bug 1021221
Change-Id: Ifbe007de5bdeafaa15a0b3f2a138086045eba160
Signed-off-by: Raghavendra VK <rvk@nvidia.com>
Reviewed-on: http://git-master/r/118179
(cherry picked from commit 74be8d4e7210d7bcea0d55565a7cbb06d6cc960e)
Reviewed-on: http://git-master/r/121087
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-by: Robert Morell <rmorell@nvidia.com>
do_heap_alloc locates a suitable free block from a nvmap heap given a
size and alignment. Unfortunately, if a heap block happens to be
smaller than the alignment passed to the function, an integer overflow
will occur, and a block that's too small gets accidentally returned.
Bug 1032642
Change-Id: Ic650c520409134d753e968f62f144ddeb065ccc7
Signed-off-by: Tuomas Tynkkynen <ttynkkynen@nvidia.com>
Reviewed-on: http://git-master/r/123076
GVS: Gerrit_Virtual_Submit
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
In rpm_suspend, when suspend fail,
before going to reschedule another autosuspend,
wake_up_all is required to avoid remote wakeup
issues.
Bug 1026169
Bug 1027598
Bug 1032565
Change-Id: Ieaf9282dae59b2cb343bf01aa2ba837a8cdc39c7
Signed-off-by: BH Hsieh <bhsieh@nvidia.com>
Reviewed-on: http://git-master/r/122978
Reviewed-by: Neil Patel <neilp@nvidia.com>
Tested-by: Neil Patel <neilp@nvidia.com>
Tested-by: Steve Lin <stlin@nvidia.com>
Reviewed-by: Steve Lin <stlin@nvidia.com>
Sometimes USB connect and disconnect events is not detected properly. The
OTG irq handler is using a workqueue which has no protection for multiple
incoming event handling.
This patch adds mutex to protect the workqueue for USB connection
handling.
BUG 968345
Change-Id: If1c6fec4231dd0dc918f7f278e0a1d7667782917
Signed-off-by: Xin Xie <xxie@nvidia.com>
Reviewed-on: http://git-master/r/122308
Reviewed-by: Rakesh Bodla <rbodla@nvidia.com>
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
Current Tegra UDC driver share same IRQ with OTG driver, and it will call
bus_resume() even if there is no UDC IRQ pending.
This patch will check UDC IRQ source and will not cause bus resume if no
IRQ pending for UDC driver.
BUG 1015685
Change-Id: Ifc5634ae5d1f7f1435c64bc527ab2e9fb8d0e36b
Reviewed-on: http://git-master/r/121896
Reviewed-by: Simone Willett <swillett@nvidia.com>
Enable the USB charging based on the USB charging spec 1.2. Now we can
detect:
1. SDP (stanardard downstream port)
2. CDP (charging downstream port)
3. DCP (dedicated charging port)
4. None (no cable connected)
5. Non-standard charger
For some non-standard charger, we cannot detect it as DCP device.
If we find a charger detected as USB device but no EP0 packet recieved
with 1s, we then decided this is 1A charger.
bug 968345
Change-Id: I804f90ea6e4794da8f52b1c3ebd694828d99f40e
Reviewed-on: http://git-master/r/120218
Check return code for set_page_array_* calls.
Change-Id: Ie62ac78b82321939d5bd9d2a636d72dadea50d28
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/123544
Increase max packet size and clean up timing logic so we can better
recover from not getting an interrupt in time for a SOF.
Bug 1026047
Signed-off-by: Mike Lockwood <lockwood@google.com>
(cherry picked from commit 3d2096a7959d023bc31a3cf934c3d425de01c94f)
Signed-off-by: Rakesh Bodla <rbodla@nvidia.com>
Change-Id: I0a0a6f448e71e4a0c478bb44cadc54fa021e13e4
Reviewed-on: http://git-master/r/123344
This driver presents a standard USB audio class interface to the host
and an ALSA PCM device to userspace
Bug 1026047
(cherry picked from commit a23ff394752015a233dd3b27b05c9d913cbf5536)
Change-Id: I4054e09888f17d9cdfcfd4a3d430ca5cfb3fd9fa
Reviewed-on: http://git-master/r/123343
Bug 1026047
(cherry picked from commit 7a3d01af4f04950a86a18f5a439f1802d8093650)
drivers/usb/gadget/f_accessory.c
Change-Id: I30bc02a1bcf636967d56370db83578f49f0e7514
Reviewed-on: http://git-master/r/123342
The control request will be used by the host to enable/disable USB audio
and the ioctl will be used by userspace to read the audio mode
Bug 1026047
(cherry picked from commit 3e1ff6142761eef148c667e540381d1fbc437d4f)
Change-Id: I5f449de230ca8f44e2dae30a0f87772310b68f20
Reviewed-on: http://git-master/r/123341
bug 1033234
Change-Id: I67a28113fbf0a2461886658322f9106d17a69f23
Signed-off-by: Kerwin Wan <kerwinw@nvidia.com>
Reviewed-on: http://git-master/r/123301
Reviewed-by: Chandler Zhang <chazhang@nvidia.com>
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
nvmap_map_into_caller_ptr takes a memory handle from usermode
and adds a memory mapping for the handle. However, the handle
is not checked for being allocated. An unallocated handle
would cause a kernel panic later on from a NULL dereference.
Change-Id: I73987b097a0c843b913660445e8bd1b4755dac61
Reviewed-on: http://git-master/r/119689
The direction apis and irq_set_wake() support the
configuration of pins in gpio mode and hence it
is not require to export the apis for gpio_enable()/
gpio_disable().
Hiding these api.
Change-Id: I5493e4f270df85da21afb6500ac841f4fa4b522a
Reviewed-on: http://git-master/r/119616
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Currently dr_controller_run() is called only during otg state
change.
When we unload a gadget driver, for example g_mass_storage
gadget driver, dr_controller_stop() is called but when it is
loaded back dr_controller_run() won't get called becasue of the
if condition failure. i.e
if (!udc->transceiver) {
dr_controller_run(udc);
So when the gadget driver is loaded for the second time
without removing the cable (i.e without otg state change),
the device won't get enumerated on the host because DR
IRQs are not enabled.
This CL fixes the above issue.
Bug 1012787
Signed-off-by: Preetham Chandru <pchandru@nvidia.com>
Change-Id: Ia127630e24dbe4c1e418163c2b858efb3baa8e45
Reviewed-on: http://git-master/r/114592
Due to issues with rcu notifiers on secureos, modifying dc flip
notifications to use a simple callback instead.
Bug 1028850
Change-Id: Iebf2a6d64d7316e3df2b88444201f9f9a29698c5
Signed-off-by: Ilan Aelion <iaelion@nvidia.com>
Reviewed-on: http://git-master/r/123103
Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-by: Nitin Kumbhar <nkumbhar@nvidia.com>
When 3D register is read, and we need to do a context switch, the old
context reference is incremented, but it never gets decremented. Fix
by using nvhost_job_get_hwctx() to acquire the reference.
Bug 1031746
Change-Id: Ic72637cb2399f960e2297733bfe45e585a8ec180
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/123678
Reviewed-by: Arto Merilainen <amerilainen@nvidia.com>
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
Add support to alloc zeroed pages for user space alloc requests. Also
define a config option to force userspace allocation requests to be
zeroed.
Change-Id: I75d3b2bc36e808f1470b423578ec4cba99e0f967
Signed-off-by: Alex Waterman <alexw@nvidia.com>
Reviewed-on: http://git-master/r/122549
host1x interrupts have been left on at suspend due to using wrong
constant for the interrupt register. Disable host1x interrupts at
suspend.
Change-Id: I915fc4e663e6ad90fccacff6fb223c5080e21fcd
Reviewed-on: http://git-master/r/123055
Reviewed-by: Andrew Howe <ahowe@nvidia.com>
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
BUG 1015045
Change-Id: Id9ac783365f08787638edc057d55f29c9a0e46eb
Reviewed-on: http://git-master/r/122310
After the charging completed, TPS80031 can re-enable the charging if it
sense the voltage dropping (120mV below target). Current drive does not
handle this event and causing the charging forever stopped.
This patch will check the above re-charging happens in the charging WDT
handler, and will ack WDT in order to continue charging.
BUG 1015045
Change-Id: Ia0a53d29cd0e73e7ebcd53f8176c8ef81b6c6090
Reviewed-on: http://git-master/r/122309
Perform throughput notifications to clients on work queue rather than
synchronously to dc flip notifications.
Bug 1028850
Change-Id: Ib9446a4ab87a476230a90a1f23c260bcf98e01dc
(cherry picked from commit f48bec5168232d7a50ecfb193146a4be214af3d7)
Reviewed-on: http://git-master/r/#change,122160
Reviewed-on: http://git-master/r/123102
Lock was missing around one state set, so we add it here.
Bug 1024031
Change-Id: Iab013fff7e8519e8bcc91e84a5ca7cd6e6e783da
Signed-off-by: Matt Wagner <mwagner@nvidia.com>
Reviewed-on: http://git-master/r/122802
When tegra-otg suspends with charger cable connected, the charger
state and type should not be changed, neither should the charger
callback be executed.
SMB349 has a debounce delay of ~20ms +/- 3 after cable is unpluged
and will stop all I2C functions for 2.3ms when getting reset to POR.
Add 50ms' delay before reading charger status to avoid I2C error and
make sure we get the right charger state.
Bug 1024735
Change-Id: I1667b23df768b46b524c6578c4bee09e131d9f96
Signed-off-by: Allen Yu <alleny@nvidia.com>
Reviewed-on: http://git-master/r/120905
nvhost context related functions were in init section, even though
they are called from non-init functions.
Bug 1022681
Change-Id: Ie85e9dd3f19873aec4153e34c7bffa19f40d37fa
Reviewed-on: http://git-master/r/120884
add compilation flag to treat warnings as errors
handle error of variable declaration
bug 949219
Change-Id: Iac05d4d0e4c4cbf39a534b7aee32c0dac57ae49d
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
Reviewed-on: http://git-master/r/118027
Reviewed-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-by: Sri Krishna Chowdary <schowdary@nvidia.com>
Reviewed-by: Manoj Chourasia <mchourasia@nvidia.com>
-add compilation flag to treat warning as error
bug 949219
Change-Id: I3f7f557099b0473883e0b959b65eb8f17ed30978
Reviewed-on: http://git-master/r/118008
nvmap_pin_ids accepts a list of handles to pin, which are passed
directly from usermode when called from nvmap_ioctl_pinop.
However, if invalid handles are passed in, the function might
still access them as valid handles, and cause a crash.
Bug 1023954
Change-Id: I6b98a2ef448bb496be7d569ddd4fb516fc399cba
Reviewed-on: http://git-master/r/119667
Give ownership of the DMA buffer back to the processor first and
then free the buffer. Otherwise processor won't be able to
access the dma mapped buffers and this would lead to slab
corruption.
When the DMA buffer is freed without a call to dma_sync_single_for_cpu(),
the kernel won't be able to set the buffer as POISON FREE and when we
acquire this memory back again the kernel will start printing slab
corruption output as the memory is not set to POISON FREE
Bug 1017884
Bug 1018161
Reviewed-on: http://git-master/r/#change,122151
Signed-off-by: Preetham Chandru R <pchandru@nvidia.com>
Change-Id: I00d6cb185cd2314cccb56f968eb0a05288588c13
Reviewed-on: http://git-master/r/122390
hsic_unregister is being called multiple times
during two step enumeration process of xmm.
In failure cases when enumeration does not
complete properly, kernel panic is seen because
of extra unregister-ehci device.
Bug 1016593
Change-Id: Ibaeb20ed0dab0e906741fdfad78f7d89a3672f60
Signed-off-by: Vinayak Pane <vpane@nvidia.com>
Reviewed-on: http://git-master/r/116626
issue a warning on flip events less than 1 microsecond apart.
Bug 1027664
Bug 1028850
Reviewed-on: http://git-master/r/121810
(cherry picked from commit 6c0e907b437765fb9f7093599911b71a836d49a6)
Change-Id: Ie15256e35475d345b2ebe6ddb637ccc181fcb61e
Reviewed-on: http://git-master/r/122326
Reviewed-by: Donghan Ryu <dryu@nvidia.com>
Tested-by: Donghan Ryu <dryu@nvidia.com>
Invalidate the FDC before submitting the context
save pushbuffer to ensure cache coherency across
both GPU cores.
Bug 1020291
Reviewed-on: http://git-master/r/121945
(cherry picked from commit cef956d07ec717f4714f5101805bbe2f0f149e71)
Change-Id: I43ffee6a77122b4f2fe17f063dc6756c501e59c7
Reviewed-on: http://git-master/r/122323
usb_put_hcd calls hcd_release which frees up memory allocated
for hcd. As iounmap is called after usb_put_hcd and it is trying
to access hcd->regs, getting warning messages during unload of
USB. Hence fixing it.
bug 1023362
Change-Id: Ic339395edad9a76a9eeae290eff3517d2c714477
Signed-off-by: Venu Byravarasu <vbyravarasu@nvidia.com>
Reviewed-on: http://git-master/r/122088
Reviewed-by: Krishna Yarlagadda <kyarlagadda@nvidia.com>
Tested-by: Krishna Yarlagadda <kyarlagadda@nvidia.com>
Device disconnect during resume might fail if notification
clients for this device removal are not ready.
Disconnecting device after the resume is complete.
Bug 1024496
Change-Id: Ia806e177d2dd2b1b43d3fea7a4af45f0d4a93cd4
Signed-off-by: Krishna Yarlagadda <kyarlagadda@nvidia.com>
Reviewed-on: http://git-master/r/122079
Fixing the potential compilation this is
currently masked as CONFIG_USB_OTG_UTILS
is enabled.
Change-Id: Ie10e5fc252156b8b904d387d87a11136fcc3f4c1
Reviewed-on: http://git-master/r/122043
Werror flag is enabled now. Fixing the compilations
errors when DEBUG is enabled.
Change-Id: I909dd177eedfd72f1f71d1a546fc40c301bd1aa7
Reviewed-on: http://git-master/r/122033
Locking in nvhdcp was set up in such a way that we couldn't
change the state of the HDMI plug while negotiating the HDCP connection.
Another lock was added that is only taken when the state of the plug or
hdcp session are changed. This enables correct failure if the plug is removed
during negotiation.
Bug 1024031
Reviewed-on: http://git-master/r/120546
(cherry picked from commit 51f746421b73f8f378bd7908b35fd6c79687e239)
Change-Id: Id9a9b09f2cd03a1b51e7334391f35fc076a1e1dd
Reviewed-on: http://git-master/r/121399
Bug 1023045
Change-Id: Id6e43c852a90cbd5445daf38279ed690712c3332
Signed-off-by: Narayan Reddy <narayanr@nvidia.com>
Reviewed-on: http://git-master/r/117637
Reviewed-by: Rakesh Kumar <krakesh@nvidia.com>
prevent a race condition on initialization which could result in
multiple notifier registrations.
Bug 1027664
Change-Id: I2e7dcad159f631a7e244d43019169fdaf195bc34
(cherry picked from commit 06ad60cd85a221eec673654c73d55fba34455a3a)
Reviewed-on: http://git-master/r/121143
Tested-by: Ilan Aelion <iaelion@nvidia.com>
Reviewed-by: Michael I Gold <gold@nvidia.com>
Prevent division by 0 on subsequent flip notifications at an interval
shorter than 1 micro-second.
Bug 1027664
Change-Id: I6e2f886721216fc2479adc1a24504b707c7ebe45
(cherry picked from commit 92807179cbbd60be67e09ff40bdaab313e3a55fe)
Reviewed-on: http://git-master/r/121142
The regmap should be initialized before irq initialization
happen as register are accessed during irq init.
Change-Id: I301e8b84596a9075209901cbaff1dc42a944e163
Reviewed-on: http://git-master/r/121623
Reviewed-by: Venu Byravarasu <vbyravarasu@nvidia.com>
Maxim 77665 is Companion PMIC for Smartphones and Tablets.
This support Flash, Fuel Gauge, Haptic, MUIC and battery
charging.
This patch add the core driver for interface for accessing
resgister of the device.
Change-Id: I7d5dff8c222147b2ca1cd21a652f593cd7294601
Reviewed-on: http://git-master/r/121587
The mfd sub devices should get added through the
mfd_add_devices() not through legacy style of
adding sub devices.
Change-Id: If275d41629d799f1e22d95fd442ebe7d3ace448e
Reviewed-on: http://git-master/r/121137
Register General Purpose ADC driver of TPS80031 as
mfd sub driver in place of adding it as a sub devices.
This is inline with the mfd driver policy.
Change-Id: Ib3f86f05716baef96ee534eec5ae262627c6a853
Reviewed-on: http://git-master/r/121136
Register battery charger driver of TPS80031 as mfd
Change-Id: I8cff39f5c9b22434f7c5b9d4ed9f3865ff4c0001
Reviewed-on: http://git-master/r/121135
Register battery gauge driver of TPS80031 as mfd
Change-Id: I15765be19fc138695de2d813e5fa025400747c86
Reviewed-on: http://git-master/r/121134
register RTC driver of TPS80031 as mfd sub
Change-Id: I2f9c13478a1e85c9670dd7bc576ec761f2e24733
Reviewed-on: http://git-master/r/121133
The gpio mode of pin is configured when setting
direction and hence this call is no more required.
Change-Id: I38dac94bd0eb753c779db61f71c1e01295faa89e
Reviewed-on: http://git-master/r/120848
Reviewed-by: Rakesh Goyal <rgoyal@nvidia.com>
We need to validate the buffer size before we
copy buffers from/to user space.
Bug 1027334
Change-Id: I0717e9ff1d2e5eb3e8a863555457f4bcfdbb2cb9
Signed-off-by: Frank Chen <frankc@nvidia.com>
Reviewed-on: http://git-master/r/120185
Reviewed-by: Charlie Huang <chahuang@nvidia.com>
Reviewed-by: Patrick Shehane <pshehane@nvidia.com>
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
This config option only builds on PPC platforms.
Change-Id: Ibe7ebdc2dd5b9aa46e8f887570481a11a373c417
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Reviewed-on: http://git-master/r/95475
Tested-by: Nitin Kumbhar <nkumbhar@nvidia.com>
