This reverts commit bdf9e11d339ebc121e80e7ecdd44e0abcaf4ff38.
When commands timeout, previously we had code to
retry the same command 3 times. But under some
situations 3 retries do not suffice. Increasing
the retries to 10 does the trick. Also if the card
does not respond after 10 retries then the card is
dead for sure. But if the same card responds in
between 3 to 10 retries then it is always beneficial
to have retries as 10.
Bug 914934
Change-Id: I6b1e95c10ca5a62dde84ce8cacbe53ad2197ab33
Reviewed-on: http://git-master/r/72092
Reviewed-by: Pavan Kunapuli <pkunapuli@nvidia.com>
(cherry picked from commit c4beda3e798ed91e1dadbce4206b407832fcc40b)
If the data commands fail due to some error, retry the transfer.
Add 3 retries for data commands.
for bug 914934
Change-Id: I53245ddd159abdbade09f841d9490d2f106e7c88
Signed-off-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Signed-off-by: Pavan Kunapuli <pkunapuli@nvidia.com>
Reviewed-on: http://git-master/r/71181
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
(cherry picked from commit fd804ee58d3f9ce10cb2fe16aa76ae0407912d32)
Add tracepoints to record the start and end of each mmc block
operation. This includes read, write, erase, secure erase,
trim, secure trim1 and secure trim 2, discard and
sanitize commands.
Change-Id: Ic5d1cbdb9adb940d8b1a2a13c73970023575df50
Signed-off-by: Ken Sumrall <ksumrall@android.com>
Signed-off-by: Iliyan Malchev <malchev@google.com>
drivers/mmc/card/block.c
drivers/mmc/core/core.c
(cherry picked from commit 4de9a433c26e47d9b4a93105eb92935321100786)
Support discard feature if MID field in the CID register is 0x15, EXT.CSD[192]
(device version) is 5 and Bit 0 in the EXT.CSD[64] is 1. Also removed REQ_SECURE flag
check to avoid kernel hang.
This patch is released from samsung.
Change-Id: I4023a900680e9bca10c40311b09ed077a22617db
(cherry picked from commit 4acc227edfb631d377e14911287c1b73682fc9c2)
Change-Id: Ia56018522e5d18ca5bfd25858ec943da93d3edc3
(cherry picked from commit e363e576f448d6132340c5d0bda580fef212888d)
drivers/mmc/host/sdhci-tegra.c
Change-Id: I46e3f1a158d61a0b255fae5d510c8f87579c435d
Reviewed-on: http://mcrd1-5.corpnet.asus/code-review/master/47847
Reviewed-by: Kirt Hsieh <Kirt_Hsieh@asus.com>
Tested-by: Kirt Hsieh <Kirt_Hsieh@asus.com>
Reviewed-by: Vincent Yue <Vincent_Yue@asus.com>
Reviewed-on: http://mcrd1-5.corpnet.asus/code-review/master/48199
Reviewed-by: Jim1 Lin <jim1_lin@asus.com>
Tested-by: Jim1 Lin <jim1_lin@asus.com>
Reviewed-by: Leslie Yu <Leslie_Yu@asus.com>
(cherry picked from commit 8eadc6d514b7838c398ff3499ab5f2e012e2fc06)
drivers/mmc/host/sdhci.c
Change-Id: I40a8481618b1a5995a713ff343c7532badd20b65
Change-Id: I399302118c9d8d8246a4a304ff7a1ea80889dbc6
Reviewed-on: http://mcrd1-5.corpnet.asus/code-review/master/45568
Reviewed-by: Ban Feng <Ban_Feng@asus.com>
Tested-by: Ban Feng <Ban_Feng@asus.com>
Reviewed-by: Sam hblee <Sam_hblee@asus.com>
(cherry picked from commit 121c0c6dffe16c683f4dbf00ed841fb4de1f70a0)
drivers/mmc/core/mmc.c
Change-Id: I28d670944cbfd55e2b2ad98b727368a8dfdc0944
Change-Id: I2bb65335c2468b257473fe264e705826cfd4474e
Reviewed-on: http://mcrd1-5.corpnet.asus/code-review/master/45300
(cherry picked from commit 1711f72a9840f3667cf93c774ac16c2d8417375c)
Change-Id: I89b544afbb0a109a222621a9948399fba8f77693
Change-Id: Ie366a152100a478e7811b4395f3fae9794bb1386
Reviewed-on: http://mcrd1-5.corpnet.asus/code-review/master/45221
include/linux/mmc/card.h
asdf
(tegra-l4t-r16-16.5)
drivers/media/video/tegra_v4l2_camera.c
drivers/watchdog/tegra_wdt.c
include/media/tegra_v4l2_camera.h
The pixel clock polarity setting was wrong: The kernel display flags
are rather somewhat confusing: The flags specify the edge where the
data should be driven by the controller (and hence not sampled by the
display!).
Please note that we don't change the default pixel clock polarity.
Our move to modedb lead to the HDMI display controller always being
enabled (unless forced off by vidargs). This patch makes sure it gets
disabled upon boot disconnected as well as upon later disconnect.
Note: This also fixes DVFS on Colibri T30 in the sense that it will
again stay at 400 MHz EMC as long as no DVI-D aka HDMI display is
connected during boot.
As stated by the eMMC 5.0 specification, a chip should not be rejected
only because of the revision stated in the EXT_CSD_REV field of the
EXT_CSD register.
Remove the control on this value, the control of the CSD_STRUCTURE field
should be sufficient to reject future incompatible changes.
Signed-off-by: Romain Izard <romain.izard.pro@gmail.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
(cherry picked from commit 03a59437ef6b6ad7fb0165cb9b96c08d6bf057fc)
With the new eMMC5.1 spec, there is a new EXT_CSD register with
the revision number(EXT_CSD_REV) 7. This patch updates the check
for ext-csd.rev number as 7.
Signed-off-by: Alim Akhtar <alim.akhtar@samsung.com>
Signed-off-by: Yuvaraj Kumar C D <yuvaraj.cd@samsung.com>
Reviewed-by: Doug Anderson <dianders@chromium.org>
Signed-off-by: Chris Ball <cjb@laptop.org>
(cherry picked from commit 6636bad839d9936e73e48c4841eda83a58fcdb53)
This commit, updates the driver to work faster with 32-Lead and 40-Lead
versions of adv7180 chip. Output pin VS/FIELD is now configured as
VSYNC.
Newer eMMC standards use CMD23 for multi-block transfer. These
command has the advantage that only one command is necessary, no
stop command after the transfer is required. The kernel already
supports this command, but we need to enable the capability on
the host level.
Tests verified that the MMC code detects that SD-card do not
support CMD23 and hence don't use that command.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
The whole rounding stuff really depends on a specific resolution.
This reverts commit 4dd83942b418b937e3da02746baabf63f37fe682.
Force round down in division calculating required logo height as
preceding code did round up as follows:
logo_lines = DIV_ROUND_UP(logo_height, vc->vc_font.height);
Which resulted in no boot-logo shown at all due to not enough lines
being available.
Additionally disable cursor for custom boot logo.
Using this unconditionally cuts the birds feet (;-p).
This reverts commit 491f263ebfb338c59abfbde6d4e0e7256a0150fa.
Make sure that we dont enter infinite loop due to
negative value of pins in some cases. Also remove
debugging check for refcount.
Bug 1478467
Change-Id: I7df8efa5b3cf8927a0c18363add4f031aca48e48
Signed-off-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-on: http://git-master/r/450209
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
Tested-by: Matthew Pedro <mapedro@nvidia.com>
Also use nvhost_syncpt_incr_max_ext().
Bug 1478352
Change-Id: Ib868bd2bd7a070e4c410e48bd51977ac45b7d477
Signed-off-by: Bryan Wu <pengw@nvidia.com>
Reviewed-on: http://git-master/r/439471
GVS: Gerrit_Virtual_Submit
Reviewed-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
There could be race in refcount update leading to
access of module registers without enabling the clock
and power.This patch tries to catch such instances
and enables power.
Bug 1478467
Change-Id: Ia32da44bfcd7838e312815b6261ccadf4470a761
Reviewed-on: http://git-master/r/448701
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
nvhost_job_unpin should always get the nvmap_handle_ref
from rb_entry after validating handle and presence
in the tree.
Bug 1478467
Change-Id: Ibf5f64a1a82fea8adbf7500bdb36b76357776448
Reviewed-on: http://git-master/r/436076
This works around a issue we see when using eMMC 4.5 on tegra
SDHCI host controller.
The 1.8V quirk also affected the internal eMMC which disabled newer
modes such as SDR50, SDR104 and DDR50. This in turn lead to an
out of spec usage since the clock was still 50MHz.
By creating a no_1v8 field in the platform data we can now enable
this work around on a per-instance basis. Hence we enable the
quirk only on the controllers which are connected to the external
SD-slots.
being available.
This commit resolves an issue of non-working vi camera driver
on Colibri T20 occured after a l4t-r16-r4 merge.
- remove reduntant emc clock rate set which is controlled by DVFS
- VI's maxim working clock freq is 300MHz
- Change VI clock divider from an integer to a decimal, so the
maxim VI clock on Cardhu should be 272MHz (PLL_P is 408MHz and
divider is 1.5)
Bug 1478352
Change-Id: I4028ed8531d92300d131befb53a4c9dc9f90930d
Reviewed-on: http://git-master/r/419071
Tested-by: Winnie Hsu <whsu@nvidia.com>
Change-Id: I67c50ff86b53a6c1001d2b688251dc55bd2eff55
Reviewed-on: http://git-master/r/419070
The driver should not try to switch to 1.8V when the SD 3.0 host
controller does not have any UHS capabilities bits set (SDR50, DDR50
or SDR104). See page 72 of "SD Specifications Part A2 SD Host
Controller Simplified Specification Version 3.00" under
"1.8V Signaling Enable". Instead of setting SDR12 and SDR25 in the host
capabilities data structure for all V3.0 host controllers, only set them
if SDR104, SDR50 or DDR50 is set in the host capabilities register. This
will prevent the switch to 1.8V later.
Bug 1402031
Acked-by: Arindam Nath <arindam.nath@amd.com>
Acked-by: Philip Rakity <prakity@marvell.com>
Acked-by: Girish K S <girish.shivananjappa@linaro.org>
Signed-off-by: Al Cooper <acooper@gmail.com>
Signed-off-by: Jeetesh Burman <jburman@nvidia.com>
Change-Id: I61d3fdb96fce223649075b6c063a3dd227aef062
Reviewed-on: http://git-master/r/365451
The OLPC XO-1.75 laptop includes a SDHCI controller which is 1.8v
capable, and it truthfully reports so in its capabilities. This
alternate voltage is used for driving new "UHS-I" SD cards at their
full speed.
However, what the controller doesn't know is that the motherboard
physically doesn't have a 1.8v supply available.
Add a quirk so that systems such as this one can override disable
1.8v support, adding support for UHS-I cards (by running them at
3.3v).
This avoids a problem where the system would first try to run the
card at 1.8v, fail, and then not be able to fully reset the card
to retry at the normal 3.3v voltage.
This is more appropriate than using the MISSING_CAPS quirk, which
is intended for cases where the SDHCI controller is actually lying
about its capabilities, and would force us to somehow override both
caps words from another source.
Bug 1402031
Change-Id: I7ca070a13241e6403eb2e243ebbc441a311110bc
Signed-off-by: Daniel Drake <dsd@laptop.org>
Reviewed-by: Philip Rakity <prakity@nvidia.com>
Reviewed-on: http://git-master/r/346323
Reworked driver in order to properly support default watchdog api
such as triggering by writing a character and disable by sending
a magic character. Renamed ENABLE_ON_PROBE to ENABLE_HEARTBEAT
which triggers the watchdog using the interrupt service routine.
Original patch:
http://git.toradex.com/gitweb/linux-toradex.git/commitdiff/5da592b805718b4f33897d642f577b1e6511bc2b
Bug 1402031
Change-Id: I33ef556dac6d6717cadc00f8937437b925dc2ca3
Reviewed-on: http://git-master/r/346477
Don't initialize the whole display controller (dc) when framebuffer
mode is set to off.
This avoids creation of the /dev/tegra_dc_x device. The tegra X
driver requires for each tegra_dc_x device an framebuffer device
with the same id. This patch avoids creation of both, which makes
the tegra X driver load correctly.
Note: Turning off tegrafb0 still leads to kernel crash due to
hard coded device enumeration.
Symptoms:
The interface stops receiving CAN frames when reception of CAN frame
and call to the introduced get_berr_counter function coincide.
Reproduction:
Ip requests, among others, the berr field for the can interfaces. NOTE
that it does so even if called as 'ip link show lo', as interface-based
filtering is only done after the system calls to receive interface
information.
Run candump on a MCP-based can interface that has a lot of traffic (via
'cangen -g1' on another can node).
On the system with the MCP chip, run
while /bin/true; do ip link > /dev/null ; done;
Reception of CAN-frames (as shown by candump) will cease within
seconds.
This issue got introduced by commit
1b59090a47101b4bf379d2c35986ad3f0bcb2aa1 as access to the SPI registers
of the MCP251x were not locked.
Issue report and patch courtesy David R. Piegdon of Indurad GmbH.
Driver features:
1. Supported formats:
- Full HD, 1920x1080, 8.5 FPS, YUYV
- VGA, 640x480, 30 FPS, YUYV
2. Available controls with enabled AE (auto exposure):
- brightness [0...255],
- contrast [16...64],
- saturation [0...256],
- hue [-2200...2200],
- gamma [100...280].
3. Works only in parallell interface mode (CSI in progress).
4. No external tools needed (for i2c).
This commit restores the full framerate (25 FPS), after a drop to
16 FPS caused by a l4t-r16-r4 merge.
This commit adds settings such as:
- values of horizontal/vertical active start,
- enabling/disabling internal sync,
to the private data of decoders: MAX9526, ADV7180, TVP5150,
OV7670 and AS0260.
The feature is available through *_tegra_camera_platform_data
struct initialised in board-*.c files.
Bug 1369083
Change-Id: I1a81bcb62e8f6bb654ffbebba09661187ab4b512
Reviewed-on: http://git-master/r/309536
Tested-by: Vikram Fugro <vfugro@nvidia.com>
Reviewed-by: Kaustubh Purandare <kpurandare@nvidia.com>
Add support for dual cameras from both CSI-A and CSI-B:
- move all the CSI settings into video buffer struct
- queue the video buffer struct to a dedicated queue
- process one video buffer struct from the queue at one time
Bug 1369083
Change-Id: Ie64d69282ab991b66e97327e288a2bacde088bd6
Reviewed-on: http://git-master/r/246269
(cherry picked from commit 228b0c2d9ae3fa1121f88836626d654ae0fc4ff0)
Reviewed-on: http://git-master/r/279987
soc_camera_link supports passing power on/off control callback to
soc_camera stack. So the power control can be handled by soc_camera
stack instead of our Tegra V4L2 host driver.
Also pass other platform_data fields via soc_camera_link instead of
a hacking nvhost_device_data struct.
Bug 1240806
Bug 1369083
Change-Id: I443a7d28196cc8292805da70d2d5ff1c3cd50a5d
Reviewed-on: http://git-master/r/246267
(cherry picked from commit 9083d270bf93b583cd5bf5151a52ea250f8541a3)
Reviewed-on: http://git-master/r/279986
