path: root/drivers
2008-11-12Merge branches 'tracing/ftrace' and 'tracing/urgent' into tracing/coreIngo Molnar
Conflicts: kernel/trace/ring_buffer.c
2008-11-11telephony: trivial: fix up email addressAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-11tty: trivial - fix up email addresses in tty related stuffAlan Cox
2008-11-11Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (35 commits) V4L/DVB (9516): cx18: Move DVB buffer transfer handling from irq handler to work_queue V4L/DVB (9557): gspca: Small changes for the sensor HV7131B in zc3xx. V4L/DVB (9556): gspca: Bad init sequence for sensor HV7131B in zc3xx. V4L/DVB (9549): gspca: Fix a typo in one of gspca chips name. V4L/DVB (9515): cx18: Use correct Mailbox IRQ Ack values and misc IRQ handling cleanup V4L/DVB (9493): kconfig patch V4L/DVB (9527): af9015: fix compile warnings V4L/DVB (9524): af9013: fix bug in status reading V4L/DVB (9511): cx18: Mark CX18_CPU_DE_RELEASE_MDL as a slow API call V4L/DVB (9510): cx18: Fix write retries for registers that always change - part 2. V4L/DVB (9506): ivtv/cx18: fix test whether modules should be loaded or not. V4L/DVB (9499): cx88-mpeg: final fix for analogue only compilation + de-alloc fix V4L/DVB (9496): cx88-blackbird: bugfix: cx88-blackbird-mpeg-users V4L/DVB (9495): cx88-blackbird: bugfix: cx88-blackbird-poll-fix V4L/DVB (9494): anysee: initialize anysee_usb_mutex statically V4L/DVB (9492): unplug oops from dvb_frontend_init... V4L/DVB (9486): ivtv/ivtvfb: no longer experimental V4L/DVB (9485): ivtv: remove incorrect V4L1 & tvaudio dependency V4L/DVB (9482): Documentation, especially regarding audio and informational links V4L/DVB (9475): cx18: Disable write retries for registers that always change - part 1. ...
2008-11-11Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: powerpc: Update desktop/server defconfigs powerpc: Fix msr check in compat_sys_swapcontext powerpc: Repair device bindings documentation powerpc: Updated Freescale PPC related defconfigs powerpc: Update QE/CPM2 usb_ctlr structures for USB support powerpc/86xx: Correct SOC bus-frequency in GE Fanuc SBC610 DTS powerpc: Fix Book-E watchdog timer interval setting powerpc/fsl-booke: Fix synchronization bug w/local tlb invalidates
2008-11-11Merge branch 'drm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: drm/i915: Move legacy breadcrumb out of the reserved status page area drm/i915: Filter pci devices based on PCI_CLASS_DISPLAY_VGA drm/radeon: map registers at load time drm: Remove infrastructure for supporting i915's vblank swapping. i915: Remove racy delayed vblank swap ioctl. i915: Don't whine when pci_enable_msi() fails. i915: Don't attempt to short-circuit object_wait_rendering by checking domains. i915: Clean up sarea pointers on leavevt i915: Save/restore MCHBAR_RENDER_STANDBY on GM965/GM45
2008-11-11Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: libata: fix last_reset timestamp handling libata: Avoid overflow in ata_tf_read_block() when tf->hba_lbal > 127 [libata] pata_pcmcia: another memory card support [libata] pata_sch: notice attached slave devices [libata] pata_cs553*.c: cleanup kernel-doc
2008-11-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: dsa: fix master interface allmulti/promisc handling dsa: fix skb->pkt_type when mac address of slave interface differs net: fix setting of skb->tail in skb_recycle_check() net: fix /proc/net/snmp as memory corruptor mac80211: fix a buffer overrun in station debug code netfilter: payload_len is be16, add size of struct rather than size of pointer ipv6: fix ip6_mr_init error path [4/4] dca: fixup initialization dependency [3/4] I/OAT: fix async_tx.callback checking [2/4] I/OAT: fix dma_pin_iovec_pages() error handling [1/4] I/OAT: fix channel resources free for not allocated channels ssb: Fix DMA-API compilation for non-PCI systems SSB: hide empty sub menu vlan: Fix typos in proc output string [netdrvr] usb/hso: Cleanup rfkill error handling sfc: Correct address of gPXE boot configuration in EEPROM el3_common_init() should be __devinit, not __init hso: rfkill type should be WWAN mlx4_en: Start port error flow bug fix af_key: mark policy as dead before destroying
2008-11-11V4L/DVB (9516): cx18: Move DVB buffer transfer handling from irq handler to ↵Andy Walls
work_queue cx18: Move DVB buffer transfer handling from irq handler to work_queue thread. In order to properly lock the epu2cpu mailbox for driver to CX23418 commands, the DVB/TS buffer handling needs to be moved from the IRQ handler and IRQ context to a work queue. This work_queue implmentation is strikingly similar to the ivtv implementation - for better or worse. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-11V4L/DVB (9557): gspca: Small changes for the sensor HV7131B in zc3xx.Jean-Francois Moine
- touch only one register for brightness change - no quality control - don't probe again at streamon time. Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-11V4L/DVB (9556): gspca: Bad init sequence for sensor HV7131B in zc3xx.Jean-Francois Moine
This patch fixes the H flip and the R & B color inversion of mode 320x240. Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-11V4L/DVB (9549): gspca: Fix a typo in one of gspca chips name.Krzysztof Helt
Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-11V4L/DVB (9515): cx18: Use correct Mailbox IRQ Ack values and misc IRQ ↵Andy Walls
handling cleanup cx18: Use correct Mailbox IRQ Ack values and misc IRQ handling cleanup. The SCB field definitions for Ack IRQ's for mailboxes were inconsistent with the bitmasks being loaded into those SCB fields and the SW2 Ack IRQ handling logic. Renamed fields in SCB to make things consistent and did misc IRQ handling cleanups: removing legacy ivtv dma_reg_lock, HPU IRQ flags, etc. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-11V4L/DVB (9493): kconfig patchFrederic CAND
Ok I made a patch that converts gspca kconfig file to a more standard= one, with tabs + 2 white spaces, so that if a warning is added it still compiles please find it attached Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-11V4L/DVB (9527): af9015: fix compile warningsAntti Palosaari
- use static to avoid compile warnings Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-11V4L/DVB (9524): af9013: fix bug in status readingroel kluin
- ! has a higher precedence than & Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-11V4L/DVB (9511): cx18: Mark CX18_CPU_DE_RELEASE_MDL as a slow API callAndy Walls
cx18: Mark CX18_CPU_DE_RELEASE_MDL as a slow API call. Give the encoder time to complete the MDL release before destroying the encoder internal task. This avoids an encoder lockup on the next digital capture and error messages about buffers being returned for an inactive encoder task handle. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-11V4L/DVB (9510): cx18: Fix write retries for registers that always change - ↵Andy Walls
part 2. cx18: Fix write retries for registers that always change - part 2. Some registers, especially interrupt related ones, will never read back the value just written. Modified interrupt register readback checks to make sure the intended effect was achieved. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-11V4L/DVB (9506): ivtv/cx18: fix test whether modules should be loaded or not.Hans Verkuil
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-11V4L/DVB (9499): cx88-mpeg: final fix for analogue only compilation + ↵Darron Broad
de-alloc fix Final fix for when analogue only is selected for compilation (ie, !CX88_DVB) This tidies up previous fix and adds missing de-alloc memory leak on fault (eg, if fe1 fails to alloc where fe0 was allocated). Signed-off-by: Darron Broad <darron@kewl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-11V4L/DVB (9496): cx88-blackbird: bugfix: cx88-blackbird-mpeg-usersFrederic CAND
Allows multiple access to the mpeg device Signed-off-by: Frederic CAND <frederic.cand@anevia.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-11V4L/DVB (9495): cx88-blackbird: bugfix: cx88-blackbird-poll-fixFrederic CAND
Starts encoder not only on a read call but also on a poll command. Signed-off-by: Frederic CAND <frederic.cand@anevia.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-11V4L/DVB (9494): anysee: initialize anysee_usb_mutex staticallyAkinobu Mita
anysee_usb_mutex is initialized at every time the anysee device is probed. If the second anysee device is probed while anysee_usb_mutex is locked by the first anysee device, the mutex is broken. This patch fixes by initialize anysee_usb_mutex statically rather than initialize at probe time. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-11V4L/DVB (9492): unplug oops from dvb_frontend_init...Daniel J Blueman
When inadvertently hot-unplugging a WT-220U USB DVB-T receiver with 2.6.24, I was met with an oops [1]. The problem is relevant to 2.6.25/26-rc also. dvb_frontend_init() was called either from re-creation of the kdvb-fe0 thread - seems unlikely, or someone called dvb_frontend_reinitialise(), causing this path in the thread - really unlikely, as I can't find any call-site for it. Either way, quite a number of drivers call dvb_usb_generic_rw() [2] without checking the validity of the relevant member in the dvb_usb_device struct - which had changed. Having dvb_usb_generic_rw() sanity-check and fail (rather than loading from 0x120) seems reasonable defensive programming [3], in light of it being called in this way. The problem with this, is that drivers don't check the return code of the init call [4]. Does it make sense to cook a patch which allows the failure to be propagated back up, or am I missing something else? Thanks, Daniel <whoops, hot unplug> [83711.538485] dvb-usb: bulk message failed: -71 (1/0) [83711.538875] dvb-usb: bulk message failed: -71 (1/0) [83711.538899] usb 7-5: USB disconnect, address 3 [83711.538905] dvb-usb: bulk message failed: -22 (1/0) [83711.538924] dvb-usb: bulk message failed: -22 (1/0) [83711.538943] dvb-usb: bulk message failed: -22 (1/0) [83711.588979] dvb-usb: bulk message failed: -22 (1/0) [83711.589031] dvb-usb: bulk message failed: -22 (1/0) [83711.589078] dvb-usb: bulk message failed: -22 (1/0) [83711.589122] dvb-usb: bulk message failed: -22 (1/0) [83711.589167] dvb-usb: bulk message failed: -22 (1/0) [83711.639233] dvb-usb: bulk message failed: -22 (1/0) [83711.639282] dvb-usb: bulk message failed: -22 (1/0) [83711.639330] dvb-usb: bulk message failed: -22 (1/0) [83711.639374] dvb-usb: bulk message failed: -22 (1/0) [83711.639421] dvb-usb: bulk message failed: -22 (1/0) [83711.658391] dvb-usb: bulk message failed: -22 (1/0) [83768.174281] dvb-usb: bulk message failed: -22 (2/-32512) [83768.174350] Unable to handle kernel NULL pointer dereference<6>dvb-usb: WideView WT-220U PenType Receiver (Typhoon/Freecom) successfully deinitialized and disconnected. [83768.174459] at 0000000000000120 RIP: [83768.174459] [<ffffffff88339b4f>] :dvb_usb:dvb_usb_generic_rw+0x2f/0x1a0 [83768.174580] PGD 0 [83768.174643] Oops: 0000 [1] SMP [83768.174723] CPU 0 [83768.174782] Modules linked in: nfsd auth_rpcgss exportfs nfs lockd nfs_acl sunrpc af_packet xt_length ipt_tos ipt_TOS xt_CLASSIFY sch_sfq sch_htb ipt_MASQUERADE ipt_REDIRECT xt_limit xt_state xt_tcpudp iptable_nat nf_nat nf_conntrack_ipv4 nf_conntrack iptable_mangle iptable_filter ip_tables x_tables xfs sbp2 parport_pc lp parport loop ftdi_sio usbserial evdev dvb_usb_dtt200u dvb_usb dvb_core i2c_core sky2 iTCO_wdt iTCO_vendor_support snd_hda_intel shpchp snd_pcm snd_timer snd_page_alloc snd_hwdep snd pci_hotplug soundcore ipv6 button intel_agp ext3 jbd mbcache sg sd_mod ata_generic pata_acpi ahci ata_piix libata scsi_mod ohci1394 ieee1394 ehci_hcd uhci_hcd usbcore e1000 thermal processor fan fbcon tileblit font bitblit softcursor fuse [83768.176968] Pid: 5732, comm: kdvb-fe-0 Not tainted 2.6.24-16-server #1 [83768.177009] RIP: 0010:[<ffffffff88339b4f>] [<ffffffff88339b4f>] :dvb_usb:dvb_usb_generic_rw+0x2f/0x1a0 [83768.177096] RSP: 0018:ffff810021939df0 EFLAGS: 00010286 [83768.177138] RAX: ffff81003bc7cc00 RBX: 0000000000000001 RCX: 0000000000000000 [83768.177181] RDX: 0000000000000001 RSI: ffff810021939e67 RDI: 0000000000000000 [83768.177223] RBP: 0000000000000000 R08: 0000000000000000 R09: 0000000000000000 [83768.177267] R10: ffff810001009880 R11: 0000000000000001 R12: ffff81003c10b400 [83768.177311] R13: ffff81003c10b5b0 R14: ffff810021939ec0 R15: 0000000000000000 [83768.177354] FS: 0000000000000000(0000) GS:ffffffff805c3000(0000) knlGS:0000000000000000 [83768.177409] CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b [83768.177449] CR2: 0000000000000120 CR3: 0000000000201000 CR4: 00000000000006e0 [83768.177491] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [83768.177534] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [83768.177576] Process kdvb-fe-0 (pid: 5732, threadinfo ffff810021938000, task ffff81003bd1b7a0) [83768.177629] Stack: ffff81003e9b6828 0000000000000000 ffff8100378369f8 0000000000000000 [83768.177800] ffff81003bd1b7a0 ffff810037836d48 ffff81003bc7cc30 ffff81003c10b400 [83768.177943] ffff81003c10b5b0 ffff810021939ec0 ffff81003c10b5e0 ffffffff88342452 [83768.178054] Call Trace: [83768.178130] [<ffffffff88342452>] :dvb_usb_dtt200u:dtt200u_fe_init+0x22/0x30 [83768.178178] [<ffffffff88339f6a>] :dvb_usb:dvb_usb_fe_wakeup+0x3a/0x50 [83768.178229] [<ffffffff88325c41>] :dvb_core:dvb_frontend_init+0x21/0x70 [83768.178278] [<ffffffff8832746b>] :dvb_core:dvb_frontend_thread+0x8b/0x370 [83768.178329] [<ffffffff883273e0>] :dvb_core:dvb_frontend_thread+0x0/0x370 [83768.178382] [<ffffffff80253e3b>] kthread+0x4b/0x80 [83768.178427] [<ffffffff8020d198>] child_rip+0xa/0x12 [83768.178473] [<ffffffff80253df0>] kthread+0x0/0x80 [83768.178514] [<ffffffff8020d18e>] child_rip+0x0/0x12 [83768.178557] [83768.178594] [83768.178594] Code: 44 8b 87 20 01 00 00 49 89 f4 45 89 ce 45 85 c0 0f 84 ad 00 [83768.179167] RIP [<ffffffff88339b4f>] :dvb_usb:dvb_usb_generic_rw+0x2f/0x1a0 [83768.179234] RSP <ffff810021939df0> [83768.179271] CR2: 0000000000000120 [83768.179419] ---[ end trace dba8483163cb1700 ]--- Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-11V4L/DVB (9486): ivtv/ivtvfb: no longer experimentalHans Verkuil
Remove the EXPERIMENTAL tag. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-11V4L/DVB (9485): ivtv: remove incorrect V4L1 & tvaudio dependencyHans Verkuil
ivtv used tvaudio in the past and at the time tvaudio required V4L1. Since tvaudio is no longer dependent on V4L1 and since ivtv actually no longer uses tvaudio at all, this is no removed from Kconfig. Without this patch ivtv won't be build if V4L1 is disabled. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-11V4L/DVB (9482): Documentation, especially regarding audio and informational ↵Tobias Lorenz
links This patch adds a recommendation to select SND_USB_AUDIO for listing and adds a documentation file for si470x. Signed-off-by: Tobias Lorenz <tobias.lorenz@gmx.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-11V4L/DVB (9475): cx18: Disable write retries for registers that always change ↵Andy Walls
- part 1. cx18: Disable write retries for registers that always change - part 1. Interrupt related registers will likely not read back the value we just wrote. Disable retries for these registers for now to avoid accidently discarding interrupts. More intelligent read back verification criteria are needed for these and other registers (e.g. GPIO line registers), which will be addressed in subsequent changes. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-11V4L/DVB (9372): Minor fixes to the saa7110 driverJean Delvare
* Apparently the author of the saa7110 driver was confused by the number of outputs returned by DECODER_GET_CAPABILITIES. Of course a decoder chip has no analog ouputs, but it must have at least one digital output. * Fix an off-by-one error when checking the input value of DECODER_SET_INPUT. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-11V4L/DVB (9368): VBI fix for cx88 cardsRafael Diniz
The attached patch fix VBI support cx88 card. I'm running a capture for hours, getting the closed caption from it[1], and it's working perfect - the output is the same of a bttv card. Please apply this patch as soon as possible. [1] - using zvbi-ntsc-cc of zvbi project. Signed-off-by: Rafael Diniz <diniz@wimobilis.com.br> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-11V4L/DVB (9358): CinergyT2: fix Kconfig typoThierry MERLE
config\tDVB_USB_CINERGY_T2 causes the make_kconfig.pl to forget to enable by default the compilation of cinergyT2 module. Signed-off-by: Thierry MERLE <thierry.merle@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-11V4L/DVB (9357): cx88-dvb: Fix Oops in case i2c bus failed to registerMatthias Schwarzott
There already is an report at kernel bugzilla about this issue: http://bugzilla.kernel.org/show_bug.cgi?id=9455 When enabling extra checks for the i2c-bus of cx88 based cards by loading i2c_algo_bit with bit_test=1 this may trigger an oops when loading cx88_dvb. This is caused by the extra check code that detects that the sda-line is stuck high and thus does not register the i2c-bus. cx88-dvb however does not check if the i2c-bus is valid and just uses core->i2c_adap to attach dvb frontend modules. This leads to an oops at the first call to i2c_transfer: $ modprobe i2c_algo_bit bit_test=1 $ modprobe cx8802 cx88/2: cx2388x MPEG-TS Driver Manager version 0.0.6 loaded cx88[0]: quirk: PCIPCI_NATOMA -- set TBFX cx88[0]: subsystem: 0070:9202, board: Hauppauge Nova-S-Plus DVB-S [card=37,autodetected], frontend(s): 1 cx88[0]: TV tuner type 4, Radio tuner type -1 cx88[0]: SDA stuck high! cx88[0]: i2c register FAILED input: cx88 IR (Hauppauge Nova-S-Plus as /class/input/input5 cx88[0]/2: cx2388x 8802 Driver Manager cx88-mpeg driver manager 0000:00:10.2: enabling device (0154 -> 0156) cx88-mpeg driver manager 0000:00:10.2: PCI INT A -> Link[LNKD] -> GSI 9 (level, low) -> IRQ 9 cx88[0]/2: found at 0000:00:10.2, rev: 5, irq: 9, latency: 64, mmio: 0xfb000000 cx8802_probe() allocating 1 frontend(s) cx88/2: cx2388x dvb driver version 0.0.6 loaded cx88/2: registering cx8802 driver, type: dvb access: shared cx88[0]/2: subsystem: 0070:9202, board: Hauppauge Nova-S-Plus DVB-S [card=37] cx88[0]/2: cx2388x based DVB/ATSC card BUG: unable to handle kernel NULL pointer dereference at 00000000 IP: [<e084d4ef>] :i2c_core:i2c_transfer+0x1f/0x80 *pde = 00000000 Modules linked in: cx88_dvb(+) cx8802 cx88xx ir_common i2c_algo_bit tveeprom videobuf_dvb btcx_risc mga drm ipv6 fscpos eeprom nfsd exportfs stv0299 b2c2_flexcop_pci b2c2_flexcop cx24123 s5h1420 ves1x93 dvb_ttpci dvb_core saa7146_vv saa7146 videobuf_dma_sg videobuf_core videodev v4l1_compat ttpci_eeprom lirc_serial lirc_dev usbhid rtc uhci_hcd 8139too i2c_piix4 i2c_core usbcore evdev Pid: 4249, comm: modprobe Not tainted (2.6.27-gentoo #3) EIP: 0060:[<e084d4ef>] EFLAGS: 00010296 CPU: 0 EIP is at i2c_transfer+0x1f/0x80 [i2c_core] EAX: 00000000 EBX: ffffffa1 ECX: 00000002 EDX: d6c71e3c ESI: d80cd050 EDI: d8093c00 EBP: d6c71e20 ESP: d6c71e0c DS: 007b ES: 007b FS: 0000 GS: 0033 SS: 0068 Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-11V4L/DVB (9356): [PATCH] saa7134: fix resource map sanity check conflictSuresh Siddha
Impact: driver could possibly stomp on resources outside of its scope {mchehab@redhat.com: I got two versions of the same patch (identical, except for whitespacing). One authored by Andy Burns and another authored by Suresh Siddha. Due to that, I'm applying the one that has less CodingStyle errors. I'm also adding both comments and the SOB's for both patches, since they are both interesting} Suresh Siddha commented: Alexey Fisher reported: > resource map sanity check conflict: 0xcfeff800 0xcff007ff 0xcfe00000 > 0xcfefffff PCI Bus 0000:01 BAR base is located in the middle of the 4K page and the hardcoded size argument makes the request span two pages causing the conflict. Fix the hard coded size argument in ioremap(). Andy Burns commented: I have already sent this patch on the linux-dvb list, but it didn't get much attention, so re-sending direct, I hope you all don't mind. While attempting to run mythtv in a xen domU, I encountered problems loading the driver for my saa7134 card, with an error from ioremap(). This error was due to the driver allocating an incorrectly sized mmio area, which was trapped by xen's permission checks, but this would go un-noticed on a kernel without xen. My card has a 1K sized mmio area, I've had information that other cards have 2K areas, perhaps others have different sizes, yet the driver always attempts to map 4K. I realise that the granularity of mapping is the page size, which typically would be 4K, but unless the card's base address happens to fall on a 4K boundary (mine does not) then the base+4K will end up spanning two pages, and this is when the error occurs under xen. My patch uses the pci_resource_len macro to determine the size required for the user's particular card, instead of the hardcoded 4K value. I've tested with a couple of printk() inside ioremap() that the start address and size do get rounded to the closest page boundary. With this patch I am able to successfully load the saa7134 driver and run mythtv under xen with my card, subject to correct pollirq settings in case of shared IRQ, I am still seeing occasional DMA panics, which I think are related to swiotlb handling by dom0/domU, usually the panic occurs when changing mux, once tuned to a mux, 12 hour continuous recordings are possible without errors. Reported-by: Alexey Fisher <bug-track@fisher-privat.net> Tested-by: Alexey Fisher <bug-track@fisher-privat.net> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Andy Burns <andy@burns.net> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-11V4L/DVB (9355): de-BKL cafe_ccic.cJonathan Corbet
Remove lock_kernel() call from cafe_ccic.c Commit d56dc61265d2527a63ab5b0f03199a43cd89ca36 added lock_kernel() calls to cafe_ccic.c. But that driver was written with proper locking and does not need the BKL, so take it back out. Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-11V4L/DVB (9352): Add some missing compat32 ioctlsGregor Jasny
This patch adds the missing compat ioctls that are needed to operate Skype in combination with libv4l and a MJPEG only camera. If you think it's trivial enough please submit it to -stable, too. Signed-off-by: Gregor Jasny <gjasny@web.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-11V4L/DVB (9351): ibmcam: Fix a regression caused by ↵Mauro Carvalho Chehab
a482f327ff56bc3cf53176a7eb736cea47291a1d As reported by David Ellingsworth: > I'm not sure if it matters or not, but the ibmcam driver in the > Mauro's linux-2.6 git tree in the for_linus branch is currently > broken. uvd is equal to NULL during most of ibmcam_probe. Due to that, an OOPS is generated at dev_info. This patch replaces uvd->dev->dev to dev->dev inside this routine. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Reviewed-by: David Ellingsworth <david@identd.dyndns.org>
2008-11-11V4L/DVB (9350): radio-si470x: add support for kworld usb radioAlexey Klimov
This patch add support for new device named KWorld USB FM Radio SnapMusic Mobile 700 (FM700). And changes few lines in comments. Signed-off-by: Alexey Klimov <klimov.linux@gmail.com> Acked-by: Tobias Lorenz <tobias.lorenz@gmx.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-11V4L/DVB (9348): dtv5100: add dependency on zl10353Antoine Jacquet
Update Kconfig to add missing dependency on zl10353 for dtv5100 driver. Signed-off-by: Antoine Jacquet <royale@zerezo.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-11V4L/DVB (9346): Optimization: Enable gate in a symmetric/disciplined way,Manu Abraham
rather than implementing different ways leading to confusion. This allows multiple gate_enable/disable's in the tuner_read/write functions, thereby lesser number of I/O operations throughout, eventually leading to better results. As a side effect demods that detect the STOP bit for auto closing of the gate can be avoided, thereby a very minimal gain in disabling the auto detect feature as well. Improves readability on the device control. Signed-off-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-11V4L/DVB (9337a): HID: Don't allow KWorld radio fm700 be handled by usb hid ↵Alexey Klimov
drivers This device is already handled by radio-si470x driver, and we therefore want usbhid to ignore it. Signed-off-by: Alexey Klimov <klimov.linux@gmail.com> Acked-by: Tobias Lorenz <tobias.lorenz@gmx.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-11Merge branch 'tracing/urgent' into tracing/ftraceIngo Molnar
Conflicts: kernel/trace/trace.c
2008-11-11drm/i915: Move legacy breadcrumb out of the reserved status page areaKeith Packard
Addresses in the hardware status page below index 0x20 are reserved for use by the hardware. The legacy breadcrumb was sitting at index 5. Move it to index 0x21, and make sure everyone uses the defined value instead of hard-coded constants. Signed-off-by: Keith Packard <keithp@keithp.com> Signed-off-by: Dave Airlie <airlied@linux.ie>
2008-11-11drm/i915: Filter pci devices based on PCI_CLASS_DISPLAY_VGADave Airlie
This fixes hangs on 855-class hardware by avoiding double attachment of the driver due to the stub second head device having the same pci id as the real device. Other DRM drivers probably want this treatment as well, but I'm applying it just to this one for safety. But we should clean up the drm_pciids.h mess now so that each driver has its own pci id list header in its own directory. Lets do that in the next release. Signed-off-by: Eric Anholt <eric@anholt.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-11-11libata: fix last_reset timestamp handlingTejun Heo
ehc->last_reset is used to ensure that resets are not issued too close to each other. It's initialized to jiffies minus one minute on EH entry. However, when new links are initialized after PMP is probed, new links have zero for this timestamp resulting in long wait depending on the current jiffies. This patch makes last_set considered iff ATA_EHI_DID_RESET is set, in which case last_reset is always initialized. As an added precaution, WARN_ON() is added so that warning is printed if last_reset is in future. This problem is spotted and debugged by Shane Huang. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Shane Huang <Shane.Huang@amd.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-11-11libata: Avoid overflow in ata_tf_read_block() when tf->hba_lbal > 127Roland Dreier
Phillip O'Donnell <phillip.odonnell@gmail.com> pointed out that the same sign extension bug that was fixed in commit ba14a9c2 ("libata: Avoid overflow in ata_tf_to_lba48() when tf->hba_lbal > 127") also appears to exist in ata_tf_read_block(). Fix this by adding a cast to u64. Signed-off-by: Roland Dreier <rolandd@cisco.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-11-11[libata] pata_pcmcia: another memory card supportMarc Pignat
Support for Apacer photo steno pro card. Signed-off-by: Marc Pignat <marc.pignat@hevs.ch> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-11-11[libata] pata_sch: notice attached slave devicesMark Salter
I posted this last month, but was prompted to do so again in bz#467457 Add capability flag to support slave devices with pata_sch driver. Signed-off-by: Mark Salter <msalter@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-11-11[libata] pata_cs553*.c: cleanup kernel-docQinghuang Feng
No arguments named @deadline in cs5535_cable_detect() and cs5536_cable_detect(). Remove them. Signed-off-by: Qinghuang Feng <qhfeng.kernel@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-11-11drm/radeon: map registers at load timeDave Airlie
Now that the radeon driver has suspend/resume functions, it needs to map its registers at load time or it will likely crash if a suspend operation occurs before the driver has been initialized. This patch moves the register mapping code from firstopen to load and makes the mapping into a _DRM_DRIVER one so that the core won't remove it at lastclose time. Fixes (at least partially) kernel bz #11891. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2008-11-11drm: Remove infrastructure for supporting i915's vblank swapping.Eric Anholt
It's not used in any other drivers, and doesn't look like it will be from drm.git master. Signed-off-by: Eric Anholt <eric@anholt.net> Signed-off-by: Dave Airlie <airlied@linux.ie>
