At present, the comment header in random.c makes no mention of
add_disk_randomness, and instead, suggests that disk activity adds to the
random pool by way of add_interrupt_randomness, which appears to not have
been the case since sometime prior to the existence of git, and even prior
to bitkeeper. Didn't look any further back. At least, as far as I can
tell, there are no storage drivers setting IRQF_SAMPLE_RANDOM, which is a
requirement for add_interrupt_randomness to trigger, so the only way for a
disk to contribute entropy is by way of add_disk_randomness. Update
comments accordingly, complete with special mention about solid state
drives being a crappy source of entropy (see e2e1a148bc for reference).
Signed-off-by: Jarod Wilson <jarod@redhat.com>
Acked-by: Matt Mackall <mpm@selenic.com>
Picochip picoXcell devices have two crypto engines, one targeted
at IPSEC offload and the other at WCDMA layer 2 ciphering.
Signed-off-by: Jamie Iles <jamie@jamieiles.com>
Request_region should be used with release_region, not release_resource.
The local variable mem, storing the result of request_mem_region, is
dropped and instead the pointer res is stored in the drvdata field of the
platform device. This information is retrieved in omap_rng_remove to
release the region. The drvdata field is not used elsewhere.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
expression x,E;
*x = request_region(...)
*x = request_mem_region(...)
... when != release_region(x)
when != x = E
* release_resource(x);
// </smpl>
clk_get() returns a struct clk cookie to the driver and some platforms
may return NULL if they only support a single clock. clk_get() has only
failed if it returns a ERR_PTR() encoded pointer.
Reviewed-by: Aaro Koskinen <aaro.koskinen@nokia.com>
Reviewed-by: Dmitry Kasatkin <dmitry.kasatkin@nokia.com>
Reviewed-and-tested-by: Tobias Karnat <tobias.karnat@googlemail.com>
This driver adds support for the True Random Number Generator in
the Picochip PC3X3 and later devices.
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'media_fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (101 commits)
[media] staging/lirc: fix mem leaks and ptr err usage
[media] hdpvr: reduce latency of i2c read/write w/recycled buffer
[media] hdpvr: enable IR part
[media] rc/mceusb: timeout should be in ns, not us
[media] v4l2-device: fix 'use-after-freed' oops
[media] v4l2-dev: don't memset video_device.dev
[media] zoran: use video_device_alloc instead of kmalloc
[media] w9966: zero device state after a detach
[media] v4l: Fix a use-before-set in the control framework
[media] v4l: Include linux/videodev2.h in media/v4l2-ctrls.h
[media] DocBook/v4l: update V4L2 revision and update copyright years
[media] DocBook/v4l: fix validation error in dev-rds.xml
[media] v4l2-ctrls: queryctrl shouldn't attempt to replace V4L2_CID_PRIVATE_BASE IDs
[media] v4l2-ctrls: fix missing 'read-only' check
[media] pvrusb2: Provide more information about IR units to lirc_zilog and ir-kbd-i2c
[media] ir-kbd-i2c: Add back defaults setting for Zilog Z8's at addr 0x71
[media] lirc_zilog: Update TODO.lirc_zilog
[media] lirc_zilog: Add Andy Walls to copyright notice and authors list
[media] lirc_zilog: Remove useless struct i2c_driver.command function
[media] lirc_zilog: Remove unneeded tests for existence of the IR Tx function
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6:
firewire: core: fix unstable I/O with Canon camcorder
* 'fwnet' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6:
firewire: net: is not experimental anymore
firewire: net: invalidate ARP entries of removed nodes
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (34 commits)
powerpc/mpic: Fix mask/unmask timeout message
powerpc/pseries: Add BNX2=m to defconfig
powerpc: Enable 64kB pages and 1024 threads in pseries config
powerpc: Disable mcount tracers in pseries defconfig
powerpc/boot/dts: Install dts from the right directory
powerpc: machine_check_generic is wrong on 64bit
powerpc: Check RTAS extended log flag before checking length
powerpc: Fix corruption when grabbing FWNMI data
powerpc: Rework pseries machine check handler
powerpc: Don't silently handle machine checks from userspace
powerpc: Remove duplicate debugger hook in machine_check_exception
powerpc: Never halt RTAS error logging after receiving an unrecoverable machine check
powerpc: Don't force MSR_RI in machine_check_exception
powerpc: Print 32 bits of DSISR in show_regs
powerpc/kdump: Disable ftrace during kexec
powerpc/kdump: Move crash_kexec_stop_spus to kdump crash handler
powerpc/kexec: Remove empty ppc_md.machine_kexec_prepare
powerpc/kexec: Don't initialise kexec hooks to default handlers
powerpc/kdump: Remove ppc_md.machine_crash_shutdown
powerpc/kexec: Remove ppc_md.machine_kexec
Fix error test in fan_{read,write}_reg()
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
It turns out that some device drivers map pages from the ACPI NVS region
during resume using ioremap(), which conflicts with ioremap_cache() used
for mapping those pages by the NVS save/restore code in nvs.c.
Make the NVS pages mapped by the code in nvs.c be unmapped before device
drivers' resume routines run.
Commit ca9b600be38c ("ACPI / PM: Make suspend_nvs_save() use
acpi_os_map_memory()") attempted to prevent the code in osl.c and nvs.c
from using different ioremap() variants by making the latter use
acpi_os_map_memory() for mapping the NVS pages. However, that also
requires acpi_os_unmap_memory() to be used for unmapping them, which
causes synchronize_rcu() to be executed many times in a row
unnecessarily and introduces substantial delays during resume on some
systems.
Instead of using acpi_os_map_memory() for mapping the NVS pages in nvs.c
introduce acpi_os_ioremap() calling ioremap_cache() and make the code in
both osl.c and nvs.c use it.
Reported-by: Jeff Chua <jeff.chua.linux@gmail.com>
* akpm:
kernel/smp.c: consolidate writes in smp_call_function_interrupt()
kernel/smp.c: fix smp_call_function_many() SMP race
memcg: correctly order reading PCG_USED and pc->mem_cgroup
backlight: fix 88pm860x_bl macro collision
drivers/leds/ledtrig-gpio.c: make output match input, tighten input checking
MAINTAINERS: update Atmel AT91 entry
mm: fix truncate_setsize() comment
memcg: fix rmdir, force_empty with THP
memcg: fix LRU accounting with THP
memcg: fix USED bit handling at uncharge in THP
memcg: modify accounting function for supporting THP better
fs/direct-io.c: don't try to allocate more than BIO_MAX_PAGES in a bio
mm: compaction: prevent division-by-zero during user-requested compaction
mm/vmscan.c: remove duplicate include of compaction.h
memblock: fix memblock_is_region_memory()
thp: keep highpte mapped until it is no longer needed
kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERT
Fix collision with kernel-supplied #define:
drivers/video/backlight/88pm860x_bl.c:24:1: warning: "CURRENT_MASK" redefined
arch/x86/include/asm/page_64_types.h:6:1: warning: this is the location of the previous definition
Cc: Haojian Zhuang <haojian.zhuang@marvell.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: <stable@kernel.org>
Replicate changes made to drivers/leds/ledtrig-backlight.c.
Cc: Richard Purdie <richard.purdie@linuxfoundation.org>
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option
is used to configure any non-standard kernel with a much larger scope than
only small devices.
This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes
references to the option throughout the kernel. A new CONFIG_EMBEDDED
option is added that automatically selects CONFIG_EXPERT when enabled and
can be used in the future to isolate options that should only be
considered for embedded systems (RISC architectures, SLOB, etc).
Calling the option "EXPERT" more accurately represents its intention: only
expert users who understand the impact of the configuration changes they
are making should enable it.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
Acked-by: David Woodhouse <david.woodhouse@intel.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Greg KH <gregkh@suse.de>
Cc: Robin Holt <holt@sgi.com>
Cc: <linux-arch@vger.kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6
* 'tty-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6:
tty: update MAINTAINERS file due to driver movement
tty: move drivers/serial/ to drivers/tty/serial/
tty: move hvc drivers to drivers/tty/hvc/
git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen
* 'xen/xenbus' of git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen:
xenbus: Fix memory leak on release
xenbus: avoid zero returns from read()
xenbus: add missing wakeup in concurrent read/write
xenbus: allow any xenbus command over /proc/xen/xenbus
xenfs/xenbus: report partial reads/writes correctly
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus:
virtio: remove virtio-pci root device
LGUEST_GUEST: fix unmet direct dependencies (VIRTUALIZATION && VIRTIO)
lguest: compile fixes
lguest: Use this_cpu_ops
lguest: document --rng in example Launcher
lguest: example launcher to use guard pages, drop PROT_EXEC, fix limit logic
lguest: --username and --chroot options
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'acpica' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6:
ACPICA: Update version to 20110112
ACPICA: Update all ACPICA copyrights and signons to 2011
ACPICA: Fix issues/fault with automatic "serialized" method support
ACPICA: Debugger: Lock namespace for duration of a namespace dump
ACPICA: Fix namespace race condition
ACPICA: Fix memory leak in acpi_ev_asynch_execute_gpe_method().
During system suspend, the "wait for ring buffer to empty" loop would
always time out after three seconds, because the faster cached ring
buffer head read would always return zero. Force the slow-and-careful
PIO read on all but the first iterations of the loop to fix it.
This also removes the unused (and useless) 'actual_head' variable that
tried to approximate doing this, but did it incorrectly.
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: Dave Airlie <airlied@linux.ie>
Cc: DRI mailing list <dri-devel@lists.freedesktop.org>
thanks to Clemens' and Maxim's fixes to firewire-ohci and -net in the
last two kernel releases.
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
This makes it possible to resume communication with a node that dropped
off the bus for a brief period. Otherwise communication will only be
possible after ARP cache entry timeouts.
Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com>
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> (rebased)
Regression since commit 10389536742c, "firewire: core: check for 1394a
compliant IRM, fix inaccessibility of Sony camcorder":
The camcorder Canon MV5i generates lots of bus resets when asynchronous
requests are sent to it (e.g. Config ROM read requests or FCP Command
write requests) if the camcorder is not root node. This causes drop-
outs in videos or makes the camcorder entirely inaccessible.
https://bugzilla.redhat.com/show_bug.cgi?id=633260
Fix this by allowing any Canon device, even if it is a pre-1394a IRM
like MV5i are, to remain root node (if it is at least Cycle Master
capable). With the FireWire controller cards that I tested, MV5i always
becomes root node when plugged in and left to its own devices.
Reported-by: Ralf Lange
Cc: <stable@kernel.org> # 2.6.32.y and newer
This partially reverts commit da8aeb92d4853f37e281f11fddf61f9c7d84c3cd
("ACPI / Battery: Update information on info notification and resume"),
which causes a hang on resume on at least some machines.
This bug was bisected on an ASUS EeePC 901, which hangs at resume time
if we do that "acpi_battery_refresh(battery)" in the battery resume
function.
Rafael suspects we'll still need to refresh the sysfs files upon resume,
but that that can be done from a PM notifier (that will run after
thawing user space).
Bisected-and-tested-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Matthew Garrett <mjg@redhat.com>
Cc: Len Brown <len.brown@intel.com>
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
We sometimes need to map between the virtio device and
the given pci device. One such use is OS installer that
gets the boot pci device from BIOS and needs to
find the relevant block device. Since it can't,
installation fails.
Instead of creating a top-level devices/virtio-pci
directory, create each device under the corresponding
pci device node. Symlinks to all virtio-pci
devices can be found under the pci driver link in
bus/pci/drivers/virtio-pci/devices, and all virtio
devices under drivers/bus/virtio/devices.
Signed-off-by: Milton Miller <miltonm@bga.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
Tested-by: Michael S. Tsirkin <mst@redhat.com>
Acked-by: Gleb Natapov <gleb@redhat.com>
Tested-by: "Daniel P. Berrange" <berrange@redhat.com>
Cc: stable@kernel.org
arch/x86/lguest/boot.c: In function ‘lguest_init_IRQ’:
arch/x86/lguest/boot.c:824: error: macro "__this_cpu_write" requires 2 arguments, but only 1 given
arch/x86/lguest/boot.c:824: error: ‘__this_cpu_write’ undeclared (first use in this function)
arch/x86/lguest/boot.c:824: error: (Each undeclared identifier is reported only once
arch/x86/lguest/boot.c:824: error: for each function it appears in.)
drivers/lguest/x86/core.c: In function ‘copy_in_guest_info’:
drivers/lguest/x86/core.c:94: error: lvalue required as left operand of assignment
Use this_cpu_ops in a couple of places in lguest.
Signed-off-by: Christoph Lameter <cl@linux.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (41 commits)
sctp: user perfect name for Delayed SACK Timer option
net: fix can_checksum_protocol() arguments swap
Revert "netlink: test for all flags of the NLM_F_DUMP composite"
gianfar: Fix misleading indentation in startup_gfar()
net/irda/sh_irda: return to RX mode when TX error
net offloading: Do not mask out NETIF_F_HW_VLAN_TX for vlan.
USB CDC NCM: tx_fixup() race condition fix
ns83820: Avoid bad pointer deref in ns83820_init_one().
ipv6: Silence privacy extensions initialization
bnx2x: Update bnx2x version to 1.62.00-4
bnx2x: Fix AER setting for BCM57712
bnx2x: Fix BCM84823 LED behavior
bnx2x: Mark full duplex on some external PHYs
bnx2x: Fix BCM8073/BCM8727 microcode loading
bnx2x: LED fix for BCM8727 over BCM57712
bnx2x: Common init will be executed only once after POR
bnx2x: Swap BCM8073 PHY polarity if required
iwlwifi: fix valid chain reading from EEPROM
ath5k: fix locking in tx_complete_poll_work
ath9k_hw: do PA offset calibration only on longcal interval
When the lirc drivers were converted over to using memdup_user, I
mistakenly also removed corresponding calls to kfree. Add those back. I
also screwed up on the allocation error check in lirc_serial, using if
(PTR_ERR()) instead of if (IS_ERR()), which broke transmit.
Reported-by: Jiri Fojtasek <jiri.fojtasek@hlohovec.net>
The current hdpvr code kmalloc's a new buffer for every i2c read and
write. Rather than do that, lets allocate a buffer in the driver's
device struct and just use that every time.
The size I've chosen for the buffer is the maximum size I could
ascertain might be used by either ir-kbd-i2c or lirc_zilog, plus a bit
of padding (lirc_zilog may use up to 100 bytes on tx, rounded that up
to 128).
Note that this might also remedy user reports of very sluggish behavior
of IR receive with hdpvr hardware.
v2: make sure (len <= (dev->i2c_buf)) [Jean Delvare]
Reported-by: Jean Delvare <khali@linux-fr.org>
Acked-by: Jean Delvare <khali@linux-fr.org>
A number of things going on here, but the end result is that the IR part
on the hdpvr gets enabled, and can be used with ir-kbd-i2c and/or
lirc_zilog.
First up, there are some conditional build fixes that come into play
whether i2c is built-in or modular. Second, we're swapping out
i2c_new_probed_device() for i2c_new_device(), as in my testing, probing
always fails, but we *know* that all hdpvr devices have a z8 chip at
0x70 and 0x71. Third, we're poking at an i2c address directly without a
client, and writing some magic bits to actually turn on this IR part
(this could use some improvement in the future). Fourth, some of the
i2c_adapter storage has been reworked, as the existing implementation
used to lead to an oops following i2c changes c. 2.6.31.
Earlier editions of this patch have been floating around the 'net for a
while, including being patched into Fedora kernels, and they *do* work.
This specific version isn't yet tested, beyond loading ir-kbd-i2c and
confirming that it does bind to the RX address of the hdpvr.
[mchehab@redhat.com: I2C_CLASS_TV_ANALOG is not defined. Fix compilation bug]
Acked-by: Andy Walls <awalls@md.metrocast.net>
Fixes an egregious bug in mceusb driver, where the receiver was being
put into idle mode far sooner than it should have, thanks to storing a
timeout value that in us where it should be ns. Basically, the receiver
kept going into idle mode before a trailing space had been fully
received, which was causing problems for some protocols, most notably
manifesting as lirc userspace never receiving a trailing space for any
rc5 signals.
Fix a bug in v4l2_device_unregister where the sd pointer can be dereferenced
after it was freed.
Normally the i2c adapter is removed before this function is called. Removing
the adapter will also unregister all subdevs on that adapter, so generally
v4l2_device_unregister has nothing to do. However, in the case of a platform
i2c bus that bus is generally not freed.
In that case, after freeing the i2c subdevice the code will fall into the
second block when it tests if the subdev is a SPI device. But by that time
the subdev is already freed and the kernel oopses.
The fix is trivial: continue with the loop after freeing the i2c or spi
subdevice.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Reported-by: Daniel Drake <dsd@laptop.org>
Zeroing video_device.dev causes a memory leak if video_set_drvdata
was called before video_register_device was called. video_set_drvdata
calls dev_set_drvdata which allocates video_device.dev.p.
memsetting this will prevent freeing of that memory.
After a detach zero the whole device state to ensure a clean slate
on the next attach.
v4l2_queryctrl sets the step value based on the control type. That would
be fine if it used the control type stored in the V4L2 kernel control
object, not the one stored in the userspace ioctl structure that has
just been memset to 0. Fix this.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Acked-by: Hans Verkuil <hverkuil@xs4all.nl>
When queryctrl is called with a V4L2_CID_PRIVATE_BASE control ID, then
currently it is replaced by the real internal ID. This is not according to
the spec so keep the V4L2_CID_PRIVATE_BASE ID in this case.
VIDIOC_S_CTRL did not check against read-only controls. Even worse, for
controls of type CTRL_CLASS it would cause a kernel oops since those controls
do not have a s_ctrl op.
ir-kbd-i2c
When registering an IR Rx device with the I2C subsystem, provide more detailed
information about the IR device and default remote configuration for the IR
driver modules.
Also explicitly register any IR Tx device with the I2C subsystem.
Signed-off-by: Andy Walls <awalls@md.metrocast.net>
Acked-by: Mike Isely <isely@pobox.com>
This reverts a portion of commit
44243fc2ef99948bc9b046901880885616dd5e89
A commit for which I errantly recommended that defaults for I2C address
0x71 not be set by ir-kbd-i2c.c
The pvrusb2 and bttv drivers currently rely on ir-kbd-i2c setting
defaults for that address. Until I can get those bridge drivers fixed
to properly send IR_i2c_init_data for boards with Zilog Z8 chips,
just add back the default settings for I2C address 0x71.
The ir_command() function is a do-nothing stub; remove it.
The driver is now structured so that it must handle an IR Tx unit
for a Z8 IR chip, or it refuses to handle that Z8 IR chip. This
allows us to assume that ir->tx != NULL in a few places in the driver,
and also allows us to always report Tx is available to userspace.
Get rid of unneeded tests for ir->tx == NULL and always report that
Tx is available.
The IR Rx polling thread was originally a kernel_thread long ago,
and had only been minimally converted to a kthread. This patch
finishes that conversion by
- cleaning up all the unneeded completions
- destroying the kthread properly by calling kthread_stop()
- changing lirc_thread() to test kthread_should_stop() just before
every point where it may sleep
- reorganizing the lirc_thread() function so it uses fewer lines
- modifying the name of the kthread from "lirc_zilog" to
"zilog-rx-i2c-N", so ps will show which kthread polls
which Zilog Z8 IR unit.
Also some minor tweaks were made to logging emitted by the
ir_probe() function.
This patch is an extensive rework of the ir_probe() and ir_remove() functions.
It removes all the double binding and allocation problems on module load.
It removes almost all the memory leaks on module exit and on device
instantiation failure. Proper destruction of the Rx polling kthread still
needs investigation and more work, but it is no worse than it already was.
This rework also had side effects that include:
- encapsulation of the ir_devices[] array
- serialization of access to the ir_devices[] array
- semantic change of the module parameter "disable_rx" to "tx_only"
If tx_only is true, the module does not claim the i2c_client for the IR Rx
function, and only claims and handles the i2c_client for the IR Tx function.
This is a first step in providing the option of letting ir-kbd-i2c.c handle
IR Rx function, while lirc_zilog handles the IR Tx function.
Don't make private copies of the i2c clients provided by the I2C
subsystem, don't change the client address field, and don't probe
the client addresses - the bridge driver already did that. This
moves us to the proper I2C and binding model.
This change is a mostly mechanical break of the main struct IR
data structure into common, Rx, and Tx structures. There were some
small logical changes required as well, such as eliminating "is_hdpvr",
to accomplish this.
This change is an intiial step in reworking lirc_zilog to decouple the
Rx and Tx handling as much as possible to fit with the new I2C
binding model. This change actually makes lirc_zilog a little more
broken than it already was - memory deallocation in particular got worse.
However, this change makes the remaining problems easier to see and address.
