We'd better place clock set-up in dc as HDMI. It makes code cleaner.
Also eliminate a false warning.
Bug 902786
Bug 850852
Signed-off-by: Kevin Huang <kevinh@nvidia.com>
Reviewed-on: http://git-master/r/65024
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
(cherry picked from commit e570e8dd45a66f11f0fc432f5919c5a036e34ba0)
Change-Id: I90d73602048e2b3c706550128ba04665c307da22
Reviewed-on: http://git-master/r/68863
Reviewed-by: Kevin Huang (Eng-SW) <kevinh@nvidia.com>
Tested-by: Kevin Huang (Eng-SW) <kevinh@nvidia.com>
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Change-Id: I1b8fa9d950dc2e8260363593ec0e41f70d275fac
Signed-off-by: Colin Patrick McCabe <cmccabe@nvidia.com>
Reviewed-on: http://git-master/r/68745
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
After allocating pages, Update page attributes in kernel
page table as per mem type requested.
Bug 865816
Reviewed-on: http://git-master/r/56334
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
(cherry picked from commit bea4d449f4ff7090e0c2797693d2348f4586d8f6)
Reviewed-on: http://git-master/r/62720
Tested-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-by: Hiro Sugawara <hsugawara@nvidia.com>
Reviewed-by: Kaz Fukuoka <kfukuoka@nvidia.com>
(cherry picked from commit 975fb95585543124de282faa4481433b147f61c6)
Change-Id: Iee71f8b37c405731314a1441cdb30ca848b41399
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/68744
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Change-Id: Ic5f70fe468651dab331059feda438d6e8871ef8a
Reviewed-on: http://git-master/r/68741
Add a couple -Wno-error options when building with the new toolchain;
it's stricter. These can be removed once the code is fixed not to
cause warnings (see bug 888158).
Bug 830289
Signed-off-by: Matt Pedro <mapedro@nvidia.com>
(cherry picked from commit 4a2bbb6dc6ab70a8e562d8db4d6016c28c290ce0)
Change-Id: I9944bf4a5fac005fed5ff5d92c38c5be32ea6f55
Reviewed-on: http://git-master/r/68740
Tested-by: Matthew Pedro <mapedro@nvidia.com>
Reviewed-by: Allen Martin <amartin@nvidia.com>
TVs/monitors which do not support underscan will crop HDMI picture.
Underscan information might be needed in userspace to adjust HDMI
resolution so that the picture will be shown correctly on such devices.
Bug 911580
Bug 912187
Change-Id: I1eec810d860e13dafef895cb85b32fd8187a4e02
Signed-off-by: Victor Ryabukhin <vryabukhin@nvidia.com>
Reviewed-on: http://git-master/r/68616
M7400 service pin should be held high by a pullup internal to it
for flashless mode. This is not working. As a fix, drive the signal
high from AP.
Bug 886459
(cherry picked from commit 1516ce643ca9c6e52540023342c27791b8a69867)
Change-Id: I8a5ba9be6bcaf9119f5b81fe30de20cb8dc412d0
Signed-off-by: Raj Jayaraman <rjayaraman@nvidia.com>
Reviewed-on: http://git-master/r/68505
Reviewed-by: Steve Lin <stlin@nvidia.com>
Adding default calibration data for the cases where no focuser
EPROM data exists.
Bug 909087
Change-Id: I303e8dd3883f93c1ebca1dd00c6726b0afc099d2
Signed-off-by: Erik Lilliebjerg <elilliebjerg@nvidia.com>
Reviewed-on: http://git-master/r/68466
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Bug 878736
Bug 886459
(cherry picked from commit 6f6a3b6759f95b833a3c98ee45015592f388b161)
Change-Id: Ieb5e9313ad9d6a32a813dadd911f448d8b334b42
Reviewed-on: http://git-master/r/68289
Reviewed-by: Rajkumar Jayaraman <rjayaraman@nvidia.com>
Tested-by: Rajkumar Jayaraman <rjayaraman@nvidia.com>
ERESTARTSYS can be used only when there is a signal pending to cause a
system call restart. In other cases, we must return a proper error
number to use space.
Change-Id: I018b051ec4cb63a0509762c39b47cc4420a21baa
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/68178
nvhost_cdma_flush() waits for channel to become empty before returning.
If there is already another process waiting for semaphore,
nvhost_cdma_flush() needs to use polling.
Change-Id: Ic0c3d7adc68b3ed93056ec73c16f685d6f1ba15e
Reviewed-on: http://git-master/r/68163
Implement proper mutex locking for nvhost_module_suspend(). At the same
time the ordering of suspend is changed to first suspend clients and
then host1x. This simplifies the power management code, and makes
nvhost_resume() a no-op.
Bug 906607
Change-Id: I60048773944369f73094140fb16682638966c731
Reviewed-on: http://git-master/r/68084
Reviewed-by: Simone Willett <swillett@nvidia.com>
When monitor is auto-detected on HDMI port, a special structure
is initialised to hold the video mode properties for the plugged-
in monitor. From this the display string is generated for displa
via the "mode" character device under /sys.
When the monitor is disconnected, the structures associated with
the monitor tself are cleared, but the pointer to the video mode
properties structure was left initialised and so pointed into thin
air, which resulted in garbage appearing on the "mode" device.
Added explicit deinitialisation code to reset pointer to video
mode properties so "cat mode" within /sys yields an empty string
when the HDMI monitor is unplugged.
Bug 849877
Reviewed-on: http://git-master/r/41205
(cherry picked from commit 8cecf2d7fbdf4d00945f3dd13bfe00161d4231d5)
Change-Id: Ibf3f070fa7904e8a01966d2886bbe07e9b69a607
Reviewed-on: http://git-master/r/68588
CONFIG_USB_EHCI_ONOFF_FEATURE is removed. Dynamic add/removel of
hcd driver can be used instead of above feature.
BUG 787720
Reviewed-on: http://git-master/r/65105
(cherry picked from commit a07377e01cd0a67f04cb74345e5a372bfc0059fb)
Change-Id: I185c08d09440cf683afc5eb1dc3f0dff5f93d25b
Reviewed-on: http://git-master/r/68393
This change reduces the EMC clock required by USB host/gadget from 150Mhz to 100Mhz.
Bug ID : 817811
Reviewed-on: http://git-master/r/54571
(cherry picked from commit 6b208d6dae6844410b9cc29c30664ce7df44e989)
Change-Id: I0d227121b7d212f44db82348ea66b2798150f387
Signed-off-by: Hyungwoo Yang <hyungwooy@nvidia.com>
Reviewed-on: http://git-master/r/68072
Reviewed-by: Luke Huang <lhuang@nvidia.com>
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
Adding regulator driver for the device FAN53555.
Bug 892117
Change-Id: I895094d3e0aaeb85cfd33f1bc16008c66961b403
Reviewed-on: http://git-master/r/67862
Tested-by: Jake Park <jakep@nvidia.com>
arch/arm/Kconfig
Change-Id: If8aaaf3efcbbf6c9017b38efb6d76ef933f147fa
[ Upstream commit 1d36cb479f204a0fedc1a3e7ce7b32c0a2c48769 ]
when use dst_get_neighbour to get neighbour, we need
rcu_read_lock to protect, since dst_get_neighbour uses
rcu_dereference.
commit 87121ca504fd1d963a66b3fb0c72054b0fd9a177 upstream.
Oprofile may crash in a KVM guest while unlaoding modules. This
happens if oprofile_arch_init() fails and oprofile switches to the hr
timer mode as a fallback. In this case oprofile_arch_exit() is called,
but it never was initialized properly which causes the crash. This
patch fixes this.
oprofile: using timer interrupt.
BUG: unable to handle kernel NULL pointer dereference at 0000000000000008
IP: [<ffffffff8123c226>] unregister_syscore_ops+0x41/0x58
PGD 41da3f067 PUD 41d80e067 PMD 0
Oops: 0002 [#1] PREEMPT SMP
CPU 5
Modules linked in: oprofile(-)
Pid: 2382, comm: modprobe Not tainted 3.1.0-rc7-00018-g709a39d #18 Advanced Micro Device Anaheim/Anaheim
RIP: 0010:[<ffffffff8123c226>] [<ffffffff8123c226>] unregister_syscore_ops+0x41/0x58
RSP: 0018:ffff88041de1de98 EFLAGS: 00010296
RAX: 0000000000000000 RBX: ffffffffa00060e0 RCX: dead000000200200
RDX: 0000000000000000 RSI: dead000000100100 RDI: ffffffff8178c620
RBP: ffff88041de1dea8 R08: 0000000000000001 R09: 0000000000000082
R10: 0000000000000000 R11: ffff88041de1dde8 R12: 0000000000000080
R13: fffffffffffffff5 R14: 0000000000000001 R15: 0000000000610210
FS: 00007f9ae5bef700(0000) GS:ffff88042fd40000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000000000000008 CR3: 000000041ca44000 CR4: 00000000000006e0
Process modprobe (pid: 2382, threadinfo ffff88041de1c000, task ffff88042db6d040)
Stack:
ffff88041de1deb8 ffffffffa0006770 ffff88041de1deb8 ffffffffa000251e
ffff88041de1dec8 ffffffffa00022c2 ffff88041de1ded8 ffffffffa0004993
ffff88041de1df78 ffffffff81073115 656c69666f72706f 0000000000610200
Call Trace:
[<ffffffffa000251e>] op_nmi_exit+0x15/0x17 [oprofile]
[<ffffffffa00022c2>] oprofile_arch_exit+0xe/0x10 [oprofile]
[<ffffffffa0004993>] oprofile_exit+0x13/0x15 [oprofile]
[<ffffffff81073115>] sys_delete_module+0x1c3/0x22f
[<ffffffff811bf09e>] ? trace_hardirqs_on_thunk+0x3a/0x3f
[<ffffffff8148070b>] system_call_fastpath+0x16/0x1b
Code: 20 c6 78 81 e8 c5 cc 23 00 48 8b 13 48 8b 43 08 48 be 00 01 10 00 00 00 ad de 48 b9 00 02 20 00 00 00 ad de 48 c7 c7 20 c6 78 81
89 42 08 48 89 10 48 89 33 48 89 4b 08 e8 a6 c0 23 00 5a 5b
RIP [<ffffffff8123c226>] unregister_syscore_ops+0x41/0x58
RSP <ffff88041de1de98>
---[ end trace 06d4e95b6aa3b437 ]---
Signed-off-by: Robert Richter <robert.richter@amd.com>
commit 6a8943d9ec2567572fca25cf69ad45844d0141a3 upstream.
The current code checks if abs(delta_delta.tv_sec) is greater or
equal to two before it discards the old delta value, but this can
trigger at close to -1 seconds since -1.000000001 seconds is stored
as tv_sec -2 and tv_nsec 999999999 in a normalized timespec.
rtc_resume had an early return check if the rtc value had not changed
since rtc_suspend. This effectivly stops time for the duration of the
short sleep. Check if sleep_time is positive after all the adjustments
have been applied instead since this allows the old_system adjustment
in rtc_suspend to have an effect even for short sleep cycles.
Signed-off-by: Arve Hjønnevåg <arve@android.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
commit c0afabd3d553c521e003779c127143ffde55a16f upstream.
Currently, the RTC code does not disable the alarm in the hardware.
This means that after a sequence such as the one below (the files are in the
RTC sysfs), the box will boot up after 2 minutes even though we've
asked for the alarm to be turned off.
# echo $((`cat since_epoch`)+120) > wakealarm
# echo 0 > wakealarm
# poweroff
Fix this by disabling the alarm when there are no timers to run.
Cc: John Stultz <john.stultz@linaro.org>
Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com>
commit 274b89ca3b006926cb9b45d78ab5906f4c0fc0aa upstream.
Group keys in IBSS or AP mode are not programmed
into the device since we give the key to it with
every TX packet. However, we do need mac80211 to
create the MMIC & PN in all cases. Move the code
around to set the key flags all the time. We set
them even when the key is removed again but that
is obviously harmless.
Reported-by: Reinette Chatre <reinette.chatre@intel.com>
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
commit 34a5b4b6af104cf18eb50748509528b9bdbc4036 upstream.
The ht40 setting should not change after association unless channel switch
This fix a problem we are seeing which cause uCode assert because driver
sending invalid information and make uCode confuse
Here is the firmware assert message:
kernel: iwlagn 0000:03:00.0: Microcode SW error detected. Restarting 0x82000000.
kernel: iwlagn 0000:03:00.0: Loaded firmware version: 17.168.5.3 build 42301
kernel: iwlagn 0000:03:00.0: Start IWL Error Log Dump:
kernel: iwlagn 0000:03:00.0: Status: 0x000512E4, count: 6
kernel: iwlagn 0000:03:00.0: 0x00002078 | ADVANCED_SYSASSERT
kernel: iwlagn 0000:03:00.0: 0x00009514 | uPc
kernel: iwlagn 0000:03:00.0: 0x00009496 | branchlink1
kernel: iwlagn 0000:03:00.0: 0x00009496 | branchlink2
kernel: iwlagn 0000:03:00.0: 0x0000D1F2 | interruptlink1
kernel: iwlagn 0000:03:00.0: 0x00000000 | interruptlink2
kernel: iwlagn 0000:03:00.0: 0x01008035 | data1
kernel: iwlagn 0000:03:00.0: 0x0000C90F | data2
kernel: iwlagn 0000:03:00.0: 0x000005A7 | line
kernel: iwlagn 0000:03:00.0: 0x5080B520 | beacon time
kernel: iwlagn 0000:03:00.0: 0xCC515AE0 | tsf low
kernel: iwlagn 0000:03:00.0: 0x00000003 | tsf hi
kernel: iwlagn 0000:03:00.0: 0x00000000 | time gp1
kernel: iwlagn 0000:03:00.0: 0x29703BF0 | time gp2
kernel: iwlagn 0000:03:00.0: 0x00000000 | time gp3
kernel: iwlagn 0000:03:00.0: 0x000111A8 | uCode version
kernel: iwlagn 0000:03:00.0: 0x000000B0 | hw version
kernel: iwlagn 0000:03:00.0: 0x00480303 | board version
kernel: iwlagn 0000:03:00.0: 0x09E8004E | hcmd
kernel: iwlagn 0000:03:00.0: CSR values:
kernel: iwlagn 0000:03:00.0: (2nd byte of CSR_INT_COALESCING is CSR_INT_PERIODIC_REG)
kernel: iwlagn 0000:03:00.0: CSR_HW_IF_CONFIG_REG: 0X00480303
kernel: iwlagn 0000:03:00.0: CSR_INT_COALESCING: 0X0000ff40
kernel: iwlagn 0000:03:00.0: CSR_INT: 0X00000000
kernel: iwlagn 0000:03:00.0: CSR_INT_MASK: 0X00000000
kernel: iwlagn 0000:03:00.0: CSR_FH_INT_STATUS: 0X00000000
kernel: iwlagn 0000:03:00.0: CSR_GPIO_IN: 0X00000030
kernel: iwlagn 0000:03:00.0: CSR_RESET: 0X00000000
kernel: iwlagn 0000:03:00.0: CSR_GP_CNTRL: 0X080403c5
kernel: iwlagn 0000:03:00.0: CSR_HW_REV: 0X000000b0
kernel: iwlagn 0000:03:00.0: CSR_EEPROM_REG: 0X07d60ffd
kernel: iwlagn 0000:03:00.0: CSR_EEPROM_GP: 0X90000001
kernel: iwlagn 0000:03:00.0: CSR_OTP_GP_REG: 0X00030001
kernel: iwlagn 0000:03:00.0: CSR_GIO_REG: 0X00080044
kernel: iwlagn 0000:03:00.0: CSR_GP_UCODE_REG: 0X000093bb
kernel: iwlagn 0000:03:00.0: CSR_GP_DRIVER_REG: 0X00000000
kernel: iwlagn 0000:03:00.0: CSR_UCODE_DRV_GP1: 0X00000000
kernel: iwlagn 0000:03:00.0: CSR_UCODE_DRV_GP2: 0X00000000
kernel: iwlagn 0000:03:00.0: CSR_LED_REG: 0X00000078
kernel: iwlagn 0000:03:00.0: CSR_DRAM_INT_TBL_REG: 0X88214dd2
kernel: iwlagn 0000:03:00.0: CSR_GIO_CHICKEN_BITS: 0X27800200
kernel: iwlagn 0000:03:00.0: CSR_ANA_PLL_CFG: 0X00000000
kernel: iwlagn 0000:03:00.0: CSR_HW_REV_WA_REG: 0X0001001a
kernel: iwlagn 0000:03:00.0: CSR_DBG_HPET_MEM_REG: 0Xffff0010
kernel: iwlagn 0000:03:00.0: FH register values:
kernel: iwlagn 0000:03:00.0: FH_RSCSR_CHNL0_STTS_WPTR_REG: 0X21316d00
kernel: iwlagn 0000:03:00.0: FH_RSCSR_CHNL0_RBDCB_BASE_REG: 0X021479c0
kernel: iwlagn 0000:03:00.0: FH_RSCSR_CHNL0_WPTR: 0X00000060
kernel: iwlagn 0000:03:00.0: FH_MEM_RCSR_CHNL0_CONFIG_REG: 0X80819104
kernel: iwlagn 0000:03:00.0: FH_MEM_RSSR_SHARED_CTRL_REG: 0X000000fc
kernel: iwlagn 0000:03:00.0: FH_MEM_RSSR_RX_STATUS_REG: 0X07030000
kernel: iwlagn 0000:03:00.0: FH_MEM_RSSR_RX_ENABLE_ERR_IRQ2DRV: 0X00000000
kernel: iwlagn 0000:03:00.0: FH_TSSR_TX_STATUS_REG: 0X07ff0001
kernel: iwlagn 0000:03:00.0: FH_TSSR_TX_ERROR_REG: 0X00000000
kernel: iwlagn 0000:03:00.0: Start IWL Event Log Dump: display last 20 entries
kernel: ------------[ cut here ]------------
WARNING: at net/mac80211/util.c:1208 ieee80211_reconfig+0x1f1/0x407()
kernel: Hardware name: 4290W4H
kernel: Pid: 1896, comm: kworker/0:0 Not tainted 3.1.0 #2
kernel: Call Trace:
kernel: [<ffffffff81036558>] ? warn_slowpath_common+0x73/0x87
kernel: [<ffffffff813b8966>] ? ieee80211_reconfig+0x1f1/0x407
kernel: [<ffffffff8139e8dc>] ? ieee80211_recalc_smps_work+0x32/0x32
kernel: [<ffffffff8139e95a>] ? ieee80211_restart_work+0x7e/0x87
kernel: [<ffffffff810472fa>] ? process_one_work+0x1c8/0x2e3
kernel: [<ffffffff810480c9>] ? worker_thread+0x17a/0x23a
kernel: [<ffffffff81047f4f>] ? manage_workers.clone.18+0x15b/0x15b
kernel: [<ffffffff8104ba97>] ? kthread+0x7a/0x82
kernel: [<ffffffff813d21b4>] ? kernel_thread_helper+0x4/0x10
kernel: [<ffffffff8104ba1d>] ? kthread_flush_work_fn+0x11/0x11
kernel: [<ffffffff813d21b0>] ? gs_change+0xb/0xb
Reported-by: Udo Steinberg <udo@hypervisor.org>
commit 158886cd2cf4599e04f9b7e10cb767f5f39b14f1 upstream.
When system enters suspend, xHCI driver clears command ring by writing zero
to all the TRBs. However, this also writes zero to the Link TRB, and the ring
is mangled. This may cause driver accesses wrong memory address and the
result is unpredicted.
When clear the command ring, keep the last Link TRB intact, only clear its
cycle bit. This should fix the "command ring full" issue reported by Oliver
Neukum.
This should be backported to stable kernels as old as 2.6.37, since the
commit 89821320 "xhci: Fix command ring replay after resume" is merged.
Signed-off-by: Andiry Xu <andiry.xu@amd.com>
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Reported-by: Oliver Neukum <oneukum@suse.de>
commit e3420901eba65b1c46bed86d360e3a8685d20734 upstream.
Fix a regression that was introduced by commit
811c926c538f7e8d3c08b630dd5844efd7e000f6 (USB: EHCI: fix HUB TT scheduling
issue with iso transfer).
We detect an error if next == start, but this means uframe 0 can't be allocated
anymore for iso transfer...
Reported-by: Sander Eikelenboom <linux@eikelenboom.it>
Signed-off-by: Matthieu CASTET <castet.matthieu@free.fr>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 811c926c538f7e8d3c08b630dd5844efd7e000f6 upstream.
The current TT scheduling doesn't allow to play and then record on a
full-speed device connected to a high speed hub.
The IN iso stream can only start on the first uframe (0-2 for a 165 us)
because of CSPLIT transactions.
For the OUT iso stream there no such restriction. uframe 0-5 are possible.
The idea of this patch is that the first uframe are precious (for IN TT iso
stream) and we should allocate the last uframes first if possible.
For that we reverse the order of uframe allocation (last uframe first).
Here an example :
hid interrupt stream
uframe | 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 |
max_tt_usecs | 125 | 125 | 125 | 125 | 125 | 125 | 30 | 0 |
used usecs on a frame | 13 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
iso OUT stream
used usecs on a frame | 13 | 125 | 39 | 0 | 0 | 0 | 0 | 0 |
There no place for iso IN stream (uframe 0-2 are used) and we got "cannot
submit datapipe for urb 0, error -28: not enough bandwidth" error.
With the patch this become.
iso OUT stream
used usecs on a frame | 13 | 0 | 0 | 0 | 125 | 39 | 0 | 0 |
iso IN stream
used usecs on a frame | 13 | 0 | 125 | 40 | 125 | 39 | 0 | 0 |
Signed-off-by: Matthieu Castet <matthieu.castet@parrot.com>
Signed-off-by: Thomas Poussevin <thomas.poussevin@parrot.com>
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
commit 580da35a31f91a594f3090b7a2c39b85cb051a12 upstream.
Commit f2c31e32b37 ("net: fix NULL dereferences in check_peer_redir()")
forgot to take care of infiniband uses of dst neighbours.
Many thanks to Marc Aurele who provided a nice bug report and feedback.
Reported-by: Marc Aurele La France <tsi@ualberta.ca>
Signed-off-by: Roland Dreier <roland@purestorage.com>
commit cec28a5428793b6bc64e56687fb239759d6da74e upstream.
Kingston DT 101 G2 replies a wrong tag while transporting, add an
unusal_devs entry to ignore the tag validation.
Signed-off-by: Qinglin Ye <yestyle@gmail.com>
commit ec0cd94d881ca89cc9fb61d00d0f4b2b52e605b3 upstream.
Tested with SIM5218EVB-KIT evaluation kit.
Signed-off-by: Veli-Pekka Peltola <veli-pekka.peltola@bluegiga.com>
commit 46b1848360c8e634e0b063932a1261062fa0f7d6 upstream.
This patch creates the missing controlling devices for the Huawei E353
HSPA+ stick.
Signed-off-by: Dirk Nehring <dnehring@gmx.net>
commit 307369b0ca06b27b511b61714e335ddfccf19c4f upstream.
Signed-off-by: Marcin Kościelnicki <koriakin@0x04.net>
commit b1807719f6acdf18cc4bde3b5400d05d77801494 upstream.
Genera Touch told us that 0001 is their single point device
and 0003 is the multitouch one. Apparently, we made the tests
someone having a prototype, and not the final product.
They said it should be safe to do the switch.
This partially reverts 5572da0 ("HID: hid-mulitouch: add support
for the 'Sensing Win7-TwoFinger'").
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@gmail.com>
commit 8746c83d538cab273d335acb2be226d096f4a5af upstream.
qset->qh.link is an __le64 field and we should be using cpu_to_le64()
to fill it.
commit 5d193ce8f1fa7c67c7fd7be2c03ef31eed344a4f upstream.
Currently the driver tries to save context in the suspend path, but
will cause an abort if the device is already runtime suspended. This
happens, for example, if MUSB loaded/compiled-in, in host mode, but no
USB devices are attached. MUSB will be runtime suspended, but then
attempting a system suspend will crash due to the context save
being attempted while the device is disabled.
On OMAP, as of v3.1, the driver's ->runtime_suspend() callback will be
called late in the suspend path (by the PM domain layer) if the driver
is not already runtime suspended, ensuring a full shutdown.
Therefore, the context save is not needed in the ->suspend() method
since it will be called in the ->runtime_suspend() method anyways
(similarily for resume.)
NOTE: this leaves the suspend/resume methods basically empty (with
some FIXMEs and comments, but I'll leave it to the maintainers
to decide whether to remove them.
Signed-off-by: Kevin Hilman <khilman@ti.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
commit 6a9ce6b654e491981f6ef7e214cbd4f63e033848 upstream.
After sleeping on a wait queue, signal_pending(current) should be
checked (not before sleeping).
Acked-by: Alessandro Rubini <rubini@gnudd.com>
Signed-off-by: Federico Vaga <federico.vaga@gmail.com>
commit df30b21cb0eed5ba8a8e0cdfeebc66ba8cde821d upstream.
In comedi_fops, mmap_count is decremented at comedi_vm_ops->close but
it is not incremented at comedi_vm_ops->open. This may result in a negative
counter. The patch introduces the open method to keep the counter
consistent.
The bug was triggerd by this sample code:
mmap(0, ...., comedi_fd);
fork();
exit(0);
commit 3ffab428f40849ed5f21bcfd7285bdef7902f9ca upstream.
This fixes kernel oops when an USB DAQ device is plugged out while it's
communicating with the userspace software.
Signed-off-by: Bernd Porr <berndporr@f2s.com>
commit 438957f8d4a84daa7fa5be6978ad5897a2e9e5e5 upstream.
Interrupts must be disabled prior to calling usb_hcd_unlink_urb_from_ep.
If interrupts are not disabled, it can potentially lead to a deadlock.
The deadlock is readily reproduceable on a slower (ARM based) device
such as the TI Pandaboard.
Signed-off-by: Bart Westgeest <bart@elbrys.com>
commit f7364ba04b0961f3a1f978bbe77102606801e35f upstream.
Complete scanning_done variable if rtsx-scan thread created failed.
Signed-off-by: wwang <wei_wang@realsil.com.cn>
commit bda63586bc5929e97288cdb371bb6456504867ed upstream.
Currently the SigmaDSP firmware loader only works correctly on little-endian
systems. Fix this by using the proper endianess conversion functions.
commit c56935bdc0a8edf50237d3b0205133a5b0adc604 upstream.
The firmware header is not part of the CRC, so skip it. Otherwise the firmware
will be rejected due to non-matching CRCs.
commit 4f718a29fe4908c2cea782f751e9805319684e2b upstream.
The SigmaDSP firmware loader currently does not perform enough boundary size
checks when processing the firmware. As a result it is possible that a
malformed firmware can cause an out of bounds memory access.
This patch adds checks which ensure that both the action header and the payload
are completely inside the firmware data boundaries before processing them.
commit f64964796dedca340608fb1075ab6baad5625851 upstream.
Avoid infinite loops waiting for surface updates if a GPU
reset happens while waiting for a page flip.
See:
https://bugs.freedesktop.org/show_bug.cgi?id=43191
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Reviewed-by: Mario Kleiner <mario.kleiner@tuebingen.mpg.de>
Tested-by: Simon Farnsworth <simon.farnsworth@onelan.co.uk>
commit 8a39ef8ba0fa0410d71db8e981e887fe4fdeca88 upstream.
Continue the init process even fail to enable msi
out_iounmap is no longer used, remove it
Reported-by: werner <w.landgraf@ru.ru>
Tested-by: werner <w.landgraf@ru.ru>
commit 745718132c3c7cac98a622b610e239dcd5217f71 upstream.
When we tear down a device we try to flush all outstanding
commands in scsi_free_queue(). However the check in
scsi_request_fn() is imperfect as it only signals that
we _might start_ aborting commands, not that we've actually
aborted some.
So move the printk inside the scsi_kill_request function,
this will also give us a hint about which commands are aborted.
Signed-off-by: Hannes Reinecke <hare@suse.de>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
Cc: Christoph Biedl <linux-kernel.bfrz@manchmal.in-ulm.de>
commit 68fa64ef606bcee688fce46d07aa68f175070156 upstream.
Fix __le32 to __le16 conversion of the first word of an 8-word block
of EEPROM read via the efuse method.
Reported-and-tested-by: Ingvar Hagelund <ingvar@redpill-linpro.com>
Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com>
Acked-by: Helmut Schaa <helmut.schaa@googlemail.com>
Acked-by: Ivo van Doorn <IvDoorn@gmail.com>
commit 2d1618170eb493d18f66f2ac03775409a6fb97c6 upstream.
priv->work must not be synced while priv->mutex is locked, because
the mutex is taken in the work handler.
Move cancel_work_sync down to after the device shutdown code.
This is safe, because the work handler checks fw_state and bails out
early in case of a race.
Signed-off-by: Michael Buesch <m@bues.ch>
Acked-by: Christian Lamparter <chunkeey@googlemail.com>
commit 32d3a3922d617a5a685a5e2d24b20d0e88f192a9 upstream.
The tx_lock is not initialized properly. Add spin_lock_init().
commit ba305e31e88ea5c2f598ff9fbc5424711a429e30 upstream.
SMPS regulator voltage control differs from the one of the LDO ones.
Current TWL code was using LDO regulator ops for controlling the SMPS
regulators, which fails. This was fixed fixed by adding separate
regulator type which uses correct logic and calculations for the
voltage levels.
Signed-off-by: Tero Kristo <t-kristo@ti.com>
aat2870_get_regulator
commit d4d6373c1109b11c8118340be97ae31b8f94d66a upstream.
In current implementation, the pointer ri is not NULL if no id is matched.
Fix it by checking i == ARRAY_SIZE(aat2870_regulators) if no id is matched.
