path: root/drivers
2011-07-06Merge branch 'gpio/merge' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'gpio/merge' of git://git.secretlab.ca/git/linux-2.6: gpio: tps65910: add missing breaks in tps65910_gpio_init
2011-07-06Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (46 commits) [media] rc: call input_sync after scancode reports [media] imon: allow either proto on unknown 0xffdc [media] imon: auto-config ffdc 7e device [media] saa7134: fix raw IR timeout value [media] rc: fix ghost keypresses with certain hw [media] [staging] lirc_serial: allocate irq at init time [media] lirc_zilog: fix spinning rx thread [media] keymaps: fix table for pinnacle pctv hd devices [media] ite-cir: 8709 needs to use pnp resource 2 [media] V4L: mx1-camera: fix uninitialized variable [media] omap_vout: Added check in reqbuf & mmap for buf_size allocation [media] OMAP_VOUT: Change hardcoded device node number to -1 [media] OMAP_VOUTLIB: Fix wrong resizer calculation [media] uvcvideo: Disable the queue when failing to start [media] uvcvideo: Remove buffers from the queues when freeing [media] uvcvideo: Ignore entities for terminals with no supported format [media] v4l: Don't access media entity after is has been destroyed [media] media: omap3isp: fix a potential NULL deref [media] media: vb2: fix allocation failure check [media] media: vb2: reset queued_count value during queue reinitialization ... Fix up trivial conflict in MAINTAINERS as per Mauro
2011-07-05gpio: tps65910: add missing breaks in tps65910_gpio_initAxel Lin
Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-05Merge branch 'usb-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6 * 'usb-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: USB: fix regression occurring during device removal USB: fsl_udc_core: fix build breakage when building for ARM arch
2011-07-05mfd: Add Makefile and Kconfig Entries for tps65911 comparatorAxel Lin
Base on Mark's comment [1], I make the Kconfig entry invisible to users. [1] https://lkml.org/lkml/2011/5/14/136 Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-07-05mfd: Fix build error for tps65911-comparator.cAxel Lin
Fix below build error: CC drivers/mfd/tps65911-comparator.o drivers/mfd/tps65911-comparator.c: In function 'tps65911_comparator_probe': drivers/mfd/tps65911-comparator.c:131: error: 'struct tps65910_platform_data' has no member named 'vmbch_threshold' drivers/mfd/tps65911-comparator.c:137: error: 'struct tps65910_platform_data' has no member named 'vmbch2_threshold' make[2]: *** [drivers/mfd/tps65911-comparator.o] Error 1 make[1]: *** [drivers/mfd] Error 2 make: *** [drivers] Error 2 Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-07-05Revert "mfd: Add omap-usbhs runtime PM support"Keshava Munegowda
This reverts commit 7e6502d577106fb5b202bbaac64c5f1b065e6daa. Oops are produced during initialization of ehci and ohci drivers. This is because the run time pm apis are used by the driver but the corresponding hwmod structures and initialization is not merged. hence revering back the commit id 7e6502d577106fb5b202bbaac64c5f1b065e6daa Signed-off-by: Keshava Munegowda <keshava_mgowda@ti.com> Reported-by: Luciano Coelho <coelho@ti.com> Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-07-05input: pmic8xxx-pwrkey: Do not use mfd_get_data()Samuel Ortiz
mfd_get_data() has been removed from the MFD API. Cc: Anirudh Ghayal <aghayal@codeaurora.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-07-05input: pmic8xxx-keypad: Do not use mfd_get_data()Samuel Ortiz
2011-07-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: (277 commits) [SCSI] isci: fix checkpatch errors isci: Device reset should request sas_phy_reset(phy, true) isci: pare back error messsages isci: cleanup silicon revision detection isci: merge scu_unsolicited_frame.h into unsolicited_frame_control.h isci: merge sata.[ch] into request.c isci: kill 'get/set' macros isci: retire scic_sds_ and scic_ prefixes isci: unify isci_host and scic_sds_controller isci: unify isci_remote_device and scic_sds_remote_device isci: unify isci_port and scic_sds_port isci: fix scic_sds_remote_device_terminate_requests isci: unify isci_phy and scic_sds_phy isci: unify isci_request and scic_sds_request isci: rename / clean up scic_sds_stp_request isci: preallocate requests isci: combine request flags isci: unify can_queue tracking on the tci_pool, uplevel tag assignment isci: Terminate dev requests on FIS err bit rx in NCQ isci: fix frame received locking ...
2011-07-04Merge branch 'at91/fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-2.6-arm-soc * 'at91/fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-2.6-arm-soc: AT91: Change nand buswidth logic to match hardware default configuration at91: Use "pclk" as con_id on at91cap9 and at91rm9200 at91: fix udc, ehci and mmc clock device name for cap9/9g45/9rl atmel_serial: fix internal port num at91: fix at91_set_serial_console: use platform device id
2011-07-04Merge branch 'fbdev-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-3.x * 'fbdev-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-3.x: vesafb: fix memory leak fbdev: amba: Link fb device to its parent fsl-diu-fb: remove check for pixel clock ranges udlfb: Correct sub-optimal resolution selection. hecubafb: add module_put on error path in hecubafb_probe() sm501fb: fix section mismatch warning gx1fb: Fix section mismatch warnings fbdev: sh_mobile_meram: Correct pointer check for YCbCr chroma plane
2011-07-04RDMA: Check for NULL mode in .devnode methodsGoldwyn Rodrigues
Commits 71c29bd5c235 ("IB/uverbs: Add devnode method to set path/mode") and c3af0980ce01 ("IB: Add devnode methods to cm_class and umad_class") added devnode methods that set the mode. However, these methods don't check for a NULL mode, and so we get a crash when unloading modules because devtmpfs_delete_node() calls device_get_devnode() with mode == NULL. Add the missing checks. Signed-off-by: Goldwyn Rodrigues <rgoldwyn@suse.de> [ Also fix cm.c. - Roland ] Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-04vesafb: fix memory leakDaniel J Blueman
When releasing framebuffer, free colourmap allocations. Signed-off-by: Daniel J Blueman <daniel.blueman@gmail.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-07-03[SCSI] isci: fix checkpatch errorsJames Bottomley
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/djbw/isciJames Bottomley
2011-07-03Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: hwmon: (k10temp) Update documentation for Fam12h hwmon-vid: Fix typo in VIA CPU name hwmon: (f71882fg) Add support for the F71869A hwmon: Use <> rather than () around my e-mail address hwmon: (emc6w201) Properly handle all errors
2011-07-03hwmon-vid: Fix typo in VIA CPU nameJean Delvare
It's Nehemiah, not Nemiah. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-07-03hwmon: (f71882fg) Add support for the F71869AHans de Goede
The F71869A is almost the same as the F71869F/E, except that it has the normal number of temp and pwm zones for a F71882FG derived chip, rather then the limited number of the F71869F/E. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Tested-by: Max Baldwin <archerseven@gmail.com> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-07-03hwmon: Use <> rather than () around my e-mail addressHans de Goede
Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-07-03hwmon: (emc6w201) Properly handle all errorsJean Delvare
Handle errors on 8-bit register reads and writes too. Also use likely and unlikely to make the functions faster on success. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-07-03isci: Device reset should request sas_phy_reset(phy, true)Jeff Skirvin
The hard_reset parameter passed to the LLDD in the direct-attached phy control case allows the LLDD to filter link failure events while the direct-attached device reset is executing. Signed-off-by: Jeff Skirvin <jeffrey.d.skirvin@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: pare back error messsagesDan Williams
The messages emitted from task.c and some from request.c likely duplicate (in a less undertandable way) what is reported by the midlayer. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: cleanup silicon revision detectionDan Williams
Perform checking per-pci device (even though all systems will only have 1 pci device in this generation), and delete support for silicon that does not report a proper revision (i.e. A0). Reported-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: merge scu_unsolicited_frame.h into unsolicited_frame_control.hDan Williams
Does not need its own file. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: merge sata.[ch] into request.cDan Williams
Undo some needless separation. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: kill 'get/set' macrosDan Williams
Most of these simple dereference macros are longer than their open coded equivalent. Deleting enum sci_controller_mode is thrown in for good measure. Reported-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: retire scic_sds_ and scic_ prefixesDan Williams
The distinction between scic_sds_ scic_ and sci_ are no longer relevant so just unify the prefixes on sci_. The distinction between isci_ and sci_ is historically significant, and useful for comparing the old 'core' to the current Linux driver. 'sci_' represents the former core as well as the routines that are closer to the hardware and protocol than their 'isci_' brethren. sci == sas controller interface. Also unwind the 'sds1' out of the parameter structs. Reported-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: unify isci_host and scic_sds_controllerDan Williams
Remove the distinction between these two implementations and unify on isci_host (local instances named ihost). Hmmm, we had two 'oem_parameters' instances, one was unused... nice. Reported-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: unify isci_remote_device and scic_sds_remote_deviceDan Williams
Remove the distinction between these two implementations and unify on isci_remote_device (local instances named idev). Reported-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: unify isci_port and scic_sds_portDan Williams
Remove the distinction between these two implementations and unify on isci_port (local instances named iport). The duplicate '->owning_port' and '->isci_port' in both isci_phy and isci_remote_device will be fixed in a later patch... this is just the straightforward rename/unification. Reported-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: fix scic_sds_remote_device_terminate_requestsDan Williams
Commit 0815632 "isci: unify remote_device stop_handlers" introduced the possibility that not all requests get terminated if we reach the request_count. Now that we properly reference count devices we don't need this self-defense and can do the straightforward scan of all active requests. Reported-by: Jeff Skirvin <jeffrey.d.skirvin@intel.com> Acked-by: Jeff Skirvin <jeffrey.d.skirvin@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: unify isci_phy and scic_sds_phyDan Williams
They are one in the same object so remove the distinction. The near duplicate fields (owning_port, and isci_port) will be cleaned up after the scic_sds_port isci_port unification. Reported-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: unify isci_request and scic_sds_requestDan Williams
They are one in the same object so remove the distinction. The near duplicate fields (owning_controller, and isci_host) will be cleaned up after the scic_sds_contoller isci_host unification. Reported-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: rename / clean up scic_sds_stp_requestDan Williams
* Rename scic_sds_stp_request to isci_stp_request * Remove the unused fields and union indirection Reported-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: preallocate requestsDan Williams
the dma_pool interface is optimized for object_size << page_size which is not the case with isci_request objects and the dma_pool routines show up in the top of the profile. The old io_request_table which tracked whether tci slots were in-flight or not is replaced with an IREQ_ACTIVE flag per request. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: combine request flagsDan Williams
Combine three bools into one unsigned long 'flags'. Doesn't increase the request size due to packing. (to do: optimize the structure layout). Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: unify can_queue tracking on the tci_pool, uplevel tag assignmentDan Williams
The tci_pool tracks our outstanding command slots which are also the 'index' portion of our tags. Grabbing the tag early in ->lldd_execute_task let's us drop the isci_host_can_queue() and ->was_tag_assigned_by_user infrastructure. ->was_tag_assigned_by_user required the task context to be duplicated in request-local buffer. With the tci established early we can build the task_context directly into its final location and skip a memcpy. With the task context buffer at a known address at request construction we have the opportunity/obligation to also fix sgl handling. This rework feels like it belongs in another patch but the sgl handling and task_context are too intertwined. 1/ fix the 'ab' pair embedded in the task context to point to the 'cd' pair in the task context (previously we were prematurely linking to the staging buffer). 2/ fix the broken iteration of pio sgls that assumes all sgls are relative to the request, and does a dangerous looking reverse lookup of physical address to virtual address. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: Terminate dev requests on FIS err bit rx in NCQJeff Skirvin
When the remote device transitions to a not-ready state because of an NCQ error condition, all outstanding requests to that device are terminated and completed to libsas on the normal path. The device then waits for a READ LOG EXT command to issue on the task management path. Signed-off-by: Jeff Skirvin <jeffrey.d.skirvin@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: fix frame received lockingDan Williams
Updates to the frame_rcvd before need to be atomic with respect to when they are evaluated by libsas. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: possible buffer overflow in isci_parse_oem_parameters fixedMaciej Patelczyk
scu_index is a parameter of isci_parse_eom_parameters and is an index in controller table. There is a check: scu_index > SCI_MAX_CONTROLLERS which is insufficient and should be: scu_index >= SCI_MAX_CONTROLLERS. scu_index is used as an index in the table which size is SCI_MAX_CONTROLLERS. Signed-off-by: Maciej Patelczyk <maciej.patelczyk@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: fix isci_task_execute_tmf completionDan Williams
1/ fix the timeout for wait_for_completion_timeout 2/ In the tmf timeout case we need to wait for our termination callback 3/ Once the request is successfully started it will be freed according to the normal lifetime for requests. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: fix support for arbitrarily large smp requestsDan Williams
Instead of duplicating the smp request buffer reuse the one provided by libsas. This future proofs the driver to support arbitrarily large smp requests, and shrinks the request structure size by ~700 bytes. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: fix dma_unmap_sg usageDan Williams
One bug and a cleanup: 1/ Fix cases where we were unmapping invalid addresses (smp requests were being unmapped) [ 604.662770] ------------[ cut here ]------------ [ 604.668026] WARNING: at lib/dma-debug.c:800 check_unmap+0x418/0x740() [ 604.675315] Hardware name: SandyBridge Platform [ 604.680465] isci 0000:03:00.0: DMA-API: device driver tries to free an invalid DMA memory address 2/ The unmap routine is too large to be an inline function, and isci_request_io_request_get_next_sge is unused. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: fix smp response frame overrunDan Williams
Due to a typo we currently copy way too much when copying over the response data, but since a request is likely backed by a full page allocation we don't corrupt live data. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: kill device_sequenceDan Williams
Now that we have upleveled device reassignment protection to the isci_remote_device reference count we no longer need this level of self-defense. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: kill isci_remote_device_change_state()Dan Williams
Now that "stopping/stopped" are one in the same and signalled by a NULL device pointer the rest of the device status infrastructure can be removed (->status and ->state_lock). The "not ready for i/o state" is replaced with a state flag, and is evaluated under scic_lock so that we don't see transients from taking the device reference to submitting the i/o. This also fixes a potential leakage of can_queue slots in the rare case that SAS_TASK_ABORTED is set at submission. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: atomic device lookup and reference countingDan Williams
We have unsafe references to remote devices that are notified to disappear at lldd_dev_gone. In order to clean this up we need a single canonical source for device lookups and stable references once a lookup succeeds. Towards that end guarantee that domain_device.lldd_dev is NULL as soon as we start the process of stopping a device. Any code path that wants to safely lookup a remote device must do so through task->dev->lldd_dev (isci_lookup_device()). For in-flight references outside of scic_lock we need reference counting to ensure that the device is not recycled before we are done with it. Simplify device back references to just scic_sds_request.target_device which is now the only permissible internal reference that is maintained relative to the reference count. There were two occasions where we wanted new i/o's to be treated as SAS_TASK_UNDELIVERED but where the domain_dev->lldd_dev link is still intact. Introduce a 'gone' flag to prevent i/o while waiting for libsas to take action on the port down event. One 'core' leftover is that we currently call scic_remote_device_destruct() from isci_remote_device_deconstruct() which is called when the 'core' says the device is stopped. It would be more natural for the final put to trigger isci_remote_device_deconstruct() but this implementation is deferred as it requires other changes. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: fix ssp response iu buffer size in isci_tmfDan Williams
In isci_task_request_complete() we save the response/sense data from the command. Make sure isci_tmf has enough space to hold the full response. [ it does not look like we actually use this data, and response_data_len/sense_data_len should be specifying the byte count, in any event do the simple fix first so we don't corrupt memory ] Reported-by: Adam Gruchala <adam.gruchala@intel.com> Tested-by: Edmund Nadolski <edmund.nadolski@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: cleanup request allocationDan Williams
Rather than return an error code and update a pointer that was passed by reference just return the request object directly (or null if allocation failed). Signed-off-by: Dan Williams <dan.j.williams@intel.com>
