commit d29f592929489d0a7c414396fae28119f3d280e1 upstream.
(i) pressure is 20-bit unsigned, not signed; the buffer description
is incorrect; for raw reads, this is just cosmetic
(ii) temperature is 12-bit signed, not 16-bit; this affects
readout of temperatures below zero as the sign bit is incorrectly
processed
reported via private mail
Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net>
Reported-by: Robert Deliën <robert@delien.nl>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
commit 8ba42fb7b17649c9ab5b5e79d4e90370a0b4645e upstream.
i2c_smbus_read_word_data() does host endian conversion already,
no need for le16_to_cpu()
commit 4f3bcd878f1d3c730fe00f619b7260c6125d49eb upstream.
at91_adc_get_trigger_value_by_name() was returning -ENOMEM truncated to
a positive u8 and that doesn't work. I've changed it to int and
refactored it to preserve the error code.
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Tested-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
commit 19bc4981a213d0c5b0e1e8b08815c0b26f01ec54 upstream.
All channels' single measurement are happening on CH 0. So enabling / disabling
the divider once is not enough, because it has impact on all channels.
Set only a flag, then check this on each measurement, and enable / disable the
divider as required.
Signed-off-by: Robert Hodaszi <robert.hodaszi@digi.com>
commit e94f62e79f7f63a68574ee5e76c19837ec12f3db upstream.
mcb_request_mem() returns an ERR_PTR(), it doesn't return NULL.
Fixes: 74aeac4da66f ('iio: adc: Add MEN 16z188 ADC driver')
commit c404618cd06dad771495fe1cf9d5a63b5664f65f upstream.
Consider high byte of proximity min and max treshold in function
'tsl2x7x_chip_on'. So far, the high byte was not set.
Signed-off-by: Mario Schuknecht <mario.schuknecht@dresearch-fe.de>
max11611.
commit a91a73c8b39a6b8bcc53fafa5372c65387c81233 upstream.
Reported-by: Erik Habbinga <Erik.Habbinga@schneider-electric.com>
Acked-by: Hartmut Knaack <knaack.h@gmx.de>
commit a100d88df1e924e5c9678fabf054d1bae7ab74fb upstream.
We try to free two pages when only one has been allocated.
Cleanup path is unlikely, so I haven't found any trace that would fit,
but I hope that free_pages_prepare() does catch it.
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
Reviewed-by: Amos Kong <akong@redhat.com>
Acked-by: Jason Wang <jasowang@redhat.com>
commit ae339336dc950b9b05e7ccd3565dd3e8781c06d9 upstream.
The current code posts periodic memory pressure status from a dedicated thread.
Under some conditions, especially when we are releasing a lot of memory into
the guest, we may not send timely pressure reports back to the host. Fix this
issue by reporting pressure in all contexts that can be active in this driver.
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
commit 5292afa657d0e790b7479ad8eef9450c1e040b3d upstream.
Make sure only to decrement the PM counters if they were actually
incremented.
Note that the USB PM counter, but not necessarily the driver core PM
counter, is reset when the interface is unbound.
Fixes: 11ea859d64b6 ("USB: additional power savings for cdc-acm devices
that support remote wakeup")
Signed-off-by: Johan Hovold <jhovold@gmail.com>
commit e4c36076c2a6195ec62c35b03c3fde84d0087dc8 upstream.
Make sure to kill any already submitted read urbs on read-urb submission
failures in open in order to prevent doing I/O for a closed port.
Fixes: 088c64f81284 ("USB: cdc-acm: re-write read processing")
commit 8727bf689a77a79816065e23a7a58a474ad544f9 upstream.
Fix errors during open not being returned to userspace. Specifically,
failed control-line manipulations or control or read urb submissions
would not be detected.
Fixes: 7fb57a019f94 ("USB: cdc-acm: Fix potential deadlock (lockdep
warning)")
commit 703df3297fb1950b0aa53e656108eb936d3f21d9 upstream.
We must not do the usb_autopm_put_interface() before submitting the read
urbs or we might end up doing I/O to a suspended device.
commit 183a45087d126d126e8dd1d9b2602fc129dff9ad upstream.
Make sure to check return value of autopm get in write() in order to
avoid urb leak and PM counter imbalance on errors.
commit ed797074031a37bb9bf4a70952fffc606b77274d upstream.
We should stop I/O unconditionally at suspend rather than rely on the
tty-port initialised flag (which is set prior to stopping I/O during
shutdown) in order to prevent suspend returning with URBs still active.
commit bae3f4c53585e9a170da9436e0f06919874bda9a upstream.
Fix runtime PM handling of control messages by adding the required PM
counter operations.
commit 140cb81ac8c625942a1d695875932c615767a526 upstream.
The current ACM runtime-suspend implementation is broken in several
ways:
Firstly, it buffers only the first write request being made while
suspended -- any further writes are silently dropped.
Secondly, writes being dropped also leak write urbs, which are never
reclaimed (until the device is unbound).
Thirdly, even the single buffered write is not cleared at shutdown
(which may happen before the device is resumed), something which can
lead to another urb leak as well as a PM usage-counter leak.
Fix this by implementing a delayed-write queue using urb anchors and
making sure to discard the queue properly at shutdown.
Reported-by: Xiao Jin <jin.xiao@intel.com>
commit e144ed28bed10684f9aaec6325ed974d53f76110 upstream.
Fix race between write() and resume() due to improper locking that could
lead to writes being reordered.
Resume must be done atomically and susp_count be protected by the
write_lock in order to prevent racing with write(). This could otherwise
lead to writes being reordered if write() grabs the write_lock after
susp_count is decremented, but before the delayed urb is submitted.
commit 5a345c20c17d87099224a4be12e69e5bd7023dca upstream.
Fix race between write() and suspend() which could lead to writes being
dropped (or I/O while suspended) if the device is runtime suspended
while a write request is being processed.
Specifically, suspend() releases the write_lock after determining the
device is idle but before incrementing the susp_count, thus leaving a
window where a concurrent write() can submit an urb.
[ Upstream commit 2853af6a2ea1a8ed09b09dd4fb578e7f435e8d34 ]
When we mirror packets from a vxlan tunnel to other device,
the mirror device should see the same packets (that is, without
outer header). Because vxlan tunnel sets dev->hard_header_len,
tcf_mirred() resets mac header back to outer mac, the mirror device
actually sees packets with outer headers
Vxlan tunnel should set dev->needed_headroom instead of
dev->hard_header_len, like what other ip tunnels do. This fixes
the above problem.
Cc: stephen hemminger <stephen@networkplumber.org>
Cc: Pravin B Shelar <pshelar@nicira.com>
Signed-off-by: Cong Wang <cwang@twopensource.com>
[ Upstream commit daf37b556e437ec1ea1a597dcfeff338068380e1 ]
Fixes:ee45fd92c739
("sfc: Use TX PIO for sufficiently small packets")
The linux net driver uses memcpy_toio() in order to copy into
the PIO buffers.
Even on a 64bit machine this causes 32bit accesses to a write-
combined memory region.
There are hardware limitations that mean that only 64bit
naturally aligned accesses are safe in all cases.
Due to being write-combined memory region two 32bit accesses
may be coalesced to form a 64bit non 64bit aligned access.
Solution was to open-code the memory copy routines using pointers
and to only enable PIO for x86_64 machines.
Not tested on platforms other than x86_64 because this patch
disables the PIO feature on other platforms.
Compile-tested on x86 to ensure that works.
The WARN_ON_ONCE() code in the previous version of this patch
has been moved into the internal sfc debug driver as the
assertion was unnecessary in the upstream kernel code.
This bug fix applies to v3.13 and v3.14 stable branches.
Signed-off-by: Shradha Shah <sshah@solarflare.com>
[ Upstream commit 87757a917b0b3c0787e0563c679762152be81312 ]
unregister_netdevice_many() API is error prone and we had too
many bugs because of dangling LIST_HEAD on stacks.
See commit f87e6f47933e3e ("net: dont leave active on stack LIST_HEAD")
In fact, instead of making sure no caller leaves an active list_head,
just force a list_del() in the callee. No one seems to need to access
the list after unregister_netdevice_many()
[ Upstream commit ba6de0f5304ccdc45ae260e7e0feb6e0ef2dd558 ]
Lars writes: "I'm only 99% sure that the net interfaces are qmi
interfaces, nothing to lose by adding them in my opinion."
And I tend to agree based on the similarity with the two Olicard
modems we already have here.
Reported-by: Lars Melin <larsm17@gmail.com>
Signed-off-by: Bjørn Mork <bjorn@mork.no>
[ Upstream commit d8b0426af5b67973585712c9af36b86f6ea97815 ]
Commit 4a55530f38e4 (net: sh_eth: modify the definitions of register) managed
to leave out the E-DMAC register entries in sh_eth_offset_fast_sh3_sh2[], thus
totally breaking SH7619/771x support. Add the missing entries using the data
from before that commit.
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
Acked-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
[ Upstream commit 530aa2d0d9d55ab2775d47621ddf4b5b15bc1110 ]
The current behaviour of the sh_eth driver is not to use the RNC bit
for the receive ring. This means that every packet recieved is not only
generating an IRQ but it also stops the receive ring DMA as well until
the driver re-enables it after unloading the packet.
This means that a number of the following errors are generated due to
the receive packet FIFO overflowing due to nowhere to put packets:
net eth0: Receive FIFO Overflow
Since feedback from Yoshihiro Shimoda shows that every supported LSI
for this driver should have the bit enabled it seems the best way is
to remove the RMCR default value from the per-system data and just
write it when initialising the RMCR value. This is discussed in
the message (http://www.spinics.net/lists/netdev/msg284912.html).
I have tested the RMCR_RNC configuration with NFS root filesystem and
the driver has not failed yet. There are further test reports from
Sergei Shtylov and others for both the R8A7790 and R8A7791.
There is also feedback fron Cao Minh Hiep[1] which reports the
same issue in (http://comments.gmane.org/gmane.linux.network/316285)
showing this fixes issues with losing UDP datagrams under iperf.
Tested-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
Signed-off-by: Ben Dooks <ben.dooks@codethink.co.uk>
Acked-by: Simon Horman <horms+renesas@verge.net.au>
commit 1d2b60a5545942b1376cb48c1d55843d71e3a08f upstream.
This patch adds an explicit check in chap_server_compute_md5() to ensure
the CHAP_C value received from the initiator during mutual authentication
does not match the original CHAP_C provided by the target.
This is in line with RFC-3720, section 8.2.1:
Originators MUST NOT reuse the CHAP challenge sent by the Responder
for the other direction of a bidirectional authentication.
Responders MUST check for this condition and close the iSCSI TCP
connection if it occurs.
Reported-by: Tejas Vaykole <tejas.vaykole@calsoftinc.com>
commit 0ed6e189e3f6ac3a25383ed5cc8b0ac24c9b97b7 upstream.
This patch fixes a NULL pointer dereference regression bug that was
introduced with:
commit 1e1110c43b1cda9fe77fc4a04835e460550e6b3c
Author: Mikulas Patocka <mpatocka@redhat.com>
Date: Sat May 17 06:49:22 2014 -0400
target: fix memory leak on XCOPY
Now that target_put_sess_cmd() -> kref_put_spinlock_irqsave() is
called with a valid se_cmd->cmd_kref, a NULL pointer dereference
is triggered because the XCOPY passthrough commands don't have
an associated se_session pointer.
To address this bug, go ahead and checking for a NULL se_sess pointer
within target_put_sess_cmd(), and call se_cmd->se_tfo->release_cmd()
to release the XCOPY's xcopy_pt_cmd memory.
Reported-by: Thomas Glanzmann <thomas@glanzmann.de>
Cc: Thomas Glanzmann <thomas@glanzmann.de>
Cc: Mikulas Patocka <mpatocka@redhat.com>
commit 2fe121e1f5aa3bf31b418a9790db6c400e922291 upstream.
The rtc user must wait at least 1 sec between each time/calandar update
(see atmel's datasheet chapter "Updating Time/Calendar").
Use the 1Hz interrupt to update the at91_rtc_upd_rdy flag and wait for
the at91_rtc_wait_upd_rdy event if the rtc is not ready.
This patch fixes a deadlock in an uninterruptible wait when the RTC is
updated more than once every second. AFAICT the bug is here from the
beginning, but I think we should at least backport this fix to 3.10 and
the following longterm and stable releases.
Signed-off-by: Boris BREZILLON <boris.brezillon@free-electrons.com>
Reported-by: Bryan Evenson <bevenson@melinkcorp.com>
Tested-by: Bryan Evenson <bevenson@melinkcorp.com>
Cc: Andrew Victor <linux@maxim.org.za>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
commit 754a292fe6b08196cb135c03b404444e17de520a upstream.
Add support for Marvell Technology Group Ltd. 88SE91A0 SATA 6Gb/s
Controller by adding its PCI ID.
Signed-off-by: Andreas Schrägle <ajs124.ajs124@gmail.com>
commit d251836508fb26cd1a22b41381739835ee23728d upstream.
This device normally comes with a proprietary driver, using a web GUI
to configure RAID:
http://www.highpoint-tech.com/USA_new/series_rr600-download.htm
But thankfully it also works out of the box with the AHCI driver,
being just a Marvell 88SE9235.
Devices 640L, 644L, 644LS should also be supported but not tested here.
Signed-off-by: Jérôme Carretero <cJ-ko@zougloub.eu>
commit 74a86272f05c3dae40f2d7b17ff09a0608cf3304 upstream.
Added support for Sveon STV27 device (rtl2832u + FC0013 tuner)
Signed-off-by: Alessandro Miceli <angelofsky1980@gmail.com>
Signed-off-by: Antti Palosaari <crope@iki.fi>
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
commit f27f5b0ee4967babfb8b03511f5e76b79d781014 upstream.
Added Sveon STV20 device based on Realtek RTL2832U and FC0012 tuner
commit 9ca24ae4083665bda38da45f4b5dc9bbaf936bc0 upstream.
Add USB ID for Peak DVB-T USB.
[crope@iki.fi: fix Brian email address and indentation]
Signed-off-by: Brian Healy <healybrian@gmail.com>
commit c40765d919d25d2d44d99c4ce39e48808f137e1e upstream.
According the spec the host should read H_CSR again
after asserting reset H_RST to ensure that reset was
read by the firmware
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
Signed-off-by: Alexander Usyskin <alexander.usyskin@intel.com>
commit 07cd7be3d92eeeae1f92a017f2cfe4fdd9256526 upstream.
It my take time till ME_RDY will be cleared after the reset,
so we cannot check the bit before we got the interrupt
commit b04ada92ffaabb868497a1fce8e4f6bf74e5488f upstream.
We cleared H_RST for H_CSR on spurious interrupt generated when ME_RDY
while cleared and not while ME_RDY is set. The spurious interrupt
is not delivered on all platforms in this case the
driver may fail to initialize.
commit b701c0b1fe819a2083fc6ec5332e0e4492b9516d upstream.
free_msi_irqs() is leaking memory, since list_for_each_entry(entry,
&dev->msi_list, list) {...} is never executed, because dev->msi_list is
made empty by the loop just above this one.
Fix it by relying on zero termination of attribute array like
populate_msi_sysfs() does.
Fixes: 1c51b50c2995 ("PCI/MSI: Export MSI mode using attributes, not kobjects")
Signed-off-by: Alexei Starovoitov <ast@plumgrid.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Pull SCSI target fixes from Nicholas Bellinger:
"Here are the remaining fixes for v3.15.
This series includes:
- iser-target fix for ImmediateData exception reference count bug
(Sagi + nab)
- iscsi-target fix for MC/S login + potential iser-target MRDSL
buffer overrun (Santosh + Roland)
- iser-target fix for v3.15-rc multi network portal shutdown
regression (nab)
- target fix for allowing READ_CAPCITY during ALUA Standby access
state (Chris + nab)
- target fix for NULL pointer dereference of alua_access_state for
un-configured devices (Chris + nab)"
* git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending:
target: Fix alua_access_state attribute OOPs for un-configured devices
target: Allow READ_CAPACITY opcode in ALUA Standby access state
iser-target: Fix multi network portal shutdown regression
iscsi-target: Fix wrong buffer / buffer overrun in iscsi_change_param_value()
iser-target: Add missing target_put_sess_cmd for ImmedateData failure
This patch fixes a OOPs where an attempt to write to the per-device
alua_access_state configfs attribute at:
/sys/kernel/config/target/core/$HBA/$DEV/alua/$TG_PT_GP/alua_access_state
results in an NULL pointer dereference when the backend device has not
yet been configured.
This patch adds an explicit check for DF_CONFIGURED, and fails with
-ENODEV to avoid this case.
Reported-by: Chris Boot <crb@tiger-computing.co.uk>
Reported-by: Philip Gaw <pgaw@darktech.org.uk>
Cc: Chris Boot <crb@tiger-computing.co.uk>
Cc: Philip Gaw <pgaw@darktech.org.uk>
Cc: stable@vger.kernel.org # 3.8+
This patch allows READ_CAPACITY + SAI_READ_CAPACITY_16 opcode
processing to occur while the associated ALUA group is in Standby
access state.
This is required to avoid host side LUN probe failures during the
initial scan if an ALUA group has already implicitly changed into
Standby access state.
This addresses a bug reported by Chris + Philip using dm-multipath
+ ESX hosts configured with ALUA multipath.
Cc: Hannes Reinecke <hare@suse.de>
Pull intel pstate fixes from Rafael Wysocki:
"Final power management fixes for 3.15
- Taking non-idle time into account when calculating core busy time
was a mistake and led to a performance regression. Since the
problem it was supposed to address is now taken care of in a
different way, we don't need to do it any more, so drop the
non-idle time tracking from intel_pstate. Dirk Brandewie.
- Changing to fixed point math throughout the busy calculation
introduced rounding errors that adversely affect the accuracy of
intel_pstate's computations. Fix from Dirk Brandewie.
- The PID controller algorithm used by intel_pstate assumes that the
time interval between two adjacent samples will always be the same
which is not the case for deferable timers (used by intel_pstate)
when the system is idle. This leads to inaccurate predictions and
artificially increases convergence times for the minimum P-state.
- intel_pstate carries out computations using 32-bit variables that
may overflow for large enough values of APERF/MPERF. Switch to
using 64-bit variables for computations, from Doug Smythies"
* tag 'pm-3.15-final' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
intel_pstate: Improve initial busy calculation
intel_pstate: add sample time scaling
intel_pstate: Correct rounding in busy calculation
intel_pstate: Remove C0 tracking
Pull drm fixes from Dave Airlie:
"All fairly small: radeon stability and a panic path fix.
Mostly radeon fixes, suspend/resume fix, stability on the CIK
chipsets, along with a locking check avoidance patch for panic times
regression"
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux:
drm/radeon: use the CP DMA on CIK
drm/radeon: sync page table updates
drm/radeon: fix vm buffer size estimation
drm/crtc-helper: skip locking checks in panicking path
drm/radeon/dpm: resume fixes for some systems
This patch fixes a iser-target specific regression introduced in
v3.15-rc6 with:
commit 14f4b54fe38f3a8f8392a50b951c8aa43b63687a
Author: Sagi Grimberg <sagig@mellanox.com>
Date: Tue Apr 29 13:13:47 2014 +0300
Target/iscsi,iser: Avoid accepting transport connections during stop stage
where the change to set iscsi_np->enabled = false within
iscsit_clear_tpg_np_login_thread() meant that a iscsi_np with
two iscsi_tpg_np exports would have it's parent iscsi_np set
to a disabled state, even if other iscsi_tpg_np exports still
existed.
This patch changes iscsit_clear_tpg_np_login_thread() to only
set iscsi_np->enabled = false when shutdown = true, and also
changes iscsit_del_np() to set iscsi_np->enabled = true when
iscsi_np->np_exports is non zero.
Cc: Sagi Grimberg <sagig@dev.mellanox.co.il>
Cc: stable@vger.kernel.org # 3.10+
In non-leading connection login, iscsi_login_non_zero_tsih_s1() calls
iscsi_change_param_value() with the buffer it uses to hold the login
PDU, not a temporary buffer. This leads to the login header getting
corrupted and login failing for non-leading connections in MC/S.
Fix this by adding a wrapper iscsi_change_param_sprintf() that handles
the temporary buffer itself to avoid confusion. Also handle sending a
reject in case of failure in the wrapper, which lets the calling code
get quite a bit smaller and easier to read.
Finally, bump the size of the temporary buffer from 32 to 64 bytes to be
safe, since "MaxRecvDataSegmentLength=" by itself is 25 bytes; with a
trailing NUL, a value >= 1M will lead to a buffer overrun. (This isn't
the default but we don't need to run right at the ragged edge here)
Reported-by: Santosh Kulkarni <santosh.kulkarni@calsoftinc.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
This patch addresses a bug where an early exception for SCSI WRITE
with ImmediateData=Yes was missing the target_put_sess_cmd() call
to drop the extra se_cmd->cmd_kref reference obtained during the
normal iscsit_setup_scsi_cmd() codepath execution.
This bug was manifesting itself during session shutdown within
isert_cq_rx_comp_err() where target_wait_for_sess_cmds() would
end up waiting indefinately for the last se_cmd->cmd_kref put to
occur for the failed SCSI WRITE + ImmediateData descriptors.
This fix follows what traditional iscsi-target code already does
for the same failure case within iscsit_get_immediate_data().
Reported-by: Sagi Grimberg <sagig@dev.mellanox.co.il>
Cc: Or Gerlitz <ogerlitz@mellanox.com>
Pull networking fixes from David Miller:
1) Unbreak zebra and other netlink apps, from Eric W Biederman.
2) Some new qmi_wwan device IDs, from Aleksander Morgado.
3) Fix info leak in DCB netlink handler of qlcnic driver, from Dan
Carpenter.
4) inet_getid() and ipv6_select_ident() do not generate monotonically
increasing ID numbers, fix from Eric Dumazet.
5) Fix memory leak in __sk_prepare_filter(), from Leon Yu.
6) Netlink leftover bytes warning message is user triggerable, rate
limit it. From Michal Schmidt.
7) Fix non-linear SKB panic in ipvs, from Peter Christensen.
8) Congestion window undo needs to be performed even if only never
retransmitted data is SACK'd, fix from Yuching Cheng.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (24 commits)
net: filter: fix possible memory leak in __sk_prepare_filter()
net: ec_bhf: Add runtime dependencies
tcp: fix cwnd undo on DSACK in F-RTO
netlink: Only check file credentials for implicit destinations
ipheth: Add support for iPad 2 and iPad 3
team: fix mtu setting
net: fix inet_getid() and ipv6_select_ident() bugs
net: qmi_wwan: interface #11 in Sierra Wireless MC73xx is not QMI
net: qmi_wwan: add additional Sierra Wireless QMI devices
bridge: Prevent insertion of FDB entry with disallowed vlan
netlink: rate-limit leftover bytes warning and print process name
bridge: notify user space after fdb update
net: qmi_wwan: add Netgear AirCard 341U
net: fix wrong mac_len calculation for vlans
batman-adv: fix NULL pointer dereferences
net/mlx4_core: Reset RoCE VF gids when guest driver goes down
emac: aggregation of v1-2 PLB errors for IER register
emac: add missing support of 10mbit in emac/rgmii
can: only rename enabled led triggers when changing the netdev name
ipvs: Fix panic due to non-linear skb
Pull two md bugfixes from Neil Brown:
"Two md bugfixes for possible corruption when restarting reshape
If a raid5/6 reshape is restarted (After stopping and re-assembling
the array) and the array is marked read-only (or read-auto), then the
reshape will appear to complete immediately, without actually moving
anything around. This can result in corruption.
There are two patches which do much the same thing in different
places. They are separate because one is an older bug and so can be
applied to more -stable kernels"
* tag 'md/3.15-fixes' of git://neil.brown.name/md:
md: always set MD_RECOVERY_INTR when interrupting a reshape thread.
md: always set MD_RECOVERY_INTR when aborting a reshape or other "resync".
The ec_bhf driver is specific to the Beckhoff CX embedded PC series.
These are based on Intel x86 CPU. So we can add a dependency on
X86, with COMPILE_TEST as an alternative to still allow for broader
build-testing.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Cc: Darek Marcinkiewicz <reksio@newterm.pl>
Queued trim only works for some users with MU05 firmware. Revert to
blacklisting all firmware versions.
Introduced by commit d121f7d0cbb8 ("libata: Update queued trim blacklist
for M5x0 drives") which this effectively reverts, while retaining the
blacklisting of M550.
See
https://bugzilla.kernel.org/show_bug.cgi?id=71371
for reports of trouble with MU05 firmware.
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Tejun Heo <tj@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB fixes from Greg KH:
"Here are some fixes for 3.15-rc8 that resolve a number of tiny USB
issues that have been reported, and there are some new device ids as
well.
All have been tested in linux-next"
* tag 'usb-3.15-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb:
xhci: delete endpoints from bandwidth list before freeing whole device
usb: pci-quirks: Prevent Sony VAIO t-series from switching usb ports
USB: cdc-wdm: properly include types.h
usb: cdc-wdm: export cdc-wdm uapi header
USB: serial: option: add support for Novatel E371 PCIe card
USB: ftdi_sio: add NovaTech OrionLXm product ID
USB: io_ti: fix firmware download on big-endian machines (part 2)
USB: Avoid runtime suspend loops for HCDs that can't handle suspend/resume
