commit 1c34203a1496d1849ba978021b878b3447d433c8 upstream.
It is not necessary to call device_remove_groups() when device_add_groups()
fails.
The group added by device_add_groups() should be removed if sysfs_create_link()
fails.
Fixes: fa6fdb33b486 ("driver core: bus_type: add dev_groups")
Signed-off-by: Junjie Mao <junjie_mao@yeah.net>
commit 13f6b191aaa11c7fd718d35a0c565f3c16bc1d99 upstream.
Using the indenting we can see the curly braces were obviously intended.
This is a static checker fix, but my guess is that we don't read enough
bytes, because we don't calculate "t_len" correctly.
Fixes: f1d82698029b ('memstick: use fully asynchronous request processing')
Cc: Alex Dubov <oakad@yahoo.com>
commit 6d7e7e02a044025237b6f62a20521170b794537f upstream.
For cases where total length of an input SGs is not same as
length of the input data for encryption, omap-aes driver
crashes. This happens in the case when IPsec is trying to use
omap-aes driver.
To avoid this, we copy all the pages from the input SG list
into a contiguous buffer and prepare a single element SG list
for this buffer with length as the total bytes to crypt, which is
similar thing that is done in case of unaligned lengths.
Fixes: 6242332ff2f3 ("crypto: omap-aes - Add support for cases of unaligned lengths")
commit a3fa71c40f1853d0c27e8f5bc01a722a705d9682 upstream.
In struct wl18xx_acx_rx_rate_stat, rx_frames_per_rates field is an
array, not a number. This means WL18XX_DEBUGFS_FWSTATS_FILE can't be
used to display this field in debugfs (it would display a pointer, not
the actual data). Use WL18XX_DEBUGFS_FWSTATS_FILE_ARRAY instead.
This bug has been found by adding a __printf attribute to
wl1271_format_buffer. gcc complained about "format '%u' expects
argument of type 'unsigned int', but argument 5 has type 'u32 *'".
Fixes: c5d94169e818 ("wl18xx: use new fw stats structures")
Signed-off-by: Nicolas Iooss <nicolas.iooss_linux@m4x.org>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
commit 08e8331654d1d7b2c58045e549005bc356aa7810 upstream.
There is a race condition between e1000_change_mtu's cleanups and
netpoll, when we change the MTU across jumbo size:
Changing MTU frees all the rx buffers:
e1000_change_mtu -> e1000_down -> e1000_clean_all_rx_rings ->
e1000_clean_rx_ring
Then, close to the end of e1000_change_mtu:
pr_info -> ... -> netpoll_poll_dev -> e1000_clean ->
e1000_clean_rx_irq -> e1000_alloc_rx_buffers -> e1000_alloc_frag
And when we come back to do the rest of the MTU change:
e1000_up -> e1000_configure -> e1000_configure_rx ->
e1000_alloc_jumbo_rx_buffers
alloc_jumbo finds the buffers already != NULL, since data (shared with
page in e1000_rx_buffer->rxbuf) has been re-alloc'd, but it's garbage,
or at least not what is expected when in jumbo state.
This results in an unusable adapter (packets don't get through), and a
NULL pointer dereference on the next call to e1000_clean_rx_ring
(other mtu change, link down, shutdown):
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffff81194d6e>] put_compound_page+0x7e/0x330
Call Trace:
[<ffffffff81195445>] put_page+0x55/0x60
[<ffffffff815d9f44>] e1000_clean_rx_ring+0x134/0x200
[<ffffffff815da055>] e1000_clean_all_rx_rings+0x45/0x60
[<ffffffff815df5e0>] e1000_down+0x1c0/0x1d0
[<ffffffff811e2260>] ? deactivate_slab+0x7f0/0x840
[<ffffffff815e21bc>] e1000_change_mtu+0xdc/0x170
[<ffffffff81647050>] dev_set_mtu+0xa0/0x140
[<ffffffff81664218>] do_setlink+0x218/0xac0
[<ffffffff814459e9>] ? nla_parse+0xb9/0x120
[<ffffffff816652d0>] rtnl_newlink+0x6d0/0x890
[<ffffffff8104f000>] ? kvm_clock_read+0x20/0x40
[<ffffffff810a2068>] ? sched_clock_cpu+0xa8/0x100
[<ffffffff81663802>] rtnetlink_rcv_msg+0x92/0x260
By setting the allocator to a dummy version, netpoll can't mess up our
rx buffers. The allocator is set back to a sane value in
e1000_configure_rx.
Fixes: edbbb3ca1077 ("e1000: implement jumbo receive with partial descriptors")
Signed-off-by: Sabrina Dubroca <sd@queasysnail.net>
Tested-by: Aaron Brown <aaron.f.brown@intel.com>
commit 9535c4757b881e06fae72a857485ad57c422b8d2 upstream.
The hardware, according to the specs, is limited to 256 byte transfers,
and current driver has no protections in case users attempt to do larger
transfers. The code will just stomp over status register and mayhem
ensues.
Let's split larger transfers into digestable chunks. Doing this allows
Atmel MXT driver on Pixel 1 function properly (it hasn't since commit
9d8dc3e529a19e427fd379118acd132520935c5d "Input: atmel_mxt_ts -
implement T44 message handling" which tries to consume multiple
touchscreen/touchpad reports in a single transaction).
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
commit fd99a0943ffaa0320ea4f69d09ed188f950c0432 upstream.
Use the correct flags for atom.
v2: handle DRM_MODE_FLAG_DBLCLK
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit c1c21f4e60ed4523292f1a89ff45a208bddd3849 upstream.
Current -next fails to link an ARM allmodconfig because drivers that use
the core recovery functions can be built as modules but those functions
are not exported:
ERROR: "i2c_generic_gpio_recovery" [drivers/i2c/busses/i2c-davinci.ko] undefined!
ERROR: "i2c_generic_scl_recovery" [drivers/i2c/busses/i2c-davinci.ko] undefined!
ERROR: "i2c_recover_bus" [drivers/i2c/busses/i2c-davinci.ko] undefined!
Add exports to fix this.
Fixes: 5f9296ba21b3c (i2c: Add bus recovery infrastructure)
Signed-off-by: Mark Brown <broonie@kernel.org>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
commit ca9b590caa17bcbbea119594992666e96cde9c2f upstream.
The current code decreases from the mss size (which is the gso_size
from the kernel skb) the size of the packet headers.
It shouldn't do that because the mss that comes from the stack
(e.g IPoIB) includes only the tcp payload without the headers.
The result is indication to the HW that each packet that the HW sends
is smaller than what it could be, and too many packets will be sent
for big messages.
An easy way to demonstrate one more aspect of the problem is by
configuring the ipoib mtu to be less than 2*hlen (2*56) and then
run app sending big TCP messages. This will tell the HW to send packets
with giant (negative value which under unsigned arithmetics becomes
a huge positive one) length and the QP moves to SQE state.
Fixes: b832be1e4007 ('IB/mlx4: Add IPoIB LSO support')
Reported-by: Matthew Finlay <matt@mellanox.com>
Signed-off-by: Erez Shitrit <erezsh@mellanox.com>
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
Signed-off-by: Doug Ledford <dledford@redhat.com>
commit 66578b0b2f69659f00b6169e6fe7377c4b100d18 upstream.
In a call to ib_umem_get(), if address is 0x0 and size is
already page aligned, check added in commit 8494057ab5e4
("IB/uverbs: Prevent integer overflow in ib_umem_get address
arithmetic") will refuse to register a memory region that
could otherwise be valid (provided vm.mmap_min_addr sysctl
and mmap_low_allowed SELinux knobs allow userspace to map
something at address 0x0).
This patch allows back such registration: ib_umem_get()
should probably don't care of the base address provided it
can be pinned with get_user_pages().
There's two possible overflows, in (addr + size) and in
PAGE_ALIGN(addr + size), this patch keep ensuring none
of them happen while allowing to pin memory at address
0x0. Anyway, the case of size equal 0 is no more (partially)
handled as 0-length memory region are disallowed by an
earlier check.
Link: http://mid.gmane.org/cover.1428929103.git.ydroneaud@opteya.com
Cc: Shachar Raindel <raindel@mellanox.com>
Cc: Jack Morgenstein <jackm@mellanox.com>
Cc: Or Gerlitz <ogerlitz@mellanox.com>
Signed-off-by: Yann Droneaud <ydroneaud@opteya.com>
Reviewed-by: Sagi Grimberg <sagig@mellanox.com>
Reviewed-by: Haggai Eran <haggaie@mellanox.com>
commit 8abaae62f3fdead8f4ce0ab46b4ab93dee39bab2 upstream.
If ib_umem_get() is called with a size equal to 0 and an
non-page aligned address, one page will be pinned and a
0-sized umem will be returned to the caller.
This should not be allowed: it's not expected for a memory
region to have a size equal to 0.
This patch adds a check to explicitly refuse to register
a 0-sized region.
commit aeff09276748b66072f2db2e668cec955cf41959 upstream.
The available (i.e. not used) buffers are returned by stk1160_clear_queue(),
on the stop_streaming() path. However, this is insufficient and the current
buffer must be released as well. Fix it.
Signed-off-by: Ezequiel Garcia <ezequiel@vanguardiasur.com.ar>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
commit 56cbd0ccc1b508de19561211d7ab9e1c77e6b384 upstream.
mvsas is giving a General protection fault when it encounters an expander
attached ATA device. Analysis of mvs_task_prep_ata() shows that the driver is
assuming all ATA devices are locally attached and obtaining the phy mask by
indexing the local phy table (in the HBA structure) with the phy id. Since
expanders have many more phys than the HBA, this is causing the index into the
HBA phy table to overflow and returning rubbish as the pointer.
mvs_task_prep_ssp() instead does the phy mask using the port properties.
Mirror this in mvs_task_prep_ata() to fix the panic.
Reported-by: Adam Talbot <ajtalbot1@gmail.com>
Tested-by: Adam Talbot <ajtalbot1@gmail.com>
Signed-off-by: James Bottomley <JBottomley@Odin.com>
commit 40384e4bbeb9f2651fe9bffc0062d9f31ef625bf upstream.
Correctly rollback state if the failure occurs after we have handed over
the ownership of the buffer to the host.
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
commit 0618764cb25f6fa9fb31152995de42a8a0496475 upstream.
I suspect this doesn't show up for most anyone because software
algorithms typically don't have a sense of being too busy. However,
when working with the Freescale CAAM driver it will return -EBUSY on
occasion under heavy -- which resulted in dm-crypt deadlock.
After checking the logic in some other drivers, the scheme for
crypt_convert() and it's callback, kcryptd_async_done(), were not
correctly laid out to properly handle -EBUSY or -EINPROGRESS.
Fix this by using the completion for both -EBUSY and -EINPROGRESS. Now
crypt_convert()'s use of completion is comparable to
af_alg_wait_for_completion(). Similarly, kcryptd_async_done() follows
the pattern used in af_alg_complete().
Before this fix dm-crypt would lockup within 1-2 minutes running with
the CAAM driver. Fix was regression tested against software algorithms
on PPC32 and x86_64, and things seem perfectly happy there as well.
Signed-off-by: Ben Collins <ben.c@servergy.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
commit 0b21503dbbfa669dbd847b33578d4041513cddb2 upstream.
Currently, a RCG's M/N counter (used for fraction division) is
set to either 'bypass' (counter disabled) or 'dual edge' (counter
enabled) based on whether the corresponding rcg struct has a mnd
field specified and a non-zero N.
In the case where M and N are the same value, the M/N counter is
still enabled by code even though no division takes place.
Leaving the RCG in such a state can result in improper behavior.
This was observed with the DSI pixel clock RCG when M and N were
both set to 1.
Add an additional check (M != N) to enable the M/N counter only
when it's needed for fraction division.
Signed-off-by: Archit Taneja <architt@codeaurora.org>
Fixes: bcd61c0f535a (clk: qcom: Add support for root clock
generators (RCGs))
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
commit 5e43e259171e1eee8bc074d9c44be434e685087b upstream.
The number of resets controls is 32 times the number of peripheral
register banks rather than 32 times the number of clocks. This reduces
(drastically) the number of reset controls registered from 10080 (315
clocks * 32) to 224 (6 peripheral register banks * 32).
This also fixes a potential crash because trying to use any of the
excess reset controls (224-10079) would have caused accesses beyond
the array bounds of the peripheral register banks definition array.
Cc: Peter De Schrijver <pdeschrijver@nvidia.com>
Cc: Prashant Gaikwad <pgaikwad@nvidia.com>
Fixes: 6d5b988e7dc5 ("clk: tegra: implement a reset driver")
Signed-off-by: Thierry Reding <treding@nvidia.com>
commit 23600969ff137cf4c3bc9098f77e381de334e3f7 upstream.
Nothing prevents GPIO drivers from returning values outside the
boolean range, and as it turns out a few drivers are actually doing so.
These values were passed as-is to unsuspecting consumers and created
confusion.
This patch makes the internal _gpiod_get_raw_value() function return a
bool, effectively clamping the GPIO value to the boolean range no
matter what the driver does.
While we are at it, we also change the value parameter of
_gpiod_set_raw_value() to bool type before drivers start doing funny
things with it as well.
Another way to fix this would be to change the prototypes of the driver
interface to use bool directly, but this would require a huge
cross-systems patch so this simpler solution is preferred.
Changes since v1:
- Change local variable type to bool as well, use boolean values in
code
- Also change prototype of open drain/open source setting functions
since they are only called from _gpiod_set_raw_value()
This probably calls for a larger booleanization of gpiolib, but let's
keep that for a latter change - right now we need to address the issue
of non-boolean values returned by drivers.
Signed-off-by: Alexandre Courbot <acourbot@nvidia.com>
Cc: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com>
commit 61819549f572edd7fce53f228c0d8420cdc85f71 upstream.
Level IRQ handlers and edge IRQ handler are managed by tow different
sets of registers. But currently the driver uses the same mask for the
both registers. It lead to issues with the following scenario:
First, an IRQ is requested on a GPIO to be triggered on front. After,
this an other IRQ is requested for a GPIO of the same bank but
triggered on level. Then the first one will be also setup to be
triggered on level. It leads to an interrupt storm.
The different kind of handler are already associated with two
different irq chip type. With this patch the driver uses a private
mask for each one which solves this issue.
It has been tested on an Armada XP based board and on an Armada 375
board. For the both boards, with this patch is applied, there is no
such interrupt storm when running the previous scenario.
This bug was already fixed but in a different way in the legacy
version of this driver by Evgeniy Dushistov:
9ece8839b1277fb9128ff6833411614ab6c88d68 "ARM: orion: Fix for certain
sequence of request_irq can cause irq storm". The fact the new version
of the gpio drive could be affected had been discussed there:
http://thread.gmane.org/gmane.linux.ports.arm.kernel/344670/focus=364012
Reported-by: Evgeniy A. Dushistov <dushistov@mail.ru>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
commit 4c533c801d1c9b5c38458a0e7516e0cf50643782 upstream.
acpi_scan_is_offline() may be called under the physical_node_lock
lock of the given device object's parent, so prevent lockdep from
complaining about that by annotating that instance with
SINGLE_DEPTH_NESTING.
Fixes: caa73ea158de (ACPI / hotplug / driver core: Handle containers in a special way)
Reported-and-tested-by: Xie XiuQi <xiexiuqi@huawei.com>
Reviewed-by: Toshi Kani <toshi.kani@hp.com>
commit 2eeff0b4317a02f0e281df891d990194f0737aae upstream.
Add 04f2:aff1 to ath3k.c supported devices list and btusb.c blacklist, so
that the device can load the ath3k firmware and re-enumerate itself as an
AR3011 device.
T: Bus=05 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=12 MxCh= 0
D: Ver= 1.10 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=04f2 ProdID=aff1 Rev= 0.01
C:* #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=100mA
I:* If#= 0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=81(I) Atr=03(Int.) MxPS= 16 Ivl=1ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
I:* If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 0 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 0 Ivl=1ms
I: If#= 1 Alt= 1 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 9 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 9 Ivl=1ms
I: If#= 1 Alt= 2 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 17 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 17 Ivl=1ms
I: If#= 1 Alt= 3 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 25 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 25 Ivl=1ms
I: If#= 1 Alt= 4 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 33 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 33 Ivl=1ms
I: If#= 1 Alt= 5 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 49 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 49 Ivl=1ms
Signed-off-by: Alexander Ploumistos <alexpl@fedoraproject.org>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
commit c836777830428372074d5129ac513e1472c99791 upstream.
In fd_do_prot_rw(), it allocates prot_buf which is used to copy from
se_cmd->t_prot_sg by sbc_dif_copy_prot(). The SG table for prot_buf
is also initialized by allocating 'se_cmd->t_prot_nents' entries of
scatterlist and setting the data length of each entry to PAGE_SIZE
at most.
However if se_cmd->t_prot_sg contains a clustered entry (i.e.
sg->length > PAGE_SIZE), the SG table for prot_buf can't be
initialized correctly and sbc_dif_copy_prot() can't copy to prot_buf.
(This actually happened with TCM loopback fabric module)
As prot_buf is allocated by kzalloc() and it's physically contiguous,
we only need a single scatterlist entry.
Cc: Sagi Grimberg <sagig@mellanox.com>
Cc: "Martin K. Petersen" <martin.petersen@oracle.com>
Cc: "James E.J. Bottomley" <James.Bottomley@HansenPartnership.com>
commit 38da0f49e8aa1649af397d53f88e163d0e60c058 upstream.
When CONFIG_DEBUG_SG=y and DIF protection support enabled, kernel
BUG()s are triggered due to the following two issues:
1) prot_sg is not initialized by sg_init_table().
When CONFIG_DEBUG_SG=y, scatterlist helpers check sg entry has a
correct magic value.
2) vmalloc'ed buffer is passed to sg_set_buf().
sg_set_buf() uses virt_to_page() to convert virtual address to struct
page, but it doesn't work with vmalloc address. vmalloc_to_page()
should be used instead. As prot_buf isn't usually too large, so
fix it by allocating prot_buf by kmalloc instead of vmalloc.
commit c8e639852ad720499912acedfd6b072325fd2807 upstream.
This patch fixes a bug for COMPARE_AND_WRITE handling with
fabrics using SCF_PASSTHROUGH_SG_TO_MEM_NOALLOC.
It adds the missing allocation for cmd->t_bidi_data_sg within
transport_generic_new_cmd() that is used by COMPARE_AND_WRITE
for the initial READ payload, even if the fabric is already
providing a pre-allocated buffer for cmd->t_data_sg.
Also, fix zero-length COMPARE_AND_WRITE handling within the
compare_and_write_callback() and target_complete_ok_work()
to queue the response, skipping the initial READ.
This fixes COMPARE_AND_WRITE emulation with loopback, vhost,
and xen-backend fabric drivers using SG_TO_MEM_NOALLOC.
Reported-by: Christoph Hellwig <hch@lst.de>
commit 8de580742fee8bc34d116f57a20b22b9a5f08403 upstream.
We may exit this function without properly freeing up the maapings
we may have acquired. Fix the bug.
Reviewed-by: Long Li <longli@microsoft.com>
commit 299d0c5b27346a77a0777c993372bf8777d4f2e5 upstream.
The comparison from the previous line seems to have been erroneously
(partially) copied-and-pasted onto the next. The second line should be
checking req.bytes, not req.lnum.
Coverity CID #139400
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
[rw: Fixed comparison]
Signed-off-by: Richard Weinberger <richard@nod.at>
commit f16db8071ce18819fbd705ddcc91c6f392fb61f8 upstream.
In some of the 'out_not_moved' error paths, lnum may be used
uninitialized. Don't ignore the warning; let's fix it.
This uninitialized variable doesn't have much visible effect in the end,
since we just schedule the PEB for erasure, and its LEB number doesn't
really matter (it just gets printed in debug messages). But let's get it
straight anyway.
Coverity CID #113449
commit d74adbdb9abf0d2506a6c4afa534d894f28b763f upstream.
If aeb->len >= vol->reserved_pebs, we should not be writing aeb into the
PEB->LEB mapping.
Caught by Coverity, CID #711212.
commit 8eef7d70f7c6772c3490f410ee2bceab3b543fa1 upstream.
We are completely discarding the earlier value of 'bitflips', which
could reflect a bitflip found in ubi_io_read_vid_hdr(). Let's use the
bitwise OR of header and data 'bitflip' statuses instead.
Coverity CID #1226856
commit 060530f1ea6740eb767085008d183f89ccdd289c upstream.
Signed-off-by: Rob Clark <robdclark@gmail.com>
[Guenter Roeck: backported to 3.14]
commit b367dcaa512922e9207160bef0895622cfae4c9f upstream.
udelay() does not work on some architectures for values above
2000, in particular on ARM:
ERROR: "__bad_udelay" [drivers/scsi/bfa/bfa.ko] undefined!
Reported-by: Vagrant Cascadian <vagrant@debian.org>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit 9374e7d2fdcad3c36dafc8d3effd554bc702c4b6 upstream.
Add new ID for ASUS N10 WiFi dongle.
Tested-by: Marek Vasut <marex@denx.de>
Cc: Larry Finger <Larry.Finger@lwfinger.net>
Cc: John W. Linville <linville@tuxdriver.com>
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
commit 2f92b314f4daff2117847ac5343c54d3d041bf78 upstream.
USB ID 2001:330d is used for a D-Link DWA-131.
commit bd884149aca61de269fd9bad83fe2a4232ffab21 upstream.
On ASUS TP500LN and X750JN, the touchpad absolute mode is reset each
time set_rate is done.
In order to fix this, we will verify the firmware version, and if it
matches the one in those laptops, the set_rate function is overloaded
with a function elantech_set_rate_restore_reg_07 that performs the
set_rate with the original function, followed by a restore of reg_07
(the register that sets the absolute mode on elantech v4 hardware).
Also the ASUS TP500LN and X750JN firmware version, capabilities, and
button constellation is added to elantech.c
Reported-and-tested-by: George Moutsopoulos <gmoutso@yahoo.co.uk>
Signed-off-by: Ulrik De Bie <ulrik.debie-os@e2big.org>
commit bbc78c07a51f6fd29c227b1220a9016e585358ba upstream.
Make sure we're using the new macro, so our
resume signaling will always pass certification.
Signed-off-by: Felipe Balbi <balbi@ti.com>
commit 74bd7b69801819707713b88e9d0bc074efa2f5e7 upstream.
commit 08debfb13b199716da6153940c31968c556b195d upstream.
commit b9e451885deb6262dbaf5cd14aa77d192d9ac759 upstream.
Acked-by: Mathias Nyman <mathias.nyman@linux.intel.com>
commit 8c0ae6574ccfd3d619876a65829aad74c9d22ba5 upstream.
commit 7a606ac29752a3e571b83f9b3fceb1eaa1d37781 upstream.
While this driver was already using a 50ms resume
timeout, let's make sure everybody uses the same
macro so it's easy to fix later should anything
go wrong.
It also gives a more "stable" expectation to Linux
users.
commit 7e136bb71a08e8b8be3bc492f041d9b0bea3856d upstream.
commit b8fb6f79f76f478acbbffccc966daa878f172a0a upstream.
commit 595227db1f2d98bfc33f02a55842f268e12b247d upstream.
commit 869aee0f31429fa9d94d5aef539602b73ae0cf4b upstream.
The res parameter passed to devm_usb_phy_match() is the location where the
pointer to the usb_phy is stored, hence it needs to be dereferenced before
comparing to the match data in order to find the correct match.
Fixes: 410219dcd2ba ("usb: otg: utils: devres: Add API's to associate a device with the phy")
Signed-off-by: Axel Lin <axel.lin@ingics.com>
commit a7117f81e8391e035c49b3440792f7e6cea28173 upstream.
Driver forgot to unregister charger power supply if registering of
battery supply failed in probe(). In such case the memory associated
with power supply leaked.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Fixes: 98a276649358 ("power_supply: Add new lp8788 charger driver")
Signed-off-by: Sebastian Reichel <sre@kernel.org>
commit 68c3ed6fa7e0d69529ced772d650ab128916a81d upstream.
The return value of power_supply_register() call was not checked and
even on error probe() function returned 0. If registering failed then
during unbind the driver tried to unregister power supply which was not
actually registered.
This could lead to memory corruption because power_supply_unregister()
unconditionally cleans up given power supply.
Fixes: da0a00ebc239 ("power: Add twl4030_madc battery driver.")
commit 1915a718b1872edffcb13e5436a9f7302d3d36f0 upstream.
Fix this by checking return status of power_supply_register() call. In
case of failure, clean up sysfs entries and fail the probe.
Fixes: 9be0fcb5ed46 ("compal-laptop: add JHL90, battery & hwmon interface")
commit f20fbaad7620af2df36a1f9d1c9ecf48ead5b747 upstream.
`spidev_message()` sums the lengths of the individual SPI transfers to
determine the overall SPI message length. It restricts the total
length, returning an error if too long, but it does not check for
arithmetic overflow. For example, if the SPI message consisted of two
transfers and the first has a length of 10 and the second has a length
of (__u32)(-1), the total length would be seen as 9, even though the
second transfer is actually very long. If the second transfer specifies
a null `rx_buf` and a non-null `tx_buf`, the `copy_from_user()` could
overrun the spidev's pre-allocated tx buffer before it reaches an
invalid user memory address. Fix it by checking that neither the total
nor the individual transfer lengths exceed the maximum allowed value.
Thanks to Dan Carpenter for reporting the potential integer overflow.
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
commit 323ece54e0761198946ecd0c2091f1d2bfdfcb64 upstream.
Values directly from descriptors given in debug statements
must be converted to native endianness.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
commit 47d68979cc968535cb87f3e5f2e6a3533ea48fbd upstream.
Since commit 20d0189b1012a37d2533a87fb451f7852f2418d1
in v3.14-rc1 RAID0 has performed incorrect calculations
when the chunksize is not a power of 2.
This happens because "sector_div()" modifies its first argument, but
this wasn't taken into account in the patch.
So restore that first arg before re-using the variable.
Reported-by: Joe Landman <joe.landman@gmail.com>
Reported-by: Dave Chinner <david@fromorbit.com>
Fixes: 20d0189b1012a37d2533a87fb451f7852f2418d1
Signed-off-by: NeilBrown <neilb@suse.de>
