present
commit 975e83cfb8dc16e7a2fdc58188c77c0c605876c2 upstream.
If the genpd->attach_dev or genpd->power_on fails, genpd_dev_pm_attach
may return -EPROBE_DEFER initially. However genpd_alloc_dev_data sets
the PM domain for the device unconditionally.
When subsequent attempts are made to call genpd_dev_pm_attach, it may
return -EEXISTS checking dev->pm_domain without re-attempting to call
attach_dev or power_on.
platform_drv_probe then attempts to call drv->probe as the return value
-EEXIST != -EPROBE_DEFER, which may end up in a situation where the
device is accessed without it's power domain switched on.
Fixes: f104e1e5ef57 (PM / Domains: Re-order initialization of generic_pm_domain_data)
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Acked-by: Ulf Hansson <ulf.hansson@linaro.org>
commit d50daa2af2618dab6d21634e65a5fbcf4ae437d6 upstream.
Include the OF-based modalias in the uevent sent when registering SPMI
devices, so that user space has a chance to autoload the kernel module
for the device.
Tested-by: Rob Clark <robdclark@gmail.com>
Reported-by: Rob Clark <robdclark@gmail.com>
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
commit 7a3b7cd332db08546f3cdd984f11773e0d1999e7 upstream.
The ULPI bus can be built as a module, and it will soon be
calling these functions when it supports probing devices from DT.
Export them so they can be used by the ULPI module.
Acked-by: Rob Herring <robh@kernel.org>
Cc: <devicetree@vger.kernel.org>
Signed-off-by: Stephen Boyd <stephen.boyd@linaro.org>
Signed-off-by: Peter Chen <peter.chen@nxp.com>
commit 7e700d2c59e5853c9126642976b4f5768f64c9b3 upstream.
nfit_init() calls nfit_mce_register() on module load. When the module
load fails the nfit mce decoder is not unregistered. The module's
memory is freed leaving the decoder chain referencing junk. This will
cause panics as future registrations will reference the free'd memory.
Unregister the nfit mce decoder on module init failure.
[v2]: register and then unregister mce handler to avoid losing mce events
[v3]: also cleanup nfit workqueue
Fixes: 6839a6d96f4e ("nfit: do an ARS scrub on hitting a latent media error")
Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net>
Cc: Len Brown <lenb@kernel.org>
Cc: Vishal Verma <vishal.l.verma@intel.com>
Cc: "Lee, Chun-Yi" <joeyli.kernel@gmail.com>
Cc: Linda Knippers <linda.knippers@hpe.com>
Cc: lszubowi@redhat.com
Acked-by: Jeff Moyer <jmoyer@redhat.com>
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
Reviewed-by: Vishal Verma <vishal.l.verma@intel.com>
commit 99975cd4fda52974a767aa44fe0b1a8f74950d9d upstream.
ib_map_mr_sg() can pass an SG-list to .map_mr_sg() that is larger
than what fits into a single MR. .map_mr_sg() must not attempt to
map more SG-list elements than what fits into a single MR.
Hence make sure that mlx5_ib_sg_to_klms() does not write outside
the MR klms[] array.
Fixes: b005d3164713 ("mlx5: Add arbitrary sg list support")
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
Reviewed-by: Max Gurtovoy <maxg@mellanox.com>
Cc: Sagi Grimberg <sagi@grimberg.me>
Cc: Leon Romanovsky <leonro@mellanox.com>
Cc: Israel Rukshin <israelr@mellanox.com>
Acked-by: Leon Romanovsky <leonro@mellanox.com>
Reviewed-by: Sagi Grimberg <sagi@grimberg.me>
Signed-off-by: Doug Ledford <dledford@redhat.com>
commit 636c4c3e762b62aa93632c645ca65879285b16e3 upstream.
Currently we may process up/down message transactions containing
uninitialized data. This can happen if there was an error during the
reception of any message in the transaction, but we happened to receive
the last message correctly with the end-of-message flag set.
To avoid this abort the reception of the transaction when the first
error is detected, rejecting any messages until a message with the
start-of-message flag is received (which will start a new transaction).
This is also what the DP 1.4 spec 2.11.8.2 calls for in this case.
In addtion this also prevents receiving bogus transactions without the
first message with the the start-of-message flag set.
v2:
- unchanged
v3:
- git add the part that actually skips messages after an error in
drm_dp_sideband_msg_build()
Cc: Dave Airlie <airlied@redhat.com>
Cc: Lyude <lyude@redhat.com>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Imre Deak <imre.deak@intel.com>
Reviewed-by: Lyude <lyude@redhat.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Link: https://patchwork.freedesktop.org/patch/msgid/20170719134632.13366-1-imre.deak@intel.com
commit 7f8b3987da54cb4d41ad2545cd4d7958b9a36bdf upstream.
In case of an unknown broadcast message is sent mstb will remain unset,
so check for this.
Link: https://patchwork.freedesktop.org/patch/msgid/20170719114330.26540-3-imre.deak@intel.com
commit 448421b5e93b9177c5698f0cf6f5e72d2995eeca upstream.
Handle any error due to partial reads, timeouts etc. to avoid parsing
uninitialized data subsequently. Also bail out if the parsing itself
fails.
Link: https://patchwork.freedesktop.org/patch/msgid/20170719114330.26540-2-imre.deak@intel.com
commit a62ab66b13a0f9bcb17b7b761f6670941ed5cd62 upstream.
Initialize the port_num for iWARP in rdma_init_qp_attr.
Fixes: 5ecce4c9b17b("Check port number supplied by user verbs cmds")
Reviewed-by: Steve Wise <swise@opengridcomputing.com>
Signed-off-by: Mustafa Ismail <mustafa.ismail@intel.com>
Tested-by: Mike Marciniszyn <mike.marciniszyn@intel.com>
commit 566e1ce22e04426fa52328b2adcdf1df49acd98e upstream.
We now get a helpful warning for code that calls copy_{from,to}_iter
without checking the return value, introduced by commit aa28de275a24
("iov_iter/hardening: move object size checks to inlined part").
drivers/staging/lustre/lnet/klnds/o2iblnd/o2iblnd_cb.c: In function 'kiblnd_send':
drivers/staging/lustre/lnet/klnds/o2iblnd/o2iblnd_cb.c:1643:2: error: ignoring return value of 'copy_from_iter', declared with attribute warn_unused_result [-Werror=unused-result]
drivers/staging/lustre/lnet/klnds/o2iblnd/o2iblnd_cb.c: In function 'kiblnd_recv':
drivers/staging/lustre/lnet/klnds/o2iblnd/o2iblnd_cb.c:1744:3: error: ignoring return value of 'copy_to_iter', declared with attribute warn_unused_result [-Werror=unused-result]
In case we get short copies here, we may get incorrect behavior.
I've added failure handling for both rx and tx now, returning
-EFAULT as expected.
Signed-off-by: James Simmons <jsimmons@infradead.org>
commit 740c433ec35187b45abe08bb6c45a321a791be8e upstream.
If vesafb is enabled in the config then /dev/fb0 is created by vesa
and this sm750 driver gets fb1, fb2. But we need to be fb0 and fb1 to
effectively work with xorg.
So if it has been alloted fb1, then try to remove the other fb0.
In the previous send, why #ifdef is used was asked.
https://lkml.org/lkml/2017/6/25/57
Answered at: https://lkml.org/lkml/2017/6/25/69
Also pasting here for reference.
'Did a quick research into "why".
The patch d8801e4df91e ("x86/PCI: Set IORESOURCE_ROM_SHADOW only for the
default VGA device") has started setting IORESOURCE_ROM_SHADOW in flags
for a default VGA device and that is being done only for x86.
And so, we will need that #ifdef to check IORESOURCE_ROM_SHADOW as that
needs to be checked only for a x86 and not for other arch.'
Signed-off-by: Teddy Wang <teddy.wang@siliconmotion.com>
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
commit 15d5193104a457d5151840247e3bce561c42e3e9 upstream.
As reported by Éric Piel on the Comedi mailing list (see
<https://groups.google.com/forum/#!topic/comedi_list/ueZiR7vTLOU/discussion>),
the analog output asynchronous commands are running too fast with a
period 50 ns shorter than it should be. This affects all boards with AO
command support that are supported by the "ni_pcimio", "ni_atmio", and
"ni_mio_cs" drivers.
This is a regression bug introduced by commit 080e6795cba3 ("staging:
comedi: ni_mio_common: Cleans up/clarifies ni_ao_cmd"), specifically,
this line in `ni_ao_cmd_set_update()`:
/* following line: N-1 per STC */
ni_stc_writel(dev, trigvar - 1, NISTC_AO_UI_LOADA_REG);
The `trigvar` variable value comes from a call to `ni_ns_to_timer()`
which converts a timer period in nanoseconds to a hardware divisor
value. The function already reduces the divisor by 1 as required by the
hardware, so the above line should not reduce it further by 1. Fix it
by replacing `trigvar` by `trigvar - 1` in the above line, and remove
the misleading comment.
Reported-by: Éric Piel <piel@delmic.com>
Fixes: 080e6795cba3 ("staging: comedi: ni_mio_common: Cleans up/clarifies ni_ao_cmd")
Cc: Éric Piel <piel@delmic.com>
Cc: Spencer E. Olson <olsonse@umich.edu>
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
commit 5a1d4c5dd4eb2f1f8a9b30e61762f3b3b564df70 upstream.
Add support for USB Device TP-Link TL-WN722N v2.
VendorID: 0x2357, ProductID: 0x010c
Signed-off-by: Michael Gugino <michael.gugino.2@gmail.com>
commit fce50a2fa4e9c6e103915c351b6d4a98661341d6 upstream.
This patch fixes a NULL pointer dereference in isert_login_recv_done()
of isert_conn->cm_id due to isert_cma_handler() -> isert_connect_error()
resetting isert_conn->cm_id = NULL during a failed login attempt.
As per Sagi, we will always see the completion of all recv wrs posted
on the qp (given that we assigned a ->done handler), this is a FLUSH
error completion, we just don't get to verify that because we deref
NULL before.
The issue here, was the assumption that dereferencing the connection
cm_id is always safe, which is not true since:
commit 4a579da2586bd3b79b025947ea24ede2bbfede62
Author: Sagi Grimberg <sagig@mellanox.com>
Date: Sun Mar 29 15:52:04 2015 +0300
iser-target: Fix possible deadlock in RDMA_CM connection error
As I see it, we have a direct reference to the isert_device from
isert_conn which is the one-liner fix that we actually need like
we do in isert_rdma_read_done() and isert_rdma_write_done().
Reported-by: Andrea Righi <righi.andrea@gmail.com>
Tested-by: Andrea Righi <righi.andrea@gmail.com>
commit 1d6ef276594a781686058802996e09c8550fd767 upstream.
This patch addresses a COMPARE_AND_WRITE se_device->caw_sem leak,
that would be triggered during normal se_cmd shutdown or abort
via __transport_wait_for_tasks().
This would occur because target_complete_cmd() would catch this
early and do complete_all(&cmd->t_transport_stop_comp), but since
target_complete_ok_work() or target_complete_failure_work() are
never called to invoke se_cmd->transport_complete_callback(),
the COMPARE_AND_WRITE specific callbacks never release caw_sem.
To address this special case, go ahead and release caw_sem
directly from target_complete_cmd().
(Remove '&& success' from check, to release caw_sem regardless
of scsi_status - nab)
Signed-off-by: Jiang Yi <jiangyilism@gmail.com>
commit bebb2a473a43c8f84a8210687d1cbdde503046d7 upstream.
In function addr_resolve() the namespace is a required input parameter
and not an output. It is passed later for searching the routing table
and device addresses. Also, it shouldn't be copied back to the caller.
Fixes: 565edd1d5555 ('IB/addr: Pass network namespace as a parameter')
Signed-off-by: Moni Shoua <monis@mellanox.com>
Signed-off-by: Leon Romanovsky <leon@kernel.org>
commit c8c16d3bae967f1c7af541e8d016e5c51e4f010a upstream.
Under heavy iser target(scst) start/stop stress during login/logout
on iser intitiator side happened trace call provided below.
The function iscsi_iser_slave_alloc iser_conn pointer could be NULL,
due to the fact that function iscsi_iser_conn_stop can be called before
and free iser connection. Let's protect that flow by introducing global mutex.
BUG: unable to handle kernel paging request at 0000000000001018
IP: [<ffffffffc0426f7e>] iscsi_iser_slave_alloc+0x1e/0x50 [ib_iser]
Call Trace:
? scsi_alloc_sdev+0x242/0x300
scsi_probe_and_add_lun+0x9e1/0xea0
? kfree_const+0x21/0x30
? kobject_set_name_vargs+0x76/0x90
? __pm_runtime_resume+0x5b/0x70
__scsi_scan_target+0xf6/0x250
scsi_scan_target+0xea/0x100
iscsi_user_scan_session.part.13+0x101/0x130 [scsi_transport_iscsi]
? iscsi_user_scan_session.part.13+0x130/0x130 [scsi_transport_iscsi]
iscsi_user_scan_session+0x1e/0x30 [scsi_transport_iscsi]
device_for_each_child+0x50/0x90
iscsi_user_scan+0x44/0x60 [scsi_transport_iscsi]
store_scan+0xa8/0x100
? common_file_perm+0x5d/0x1c0
dev_attr_store+0x18/0x30
sysfs_kf_write+0x37/0x40
kernfs_fop_write+0x12c/0x1c0
__vfs_write+0x18/0x40
vfs_write+0xb5/0x1a0
SyS_write+0x55/0xc0
Fixes: 318d311e8f01 ("iser: Accept arbitrary sg lists mapping if the device supports it")
Signed-off-by: Vladimir Neyelov <vladimirn@mellanox.com>
Reviewed-by: Sagi Grimberg <sagi@grimbeg.me>
commit 340d394a789518018f834ff70f7534fc463d3226 upstream.
The driver checks port->exists twice in i8042_interrupt(), first when
trying to assign temporary "serio" variable, and second time when deciding
whether it should call serio_interrupt(). The value of port->exists may
change between the 2 checks, and we may end up calling serio_interrupt()
with a NULL pointer:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000050
IP: [<ffffffff8150feaf>] _spin_lock_irqsave+0x1f/0x40
PGD 0
Oops: 0002 [#1] SMP
last sysfs file:
CPU 0
Modules linked in:
Pid: 1, comm: swapper Not tainted 2.6.32-358.el6.x86_64 #1 QEMU Standard PC (i440FX + PIIX, 1996)
RIP: 0010:[<ffffffff8150feaf>] [<ffffffff8150feaf>] _spin_lock_irqsave+0x1f/0x40
RSP: 0018:ffff880028203cc0 EFLAGS: 00010082
RAX: 0000000000010000 RBX: 0000000000000000 RCX: 0000000000000000
RDX: 0000000000000282 RSI: 0000000000000098 RDI: 0000000000000050
RBP: ffff880028203cc0 R08: ffff88013e79c000 R09: ffff880028203ee0
R10: 0000000000000298 R11: 0000000000000282 R12: 0000000000000050
R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000098
FS: 0000000000000000(0000) GS:ffff880028200000(0000) knlGS:0000000000000000
CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b
CR2: 0000000000000050 CR3: 0000000001a85000 CR4: 00000000001407f0
Process swapper (pid: 1, threadinfo ffff88013e79c000, task ffff88013e79b500)
Stack:
ffff880028203d00 ffffffff813de186 ffffffffffffff02 0000000000000000
<d> 0000000000000000 0000000000000000 0000000000000000 0000000000000098
<d> ffff880028203d70 ffffffff813e0162 ffff880028203d20 ffffffff8103b8ac
Call Trace:
<IRQ>
[<ffffffff813de186>] serio_interrupt+0x36/0xa0
[<ffffffff813e0162>] i8042_interrupt+0x132/0x3a0
[<ffffffff8103b8ac>] ? kvm_clock_read+0x1c/0x20
[<ffffffff8103b8b9>] ? kvm_clock_get_cycles+0x9/0x10
[<ffffffff810e1640>] handle_IRQ_event+0x60/0x170
[<ffffffff8103b154>] ? kvm_guest_apic_eoi_write+0x44/0x50
[<ffffffff810e3d8e>] handle_edge_irq+0xde/0x180
[<ffffffff8100de89>] handle_irq+0x49/0xa0
[<ffffffff81516c8c>] do_IRQ+0x6c/0xf0
[<ffffffff8100b9d3>] ret_from_intr+0x0/0x11
[<ffffffff81076f63>] ? __do_softirq+0x73/0x1e0
[<ffffffff8109b75b>] ? hrtimer_interrupt+0x14b/0x260
[<ffffffff8100c1cc>] ? call_softirq+0x1c/0x30
[<ffffffff8100de05>] ? do_softirq+0x65/0xa0
[<ffffffff81076d95>] ? irq_exit+0x85/0x90
[<ffffffff81516d80>] ? smp_apic_timer_interrupt+0x70/0x9b
[<ffffffff8100bb93>] ? apic_timer_interrupt+0x13/0x20
To avoid the issue let's change the second check to test whether serio is
NULL or not.
Also, let's take i8042_lock in i8042_start() and i8042_stop() instead of
trying to be overly smart and using memory barriers.
Signed-off-by: Chen Hong <chenhong3@huawei.com>
[dtor: take lock in i8042_start()/i8042_stop()]
commit 9c40f956ce9b331493347d1b3cb7e384f7dc0581 upstream.
On Lenovo ThinkPad X1 Carbon - the 5th Generation, enabling an earlier
EC event freezing timing causes acpitz-virtual-0 to report a stuck
48C temparature. And with EC firmware revisioned as 1.14, without
reverting back to old EC event freezing timing, the fan still blows
up after a system resume.
This reverts the culprit change so that the regression can be fixed
without upgrading the EC firmware.
Fixes: d30283057ecd (ACPI / EC: Enable event freeze mode to improve event handling)
Link: https://bugzilla.kernel.org/show_bug.cgi?id=191181#c168
Tested-by: Damjan Georgievski <gdamjan@gmail.com>
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
commit 662591461c4b9a1e3b9b159dbf37648a585ebaae upstream.
According to bug reports, although the busy polling mode can make
noirq stages execute faster, it causes abnormal fan blowing up after
system resume (see the first link below for a video demonstration)
on Lenovo ThinkPad X1 Carbon - the 5th Generation. The problem can
be fixed by upgrading the EC firmware on that machine.
However, many reporters confirm that the problem can be fixed by
stopping busy polling during suspend/resume and for some of them
upgrading the EC firmware is not an option.
For this reason, drop the noirq stage hooks from the EC driver
to fix the regression.
Fixes: c3a696b6e8f8 (ACPI / EC: Use busy polling mode when GPE is not enabled)
Link: https://youtu.be/9NQ9x-Jm99Q
Link: https://bugzilla.kernel.org/show_bug.cgi?id=196129
Reported-by: Andreas Lindhe <andreas@lindhe.io>
Tested-by: Gjorgji Jankovski <j.gjorgji@gmail.com>
Tested-by: Fernando Chaves <nanochaves@gmail.com>
Tested-by: Tomislav Ivek <tomislav.ivek@gmail.com>
Tested-by: Denis P. <theoriginal.skullburner@gmail.com>
commit 5e599d73c1c1816af07f94ddba879499aa39b43c upstream.
This patch improves the way the RDMA IB signalling is done by using atomic
operations for the signalling variable. This avoids race conditions on
sig_count.
The signalling interval changes slightly and is now the largest power of
two not larger than queue depth / 2.
ilog() usage idea by Bart Van Assche.
Signed-off-by: Marta Rybczynska <marta.rybczynska@kalray.eu>
commit 5d6dee80a1e94cc284d03e06d930e60e8d3ecf7d upstream.
At the point where the kvm-vfio pseudo device wants to release its
vfio group reference, we can't always acquire a new reference to make
that happen. The group can be in a state where we wouldn't allow a
new reference to be added. This new helper function allows a caller
to match a file to a group to facilitate this. Given a file and
group, report if they match. Thus the caller needs to already have a
group reference to match to the file. This allows the deletion of a
group without acquiring a new reference.
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
Reviewed-by: Eric Auger <eric.auger@redhat.com>
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
Tested-by: Eric Auger <eric.auger@redhat.com>
commit 811642d8d8a82c0cce8dc2debfdaf23c5a144839 upstream.
If vfio_iommu_group_notifier() acquires a group reference and that
reference becomes the last reference to the group, then vfio_group_put
introduces a deadlock code path where we're trying to unregister from
the iommu notifier chain from within a callout of that chain. Use a
work_struct to release this reference asynchronously.
commit 8046e1955465e3f24e9154d0f2a2e0a8e3f8dccf upstream.
We unref the man->move fence in ttm_bo_clean_mm() and then call
ttm_bo_force_list_clean() which waits on it, except the refcount is now
zero so a warning is generated (or worse):
[149492.279301] refcount_t: increment on 0; use-after-free.
[149492.279309] ------------[ cut here ]------------
[149492.279315] WARNING: CPU: 3 PID: 18726 at lib/refcount.c:150 refcount_inc+0x2b/0x30
[149492.279315] Modules linked in: vhost_net vhost tun x86_pkg_temp_thermal crc32_pclmul ghash_clmulni_intel efivarfs amdgpu(
-) i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ttm drm
[149492.279326] CPU: 3 PID: 18726 Comm: rmmod Not tainted 4.12.0-rc5-drm-next-4.13-ttmpatch+ #1
[149492.279326] Hardware name: Gigabyte Technology Co., Ltd. Z97X-UD3H-BK/Z97X-UD3H-BK-CF, BIOS F6 06/17/2014
[149492.279327] task: ffff8804ddfedcc0 task.stack: ffffc90008d20000
[149492.279329] RIP: 0010:refcount_inc+0x2b/0x30
[149492.279330] RSP: 0018:ffffc90008d23c30 EFLAGS: 00010286
[149492.279331] RAX: 000000000000002b RBX: 0000000000000170 RCX: 0000000000000000
[149492.279331] RDX: 0000000000000000 RSI: ffff88051ecccbe8 RDI: ffff88051ecccbe8
[149492.279332] RBP: ffffc90008d23c30 R08: 0000000000000001 R09: 00000000000003ee
[149492.279333] R10: ffffc90008d23bb0 R11: 00000000000003ee R12: ffff88043aaac960
[149492.279333] R13: ffff8805005e28a8 R14: 0000000000000002 R15: ffff88050115e178
[149492.279334] FS: 00007fc540168700(0000) GS:ffff88051ecc0000(0000) knlGS:0000000000000000
[149492.279335] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[149492.279336] CR2: 00007fc3e8654140 CR3: 000000027ba77000 CR4: 00000000001426e0
[149492.279337] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[149492.279337] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
[149492.279338] Call Trace:
[149492.279345] ttm_bo_force_list_clean+0xb9/0x110 [ttm]
[149492.279348] ttm_bo_clean_mm+0x7a/0xe0 [ttm]
[149492.279375] amdgpu_ttm_fini+0xc9/0x1f0 [amdgpu]
[149492.279392] amdgpu_bo_fini+0x12/0x40 [amdgpu]
[149492.279415] gmc_v7_0_sw_fini+0x32/0x40 [amdgpu]
[149492.279430] amdgpu_fini+0x2c9/0x490 [amdgpu]
[149492.279445] amdgpu_device_fini+0x58/0x1b0 [amdgpu]
[149492.279461] amdgpu_driver_unload_kms+0x4f/0xa0 [amdgpu]
[149492.279470] drm_dev_unregister+0x3c/0xe0 [drm]
[149492.279485] amdgpu_pci_remove+0x19/0x30 [amdgpu]
[149492.279487] pci_device_remove+0x39/0xc0
[149492.279490] device_release_driver_internal+0x155/0x210
[149492.279491] driver_detach+0x38/0x70
[149492.279493] bus_remove_driver+0x4c/0xa0
[149492.279494] driver_unregister+0x2c/0x40
[149492.279496] pci_unregister_driver+0x21/0x90
[149492.279520] amdgpu_exit+0x15/0x406 [amdgpu]
[149492.279523] SyS_delete_module+0x1a8/0x270
[149492.279525] ? exit_to_usermode_loop+0x92/0xa0
[149492.279528] entry_SYSCALL_64_fastpath+0x13/0x94
[149492.279529] RIP: 0033:0x7fc53fcb68e7
[149492.279529] RSP: 002b:00007ffcfbfaabb8 EFLAGS: 00000206 ORIG_RAX: 00000000000000b0
[149492.279531] RAX: ffffffffffffffda RBX: 0000563117adb200 RCX: 00007fc53fcb68e7
[149492.279531] RDX: 000000000000000a RSI: 0000000000000800 RDI: 0000563117adb268
[149492.279532] RBP: 0000000000000003 R08: 0000000000000000 R09: 1999999999999999
[149492.279533] R10: 0000000000000883 R11: 0000000000000206 R12: 00007ffcfbfa9ba0
[149492.279533] R13: 0000000000000000 R14: 0000000000000000 R15: 0000563117adb200
[149492.279534] Code: 55 48 89 e5 e8 77 fe ff ff 84 c0 74 02 5d c3 80 3d 40 f2 a4 00 00 75 f5 48 c7 c7 20 3c ca 81 c6 05 30 f2 a4 00 01 e8 91 f0 d7 ff <0f> ff 5d c3 90 55 48 89 fe bf 01 00 00 00 48 89 e5 e8 9f fe ff
[149492.279557] ---[ end trace 2d4e0ffcb66a1016 ]---
Unref the fence *after* waiting for it.
v2: Set man->move to NULL after dropping the last ref (Christian König)
Fixes: aff98ba1fdb8 (drm/ttm: wait for eviction in ttm_bo_force_list_clean)
Signed-off-by: John Brooks <john@fastquake.com>
Reviewed-by: Christian König <christian.koenig@amd.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 4495ec6d770e1bca7a04e93ac453ab6720c56c5d upstream.
When getting flags, a response to a different message would
result in a deadlock because of a missing unlock. Add that
unlock and a comment. Found by static analysis.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Corey Minyard <cminyard@mvista.com>
commit cdea46566bb21ce309725a024208322a409055cc upstream.
A vendor with a system having more than 128 CPUs occasionally encounters
the following crash during shutdown. This is not an easily reproduceable
event, but the vendor was able to provide the following analysis of the
crash, which exhibits the same footprint each time.
crash> bt
PID: 0 TASK: ffff88017c70ce70 CPU: 5 COMMAND: "swapper/5"
#0 [ffff88085c143ac8] machine_kexec at ffffffff81059c8b
#1 [ffff88085c143b28] __crash_kexec at ffffffff811052e2
#2 [ffff88085c143bf8] crash_kexec at ffffffff811053d0
#3 [ffff88085c143c10] oops_end at ffffffff8168ef88
#4 [ffff88085c143c38] no_context at ffffffff8167ebb3
#5 [ffff88085c143c88] __bad_area_nosemaphore at ffffffff8167ec49
#6 [ffff88085c143cd0] bad_area_nosemaphore at ffffffff8167edb3
#7 [ffff88085c143ce0] __do_page_fault at ffffffff81691d1e
#8 [ffff88085c143d40] do_page_fault at ffffffff81691ec5
#9 [ffff88085c143d70] page_fault at ffffffff8168e188
[exception RIP: unknown or invalid address]
RIP: ffffffffa053c800 RSP: ffff88085c143e28 RFLAGS: 00010206
RAX: ffff88017c72bfd8 RBX: ffff88017a8dc000 RCX: ffff8810588b5ac8
RDX: ffff8810588b5a00 RSI: ffffffffa053c800 RDI: ffff8810588b5a00
RBP: ffff88085c143e58 R8: ffff88017c70d408 R9: ffff88017a8dc000
R10: 0000000000000002 R11: ffff88085c143da0 R12: ffff8810588b5ac8
R13: 0000000000000100 R14: ffffffffa053c800 R15: ffff8810588b5a00
ORIG_RAX: ffffffffffffffff CS: 0010 SS: 0018
<IRQ stack>
[exception RIP: cpuidle_enter_state+82]
RIP: ffffffff81514192 RSP: ffff88017c72be50 RFLAGS: 00000202
RAX: 0000001e4c3c6f16 RBX: 000000000000f8a0 RCX: 0000000000000018
RDX: 0000000225c17d03 RSI: ffff88017c72bfd8 RDI: 0000001e4c3c6f16
RBP: ffff88017c72be78 R8: 000000000000237e R9: 0000000000000018
R10: 0000000000002494 R11: 0000000000000001 R12: ffff88017c72be20
R13: ffff88085c14f8e0 R14: 0000000000000082 R15: 0000001e4c3bb400
ORIG_RAX: ffffffffffffff10 CS: 0010 SS: 0018
This is the corresponding stack trace
It has crashed because the area pointed with RIP extracted from timer
element is already removed during a shutdown process.
The function is smi_timeout().
And we think ffff8810588b5a00 in RDX is a parameter struct smi_info
crash> rd ffff8810588b5a00 20
ffff8810588b5a00: ffff8810588b6000 0000000000000000 .`.X............
ffff8810588b5a10: ffff880853264400 ffffffffa05417e0 .D&S......T.....
ffff8810588b5a20: 24a024a000000000 0000000000000000 .....$.$........
ffff8810588b5a30: 0000000000000000 0000000000000000 ................
ffff8810588b5a40: ffffffffa053a040 ffffffffa053a060 @.S.....`.S.....
ffff8810588b5a50: 0000000000000000 0000000100000001 ................
ffff8810588b5a60: 0000000000000000 0000000000000e00 ................
ffff8810588b5a70: ffffffffa053a580 ffffffffa053a6e0 ..S.......S.....
ffff8810588b5a80: ffffffffa053a4a0 ffffffffa053a250 ..S.....P.S.....
ffff8810588b5a90: 0000000500000002 0000000000000000 ................
Unfortunately the top of this area is already detroyed by someone.
But because of two reasonns we think this is struct smi_info
1) The address included in between ffff8810588b5a70 and ffff8810588b5a80:
are inside of ipmi_si_intf.c see crash> module ffff88085779d2c0
2) We've found the area which point this.
It is offset 0x68 of ffff880859df4000
crash> rd ffff880859df4000 100
ffff880859df4000: 0000000000000000 0000000000000001 ................
ffff880859df4010: ffffffffa0535290 dead000000000200 .RS.............
ffff880859df4020: ffff880859df4020 ffff880859df4020 @.Y.... @.Y....
ffff880859df4030: 0000000000000002 0000000000100010 ................
ffff880859df4040: ffff880859df4040 ffff880859df4040 @@.Y....@@.Y....
ffff880859df4050: 0000000000000000 0000000000000000 ................
ffff880859df4060: 0000000000000000 ffff8810588b5a00 .........Z.X....
ffff880859df4070: 0000000000000001 ffff880859df4078 ........x@.Y....
If we regards it as struct ipmi_smi in shutdown process
it looks consistent.
The remedy for this apparent race is affixed below.
Signed-off-by: Tony Camuso <tcamuso@redhat.com>
This was first introduced in 7ea0ed2b5be817 ipmi: Make the
message handler easier to use for SMI interfaces
where some code was moved outside of the rcu_read_lock()
and the lock was not added.
commit 564d8a2cf3abf16575af48bdc3e86e92ee8a617d upstream.
The late 2009, 27 inch Apple iMac10,1 has an
internal eDP display and an external Mini-
Displayport output, driven by a DCE-3.2, RV730
Radeon Mobility HD-4670.
The machine worked fine in a dual-display setup
with eDP panel + externally connected HDMI
or DVI-D digital display sink, connected via
MiniDP to DVI or HDMI adapter.
However, booting the machine single-display with
only eDP panel results in a completely black
display - even backlight powering off, as soon as
the radeon modesetting driver loads.
This patch fixes the single dispay eDP case by
assigning encoders based on dig->linkb, similar
to DCE-4+. While this should not be generally
necessary (Alex: "...atom on normal boards
should be able to handle any mapping."), Apple
seems to use some special routing here.
One remaining problem not solved by this patch
is that an external Minidisplayport->DP sink
does still not work on iMac10,1, whereas external
DVI and HDMI sinks continue to work.
The problem affects at least all tested kernels
since Linux 3.13 - didn't test earlier kernels, so
backporting to stable probably makes sense.
v2: With the original patch from 2016, Alex was worried it
will break other DCE3.2 systems. Use dmi_match() to
apply this special encoder assignment only for the
Apple iMac 10,1 from late 2009.
Signed-off-by: Mario Kleiner <mario.kleiner.de@gmail.com>
Cc: Alex Deucher <alexander.deucher@amd.com>
Cc: Michel Dänzer <michel.daenzer@amd.com>
commit ab03d9fe508f4e2914a8f4a9eef1b21051cacd0f upstream.
Even if the vblank period would allow it, it still seems to
be problematic on some cards.
v2: fix logic inversion (Nils)
bug: https://bugs.freedesktop.org/show_bug.cgi?id=96868
Acked-by: Christian König <christian.koenig@amd.com>
commit 9156e723301c0a7a7def4cde820e018ce791b842 upstream.
If you initiate a read that is out of the VRAM address space return
ENXIO instead of 0.
Reads that begin below that point will read upto the VRAM limit as
before.
Signed-off-by: Tom St Denis <tom.stdenis@amd.com>
commit b5d27718f38843a74552e9a93d32e2391fd3999f upstream.
The raid5 md device is created by the disks which we don't use the total size. For example,
the size of the device is 5G and it just uses 3G of the devices to create one raid5 device.
Then change the chunksize and wait reshape to finish. After reshape finishing stop the raid
and assemble it again. It fails.
mdadm -CR /dev/md0 -l5 -n3 /dev/loop[0-2] --size=3G --chunk=32 --assume-clean
mdadm /dev/md0 --grow --chunk=64
mdadm -S /dev/md0
mdadm -As
The error messages:
[197519.814302] md: loop1 does not have a valid v1.2 superblock, not importing!
[197519.821686] md: md_import_device returned -22
After reshape the data offset is changed. It selects backwards direction in this condition.
In function super_1_load it compares the available space of the underlying device with
sb->data_size. The new data offset gets bigger after reshape. So super_1_load returns -EINVAL.
rdev->sectors is updated in md_finish_reshape. Then sb->data_size is set in super_1_sync based
on rdev->sectors. So add md_finish_reshape in end_reshape.
Signed-off-by: Xiao Ni <xni@redhat.com>
Acked-by: Guoqing Jiang <gqjiang@suse.com>
Signed-off-by: Shaohua Li <shli@fb.com>
commit 4e3f0701f25ab194c5362576b1146a1e6cc6c2e7 upstream.
__add_badblock_range() does not account sector alignment when
it sets 'num_sectors'. Therefore, an ARS error record range
spanning across two sectors is set to a single sector length,
which leaves the 2nd sector unprotected.
Change __add_badblock_range() to set 'num_sectors' properly.
Fixes: 0caeef63e6d2 ("libnvdimm: Add a poison list and export badblocks")
Signed-off-by: Toshi Kani <toshi.kani@hpe.com>
commit c13c43d54f2c6a3be1c675766778ac1ad8dfbfcc upstream.
btt_rw_page was not propagating errors frm btt_do_bvec, resulting in any
IO errors via the rw_page path going unnoticed. the pmem driver recently
fixed this in e10624f pmem: fail io-requests to known bad blocks
but same problem in BTT went neglected.
Fixes: 5212e11fde4d ("nd_btt: atomic sector updates")
Cc: Toshi Kani <toshi.kani@hpe.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Jeff Moyer <jmoyer@redhat.com>
Signed-off-by: Vishal Verma <vishal.l.verma@intel.com>
commit 4e0973a918b9a42e217093f078e04a61e5dd95a5 upstream.
Setting initial standard at the top of cx8800_initdev would cause the
first call to cx88_set_tvnorm() to return without programming any
registers (leaving the driver saying it's set to NTSC but the hardware
isn't programmed). Even worse, any subsequent attempt to explicitly
set it to NTSC-M will return success but actually fail to program the
underlying registers unless first changing the standard to something
other than NTSC-M.
Set the initial standard later in the process, and make sure the field
is zero at the beginning to ensure that the call always goes through.
This regression was introduced in the following commit:
commit ccd6f1d488e7 ("[media] cx88: move width, height and field to core
struct")
Author: Hans Verkuil <hans.verkuil@cisco.com>
[media] cx88: move width, height and field to core struct
Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
commit f9c79bc05a2a91f4fba8bfd653579e066714b1ec upstream.
The function flush_signals clears all pending signals for the process. It
may be used by kernel threads when we need to prepare a kernel thread for
responding to signals. However using this function for an userspaces
processes is incorrect - clearing signals without the program expecting it
can cause misbehavior.
The raid1 and raid5 code uses flush_signals in its request routine because
it wants to prepare for an interruptible wait. This patch drops
flush_signals and uses sigprocmask instead to block all signals (including
SIGKILL) around the schedule() call. The signals are not lost, but the
schedule() call won't respond to them.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Acked-by: NeilBrown <neilb@suse.com>
commit b8b9c974afee685789fcbb191b52d1790be3608c upstream.
A gadget driver will not disable eps immediately when ->disconnect()
is called. But, since this driver assumes all eps stop after
the ->disconnect(), unexpected behavior happens (especially in system
suspend).
So, this patch disables all eps in usbhsg_try_stop(). After disabling
eps by renesas_usbhs driver, since some functions will be called by
both a gadget and renesas_usbhs driver, renesas_usbhs driver should
protect uep->pipe. To protect uep->pipe easily, this patch adds a new
lock in struct usbhsg_uep.
Fixes: 2f98382dc ("usb: renesas_usbhs: Add Renesas USBHS Gadget")
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
commit 59a0879a0e17b2e43ecdc5e3299da85b8410d7ce upstream.
This patch fixes an issue that some registers may be not initialized
after resume if the USBHSF_RUNTIME_PWCTRL is not set. Otherwise,
if a cable is not connected, the driver will not enable INTENB0.VBSE
after resume. And then, the driver cannot detect the VBUS.
Fixes: ca8a282a5373 ("usb: gadget: renesas_usbhs: add suspend/resume support")
commit fe855789d605590e57f9cd968d85ecce46f5c3fd upstream.
Add device-id entry for DATECS FP-2000 fiscal printer needing the
NO_UNION_NORMAL quirk.
Reported-by: Anton Avramov <lukav@lukav.com>
Signed-off-by: Johan Hovold <johan@kernel.org>
Acked-by: Oliver Neukum <oneukum@suse.com>
commit 446230f52a5bef593554510302465eabab45a372 upstream.
When us->extra is null the driver is not initialized, however, a
later call to osd200_scsi_to_ata is made that dereferences
us->extra, causing a null pointer dereference. The code
currently detects and reports that the driver is not initialized;
add a return to avoid the subsequent dereference issue in this
check.
Thanks to Alan Stern for pointing out that srb->result needs setting
to DID_ERROR << 16
Detected by CoverityScan, CID#100308 ("Dereference after null check")
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit d90b336f3f652ff0441e631a06236f785581c8f7 upstream.
The recent changes in 4.9 to mandate USB buffers be heap allocated
broke this driver, which was allocating the buffers on the stack.
This resulted in the device failing at initialization.
Introduce dedicated send/receive buffers as part of the state
structure, and add a mutex to protect access to them.
Note: we also had to tweak the API to mxl111sf_ctrl_msg to pass
the pointer to the state struct rather than the device, since
we need it inside the function to access the buffers and the
mutex. This patch adjusts the callers to match the API change.
Reported-by: Doug Lung <dlung0@gmail.com>
Cc: Michael Ira Krufky <mkrufky@linuxtv.org>
commit 9da5a1092b13468839b1a864b126cacfb72ad016 upstream.
When USB Ethernet is plugged in ASMEDIA ASM1042A xHCI host, bad
performance was manifesting in Web browser use (like download
large file such as ISO image). It is known limitation of
ASM1042A that is not compatible with driver scheduling,
As a workaround we can modify flow control handling of ASM1042A.
The register we modify is changes the behavior
[use quirk bit 28, usleep_range 40-60us, empty non-pci function -Mathias]
Signed-off-by: Jiahau Chang <Lars_chang@asmedia.com.tw>
Signed-off-by: Ian Pilcher <arequipeno@gmail.com>
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
commit 4b895868bb2da60a386a17cde3bf9ecbc70c79f4 upstream.
This off by one in stream_id indexing caused NULL pointer dereference and
soft lockup on machines with USB attached SCSI devices connected to a
hotpluggable xhci controller.
The code that cleans up pending URBs for dead hosts tried to dereference
a stream ring at the invalid stream_id 0.
ep->stream_info->stream_rings[0] doesn't point to a ring.
Start looping stream_id from 1 like in all the other places in the driver,
and check that the ring exists before trying to kill URBs on it.
Reported-by: rocko r <rockorequin@gmail.com>
commit a54408d0a004757789863d74e29c2297edae0b4d upstream.
A uncleared PLC (port link change) bit will prevent furuther port event
interrupts for that port. Leaving it uncleared caused get_port_status()
to timeout after 20000ms while waiting to get the final port event
interrupt for resume -> U0 state change.
This is a targeted fix for a specific case where we get a port resume event
racing with xhci resume. The port event interrupt handler notices xHC is
not yet running and bails out early, leaving PLC uncleared.
The whole xhci port resuming needs more attention, but while working on it
it anyways makes sense to always ensure PLC is cleared in get_port_status
before setting a new link state and waiting for its completion.
commit e60514bd4485c0c7c5a7cf779b200ce0b95c70d6 upstream.
Currently we saw a lot of "No irq handler" errors during hibernation, which
caused the system hang finally:
ata4.00: qc timeout (cmd 0xec)
ata4.00: failed to IDENTIFY (I/O error, err_mask=0x4)
ata4.00: revalidation failed (errno=-5)
ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
do_IRQ: 31.151 No irq handler for vector
According to above logs, there is an interrupt triggered and it is
dispatched to CPU31 with a vector number 151, but there is no handler for
it, thus this IRQ will not get acked and will cause an IRQ flood which
kills the system. To be more specific, the 31.151 is an interrupt from the
AHCI host controller.
After some investigation, the reason why this issue is triggered is because
the thaw_noirq() function does not restore the MSI/MSI-X settings across
hibernation.
The scenario is illustrated below:
1. Before hibernation, IRQ 34 is the handler for the AHCI device, which
is bound to CPU31.
2. Hibernation starts, the AHCI device is put into low power state.
3. All the nonboot CPUs are put offline, so IRQ 34 has to be migrated to
the last alive one - CPU0.
4. After the snapshot has been created, all the nonboot CPUs are brought
up again; IRQ 34 remains bound to CPU0.
5. AHCI devices are put into D0.
6. The snapshot is written to the disk.
The issue is triggered in step 6. The AHCI interrupt should be delivered
to CPU0, however it is delivered to the original CPU31 instead, which
causes the "No irq handler" issue.
Ying Huang has provided a clue that, in step 3 it is possible that writing
to the register might not take effect as the PCI devices have been
suspended.
In step 3, the IRQ 34 affinity should be modified from CPU31 to CPU0, but
in fact it is not. In __pci_write_msi_msg(), if the device is already in
low power state, the low level MSI message entry will not be updated but
cached. During the device restore process after a normal suspend/resume,
pci_restore_msi_state() writes the cached MSI back to the hardware.
But this is not the case for hibernation. pci_restore_msi_state() is not
currently called in pci_pm_thaw_noirq(), although pci_save_state() has
saved the necessary PCI cached information in pci_pm_freeze_noirq().
Restore the PCI status for the device during hibernation. Otherwise the
status might be lost across hibernation (for example, settings for MSI,
MSI-X, ATS, ACS, IOV, etc.), which might cause problems during hibernation.
Suggested-by: Ying Huang <ying.huang@intel.com>
Suggested-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Signed-off-by: Chen Yu <yu.c.chen@intel.com>
[bhelgaas: changelog]
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Reviewed-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Cc: Len Brown <len.brown@intel.com>
Cc: Rui Zhang <rui.zhang@intel.com>
Cc: Ying Huang <ying.huang@intel.com>
commit dc8cca5ef25ac4cb0dfc37467521a759767ff361 upstream.
Rockchip's RC has two banks of registers for the root port: a normal bank
that is strictly compatible with the PCIe spec, and a privileged bank that
can be used to change RO bits of root port registers.
When probing the RC driver, we use the privileged bank to do some basic
setup work as some RO bits are hw-inited to wrong value. But we didn't
change to the normal bank after probing the driver.
This leads to a serious problem when the PME code tries to clear the PME
status by writing PCI_EXP_RTSTA_PME to the register of PCI_EXP_RTSTA. Per
PCIe 3.0 spec, section 7.8.14, the PME status bit is RW1C. So the PME code
is doing the right thing to clear the PME status but we find the RC doesn't
clear it but actually setting it to one. So finally the system trap in
pcie_pme_work_fn() as PCI_EXP_RTSTA_PME is true now forever. This issue
can be reproduced by booting kernel with pci=nomsi.
Use the normal register bank for the PCI config accessors. The privileged
bank is used only internally by this driver.
Fixes: e77f847d ("PCI: rockchip: Add Rockchip PCIe controller support")
Signed-off-by: Shawn Lin <shawn.lin@rock-chips.com>
Cc: Jeffy Chen <jeffy.chen@rock-chips.com>
Cc: Brian Norris <briannorris@chromium.org>
commit 9f4ab18ac51dc87345a9cbd2527e6acf7a0a9335 upstream.
scsiback_release_cmd() must not dereference se_cmd->se_tmr_req
because that memory is freed by target_free_cmd_mem() before
scsiback_release_cmd() is called. Fix this use-after-free by
inlining struct scsiback_tmr into struct vscsibk_pend.
Reviewed-by: Juergen Gross <jgross@suse.com>
Cc: Hannes Reinecke <hare@suse.com>
Cc: David Disseldorp <ddiss@suse.de>
Cc: xen-devel@lists.xenproject.org
commit 138d351eefb727ab9e41a3dc5f112ceb4f6e59f2 upstream.
This patch re-introduces part of a long standing login workaround that
was recently dropped by:
commit 1c99de981f30b3e7868b8d20ce5479fa1c0fea46
Author: Nicholas Bellinger <nab@linux-iscsi.org>
Date: Sun Apr 2 13:36:44 2017 -0700
iscsi-target: Drop work-around for legacy GlobalSAN initiator
Namely, the workaround for FirstBurstLength ended up being required by
Mellanox Flexboot PXE boot ROMs as reported by Robert.
So this patch re-adds the work-around for FirstBurstLength within
iscsi_check_proposer_for_optional_reply(), and makes the key optional
to respond when the initiator does not propose, nor respond to it.
Also as requested by Arun, this patch introduces a new TPG attribute
named 'login_keys_workaround' that controls the use of both the
FirstBurstLength workaround, as well as the two other existing
workarounds for gPXE iSCSI boot client.
By default, the workaround is enabled with login_keys_workaround=1,
since Mellanox FlexBoot requires it, and Arun has verified the Qlogic
MSFT initiator already proposes FirstBurstLength, so it's uneffected
by this re-adding this part of the original work-around.
Reported-by: Robert LeBlanc <robert@leblancnet.us>
Cc: Robert LeBlanc <robert@leblancnet.us>
Reviewed-by: Arun Easi <arun.easi@cavium.com>
commit f9279c968c257ee39b0d7bd2571a4d231a67bcc1 upstream.
The addition of the STARGET_REMOVE state had the side effect of
introducing a race condition that can cause a crash.
scsi_target_reap_ref_release() checks the starget->state to
see if it still in STARGET_CREATED, and if so, skips calling
transport_remove_device() and device_del(), because the starget->state
is only set to STARGET_RUNNING after scsi_target_add() has called
device_add() and transport_add_device().
However, if an rport loss occurs while a target is being scanned,
it can happen that scsi_remove_target() will be called while the
starget is still in the STARGET_CREATED state. In this case, the
starget->state will be set to STARGET_REMOVE, and as a result,
scsi_target_reap_ref_release() will take the wrong path. The end
result is a panic:
[ 1255.356653] Oops: 0000 [#1] SMP
[ 1255.360154] Modules linked in: x86_pkg_temp_thermal kvm_intel kvm irqbypass crc32c_intel ghash_clmulni_i
[ 1255.393234] CPU: 5 PID: 149 Comm: kworker/u96:4 Tainted: G W 4.11.0+ #8
[ 1255.401879] Hardware name: Dell Inc. PowerEdge R320/08VT7V, BIOS 2.0.22 11/19/2013
[ 1255.410327] Workqueue: scsi_wq_6 fc_scsi_scan_rport [scsi_transport_fc]
[ 1255.417720] task: ffff88060ca8c8c0 task.stack: ffffc900048a8000
[ 1255.424331] RIP: 0010:kernfs_find_ns+0x13/0xc0
[ 1255.429287] RSP: 0018:ffffc900048abbf0 EFLAGS: 00010246
[ 1255.435123] RAX: 0000000000000000 RBX: 0000000000000000 RCX: 0000000000000000
[ 1255.443083] RDX: 0000000000000000 RSI: ffffffff8188d659 RDI: 0000000000000000
[ 1255.451043] RBP: ffffc900048abc10 R08: 0000000000000000 R09: 0000012433fe0025
[ 1255.459005] R10: 0000000025e5a4b5 R11: 0000000025e5a4b5 R12: ffffffff8188d659
[ 1255.466972] R13: 0000000000000000 R14: ffff8805f55e5088 R15: 0000000000000000
[ 1255.474931] FS: 0000000000000000(0000) GS:ffff880616b40000(0000) knlGS:0000000000000000
[ 1255.483959] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 1255.490370] CR2: 0000000000000068 CR3: 0000000001c09000 CR4: 00000000000406e0
[ 1255.498332] Call Trace:
[ 1255.501058] kernfs_find_and_get_ns+0x31/0x60
[ 1255.505916] sysfs_unmerge_group+0x1d/0x60
[ 1255.510498] dpm_sysfs_remove+0x22/0x60
[ 1255.514783] device_del+0xf4/0x2e0
[ 1255.518577] ? device_remove_file+0x19/0x20
[ 1255.523241] attribute_container_class_device_del+0x1a/0x20
[ 1255.529457] transport_remove_classdev+0x4e/0x60
[ 1255.534607] ? transport_add_class_device+0x40/0x40
[ 1255.540046] attribute_container_device_trigger+0xb0/0xc0
[ 1255.546069] transport_remove_device+0x15/0x20
[ 1255.551025] scsi_target_reap_ref_release+0x25/0x40
[ 1255.556467] scsi_target_reap+0x2e/0x40
[ 1255.560744] __scsi_scan_target+0xaa/0x5b0
[ 1255.565312] scsi_scan_target+0xec/0x100
[ 1255.569689] fc_scsi_scan_rport+0xb1/0xc0 [scsi_transport_fc]
[ 1255.576099] process_one_work+0x14b/0x390
[ 1255.580569] worker_thread+0x4b/0x390
[ 1255.584651] kthread+0x109/0x140
[ 1255.588251] ? rescuer_thread+0x330/0x330
[ 1255.592730] ? kthread_park+0x60/0x60
[ 1255.596815] ret_from_fork+0x29/0x40
[ 1255.600801] Code: 24 08 48 83 42 40 01 5b 41 5c 5d c3 66 66 66 2e 0f 1f 84 00 00 00 00 00 66 66 66 66 90
[ 1255.621876] RIP: kernfs_find_ns+0x13/0xc0 RSP: ffffc900048abbf0
[ 1255.628479] CR2: 0000000000000068
[ 1255.632756] ---[ end trace 34a69ba0477d036f ]---
Fix this by adding another scsi_target state STARGET_CREATED_REMOVE
to distinguish this case.
Fixes: f05795d3d771 ("scsi: Add intermediate STARGET_REMOVE state to scsi_target_state")
Reported-by: David Jeffery <djeffery@redhat.com>
Signed-off-by: Ewan D. Milne <emilne@redhat.com>
Reviewed-by: Laurence Oberman <loberman@redhat.com>
Tested-by: Laurence Oberman <loberman@redhat.com>
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
commit 62e62ffd95539b9220894a7900a619e0f3ef4756 upstream.
The enclosure_add_device() function should fail if it can't create the
relevant sysfs links.
Signed-off-by: Maurizio Lombardi <mlombard@redhat.com>
Tested-by: Douglas Miller <dougmill@linux.vnet.ibm.com>
Acked-by: James Bottomley <jejb@linux.vnet.ibm.com>
commit a7e2d1bce4c1db471f1cbc0c4666a3112bbf0994 upstream.
of_genpd_remove_last() iterates over list of domains and removes
matching element thus it has to use safe version of list iteration.
Fixes: 17926551c98a (PM / Domains: Add support for removing nested PM domains by provider)
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
commit b556b15dc04e9b9b98790f04c21acf5e24f994b2 upstream.
of_genpd_del_provider() iterates over list of domain provides and
removes matching element thus it has to use safe version of list
iteration.
Fixes: aa42240ab254 (PM / Domains: Add generic OF-based PM domain look-up)
