_info from bio-based device mapper. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-12-21dm raid1: dont use map_contextMikulas Patocka
Don't use map_info any more in dm-raid1. map_info was used for writes to hold the region number. For this purpose we add a new field dm_bio_details to dm_raid1_bio_record. map_info was used for reads to hold a pointer to dm_raid1_bio_record (if the pointer was non-NULL, bio details were saved; if the pointer was NULL, bio details were not saved). We use dm_raid1_bio_record.details->bi_bdev for this purpose. If bi_bdev is NULL, details were not saved, if bi_bdev is non-NULL, details were saved. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-12-21dm flakey: dont use map_contextMikulas Patocka
Replace map_info with a per-bio structure "struct per_bio_data" in dm-flakey. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-12-21dm raid1: rename read_record to bio_recordMikulas Patocka
Rename struct read_record to bio_record in dm-raid1. In the following patch, the structure will be used for both read and write bios, so rename it. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-12-21dm: move target request nr to dm_target_ioMikulas Patocka
This patch moves target_request_nr from map_info to dm_target_io and makes it accessible with dm_bio_get_target_request_nr. This patch is a preparation for the next patch that removes map_info. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-12-21dm snapshot: use per_bio_dataMikulas Patocka
Replace tracked_chunk_pool with per_bio_data in dm-snap. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-12-21dm verity: use per_bio_dataMikulas Patocka
Replace io_mempool with per_bio_data in dm-verity. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-12-21dm raid1: use per_bio_dataMikulas Patocka
Replace read_record_pool with per_bio_data in dm-raid1. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-12-21dm: introduce per_bio_dataMikulas Patocka
Introduce a field per_bio_data_size in struct dm_target. Targets can set this field in the constructor. If a target sets this field to a non-zero value, "per_bio_data_size" bytes of auxiliary data are allocated for each bio submitted to the target. These data can be used for any purpose by the target and help us improve performance by removing some per-target mempools. Per-bio data is accessed with dm_per_bio_data. The argument data_size must be the same as the value per_bio_data_size in dm_target. If the target has a pointer to per_bio_data, it can get a pointer to the bio with dm_bio_from_per_bio_data() function (data_size must be the same as the value passed to dm_per_bio_data). Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-12-21dm kcopyd: add WRITE SAME support to dm_kcopyd_zeroMike Snitzer
Add WRITE SAME support to dm-io and make it accessible to dm_kcopyd_zero(). dm_kcopyd_zero() provides an asynchronous interface whereas the blkdev_issue_write_same() interface is synchronous. WRITE SAME is a SCSI command that can be leveraged for more efficient zeroing of a specified logical extent of a device which supports it. Only a single zeroed logical block is transfered to the target for each WRITE SAME and the target then writes that same block across the specified extent. The dm thin target uses this. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
