gpu virtual memory cannot be allocated for external use
this issue occurs in ARD board with 2G above memory address
Signed-off-by: Xianzhong <b07117@freescale.com>
Acked-by: Jason Liu
This patch updates IPUv3 IC RGB to YUV color space conversion
matrix's parameters to align with the default VIV GPU CSC
implementation so that we may pass relevant Android CTS test
cases.
Signed-off-by: Liu Ying <Ying.Liu@freescale.com>
(cherry picked from commit 17b6dbef8eea2051a6c3819f3690c21948bd0e93)
Android Recovery UI framework uses FBIOPUT_VSCREENINFO with yoffset update
to update display.
Both elcdif and ipuv3 FB will set var.activate to be FB_ACTIVATE_FORCE in
driver's probe. User space will get the VSCREENINFO with activate been set
to FB_ACTIVE_FORCE. Each FBIOPUT_VSCREENINFO with only yoffset update will
make the driver reinit.The activate should be cleared once set_par() been
finished.
HDMI driver should only reinit hdmi only when the mode changed. fbmem will
broadcast MODE_CHANGE for each FBIOPUT_VSCREENINFO ioctl even it only have
yoffset update.
Signed-off-by: guoyin.chen <guoyin.chen@freescale.com>
this issue cause system boot with multi-user switch on JB4.3,
root cause is gpu memory cannot be multi-locked in same process,
gpu memory lock reference is added to allow multi-lock in kernel driver.
Acked-by: Jason Liu
Fixed by add check for cam->sensor
Signed-off-by: Fang Hui <b31070@freescale.com>
We enable WOW mode last commit, it will try to set mmc host's power
capability to keep power on at some points. Delete this act which is
bond with one force scan action. For we didn't add force scan function
in it. We are using runtime_pm feature to trigger scan when doing init.
Signed-off-by: Jianzheng Zhou <jianzheng.zhou@freescale.com>
imx_3.0.35_android
When do stream on/off in pair repeatedly without close the v4l device,
the kernel dump happens:
Unable to handle kernel paging request at virtual address 00200200
pgd = c0004000
[00200200] *pgd=00000000
Internal error: Oops: 805 [#1] PREEMPT
Modules linked in:
CPU: 0 Not tainted (3.0.35-06027-gbbea887-dirty #21)
PC is at camera_callback+0x15c/0x1c8
LR is at 0x200200
pc : [<c03747d0>] lr : [<00200200>] psr: 20000193
sp : c0b0fed0 ip : 00200200 fp : daf1102c
r10: daf11034 r9 : 00100100 r8 : daf11098
r7 : daf11100 r6 : daf11034 r5 : daf11000 r4 : c0b0e000
r3 : 00000000 r2 : 00000001 r1 : 00000001 r0 : daf114b8
Flags: nzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: 10c53c7d Table: 8cc8c059 DAC: 00000015
Process swapper (pid: 0, stack limit = 0xc0b0e2e8)
Stack: (0xc0b0fed0 to 0xc0b10000)
fec0: c0374674 822a4000 daf11000 c0b87eb4
fee0: 00000000 00000027 c0b73904 c0b305e0 00000001 c0374090 da2bbbe0 c0b0e000
ff00: 00000000 c00acc58 00000000 c0098058 00989680 c0b305e0 c0b0e000 00000000
ff20: 00000002 00000001 c0b0e000 00000000 00000000 c00acdf8 00000000 c0b0e000
ff40: 9e4e7881 c0b305e0 c0b0e000 c00aee44 c00aed9c c0b43c6c 00000027 c00ac634
ff60: 00000270 c004257c ffffffff f2a00100 00000027 c00417cc 20000000 00000006
ff80: f40c4000 00000000 c0b0e000 c0b6a924 c0b1876c c0b18764 80004059 412fc09a
ffa0: 00000000 00000000 c0063a40 c0b0ffc0 c004f758 c0042690 80000013 ffffffff
ffc0: c004266c c004294c c0b1013c 00000000 c10960c0 c00088ec c0008334 00000000
ffe0: 00000000 c00337d4 10c53c7d c0b10060 c00337d0 80008040 00000000 00000000
[<c03747d0>] (camera_callback+0x15c/0x1c8) from [<c0374090>] (csi_irq_handler+
0x7c/0x160)
[<c0374090>] (csi_irq_handler+0x7c/0x160) from [<c00acc58>] (
handle_irq_event_percpu+0x50/0x19c)
[<c00acc58>] (handle_irq_event_percpu+0x50/0x19c) from [<c00acdf8>] (
handle_irq_event+0x54/0x84)
[<c00acdf8>] (handle_irq_event+0x54/0x84) from [<c00aee44>] (handle_fasteoi_irq
+0xa8/0x160)
[<c00aee44>] (handle_fasteoi_irq+0xa8/0x160) from [<c00ac634>] (
generic_handle_irq+0x2c/0x40)
[<c00ac634>] (generic_handle_irq+0x2c/0x40) from [<c004257c>] (handle_IRQ
+0x30/0x84)
[<c004257c>] (handle_IRQ+0x30/0x84) from [<c00417cc>] (__irq_svc+0x4c/0xa8)
[<c00417cc>] (__irq_svc+0x4c/0xa8) from [<c0042690>] (default_idle+0x24/0x28)
[<c0042690>] (default_idle+0x24/0x28) from [<c004294c>] (cpu_idle+0x8c/0xc0)
[<c004294c>] (cpu_idle+0x8c/0xc0) from [<c00088ec>] (start_kernel+0x294/0x2e4)
[<c00088ec>] (start_kernel+0x294/0x2e4) from [<80008040>] (0x80008040)
Code: e88c4200 e595c030 e5858030 e8881800 (e58c8000)
---[ end trace 224150c26d2bd5f7 ]---
The root cause is cam->enc_counter is not re-initialized to 0 when calls
STREAMOFF ioctl, and then in DQBUF ioctl wait_event_interruptible_timeout()
sees the condition is true and access cam->done_q queue which has no strict
check and could be empty.
This patch adds the re-initialization and the sanity check.
Also, add the pointer check for memcpy because the destination may be
NULL on UERSPTR mode.
Signed-off-by: Robby Cai <R63905@freescale.com>
V4L2_PIX_FMT_YUYV is the original format from camera and the source format
for CSI. This format may be needed on Android to do CSC before encoding.
We can now choose V4L2_PIX_FMT_YUYV or V4L2_PIX_FMT_UYVY for the CSI
output format.
Fix "Timeout Waiting for Hardware Interrupt on mmc1" issue in
suspend/resume which is caused by not keep power in host.
Enable WOW mode in card side to enable MMC_KEEP_POWER capability
of host will tackle this issue.
The baseAddress of contiguousVidMem is the actual physical address
which is not subtracted by gpu baseAddress, but the allocated physical address
has been subtracted by gpu baseAddress in gckVIDMEM_Lock,
so the invalid offset is produced and used to calculate the logical address.
Acked-by: Shawn Guo
imx_3.0.35_android
There's an interim buffer which should only be used when PxP CSC is used.
Otherwise the video buffer gets incorrect data by copying the content of
interim buffer. The patch fixes this by moving the memcpy to the right place.
(cherry picked from commit 8e0b8ff485dd7cdeabc653f1e27c271ac923710e)
One bd actually needs 4KB page size. So changed the iram_alloc()
size parameter to allocate a precise iram memory for bd.
This patch also removed the extra iram pool for SDMA due to its
insufficient total size: SDMA allows around 48 channels to work
simultaneously, so it's better to allocate memory from iram pool
directly.
[There will be 3KB size waste in sdma->channel_control, which is
640B but actually using 4KB due to 4KB alignment for iram pool.]
Acked-by: Huang Shijie <b32955@freescale.com>
Signed-off-by: Nicolin Chen <b42378@freescale.com>
This reverts commit 881e21c1275dcc40ccd63fb4fa46b990eeb4fb00.
With the commit 881e21c1 and 7b60e285, the system will hang when do suspend
and resume stress test continuouly while run edpc test in the background.
Revert it now and revisit it later.
imx_3.0.35_android
The display MIX can be power gated when EPDC, PXP and LCDIF are all inactive.
This will save around 1.5mW-1.8mW of power in system IDLE mode.
Need to re-initialize the EPDC and PXP whenever the display MIX is
powered up as all the register state is lost when the display MIX is
power gated.
Signed-off-by: Ranjani Vaidyanathan <ra5478@freescale.com>
Android Framework need the timestamp from VSYNC to driver the UI update
We have not implemented fully OTG support, so we can't call
otg_statemachine since the state machine may incorrect at current
dual-role switch design.
At existed code, it will call otg_statemachine, in fact, it doesn't
need. Besides, it causes one kernel dump at Sabreauto board due
to it calls gpio API at spin lock, but at Sabreauto board the
USB power GPIO is expanded by MAX7310 which calls i2c read/write
and will schedule itself.
Signed-off-by: Peter Chen <peter.chen@freescale.com>
Add wifi driver for rtl8723as. Need change some cfg80211 config for it also.
The driver should inform the upper-lever application the exact size of
the image. PAGE_ALIGN macro should be removed.
add the strict check for crop setting in S_CROP ioctl
- add the CROPCAP ioctrl support
Fix the build error in csi capture
The original calculation of the boot size is wrong.
Fix it by the right calculation.
Signed-off-by: Richard Zhu <r65037@freescale.com>
In the imx6sl, we meet the compiling warning shows below:
drivers/dma/imx-sdma.c: In function Pleasesdma_iram_free:
drivers/dma/imx-sdma.c:366: warning: passing argument 2 of
Pleasegen_pool_free makes integer from pointer without a cast
include/linux/genalloc.h:58: note: expected Pleaselong unsigned integer
but argument is of type Pleaselong unsigned int *Please
drivers/dma/imx-sdma.c: In function Pleasesdma_load_script:
drivers/dma/imx-sdma.c:452: warning: passing argument 2 of
Pleasesdma_iram_malloc makes pointer from integer without a cast
drivers/dma/imx-sdma.c:352: note: expected Pleaselong unsigned
int *Please but argument is of type Pleaselong unsigned integer
drivers/dma/imx-sdma.c:475: warning: passing argument 1 of
Pleasesdma_iram_free makes pointer from integer without a cast
drivers/dma/imx-sdma.c:361: note: expected Pleaselong unsigned
int *Please but argument is of type Pleasedma_addr_t
drivers/dma/imx-sdma.c: In function Pleasesdma_request_channel:
drivers/dma/imx-sdma.c:942: warning: passing argument 2 of
drivers/dma/imx-sdma.c:352: note: expected Pleaselong unsigned int
drivers/dma/imx-sdma.c: In function Pleasesdma_free_chan_resources:
drivers/dma/imx-sdma.c:1109: warning: passing argument 1 of
drivers/dma/imx-sdma.c:361: note: expected Pleaselong unsigned int
drivers/dma/imx-sdma.c: In function Pleasesdma_init:
drivers/dma/imx-sdma.c:1505: warning: passing argument 2 of
Pleasesdma_iram_malloc from incompatible pointer type
*Please but argument is of type Pleasedma_addr_t *Please
this patch fixes it.
Signed-off-by: Huang Shijie <b32955@freescale.com>
Fixed code so condition causing the warning never occurs.
Signed-off-by: Jay Monkman <jay.monkman@freescale.com>
TV will been setting powerdown state when first run HDMI CEC unit
test on MX6Q, but failed in the secondly run and loop in print
message:
sleep for ready!
sleep for ready!
sleep for ready!
It is cause by cec interrupter been enabled before interrupter
polarity setting, controler will received fake interrupter,
and cec unit test will get wrong device state.
Fix the issue with move interrupter polarity setting code before
interrupter enabled.
Signed-off-by: Sandor Yu <R01008@freescale.com>
CC [M] drivers/gpu/drm/drm_global.o
drivers/mxc/mlb/mxc_mlb150.c: In function 'mxc_mlb150_open':
drivers/mxc/mlb/mxc_mlb150.c:1910: warning: format '%x'
expects type 'unsigned int', but argument 2 has type 'void *'
Signed-off-by: Dong Aisheng <b29396@freescale.com>
The problem locates at:
fsl_otg_start_host(fsm, 0);
if (pdata->wake_up_enable)
pdata->wake_up_enable(pdata, false);
otg_drv_vbus(fsm, 0);
fsl_otg_start_host(fsm, 0) internally calls fsl_otg_drv_vbus(), which does
the same thing as otg_drv_vbus(fsm, 0). More critically, we need disable
VBUS wakeup before close VBUS operation, otherwise unexpected VBUS
wakeup will occur. The solution is to remove the call of fsl_otg_drv_vbus()
in fsl_otg_start_host().
We call the function ipu_calc_stripes_sizes() to calculate
stripe settings for vdi split mode. Chances are that the
parameters output_frame_width and maximal_stripe_width for the
function satisfy the relationship 'output_frame_width <=
maximal_stripe_width' and make the function return non-zero
value. This causes the IPU device driver generates an annoying
warning message, though the default stripe settings still can
work. This patch simply silences the warning message by reducing
the print log level from error to debug.
(cherry picked from commit 58d6cb0f2d5013c7a6f7b163ce8834019f0dcbc0)
imx_3.0.35_android
arch/arm/mach-mx6/Kconfig
arch/arm/mach-mx6/board-mx6q_arm2.c
arch/arm/mach-mx6/board-mx6q_arm2.h
arch/arm/mach-mx6/board-mx6q_hdmidongle.c
arch/arm/mach-mx6/board-mx6q_sabreauto.c
arch/arm/mach-mx6/board-mx6q_sabreauto.h
arch/arm/mach-mx6/board-mx6q_sabrelite.c
arch/arm/mach-mx6/board-mx6q_sabresd.c
arch/arm/mach-mx6/board-mx6q_sabresd.h
arch/arm/mach-mx6/clock.c
arch/arm/mach-mx6/pcie.c
arch/arm/plat-mxc/include/mach/iomux-mx6q.h
arch/arm/plat-mxc/include/mach/pcie.h
drivers/input/touchscreen/egalax_ts.c
drivers/media/video/mxc/capture/csi_v4l2_capture.c
drivers/mxc/gpu-viv/hal/os/linux/kernel/gc_hal_kernel_os.c
drivers/mxc/thermal/thermal.c
drivers/net/fec.c
drivers/usb/host/ehci-arc.c
drivers/video/mxc/mxc_ipuv3_fb.c
include/linux/fec.h
sound/soc/imx/imx-wm8962.c
Board files correctly define fec gpio irq to wake up wait mode since FEC
interrupt cannot connect to GPC, otherwise board files define fec gpio irq
to -1. So, fec probe function check the gpio irq to decide whether fec use
gpio irq or fec irq.
Current irq checking logic is incorrect. Correct the gpio irq checking.
Signed-off-by: Fugang Duan <B38611@freescale.com>
For imx6 serial silicon, fec MDC clock parent is ipg 66MHz.
The current clock file define the clock source is enet_pll8 50Mhz.
So, the MDC clock is more than 2.5Mhz after divider.
The phy Ar8031 work fine in current MDC clock, which shows the phy
have exceeding flexibility. Correct the parent clock source to make
MDC clock little than 2.5Mhz.
Add a command line option to route the ENET interrupts to the GPIO_1_6.
To route the ENET interrupts to GPIO_6 add "enet_gpio_6" to the
kernel command line.
Also remove the CONFIG option (MX6_ENET_IRQ_TO_GPIO).
This commit should be applied on top of following commits:
72c86f0b9a953e91bb1ed31021b71f337050bc28
808863866d2c17aeb3e70a7fcd094bd96db4b601
bae4d40849f3acdd9663f5a0857c9415ed7e6d5d
We need 2 video buffers to get a deinterlaced frame in VDI low motion
mode or medium motion mode. When there is no enough video buffer in
the active list, no one triggers the video buffer timer, then users
may be blocked at dqueue buffer ioctrl if they are in blocking mode.
In order to fix this issue, we may peek the first available video
buffer in the queue list so that the buffer may be taken as a reference
video buffer to do deinterlacing. If there is no video buffer in the
queue list, we should make users be able to trigger the timer again
when they queue buffers to the driver.
(cherry picked from commit 52d0e3f01afbf49d8d16225dede18cc71daa0570)
Use ePxP to do the horizontal/vertical flip and rotation support
(cherry picked from commit d0b9c741601b766213af1332329963f4267cd0c6)
- the root cause is pxp input/output buffer for csi post-processing is
same one, some part of content is overridded.
- use S_CROP ioctl to control crop, S_FMT to control output size.
(cherry picked from commit 9f3685ea1cd4e56b5d89bfbaf48920ba862edb49)
ASRC driver allows users to set channel number via PROC interface,
but only passes the total number equal 10.
This's not reasonable because ASRC can use total number lower than 10
if user assure each of them is an even number.
Acked-by: Wang Shengjiu <b02247@freescale.com>
(cherry picked from commit d76d08c93550cf2de9b1eff569ad6c0928ba122c)
Set ASRC processing clock 56k/76k with the recommended value from spec.
(cherry picked from commit 0519d385f5ed78f3526b72a211ccf22ac77c102e)
The pair config code was prolix. Actually the three pair could use the same
part of code with different configurations. So remove the prolix code.
(cherry picked from commit feb58d669633b94f97f111d79f81cb4abf1bf2c1)
There's already a same section of code above the removed one.
(cherry picked from commit b69af65683f17bfa701fdbb2dd3a93f53dc3503b)
The old req_pair() constrained that only Pair B could afford 6 channels,
while actually not. So rewrite it to be more flexible.
(cherry picked from commit adbc9dbba6ee46c05c0878a8e3bab118981d62c7)
Added missing clock and revised the clock map for v2
(cherry picked from commit c7e1b9af10cb579efaf7c4644170f6f8bee401e2)
The comments for the input/output prescaler and divider were swapped,
so reverse them.
(cherry picked from commit bb6347bc5acb1d59e001063968c18d1056807cf9)
The offset of output clock prescaler and divider were swapped, so reverse them.
(cherry picked from commit 4cda1ac12a8fdef84082212fb8fc5590c6c22fe7)
Some expiring video buffers may have been rendered to
display triple buffers for display. The relevant triple
buffers are set to be ready and depend on the display
hardware engine to switch them to be active on screen in
turn automatically. So, we need to wait for at least 2
vsyncs to make sure all of the expiring video buffers be
shown on display already.
(cherry picked from commit f7479db43eb2fa9bdb03c1ce99239a3136345105)
We hope the queued works can be done before streamoff, since the
works will render expiring video buffers to display. But, the
function cancel_work_sync() cannot guarantee this. Instead, it
may cancel some queued works before they starts to work. This
patch removes the function call cancel_work_sync() when streamoff.
We rely on the function flush_workqueue() right after it to make
sure queued works be done before streamoff.
(cherry picked from commit d88f6f7eaf3b78e667de46aa355cf366a1142e47)
Need to add timeout for temperature update, otherwise, if suspend
comes during thermal sensor measurement, its power will be turned
off, and after resume, the delay work thread will never get
finish flag and result in thread forever loop, temperature will
never get updated. And if we wait for the measurement finish before
suspend, the time is too long for suspend, as one single measurement
would take as long as 100ms which is not good for suspend, so just
add a timeout.
Signed-off-by: Anson Huang <b20788@freescale.com>
Add VPU_IOC_LOCK_DEV to lock VPU device
Signed-off-by: Hongzhang Yang <Hongzhang.Yang@freescale.com>
