Some Micrel KSZ8041NL PHY chips exhibit continous RX errors after
using the power down mode bit (0.11). If the PHY is taken out of
power down mode in a certain temperature range, the PHY enters a
weird state which leads to continously reporting RX errors. In that
state, the MAC is not able to receive or send any Ethernet frames
and the activity LED is constantly blinking. Since Linux is using
the suspend callback when the interface is taken down, ending up
in that state can easily happen during a normal startup.
Micrel confirmed the issue, caused by abnormal clock recovery when
using power down mode. Even the latest revision (A4, Revision ID
0x1513) seems to suffer that problem.
Remove the suspend/resume callback to avoid using the power down
mode completely.
(cherry picked from commit a76182f34d2963ee5dca3bc026cbddb44b19be7c)
Fix obvious typo that first return value is set but not checked.
Signed-off-by: Max Uvarov <muvarov@gmail.com>
(cherry picked from commit a0da456bbf95d2a9294799bb05c61bfb24736bb7)
(cherry picked from commit 5f0a65495d895df2be2ddd681662f877f1a05b7f)
The current reset-gpio support triggers an interrupt storm on platforms
using the maxtouch with level based interrupt. The Motorola Droid 4,
which I used for some of the tests is not affected, since it uses a edge
based interrupt.
This change avoids the interrupt storm by enabling the device while its
interrupt is disabled. Afterwards we wait 100ms. This is important for
two reasons: The device is unresponsive for some time (~22ms for
mxt224E) and the CHG (interrupt) line is not working properly for 100ms.
We don't need to wait for any following interrupts, since the following
mxt_initialize() checks for bootloader mode anyways.
This fixes a boot issue on GE PPD (watchdog kills device due to
interrupt storm) and does not cause regression on Motorola Droid 4.
Fixes: f657b00df22e ("Input: atmel_mxt_ts - add support for reset line")
Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
Reviewed-by: Pavel Machek <pavel@ucw.cz>
(cherry picked from commit ca1cd36cef00260db6b35b32d863e0c580c0488d)
(cherry picked from commit 6d7ffbea51c1f314a4435065147b36159169571f)
Missing commit 688f897ddd96 ("Merge remote-tracking branch
'linux-fslc/4.9-1.0.x-imx' into toradex_4.9-1.0.x-imx-next").
during __sdhci_read_caps
The sdhci capabilities register can be incorrect. The sdhci-caps-mask
and sdhci-caps dt properties specify which bits of the register are
incorrect and what their values should be. This patch makes the sdhci
driver use those properties to correct the caps during
__sdhci_read_caps.
During __sdhci_read_caps
Use the sdhci-caps-mask property to turn off the incorrect bits of the
sdhci register after reading them.
Use the sdhci-caps to turn on bits after using sdhci-caps-mask to turn
off the incorrect ones.
Signed-off-by: Zach Brown <zach.brown@ni.com>
Acked-by: Adrian Hunter <adrian.hunter@intel.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
(cherry picked from commit 92e0c44b92e463a47746b520ea9aa9ef154f27e7)
Forward porting of 35928d6c6a to 6e9e049fa introduced a bug for host
controllers which are not aliased in the device tree. Instead of
instantiating the driver it fails with:
sdhci-esdhc-imx 2194000.usdhc: sdhci_pltfm_init failed -12
sdhci-esdhc-imx: probe of 2194000.usdhc failed with error -12
Provide support for controlling reset pin. If this is not driven
correctly the device will be held in reset and will not respond.
Acked-by: Rob Herring <robh@kernel.org>
(cherry picked from commit f657b00df22e231da217ca0162a75db452475e8f)
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
Switch mxt_data and interrupt to resource managed allocation methods,
which cleans up the driver slightly and prepares for adding
reset GPIO support.
(cherry picked from commit 8cc8446b9b62ef954b630ed30e53bd1553e916a6)
Entry into recent versions of ARM Trusted Firmware will invalidate the CPU
branch predictor state in order to protect against aliasing attacks.
This patch exposes the PSCI "VERSION" function via psci_ops, so that it
can be invoked outside of the PSCI driver where necessary.
Acked-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
(cherry picked commit from a6df699da786079b7e2249df3f3211be7862f0e1)
Signed-off-by: Jason Liu <jason.hui.liu@nxp.com>
This reverts commit 9a4bf05126f42c2632729ab0da503021d74ed454.
With this commit the PCIe enumaration fails. A follow up commit further
addresses the issue.
Add device tree properties to influence RTS polarity and whether
the receiver is enabled during transmission (rs485-rts-active-low,
rs485-rx-during-tx).
This aligns with behavior with upstream Linux, where RTS is active
high by default (SER_RS485_RTS_AFTER_SEND) and the receiver is
disabled by default when using RS485 (SER_RS485_RX_DURING_TX).
Note that for Toradex hardware both properties are required, hence
using RS-485 on Toradex Carrier Boards requires the following
properties being specified in the device tree:
linux,rs485-enabled-at-boot-time;
rs485-rts-active-low;
rs485-rx-during-tx;
Signed-off-by: Andri Schmidt <a.schmidt@scewo.ch>
pci-imx6.c:303:20: warning: unused variable 'pp' [-Wunused-variable]
SDHCI falls back to fixed sampling if there is an error during tuning.
However it also reports an error unless there is periodic re-tuning.
That is not the best option because:
a) there is a reasonable chance that fixed sampling will work, especially
at room temperature.
b) re-tuning will be done again anyway if there are CRC errors.
Change to return no error always when falling back to fixed sampling.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
(cherry picked from commit 0760c355525c08dd598e86edb2a310688ac8af4c)
This seems to limit possible baud rates due to lower input clock.
Since Toradex modules do not use UART5/6 as console, do not set
clock explicitly.
This reverts commit 4f447cb8bccb1d40973e46478d7b11aa61961c90.
Since Toradex modules do not use UART3 as console, do not set
clock explicitly.
This reverts commit 89869792e2f59c81354f9a53280c4eb6e95f4a9a.
Add support to allow configuring the display timings via
kernel command line.
e.g.:
video=mxsfb:800x480M-16@60,pixclockpol=1,outputen=1
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
(cherry picked from commit 22db6beb45cba5a67cab9e9a55cd60d7471591d9)
drivers/video/fbdev/mxsfb.c
This was seen in code inspection.
While at it, fix error text.
Some device make use of the OCOTP via syscon. While the OCOTP node
specifies a clock, in newer kernels the access via syscon does not
enable the clock! During the main boot phase this is not usually a
problem since the clock is initially on. However, after unused
clocks get disabled, any access leads to a freeze. This has been
observed when the i.MX Thermal driver probe has been deferred: The
driver tried to read the calibration data from OCOTP via syscon
and caused a system freeze.
In upstream Linux this has recently been resolved using the NVMEM
framework, see:
Commit ae6215576d6b ("thermal: imx: Add support for reading OCOTP
through nvmem")
Commit a6c856e9a8cd ("ARM: dts: imx6sx: Use nvmem-cells for tempmon")
Use a simpler work around by just adding the clock to the list of
clocks which should kept on.
The i.MX 7Solo currently does not have multiple operating points,
however, in order for the i.MX Thermal driver to successfully probe
a cpufreq device is required. Add i.MX 7Solo to the devices which
use the generic device tree cpufreq driver.
Other unsigned properties return hexadecimal values, follow this
convention when printing b_vendor_code too. Also add newlines to
the OS Descriptor support related properties, like other sysfs
files use.
Reviewed-by: Krzysztof Opasiak <k.opasiak@samsung.com>
Signed-off-by: Stefan Agner <stefan@agner.ch>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
(cherry picked from commit e800e8cbdf42c73602b90258f82a2cfe86ec53a7)
Currently qw_sign requires UTF-8 character to set, but returns UTF-16
when read. This isn't obvious when simply using cat since the null
characters are not visible, but hexdump unveils the true string:
# echo MSFT100 > os_desc/qw_sign
# hexdump -C os_desc/qw_sign
00000000 4d 00 53 00 46 00 54 00 31 00 30 00 30 00 |M.S.F.T.1.0.0.|
Make qw_sign symmetric by returning an UTF-8 string too. Also follow
common convention and add a new line at the end.
(cherry picked from commit 76180d716f91f035d9c8639497cf5459b44e1a51)
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
(cherry picked from commit df7b30b5b521fad21e682f318ee703be2144358b)
(cherry picked from commit 62785dfc6e934d8947b8367bf553dd2c81f5fb21)
drivers/pci/host/pci-imx6.c
This fixes PCIe EP device self-initialisation in case only a regular
reset EP GPIO is used as PERST# which is e.g. the case on our Ixora
carrier board by always waiting 20 milliseconds after releasing PERST#.
(cherry picked from commit 3eaf56fc694e8b960a29e0205f40380cf59f9fc9)
(cherry picked from commit 826486c65363059986fa12fa1eeb7c0e50c3af48)
If the reset gpio for a PCIe switch is invalid, but a gpio for
reseting downstream EP devices is valid no reset pulse for the EP devices is
generated.
(i.e. in the device tree reset-gpio is not defined but reset-ep-gpio is defined)
The patch fixes this.
Original patch from Juha Kokkonen, Huoltamoeletroniikka Ky
(cherry picked from commit f593ebc9921013a992c1d096bf4cbad17c1af01b)
(cherry picked from commit 8437c2f0e4fafb9a31dd260704cc6b7a22bf33f8)
(cherry picked from commit fc0d0a29ab0e6fc0de72b63fba80845cc554d543)
With the following dtb node one can define a gpio to reset
downstream endpoints.
reset-ep-gpio = <...>;
Currently the logic is 1 for reset asserted
and 0 for reset deasserted.
Some pcie switches require their downstream endpoints to be kept in reset
for an additonal millisecond after their reset has been deasserted.
(cherry picked from commit 94a60e7f645965b1e422e4e80aa8ccb9e0ec845c)
(cherry picked from commit f2bb337d37acd680404371d2530a486bfe821ce2)
(cherry picked from commit 557f0276856f1731264492ad82fe2f13e2d64831)
Return ENOTTY if no reader is using the TTY. Note that the
VirtIO transport used by RPmsg currently does not use the
return value of this callback, hence currently will not
influence operation in any way.
For some reason USDHC and USB access crashes the kernel if the
OCOTP clock is not enabled. It seems not to be software related
since there is no direct access from the USDHC/Chipidea USB
driver to the OCOTP IP. It might be that the hardware checks
the fuses to determine if the particular SoC is supposed to
let user access a certain peripheral...
(cherry picked from commit bce5146373372651052654b84cd3b773ac4d1882)
The device tree property fsl,legacy-bch-geometry was only evaluated
when nand-on-flash-bbt was also defined. This looks wrong.
In mainline (as of 4.12) fsl,legacy-bch-geometry doesn't exist,
its functionality seems to be taken over by the fsl,use-minimum-ecc
property and it is used independent of nand-on-flash-bbt.
The move of code gets also rid of the following compiler warning:
drivers/mtd/nand/gpmi-nand/gpmi-nand.c:2274:2: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
if (of_property_read_bool(this->dev->of_node,
drivers/mtd/nand/gpmi-nand/gpmi-nand.c:2278:3: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
(cherry picked from commit c8f0033be80ccb23230b6b572c328d1c02e4ad04)
POWER_ENABLE_MOCI
Poweroff failed powering off the carrier board side of things
and did not deassert POWER_ENABLE_MOCI on poweroff. Fix this.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
(cherry picked from commit 090138a21869fe2a4b1efa725e6f962ecdff86e5)
Using the mode_str passed via device tree
as default fall back, fb_find_mode fails
while finding the mode, so avoid using the
non standard mode_str passed via device tree
and use the mode_str from command line as is.
(cherry picked from commit 50e26af30f04d24f4783dae15206c5dba889fd2b)
Revert the hack for reset GPIO request failure.
(Remove the used pins from /usr/bin/gpio-export.sh)
(cherry picked from commit d826eb44e78b5103c96c3e1c28ede8ec224e5371)
Add support to enable RS485 via device tree
(cherry picked from commit b8e5d21a1351bc0e45ae1762f0799b428d9993ea)
Do not disable peripheral while entering suspend mode. Disabling
the peripheral does not allow waking up from suspend on a CAN
frame reception.
(cherry picked from commit f972815d2a4db5c93ded76bd11b660261e41f28c)
The driver currently advertise events, however, the required callback
read_event_config is not implemented. This leads to a stack trace
when trying to read the even files in sysfs:
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = 80e04000
[00000000] *pgd=10a57831, *pte=00000000, *ppte=00000000
Internal error: Oops: 80000007 [#1] SMP ARM
Modules linked in:
CPU: 0 PID: 175 Comm: cat Not tainted 4.1.39-00001-g52349f183498 #41
Hardware name: Freescale i.MX6 Quad/DualLite (Device Tree)
task: 80e4e800 ti: 80a38000 task.ti: 80a38000
PC is at 0x0
LR is at iio_ev_state_show+0x4c/0x70
pc : [<00000000>] lr : [<80613704>] psr: a0070013
sp : 80a39aa0 ip : 807f1a74 fp : 80a39ab4
r10: 00000001 r9 : 8809d000 r8 : 80e74800
r7 : 80da0c18 r6 : 807cae38 r5 : 00000000 r4 : 8809d000
r3 : 00000002 r2 : 00000000 r1 : 807f1730 r0 : 80da0c00
Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: 10c5387d Table: 10e0404a DAC: 00000015
Process cat (pid: 175, stack limit = 0x80a38210)
(cherry picked from commit b6798bb5050a786f7cdd2a47db8029fee74e36fe)
Add support to read back raw value scale. This allows to calculate
actual voltages from the raw values.
Also combine the value acquisition and implement error handling
closer the way used in other IIO ADC drivers.
(cherry picked from commit 7a751b2238383593fef0b3549fcf5a04558a0d3e)
(cherry picked from commit 051ee1a1c24058db62f10a177b1271daebbd2ebe)
After the system has been shutdown with PMIC_ON_REQ and VCC_BATT is supplied
from a battery it will never restart either by RESET or power cycle.
So use the PMIC_STBY_REQ after shutdown to switch off power rails.
arch/arm/mach-imx/pm-imx6.c
drivers/regulator/pfuze100-regulator.c
(cherry-picked from commit c8b186404065c4502b485820ad4a51515924795c)
(cherry-picked from commit ee4c5c4da3b32f65528a2d523ca4bce574dee3c5)
(cherry picked from commit 29ff2389ecf7cb4e30924c80b8d42165cf306936)
Removing the device (e.g. using unbind) leads to a NULL pointer
dereference stack trace. There is no need to manually unregister
the platform device, so remove this obsolete code. This fixes
unbinding the device e.g. using:
# echo 2-0041 > /sys/bus/i2c/drivers/stmpe-i2c/unbind
Also make sure the respective block is disabled in case we only
unbind the ADC block:
# echo stmpe-adc > /sys/bus/platform/drivers/stmpe-adc/unbind
(cherry picked from commit 091594ee53e9f6ae330f40c3528bf93f181b4cd5)
Let the M4 handle the clock frequency by itself. We also don't need
to take care to make sure clocks stay on, the per domain CCM clock
gate control registers can be used to let the CCM know that the M4
runs on that PLL:
CCM_ControlGate(CCM, ccmPllGateSysDiv2, ccmClockNeededRun);
(cherry picked from commit 98adbbaef78b8a401350a0bf27c3ddc1881ec34d)
Use force suspend/resume to trigger runtime PM when entering system
suspend.
(cherry picked from commit c6634703d092bffee980cbe5c0459074f94d9299)
suspend.
(cherry picked from commit 2df675a89358549e656592c3eb9781860e909cd4)
suspend.
(cherry picked from commit ebf45652f2e9ec2ab19831d852363deadeb6407e)
suspend.
(cherry picked from commit a2ccbd22f2b1da9b152039538fb3b5cb2cfc55c7)
Add new 'unique_id' sysfs attribute to expose SoC unique ID
(cherry picked from commit 8a098f2f1b8ae277a38ee0c5e0b974d5baa8dd01)
The keypad port (KPP) module is clocked by the IPG root clock
through clock gate CCM_CCGR170.
(cherry picked from commit 7b51b6365ebcf65b1054337a5bb0e1879397aae6)
Pushing data while there is no reader seems to lock/crash the TTY
layer in some way. Especially when a reader gets attached again,
the kernel crashes with
Unable to handle kernel paging request at virtual address 00002248
Also use tty_insert_flip_string which handels the copying and TTY
buffer resizing if necessary.
(cherry picked from commit 5aba75e2c61d4044bed21730b7c471822860fac1)
Let RPMSG_NUM_BUFS to be the number of buffers per VirtIO queue,
so that each queue (TX/RX) has 256 buffers. The change does not
affect the number of buffers. But specifing per VirtIO queue
aligns better with the way buffer sizes are specified on the
FreeRTOS side (in platform_info.c).
(cherry picked from commit 1db9a161430d3975b4b3822b91b2a14c5b8193ba)
Add a kernel parameter ("gpio-mxc.noclearirq") to disable
unconditional interrupt mask/clearing. This is useful when a
second CPU (the Cortex-M4) is accessing the same GPIO bank.
Using the same GPIO bank from the Cortex-A7 and M4 sounds risky,
but it seems to work quite well. Most registers are write only
(e.g. interrupt status register can be cleared with a single
write), which makes them safe for concurrent access. However,
sharing a single GPIO bank between two cores does not allow to
use the Resource Domain Controller. Hence for secure applications
assigning a dedicated GPIO bank is still preferable.
(cherry picked from commit 4cfa939c693b20ca213f054c1dfe5583d966beb4)
Add support for LVDS frame buffer configuration via kernel boot arguments.
Fix use of the device tree native-mode property.
(cherry picked from commit 122acb64708ac40faa8c5755624a0bcfbebcb9e8)
(cherry picked from commit 735d4f8addae71ef4a70eb16a9639bd6204fd2b9)
