Implementing dma_sync_* functions for usb transfer buffers
when DMA is being used by ehci-hcd.
Bug 953885
Change-Id: Ia772138752e3fe03bb45ee983dffa1b5d8d620f5
Signed-off-by: Vinayak Pane <vpane@nvidia.com>
Reviewed-on: http://git-master/r/102687
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
Adds a global alpha parameter to each window. It provides a default
alpha value for pixel formats that do not include alpha.
Change-Id: I5465864877a727b4daed0eb32fb8219e2ccb663e
Signed-off-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-on: http://git-master/r/101806
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Use nvmap.h include file from kernel/include instead of mach-tegra/include.
Bug 854182
Change-Id: I23eec4df8f69da185d08acd37ae0fba984675e92
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/102726
GVS: Gerrit_Virtual_Submit
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Bug 854182
Change-Id: I9b2899c6170f1867043804ec756f37da93161242
Reviewed-on: http://git-master/r/102725
Bug 854182
Change-Id: I85ee8d8aacf5884d6a1b6bb3fb70e6f6d4110011
Reviewed-on: http://git-master/r/102724
Bug 854182
Change-Id: Ibfa271191bfce371986df29a7971b1da077c3f06
Reviewed-on: http://git-master/r/102722
Bug 854182
Change-Id: I9a44471dc77d1ed7aa3b6e61a5eca4833fe6dc25
Reviewed-on: http://git-master/r/102721
Bug 854182
Change-Id: I385657f45483f2696e99fc2b4ed934fef5decd1e
Reviewed-on: http://git-master/r/102720
Enable output discharge always to have faster ramp-down
time.
bug 981330
Change-Id: I0a00ab38e9be631a58bc8b11148be5c3c508d119
Reviewed-on: http://git-master/r/102882
Tested-by: Pradeep Goudagunta <pgoudagunta@nvidia.com>
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Add EMC clock rate control to tegra_camera ioctl.
This change allows user space to change EMC clock requirement
for camera based on use case and resolution.
For example, video recording use case needs more than double
memory bandwidth of preview use case.
Bug 964635
Change-Id: Ibe5a77a810869b53b6e057f2ee62ebb96997c2f4
Signed-off-by: Jihoon Bang <jbang@nvidia.com>
Reviewed-on: http://git-master/r/101274
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Allow clk API users to simplify their cleanup paths by providing a
managed version of clk_get() and clk_put().
Cherry-picked from mainline
a8a97db984bdc5e89d42e41891543d2daaf314cb
Change-Id: Ib36c0c82063928937166b6014fca92025bc83878
Reviewed-on: http://git-master/r/102860
Set correct VIC value for 1080p/30Hz mode in AVI infoframe.
Bug 969243
Change-Id: I6da9236124dbad7e4d74f3cf6dad7e273bd7778b
Signed-off-by: Youngjin Kim <nkim@nvidia.com>
Reviewed-on: http://git-master/r/100553
(cherry picked from commit 41858f2fd99face9dc0c47bd2870045291a6c0b6)
Reviewed-on: http://git-master/r/102378
Reviewed-by: Donghan Ryu <dryu@nvidia.com>
To avoid border color making limited range test of MHL
certification failed.
Bug 966615
Bug 969243
Signed-off-by: Vick Yu <vyu@nvidia.com>
Change-Id: I5c9659358a1c8dac9c6a5194bbc6f59b8230f116
Reviewed-on: http://git-master/r/100552
(cherry picked from commit 20774a3db055630ba0e59669e2e7cbd412f03178)
Reviewed-on: http://git-master/r/102377
Reviewed-by: Youngjin Kim <nkim@nvidia.com>
Tested-by: Youngjin Kim <nkim@nvidia.com>
Merges of dma changes from mainline reported conflict and
it was not got resolved properly.
Fix the resolution issue.
Change-Id: I7edc5effc0b9a61363e77e6cc39eb62e315396d0
Reviewed-on: http://git-master/r/102590
If two threads need to wait for CDMA to become quiet at the same
time, the second one will cause a BUG(). Replace the BUG() with a
code to yield and try again.
Change-Id: I7925ad0cc0e8292919e54d0fa45f7837f453358d
Reviewed-on: http://git-master/r/102437
Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
Tested-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
nvhost attempts to purge all buffers from timed out contexts. This is
very error prone, and not necessary. Change behavior so that only the
hung job, and the immediately following jobs from same context are
purged. This simplifies code, and corrects bug where the push buffer
modifications caused panics.
Bug 982946
Change-Id: Ifb26484cf02ef40f8d5b20338eebc0a731f453cf
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/102234
This driver supports ivoltage regulator driver for MAX8973
voltage regulator chip. The MAX8973 high-efficiency, three-phase,
DC-DC step-down switching regulator delivers up to 9A of
output current.
bug 981355
Change-Id: I6e4ff62139face4e47e2be269554a64c2654e74b
Reviewed-on: http://git-master/r/102148
nvhost panics if hardware does not respond within 30 seconds. Remove
this behavior, as it causes problems in emulation and simulation.
Panic should be used only to prevent corruption.
Submits are now given a default timeout of 30 seconds. The clients
can still override with their own timeout value.
MPE doesn't provide the number of slots for context save/restore.
This information is needed to be able to use the submit timeout for
MPE.
Bug 982946
Change-Id: I0f54d639df0fb726cc3163b317bf9c90bf56798b
Reviewed-on: http://git-master/r/100246
Integrate Marvell SD8797 M2614311-GPL driver release
Package Ver: T3T-14.69.11.p122-M2614311_A0B0-MGPL
Bug 954218
Change-Id: Ic4c110cc06f45cf3f612df323e68c75edeb46e11
Signed-off-by: Mohan T <mohant@nvidia.com>
Reviewed-on: http://git-master/r/100052
Reviewed-by: Rakesh Kumar <krakesh@nvidia.com>
- nvhost_master holds a reference to all the channels for
a chip architecture
- however, nvhost_master is a private data of host1x hardware
device. so it should contain only members needed by host1x
hardware device
- add chip specific apis to allocate and free channels
- this will also help to remove the static binding between
nvhost_device and a channel per SoC in future
Bug 871237
Change-Id: I2148db57b995b4cb60954ebb6e670f588552eca4
Signed-off-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Reviewed-on: http://git-master/r/91687
Clipping PM QoS requests to combined old policy limits that include
both PM QoS and user policy requests creates a circular dependency.
As a result new PM QoS maximum limit is rejected if it is above
previous PM QoS minimum limit even though the new PM QoS minimum
limit has been already lowered below new PM QoS maximum limit.
Instead clip PM QoS request to the old user policy limits only.
Change-Id: Ice0a53a699e0798f07f0e32d6b8a28586fe5db0c
Signed-off-by: Alex Frid <afrid@nvidia.com>
Reviewed-on: http://git-master/r/102386
Reviewed-by: Antti Miettinen <amiettinen@nvidia.com>
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
Tested-by: Vikas Ramesh Kedigehalli <vikasr@nvidia.com>
Move WinB's format limitations to a list of preferred formats.
Bug 985197
Change-Id: Ife37c79441b2737592ace51e94ab0c80af4af917
Reviewed-on: http://git-master/r/102629
Reviewed-by: Chao Xu <cxu@nvidia.com>
Reviewed-by: Robert Morell <rmorell@nvidia.com>
Reviewed-by: Michael Frydrych <mfrydrych@nvidia.com>
Reviewed-by: Kevin Huang (Eng-SW) <kevinh@nvidia.com>
Add MODULE_LICENSE to modules that do not advertise a license,
and therefore taint the kernel.
Bug 979176
Change-Id: I1abbfa9ca1535b39e70d8bf7aa975e2663a6e45d
Signed-off-by: Eric Brower <ebrower@nvidia.com>
Reviewed-on: http://git-master/r/100214
Makes function pointer type for mode_filter match the function in hdmi.c
Change-Id: Id61f319a4ddef003b79782391e9e7f2f8cb32dda
Reviewed-on: http://git-master/r/102630
Reviewed-by: Shashank Sharma <shashanks@nvidia.com>
Use static for functions that are not called externally.
Change-Id: Iacccb83e31e860d10f92897041421298231e45b1
Reviewed-on: http://git-master/r/102623
Tested-by: Jon Mayo <jmayo@nvidia.com>
Fix section mismatch warnings derived from
tegra_uart_platform_driver.
Bug 984436
Change-Id: Iec737f28b0a7ce3ae521ad788e6ca5a101675c52
Signed-off-by: Pradeep Kumar <pgoudagunta@nvidia.com>
Reviewed-on: http://git-master/r/102237
Bug 955184
Change-Id: I7ac0a290c2b6acd454de05d094bd676b88f4b476
Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-on: http://git-master/r/101546
Reviewed-by: Simone Willett <swillett@nvidia.com>
-Move _tegra_dc_enable to before irq_request and remove
disable_dc_irq.
-It will remove warning of "IRQ when DC not powered!".
Bug 955184
Change-Id: If9b039f3f1635d92f10bfc54af08101972fc3d57
Reviewed-on: http://git-master/r/101498
The regulator module consists of 1 DCDC. The output voltage
is configurable and is meant for supply power to the core
voltage of Soc.
Change-Id: Ic62d100a588f7b6f1b30c11fd44a925c97393069
Reviewed-on: http://git-master/r/100653
WAR comprises of soft reset dsi controller followed by
explicitly clearing host trigger.
Bug 982919
Change-Id: Ia8c497dd496435e429cd5b5ee8aaf1b7d78dc797
Signed-off-by: Animesh Kishore <ankishore@nvidia.com>
Reviewed-on: http://git-master/r/102204
Reviewed-by: Pavan Kunapuli <pkunapuli@nvidia.com>
check if requested state and current BT power state is same,
if yes, do not toggle BT power GPIO's.
if not, set requested power state.
Bug 982600
Bug 928604
Change-Id: I82c65fd6d43940c86cc3de440295ba179a4ade33
Signed-off-by: Nagarjuna Kristam <nkristam@nvidia.com>
Reviewed-on: http://git-master/r/102190
RTC_WKALM_SET ioctl should do two things:
1. Set alarm value
2. Enable alarm irq
In the current implementation for RTC_WKALM_SET ioctl we are only setting
the alarm value but not enabling the alarm irq and hence the system
is not waking from lp0 state once the set alarm value expiries.
For RTC_WKALM_SET ioctl, alarm->enabled will be set to one from userspace.
So based on this condition we can differentiate between RTC_WKALM_SET &
RTC_ALM_SET and accordingly enable alarm irq.
Bug 978205
Signed-off-by: Preetham Chandru R <pchandru@nvidia.com>
Change-Id: Ia35192e691ca116b13093f52873020f67c5c2f8d
Reviewed-on: http://git-master/r/101447
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Adding a new config option and enabling background ops in driver.
Correcting the EXT_CSD byte that needs to be written in order to
trigger background ops in the MMC firmware.
Bug 847037.
Change-Id: Ibc517540cab43fa5070b142a416f6b67f2f7e7be
Signed-off-by: Vishal Singh <vissingh@nvidia.com>
Reviewed-on: http://git-master/r/99117
tegra_ehci_suspend_noirq/tegra_ehci_resume_noirq breaks
the modem suspend call as it does a regulator_disable()/regulator_enable
call which in turn requires the irqs to be enabled.
Hence maintain a normal suspend call i.e with irqs enabled but
split the resume to normal resume and noirq resume.
Spliting the resume in this way takes care of the below erros in
lp0/lp1
"tegra-ehci tegra-ehci.2:fatal error"
"tegra-ehci tegra-ehci.2: HC died; cleaning up"
Originally resume_noirq & suspend_noirq were added to avoid the above
errors but since it breaks the modem suspend call splitting the suspend
and resume in this way
Bug 954564
Change-Id: I630b3dbe2ca66d194857dc71ababa3e5955785b1
Reviewed-on: http://git-master/r/99100
Set the eMMC ddr mode clock dynamically based on emc
clock rate. If ddr clock limit is specified and the emc
clock is less than max emc freq, then limit emmc ddr
clk. If not, set the max eMMC ddr clock.
Bug 967719
Change-Id: I9f70077c4ac4bb1f3e6d894fcb8420b1aba284dd
Signed-off-by: Pavan Kunapuli <pkunapuli@nvidia.com>
Reviewed-on: http://git-master/r/100579
Move initialization for HOST1X sync point irq to nvhost driver.
Bug 871237
Change-Id: I0d31e03b43999c609194665cdcbd2f0e498d848f
Reviewed-on: http://git-master/r/100250
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
add ov5640 yuv sensor support - initial.
bug 921322
Change-Id: I813afa8963e39afe475f9fdd43152cfaf1a16ae1
Signed-off-by: Charlie Huang <chahuang@nvidia.com>
Reviewed-on: http://git-master/r/99506
Reviewed-by: Frank Chen <frankc@nvidia.com>
BT Filetransfer have some issue.
This reverts commit e8c243d5d09d1a552b66df7a8a0a0313047ebbac.
Bug 982630
Change-Id: I6e76d44e076874569518fa881e427918d3e546f2
Reviewed-on: http://git-master/r/101914
- currently, nvhost_master holds the reference to struct
chip_support
- the struct chip_support hides the chip specific implementation
for channel submit, cdma, push buffer operations etc. so
it exposed all the internal structures through nvhost_master
- move chip_support to be a part of nvhost_bus since it only has
function pointers to chip specific api implementations
- nvhost_master is host1x device specific private data so
ideally it should not hold reference to chip specifics
Bug 871237
Change-Id: I4f3f48ee5fc47a90288d110ea8eef905150275a0
Reviewed-on: http://git-master/r/94421
In SDR50 mode, set the controller clock to double
the requested clock to ensure that the core voltage
is maintained at a min of 1.2V.
Bug 965298
Change-Id: I557a07de97efd6b44f812a11da657e03d3ddefd0
Reviewed-on: http://git-master/r/101522
Add display feature table so that user and kernel could set and
update window attributes properly.
Bug 962353
Change-Id: I08490a225892660126f3eefe4d5b7a4bb61d9bf7
Signed-off-by: Kevin Huang <kevinh@nvidia.com>
Reviewed-on: http://git-master/r/101078
Retries should be done only after abort command
is issued for the current failed transfer. The block
layer already has an implementation for retrying.
No need for the extra retries.
Bug 961761
Bug 922239
Change-Id: I07f60e85e093b725007727833739013f8fd66d43
Reviewed-on: http://git-master/r/100563
Add trace events for updating the syncpt value from hardware, and
wait check.
Change-Id: If17de153ae36c0665fe0af2f405dfe42f7fcd656
Reviewed-on: http://git-master/r/101524
Reviewed-by: Ken Adams <kadams@nvidia.com>
Add context switch to the ftrace dump.
Change-Id: I5df032273982b919fb94263cff38d8b8b6b6be45
Reviewed-on: http://git-master/r/101523
timing1_read was initialized with timing0 from nor platform data
changed the same to use timing1 from platform data instead of
timing0
Bug 934187
Change-Id: I04c41323de25fb2bb53dac91301cee9c0820707a
Signed-off-by: Mohit Kataria <mkataria@nvidia.com>
Reviewed-on: http://git-master/r/95293
Reviewed-on: http://git-master/r/100904
Reviewed-by: Amlan Kundu <akundu@nvidia.com>
Cancel delayed work upon suspend and schedule it on resume
Bug 917914
Reviewed-on: http://git-master/r/95833
(cherry picked from commit a191d13e9dcdae715c9e03e1980857d00c082dc5)
Change-Id: Ib8292daed3b4115657b1a66e1382ed7c1c448071
Reviewed-on: http://git-master/r/97080
Reviewed-by: Pritesh Raithatha <praithatha@nvidia.com>
Tested-by: Sang-Hun Lee <sanlee@nvidia.com>
GVS: Gerrit_Virtual_Submit <kchilds@nvidia.com>
We should not call dev_get_drvdata() as the driver data is never set.
We should use container_of() as it is been used for other sysfs attributes.
Without this change writing to the soft_connect or srp interfaces crashes
the kernel because of null pointer dereference.
Bug 975473
Signed-off-by: Preeham Chandru R <pchandru@nvidia.com>
Change-Id: I45f6dab32f5435d518bd5b4fcdfafa54b9b89acd
Reviewed-on: http://git-master/r/100238
Tested-by: Preetham Chandru <pchandru@nvidia.com>
Reviewed-by: Rakesh Bodla <rbodla@nvidia.com>
Reviewed-by: Kiran Adduri <kadduri@nvidia.com>
This implementation sets governor for a cpu using existing
cpufreq interfaces.
bug 871958
Change-Id: Ic4e7e2a2b0babaf1829b559b5db211666d449b86
Signed-off-by: Puneet Saxena <puneets@nvidia.com>
Reviewed-on: http://git-master/r/97939
bug 949219
Change-Id: I408fb008a70c7ea546384e68ac50c1f0604fc39a
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/92276
Do not use nb_channels to find out the number of client devices.
Instead, allocate devno regions when they are needed and find a
device by module id by iterating over nvhost bus.
Bug 871237
Change-Id: I53fd0d8e5874422ef9877430c0a170db2660118a
Reviewed-on: http://git-master/r/99067
