commit bf5140817b2d65faac9b32fc9057a097044ac35b upstream.
On writes in MODE_RAW the mtd_oob_ops struct is not sufficiently
initialized which may cause nandwrite to fail. With this patch
it is possible to write raw nand/oob data without additional ECC
(either for testing or when some sectors need different oob layout
e.g. bootloader) like
nandwrite -n -r -o /dev/mtd0 <myfile>
Signed-off-by: Peter Wippich <pewi@gw-instruments.de>
Tested-by: Ricard Wanderlof <ricardw@axis.com>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
commit 98fb2cc115b4ef1ea0a2d87a170c183bd395dd6c upstream.
This patch fixes system hang when resuming from S3 state
and lower rate sens failure issue.
Signed-off-by: Rajkumar Manoharan <rmanohar@qca.qualcomm.com>
commit 3bf3f8b19d2bfccc40f13c456bf339fd8f535ebc upstream.
Callers to __acpi_ioremap_fast() pass the bit_width that they found in the
acpi_generic_address structure. Convert from bits to bytes when passing to
__acpi_find_iomap() - as it wants to see bytes, not bits.
Signed-off-by: Tony Luck <tony.luck@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
commit 6eb40b2af4908e9aee71e43e7a384243128c56dd upstream.
This patch fixes another bug from LUN_RESET re-org fallout in
core_tmr_drain_tmr_list() that was adding the wrong se_tmr_req
into the local drain_tmr_list to be walked + released.
Signed-off-by: Joern Engel <joern@logfs.org>
Cc: Joern Engel <joern@logfs.org>
Reviewed-by: Roland Dreier <roland@purestorage.com>
Cc: Roland Dreier <roland@purestorage.com>
commit 80ccbc8e00f7001d79dd503c2781487906b98611 upstream.
This patch fixes a bug in core_tmr_drain_tmr_list() where drain_tmr_list
was using the wrong se_tmr_req for cmd assignment due to a typo during the
LUN_RESET re-org. This was resulting in general protection faults while
using the leftover bogus *tmr_p pointer from list_for_each_entry_safe().
commit c4853efec665134b2e6fc9c13447323240980351 upstream.
The P600 requires a small delay when changing states. Otherwise we may think
the board did not reset and we bail. This for kdump only and is particular
to the P600.
Signed-off-by: Mike Miller <mike.miller@hp.com>
commit 5c62cb48602dba95159c81ffeca179d3852e25be upstream.
We did not increment the amount of sectors written to disk
b/c we tested for the == WRITE which is incorrect - as the
operations are more of WRITE_FLUSH, WRITE_ODIRECT. This patch
fixes it by doing a & WRITE check.
Reported-by: Andy Burns <xen.lists@burns.me.uk>
Suggested-by: Ian Campbell <Ian.Campbell@citrix.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 0167ac67ff6f35bf2364f7672c8012b0cd40277f upstream.
Fix for issue : While discovery is in progress, hot unplug and hot plug of
enclosure connected to the controller card is causing system to hang.
When a device is in the process of being detected at driver load time then
if it is removed, the device that is no longer present will not be added
to the list. So the code in _scsih_probe_sas() is rearranged as such so
the devices that failed to be detected are not added to the list.
Signed-off-by: Nagalakshmi Nandigama <nagalakshmi.nandigama@lsi.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit f7c9c6bb14f3104608a3a83cadea10a6943d2804 upstream.
When looking at memory consumption issues I noticed quite a
lot of memory in the kmalloc-2048 bucket:
OBJS ACTIVE USE OBJ SIZE SLABS OBJ/SLAB CACHE SIZE NAME
6561 6471 98% 2.30K 243 27 15552K kmalloc-2048
Over 15MB. slub debug shows that cfq is responsible for almost
all of it:
# sort -nr /sys/kernel/slab/kmalloc-2048/alloc_calls
6402 .cfq_init_queue+0xec/0x460 age=43423/43564/43655 pid=1 cpus=4,11,13
In scsi_alloc_sdev we do scsi_alloc_queue but if slave_alloc
fails we don't free it with scsi_free_queue.
The patch below fixes the issue:
135 72 53% 2.30K 5 27 320K kmalloc-2048
# cat /sys/kernel/slab/kmalloc-2048/alloc_calls
3 .cfq_init_queue+0xec/0x460 age=3811/3876/3925 pid=1 cpus=4,11,13
commit 3308511c93e6ad0d3c58984ecd6e5e57f96b12c8 upstream.
Make sure that SCSI device removal via scsi_remove_host() does finish
all pending SCSI commands. Currently that's not the case and hence
removal of a SCSI host during I/O can cause a deadlock. See also
"blkdev_issue_discard() hangs forever if underlying storage device is
removed" (http://bugzilla.kernel.org/show_bug.cgi?id=40472). See also
http://lkml.org/lkml/2011/8/27/6.
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
commit a18a920c70d48a8e4a2b750d8a183b3c1a4be514 upstream.
This patch validates sdev pointer in scsi_dh_activate before proceeding further.
Without this check we might see the panic as below. I have seen this
panic multiple times..
Call trace:
#0 [ffff88007d647b50] machine_kexec at ffffffff81020902
#1 [ffff88007d647ba0] crash_kexec at ffffffff810875b0
#2 [ffff88007d647c70] oops_end at ffffffff8139c650
#3 [ffff88007d647c90] __bad_area_nosemaphore at ffffffff8102dd15
#4 [ffff88007d647d50] page_fault at ffffffff8139b8cf
[exception RIP: scsi_dh_activate+0x82]
RIP: ffffffffa0041922 RSP: ffff88007d647e00 RFLAGS: 00010046
RAX: 0000000000000000 RBX: 0000000000000000 RCX: 00000000000093c5
RDX: 00000000000093c5 RSI: ffffffffa02e6640 RDI: ffff88007cc88988
RBP: 000000000000000f R8: ffff88007d646000 R9: 0000000000000000
R10: ffff880082293790 R11: 00000000ffffffff R12: ffff88007cc88988
R13: 0000000000000000 R14: 0000000000000286 R15: ffff880037b845e0
ORIG_RAX: ffffffffffffffff CS: 0010 SS: 0000
#5 [ffff88007d647e38] run_workqueue at ffffffff81060268
#6 [ffff88007d647e78] worker_thread at ffffffff81060386
#7 [ffff88007d647ee8] kthread at ffffffff81064436
#8 [ffff88007d647f48] kernel_thread at ffffffff81003fba
Signed-off-by: Babu Moger <babu.moger@netapp.com>
commit c68bf8eeaa57c852e74adcf597237be149eef830 upstream.
The call to complete() in st_scsi_execute_end() wakes up sleeping thread
in write_behind_check(), which frees the st_request, thus invalidating
the pointer to the associated bio structure, which is then passed to the
blk_rq_unmap_user(). Fix by storing pointer to bio structure into
temporary local variable.
This bug is present since at least linux-2.6.32.
Signed-off-by: Petr Uzel <petr.uzel@suse.cz>
Reported-by: Juergen Groß <juergen.gross@ts.fujitsu.com>
Acked-by: Kai Mäkisara <kai.makisara@kolumbus.fi>
commit 5a4c8666c6d576f076a7c6824589cdbb984c0f84 upstream.
This patch addresses two issues with non immediate TMR handling in
iscsit_handle_task_mgt_cmd(). The first involves breakage due to
v3.1-rc conversion of iscsit_sequence_cmd(), which upon good status
would hit the iscsit_add_reject_from_cmd() block of code. This patch
adds an explict check for CMDSN_ERROR_CANNOT_RECOVER.
The second adds a check to return when non immediate TMR operation is
detected after iscsit_ack_from_expstatsn(), as iscsit_sequence_cmd()
-> iscsit_execute_cmd() will have called transport_generic_handle_tmr()
for the non immediate TMR case already.
Cc: Andy Grover <agrover@redhat.com>
commit 7e32da55e26b80d57961681e53aa67938268db3f upstream.
This patch adds a missing CMDSN_LOWER_THAN_EXP return check for
iscsit_sequence_cmd() in iscsit_handle_scsi_cmd() that was incorrectly
dropped during the v3.1-rc cleanups to use iscsit_sequence_cmd().
commit 8cd79f24350826b81e16990d9e12bc878e67d385 upstream.
This patch addresses an issue with buggy userspace code sending I/O
via scsi-generic that does not explictly clear their associated read
buffers. It adds an explict memset of the first SGL entry within
tcm_loop_new_cmd_map() for SCF_SCSI_CONTROL_SG_IO_CDB payloads that
are currently guaranteed to be a single SGL by target-core code.
This issue is a side effect of the v3.1-rc1 merge to remove the
extra memcpy between certain control CDB types using a contigious
+ cleared buffer in target-core, and performing a memcpy into the
SGL list within tcm_loop.
It was originally mainfesting itself by udev + scsi_id + scsi-generic
not properly setting up the expected /dev/disk/by-id/ symlinks because
the INQUIRY payload was containing extra bogus data preventing the
proper NAA IEEE WWN from being parsed by userspace.
commit bfa02b0da66965caf46e441270af87edda4fea14 upstream.
Commit 2265cef2 (hwmon: (w83627ehf) Properly report PECI and AMD-SI
sensor types) results in kernel panic if data->temp_label was not
initialized.
The problem was found with chip W83627DHG-P.
Add check if data->temp->label was set before use.
Based on incomplete patch by Alexander Beregalov.
Reported-by: Alexander Beregalov <a.beregalov@gmail.com>
Tested-by: Alexander Beregalov <a.beregalov@gmail.com>
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
commit 2265cef2751b3441df91f85e0107f9f549e5b711 upstream.
When temperature sources are PECI or AMD-SI agents, it makes no sense
to report their type as diode or thermistor. Instead we must report
their digital nature.
Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
commit 2aba6cac2a84f3b80e11a680c34d55e7739b474d upstream.
The definition of TO_ATTR_NO in the non-SMP case is wrong. As the SMP
definition resolves to the correct value, just use this for both
cases.
Without this fix the temperature attributes are named temp0_* instead
of temp2_*, so libsensors won't pick them. Broken since kernel 3.0.
Tested-by: Phil Sutter <phil@nwl.cc>
Acked-by: Durgadoss R <Durgadoss.r@intel.com>
commit ab5dbebe33e0c353e8545f09c34553ac3351dad6 upstream.
to the P600.
commit b2c0a863e14676fa5760c6d828fd373288e2f64a upstream.
Originally, the runtime PM core would send an idle notification
whenever a suspend attempt failed. The idle callback routine could
then schedule a delayed suspend for some time later.
However this behavior was changed by commit
f71648d73c1650b8b4aceb3856bebbde6daa3b86 (PM / Runtime: Remove idle
notification after failing suspend). No notifications were sent, and
there was no clear mechanism to retry failed suspends.
This caused problems for the usbhid driver, because it fails
autosuspend attempts as long as a key is being held down. A companion
patch changes the PM core's behavior, but we also need to change the
USB core. In particular, this patch (as1493) updates the device's
last_busy time when an autosuspend fails, so that the PM core will
retry the autosuspend in the future when the delay time expires
again.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Tested-by: Henrik Rydberg <rydberg@euromail.se>
commit 886486b792e4f6f96d4fbe8ec5bf20811cab7d6a upstream.
autosuspend attempts as long as a key is being held down. Therefore
this patch (as1492) adds a mechanism for retrying failed
autosuspends. If the callback routine updates the last_busy field so
that the next autosuspend expiration time is in the future, the
autosuspend will automatically be rescheduled.
commit 64912e997f0fe13512e4c7b90e4f7c11cb922ab5 upstream.
Polarity needs to be set accordingly to connector status (connected
or disconnected). Set it up in hpd_init() so first hotplug works
reliably no matter what is the initial set of connector. hpd_init()
also covers resume so HPD will work correctly after resume as well.
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Cc: Jerome Glisse <j.glisse@gmail.com>
commit a18cee15ed4c8b6a35f96b7b26a46bac32e04bd9 upstream.
Allow the user to override whether MSIs are enabled
or not on supported ASICs. MSIs are disabled by default
on IGP chips as they tend not to work. However certain
IGP chips only seem to work with MSIs enabled.
I suspect this is a chipset or bios issue, but I'm not sure
what the proper fix is. This will at least make diagnosing
and working around the problem much easier.
See:
https://bugs.freedesktop.org/show_bug.cgi?id=37679
commit 01e718ec194e30b3e8eb3858c742c13649757efc upstream.
Some Dell laptops only seem to work with MSIs. This
looks like a platform/bios bug.
Fixes:
commit 00dfb8df5bf8c3afe4c0bb8361133156b06b7a2c upstream.
This should make eDP more reliable.
commit 8ab250d4484b72ccc78e34276c5ffa84c1d41303 upstream.
or disconnected). Set it up at module init so first hotplug works
Signed-off-by: Jerome Glisse <jglisse@redhat.com>
commit b362105f7f5223fa4d2e03ceeea0e51da754ccc6 upstream.
Some HP laptops only seem to work with MSIs. This
Fixes:
commit 8f6c25c59b0c895c68cae59d1b34e9a7b36971bc upstream.
This makes it easier to add quirks for certain systems.
commit 340764465aa4a586ca332e61ae64883e5ad6f183 upstream.
Since force handling rework of d0d0a225e6ad43314c9aa7ea081f76adc5098ad4
we could end up bouncing connector status btw disconnected and unknown.
When connector status change a call to output_poll_changed happen which
in turn ask again for detect but with force set.
So set the load detect flags whenever we report the connector as
connected or unknown this avoid bouncing btw disconnected and unknown.
Reviewed-by: Alex Deucher <alexdeucher@gmail.com>
Cc: Stefan Lippers-Hollmann <s.L-H@gmx.de>
commit 6fd4562178508a0949c9fdecd8558d8b10d671bd upstream.
When the link state changes, xHC will report a port status change event
and set the PORT_PLC bit, for both USB3 and USB2 root hub ports.
The PLC will be cleared by usbcore for USB3 root hub ports, but not for
USB2 ports, because they do not report USB_PORT_STAT_C_LINK_STATE in
wPortChange.
Clear it for USB2 root hub ports in handle_port_status().
Signed-off-by: Andiry Xu <andiry.xu@amd.com>
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
commit d2f52c9e585bbb1a3c164e02b8dcd0d996c67353 upstream.
Introduce xhci_test_and_clear_bit() to clear RWC bit in PORTSC register.
commit 2dc3753997f3c80ce8b950242ab9bb3fb936acfd upstream.
Some alternate interface settings have no endpoints associated with them.
This shows up in some USB webcams, particularly the Logitech HD 1080p,
which uses the uvcvideo driver. If a driver switches between two alt
settings with no endpoints, there is no need to issue a configure endpoint
command, because there is no endpoint information to update.
The only time a configure endpoint command with just the add slot flag set
makes sense is when the driver is updating hub characteristics in the slot
context. However, that code never calls xhci_check_bandwidth, so we
should be safe not issuing a command if only the slot context add flag is
set.
commit f02fe890ece7d695a5744b20525d45312382e6e4 upstream.
Scanning cannot be run during suspend or hibernation, but if
usb-stor-scan freezes another thread waiting on scanning to
complete may fail to freeze.
However, if usb-stor-scan is left freezable without ever actually
freezing then the freezer will wait on it to exit, and threads
waiting for scanning to finish will no longer be blocked. One
problem with this approach is that usb-stor-scan has a delay to
wait for devices to settle (which is currently the only point where
it can freeze). To work around this we can request that the freezer
send a fake signal when freezing, then use interruptible sleep to
wake the thread early when freezing happens.
To make this happen, the following changes are made to
usb-stor-scan:
* Use set_freezable_with_signal() instead of set_freezable() to
request a fake signal when freezing
* Use wait_event_interruptible_timeout() instead of
wait_event_freezable_timeout() to avoid freezing
Signed-off-by: Seth Forshee <seth.forshee@canonical.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 0e053fcbbbc4d945247cb32cad2767b483cb65f8 upstream.
Fixes the deadlock when inserting and removing the ds2780.
Signed-off-by: Clifton Barnes <cabarnes@indesign-llc.com>
Cc: Evgeniy Polyakov <zbr@ioremap.net>
commit 9fe678fa2feb4aaac0b4220de63e1b7f8ccebae6 upstream.
Adds a nolock function to the w1 interface to avoid locking the
mutex if needed.
commit 853eee72f74f449797f0500ea19fc1bf497428d8 upstream.
Simply creates one point to call the w1 interface.
commit 93b465c2e186d96fb90012ba0f9372eb9952e732 upstream.
Since we're using non-atomic radix tree allocations, we
should be protecting the tree using a mutex and not a
spinlock.
Non-atomic allocations and process context locking is good enough,
as the tree is manipulated only when locks are registered/
unregistered/requested/freed.
The locks themselves are still protected by spinlocks of course,
and mutexes are not involved in the locking/unlocking paths.
Signed-off-by: Juan Gutierrez <jgutierrez@ti.com>
[ohad@wizery.com: rewrite the commit log, #include mutex.h, add minor
commentary]
[ohad@wizery.com: update register/unregister parts in hwspinlock.txt]
Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
commit e0c87bd95e8dad455c23bc56513af8dcb1737e55 upstream.
Modify Ethernet addess macros to be compatible with BE/LE platforms
Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com>
Cc: Chul Kim <chul.kim@idt.com>
Cc: Kumar Gala <galak@kernel.crashing.org>
Cc: Matt Porter <mporter@kernel.crashing.org>
Cc: Li Yang <leoli@freescale.com>
[ Upstream commit f7ff19871bb4a3451e1ca2cf660bf633018cfbec ]
Ari got kernel panics using tg3 NIC, and bisected to 2669069aacc9 "tg3:
enable transmit time stamping."
This is because tigon3_dma_hwbug_workaround() might alloc a new skb and
free the original. We panic when skb_tx_timestamp() is called on freed
skb.
Reported-by: Ari Savolainen <ari.m.savolainen@gmail.com>
commit 9d898966c4a07e4a5092215b5a2829d0ef02baa2 upstream.
jsm uses a write queue that copies from uart_core circular buffer. This
copying however has some bugs, like not wrapping the head counter. Since
this write queue is also a circular buffer, the consumer function is
ready to use the uart_core circular buffer directly.
This buggy copying function was making some bytes be dropped when
transmitting to a raw tty, doing something like this.
[root@hostname ~]$ cat /dev/ttyn1 > cascardo/dump &
[1] 2658
[root@hostname ~]$ cat /proc/tty/drivers > /dev/ttyn0
/dev/tty /dev/tty 5 0 system:/dev/tty
/dev/console /dev/console 5 1 system:console
/dev/ptmx /dev/ptmx 5 2 system
/dev/vc/0 /dev/vc/0 4 0 system:vtmaster
jsm /dev/ttyn 250 0-31 serial
serial /dev/ttyS 4 64-95 serial
hvc /dev/hvc 229 0-7 system
pty_slave /dev/pts 136 0-1048575 pty:slave
pty_master /dev/ptm 128 0-1048575 pty:master
unknown /dev/tty 4 1-63 console
[root@hostname ~]$ cat cascardo/dump
/dev/vc/0 /dev/vc/0 4 0 system:vtmaste[root@hostname ~]$
This patch drops the driver write queue entirely, using the circular
buffer from uart_core only.
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@linux.vnet.ibm.com>
commit 1458d160de3f1862aeaac57447ba96e7857ac52b upstream.
Currently there is a request_mem_region(r->start, ..
followed by r->start += pdata->regs_offset;
And then in remove
r = platform_get_resource(pdev, IORESOURCE_MEM, 0);
release_mem_region(r->start, resource_size(r));
Here the offset addition is not taken care. Fix the code for the
same.
Signed-off-by: Shubhrajyoti D <shubhrajyoti@ti.com>
commit effd4d9aece9184f526e6556786a94d335e38b71 upstream.
Since the dawn of its time, iwlwifi has used
interruptible waits to wait for synchronous
commands and firmware loading.
This leads to "interesting" bugs, because it
can't actually handle the interruptions; for
example when a command sending is interrupted
it will assume the command completed fully,
and then leave it pending, which leads to all
kinds of trouble when the command finishes
later.
Since there's no easy way to gracefully deal
with interruptions, fix the driver to not use
interruptible waits.
This at least fixes the error
iwlagn 0000:02:00.0: Error: Response NULL in 'REPLY_SCAN_ABORT_CMD'
I have seen in P2P testing, but it is likely
that there are other errors caused by this.
Cc: Stanislaw Gruszka <sgruszka@redhat.com>
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
commit 7fcc7c8acf0fba44d19a713207af7e58267c1179 upstream.
This is a fairly serious bug in RAID10.
When a RAID10 array is degraded and a hot-spare is activated, the
spare does not take up the empty slot, but rather replaces the first
working device.
This is likely to make the array non-functional. It would normally
be possible to recover the data, but that would need care and is not
guaranteed.
This bug was introduced in commit
2bb77736ae5dca0a189829fbb7379d43364a9dac
which first appeared in 3.1.
Signed-off-by: NeilBrown <neilb@suse.de>
commit 9bed77ee2fb46b74782d0d9d14b92e9d07f3df6e upstream.
This device is not using the proper demod IF. Instead of using the
IF macro, it is specifying a IF frequency. This doesn't work, as xc3028
needs to load an specific SCODE for the tuner. In this case, there's
no IF table for 5 MHz.
commit bff469f4167fdabfe15294f375577d7eadbaa1bb upstream.
This patch protects the common buffer access inside the dib0700 in order
to manage concurrent access. This protection is done using mutex.
Cc: Mauro Carvalho Chehab <mchehab@redhat.com>
Cc: Florian Mickler <florian@mickler.org>
Signed-off-by: Javier Marcet <javier@marcet.info>
Signed-off-by: Olivier Grenie <olivier.grenie@dibcom.fr>
Signed-off-by: Patrick Boettcher <patrick.boettcher@dibcom.fr>
[mchehab@redhat.com: dprint requires 3 arguments. Replaced by dib_info]
commit 79fcce3230b140f7675f8529ee53fe2f9644f902 upstream.
This patch protects the I2C buffer access in order to manage concurrent
Furthermore, for the dib9000, if a pid filtering command is
received during the tuning, this pid filtering command is delayed to
avoid any concurrent access issue.
Signed-off-by: Patrick Boettcher <Patrick.Boettcher@dibcom.fr>
commit 936a3f770b8de7042d793272f008ef1bb08522e9 upstream.
This patch adds checks for minimum and maximum pitch size to prevent
invalid settings which could otherwise crash the machine. Also the
alignment is done in a slightly more readable way.
Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
commit d933990c57b498c092ceef591c7c5d69dbfe9f30 upstream.
As Laurent pointed out we must not use any information in the passed
var besides xoffset, yoffset and vmode as otherwise applications
might abuse it. Also use the aligned fix.line_length and not the
(possible) unaligned xres_virtual.
Reported-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
commit 4a47a0e09c504e3ce0ccdb405411aefc5b09deb8 upstream.
Following on Herton's patch "fb: avoid possible deadlock caused by
fb_set_suspend" which moves lock_fb_info() out of fb_set_suspend()
to its callers, correct sh-mobile's locking around call to
fb_set_suspend() and the same sort of deaklocks with console_lock()
due to order of taking the lock.
console_lock() must be taken while fb_info is already locked and fb_info
must be locked while calling fb_set_suspend().
Signed-off-by: Bruno Prémont <bonbons@linux-vserver.org>
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
commit 9e769ff3f585db8f978f9113be83d36c7e3965dd upstream.
A lock ordering issue can cause deadlocks: in framebuffer/console code,
all needed struct fb_info locks are taken before acquire_console_sem(),
in places which need to take console semaphore.
But fb_set_suspend is always called with console semaphore held, and
inside it we call lock_fb_info which gets the fb_info lock, inverse
locking order of what the rest of the code does. This causes a real
deadlock issue, when we write to state fb sysfs attribute (which calls
fb_set_suspend) while a framebuffer is being unregistered by
remove_conflicting_framebuffers, as can be shown by following show
blocked state trace on a test program which loads i915 and runs another
forked processes writing to state attribute:
Test process with semaphore held and trying to get fb_info lock:
fb-test2 D 0000000000000000 0 237 228 0x00000000
ffff8800774f3d68 0000000000000082 00000000000135c0 00000000000135c0
ffff880000000000 ffff8800774f3fd8 ffff8800774f3fd8 ffff880076ee4530
00000000000135c0 ffff8800774f3fd8 ffff8800774f2000 00000000000135c0
Call Trace:
[<ffffffff8141287a>] __mutex_lock_slowpath+0x11a/0x1e0
[<ffffffff814142f2>] ? _raw_spin_lock_irq+0x22/0x40
[<ffffffff814123d3>] mutex_lock+0x23/0x50
[<ffffffff8125dfc5>] lock_fb_info+0x25/0x60
[<ffffffff8125e3f0>] fb_set_suspend+0x20/0x80
[<ffffffff81263e2f>] store_fbstate+0x4f/0x70
[<ffffffff812e7f70>] dev_attr_store+0x20/0x30
[<ffffffff811c46b4>] sysfs_write_file+0xd4/0x160
[<ffffffff81155a26>] vfs_write+0xc6/0x190
[<ffffffff81155d51>] sys_write+0x51/0x90
[<ffffffff8100c012>] system_call_fastpath+0x16/0x1b
modprobe process stalled because has the fb_info lock (got inside
unregister_framebuffer) but waiting for the semaphore held by the
test process which is waiting to get the fb_info lock:
modprobe D 0000000000000000 0 230 218 0x00000000
ffff880077a4d618 0000000000000082 0000000000000001 0000000000000001
ffff880000000000 ffff880077a4dfd8 ffff880077a4dfd8 ffff8800775a2e20
00000000000135c0 ffff880077a4dfd8 ffff880077a4c000 00000000000135c0
Call Trace:
[<ffffffff81411fe5>] schedule_timeout+0x215/0x310
[<ffffffff81058051>] ? get_parent_ip+0x11/0x50
[<ffffffff814130dd>] __down+0x6d/0xb0
[<ffffffff81089f71>] down+0x41/0x50
[<ffffffff810629ac>] acquire_console_sem+0x2c/0x50
[<ffffffff812ca53d>] unbind_con_driver+0xad/0x2d0
[<ffffffff8126f5f7>] fbcon_event_notify+0x457/0x890
[<ffffffff814144ff>] ? _raw_spin_unlock_irqrestore+0x1f/0x50
[<ffffffff8141836d>] notifier_call_chain+0x4d/0x70
[<ffffffff8108a3b8>] __blocking_notifier_call_chain+0x58/0x80
[<ffffffff8108a3f6>] blocking_notifier_call_chain+0x16/0x20
[<ffffffff8125dabb>] fb_notifier_call_chain+0x1b/0x20
[<ffffffff8125e6ac>] unregister_framebuffer+0x7c/0x130
[<ffffffff8125e8b3>] remove_conflicting_framebuffers+0x153/0x180
[<ffffffff8125eef3>] register_framebuffer+0x93/0x2c0
[<ffffffffa0331112>] drm_fb_helper_single_fb_probe+0x252/0x2f0 [drm_kms_helper]
[<ffffffffa03314a3>] drm_fb_helper_initial_config+0x2f3/0x6d0 [drm_kms_helper]
[<ffffffffa03318dd>] ? drm_fb_helper_single_add_all_connectors+0x5d/0x1c0 [drm_kms_helper]
[<ffffffffa037b588>] intel_fbdev_init+0xa8/0x160 [i915]
[<ffffffffa0343d74>] i915_driver_load+0x854/0x12b0 [i915]
[<ffffffffa02f0e7e>] drm_get_pci_dev+0x19e/0x360 [drm]
[<ffffffff8141821d>] ? sub_preempt_count+0x9d/0xd0
[<ffffffffa0386f91>] i915_pci_probe+0x15/0x17 [i915]
[<ffffffff8124481f>] local_pci_probe+0x5f/0xd0
[<ffffffff81244f89>] pci_device_probe+0x119/0x120
[<ffffffff812eccaa>] ? driver_sysfs_add+0x7a/0xb0
[<ffffffff812ed003>] driver_probe_device+0xa3/0x290
[<ffffffff812ed1f0>] ? __driver_attach+0x0/0xb0
[<ffffffff812ed29b>] __driver_attach+0xab/0xb0
[<ffffffff812ebd3e>] bus_for_each_dev+0x5e/0x90
[<ffffffff812ecc2e>] driver_attach+0x1e/0x20
[<ffffffff812ec6f2>] bus_add_driver+0xe2/0x320
[<ffffffffa03aa000>] ? i915_init+0x0/0x96 [i915]
[<ffffffff812ed536>] driver_register+0x76/0x140
[<ffffffff81245216>] __pci_register_driver+0x56/0xd0
[<ffffffffa02f1264>] drm_pci_init+0xe4/0xf0 [drm]
[<ffffffffa02e84a8>] drm_init+0x58/0x70 [drm]
[<ffffffffa03aa094>] i915_init+0x94/0x96 [i915]
[<ffffffff81002194>] do_one_initcall+0x44/0x190
[<ffffffff810a066b>] sys_init_module+0xcb/0x210
fb-test2 which reproduces above is available on kernel.org bug #26232.
To solve this issue, avoid calling lock_fb_info inside fb_set_suspend,
and move it out to where needed (callers of fb_set_suspend must call
lock_fb_info before if needed). So far, the only place which needs to
call lock_fb_info is store_fbstate, all other places which calls
fb_set_suspend are suspend/resume hooks that should not need the lock as
they should be run only when processes are already frozen in
suspend/resume.
References: https://bugzilla.kernel.org/show_bug.cgi?id=26232
Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br>
