[ Upstream commit 07222e535831b916221dd2a48a3047ec7e45dc72 ]
Sparse reports the following:
CHECK drivers/staging/rtl8712/rtl871x_xmit.c
drivers/staging/rtl8712/rtl871x_xmit.c:350:44: warning: restricted __le32 degrades to integer
drivers/staging/rtl8712/rtl871x_xmit.c:491:23: warning: incorrect type in initializer (different base types)
drivers/staging/rtl8712/rtl871x_xmit.c:491:23: expected unsigned short [usertype] *fctrl
drivers/staging/rtl8712/rtl871x_xmit.c:491:23: got restricted __le16 *<noident>
drivers/staging/rtl8712/rtl871x_xmit.c:580:36: warning: incorrect type in assignment (different base types)
drivers/staging/rtl8712/rtl871x_xmit.c:580:36: expected unsigned short [unsigned] [short] [usertype] <noident>
drivers/staging/rtl8712/rtl871x_xmit.c:580:36: got restricted __be16 [usertype] <noident>
[ Upstream commit 4e93b6481c87ea5afde944a32b4908357ec58992 ]
When registering for the Xenstore watch of the node control/sysrq the
handler will be called at once. Don't issue an error message if the
Xenstore node isn't there, as it will be created only when an event
is being triggered.
Signed-off-by: Juergen Gross <jgross@suse.com>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
[ Upstream commit cdcb33f9824429a926b971bf041a6cec238f91ff ]
pci_lock is an IRQ-safe spinlock that protects all accesses to PCI
configuration space (see PCI_OP_READ() and PCI_OP_WRITE() in pci/access.c).
The pci_cfg_access_unlock() path acquires pci_lock, then p->pi_lock (inside
wake_up_all()). According to lockdep, there is a possible path involving
snbep_uncore_pci_read_counter() that could acquire them in the reverse
order: acquiring p->pi_lock, then pci_lock, which could result in a
deadlock. Lockdep details are in the bugzilla below.
Avoid the possible deadlock by dropping pci_lock before waking up any
config access waiters.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=192901
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
[ Upstream commit e41456bfc811f12b5dcda6f2d6849bdff68f6c0a ]
The size computations done in the ioctl function use an integer.
If userspace submits a request with req->cmd_nr or req->cmd_buf_nr
set to INT_MAX, the integer computations overflow later, leading
to potential (kernel) memory corruption.
Prevent this issue by enforcing a limit on the number of submitted
commands, so that we have enough headroom later for the size
computations.
Note that this change has no impact on the currently available
users in userspace, like e.g. libdrm/exynos.
While at it, also make a comment about the size computation more
detailed.
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Signed-off-by: Tobias Jakobi <tjakobi@math.uni-bielefeld.de>
Signed-off-by: Inki Dae <inki.dae@samsung.com>
[ Upstream commit 6792eb0cf9310ec240b7e7c9bfa86dff4c758c68 ]
If dvb_attach() fails then we were just printing an error message and
exiting but the memory allocated to state was not released.
Signed-off-by: Sudip Mukherjee <sudip.mukherjee@codethink.co.uk>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
[ Upstream commit 2202134e48a3b50320aeb9e3dd1186833e9d7e66 ]
Check if the device pointer is valid. Just a sanity check since we already
are in the int handler of the device.
Signed-off-by: Stefan Haberland <sth@linux.vnet.ibm.com>
[ Upstream commit 7c47d2ca0feca767479329da23523ed798acb854 ]
Request for a notification from a disconnected client will be ignored
silently by the FW but the caller should know that the operation hasn't
succeeded.
Signed-off-by: Alexander Usyskin <alexander.usyskin@intel.com>
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
[ Upstream commit 4742575cde1f3cee0ea6b41af42781672315b04b ]
Free memory mapping, if fimc_is_probe is not successful.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
[ Upstream commit f4737a62033d7f3e0db740c449fc62119da7ab8a ]
This method may be unsupported (see: USB bus) or may just fail (see:
SDIO bus).
While at it rework logic in brcmf_sdio_bus_get_memdump function to avoid
too many conditional code nesting levels.
Signed-off-by: Rafał Miłecki <rafal@milecki.pl>
Acked-by: Arend van Spriel <arend.vanspriel@broadcom.com>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
[ Upstream commit 30af99db7ab3483f5ce83ccb890533c9378c2ced ]
This issue is found by smatch; has been reported as-
Unchecked usage of potential ERR_PTR result in lmv_hsm_req_count
and lmv_hsm_req_build. Added ERR_PTR in both functions and also
return value check added.
Signed-off-by: Ulka Vaze <ulka.vaze@yahoo.in>
Signed-off-by: Aditya Pandit <panditadityashreesh@yahoo.com>
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-6523
Reviewed-on: http://review.whamcloud.com/14918
Reviewed-by: Dmitry Eremin <dmitry.eremin@intel.com>
Reviewed-by: Andreas Dilger <andreas.dilger@intel.com>
Reviewed-by: Oleg Drokin <oleg.drokin@intel.com>
Signed-off-by: James Simmons <jsimmons@infradead.org>
[ Upstream commit 4c43c27ddc461d8473cedd70f2549614641dfbc7 ]
This patch resolves IO vs eviction race.
After eviction failed export stayed at stale list,
a client had IO processing and reconnected during it.
A client sent brw rpc with last lock cookie and new connection.
The lock with failed export was found and assert was happened.
(ost_handler.c:1812:ost_prolong_lock_one())
ASSERTION( lock->l_export == opd->opd_exp ) failed:
1. Skip the lock at ldlm_handle2lock if lock export failed.
2. Validation of lock for IO was added at hpreq_check(). The lock
searching is based on granted interval tree. If server doesn`t
have a valid lock, it reply to client with ESTALE.
Signed-off-by: Alexander Boyko <alexander.boyko@seagate.com>
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-7702
Seagate-bug-id: MRP-2787
Reviewed-on: http://review.whamcloud.com/18120
Reviewed-by: Fan Yong <fan.yong@intel.com>
Reviewed-by: Vitaly Fertman <vitaly.fertman@seagate.com>
[ Upstream commit 22aadb91c0a0055935109c175f5446abfb130702 ]
The function hai_dump_data_field will do a stack buffer
overrun when cat'ing /sys/fs/lustre/.../hsm/actions if an action has
some data in it.
hai_dump_data_field uses snprintf. But there is no check for
truncation, and the value returned by snprintf is used as-is. The
coordinator code calls hai_dump_data_field with 12 bytes in the
buffer. The 6th byte of data is printed incompletely to make room for
the terminating NUL. However snprintf still returns 2, so when
hai_dump_data_field writes the final NUL, it does it outside the
reserved buffer, in the 13th byte of the buffer. This stack buffer
overrun hangs my VM.
Fix by checking that there is enough room for the next 2 characters
plus the NUL terminator. Don't print half bytes. Change the format to
02X instead of .2X, which makes more sense.
Signed-off-by: frank zago <fzago@cray.com>
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-8171
Reviewed-on: http://review.whamcloud.com/20338
Reviewed-by: John L. Hammond <john.hammond@intel.com>
Reviewed-by: Jean-Baptiste Riaux <riaux.jb@intel.com>
[ Upstream commit 77759771fb95420d23876cb104ab65c022613325 ]
The function generic_file_read_iter() does not check EOF
before invoke direct_IO callback. So we have to check it
ourselves.
Signed-off-by: Yang Sheng <yang.sheng@intel.com>
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-8969
Reviewed-on: https://review.whamcloud.com/24552
Reviewed-by: Bob Glossman <bob.glossman@intel.com>
Reviewed-by: Bobi Jam <bobijam@hotmail.com>
[ Upstream commit a93151a72061e944a4915458b1b1d6d505c03bbf ]
If the driver is built as a module, autoload won't work because the module
alias information is not filled. So user-space can't match the registered
device with the corresponding module.
Export the module alias information using the MODULE_DEVICE_TABLE() macro.
Before this patch:
$ modinfo drivers/platform/x86/intel_mid_thermal.ko | grep alias
After this patch:
alias: platform:msic_thermal
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
[ Upstream commit 4ec57fb4edaec523f0f78a0449a3b063749ac58b ]
Make sure that the driver processes error conditions even in the fast
response path for response from the adapter.
Signed-off-by: Raghava Aditya Renukunta <RaghavaAditya.Renukunta@microsemi.com>
Signed-off-by: Dave Carroll <David.Carroll@microsemi.com>
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
[ Upstream commit 4fed1b125eb6252bde478665fc05d4819f774fa8 ]
A negative return value indicates an error; in fact the function at
present won't ever return zero.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Reviewed-by: Juergen Gross <jgross@suse.com>
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
[ Upstream commit e8e1a5b5679b1ae1ff03a3883b011b84e7226171 ]
This driver now using devm_regmap_init/devm_regmap_init_i2c, so it needs
to select REGMAP/REGMAP_I2C accordingly.
Fixes: ("3d84fdb3f0b5 gpio: mcp23s08: use regmap")
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Acked-By: Sebastian Reichel <sre@kernel.org>
[ Upstream commit 19649e2c16fbc94b664f7074ec4fa9f15292fdce ]
wait_for_completion_timeout() returns 0 if a timeout occurred, 1
otherwise. Fix the sunxi_nfc_wait_events() accordingly.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
[ Upstream commit 5d806f9fc8e63d7a44e0fd1ef26a7c27efae0e51 ]
This kzalloc() could fail. Let's bail out with -ENOMEM here
instead of NULL dereferencing. That silences static checkers. We
should also cleanup on the error path even though this function
returning an error probably means the system won't boot.
Cc: Chen-Yu Tsai <wens@csie.org>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
[ Upstream commit 7f622593cc5add77a99cd39404e8a851be9de792 ]
With QCA4019 platform, SRAM address can be accessed directly from host but
currently, we are assuming sram addresses cannot be accessed directly and
hence we convert the addresses.
While there, clean up growing hw checks during conversion of target CPU
address to CE address. Now we have function pointer pertaining to different
chips.
Signed-off-by: Ashok Raj Nagarajan <arnagara@qti.qualcomm.com>
Signed-off-by: Kalle Valo <kvalo@qca.qualcomm.com>
[ Upstream commit 6c5da8031a3abfad259190d35f83d89568b72ee2 ]
Internal Master 3 Bus can send and receive only 4 bytes per time.
Signed-off-by: Oleh Kravchenko <oleg@kaa.org.ua>
[ Upstream commit ac6e058b75be71208e98a5808453aae9a17be480 ]
The DP83867 when not properly bootstrapped - especially with LED_0 pin -
can enter N/A MODE4 for "port mirroring" feature.
To provide normal operation of the PHY, one needs not only to explicitly
disable the port mirroring feature, but as well stop some IC internal
testing (which disables RGMII communication).
To do that the STRAP_STS1 (0x006E) register must be read and RESERVED bit
11 examined. When it is set, the another RESERVED bit (11) at PHYCR
(0x0010) register must be clear to disable testing mode and enable RGMII
communication.
Thorough explanation of the problem can be found at following e2e thread:
"DP83867IR: Problem with RESERVED bits in PHY Control Register (PHYCR) -
Linux driver"
https://e2e.ti.com/support/interface/ethernet/f/903/p/571313/2096954#2096954
Signed-off-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
[ Upstream commit ef15d36154cc741d7ded4ae4fa0cf7987354e313 ]
clk_prepare_enable() may fail, so we should better check its return
value.
Also place the of_node_put() function right after clk_prepare_enable(),
in order to avoid calling of_node_put() twice in case clk_prepare_enable()
fails.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Signed-off-by: Stefan Agner <stefan@agner.ch>
[ Upstream commit d45cb20e123c5d7d6cd56301bc98f0bfd725cd77 ]
When we send a deauth to a station we don't know about, we
need to use the PROBE_RESP queue. This can happen when we
send a deauth to a station that is not associated to us.
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
[ Upstream commit 28ed5504ab4b211a4e589e648e5ebd1e0caa7a6a ]
Signed-off-by: Rex Zhu <Rex.Zhu@amd.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
Acked-by: Christian König <christian.koenig@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
[ Upstream commit 71ccea095ea1d4efd004dab971be6d599e06fc3f ]
This fixes the condition where the controller has not fully completed its
final transfer and leaves the bus and controller in a undesirable state.
At the end of the last transmitted byte, the existing driver would just
signal for a STOP condition to be transmitted then immediately signal
completion. However, the full STOP procedure might not have fully taken
place by the time the runtime PM shuts off the peripheral clock, leaving
the bus in a suspended state.
Alternatively, the STOP condition on the bus may have completed, but when
the next transaction is requested by the upper layer, not all the
necessary register cleanup was finished from the last transfer which made
the driver return BUS BUSY when it really wasn't.
This patch now makes all transmit and receive transactions wait for the
STOP condition to fully complete before signaling a completed transaction.
With this new method, runtime PM no longer seems to be an issue.
Fixes: 310c18a41450 ("i2c: riic: add driver")
Signed-off-by: Chris Brandt <chris.brandt@renesas.com>
Reviewed-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
[ Upstream commit 7102a18ac3f323805e3cd8f3dc64907644608c1e ]
The timeouts were too agressive and sometimes cause false alarms.
Signed-off-by: Netanel Belgazal <netanel@annapurnalabs.com>
[ Upstream commit 9303ab2b3402b60f6c39abfdbfa4ce00fce8bee4 ]
drivers/net/ethernet/marvell/mvneta.c:2694:26: error: storage size of 'status' isn't known
drivers/net/ethernet/marvell/mvneta.c:2695:26: error: storage size of 'changed' isn't known
drivers/net/ethernet/marvell/mvneta.c:2695:9: error: variable 'changed' has initializer but incomplete type
drivers/net/ethernet/marvell/mvneta.c:2709:2: error: implicit declaration of function 'fixed_phy_update_state' [-Werror=implicit-function-declaration]
Add linux/phy_fixed.h to mvneta.c
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
Acked-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
[ Upstream commit 3adfb572f2978a980b250a9e1a56f84f3a031001 ]
If alloc_msi_entry() fails, we free resources and set ret = -ENOMEM.
However, msix_setup_entries() returns 0 unconditionally. Return the error
code instead.
Fixes: e75eafb9b039 ("genirq/msi: Switch to new irq spreading infrastructure")
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
[ Upstream commit 221c46d28957bd6e2158abc2179ce4a8c9ce07d3 ]
The headers describing a number of network packets do not have the
correct endian settings for several types of data.
[ Upstream commit 32b40798c1b40343641f04cdfd09652af70ea0e9 ]
Signed-off-by: Deepak Khungar <deepak.khungar@broadcom.com>
Signed-off-by: Michael Chan <michael.chan@broadcom.com>
[ Upstream commit 1af468ebe45591651ec3bafc2e9ddc6fdef70ae0 ]
The R in PEK_DBR stands for rising, so it should be mapped to
AXP288_IRQ_POKP where the last P stands for positive edge.
Likewise PEK_DBF should be mapped to the falling edge, aka the
_N_egative edge, so it should be mapped to AXP288_IRQ_POKN.
This fixes the inverted powerbutton status reporting by the
axp20x-pek driver.
Acked-by: Chen-Yu Tsai <wens@csie.org>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
[ Upstream commit 7e9c40c63933a643908d686bd89dfc2315e8c70a ]
In the current boot, clients making use of the AB8500 sysctrl
may be probed before the ab8500-sysctrl driver. This gives them
-EINVAL, but should rather give -EPROBE_DEFER.
Before this, the abx500 clock driver didn't probe properly,
and as a result the codec driver in turn using the clocks did
not probe properly. After this patch, everything probes
properly.
Also add OF compatible-string probing. This driver is all
device tree, so let's just make a drive-by-fix of that as
well.
[ Upstream commit e1c6ec26b853e9062f0b3daaf695c546d0702953 ]
I got this new build error on today's linux-next
drivers/mmc/host/s3cmci.h:69:24: error: field 'pio_tasklet' has incomplete type
struct tasklet_struct pio_tasklet;
drivers/mmc/host/s3cmci.c: In function 's3cmci_enable_irq':
drivers/mmc/host/s3cmci.c:390:4: error: implicit declaration of function 'enable_irq';did you mean 'enable_imask'? [-Werror=implicit-function-declaration]
While I haven't found out why this happened now and not earlier, the
solution is obvious, we should include the header that defines
the structure.
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
change fp_possible to bool
[ Upstream commit 1d6dbd1752fb4347a4a5db06c8f5cd35dd1919f4 ]
FIX - firmware wants non-RW SYS PD IOs to avoid FastPath for better
tracking and other functionalities if the device is task management
capable.
Signed-off-by: Kashyap Desai <kashyap.desai@broadcom.com>
Signed-off-by: Shivasharan S <shivasharan.srikanteshwara@broadcom.com>
Reviewed-by: Hannes Reinecke <hare@suse.com>
Reviewed-by: Tomas Henzl <thenzl@redhat.com>
[ Upstream commit 09bb6e93956ae5175b96905b723ec879c3ca0765 ]
There are two reasons for reporting wakeup event when dedicated wakeup
IRQ is triggered:
- wakeup events accounting, so proper statistical data will be
displayed in sysfs and debugfs;
- there are small window when System is entering suspend during which
dedicated wakeup IRQ can be lost:
dpm_suspend_noirq()
|- device_wakeup_arm_wake_irqs()
|- dev_pm_arm_wake_irq(X)
|- IRQ is enabled and marked as wakeup source
[1]...
|- suspend_device_irqs()
|- suspend_device_irq(X)
|- irqd_set(X, IRQD_WAKEUP_ARMED);
|- wakup IRQ armed
The wakeup IRQ can be lost if it's triggered at point [1]
and not armed yet.
Hence, fix above cases by adding simple pm_wakeup_event() call in
handle_threaded_wake_irq().
Fixes: 4990d4fe327b (PM / Wakeirq: Add automated device wake IRQ handling)
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
Tested-by: Keerthy <j-keerthy@ti.com>
[ tony@atomide.com: added missing return to avoid warnings ]
Tested-by: Tony Lindgren <tony@atomide.com>
[ Upstream commit ed88451e1f2d400fd6a743d0a481631cf9f97550 ]
For Routable RoCE QPs, the DSCP should be set in the QP's
address path.
The DSCP's value is derived from the traffic class.
Fixes: 2811ba51b049 ("IB/mlx5: Add RoCE fields to Address Vector")
Cc: Achiad Shochat <achiad@mellanox.com>
Signed-off-by: Majd Dibbiny <majd@mellanox.com>
Reviewed-by: Moni Shoua <monis@mellanox.com>
Signed-off-by: Leon Romanovsky <leon@kernel.org>
Reviewed-by: Yuval Shaia <yuval.shaia@oracle.com>
Signed-off-by: Doug Ledford <dledford@redhat.com>
[ Upstream commit 07e9ef146071adf316312b3dd4abfe41c9a45a7d ]
Compiling the fsl-mc bus driver will yield a couple of static analysis
errors:
warning: symbol 'fsl_mc_msi_domain_alloc_irqs' was not declared
warning: symbol 'fsl_mc_msi_domain_free_irqs' was not declared.
warning: symbol 'its_fsl_mc_msi_init' was not declared.
warning: symbol 'its_fsl_mc_msi_cleanup' was not declared.
Since these are properly declared, but the header is not included, add
it in the source files. This way the symbol is properly exported.
Signed-off-by: Bogdan Purcareata <bogdan.purcareata@gmail.com>
[ Upstream commit f7cc02b3c3a33a10dd5bb9e5dfd22e47e09503a2 ]
Ensure that the size field is correctly populated for
all AES modes.
Signed-off-by: Gary R Hook <gary.hook@amd.com>
[ Upstream commit f451014692ae34e587b00de6745e16661cf734d8 ]
If new_policy is set in cpufreq_online(), the policy object has just
been created and its real_cpus mask has been zeroed on allocation,
and the driver's ->init() callback should not touch it.
It doesn't need to be cleared again, so don't do that.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
commit 65e93108891e571f177c202add9288eda9ac4100 upstream.
We recently added an integer overflow check but it needs an additional
tweak to work properly on 32 bit systems.
The problem is that we're doing the right hand side of the assignment as
type unsigned long so the max it will have an integer overflow instead
of being larger than SIZE_MAX. That means the "sz > SIZE_MAX" condition
is never true even on 32 bit systems. We need to first cast it to u64
and then do the math.
Fixes: 4a630fadbb29 ("drm/msm: Fix potential buffer overflow issue")
Acked-by: Jordan Crouse <jcrouse@codeaurora.org>
Signed-off-by: Rob Clark <robdclark@gmail.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
commit 4a630fadbb29d9efaedb525f1a8f7449ad107641 upstream.
In function submit_create, if nr_cmds or nr_bos is assigned with
negative value, the allocated buffer may be small than intended.
Using this buffer will lead to buffer overflow issue.
Signed-off-by: Kasin Li <donglil@codeaurora.org>
Signed-off-by: Jordan Crouse <jcrouse@codeaurora.org>
commit 7c838e2a9be5ab79b11c7f1520813bfdf0f45462 upstream.
Per my reading of the eDP spec, DP_DPCD_DISPLAY_CONTROL_CAPABLE bit in
DP_EDP_CONFIGURATION_CAP should be set if the eDP display control
registers starting at offset DP_EDP_DPCD_REV are "enabled". Currently we
check the bit before reading the registers, and DP_EDP_DPCD_REV is the
only way to detect eDP revision.
Turns out there are (likely buggy) displays that require eDP 1.4+
features, such as supported link rates and link rate select, but do not
have the bit set. Read the display control registers
unconditionally. They are supposed to read zero anyway if they are not
supported, so there should be no harm in this.
This fixes the referenced bug by enabling the eDP version check, and
thus reading of the supported link rates. The panel in question has 0 in
DP_MAX_LINK_RATE which is only supported in eDP 1.4+. Without the
supported link rates method we default to RBR which is insufficient for
the panel native mode. As a curiosity, the panel also has a bogus value
of 0x12 in DP_EDP_DPCD_REV, but that passes our check for >= DP_EDP_14
(which is 0x03).
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=103400
Reported-and-tested-by: Nicolas P. <issun.artiste@gmail.com>
Cc: Ville Syrjälä <ville.syrjala@linux.intel.com>
Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Reviewed-by: Manasi Navare <manasi.d.navare@intel.com>
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20171026142932.17737-1-jani.nikula@intel.com
(cherry picked from commit 0501a3b0eb01ac2209ef6fce76153e5d6b07034e)
Signed-off-by: Rodrigo Vivi <rodrigo.vivi@intel.com>
commit cb4b02d7cac56a69d8137d8d843507cca9182aed upstream.
Fixes init failures on polaris cards with harvested UVD.
Signed-off-by: Leo Liu <leo.liu@amd.com>
commit fc1111b885437f374ed54aadda44d8b241ebd2a3 upstream.
The device tree nodes all correctly describe the regulators as
syr827 or syr828, but the I2C device id is currently set to the
wildcard value of syr82x in the driver. This causes udev to fail
to match the driver module with the modalias data from sysfs.
Fix this by replacing the I2C device ids with ones that match the
device tree descriptions, with syr827 and syr828. Tested on
Firefly rk3288 board. The syr82x id was not used anywhere.
Fixes: e80c47bd738b (regulator: fan53555: Export I2C module alias information)
Signed-off-by: Guillaume Tucker <guillaume.tucker@collabora.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
commit e1d2d1329a5722dbecc9c278303fcc4aa01f8790 upstream.
To avoid kernel warning "Unhandled message (68)", ignore the
CMD_FLUSH_QUEUE_REPLY message for now.
As of Leaf v2 firmware version v4.1.844 (2017-02-15), flush tx queue is
synchronous. There is a capability bit indicating whether flushing tx
queue is synchronous or asynchronous.
A proper solution would be to query the device for capabilities. If the
synchronous tx flush capability bit is set, we should wait for
CMD_FLUSH_QUEUE_REPLY message, while flushing the tx queue.
Signed-off-by: Jimmy Assarsson <jimmyassarsson@gmail.com>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit 8f65a923e6b628e187d5e791cf49393dd5e8c2f9 upstream.
If the return value from kvaser_usb_send_simple_msg() was non-zero, the
return value from kvaser_usb_flush_queue() was printed in the kernel
warning.
commit 3a379f5b36ae039dfeb6f73316e47ab1af4945df upstream.
Fix loopback mode by setting the right flag and remove presume mode.
Signed-off-by: Gerhard Bertelsmann <info@gerhard-bertelsmann.de>
commit 8b95f4f730cba02ef6febbdc4ca7e55ca045b00e upstream.
refresh_rate was not initialized when program
display gap.
this patch can fix vce ring test failed
when do S3 on Polaris10.
bug: https://bugs.freedesktop.org/show_bug.cgi?id=103102
bug: https://bugzilla.kernel.org/show_bug.cgi?id=196615
commit 587c3c9f286cee5c9cac38d28c8ae1875f4ec85b upstream.
Commit 109bade9c625 ("scsi: sg: use standard lists for sg_requests")
introduced an off-by-one error in sg_ioctl(), which was fixed by commit
bd46fc406b30 ("scsi: sg: off by one in sg_ioctl()").
Unfortunately commit 4759df905a47 ("scsi: sg: factor out
sg_fill_request_table()") moved that code, and reintroduced the
bug (perhaps due to a botched rebase). Fix it again.
Fixes: 4759df905a47 ("scsi: sg: factor out sg_fill_request_table()")
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
Acked-by: Douglas Gilbert <dgilbert@interlog.com>
