commit 5feb54a1ab91a237e247c013b8c4fb100ea347b1 upstream.
We can use up to four bus-clocks; but on module remove, we didn't
disable the fourth bus clock.
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
Signed-off-by: Chris Ball <cjb@laptop.org>
Cc: Ben Hutchings <ben@decadent.org.uk>
commit 52965cc012f7a3cf35f06485ec275ebf3b3fddae upstream.
Some bcm5974 trackpads have a physical button beneath the physical surface.
This patch sets the property bit so user space applications can detect the
trackpad type and act accordingly.
Signed-off-by: Jussi Pakkanen <jussi.pakkanen@canonical.com>
Reviewed-by: Henrik Rydberg <rydberg@euromail.se>
Cc: maximilian attems <max@stro.at>
commit 67e1d34cd54cbf33f093f1dd53e7bda1124eb972 upstream.
BugLink: http://launchpad.net/bugs/865807
There is no entry for P key on TM8372, so when P key is pressed, only
"acer_wmi: Unknown key number - 0x29" in dmesg.
Signed-off-by: Merlin Schumacher <merlin.schumacher@gmail.com>
Signed-off-by: Ike Panhc <ike.pan@canonical.com>
commit 5260e458f5eff269a43e4f1e9c47186c57b88ddb upstream.
Make sure generic close is called at close.
The driver relies on the generic write implementation but did not call
generic close.
Note that the call to kill the read urb is not redundant, as mct_u232
uses an interrupt urb from the second port as the read urb and that
generic close therefore fails to kill it.
Compile-only tested.
Signed-off-by: Johan Hovold <jhovold@gmail.com>
[bwh: Backported to 3.2: adjust context]
commit 9e791e4a04c08868f02cd579a428a7268492e1b4 upstream.
Support for new 82599 based quad port adapter.
Signed-off-by: Emil Tantilov <emil.s.tantilov@intel.com>
Tested-by: Phil Schmitt <phillip.j.schmitt@intel.com>
Signed-off-by: Abdallah Chatila <Abdallah.Chatila@ericsson.com>
commit 7d145282da8d1ae4ba5f7ead8a4f51183496803c upstream.
This patch adds support for new device ID.
commit b03e66a6be91f8389fcd902ab6c1563db1c9c06b upstream.
If kdump is triggered with pending IO, controller may not respond causing
kdump to fail.
http://marc.info/?l=linux-ide&m=133032255424658&w=2
During error recovery ata_do_dev_read_id never completes due hang
in mmio_insw.
ata_do_dev_read_id
ata_sff_data_xfer
ioread16_rep
mmio_insw
if DMA start bit is cleared before reset, PIO command is successful
and kdump succeeds.
Signed-off-by: David Milburn <dmilburn@redhat.com>
Cc: CAI Qian <caiqian@redhat.com>
commit df376f0de167754da9b3ece4afdb5bb8bf3fbf3e upstream.
This patch adds device support for Ethernet Controller X540-AT1.
Signed-off-by: Josh Hay <joshua.a.hay@intel.com>
commit c6fdd8e5d0c65bb8821dc6da26ee1a2ddd58b3cc upstream.
The delayed work function int_in_work() may call usb_reset_device()
and thus, indirectly, the driver's pre_reset method. Trying to
cancel the work synchronously in that situation would deadlock.
Fix by avoiding cancel_work_sync() in the pre_reset method.
If the reset was NOT initiated by int_in_work() this might cause
int_in_work() to run after the post_reset method, with urb_int_in
already resubmitted, so handle that case gracefully.
Signed-off-by: Tilman Schmidt <tilman@imap.cc>
commit 45171002b01b2e2ec4f991eca81ffd8430fd0aec upstream.
The Intel 82855PM host bridge / Mobility FireGL 9000 RV250 combination
in an (outdated) ThinkPad T41 needs AGPMode 1 for suspend/resume (under
KMS, that is). So add a quirk for it.
(Change R250 to RV250 in comment for preceding quirk too.)
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit a8c32a5c98943d370ea606a2e7dc04717eb92206 upstream.
Request based dm attempts to re-run the request queue off the
request completion path. If used with a driver that potentially does
end_io from its request_fn, we could deadlock trying to recurse
back into request dispatch. Fix this by punting the request queue
run to kblockd.
Tested to fix a quickly reproducible deadlock in such a scenario.
Acked-by: Alasdair G Kergon <agk@redhat.com>
commit c36a7ff4578ab6294885aef5ef241aeec4cdb1f0 upstream.
Fixed parsing end absolute address.
Signed-off-by: Jiri Engelthaler <engycz@gmail.com>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
commit 49bd665c5407a453736d3232ee58f2906b42e83c upstream.
SATA MICROCODE DOWNALOAD fails on isci driver. After receiving Register
Device to Host (FIS 0x34) frame Initiator resets phy.
In the frame handler routine response (FIS 0x34) was copied into wrong
buffer and upper layer did not receive any answer which resulted in
timeout and reset.
This patch corrects this bug.
Signed-off-by: Maciej Patelczyk <maciej.patelczyk@intel.com>
Signed-off-by: Lukasz Dorau <lukasz.dorau@intel.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit dd321acddc3be1371263b8c9e6c6f2af89f63d57 upstream.
When host_sleep_config command fails we should return error to
MMC core to indicate the failure for our device.
The misspelled variable is also removed as it's redundant.
Signed-off-by: Bing Zhao <bzhao@marvell.com>
commit a485e827f07bfdd0762059386e6e787bed6e81ee upstream.
This is an ISY IWL 2000. Probably a clone of Belkin F7D1102 050d:1102.
Its FCC ID is the same.
Signed-off-by: Albert Pool <albertpool@solcon.nl>
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
commit c718a54649475cc397484f96e70f6d0fdd267165 upstream.
Fix several -Wuninitialized compiler warnings by changing the
order of getting modedb in riva_update_default_var() to set
first the fallback and then the prefered timing.
Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de>
Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
commit cecd353a02fb1405c8a72a324b26b5acf97e7411 upstream.
Set CommandMailbox with memset before use it. Fix for:
drivers/block/DAC960.c: In function ‘DAC960_V1_EnableMemoryMailboxInterface’:
arch/x86/include/asm/io.h:61:1: warning: ‘CommandMailbox.Bytes[12]’
may be used uninitialized in this function [-Wuninitialized]
drivers/block/DAC960.c:1175:30: note: ‘CommandMailbox.Bytes[12]’
was declared here
commit bca505f1097c725708ddc055cf8055e922b0904b upstream.
Fixed compiler warning:
comparison between ‘DAC960_V2_IOCTL_Opcode_T’ and ‘enum <anonymous>’
Renamed enum, added a new enum for SCSI_10.CommandOpcode in
DAC960_V2_ProcessCompletedCommand().
commit a4ac9fea016fc5c09227eb479bd35e34978323a4 upstream.
During debug of one SRIOV enabled hotplug device, we found found that
add_size is not passed properly.
The device has devices under two level bridges:
+-[0000:80]-+-00.0-[81-8f]--
| +-01.0-[90-9f]--
| +-02.0-[a0-af]----00.0-[a1-a3]--+-02.0-[a2]--+-00.0 Oracle Corporation Device
| | \-03.0-[a3]--+-00.0 Oracle Corporation Device
Which means later the parent bridge will not try to add a big enough range:
[ 557.455077] pci 0000:a0:00.0: BAR 14: assigned [mem 0xf9000000-0xf93fffff]
[ 557.461974] pci 0000:a0:00.0: BAR 15: assigned [mem 0xf6000000-0xf61fffff pref]
[ 557.469340] pci 0000:a1:02.0: BAR 14: assigned [mem 0xf9000000-0xf91fffff]
[ 557.476231] pci 0000:a1:02.0: BAR 15: assigned [mem 0xf6000000-0xf60fffff pref]
[ 557.483582] pci 0000:a1:03.0: BAR 14: assigned [mem 0xf9200000-0xf93fffff]
[ 557.490468] pci 0000:a1:03.0: BAR 15: assigned [mem 0xf6100000-0xf61fffff pref]
[ 557.497833] pci 0000:a1:03.0: BAR 14: can't assign mem (size 0x200000)
[ 557.504378] pci 0000:a1:03.0: failed to add optional resources res=[mem 0xf9200000-0xf93fffff]
[ 557.513026] pci 0000:a1:02.0: BAR 14: can't assign mem (size 0x200000)
[ 557.519578] pci 0000:a1:02.0: failed to add optional resources res=[mem 0xf9000000-0xf91fffff]
It turns out we did not calculate size1 properly.
static resource_size_t calculate_memsize(resource_size_t size,
resource_size_t min_size,
resource_size_t size1,
resource_size_t old_size,
resource_size_t align)
if (size < min_size)
size = min_size;
if (old_size == 1 )
old_size = 0;
if (size < old_size)
size = old_size;
size = ALIGN(size + size1, align);
return size;
We should not pass add_size with min_size in calculate_memsize since
that will make add_size not contribute final add_size.
So just pass add_size with size1 to calculate_memsize().
With this change, we should have chance to remove extra addon in
pci_reassign_resource.
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: Andrew Worsley <amworsley@gmail.com>
commit 2bbc6942273b5b3097bd265d82227bdd84b351b2 upstream.
Currently pci-bridges are allocated enough resources to satisfy their immediate
requirements. Any additional resource-requests fail if additional free space,
contiguous to the one already allocated, is not available. This behavior is not
reasonable since sufficient contiguous resources, that can satisfy the request,
are available at a different location.
This patch provides the ability to expand and relocate a allocated resource.
v2: Changelog: Fixed size calculation in pci_reassign_resource()
v3: Changelog : Split this patch. The resource.c changes are already
upstream. All the pci driver changes are in here.
Signed-off-by: Ram Pai <linuxram@us.ibm.com>
commit a9193983f4f292a82a00c72971c17ec0ee8c6c15 upstream.
The overlay on the i830M has a peculiar failure mode: It works the
first time around after boot-up, but consistenly hangs the second time
it's used.
Chris Wilson has dug out a nice errata:
"1.5.12 Clock Gating Disable for Display Register
Address Offset: 06200h–06203h
"Bit 3
Ovrunit Clock Gating Disable.
0 = Clock gating controlled by unit enabling logic
1 = Disable clock gating function
DevALM Errata ALM049: Overlay Clock Gating Must be Disabled: Overlay
& L2 Cache clock gating must be disabled in order to prevent device
hangs when turning off overlay.SW must turn off Ovrunit clock gating
(6200h) and L2 Cache clock gating (C8h)."
Now I've nowhere found that 0xc8 register and hence couldn't apply the
l2 cache workaround. But I've remembered that part of the magic that
the OVERLAY_ON/OFF commands are supposed to do is to rearrange cache
allocations so that the overlay scaler has some scratch space.
And while pondering how that could explain the hang the 2nd time we
enable the overlay, I've remembered that the old ums overlay code did
_not_ issue the OVERLAY_OFF cmd.
And indeed, disabling the OFF cmd results in the overlay working
flawlessly, so I guess we can workaround the lack of the above
workaround by simply never disabling the overlay engine once it's
enabled.
Note that we have the first part of the above w/a already implemented
in i830_init_clock_gating - leave that as-is to avoid surprises.
v2: Add a comment in the code.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=47827
Tested-by: Rhys <rhyspuk@gmail.com>
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
- Adjust context
- s/intel_ring_emit(ring, /OUT_RING(/]
commit d663d181b9e92d80c2455e460e932d34e7a2a7ae upstream.
Re-enable interrupts if it is not our interrupt
Signed-off-by: Mirko Lindner <mlindner@marvell.com>
Cc: Jonathan Nieder <jrnieder@gmail.com>
commit 0658a3366db7e27fa32c12e886230bb58c414c92 upstream.
The use of kfree(serial) in error cases of usb_serial_probe
was invalid - usb_serial structure allocated in create_serial()
gets reference of usb_device that needs to be put, so we need
to use usb_serial_put() instead of simple kfree().
Signed-off-by: Jan Safrata <jan.nikitenko@gmail.com>
Acked-by: Johan Hovold <jhovold@gmail.com>
Cc: Richard Retanubun <richardretanubun@ruggedcom.com>
commit aee77e4accbeb2c86b1d294cd84fec4a12dde3bd upstream.
The r8169 driver currently limits the DMA burst for TX to 1024 bytes. I have
a box where this prevents the interface from using the gigabit line to its full
potential. This patch solves the problem by setting TX_DMA_BURST to unlimited.
The box has an ASRock B75M motherboard with on-board RTL8168evl/8111evl
(XID 0c900880). TSO is enabled.
I used netperf (TCP_STREAM test) to measure the dependency of TX throughput
on MTU. I did it for three different values of TX_DMA_BURST ('5'=512, '6'=1024,
'7'=unlimited). This chart shows the results:
http://michich.fedorapeople.org/r8169/r8169-effects-of-TX_DMA_BURST.png
Interesting points:
- With the current DMA burst limit (1024):
- at the default MTU=1500 I get only 842 Mbit/s.
- when going from small MTU, the performance rises monotonically with
increasing MTU only up to a peak at MTU=1076 (908 MBit/s). Then there's
a sudden drop to 762 MBit/s from which the throughput rises monotonically
again with further MTU increases.
- With a smaller DMA burst limit (512):
- there's a similar peak at MTU=1076 and another one at MTU=564.
- With unlimited DMA burst:
- at the default MTU=1500 I get nice 940 Mbit/s.
- the throughput rises monotonically with increasing MTU with no strange
peaks.
Notice that the peaks occur at MTU sizes that are multiples of the DMA burst
limit plus 52. Why 52? Because:
20 (IP header) + 20 (TCP header) + 12 (TCP options) = 52
The Realtek-provided r8168 driver (v8.032.00) uses unlimited TX DMA burst too,
except for CFG_METHOD_1 where the TX DMA burst is set to 512 bytes.
CFG_METHOD_1 appears to be the oldest MAC version of "RTL8168B/8111B",
i.e. RTL_GIGA_MAC_VER_11 in r8169. Not sure if this MAC version really needs
the smaller burst limit, or if any other versions have similar requirements.
Signed-off-by: Michal Schmidt <mschmidt@redhat.com>
Acked-by: Francois Romieu <romieu@fr.zoreil.com>
commit c0bc3098871dd9b964f6b45ec1e4d70d87811744 upstream.
Signed-off-by: Dan Williams <dcbw@redhat.com>
commit fcb21645f1bd86d2be29baf48aa1b298de52ccc7 upstream.
The Dell 5800 appears to be a simple rebrand of the Novatel E362.
commit 3e7abe2556b583e87dabda3e0e6178a67b20d06f upstream.
When unbinding a device so that I could pass it through to a KVM VM, I
got the lockdep report below. It looks like a legitimate lock
ordering problem:
- domain_context_mapping_one() takes iommu->lock and calls
iommu_support_dev_iotlb(), which takes device_domain_lock (inside
iommu->lock).
- domain_remove_one_dev_info() starts by taking device_domain_lock
then takes iommu->lock inside it (near the end of the function).
So this is the classic AB-BA deadlock. It looks like a safe fix is to
simply release device_domain_lock a bit earlier, since as far as I can
tell, it doesn't protect any of the stuff accessed at the end of
domain_remove_one_dev_info() anyway.
BTW, the use of device_domain_lock looks a bit unsafe to me... it's
at least not obvious to me why we aren't vulnerable to the race below:
domain_remove_dev_info()
lock device_domain_lock
find info
unlock device_domain_lock
find same info
free_devinfo_mem(info)
do stuff with info after it's free
However I don't understand the locking here well enough to know if
this is a real problem, let alone what the best fix is.
Anyway here's the full lockdep output that prompted all of this:
[ INFO: possible circular locking dependency detected ]
2.6.39.1+ #1
bash/13954 is trying to acquire lock:
(&(&iommu->lock)->rlock){......}, at: [<ffffffff812f6421>] domain_remove_one_dev_info+0x121/0x230
but task is already holding lock:
(device_domain_lock){-.-...}, at: [<ffffffff812f6508>] domain_remove_one_dev_info+0x208/0x230
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #1 (device_domain_lock){-.-...}:
[<ffffffff8109ca9d>] lock_acquire+0x9d/0x130
[<ffffffff81571475>] _raw_spin_lock_irqsave+0x55/0xa0
[<ffffffff812f8350>] domain_context_mapping_one+0x600/0x750
[<ffffffff812f84df>] domain_context_mapping+0x3f/0x120
[<ffffffff812f9175>] iommu_prepare_identity_map+0x1c5/0x1e0
[<ffffffff81ccf1ca>] intel_iommu_init+0x88e/0xb5e
[<ffffffff81cab204>] pci_iommu_init+0x16/0x41
[<ffffffff81002165>] do_one_initcall+0x45/0x190
[<ffffffff81ca3d3f>] kernel_init+0xe3/0x168
[<ffffffff8157ac24>] kernel_thread_helper+0x4/0x10
-> #0 (&(&iommu->lock)->rlock){......}:
[<ffffffff8109bf3e>] __lock_acquire+0x195e/0x1e10
[<ffffffff812f8b42>] device_notifier+0x72/0x90
[<ffffffff8157555c>] notifier_call_chain+0x8c/0xc0
[<ffffffff81089768>] __blocking_notifier_call_chain+0x78/0xb0
[<ffffffff810897b6>] blocking_notifier_call_chain+0x16/0x20
[<ffffffff81373a5c>] __device_release_driver+0xbc/0xe0
[<ffffffff81373ccf>] device_release_driver+0x2f/0x50
[<ffffffff81372ee3>] driver_unbind+0xa3/0xc0
[<ffffffff813724ac>] drv_attr_store+0x2c/0x30
[<ffffffff811e4506>] sysfs_write_file+0xe6/0x170
[<ffffffff8117569e>] vfs_write+0xce/0x190
[<ffffffff811759e4>] sys_write+0x54/0xa0
[<ffffffff81579a82>] system_call_fastpath+0x16/0x1b
6 locks held by bash/13954:
#0: (&buffer->mutex){+.+.+.}, at: [<ffffffff811e4464>] sysfs_write_file+0x44/0x170
#1: (s_active#3){++++.+}, at: [<ffffffff811e44ed>] sysfs_write_file+0xcd/0x170
#2: (&__lockdep_no_validate__){+.+.+.}, at: [<ffffffff81372edb>] driver_unbind+0x9b/0xc0
#3: (&__lockdep_no_validate__){+.+.+.}, at: [<ffffffff81373cc7>] device_release_driver+0x27/0x50
#4: (&(&priv->bus_notifier)->rwsem){.+.+.+}, at: [<ffffffff8108974f>] __blocking_notifier_call_chain+0x5f/0xb0
#5: (device_domain_lock){-.-...}, at: [<ffffffff812f6508>] domain_remove_one_dev_info+0x208/0x230
stack backtrace:
Pid: 13954, comm: bash Not tainted 2.6.39.1+ #1
Call Trace:
[<ffffffff810993a7>] print_circular_bug+0xf7/0x100
[<ffffffff810972bd>] ? trace_hardirqs_off+0xd/0x10
[<ffffffff8109d57d>] ? trace_hardirqs_on_caller+0x13d/0x180
[<ffffffff812f6421>] ? domain_remove_one_dev_info+0x121/0x230
Signed-off-by: Roland Dreier <roland@purestorage.com>
Fix warning about unused variable introduced by commit e681b66f2e19fa
("USB: mos7840: remove invalid disconnect handling") upstream.
A subsequent fix which removed the disconnect function got rid of the
warning but that one was only backported to v3.6.
Reported-by: Jiri Slaby <jslaby@suse.cz>
commit b6e0e543f75729f207b9c72b0162ae61170635b2 upstream.
Like in the case of native hdmi, which is fixed already in
commit adf00b26d18e1b3570451296e03bcb20e4798cdd
Author: Paulo Zanoni <paulo.r.zanoni@intel.com>
Date: Tue Sep 25 13:23:34 2012 -0300
drm/i915: make sure we write all the DIP data bytes
we need to clear the entire sdvo buffer to avoid upsetting the
display.
Since infoframe buffer writing is now a bit more elaborate, extract it
into it's own function. This will be useful if we ever get around to
properly update the ELD for sdvo. Also #define proper names for the
two buffer indexes with fixed usage.
v2: Cite the right commit above, spotted by Paulo Zanoni.
v3: I'm too stupid to paste the right commit.
v4: Ben Hutchings noticed that I've failed to handle an underflow in
my loop logic, breaking it for i >= length + 8. Since I've just lost C
programmer license, use his solution. Also, make the frustrated 0-base
buffer size a notch more clear.
Reported-and-tested-by: Jürg Billeter <j@bitron.ch>
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=25732
Cc: Paulo Zanoni <przanoni@gmail.com>
Reviewed-by: Rodrigo Vivi <rodrigo.vivi@gmail.com>
commit 81014b9d0b55fb0b48f26cd2a943359750d532db upstream.
At least the worst offenders:
- SDVO specifies that the encoder should compute the ecc. Testing also
shows that we must not send the ecc field, so copy the dip_infoframe
struct to a temporay place and avoid the ecc field. This way the avi
infoframe is exactly 17 bytes long, which agrees with what the spec
mandates as a minimal storage capacity (with the ecc field it would
be 18 bytes).
- Only 17 when sending the avi infoframe. The SDVO spec explicitly
says that sending more data than what the device announces results
in undefined behaviour.
- Add __attribute__((packed)) to the avi and spd infoframes, for
otherwise they're wrongly aligned. Noticed because the avi infoframe
ended up being 18 bytes large instead of 17. We haven't noticed this
yet because we don't use the uint16_t fields yet (which are the only
ones that would be wrongly aligned).
This regression has been introduce by
3c17fe4b8f40a112a85758a9ab2aebf772bdd647 is the first bad commit
commit 3c17fe4b8f40a112a85758a9ab2aebf772bdd647
Author: David Härdeman <david@hardeman.nu>
Date: Fri Sep 24 21:44:32 2010 +0200
i915: enable AVI infoframe for intel_hdmi.c [v4]
Patch tested on my g33 with a sdvo hdmi adaptor.
Tested-by: Peter Ross <pross@xvid.org> (G35 SDVO-HDMI)
Reviewed-by: Eugeni Dodonov <eugeni.dodonov@intel.com>
Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 95e8f6a21996c4cc2c4574b231c6e858b749dce3 upstream.
The device would not reset properly when resuming from hibernation.
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
Reviewed-by: Brian Paul <brianp@vmware.com>
Reviewed-by: Dmitry Torokhov <dtor@vmware.com>
Cc: linux-graphics-maintainer@vmware.com
[ Upstream commit 39707c2a3ba5011038b363f84d37c8a98d2d9db1 ]
Driver anchors the tx urbs and defers the urb submission if
a transmit request comes when the interface is suspended.
Anchoring urb increments the urb reference count. These
deferred urbs are later accessed by calling usb_get_from_anchor()
for submission during interface resume. usb_get_from_anchor()
unanchors the urb but urb reference count remains same.
This causes the urb reference count to remain non-zero
after usb_free_urb() gets called and urb never gets freed.
Hence call usb_put_urb() after anchoring the urb to properly
balance the reference count for these deferred urbs. Also,
unanchor these deferred urbs during disconnect, to free them
up.
Signed-off-by: Hemant Kumar <hemantk@codeaurora.org>
Acked-by: Oliver Neukum <oneukum@suse.de>
commit 3300fb4f88688029fff8dfb9ec0734f6e4cba3e7 upstream.
Don't assume bank 0 is selected at device probe time. This may not be
the case. Force bank selection at first register access to guarantee
that we read the right registers upon driver loading.
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
commit 0f1cb1bd94a9c967cd4ad3de51cfdabe61eb5dcc upstream.
If drm_setup (called at first open) fails, the whole
open call has failed, so we should not keep the
open_count incremented.
Signed-off-by: Ilija Hadzic <ihadzic@research.bell-labs.com>
Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com>
commit 83325d072185899b706de2956170b246585aaec9 upstream.
An uninitialized variable led to broken load detection.
Signed-off-by: Egbert Eich <eich@suse.de>
commit 0d0f9dfb31e0a6c92063e235417b42df185b3275 upstream.
If the call to core_dev_release_virtual_lun0() fails, then nothing
sets ret to anything other than 0, so even though everything is
torn down and freed, target_core_init_configfs() will seem to succeed
and the module will be loaded. Fix this by passing the return value
on up the chain.
commit bf7e1abe434ba9e22e8dc04a4cba4ab504b788b8 upstream.
Some hardware has correct (!= 0xff) value of tssi_bounds[4] in the
EEPROM, but step is equal to 0xff. This results on ridiculous delta
calculations and completely broke TX power settings.
Reported-and-tested-by: Pavel Lucik <pavel.lucik@gmail.com>
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Acked-by: Ivo van Doorn <IvDoorn@gmail.com>
commit 8c6e30936a7893a85f6222084f0f26aceb81137a upstream.
bf->bf_next is only while buffers are chained as part of an A-MPDU
in the tx queue. When a tid queue is flushed (e.g. on tearing down
an aggregation session), frames can be enqueued again as normal
transmission, without bf_next being cleared. This can lead to the
old pointer being dereferenced again later.
This patch might fix crashes and "Failed to stop TX DMA!" messages.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
commit cee59f15a60cc6269a25e3f6fbf1a577d6ab8115 upstream.
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
commit f6365201d8a21fb347260f89d6e9b3e718d63c70 upstream.
The X86_32-only disable_hlt/enable_hlt mechanism was used by the
32-bit floppy driver. Its effect was to replace the use of the
HLT instruction inside default_idle() with cpu_relax() - essentially
it turned off the use of HLT.
This workaround was commented in the code as:
"disable hlt during certain critical i/o operations"
"This halt magic was a workaround for ancient floppy DMA
wreckage. It should be safe to remove."
H. Peter Anvin additionally adds:
"To the best of my knowledge, no-hlt only existed because of
flaky power distributions on 386/486 systems which were sold to
run DOS. Since DOS did no power management of any kind,
including HLT, the power draw was fairly uniform; when exposed
to the much hhigher noise levels you got when Linux used HLT
caused some of these systems to fail.
They were by far in the minority even back then."
Alan Cox further says:
"Also for the Cyrix 5510 which tended to go castors up if a HLT
occurred during a DMA cycle and on a few other boxes HLT during
DMA tended to go astray.
Do we care ? I doubt it. The 5510 was pretty obscure, the 5520
fixed it, the 5530 is probably the oldest still in any kind of
use."
So, let's finally drop this.
Signed-off-by: Len Brown <len.brown@intel.com>
Signed-off-by: Josh Boyer <jwboyer@redhat.com>
Acked-by: "H. Peter Anvin" <hpa@zytor.com>
Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Stephen Hemminger <shemminger@vyatta.com
Link: http://lkml.kernel.org/n/tip-3rhk9bzf0x9rljkv488tloib@git.kernel.org
[ If anyone cares then alternative instruction patching could be
used to replace HLT with a one-byte NOP instruction. Much simpler. ]
commit 238ab78469c6ab7845b43d5061cd3c92331b2452 upstream.
If blk_init_queue fails, we do not call put_disk on the current dr
(dr is decremented first in the error handling loop).
Reviewed-by: Ben Hutchings <ben@decadent.org.uk>
Signed-off-by: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com>
commit 9756fe38d10b2bf90c81dc4d2f17d5632e135364 upstream.
This box claims to have an LVDS interface but doesn't
actually have one.
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
commit aaeb61a97b7159ebe30b18a422d04eeabfa8790b upstream.
`pc236_detach()` is called by the comedi core if it attempted to attach
a device and failed. `pc236_detach()` calls `pc236_intr_disable()` if
the comedi device private data pointer (`devpriv`) is non-null. This
test is insufficient as `pc236_intr_disable()` accesses hardware
registers and the attach routine may have failed before it has saved
their I/O base addresses.
Fix it by checking `dev->iobase` is non-zero before calling
`pc236_intr_disable()` as that means the I/O base addresses have been
saved and the hardware registers can be accessed. It also implies the
comedi device private data pointer is valid, so there is no need to
check it.
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
commit e4df1cbcc1f329e53a1fff7450b2229e0addff20 upstream.
Commit 6889125b8b4e09c5e53e6ecab3433bed1ce198c9
(cpufreq/powernow-k8: workqueue user shouldn't migrate the kworker to another CPU)
causes powernow-k8 to trigger a preempt warning, e.g.:
BUG: using smp_processor_id() in preemptible [00000000] code: cpufreq/3776
caller is powernowk8_target+0x20/0x49
Pid: 3776, comm: cpufreq Not tainted 3.6.0 #9
Call Trace:
[<ffffffff8125b447>] debug_smp_processor_id+0xc7/0xe0
[<ffffffff814877e7>] powernowk8_target+0x20/0x49
[<ffffffff81482b02>] __cpufreq_driver_target+0x82/0x8a
[<ffffffff81484fc6>] cpufreq_governor_performance+0x4e/0x54
[<ffffffff81482c50>] __cpufreq_governor+0x8c/0xc9
[<ffffffff81482e6f>] __cpufreq_set_policy+0x1a9/0x21e
[<ffffffff814839af>] store_scaling_governor+0x16f/0x19b
[<ffffffff81484f16>] ? cpufreq_update_policy+0x124/0x124
[<ffffffff8162b4a5>] ? _raw_spin_unlock_irqrestore+0x2c/0x49
[<ffffffff81483640>] store+0x60/0x88
[<ffffffff811708c0>] sysfs_write_file+0xf4/0x130
[<ffffffff8111243b>] vfs_write+0xb5/0x151
[<ffffffff811126e0>] sys_write+0x4a/0x71
[<ffffffff816319a9>] system_call_fastpath+0x16/0x1b
Fix this by by always using work_on_cpu().
Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com>
commit 1fffa905adffbf0d3767fc978ef09afb830275eb upstream.
When cores are unregistered, entries
need to be removed from cores list in a safe manner.
Reported-by: Stanislaw Gruszka <sgruszka@redhat.com>
Reviewed-by: Arend Van Spriel <arend@broadcom.com>
Signed-off-by: Piotr Haber <phaber@broadcom.com>
commit 910a578f7e9400a78a3b13aba0b4d2df16a2cb05 upstream.
We copy head count to a 16 bit field, this works by chance on LE but on
BE guest gets 0. Fix it up.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Tested-by: Alexander Graf <agraf@suse.de>
commit 43a09f7fb01fa1e091416a2aa49b6c666458c1ee upstream.
The command cancellation code doesn't check whether find_trb_seg()
couldn't find the segment that contains the TRB to be canceled. This
could cause a NULL pointer deference later in the function when next_trb
is called. It's unlikely to happen unless something is wrong with the
command ring pointers, so add some debugging in case it happens.
This patch should be backported to stable kernels as old as 3.0, that
contain the commit b63f4053cc8aa22a98e3f9a97845afe6c15d0a0d "xHCI:
handle command after aborting the command ring".
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
commit e681b66f2e19fadbe8a7e2a17900978cb6bc921f upstream.
Remove private zombie flag used to signal disconnect and to prevent
control urb from being submitted from interrupt urb completion handler.
The control urb will not be re-submitted as both the control urb and the
interrupt urb is killed on disconnect.
commit 28c3ae9a8cf45f439c9a0779ebd0256e2ae72813 upstream.
The private int_urb is never allocated so the submission from the
control completion handler will always fail. Remove this odd piece of
broken code.
commit 3eb55cc4ed88eee3b5230f66abcdbd2a91639eda upstream.
The driver set the usb-serial port pointers to NULL on errors in attach,
effectively preventing usb-serial core from decrementing the port ref
counters and releasing the port devices and associated data.
