Signed-off-by: Chia-chi Yeh <chiachi@android.com>
Cleanup some style warnings reported by checkpatch
Change-Id: Ie2e6903d52867fb3347e009d7efa3bc4ca755cea
Signed-off-by: Allen Martin <amartin@nvidia.com>
Update the Kconfig help paragraph to give more detail about
interactive governor.
Change-Id: I607b817b370accac3a685001649a15e2f7894f59
Add a new sysfs control that tunes the rate of the timer used to
increase cpu frequency
Change-Id: I1aa13ae54bb43aff5b3688984d2955f56aae1658
This adds better error checking on tunable parameters on sysfs
interfaces. Also fixes return value from these functions, previously
on success they would return 0 which would cause a infinite loop.
Change-Id: Ic05038492166f8673d007202092471f98a2f0dfa
Convert interactive governor to use idle notifier instead of
hooking pm_idle directly.
Change-Id: I47e007f330468ac559240a0ae8a3cb06a89ccb67
Remove debug trace code in preparation of upstreaming
Change-Id: I0905885e75031f5e9d7cb06878fb68c1fd06d4fe
MTP_SEND_FILE_WITH_HEADER ioctl allows sending a file with the 12 byte header
prepended at the beginning.
This is to allow MTP to use a single packet for the data phase instead of two.
Signed-off-by: Mike Lockwood <lockwood@android.com>
Signed-off-by: Dmitry Shmidt <dimitrysh@google.com>
In case the WPA cipher can't be determined the pval and gval variables don't
get updated which generates a warning in newer versions of gcc (tested with
4.5.2). Since the bcmdhd driver gets compiled with warnings treated as errors
this change is needed to fix the build.
Change-Id: Ia483777fee54ac526bb0db7c666fa2bf5df17354
Signed-off-by: Rom Lemarchand <rlemarchand@sta.samsung.com>
Add a otg_id notifier to allow multiple drivers to cooperate to
determine the type of cable connected to a USB connector without
requiring direct calls between the drivers.
Change-Id: Ic5675f1a89daf85b17336765de24e4bdb6df6348
Signed-off-by: Colin Cross <ccross@android.com>
If the platform data sets the use_otg_notifier flag,
the driver will now register an otg notifier callback and listen
to transceiver events for AC/USB plug-in events instead. This would
normally be used by not specifying is_xx_online callbacks and
not specifying any irqs so the state machine is completely driven
from OTG xceiver events.
Change-Id: Ic4b3bc4010f299156e41fd2411696c7ff5a88e92
Signed-off-by: Dima Zavin <dima@android.com>
Before freeing or sharing handles, confirm that they
are valid in the provided client
Change-Id: I06ec599c0b277fcb5417325a12ecbf8b2d248a7b
Signed-off-by: Rebecca Schultz Zavin <rebecca@android.com>
Enabled by default, can disable with:
echo N > /sys/module/otg_wakelock/parameters/enabled
Change-Id: I34974624c52ae23490852b44c270d2f326cf6116
Signed-off-by: Todd Poynor <toddpoynor@google.com>
Change-Id: I986c380d75591571890f1a2cba1405e66789b25c
Signed-off-by: Choi, Jong-Hwan <jhbird.choi@samsung.com>
Change-Id: I66f5ad2c95513dfab9f4fc5ae2fcb1316f486d34
ion_client_create now does a lookup, so this need not
also be done from ion_open
Change-Id: Icb101bbf514bf2e40b4b5d9b320130bf185349aa
ion_client_destroy kernel api should only delete the client
if it's refcount has gone to zero.
Change-Id: Iaa662bd82d67279a9807e01f9a24aebe3d21c17d
If a process already had a client, ion_client_create
would loop forever.
Change-Id: I723207b5872dfc11be04ca27d38a3cf39c4a1426
If MAC address setting fails from wifi_get_mac_addr() it will be picked up
from nvram.
Add logic to get MAC address before firmware is loaded
Change-Id: I2151a0fcc5aab914cfec8bfedf761b9f06445d1a
Signed-off-by: Howard M. Harte <hharte@broadcom.com>
* Move Android specific functions to wl_android (wifi control functions,
wifi device, pre-alloc buffer.)
* Link Android start/stop commands to interface up/down (download firmware
when primary interfacde is up.)
* Fix a issue in driver unload, the same IRQ can not be disabled twice
(set_irq_wake)
Change-Id: Id49c4f746f69371323c9a34834c3b628b78ff713
The function name is wrong here, and this function may
sometimes be called to see if a value passed from userspace
is an ion handle. Since it's not really an error when it
fails, remove the log message.
Change-Id: I7bee0e7ffb72b4c4768774a3586f97e306700c21
Fix some cases where locks were not released on error paths
Change heap->prio to heap->id to make meaning clearer
Fix kernel doc to match sources
This reverts commit fa92a3d6959546baa27e892188d3e9bb79c31741.
This reverts commit a0f07aae54e87a9fad6d19c0e57398f54d858f06.
The arguments to shrink functions have changed, update
lowmem_shrink to match.
Change-Id: I48f436e0509c416dc0b18db500234f7b1d6d42e1
This is the same as MTP but with PTP interface descriptor.
Also removed obsolete ioctl for switching between MTP and PTP mode
Fixes problem sending "store added" events when there are multiple stores
