The older add_mtd_device()/add_mtd_partitions() and
their removal are depricated. Replace uses with
mtd_device_register() and mtd_device_unregister().
bug 923135
Change-Id: I03790072d95ac27b4f11a6c522bb5d9de087a0df
Signed-off-by: Manoj Chourasia <mchourasia@nvidia.com>
Reviewed-on: http://git-master/r/83073
Reviewed-by: Preetham Chandru <pchandru@nvidia.com>
Reviewed-by: Sandeep Trasi <strasi@nvidia.com>
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Fixing the voltage selection logics for a given mininum/maximum
range.
bug 934544
Reviewed-on: http://git-master/r/78970
(cherry picked from commit 59b0264b6eda9f1e8123ee5cd82eae7104c3513e)
Change-Id: Ib9f6e8b1b1f0603aeb02af8345704110cd87b51a
Reviewed-on: http://git-master/r/79512
Fix bug in releasing nvmap client handles when nvavp release
is invoked.
Bug 930028
Signed-off-by: Kamal Kannan Balagopalan <kbalagopalan@nvidia.com>
Reviewed-on: http://git-master/r/78594
(cherry picked from commit 232e208f6c12d6112efe96f434b34c2b8c83d809)
Change-Id: I94f6990dddf7e683adbd896e059ba1b5e5aa3a75
Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-on: http://git-master/r/82708
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
This patch contains:
1. Addition of function tegra_fb_flip_win
2. Call to function tegra_fb_flip_win for an unblank event
tegra_dc needs a flip event after blank, to unblank sceen
Bug: 932784
Change-Id: Iec7e3f5ee898228e4efc90ca0efc2ca2b02021ae
Reviewed-on: http://git-master/r/79740
Reviewed-by: Simone Willett <swillett@nvidia.com>
1. Changes in fb.c to support the old color scheme for fbcon
2. Addition of color registration function in fb ops in fb.c
tegra_fb_setcolreg was removed by mistake in commit
f80e81610f4e2e3a9051b465a9176ac70f6913f1 (http://git-master/r/60201)
This patch contains a work around for the co-existence of both basic
and new color schemes.
Bug: 921567
Change-Id: I2b10d4956ce655511fc277d113e623d5d717ed5c
Signed-off-by: Shashank Sharma <shashanks@nvidia.com>
Reviewed-on: http://git-master/r/79397
This patch adds Kconfig and Makefile changes to smb349 driver
Signed-off-by: Syed Rafiuddin <srafiuddin@nvidia.com>
Reviewed-on: http://git-master/r/78292
(cherry picked from commit 2ffb0d06c5b2cda4dfde283257f2dd4f4d6f8300)
Change-Id: Icdb98cadafdcefd84011c92f846cf03f176e448f
Reviewed-on: http://git-master/r/82704
This patch enables Kconfig and Makefile option
Reviewed-on: http://git-master/r/78289
(cherry picked from commit b0bc7843eff62ff0a0d2476645fb96b1b947baa4)
Change-Id: Ib5928f88d041731b95713a97f894a0ee3a28ae1c
Reviewed-on: http://git-master/r/82701
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
Addition of initial max17048 fuel-gauge driver for maxim's max17048
chipset used in kai platform.
Reviewed-on: http://git-master/r/78210
(cherry picked from commit edb662a31ba9312227653c3211f23e853ade8d0a)
Change-Id: I78569e112488ed5d99a07e8a26dc912416e78ad5
Reviewed-on: http://git-master/r/79979
Reviewed-by: Syed Rafiuddin <srafiuddin@nvidia.com>
Issue BKOPS when the request queue is empty.
Before handling any new request, issue HPI
if bkops is being performed.
bug 919232
Originally reviewed on http://git-master/r/69779
Change-Id: Ic9258ebfea7f9cde96525371a5ef9d6d003ebf2f
Signed-off-by: Pavan Kunapuli <pkunapuli@nvidia.com>
Signed-off-by: Shridhar Rasal <srasal@nvidia.com>
Reviewed-on: http://git-master/r/77335
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Added support for starting BKOPS and issuing HPI
commands which are supported by eMMC v4.41 and eMMC
v4.5 cards.
Enable BKOPS and HPI interrupt if the host and card
support it.
Originally reviewed on: http://git-master/r/69778
Bug 919232
Change-Id: I09b33ddc18013e2eeb505fdb28dd8357fa75b569
Reviewed-on: http://git-master/r/77319
Resuming from LP1 is not working if usb device is connected
or disconnected while system in LP1 state.
So clear the otg interrupt in suspend and re-enable it while
resuming.
Bug 906171
Bug 935273
Signed-off-by: Alok Chauhan <alokc@nvidia.com>
Reviewed-on: http://git-master/r/79449
(cherry picked from commit 54935893382a1b49a1a23ec39c6e479d163b910b)
Change-Id: Ia62f6fcd475905e5d3bcc93eae8a1e04c356111e
Reviewed-on: http://git-master/r/82728
Reduce permissions on the max_boost and go_maxspeed_load, the init
scripts will change their owner so the current users continue to work.
Bug 906796
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Reviewed-on: http://git-master/r/79096
(cherry picked from commit f1d91095baff48e58a04af0062f579f394094b47)
Change-Id: Id9542a202bcf02f886cfee9c0bbe69cc83b8c200
Reviewed-on: http://git-master/r/82726
Take off the world-write bit from the default permissions for the
mem_access debug node. The init scripts will make it accessible on
engineering builds.
Bug 906796
Reviewed-on: http://git-master/r/79095
(cherry picked from commit a6ba61cc290bebb5dd16e4ad02cd1e8b3b9802b2)
Change-Id: I3e118dd502aa8912ad5fcb8452105c7f5f1c833a
Reviewed-on: http://git-master/r/82725
When HDMI NULL sample injection is enabled codec inserts null samples
into the audio FIFO for each Azalia frame in which it did not receive
any samples. This support is needed to prevent audio loss for HDMI
devices from some vendor(e.g. sony).
Bug 924926
Signed-off-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-on: http://git-master/r/79227
(cherry picked from commit 898fd83d94506de3bd604f75d25084d9bcb6dd9e)
Change-Id: I81f55cab52c92377b49ab94635c8e8aa394b6739
Reviewed-on: http://git-master/r/82724
Tested-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-by: Scott Peterson <speterson@nvidia.com>
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Reuse rx urb to avoid memory leak.
Detect usb interface disconnect state to avoid rx / tx urb submit
on disconnected interface.
Signed-off-by: Seshendra Gadagottu <sgadagottu@nvidia.com>
Reviewed-on: http://git-master/r/77969
(cherry picked from commit 343dcb023cd465a6210239cf64ebed5858223096)
Change-Id: I7e49c73b47f6e1c803cd5f0cdb2e6f81bf8171d3
Reviewed-on: http://git-master/r/82722
Reviewed-by: Seshendra Gadagottu <sgadagottu@nvidia.com>
Move CSCAN driver compilation flag to CONFIG_BCM4329_CSCAN_ENABLE
Kconfig option; CSCAN is not supported in all userspace environments.
The driver implementation of PNO_SUPPORT has a dependency on CSCAN, so
make that option controlled by CONFIG_BCM4329_CSCAN_ENABLE.
Bug 929960
Signed-off-by: Eric Brower <ebrower@nvidia.com>
(cherry picked from commit af965bf9a82041353a322a3205574ff402c6ff05)
Reviewed-on: http://git-master/r/77890
(cherry picked from commit 2f641aa2781afc80ed496978c55fc83aa251f727)
Change-Id: Iaf9ba7c7122571c7b5c5a670e0b9330d53a8940e
Reviewed-on: http://git-master/r/82721
Set the parent field of the netdevice, which causes sysfs
to create a device subdirectory under the netdevice. Without
this subdirectory the user-space NetworkManager cannot manage
the network device.
Implemented using void * to maintain current driver implementation
of segregated OS-specific implementation.
Bug 929960
Reviewed-on: http://git-master/r/77889
(cherry picked from commit 5055320be16c36557e1ab9966ff7537500ca6d4d)
Change-Id: Ia5ea298c32823f896428905a779a734140306861
Reviewed-on: http://git-master/r/82720
commit 598781d71119827b454fd75d46f84755bca6f0c6 upstream.
If the master tries to authenticate a client using drm_authmagic and
that client has already closed its drm file descriptor,
either wilfully or because it was terminated, the
call to drm_authmagic will dereference a stale pointer into kmalloc'ed memory
and corrupt it.
Typically this results in a hard system hang.
This patch fixes that problem by removing any authentication tokens
(struct drm_magic_entry) open for a file descriptor when that file
descriptor is closed.
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Change-Id: Icbba107e666306a34a621955458091410da3956a
Reviewed-on: http://git-master/r/79654
commit 44517c44496062180a6376cc704b33129441ce60 upstream.
Interrupts only work with MSIs.
https://bugs.freedesktop.org/show_bug.cgi?id=37679
Reported-by: Dmitry Podgorny <pasis.uax@gmail.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Change-Id: I54ba865b1bf3d7584911d57af90e7238e55c7ecc
Reviewed-on: http://git-master/r/79653
The mainline IOMMU API v3.3-rc1 has been changed so that bytes are
used in mapping size instead of page order and page-by-page iteration
is taken care of by iommu core.
The rest are mostly for maintainability:
$ git co iommu/next drivers/iommu/tegra-gart.c
Change-Id: Id88ae8d23d11f4e003d11ec1e4223a72215ad142
Signed-off-by: Hiroshi DOYU <hdoyu@nvidia.com>
Reviewed-on: http://git-master/r/78138
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
enabling quirk *SDHCI_QUIRK_NO_CALC_MAX_DISCARD_TO* for not to
calculate max discard timeout.
bug 930767
Change-Id: Id2ca4fd202961d1997c9269eb0d437a6fca241cf
Reviewed-on: http://git-master/r/79840
Adding SDHCI_QUIRK_NO_CALC_MAX_DISCARD_TO for not to calculate
max_discard_to which is deviation in setting max_discard.
For some host controllers, combination of
1) calculated non-zero value of max_discard_to and
2) erase_group_def not set
can result into setting max_discard value to pref_erase in
sectors which is very less, so it takes long time for erase.
With this change host controller can specify to calculate
max_discard_to and based on that max_discard value will be set.
bug 930767
Change-Id: I2c64ef8a6821620f2a65c06e25d2af68e3554a75
Reviewed-on: http://git-master/r/79839
This reverts commit 944a82b32d44bae0acb56abf5fec33a1c696c362.
Bug 934678
Change-Id: Icf6cbc2cd8dc22dcd3126f2da19923e7076c0071
Signed-off-by: Nagarjuna Kristam <nkristam@nvidia.com>
Reviewed-on: http://git-master/r/79710
commit 62aaf24dc125d7c55c93e313d15611f152b030c7 upstream.
wdm_disconnect() waits for the mutex held by wdm_read() before
calling wake_up_all(). This causes a deadlock, preventing device removal
to complete. Do the wake_up_all() before we start waiting for the locks.
Signed-off-by: Bjørn Mork <bjorn@mork.no>
Cc: Oliver Neukum <oliver@neukum.org>
Cc: stable <stable@vger.kernel.org>
Change-Id: Ic92d101f26698708a10ba276eff70825d19d6c89
Reviewed-on: http://git-master/r/79686
commit 26aa38cafae0dbef3b2fe75ea487c83313c36d45 upstream.
There was an error on the jsm driver that would cause it to be unable to
recover after a second error is detected.
At the first error, the device recovers properly:
[72521.485691] EEH: Detected PCI bus error on device 0003:02:00.0
[72521.485695] EEH: This PCI device has failed 1 times in the last hour:
[72532.035693] ttyn3 at MMIO 0x0 (irq = 49) is a jsm
[72532.105689] jsm: Port 3 added
However, at the second error, it cascades until EEH disables the device:
[72631.229549] Call Trace:
[72641.725687] jsm: Port 3 added
[72641.725695] EEH: Detected PCI bus error on device 0003:02:00.0
[72641.725698] EEH: This PCI device has failed 3 times in the last hour:
It was caused because the PCI state was not being saved after the first
restore. Therefore, at the second recovery the PCI state would not be
restored.
Signed-off-by: Lucas Kannebley Tavares <lucaskt@linux.vnet.ibm.com>
Signed-off-by: Breno Leitao <brenohl@br.ibm.com>
Acked-by: Thadeu Lima de Souza Cascardo <cascardo@linux.vnet.ibm.com>
Change-Id: I17d5be5ce4b8acc1c881290d19933405b3e476b9
Reviewed-on: http://git-master/r/79677
commit ef605fdb33883d687cff5ba75095a91b313b4966 upstream.
Protect against pl011_console_write() and the interrupt for
the console UART running concurrently on different CPUs.
Otherwise the console_write could spin for a long time
waiting for the UART to become not busy, while the other
CPU continuously services UART interrupts and keeps the
UART busy.
The checks for sysrq and oops_in_progress are taken
from 8250.c.
Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com>
Reviewed-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Reviewed-by: Bibek Basu <bibek.basu@stericsson.com>
Reviewed-by: Shreshtha Kumar Sahu <shreshthakumar.sahu@stericsson.com>
Change-Id: I0874bd94d979a5f3a61922ec5fb4c092d7e40874
Reviewed-on: http://git-master/r/79676
commit 0eee50af5b13e00b3fb7a5fe8480419a71b8235d upstream.
Commit 74c2107759d (serial: Use block_til_ready helper) and its fixup
3f582b8c110 (serial: fix termios settings in open) introduced a
regression on UV systems. The serial eventually freezes while being
used. It's completely unpredictable and sometimes needs a heap of
traffic to happen first.
To reproduce this, yast installation was used as it turned out to be
pretty reliable in reproducing. Especially during installation process
where one doesn't have an SSH daemon running. And no monitor as the HW
is completely headless. So this was fun to find. Given the machine
doesn't boot on vanilla before 2.6.36 final. (And the commits above
are older.)
Unless there is some bad race in the code, the hardware seems to be
pretty broken. Otherwise pure MSR read should not cause such a bug,
or?
So to prevent the bug, revert to the old behavior. I.e. read modem
status only if we really have to -- for non-CLOCAL set serials.
Non-CLOCAL works on this hardware OK, I tried. See? I don't.
And document that shit.
References: https://lkml.org/lkml/2011/12/6/573
References: https://bugzilla.novell.com/show_bug.cgi?id=718518
Change-Id: Ib498daa38459e658a081a3e218e9c87d63f1fc3b
Reviewed-on: http://git-master/r/79675
commit 6d443d8499e4e59ffb949759cdded32730f8d2f6 upstream.
Calling edge_remove_sysfs_attrs from edge_disconnect is too late
as the device has already been removed from sysfs.
Do the simple and obvious thing and make edge_remove_sysfs_attrs
the port_remove method.
Reported-by: Wolfgang Frisch <wfpub@roembden.net>
Change-Id: I13e0dc8ffc1e26d14a66fabc1d40c8ba02ac1b3a
Reviewed-on: http://git-master/r/79674
commit 074cc73506f529f39fef32ad1c9e1d4cdd8acf6c upstream.
More ports we now know how to talk to.
Signed-off-by: Dan Williams <dcbw@redhat.com>
Change-Id: I94880694af4a404ad56476a4d1676ad48a862339
Reviewed-on: http://git-master/r/79673
commit e8537bd2c4f325a4796da33564ddcef9489b7feb upstream.
using a separate read and write mutex for locking is sufficient to make the
driver accept simultaneous read and write. This improves useability a lot.
Cc: Oliver Neukum <oneukum@suse.de>
Change-Id: I10ed5f0e41b379f0fef8a22abde46d4231162ff9
Reviewed-on: http://git-master/r/79672
commit c428b70c1e115c5649707a602742e34130d19428 upstream.
wdm_in_callback() will also touch this field, so we cannot change it without locking
Acked-by: Oliver Neukum <oneukum@suse.de>
Change-Id: I7eb2367de1a74be1ac68578354113154595d02cc
Reviewed-on: http://git-master/r/79671
commit 2353f806c97020d4c7709f15eebb49b591f7306d upstream.
0x04d8, 0x000a: Hornby Elite
Signed-off-by: Alan Cox <alan@linux.intel.com>
Change-Id: I0cdcd93865fe4ce86bb5fa5e18c585a64b0edb78
Reviewed-on: http://git-master/r/79670
commit fc216ec363f4d174932df90bbf35c77d0540e561 upstream.
I tested this against 2.6.39 in the Ubuntu kernel, however I see the IDs
are not in latest 3.2 git.
This adds IDs for the FTDI controller in the Rainforest Automation
Zigbee dongle.
Signed-off-by: Peter Naulls <peter@chocky.org>
Change-Id: I27ff506978bf3387a2571e5146b3c181eed95bf0
Reviewed-on: http://git-master/r/79669
commit 55f13aeae0346f0c89bfface91ad9a97653dc433 upstream.
Port A for JTAG, port B for serial.
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
Change-Id: I4ce3e7aa2d117dde3840f3da1adb21caee413e03
Reviewed-on: http://git-master/r/79668
commit 108e02b12921078a59dcacd048079ece48a4a983 upstream.
Fix regression introduced by commit b1ffb4c851f1 ("USB: Fix Corruption
issue in USB ftdi driver ftdi_sio.c") which caused the termios settings
to no longer be initialised at open. Consequently it was no longer
possible to set the port to the default speed of 9600 baud without first
changing to another baud rate and back again.
Reported-by: Roland Ramthun <mail@roland-ramthun.de>
Signed-off-by: Johan Hovold <jhovold@gmail.com>
Tested-by: Roland Ramthun <mail@roland-ramthun.de>
Change-Id: Ic092fe37a53c546aceb7e1b3cd8bd44cd8b8369b
Reviewed-on: http://git-master/r/79667
commit eb833a9e0972f60beb4ab8104ad7ef6bf30f02fc upstream.
Return EINVAL if new baud_base does not match the current one.
The baud_base is device specific and can not be changed. This restores
the old (pre-2005) behaviour which was changed due to a
misunderstanding regarding this fact (see
https://lkml.org/lkml/2005/1/20/84).
Reported-by: Torbjörn Lofterud <torbjorn@pi.nxs.se>
Change-Id: I672bd484e4c55708f0e97c83037c5acbc7b9e7c7
Reviewed-on: http://git-master/r/79666
commit e423d7401fd0717cb56a6cf51dd8341cc3e800d2 upstream.
Add vendor and product ID for USB 3G/LTE modem of docomo L-02C
Signed-off-by: Kentaro Matsuyama <kentaro.matsuyama@gmail.com>
Change-Id: I265980e25c6db426f3b88339d68b09e02dc86226
Reviewed-on: http://git-master/r/79665
commit ba68e086223a5f149f37bf8692c8cdbf1b0ba3ef upstream.
This is a revert of 81a14b46846fea0741902e8d8dfcc6c6c78154c8.
We already set the mode polarity using the SDVO commands with struct
intel_sdvo_dtd. We have at least 3 bugs that get fixed with this patch.
The documentation, despite not clear, can also be interpreted in a way
that suggests this patch is needed.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=15766
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=42174
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=43333
Reviewed-by: Eric Anholt <eric@anholt.net>
Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Signed-off-by: Paulo Zanoni <paulo.r.zanoni@intel.com>
Signed-off-by: Keith Packard <keithp@keithp.com>
Change-Id: If7b6ecb7fe43fa8611a8ea7f4260f9d3d378284c
Reviewed-on: http://git-master/r/79663
Signed-off-by: Xin Xie <xxie@nvidia.com>
Reviewed-on: http://git-master/r/70702
(cherry picked from commit 50992cf718c37882d90e2b781fbe3f01b4997df8)
Reviewed-on: http://git-master/r/77928
(cherry picked from commit a51315ad482758e53a75096be0415ca9b49b9483)
Change-Id: I22389cfc7010937dc60c5b1aa4b59c4992f9906b
Reviewed-on: http://git-master/r/80003
typically PM QoS clients request the maximum cpu frequency by
setting cpu_freq_min to INT_MAX. Therefore, we need to clamp INT_MAX
to whatever the maximum frequency allowed by the policy to make
the requested cpu_freq_min is same as the maximum allowed cpu
frequency. Inverse logic applies to the cpu_freq_max as well.
Bug 932477
Signed-off-by: Donghan Ryu <dryu@nvidia.com>
Reviewed-on: http://git-master/r/78401
(cherry picked from commit 9688430a621515f3afe3e0ab358ea7ad5aab6d91)
Change-Id: Ie5edcd4a873ed5cce45ec0f9b981f28db6091ff1
Reviewed-on: http://git-master/r/80002
Reviewed-on: http://git-master/r/70625
(cherry picked from commit 90add398c43bb111903015bb6a3cd57a8d62262f)
Reviewed-on: http://git-master/r/77926
(cherry picked from commit 4a781c10f2b302f3b467b69060028f9c3b2f9774)
Change-Id: Ia2b4935896a44d1717e20693e26a244c6f556c98
Reviewed-on: http://git-master/r/79999
Set all parameters of the video mode on probe so that
FBIOGET_VSCREENINFO can query the current mode.
Bug 931383
Signed-off-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-on: http://git-master/r/77433
(cherry picked from commit cb97eadc17a204fc8051fe5b9321a27905f890bb)
Change-Id: Ibd7fc05b1203044cc616c1ee628873385643c909
Reviewed-on: http://git-master/r/79997
Bug 915417
Signed-off-by: Alexandre Courbot <acourbot@nvidia.com>
Reviewed-on: http://git-master/r/74134
(cherry picked from commit 37018b3493d2d3006e38eb7a2f81cf47b111e5ea)
Change-Id: I1f8bda8be92f3861fabc51c362e677497e1cb44f
Reviewed-on: http://git-master/r/79993
Smb349 battery charger driver for kai platform.
Reviewed-on: http://git-master/r/78211
(cherry picked from commit f059c9db2735a6e0088dd9cd61a623b13b5d717e)
Change-Id: Ifa401713928d29bb4235353e50b66e632c7625ba
Reviewed-on: http://git-master/r/79980
The month field of tm structure managed by kernel,
expects a value between 0 to 11.
However, TPS6591x RTC month register expects the month
range to be between 1 to 12.
Hence fixing it.
Signed-off-by: Venu Byravarasu <vbyravarasu@nvidia.com>
Change-Id: I054de10dcd58497167c8460fe935325cee3c582f
Reviewed-on: http://git-master/r/79930
Tested-by: Venu Byravarasu <vbyravarasu@nvidia.com>
However, TPS80031 RTC month register expects the month
Hence fixing it.
bug 931452
Change-Id: Ie208c50b316e452e50eb2b607bafe83cb227eaea
Reviewed-on: http://git-master/r/79928
the USB core
commit 655e247daf52b202a6c2d0f8a06dd2051e756ce4 upstream.
As it turns out, there was a mismatch between the allocated inbuf size
(desc->bMaxPacketSize0, typically something like 64) and the length we
specified in the URB (desc->wMaxCommand, typically something like 2048)
Change-Id: I00872baa6896dfdd076fdcfc57956f1420973a7f
Reviewed-on: http://git-master/r/79687
commit d1620ca9e7bb0030068c3b45b653defde8839dac upstream.
Allow more baud rates to be set in [1M,2M] baud.
Cc: Preston Fick <preston.fick@silabs.com>
Change-Id: Idbfba5dd348d4d108394918e2349a55ca7a541aa
Reviewed-on: http://git-master/r/79705
commit cdc32fd6f7b2b2580d7f1b74563f888e4dd9eb8a upstream.
The newer cp2104 devices require the baud rate to be initialised after
power on. Make sure it is set when port is opened.
Change-Id: I165e4c3692ed7f177815a729128b4bc325ac6908
Reviewed-on: http://git-master/r/79704
commit e5990874e511d5bbca23b3396419480cb2ca0ee7 upstream.
Clean up and refactor speed handling.
Document baud rate handling for CP210{1,2,4,5,10}.
Change-Id: Icf3d3a2ae7116d8c9fe93b356304950cc97cb15e
Reviewed-on: http://git-master/r/79703
