path: root/drivers
2011-03-07Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: [S390] tape: deadlock on system work queue [S390] keyboard: integer underflow bug [S390] xpram: remove __initdata attribute from module parameters
2011-03-06virtio: console: Don't access vqs if device was unpluggedAmit Shah
If a virtio-console device gets unplugged while a port is open, a subsequent close() call on the port accesses vqs to free up buffers. This can lead to a crash. The buffers are already freed up as a result of the call to unplug_ports() from virtcons_remove(). The fix is to simply not access vq information if port->portdev is NULL. Reported-by: juzhang <juzhang@redhat.com> CC: stable@kernel.org Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-04drivers/video/backlight/ltv350qv.c: fix a memory leakAxel Lin
Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-04pps: make pps_gen_parport depend on BROKENThomas Gleixner
This driver causes hard lockups, when the active clock soure is jiffies. The reason is that it loops with interrupts disabled waiting for a timestamp to be reached by polling getnstimeofday(). Though with a jiffies clocksource, when that code runs on the same CPU which is responsible for updating jiffies, then we loop in circles for ever simply because the timer interrupt cannot update jiffies. So both UP and SMP can be affected. There is no easy fix for that problem so make it depend on BROKEN for now. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Alexander Gordeev <lasaine@lvk.cs.msu.su> Cc: Rodolfo Giometti <giometti@linux.it> Cc: john stultz <johnstul@us.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-04drivers/misc/bmp085.c: add MODULE_DEVICE_TABLEAxel Lin
The device table is required to load modules based on modaliases. Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Shubhrajyoti D <shubhrajyoti@ti.com> Cc: Christoph Mair <christoph.mair@gmail.com> Cc: Jonathan Cameron <jic23@cam.ac.uk> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-04drivers/rtc/rtc-s3c.c: fix prototype for s3c_rtc_setaie()Axel Lin
Fix s3c_rtc_setaie() prototype to eliminate the following compile warning: drivers/rtc/rtc-s3c.c:383: warning: initialization from incompatible pointer type (akpm: the rtc_class_ops.alarm_irq_enable() handler is being passed two arguments where it expects just one, presumably with undesired effects) Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-04drm/nouveau: allocate kernel's notifier object at end of blockBen Skeggs
The nv30/nv40 3d driver is about to start using DMA_FENCE from the 3D object which, it turns out, doesn't like its DMA object to not be aligned to a 4KiB boundary. Signed-off-by: Ben Skeggs <bskeggs@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-03-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (42 commits) MAINTAINERS: Add Andy Gospodarek as co-maintainer. r8169: disable ASPM RxRPC: Fix v1 keys AF_RXRPC: Handle receiving ACKALL packets cnic: Fix lost interrupt on bnx2x cnic: Prevent status block race conditions with hardware net: dcbnl: check correct ops in dcbnl_ieee_set() e1000e: disable broken PHY wakeup for ICH10 LOMs, use MAC wakeup instead igb: fix sparse warning e1000: fix sparse warning netfilter: nf_log: avoid oops in (un)bind with invalid nfproto values dccp: fix oops on Reset after close ipvs: fix dst_lock locking on dest update davinci_emac: Add Carrier Link OK check in Davinci RX Handler bnx2x: update driver version to 1.62.00-6 bnx2x: properly calculate lro_mss bnx2x: perform statistics "action" before state transition. bnx2x: properly configure coefficients for MinBW algorithm (NPAR mode). bnx2x: Fix ethtool -t link test for MF (non-pmf) devices. bnx2x: Fix nvram test for single port devices. ...
2011-03-03Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: block: kill loop_mutex blktrace: Remove blk_fill_rwbs_rq. block: blk-flush shouldn't call directly into q->request_fn() __blk_run_queue() block: add @force_kblockd to __blk_run_queue() block: fix kernel-doc format for blkdev_issue_zeroout blk-throttle: Do not use kblockd workqueue for throtl work
2011-03-03r8169: disable ASPMStanislaw Gruszka
For some time is known that ASPM is causing troubles on r8169, i.e. make device randomly stop working without any errors in dmesg. Currently Tomi Leppikangas reports that system with r8169 device hangs with MCE errors when ASPM is enabled: https://bugzilla.redhat.com/show_bug.cgi?id=642861#c4 Lets disable ASPM for r8169 devices at all, to avoid problems with r8169 PCIe devices at least for some users. Reported-by: Tomi Leppikangas <tomi.leppikangas@gmail.com> Cc: stable@kernel.org Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-03[S390] tape: deadlock on system work queueMartin Schwidefsky
The 34xx and 3590 tape driver uses the system work queue to defer work from the interrupt function to process context, e.g. a medium sense after an unsolicited interrupt. The tape commands started by the work handler need to be asynchronous, otherwise a deadlock on the system work queue can occur. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-03-03[S390] keyboard: integer underflow bugDan Carpenter
The "ct" variable should be an unsigned int. Both struct kbdiacrs ->kb_cnt and struct kbd_data ->accent_table_size are unsigned ints. Making it signed causes a problem in KBDIACRUC because the user could set the signed bit and cause a buffer overflow. Cc: <stable@kernel.org> Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-03-03[S390] xpram: remove __initdata attribute from module parametersMartin Schwidefsky
The module parameter 'devs' and 'sizes' are marked as __initdata. The memory for the parameters are freed after module_init completed. This can lead to kernel crashes in param_free_charp. Remove the __initdata attribute to fix the problem. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-03-03block: kill loop_mutexPetr Uzel
Following steps lead to deadlock in kernel: dd if=/dev/zero of=img bs=512 count=1000 losetup -f img mkfs.ext2 /dev/loop0 mount -t ext2 -o loop /dev/loop0 mnt umount mnt/ Stacktrace: [<c102ec04>] irq_exit+0x36/0x59 [<c101502c>] smp_apic_timer_interrupt+0x6b/0x75 [<c127f639>] apic_timer_interrupt+0x31/0x38 [<c101df88>] mutex_spin_on_owner+0x54/0x5b [<fe2250e9>] lo_release+0x12/0x67 [loop] [<c10c4eae>] __blkdev_put+0x7c/0x10c [<c10a4da5>] fput+0xd5/0x1aa [<fe2250cf>] loop_clr_fd+0x1a9/0x1b1 [loop] [<fe225110>] lo_release+0x39/0x67 [loop] [<c10c4eae>] __blkdev_put+0x7c/0x10c [<c10a59d9>] deactivate_locked_super+0x17/0x36 [<c10b6f37>] sys_umount+0x27e/0x2a5 [<c10b6f69>] sys_oldumount+0xb/0xe [<c1002897>] sysenter_do_call+0x12/0x26 [<ffffffff>] 0xffffffff Regression since 2a48fc0ab24241755dc9, which introduced the private loop_mutex as part of the BKL removal process. As per [1], the mutex can be safely removed. [1] http://www.gossamer-threads.com/lists/linux/kernel/1341930 Addresses: https://bugzilla.novell.com/show_bug.cgi?id=669394 Addresses: https://bugzilla.kernel.org/show_bug.cgi?id=29172 Signed-off-by: Petr Uzel <petr.uzel@suse.cz> Cc: stable@kernel.org Reviewed-by: Nikanth Karthikesan <knikanth@suse.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-02Merge branch 'drm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: drm/i915: fix memory corruption with GM965 and >4GB RAM
2011-03-02Merge branch 'devicetree/merge' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'devicetree/merge' of git://git.secretlab.ca/git/linux-2.6: of/promtree: allow DT device matching by fixing 'name' brokenness (v5) x86: OLPC: have prom_early_alloc BUG rather than return NULL of/flattree: Drop an uninteresting message to pr_debug level of: Add missing of_address.h to xilinx ehci driver
2011-03-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: mfd: Avoid tps6586x burst writes mfd: Don't suspend WM8994 if the CODEC is not suspended mfd: Fix DaVinci voice codec device name mfd: Fix NULL pointer due to non-initialized ucb1x00-ts absinfo mfd: Fix ASIC3 build with GENERIC_HARDIRQS_NO_DEPRECATED
2011-03-02Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] p4-clockmod: print EST-capable warning message only once [CPUFREQ] fix BUG on cpufreq policy init failure [CPUFREQ] Fix another notifier leak in powernow-k8. [CPUFREQ] Missing "unregister_cpu_notifier" in powernow-k8.c
2011-03-02Merge branch 'idle-release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6 * 'idle-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6: intel_idle: disable Atom/Lincroft HW C-state auto-demotion intel_idle: disable NHM/WSM HW C-state auto-demotion
2011-03-02cnic: Fix lost interrupt on bnx2xMichael Chan
We service 2 queues (kcq1 and kcq2) in cnic_service_bnx2x_bh(). If the status block index has changed when servicing the kcq2, we must go back and check kcq1. The latest status block index will be used to acknowledge the interrupt, and without looping back to check kcq1, we may miss events on kcq1. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-02cnic: Prevent status block race conditions with hardwareMichael Chan
The status block index is used to acknowledge interrupt events and must be read before checking for the interrupt events, so we need to add rmb() to guarantee that. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-02Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: ACPI / ACPICA: Implicit notify for multiple devices ACPI / debugfs: Fix buffer overflows, double free
2011-03-02Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/jkirsher/net-2.6
2011-03-02of/promtree: allow DT device matching by fixing 'name' brokenness (v5)Andres Salomon
Commit e2f2a93b, "of/promtree: add package-to-path support to pdt" changed dp->name from using the 'name' property to using package-to-path. This fixed /proc/device-tree creation by eliminating conflicts between names (the 'name' property provides names like 'battery', whereas package-to-path provides names like '/foo/bar/battery@0', which we stripped to 'battery@0'). However, it also breaks of_device_id table matching. The fix that we _really_ wanted was to keep dp->name based upon the name property ('battery'), but based dp->full_name upon package-to-path ('battery@0'). This patch does just that. This changes all users (except SPARC) of promtree to use the full result from package-to-path for full_name, rather than stripping the directory out. In practice, the strings end up being exactly the same; this change saves time, code, and memory. SPARC continues to use the existing build_path_component() code. v2: combine two patches and revert of_pdt_node_name to original version v3: use dp->phandle instead of passing around node v4: warn/bail out for non-sparc archs if pkg2path is not set v5: split of_pdt_build_full_name into sparc & non-sparc versions v6: Pass NULL to pkg2path before buf gets assigned. Drop check for pkg2path hook on each and every node. v7: Don't BUG() when unable to get the full_path; create a known-unique name instead. Signed-off-by: Andres Salomon <dilinger@queued.net> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-02of: Add missing of_address.h to xilinx ehci driverMichal Simek
Build log: In file included from drivers/usb/host/ehci-hcd.c:1208: drivers/usb/host/ehci-xilinx-of.c: In function 'ehci_hcd_xilinx_of_probe': drivers/usb/host/ehci-xilinx-of.c:168: error: implicit declaration of function 'of_address_to_resource' Signed-off-by: John Williams <john.williams@petalogix.com> Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-02block: add @force_kblockd to __blk_run_queue()Tejun Heo
__blk_run_queue() automatically either calls q->request_fn() directly or schedules kblockd depending on whether the function is recursed. blk-flush implementation needs to be able to explicitly choose kblockd. Add @force_kblockd. All the current users are converted to specify %false for the parameter and this patch doesn't introduce any behavior change. stable: This is prerequisite for fixing ide oops caused by the new blk-flush implementation. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jan Beulich <JBeulich@novell.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-02e1000e: disable broken PHY wakeup for ICH10 LOMs, use MAC wakeup insteadBruce Allan
When support for 82577/82578 was added[1] in 2.6.31, PHY wakeup was in- advertently enabled (even though it does not function properly) on ICH10 LOMs. This patch makes it so that the ICH10 LOMs use MAC wakeup instead as was done with the initial support for those devices (i.e. 82567LM-3, 82567LF-3 and 82567V-4). [1] commit a4f58f5455ba0efda36fb33c37074922d1527a10 Reported-by: Aurelien Jarno <aurelien@aurel32.net> Cc: <stable@kernel.org> Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-03-02igb: fix sparse warningJeff Kirsher
Reported-by: Stephen Hemminger <shemminger@vyatta.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-03-02e1000: fix sparse warningStephen Hemminger
Sparse complains because the e1000 driver is calling ioread on a pointer not tagged as __iomem. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Reviewed-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-03-02mfd: Avoid tps6586x burst writesvwadekar@nvidia.com
tps6586 does not support burst writes. i2c writes have to be 1 byte at a time. Cc: stable@kernel.org Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-03-02mfd: Don't suspend WM8994 if the CODEC is not suspendedMark Brown
ASoC supports keeping the audio subsysetm active over suspend in order to support use cases such as audio passthrough from a cellular modem with the main CPU suspended. Ensure that we don't power down the CODEC when this is happening by checking to see if VMID is up and skipping suspend and resume when it is. If the CODEC has suspended then it'll turn VMID off before the core suspend() gets called. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-03-02mfd: Fix DaVinci voice codec device nameManjunathappa, Prakash
Fix the device name in DaVinci Voice Codec MFD driver to load davinci-vcif and cq93vc codec client drivers. Signed-off-by: Manjunathappa, Prakash <prakash.pm@ti.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-03-02mfd: Fix NULL pointer due to non-initialized ucb1x00-ts absinfoJochen Friedrich
Call input_set_abs_params instead of manually setting absbit only. This fixes this oops: Unable to handle kernel NULL pointer dereference at virtual address 00000024 Internal error: Oops: 41b67017 [#1] CPU: 0 Not tainted (2.6.37 #4) pc : [<c016d1fc>] lr : [<00000000>] psr: 20000093 sp : c19e5f30 ip : c19e5e6c fp : c19e5f58 r10: 00000000 r9 : c19e4000 r8 : 00000003 r7 : 000001e4 r6 : 00000001 r5 : c1854400 r4 : 00000003 r3 : 00000018 r2 : 00000018 r1 : 00000018 r0 : c185447c Flags: nzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel Control: c1b6717f Table: c1b6717f DAC: 00000017 Stack: (0xc19e5f30 to 0xc19e6000) 5f20: 00000003 00000003 c1854400 00000013 5f40: 00000001 000001e4 000001c5 c19e5f80 c19e5f5c c016d5e8 c016cf5c 000001e4 5f60: c1854400 c18b5860 00000000 00000171 000001e4 c19e5fc4 c19e5f84 c01559a4 5f80: c016d584 c18b5868 00000000 c1bb5c40 c0035afc c18b5868 c18b5868 c1a55d54 5fa0: c18b5860 c0155750 00000013 00000000 00000000 00000000 c19e5ff4 c19e5fc8 5fc0: c0050174 c015575c 00000000 c18b5860 00000000 c19e5fd4 c19e5fd4 c1a55d54 5fe0: c00500f0 c003b464 00000000 c19e5ff8 c003b464 c00500fc 04000400 04000400 Backtrace: Function entered at [<c016cf50>] from [<c016d5e8>] Function entered at [<c016d578>] from [<c01559a4>] r8:000001e4 r7:00000171 r6:00000000 r5:c18b5860 r4:c1854400 Function entered at [<c0155750>] from [<c0050174>] Function entered at [<c00500f0>] from [<c003b464>] r6:c003b464 r5:c00500f0 r4:c1a55d54 Code: e59520fc e1a03286 e0433186 e0822003 (e592000c) >>PC; c016d1fc <input_handle_event+2ac/5a0> <===== Trace; c016cf50 <input_handle_event+0/5a0> Trace; c016d5e8 <input_event+70/88> Trace; c016d578 <input_event+0/88> Trace; c01559a4 <ucb1x00_thread+254/2dc> Trace; c0155750 <ucb1x00_thread+0/2dc> Trace; c0050174 <kthread+84/8c> Trace; c00500f0 <kthread+0/8c> Trace; c003b464 <do_exit+0/624> Signed-off-by: Jochen Friedrich <jochen@scram.de> CC: stable@kernel.org Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-03-02mfd: Fix ASIC3 build with GENERIC_HARDIRQS_NO_DEPRECATEDLennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-03-01[CPUFREQ] fix BUG on cpufreq policy init failureJiri Slaby
cpufreq_register_driver sets cpufreq_driver to a structure owned (and placed) in the caller's memory. If cpufreq policy fails in its ->init function, sysdev_driver_register returns nonzero in cpufreq_register_driver. Now, cpufreq_register_driver returns an error without setting cpufreq_driver back to NULL. Usually cpufreq policy modules are unloaded because they propagate the error to the module init function and return that. So a later access to any member of cpufreq_driver causes bugs like: BUG: unable to handle kernel paging request at ffffffffa00270a0 IP: [<ffffffff8145eca3>] cpufreq_cpu_get+0x53/0xe0 PGD 1805067 PUD 1809063 PMD 1c3f90067 PTE 0 Oops: 0000 [#1] SMP last sysfs file: /sys/devices/virtual/net/tun0/statistics/collisions CPU 0 Modules linked in: ... Pid: 5677, comm: thunderbird-bin Tainted: G W 2.6.38-rc4-mm1_64+ #1389 To be filled by O.E.M./To Be Filled By O.E.M. RIP: 0010:[<ffffffff8145eca3>] [<ffffffff8145eca3>] cpufreq_cpu_get+0x53/0xe0 RSP: 0018:ffff8801aec37d98 EFLAGS: 00010086 RAX: 0000000000000202 RBX: 0000000000000000 RCX: 0000000000000001 RDX: ffffffffa00270a0 RSI: 0000000000001000 RDI: ffffffff8199ece8 ... Call Trace: [<ffffffff8145f490>] cpufreq_quick_get+0x10/0x30 [<ffffffff8103f12b>] show_cpuinfo+0x2ab/0x300 [<ffffffff81136292>] seq_read+0xf2/0x3f0 [<ffffffff8126c5d3>] ? __strncpy_from_user+0x33/0x60 [<ffffffff8116850d>] proc_reg_read+0x6d/0xa0 [<ffffffff81116e53>] vfs_read+0xc3/0x180 [<ffffffff81116f5c>] sys_read+0x4c/0x90 [<ffffffff81030dbb>] system_call_fastpath+0x16/0x1b ... It's all cause by weird fail path handling in cpufreq_register_driver. To fix that, shuffle the code to do proper handling with gotos. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Dave Jones <davej@redhat.com>
2011-03-01drm/i915: fix memory corruption with GM965 and >4GB RAMJan Niehusmann
On a Thinkpad x61s, I noticed some memory corruption when plugging/unplugging the external VGA connection. The symptoms are that 4 bytes at the beginning of a page get overwritten by zeroes. The address of the corruption varies when rebooting the machine, but stays constant while it's running (so it's possible to repeatedly write some data and then corrupt it again by plugging the cable). Further investigation revealed that the corrupted address is (dev_priv->status_page_dmah->busaddr & 0xffffffff), ie. the beginning of the hardware status page of the i965 graphics card, cut to 32 bits. So it seems that for some memory access, the hardware uses only 32 bit addressing. If the hardware status page is located >4GB, this corrupts unrelated memory. Signed-off-by: Jan Niehusmann <jan@gondor.com> Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: stable@kernel.org
2011-03-01Revert "TPM: Long default timeout fix"Linus Torvalds
This reverts commit c4ff4b829ef9e6353c0b133b7adb564a68054979. Ted Ts'o reports: "TPM is working for me so I can log into employer's network in 2.6.37. It broke when I tried 2.6.38-rc6, with the following relevant lines from my dmesg: [ 11.081627] tpm_tis 00:0b: 1.2 TPM (device-id 0x0, rev-id 78) [ 25.734114] tpm_tis 00:0b: Operation Timed out [ 78.040949] tpm_tis 00:0b: Operation Timed out This caused me to get suspicious, especially since the _other_ TPM commit in 2.6.38 had already been reverted, so I tried reverting commit c4ff4b829e: "TPM: Long default timeout fix". With this commit reverted, my TPM on my Lenovo T410 is once again working." Requested-and-tested-by: Theodore Ts'o <tytso@mit.edu> Acked-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-01Merge branch 'master' of ↵David S. Miller
2011-02-28Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging: hwmon: (adt7411) add MODULE_DEVICE_TABLE hwmon: (ad7414) add MODULE_DEVICE_TABLE
2011-02-28ACPI: Fix build for CONFIG_NET unsetRafael J. Wysocki
Several ACPI drivers fail to build if CONFIG_NET is unset, because they refer to things depending on CONFIG_THERMAL that in turn depends on CONFIG_NET. However, CONFIG_THERMAL doesn't really need to depend on CONFIG_NET, because the only part of it requiring CONFIG_NET is the netlink interface in thermal_sys.c. Put the netlink interface in thermal_sys.c under #ifdef CONFIG_NET and remove the dependency of CONFIG_THERMAL on CONFIG_NET from drivers/thermal/Kconfig. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Len Brown <lenb@kernel.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Luming Yu <luming.yu@intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-28Merge branch 'drm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: drm: fix unsigned vs signed comparison issue in modeset ctl ioctl. drm/nv50-nvc0: make sure vma is definitely unmapped when destroying bo
2011-02-28davinci_emac: Add Carrier Link OK check in Davinci RX HandlerHegde, Vinay
This patch adds an additional check in the Davinci EMAC RX Handler, which tests the __LINK_STATE_NOCARRIER flag along with the __LINK_STATE_START flag as part EMAC shutting down procedure. This avoids WARNING: at drivers/net/davinci_emac.c:1040 emac_rx_handler+0xf8/0x120() during rtcwake used to suspend the target for a specified duration. Signed-off-by: Hegde, Vinay <vinay.hegde@ti.com> Acked-by: Cyril Chemparathy <cyril@ti.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-28bnx2x: update driver version to 1.62.00-6Dmitry Kravkov
Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-28bnx2x: properly calculate lro_mssVladislav Zolotarov
2011-02-28bnx2x: perform statistics "action" before state transition.Vladislav Zolotarov
2011-02-28bnx2x: properly configure coefficients for MinBW algorithm (NPAR mode).Dmitry Kravkov
2011-02-28bnx2x: Fix ethtool -t link test for MF (non-pmf) devices.Dmitry Kravkov
2011-02-28bnx2x: Fix nvram test for single port devices.Dmitry Kravkov
2011-02-28bnx2x: (NPAR mode) Fix FW initializationDmitry Kravkov
Fix FW initialization according to max BW stored in percents for NPAR mode. Protect HW from being configured to speed 0. Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-28f_phonet: avoid pskb_pull(), fix OOPS with CONFIG_HIGHMEMRémi Denis-Courmont
This is similar to what we already do in cdc-phonet.c in the same situation. pskb_pull() refuses to work with HIGHMEM, even if it is known that the socket buffer is entirely in "low" memory. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
