Currently dr_controller_run() is called only during otg state
change.
When we unload a gadget driver, for example g_mass_storage
gadget driver, dr_controller_stop() is called but when it is
loaded back dr_controller_run() won't get called becasue of the
if condition failure. i.e
if (!udc->transceiver) {
dr_controller_run(udc);
So when the gadget driver is loaded for the second time
without removing the cable (i.e without otg state change),
the device won't get enumerated on the host because DR
IRQs are not enabled.
This CL fixes the above issue.
Bug 1012787
Signed-off-by: Preetham Chandru <pchandru@nvidia.com>
Change-Id: Ia127630e24dbe4c1e418163c2b858efb3baa8e45
Reviewed-on: http://git-master/r/114592
(cherry picked from commit be3e9def273181d1b44c1891de8602faebd719a8)
Reviewed-on: http://git-master/r/124283
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
Give ownership of the DMA buffer back to the processor first and
then free the buffer. Otherwise processor won't be able to
access the dma mapped buffers and this would lead to slab
corruption.
When the DMA buffer is freed without a call to dma_sync_single_for_cpu(),
the kernel won't be able to set the buffer as POISON FREE and when we
acquire this memory back again the kernel will start printing slab
corruption output as the memory is not set to POISON FREE
Bug 1017884
Bug 1018161
Reviewed-on: http://git-master/r/#change,122151
Signed-off-by: Preetham Chandru R <pchandru@nvidia.com>
Reviewed-on: http://git-master/r/122390
(cherry picked from commit 642d37a0eee196d0ce811dd11bb7af5ba281ee3a)
Change-Id: I00d6cb185cd2314cccb56f968eb0a05288588c13
Reviewed-on: http://git-master/r/123907
Set activation of a mode forcefully via setting FB_ACTIVATE_FORCE
flag. Required for stereo modes also.
Bug 1005399
Change-Id: I37872cc2a04abc8774a5f9f9df7d9e90f2c977f6
Signed-off-by: Shashank Sharma <shashanks@nvidia.com>
Reviewed-on: http://git-master/r/122087
GVS: Gerrit_Virtual_Submit
This patch contains following changes:
1. Modify tegra_fb_update_monspecs to select best mode to apply
on framebuffer, in HDMI hotplug.
2. Add a console_lock to prevent corruption while fbcon running
in multiple threads.
3. Add a tegra_dc_disable/enable in tegra_fb_set_par to reflect
the programmed new mode applied on DC.
Bug: 1005399
Change-Id: I133b38b00f25f767afc05549550fecde8d092fb2
Reviewed-on: http://git-master/r/120932
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-by: Kiran Adduri <kadduri@nvidia.com>
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
NVMAP_CONVERT_CARVEOUT_TO_IOVMM is only available for IOMMU less SoCs.
This was introduced by (in 'main'):
commit b8b0b4c42fc77d94b8deadaa46f795784f3bbb5e
video: tegra: nvmap: Make IOMMU/IOVMM selectable in Kconfig
Bug 1017112
Change-Id: I2a6f101b15085ece600f77690bc77adc042eb29f
Reviewed-on: http://git-master/r/117976
(cherry picked from commit a68ae587edbc3ca5d3216d39c462abd84f469027)
Reviewed-on: http://git-master/r/121409
Reviewed-by: Hiroshi Doyu <hdoyu@nvidia.com>
Tested-by: Matthew Pedro <mapedro@nvidia.com>
Make sure phy is turned ON before reading USB
registers.
Bug 993380
Bug 1006579
Bug 1018601
Change-Id: Ib951cad822f90f59fe829d016e2c1bda7a7cc243
Signed-off-by: Rakesh Bodla <rbodla@nvidia.com>
Reviewed-on: http://git-master/r/116045
(cherry picked from commit a1a6db7dc88880fb3d4bca0036ce421e4032adae)
Reviewed-on: http://git-master/r/117972
Tested-by: Preetham Chandru <pchandru@nvidia.com>
This patch allows nvmap to use the standard IOMMU API as its backend
engine instead of the legacy tegra IOVMM by Kconfig.
Enable TEGRA_IOMMU_{GART,SMMU} under IOMMU in config, and it
automatically disables IOVMM, instead.
Change-Id: I71112ef8072591aac4a93075623ca31c8851a960
Signed-off-by: Hiroshi DOYU <hdoyu@nvidia.com>
Reviewed-on: http://git-master/r/114217
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Without the CONFIG_SWITCH enabled, there are multiple unused
variable warnings that get treated as error.
bug 949219
Signed-off-by: Rhyland Klein <rklein@nvidia.com>
Change-Id: I39512367fa4bbd3b00a435d0d7a31cfede9e712f
Reviewed-on: http://git-master/r/115428
Reviewed-by: Sanjay Singh Rawat <srawat@nvidia.com>
It takes read RW semaphore to access policy governor
bug 997731
Change-Id: Ibdc3dd54cf6076c0fef4bc58f144e4bcb4631d76
Signed-off-by: Puneet Saxena <puneets@nvidia.com>
Reviewed-on: http://git-master/r/107079
Reviewed-by: Sang-Hun Lee <sanlee@nvidia.com>
Reviewed-by: Peter Boonstoppel <pboonstoppel@nvidia.com>
Use the right number of parameters for tegra_dc_calc_fresh() when called from
print_mode(). This code is only used for debug.
Change-Id: I4d0bb8b1700f670644057039fe8d0bc315b27c1d
Signed-off-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-on: http://git-master/r/115485
when BT is turned off HCI_DEV_DOWN event is received and bluesleep
protocol is stopped. On bluesleep stop, EXT_WAKE gpio will be set to
default high level. This condition does not allow BT chip to enter
low power mode. So, start and stop bluesleep based on HCI_DEV_REG
and HCI_DEV_UNREG events instead of HCI_DEV_UP and HCI_DEV_DOWN.
Also, enable and disable host wake functionality based on HCI_DEV_UP and
HCI_DEV_DOWN events, as these events indicate BT turn ON and OFF
Bug 1014590
Change-Id: I3929c1328ac024eb080359283107dabf3712e9ea
Signed-off-by: Nagarjuna Kristam <nkristam@nvidia.com>
Reviewed-on: http://git-master/r/114984
Reviewed-by: Rakesh Kumar <krakesh@nvidia.com>
After making pclk output ahead of LVDS_SHDN# , data output is later than
panel ready then caused partial black screen. Force triggered data output to
get it fixed.
Bug 972377
Bug 976081
Bug 1001434
Change-Id: Icd455d7439f622e46295158a5435286c521526aa
Signed-off-by: Roger Hsieh <rhsieh@nvidia.com>
Reviewed-on: http://git-master/r/113164
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
When set threshold of tsensor,convert the temp to counter.
The counter convert from temp is with ~1.8C average error.
Improved the accuracy, make it to be ~0.1C.
Bug 1015288
Change-Id: Icab03b559eaeb8846dd1191869afe39c9965f934
Signed-off-by: Daniel Fu <danifu@nvidia.com>
Reviewed-on: http://git-master/r/114904
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
This is similar to commit a62be5b5595ad86411ced81bceeb3d6a693426d2
pushed for rel-14 branch.
Bug 1004341
Signed-off-by: Bharat Nihalani <bnihalani@nvidia.com>
Reviewed-on: http://git-master/r/111227
(cherry-picked from fbfce3106da8dad18948103c812bdd9d45ffdd06)
Change-Id: Ib459094fd6499b3cc63bc534bf36e57dc98ce62b
Reviewed-on: http://git-master/r/114584
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
updated MT9E013 and AR0832 Recommended Settings
Bug 1009371
Change-Id: Ib1e4ce2f42ebc8d2080a47613cf7054a19198dda
Signed-off-by: Amy Deng <amyd@nvidia.com>
Reviewed-on: http://git-master/r/113092
Reviewed-by: Yining Deng <ydeng@nvidia.com>
Reviewed-by: Frank Chen <frankc@nvidia.com>
Allows overidding the default disp mode without having to recompile
the kernel. Boot args can be specified in the following format:
disp_params=<rgb|hdmi|dsi>:pclk,h_active,v_active,h_ref_to_sync,
v_ref_to_sync,h_sync_width,v_sync_width,h_back_porch,v_back_porch,
h_front_porch,v_front_porch;<rgb|hdmi|dsi>:pclk,h_active,...
Bug 969088
Change-Id: Id0acf608de145493f6749d5b799d4bbb8162ba72
Signed-off-by: Nirav Patel <nipatel@nvidia.com>
Reviewed-on: http://git-master/r/104604
- Adding flag to treat warning as error.
- Handled warning of unused function.
bug 949219
Change-Id: Ic6edfc28bae95b8395cbd51e80f14aa4aa663f61
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/114624
WFD specific changes integrated from broadcom patch
Bug 1001418
Bug 997838
Change-Id: I0632307bf5fb959def4ee12687430a14ab9e068e
Signed-off-by: Narayan Reddy <narayanr@nvidia.com>
Reviewed-on: http://git-master/r/111032
Tested-by: Rakesh Goyal <rgoyal@nvidia.com>
Support for get/set capabilities added. Focuser code has a way to
calibrate itself that results in determination of optimal working
range. This along with actual range from device ROM are returned
to the caller. Focuser has the macro at lower end and infinity at
farther end of the range, which are reversed to the user level to
keep the inf/macro positions to be consistent. Focuser range
translation is taken out.
Bug 1004816
Change-Id: I1a086ff10e99940f9ad861397bf7e71e9996c68a
Signed-off-by: Naren Bhat <nbhat@nvidia.com>
Reviewed-on: http://git-master/r/110443
Reviewed-by: Charlie Huang <chahuang@nvidia.com>
Reviewed-by: Patrick Shehane <pshehane@nvidia.com>
Tested-by: Charlie Huang <chahuang@nvidia.com>
Introduce IOMMU backend functions which use DMA API familiy
internally. Replace tegra_iovmm_*() API with arm_iommu_*iova*() and
dma_(un)map_page_(at)().
Change-Id: I0b014926ffedc12bf8f868b163982c6082d050b6
Reviewed-on: http://git-master/r/114216
Allow tegra_iovmm_alloc_client() to take struct device * instead of
const char *name w/ __tegra_iovmm_alloc_client(). This is necessary to
support IOVMM and IOMMU simultaneously.
Change-Id: I18df5001bfe0ece8f9f15b636eb11def9f228dfb
Reviewed-on: http://git-master/r/114215
Move tegra_smmu_init in core_init. IOMMU should be available at early
stage of system booting.
Change-Id: I8675e62acef44fb585a731c0f24be716b76ca41a
Reviewed-on: http://git-master/r/114214
Revisited later with new conf passed from DT.
Change-Id: Ic94a698b0ee56603bbb7f2204ae8c5412ea133b1
Reviewed-on: http://git-master/r/114213
Now consider frequency greater than or equal to idle_top_freq as UP
Change-Id: I1332d46d1e42a00b3b31897b158eaf4ccfbaf8f5
Signed-off-by: Sai Charan Gurrappadi <sgurrappadi@nvidia.com>
Reviewed-on: http://git-master/r/113678
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Reviewed-by: Peter De Schrijver <pdeschrijver@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Fixed hi and lo limit bug in thermal estimator driver.
bug 1007726
Change-Id: I2be90ca7d875dbed34004b83f070fb5cbd8bc467
Signed-off-by: Joshua Primero <jprimero@nvidia.com>
Reviewed-on: http://git-master/r/113564
debug uart driver needs to be resumed before calling printk
so move debug message after finishing resume
bug 992588
Change-Id: Ia8991a4b7be7a4e2a765c8e6b494fd906b38b98c
Signed-off-by: Daehyoung Ko <dko@nvidia.com>
Reviewed-on: http://git-master/r/108435
(cherry picked from commit 75e7ef273d52b40d5d662541043e7eebc74ee24e)
Reviewed-on: http://git-master/r/110433
Wake sources usb VBUS or ID detect enabled
bug 980993
bug 936982
Change-Id: Iea36d308c1a118abdb7815212d749bd058d0054f
Signed-off-by: Bitan Biswas <bbiswas@nvidia.com>
Reviewed-on: http://git-master/r/103141
Reviewed-by: Rakesh Bodla <rbodla@nvidia.com>
Earlier implementation only allowed single wake source
for a particular irq in wake table. Changed implementation
to support multiple wake sources ==> single irq mapping.
bug 980993
Change-Id: Iacb00487531129ef19c53128824aba802e80350e
Reviewed-on: http://git-master/r/103140
Because SE interrupts could be enabled in bootloader, if it's not
cleared before jumping into kernel, it continues to assert the
interrupt line to interrupt controller. When SE interrupts is
enabled in kernel, to access SE registers in IST without clock
enabled hung the CPU. To fix this issue, interrupt enabling is
moved after clock is enabled.
bug 1010334
Change-Id: I1b909efce2c9d92c3112039fc217f7c1360f9bbb
Reviewed-on: http://git-master/r/113073
(cherry picked from commit b06e6662f738ad01a3b2b6803db654abaa03385e)
Signed-off-by: Victor(Weiguo) Pan <wpan@nvidia.com>
Change-Id: Ide4b0295c781e0bba7aa071616e3e6160e44ee76
Reviewed-on: http://git-master/r/114064
This change is for programming VI and EPP through ISP channel
to support RGB input and dual video capturing.
1. Added syncpt in the ISP channel to submit the channel.
2. Added epp clock to use VI2EPP for RGB capture.
Note: To use this channel, EPP should be free from 2D.
Bug 988546
Change-Id: I17fe278c9325aac2ea1e29cbaf50c8a4499d8551
Signed-off-by: Songhee Baek <sbaek@nvidia.com>
Reviewed-on: http://git-master/r/113965
- Handled warning of, possible use of uninitialized variable and unused
function.
bug 949219
Change-Id: I0d7d345e66774f08e52a12e653a5e7aa6a7a8591
Reviewed-on: http://git-master/r/113905
- Handled warning of unused label.
bug 949219
Change-Id: I72e22063b199562c4a4c065419c1656e3e8ff7ff
Reviewed-on: http://git-master/r/113880
Freeze vblank worker while suspending by adding the work into
system freezewq. This eliminates a kernel panic caused by nvsd
reading brightness valuesfrom display while clock gated.
Bug 1006180
Bug 1003969
Bug 1003730
Change-Id: Ice9bfb18e5c826ae063c2b901421b1047ff9d2f0
Signed-off-by: Mark Zhang <markz@nvidia.com>
Reviewed-on: http://git-master/r/112880
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
APB clock for dtv logic block should be recorded by dtv_ctx->clk
hanlder. Otherwise, kernel will trigger a NULL point error in suspend.
Fixed Bug 1011149
Change-Id: I5d342ab6fc8ffb71211e370d304b17d5d44eef20
Signed-off-by: Adam Jiang <chaoj@nvidia.com>
Reviewed-on: http://git-master/r/108743
Add init value for rc in lightsensor_ioctl() to fix compile time
warning.
Change-Id: Ifcb953873b5bc861303d9d32b1906a69b2c8311f
Signed-off-by: Chandler Zhang <chazhang@nvidia.com>
Reviewed-on: http://git-master/r/113121
Previously the callback was added to control USB VBUS.
The standard way is to use regulator.
Bug 997805
Change-Id: I88b15befaf4e162478da19ead50695978b2c5f4b
Reviewed-on: http://git-master/r/112901
Reviewed-by: Syed Rafiuddin <srafiuddin@nvidia.com>
The callback in otg driver is not a standard way of controlling
USB VBUS. Remove the callback and use regulator to control.
Bug 997805
Change-Id: I6d7fd01f9346e037515901ac6fe6d349a140d13e
Signed-off-by: Chander Zhang <chazhang@nvidia.com>
Reviewed-on: http://git-master/r/112896
Enable FIQ on 2nd watchdog expiry to make use of FIQ debugger. FIQ
debugger can be used to dump call-stack and registers when WDT logic
triggers FIQ on 2nd timeout.
Bug 970018
Change-Id: Ia2e7f8b136499974ff51f2f0c2ef55704dfe37e1
Signed-off-by: Kamal Kannan Balagopalan <kbalagopalan@nvidia.com>
Reviewed-on: http://git-master/r/110953
Reviewed-by: Xin Xie <xxie@nvidia.com>
Reviewed-by: Steve Kuo <stevek@nvidia.com>
- Make all CPU watchdogs accessible except WDT0
- CPU WDT0 is reserved for suspend/resume WDT recovery
- Fix WDT enable sequence on watchdog driver probe
Bug 857748
Change-Id: Ia2d07856c32230ab8c9195fee151af09bce3ddde
Reviewed-on: http://git-master/r/99780
Changed the low temp to 0C since 20C is very easy to trigger thermal
alert under -15C to 15C environment temperature. And the thermal alert
will run into endless alert from tsensor_work_func.
Also revised suspend and resume routine to cancel the work when suspending
and disable/enable irq.
Bug 999175
Signed-off-by: Linqiang Pu <dpu@nvidia.com>
(cherry picked from commit 6a909bfa690991438be298d4933946a92e4929c4)
Change-Id: Icafc6d5f0164204cc0cb7bea64bef2fadadbfbfd
Reviewed-on: http://git-master/r/111550
tsensor driver uses fixed point approximations.
Improved accuracy of tsensor temperature reading
- adding support to handle negative temperature to counter
conversions and vice-versa
bug 1001632
bug 999175
(cherry picked from commit 86ae0bdc3fbd34a5a1d0e08f7721ed527ddf5408)
Change-Id: I5f6df85611d502a6dda1186234078fe973d7ca75
Reviewed-on: http://git-master/r/100576
Tested-by: Bitan Biswas <bbiswas@nvidia.com>
Restrict go_maxspeed_load and max_boost at mid-range frequencies.
Change-Id: I9e3c59bbe708b428e12ce4dbef2144be09751d5a
Signed-off-by: satya popuri <spopuri@nvidia.com>
Reviewed-on: http://git-master/r/111754
Reviewed-by: Karthikeyan Samynathan <ksamynathan@nvidia.com>
- Using the dma sync apis to keep coherency.
bug 984039
Change-Id: I9e389d2679f05c519ae4a51462247b7efeae01ca
Reviewed-on: http://git-master/r/111612
READ API:
read API ignores count and will always return 16 bit data.
read API expects user to supply it with min of 16 bits data
it returns CEC packet in following format
bit 0-7: data
bit 8: EOM
bit 9: ACK
WRITE API:
write API ignores count and will always accept 32 bit data.
write API expects user to supply it with min of 32 bits data
it accepts CEC packet supllied in following format
bit 0-7: data
bit 8: EOM
bit 12: Address mode, 0 = Direct, 1 = Broadcast
bit 16: Generate Start bit, 0 = Disable, 1 = Enable
bit 17: Retry frame, 0 = Disable, 1 = Enable
Logical address is set to 4, as of now there is no mechanism to change this
address from userspace.
Driver is disabled by default in Kconfig
Change-Id: Ia3835cec0bb717e63dabca5c5fcb1236847bf492
Signed-off-by: Ankit Pashiney <apashiney@nvidia.com>
Reviewed-on: http://git-master/r/105520
Addressed below items with this patch:
1. Using devm_kzalloc in place of kzalloc.
2. Correcting platform_get_irq return value check
Change-Id: I68225fe40adbb4be98e16ee2e0a4fccefadd8626
Reviewed-on: http://git-master/r/105843
Turn off regulators along with clocks during suspend
Bug 991262
Reviewed-on: http://git-master/r/108820
(cherry picked from commit 41ae7ac21a2c08da0e4312b8395b380a704fa16c)
Change-Id: Ib49eec5d91571d75881f4d252d956dece1d37d60
Reviewed-on: http://git-master/r/105364
- Handling warning of wrong return type from function.
bug 949219
Change-Id: I49e74de9314ee4934a5a58a8e406f9bade278aaf
Reviewed-on: http://git-master/r/112906
Include pm_qos_params header file to avail pm_qos
apis.
Bug 923594
Change-Id: Icbaad45e83a688b537159eea22ddd7356565fabf
Reviewed-on: http://git-master/r/113438
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
Do not register bcmdhd driver for all sdio devices.
Bug 1006828
Change-Id: I49e2d2bc7fbda4414392d8a28a0feefb1c8031ec
Signed-off-by: Mursalin Akon <makon@nvidia.com>
Reviewed-on: http://git-master/r/113045
Reviewed-by: Simone Willett <swillett@nvidia.com>
Change-Id: I03c11c295b40ebd500a715974f7fdca560d9a43a
Reviewed-on: http://git-master/r/111286
