path: root/drivers
2012-05-15video: tegra: dc: correct dc initialisation sequencePritesh Raithatha
-Move _tegra_dc_enable to before irq_request and remove disable_dc_irq. -It will remove warning of "IRQ when DC not powered!". Bug 955184 Change-Id: If9b039f3f1635d92f10bfc54af08101972fc3d57 Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com> Reviewed-on: http://git-master/r/101498 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-05-15regulator: TPS6238X0: Add tps6238X0 regulator driverLaxman Dewangan
The regulator module consists of 1 DCDC. The output voltage is configurable and is meant for supply power to the core voltage of Soc. Change-Id: Ic62d100a588f7b6f1b30c11fd44a925c97393069 Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/100653 Reviewed-by: Automatic_Commit_Validation_User Tested-by: Pradeep Goudagunta <pgoudagunta@nvidia.com> Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
2012-05-15video: tegra: dsi: WAR to stop on going host writeAnimesh Kishore
WAR comprises of soft reset dsi controller followed by explicitly clearing host trigger. Bug 982919 Change-Id: Ia8c497dd496435e429cd5b5ee8aaf1b7d78dc797 Signed-off-by: Animesh Kishore <ankishore@nvidia.com> Reviewed-on: http://git-master/r/102204 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Pavan Kunapuli <pkunapuli@nvidia.com> Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com>
2012-05-15misc: bt rfkill: toggle power GPIO based on current power stateNagarjuna Kristam
check if requested state and current BT power state is same, if yes, do not toggle BT power GPIO's. if not, set requested power state. Bug 982600 Bug 928604 Change-Id: I82c65fd6d43940c86cc3de440295ba179a4ade33 Signed-off-by: Nagarjuna Kristam <nkristam@nvidia.com> Reviewed-on: http://git-master/r/102190 Reviewed-by: Rakesh Kumar <krakesh@nvidia.com> Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-05-15rtc: tps6591x: Enable alarm interrupt for RTC_WKALM_SET ioctlPreetham Chandru
RTC_WKALM_SET ioctl should do two things: 1. Set alarm value 2. Enable alarm irq In the current implementation for RTC_WKALM_SET ioctl we are only setting the alarm value but not enabling the alarm irq and hence the system is not waking from lp0 state once the set alarm value expiries. For RTC_WKALM_SET ioctl, alarm->enabled will be set to one from userspace. So based on this condition we can differentiate between RTC_WKALM_SET & RTC_ALM_SET and accordingly enable alarm irq. Bug 978205 Signed-off-by: Preetham Chandru R <pchandru@nvidia.com> Change-Id: Ia35192e691ca116b13093f52873020f67c5c2f8d Reviewed-on: http://git-master/r/101447 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
2012-05-15mmc: enable background ops in driverVishal Singh
Adding a new config option and enabling background ops in driver. Correcting the EXT_CSD byte that needs to be written in order to trigger background ops in the MMC firmware. Bug 847037. Change-Id: Ibc517540cab43fa5070b142a416f6b67f2f7e7be Signed-off-by: Vishal Singh <vissingh@nvidia.com> Reviewed-on: http://git-master/r/99117 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-05-15usb: ehci: tegra: Split resume & suspend call appropriatelyPreetham Chandru
tegra_ehci_suspend_noirq/tegra_ehci_resume_noirq breaks the modem suspend call as it does a regulator_disable()/regulator_enable call which in turn requires the irqs to be enabled. Hence maintain a normal suspend call i.e with irqs enabled but split the resume to normal resume and noirq resume. Spliting the resume in this way takes care of the below erros in lp0/lp1 "tegra-ehci tegra-ehci.2:fatal error" "tegra-ehci tegra-ehci.2: HC died; cleaning up" Originally resume_noirq & suspend_noirq were added to avoid the above errors but since it breaks the modem suspend call splitting the suspend and resume in this way Bug 954564 Signed-off-by: Preetham Chandru R <pchandru@nvidia.com> Change-Id: I630b3dbe2ca66d194857dc71ababa3e5955785b1 Reviewed-on: http://git-master/r/99100 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
2012-05-14mmc: tegra: Set eMMC DDR clock based on emc clockPavan Kunapuli
Set the eMMC ddr mode clock dynamically based on emc clock rate. If ddr clock limit is specified and the emc clock is less than max emc freq, then limit emmc ddr clk. If not, set the max eMMC ddr clock. Bug 967719 Change-Id: I9f70077c4ac4bb1f3e6d894fcb8420b1aba284dd Signed-off-by: Pavan Kunapuli <pkunapuli@nvidia.com> Reviewed-on: http://git-master/r/100579 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-05-14drivers: video: tegra: Implement HOST1X syncpt initTerje Bergstrom
Move initialization for HOST1X sync point irq to nvhost driver. Bug 871237 Change-Id: I0d31e03b43999c609194665cdcbd2f0e498d848f Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com> Reviewed-on: http://git-master/r/100250 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com> GVS: Gerrit_Virtual_Submit Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
2012-05-14media: video: tegra: ov5640: add supportCharlie Huang
add ov5640 yuv sensor support - initial. bug 921322 Change-Id: I813afa8963e39afe475f9fdd43152cfaf1a16ae1 Signed-off-by: Charlie Huang <chahuang@nvidia.com> Reviewed-on: http://git-master/r/99506 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Frank Chen <frankc@nvidia.com> Reviewed-by: Jon Mayo <jmayo@nvidia.com>
2012-05-11Revert "serial: tegra: Use tegra_dma_cancel() to abort request"Pradeep Kumar
BT Filetransfer have some issue. This reverts commit e8c243d5d09d1a552b66df7a8a0a0313047ebbac. Bug 982630 Change-Id: I6e76d44e076874569518fa881e427918d3e546f2 Signed-off-by: Pradeep Kumar <pgoudagunta@nvidia.com> Reviewed-on: http://git-master/r/101914 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com> GVS: Gerrit_Virtual_Submit
2012-05-11video: tegra: host: move chip_support out of nvhost_masterMayuresh Kulkarni
- currently, nvhost_master holds the reference to struct chip_support - the struct chip_support hides the chip specific implementation for channel submit, cdma, push buffer operations etc. so it exposed all the internal structures through nvhost_master - move chip_support to be a part of nvhost_bus since it only has function pointers to chip specific api implementations - nvhost_master is host1x device specific private data so ideally it should not hold reference to chip specifics Bug 871237 Change-Id: I4f3f48ee5fc47a90288d110ea8eef905150275a0 Signed-off-by: Mayuresh Kulkarni <mkulkarni@nvidia.com> Reviewed-on: http://git-master/r/94421 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com> GVS: Gerrit_Virtual_Submit
2012-05-11mmc: tegra: Fix SDR50 mode clock rate settingPavan Kunapuli
In SDR50 mode, set the controller clock to double the requested clock to ensure that the core voltage is maintained at a min of 1.2V. Bug 965298 Change-Id: I557a07de97efd6b44f812a11da657e03d3ddefd0 Signed-off-by: Pavan Kunapuli <pkunapuli@nvidia.com> Reviewed-on: http://git-master/r/101522 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-05-11video: tegra: dc: Add display feature table support.Kevin Huang
Add display feature table so that user and kernel could set and update window attributes properly. Bug 962353 Change-Id: I08490a225892660126f3eefe4d5b7a4bb61d9bf7 Signed-off-by: Kevin Huang <kevinh@nvidia.com> Reviewed-on: http://git-master/r/101078 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-05-11mmc: core: Abort failed transfer before retriesPavan Kunapuli
Retries should be done only after abort command is issued for the current failed transfer. The block layer already has an implementation for retrying. No need for the extra retries. Bug 961761 Bug 922239 Change-Id: I07f60e85e093b725007727833739013f8fd66d43 Signed-off-by: Pavan Kunapuli <pkunapuli@nvidia.com> Reviewed-on: http://git-master/r/100563 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
2012-05-10video: tegra: host: Add syncpt trace eventsTerje Bergstrom
Add trace events for updating the syncpt value from hardware, and wait check. Change-Id: If17de153ae36c0665fe0af2f405dfe42f7fcd656 Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com> Reviewed-on: http://git-master/r/101524 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com> Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com> Reviewed-by: Ken Adams <kadams@nvidia.com>
2012-05-10video: tegra: host: Add context switch to trace dumpTerje Bergstrom
Add context switch to the ftrace dump. Change-Id: I5df032273982b919fb94263cff38d8b8b6b6be45 Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com> Reviewed-on: http://git-master/r/101523 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com> Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
2012-05-10Arm: Tegra: Nor: use timing1 proper valueMohit Kataria
timing1_read was initialized with timing0 from nor platform data changed the same to use timing1 from platform data instead of timing0 Bug 934187 Change-Id: I04c41323de25fb2bb53dac91301cee9c0820707a Signed-off-by: Mohit Kataria <mkataria@nvidia.com> Reviewed-on: http://git-master/r/95293 Reviewed-on: http://git-master/r/100904 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Amlan Kundu <akundu@nvidia.com> Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
2012-05-09power: bq27x00: start/stop delayed work upon suspend/resumePritesh Raithatha
Cancel delayed work upon suspend and schedule it on resume Bug 917914 Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com> Reviewed-on: http://git-master/r/95833 (cherry picked from commit a191d13e9dcdae715c9e03e1980857d00c082dc5) Change-Id: Ib8292daed3b4115657b1a66e1382ed7c1c448071 Reviewed-on: http://git-master/r/97080 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Pritesh Raithatha <praithatha@nvidia.com> Tested-by: Sang-Hun Lee <sanlee@nvidia.com> GVS: Gerrit_Virtual_Submit <kchilds@nvidia.com> Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-05-09usb: gadget: udc-core: fix kernel crash on soft_connect and srp interfacesPreetham Chandru
We should not call dev_get_drvdata() as the driver data is never set. We should use container_of() as it is been used for other sysfs attributes. Without this change writing to the soft_connect or srp interfaces crashes the kernel because of null pointer dereference. Bug 975473 Signed-off-by: Preeham Chandru R <pchandru@nvidia.com> Change-Id: I45f6dab32f5435d518bd5b4fcdfafa54b9b89acd Reviewed-on: http://git-master/r/100238 Tested-by: Preetham Chandru <pchandru@nvidia.com> Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Rakesh Bodla <rbodla@nvidia.com> Reviewed-by: Kiran Adduri <kadduri@nvidia.com> Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
2012-05-08cpufreq: interface for setting governor for a cpuPuneet Saxena
This implementation sets governor for a cpu using existing cpufreq interfaces. bug 871958 Change-Id: Ic4e7e2a2b0babaf1829b559b5db211666d449b86 Signed-off-by: Puneet Saxena <puneets@nvidia.com> Reviewed-on: http://git-master/r/97939 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-05-08input: touchscreen: resolve compilation time warningsSanjay Singh Rawat
bug 949219 Change-Id: I408fb008a70c7ea546384e68ac50c1f0604fc39a Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com> Reviewed-on: http://git-master/r/92276 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-05-08video: tegra: host: Iterate devices without nb_channelsTerje Bergstrom
Do not use nb_channels to find out the number of client devices. Instead, allocate devno regions when they are needed and find a device by module id by iterating over nvhost bus. Bug 871237 Change-Id: I53fd0d8e5874422ef9877430c0a170db2660118a Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com> Reviewed-on: http://git-master/r/99067 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
2012-05-08video: tegra: fb: Call mode filter from check varShashank Sharma
Call dc_hdmi_mode_filter to validate a videomode. X prepares its own modedb of supported HDMI modes, but all of them may not be supported from the HDMI driver. This call makes sure a X-mode is listed only if supported in DC driver. Bug: 959676 Change-Id: I8aff65f4e08fcc4471af096150e3972b5913a95a Signed-off-by: Shashank Sharma <shashanks@nvidia.com> Reviewed-on: http://git-master/r/99650 Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com> Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
2012-05-08video: tegra: dc: Set default videomodeShashank Sharma
Set default videomode during the dc probe. This patch enables HDMI during the probe only and fixes following issues: 1. Until Xinit there was no display on HDMI. 2. Framebuffer console on HDMI needs it to be enabled well before Xinit. To avoide un-necessary powering on HDMI,Check HPD and enable HDMI only if it's present. Bug: 930136 Bug: 977705 Change-Id: Ifb71328e5df0ccbb5751669db71fd24719fe3738 Signed-off-by: Shashank Sharma <shashanks@nvidia.com> Reviewed-on: http://git-master/r/100656 Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com> Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
2012-05-07mfd: max77663: Add gpio irq masking in irq_sync_unlockJinyoung Park
Add gpio irq masking in irq_sync_unlock. Change-Id: I008caf58ae82d9ed888f4720f54675e9106f027d Signed-off-by: Jinyoung Park <jinyoungp@nvidia.com> Reviewed-on: http://git-master/r/98664 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-05-07mmc: host: loglevel of a message to KERN_INFORamalingam C
Some boards don't have a vddio regulator for few rails hence not getting the regulator handle. And we assume that those rails are always powered. Hence rephrased the error message and lowered the loglevel to KERN_INFO. Bug 976177 Change-Id: I92b82f75934eaf7137584a625065e3389b6ae1b7 Signed-off-by: Ramalingam C <ramalingamc@nvidia.com> Reviewed-on: http://git-master/r/100490 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-05-07regulator: max77663: fix fps update conditionJinyoung Park
Fix fps update condition in max77663_regulator_set_fps(). Bug 930883 Change-Id: I2f57603320a91b2727932586fc3c66d9de347d64 signed-off-by: Jinyoung Park <jinyoungp@nvidia.com> Reviewed-on: http://git-master/r/92707 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-05-07mfd: max77663: Unmask EN0 rising interruptJinyoung Park
Unmasked EN0 rising interrupt to generate fast PMU_INT by EN0(POWER_KEY). Bug 930883 Change-Id: I9a3d8c4f564e83deea86fbd3d05f14933a0b0f65 Signed-off-by: Jinyoung Park <jinyoungp@nvidia.com> Reviewed-on: http://git-master/r/98665 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-05-07bluetooth: tibluesleep: clean up tibluesleep driverNagarjuna Kristam
Remove UART clock enable code, as UART clock gating is not needed in tibluesleep driver. Remove un-wanted tasklets, workqueues and wakelocks Remove extra lines and spaces Change-Id: I422e09ece2c736c4a98911a5bd84029ad654cb08 Signed-off-by: Nagarjuna Kristam <nkristam@nvidia.com> Reviewed-on: http://git-master/r/96944 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Rakesh Goyal <rgoyal@nvidia.com> Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-05-07video: tegra: nvmap: config option to enable page pools.Krishna Reddy
Add config option to enable/disable nvmap page pools. Change-Id: I873e81a675fecd768534d4ce03c2f8fdd3c6a063 Signed-off-by: Krishna Reddy <vdumpa@nvidia.com> Reviewed-on: http://git-master/r/100424 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
2012-05-06usb: otg: tegra: Change suspend resume logicRakesh Bodla
Changed the suspend resume logic as per new UDC driver. Also, added few debug prints. Bug 887361 Change-Id: I36ec1f160e8b4db54b5bd2153bdbf1c4fae1cc2a Signed-off-by: Rakesh Bodla <rbodla@nvidia.com> Reviewed-on: http://git-master/r/99450 Reviewed-by: Venkat Moganty <vmoganty@nvidia.com> Reviewed-by: Automatic_Commit_Validation_User
2012-05-06usb: tegra: add USB device controller driver for tegra chipRakesh Bodla
Add High-speed USB device controller driver for tegra chips. This can work in OTG device mode with tegra OTG driver. Driver currently supports only UMTIP PHY. Bug 887361 Change-Id: I63774a44e3bb607c93007b170ba8b811f96e43f8 Signed-off-by: Rakesh Bodla <rbodla@nvidia.com> Reviewed-on: http://git-master/r/97918 Reviewed-by: Venkat Moganty <vmoganty@nvidia.com> Reviewed-by: Automatic_Commit_Validation_User
2012-05-04video: early exit from update_cdmaPranav Chaturvedi
when update_cdma_locked() is invoked, CDMA is not running implies that the queue is cleared and we can return immediately. Bug 960487 Change-Id: I599027906dc405f4490590443d4f4d5a3202b5b0 Reviewed-on: http://git-master/r/96650 (cherry picked from commit f297b4812d15540f4b14c87178662a7ca6575ce9) Reviewed-on: http://git-master/r/99994 Reviewed-by: Varun Colbert <vcolbert@nvidia.com> Tested-by: Varun Colbert <vcolbert@nvidia.com>
2012-05-04video: tegra: host: Clean up includesTerje Bergstrom
Clean up #includes. Replace #includes with forward declarations where possible, and remove extraneous #includes. Bug 871237 Change-Id: I6942e0c632b42ad7009589ebdd78def88ae4baa4 Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com> Reviewed-on: http://git-master/r/99046 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com> GVS: Gerrit_Virtual_Submit Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
2012-05-04media: video: tegra: ov5650: read sensor fuse idCharlie Huang
The sequence of read fuse id is: 1. write to OTP index register 0x3d00. 2. read out byte from ox3d04. 3. repeat step 1 to the next byte with its index respectively. also fixed ov5650_read_reg always fail issue. bug 957657 Change-Id: I649a7765320d0d4be8111a7f523d8487b872b620 Signed-off-by: Charlie Huang <chahuang@nvidia.com> Reviewed-on: http://git-master/r/98330 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Wei Chen <wechen@nvidia.com> Reviewed-by: Frank Chen <frankc@nvidia.com> Reviewed-by: Jon Mayo <jmayo@nvidia.com>
2012-05-03mfd: tps80031: fix missed irq issueSteve Kuo
We found missed irq could be happened if clear all INT_STS_x register in one time. Shadow register pushes the irq status after the first byte of INT_STS_x was cleared The proposed way to clear interrupt is to write only one INT_STS_x register. It will also clear the other two ones. Bug 952476 Reviewed-on: http://git-master/r/93453 Signed-off-by: Steve Kuo <stevek@nvidia.com> (cherry picked from commit 0c92f32e9e03defaeac991518b26134e59ef4db6) Change-Id: I76179be4847f59a1687926b9b0dde6ebd3f58aa4 Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/100306
2012-05-03Revert "video: tegra: dc: Set default videomode"Hunk Lin
This reverts commit 9349cedf17f9b3c10760c8d48f831473f87a3a15. It is reviewed on http://git-master/r/99635 It will cause HDMI power ON and emc clock bump up to 667Mhz after resume from LP0. bug 930136 Change-Id: I130494fdb381b3d322ac0e3fc8be2e44f2c2d7a7 Signed-off-by: Hunk Lin <hulin@nvidia.com> Reviewed-on: http://git-master/r/100202 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Jon Mayo <jmayo@nvidia.com>
2012-05-03gpio: tegra: implement gpio_request and gpio_free.Laxman Dewangan
Recent pinctrl discussions concluded that gpiolib APIs should in fact do whatever is required to mux a GPIO onto pins. This change is based on the work done by Stephen Warren in mainline kernel. ----- commit 3e215d0a19c2a0c389bd9117573b6dd8e46f96a8 gpio: tegra: Hide tegra_gpio_enable/disable() Recent pinctrl discussions concluded that gpiolib APIs should in fact do whatever is required to mux a GPIO onto pins, by calling pinctrl APIs if required. This change implements this for the Tegra GPIO driver, and removes calls to the Tegra-specific APIs from drivers and board files. ---- Change-Id: I482ea5c177cf2ee6fa06ddac48b556f1508efacb Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/98466 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Pritesh Raithatha <praithatha@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2012-05-03video: tegra: dsi: Ref-count pllp_out3 clock in DSI.Kevin Huang
Bug 933653 Change-Id: If7ce4dc5129782a7e3487028d2dba01c9380ba90 Signed-off-by: Kevin Huang <kevinh@nvidia.com> Reviewed-on: http://git-master/r/98256 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Aleksandr Frid <afrid@nvidia.com> Reviewed-by: Animesh Kishore <ankishore@nvidia.com> Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
2012-05-02net: wireless: sd8797: change wlan interface to wlan0Narayan Reddy
Change wlan interface from mlan to wlan. Bug 954218 Change-Id: I5b2b2840a4830eda908a47cc0fc59d0479a1df34 Signed-off-by: Narayan Reddy <narayanr@nvidia.com> Reviewed-on: http://git-master/r/98997 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Reviewed-by: Rakesh Kumar <krakesh@nvidia.com>
2012-05-02mmc: host: Disable SDIO card clock when idle for Tegra 3 onlyMursalin Akon
The CL disables SDIO card clock when idle for Tegra 3 only. Bonus: conditional build for some tegra 3 functionalities. Bug 975541 Change-Id: I097c4771f3565bf9137d7854ada10c1fe8535056 Signed-off-by: Mursalin Akon <makon@nvidia.com> Reviewed-on: http://git-master/r/99707 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Allen Martin <amartin@nvidia.com> Reviewed-by: Peer Chen <pchen@nvidia.com>
2012-05-02video: tegra: fb: Enable window state while panShashank Sharma
Set window enabled flag in pan display. This fixes a blank window display while switching console from dc_ext device to framebuffer device, and allows dc_ext and fbdev to co-exist. Removed previous work around to unblank fb from tegra_dc_blank function. Bug: 970263 Bug: 963480 Change-Id: I9853da211f78815246965d240d1717345c5ab391 Signed-off-by: Shashank Sharma <shashanks@nvidia.com> Reviewed-on: http://git-master/r/99422 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Jon Mayo <jmayo@nvidia.com> Reviewed-by: Kiran Adduri <kadduri@nvidia.com> Reviewed-by: Allen Martin <amartin@nvidia.com>
2012-05-01video: tegra: dc: Set default videomodeShashank Sharma
Set default videomode during the dc probe. This patch enables HDMI during the probe only and fixes following issues: 1. Until Xinit there was no display on HDMI. 2. Framebuffer console on HDMI needs it to be enabled well before Xinit. Bug: 930136 Change-Id: Ieaf5c69eefa4a6584893425ad4fd772bcd91ea11 Signed-off-by: Shashank Sharma <shashanks@nvidia.com> Reviewed-on: http://git-master/r/99635 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-05-01Revert "video: tegra: dc: Clear window option before window update."Kevin Huang
This reverts commit 90b79e5712300baab889772a5af348559ac95836. Bug 955393 Change-Id: I0e2a15b7d0898dbbb62f09d8bd3502ec93366664 Signed-off-by: Kevin Huang <kevinh@nvidia.com> Reviewed-on: http://git-master/r/99261 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Jon Mayo <jmayo@nvidia.com> Reviewed-by: Nirav Patel <nipatel@nvidia.com> Reviewed-by: Adam Cheney <acheney@nvidia.com> Tested-by: Adam Cheney <acheney@nvidia.com>
2012-05-01regulator: add sysfs for rail enable/disableLaxman Dewangan
Added support for enable/disable rails from user space. bug 966960 Change-Id: Iae660699c60f537296f90508a78bd40959c46535 Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/99186 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Hunk Lin <hulin@nvidia.com> Tested-by: Hunk Lin <hulin@nvidia.com> GVS: Gerrit_Virtual_Submit
2012-05-01power: smb349: update correct charger statusSyed Rafiuddin
Update correct status to fuel-gauge driver when charger cable is disconnected. Bug 960318 Change-Id: I4c3ad2030ada7c06825e80a3eb4697b669fe7cb6 Signed-off-by: Syed Rafiuddin <srafiuddin@nvidia.com> Reviewed-on: http://git-master/r/98719 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-05-01mfd: max77663: Add FPWM and FSRADE clearing when initializationJinyoung Park
If sd power rail is not configured to FORCED_PWM_MODE or FSRADE_DISABLE, clear corresponding bits(FPWM and FSRADE) when initialization. Change-Id: I4e08329a430c6ccf7179b77cc7a283460ffaedd1 Signed-off-by: Jinyoung Park <jinyoungp@nvidia.com> Reviewed-on: http://git-master/r/98715 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-05-01power: smb349: fix NULL pointer issue.Syed Rafiuddin
Configure i2c client structure in update charger structure only when the charger driver is in use. If charger driver is not used return -ENODEV Change-Id: Ib1bc99145ee75bea819f69157920f9096e5d40ba Signed-off-by: Syed Rafiuddin <srafiuddin@nvidia.com> Reviewed-on: http://git-master/r/98712 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-05-01power: max17048: correcting vcell calcualtionSyed Rafiuddin
Vcell is calculated based on upper 12msb's of ADC result. Signed-off-by: Syed Rafiuddin <srafiuddin@nvidia.com> Reviewed-on: http://git-master/r/95830 (cherry picked from commit e550636d9b03207b9d4fecf078168175964d85fd) Change-Id: Ic2834d8c8576b938e9d7d400c2beeb459ddeb5fc Reviewed-on: http://git-master/r/98669 Reviewed-by: Syed Rafiuddin <srafiuddin@nvidia.com> Tested-by: Syed Rafiuddin <srafiuddin@nvidia.com> Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
