commit 6b90466cfec2a2fe027187d675d8d14217c12d82 upstream.
In patch "HID: microsoft: fix invalid rdesc for 3k kbd" I fixed
support for MS 3k keyboards. However the added check using memcmp and
a compound statement breaks build on architectures where memcmp is a
macro with parameters.
hid-microsoft.c:51:18: error: macro "memcmp" passed 6 arguments, but takes just 3
On x86_64, memcmp is a function, so I did not see the error.
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
commit fcd99434fb5c137274d2e15dd2a6a7455f0f29ff upstream.
Now that netdev_rx_handler_unregister contains synchronize_net(), we need
to call it outside of bond->lock, cause it might sleep. Also, remove the
already unneded synchronize_net().
Signed-off-by: Veaceslav Falico <vfalico@redhat.com>
[ Upstream commit 4c51e53689569398d656e631c17308d9b8e84650 ]
This patch enables RX of jumbo frames for LAN7500.
Previously the driver would transmit jumbo frames succesfully but
would drop received jumbo frames (incrementing the interface errors
count).
With this patch applied the device can succesfully receive jumbo
frames up to MTU 9000 (9014 bytes on the wire including ethernet
header).
Signed-off-by: Steve Glendinning <steve.glendinning@shawell.net>
[ Upstream commit 76a0e68129d7d24eb995a6871ab47081bbfa0acc ]
skb->ip_summed should be CHECKSUM_UNNECESSARY when the driver reports that
checksums were correct and CHECKSUM_NONE in any other case. They're
currently placed vice versa, which breaks the forwarding scenario. Fix it
by placing them as described above.
[ Upstream commit 14bc435ea54cb888409efb54fc6b76c13ef530e9 ]
According to the Datasheet (page 52):
15-12 Reserved
11-0 RXBC Receive Byte Count
This field indicates the present received frame byte size.
The code has a bug:
rxh = ks8851_rdreg32(ks, KS_RXFHSR);
rxstat = rxh & 0xffff;
rxlen = rxh >> 16; // BUG!!! 0xFFF mask should be applied
Signed-off-by: Max Nekludov <Max.Nekludov@us.elster.com>
[ Upstream commit 6741f40d198c6a5feb23653a1efd4ca47f93d83d ]
Fix bug for DM9000 revision B which contain a DSP PHY
DM9000B use DSP PHY instead previouse DM9000 revisions' analog PHY,
So need extra change in initialization, For
explicity PHY Reset and PHY init parameter, and
first DM9000_NCR reset need NCR_MAC_LBK bit by dm9000_probe().
Following DM9000_NCR reset cause by dm9000_open() clear the
NCR_MAC_LBK bit.
Without this fix, Power-up FIFO pointers error happen around 2%
rate among Davicom's customers' boards. With this fix, All above
cases can be solved.
Signed-off-by: Joseph CHANG <josright123@gmail.com>
[ Upstream commit 188ab1b105c96656f6bcfb49d0d8bb1b1936b632 ]
Usage of pci-msi results in corrupted dma packet transfers to the host.
Reported-by: rebelyouth <rebelyouth.hacklab@gmail.com>
Cc: Huang, Xiong <xiong@qca.qualcomm.com>
Tested-by: Christian Sünkenberg <christian.suenkenberg@student.kit.edu>
[ Upstream commit 91c5746425aed8f7188a351f1224a26aa232e4b3 ]
Some network drivers use a non default hard_header_len
Transmitted skb should take into account dev->hard_header_len, or risk
crashes or expensive reallocations.
In the case of aoe, lets reserve MAX_HEADER bytes.
David reported a crash in defxx driver, solved by this patch.
Reported-by: David Oostdyk <daveo@ll.mit.edu>
Tested-by: David Oostdyk <daveo@ll.mit.edu>
Cc: Ed Cashin <ecashin@coraid.com>
restarting tx queue
commit 7e51cde276ca820d526c6c21cf8147df595a36bf upstream.
To restart tx queue use netif_wake_queue() intead of netif_start_queue()
so that net schedule will restart transmission immediately which will
increase network performance while doing huge data transfers.
Reported-by: Dan Franke <dan.franke@schneider-electric.com>
Suggested-by: Sriramakrishnan A G <srk@ti.com>
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
[ Upstream commit 1bc7db16782c2a581fb4d53ca853631050f31611 ]
Currently if either arp_interval or miimon is disabled, they both get
disabled, and upon disabling they get executed once more which is not
the proper behaviour. Also when doing a no-op and disabling an already
disabled one, the other again gets disabled.
Also fix the error messages with the proper valid ranges, and a small
typo fix in the up delay error message (outputting "down delay", instead
of "up delay").
Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com>
[ Upstream commit 9fe16b78ee17579cb4f333534cf7043e94c67024 ]
If slave sysfs symlink failes to be created - we end up without removing
the master sysfs symlink. Remove it in case of failure.
[ Upstream commit fbb0c41b814d497c656fc7be9e35456f139cb2fb ]
First I would give three observations which will be used later.
Observation 1: if (delayed_work_pending(wq)) cancel_delayed_work(wq)
This usage is wrong because the pending bit is cleared just before the
work's fn is executed and if the function re-arms itself we might end up
with the work still running. It's safe to call cancel_delayed_work_sync()
even if the work is not queued at all.
Observation 2: Use of INIT_DELAYED_WORK()
Work needs to be initialized only once prior to (de/en)queueing.
Observation 3: IFF_UP is set only after ndo_open is called
Related race conditions:
1. Race between bonding_store_miimon() and bonding_store_arp_interval()
Because of Obs.1 we can end up having both works enqueued.
2. Multiple races with INIT_DELAYED_WORK()
Since the works are not protected by anything between INIT_DELAYED_WORK()
and calls to (en/de)queue it is possible for races between the following
functions:
(races are also possible between the calls to INIT_DELAYED_WORK()
and workqueue code)
bonding_store_miimon() - bonding_store_arp_interval(), bond_close(),
bond_open(), enqueued functions
bonding_store_arp_interval() - bonding_store_miimon(), bond_close(),
3. By Obs.1 we need to change bond_cancel_all()
Bugs 1 and 2 are fixed by moving all work initializations in bond_open
which by Obs. 2 and Obs. 3 and the fact that we make sure that all works
are cancelled in bond_close(), is guaranteed not to have any work
enqueued.
Also RTNL lock is now acquired in bonding_store_miimon/arp_interval so
they can't race with bond_close and bond_open. The opposing work is
cancelled only if the IFF_UP flag is set and it is cancelled
unconditionally. The opposing work is already cancelled if the interface
is down so no need to cancel it again. This way we don't need new
synchronizations for the bonding workqueue. These bugs (and fixes) are
tied together and belong in the same patch.
Note: I have left 1 line intentionally over 80 characters (84) because I
didn't like how it looks broken down. If you'd prefer it otherwise,
then simply break it.
v2: Make description text < 75 columns
Signed-off-by: Jay Vosburgh <fubar@us.ibm.com>
[ Upstream commit 74f9f42c1c1650e74fb464f76644c9041f996851 ]
The sky2 driver sets the Rx Upper Threshold for Pause Packet generation to a
wrong value which leads to only 2kB of RAM remaining space. This can lead to
Rx overflow errors even with activated flow-control.
Fix: We should increase the value to 8192/8
Signed-off-by: Mirko Lindner <mlindner@marvell.com>
Acked-by: Stephen Hemminger <stephen@networkplumber.org>
[ Upstream commit 9cfe8b156c21cf340b3a10ecb3022fbbc1c39185 ]
The sky2 driver doesn't count the Receive Overflows because the MAC
interrupt for this event is not set in the MAC's interrupt mask.
The MAC's interrupt mask is set only for Transmit FIFO Underruns.
Fix: The correct setting should be (GM_IS_TX_FF_UR | GM_IS_RX_FF_OR)
Otherwise the Receive Overflow event will not generate any interrupt.
The Receive Overflow interrupt is handled correctly
commit c1681bf8a7b1b98edee8b862a42c19c4e53205fd upstream.
struct block_device lifecycle is defined by its inode (see fs/block_dev.c) -
block_device allocated first time we access /dev/loopXX and deallocated on
bdev_destroy_inode. When we create the device "losetup /dev/loopXX afile"
we want that block_device stay alive until we destroy the loop device
with "losetup -d".
But because we do not hold /dev/loopXX inode its counter goes 0, and
inode/bdev can be destroyed at any moment. Usually it happens at memory
pressure or when user drops inode cache (like in the test below). When later in
loop_clr_fd() we want to use bdev we have use-after-free error with following
stack:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000280
bd_set_size+0x10/0xa0
loop_clr_fd+0x1f8/0x420 [loop]
lo_ioctl+0x200/0x7e0 [loop]
lo_compat_ioctl+0x47/0xe0 [loop]
compat_blkdev_ioctl+0x341/0x1290
do_filp_open+0x42/0xa0
compat_sys_ioctl+0xc1/0xf20
do_sys_open+0x16e/0x1d0
sysenter_dispatch+0x7/0x1a
To prevent use-after-free we need to grab the device in loop_set_fd()
and put it later in loop_clr_fd().
The issue is reprodusible on current Linus head and v3.3. Here is the test:
dd if=/dev/zero of=loop.file bs=1M count=1
while [ true ]; do
losetup /dev/loop0 loop.file
echo 2 > /proc/sys/vm/drop_caches
losetup -d /dev/loop0
done
[ Doing bdgrab/bput in loop_set_fd/loop_clr_fd is safe, because every
time we call loop_set_fd() we check that loop_device->lo_state is
Lo_unbound and set it to Lo_bound If somebody will try to set_fd again
it will get EBUSY. And if we try to loop_clr_fd() on unbound loop
device we'll get ENXIO.
loop_set_fd/loop_clr_fd (and any other loop ioctl) is called under
loop_device->lo_ctl_mutex. ]
Signed-off-by: Anatol Pomozov <anatol.pomozov@gmail.com>
commit 6ef9e2f6d12ce9e2120916804d2ddd46b954a70b upstream.
If CONFIG_MAC80211_MESH is not set, cfg80211 will now allow advertising
interface combinations with NL80211_IFTYPE_MESH_POINT present.
Add appropriate ifdefs to avoid running into errors.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Acked-by: Gertjan van Wingerde <gwingerde@gmail.com>
[lxiang: Backported for 3.4-stable. Removed code of simultaneous AP and mesh
mode added in 4a5fc6d 3.9-rc1.]
Signed-off-by: Lingzhu Xiang <lxiang@redhat.com>
Reviewed-by: CAI Qian <caiqian@redhat.com>
commit f01fc1a82c2ee68726b400fadb156bd623b5f2f1 upstream.
ixgbe_notify_dca cannot be called before driver registration
because it expects driver's klist_devices to be allocated and
initialized. While on it make sure debugfs files are removed
when registration fails.
Signed-off-by: Jakub Kicinski <jakub.kicinski@intel.com>
Tested-by: Phil Schmitt <phillip.j.schmitt@intel.com>
[bwh: Backported to 3.2: no debugfs support]
commit c5fb301ae83bec6892e54984e6ec765c47df8e10 upstream.
Matthew reported kernels fail the pci_eisa probe and are later successful
with the virtual_eisa_root_init force probe without slot0.
The reason for that is: PNP probing is before pci_eisa_init gets called
as pci_eisa_init is called via pci_driver.
pnp 00:0f has 0xc80 - 0xc84 reserved.
[ 9.700409] pnp 00:0f: [io 0x0c80-0x0c84]
so eisa_probe will fail from pci_eisa_init
==>eisa_root_register
==>eisa_probe path.
as force_probe is not set in pci_eisa_root, it will bail early when
slot0 is not probed and initialized.
Try to use subsys_initcall_sync instead, and will keep following sequence:
pci_subsys_init
pci_eisa_init_early
pnpacpi_init/isapnp_init
After this patch EISA can be initialized properly, and PNP overlapping
resource will not be reserved.
[ 10.104434] system 00:0f: [io 0x0c80-0x0c84] could not be reserved
Reported-by: Matthew Whitehead <mwhitehe@redhat.com>
Tested-by: Matthew Whitehead <mwhitehe@redhat.com>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
commit 1ad849aee5f53353ed88d9cd3d68a51b03a7d44f upstream.
Some SPI slave devices require asserted chip select signal across
multiple transfer segments of an SPI message. Currently the driver
always de-asserts the internal SS signal for every single transfer
segment of the message and ignores the 'cs_change' flag of the
transfer description. Disable the internal chip select (SS) only
if this is needed and indicated by the 'cs_change' flag.
Without this change, each partial transfer of a surrounding
multi-part SPI transaction might erroneously change the SS
signal, which might prevent slaves from answering the request
that was sent in a previous transfer segment because the
transaction could be considered aborted (SS was de-asserted
before reading the response).
Reported-by: Gerhard Sittig <gerhard.sittig@ifm.com>
commit 9ba5c80b1aea8648a3efe5f22dc1f7cacdfbeeb8 upstream.
When multiple ovq operations are being performed (lots of open/close
operations on virtio_console fds), the __send_control_msg() function can
get confused without locking.
A simple recipe to cause badness is:
* create a QEMU VM with two virtio-serial ports
* in the guest, do
while true;do echo abc >/dev/vport0p1;done
while true;do echo edf >/dev/vport0p2;done
In one run, this caused a panic in __send_control_msg(). In another, I
got
virtio_console virtio0: control-o:id 0 is not a head!
This also results repeated messages similar to these on the host:
qemu-kvm: virtio-serial-bus: Unexpected port id 478762112 for device virtio-serial-bus.0
qemu-kvm: virtio-serial-bus: Unexpected port id 478762368 for device virtio-serial-bus.0
Reported-by: FuXiangChun <xfu@redhat.com>
Signed-off-by: Amit Shah <amit.shah@redhat.com>
Reviewed-by: Wanlong Gao <gaowanlong@cn.fujitsu.com>
Reviewed-by: Asias He <asias@redhat.com>
[bwh: Backported to 3.2: adjust context]
commit 165b1b8bbc17c9469b053bab78b11b7cbce6d161 upstream.
The cvq_lock was taken for the c_ivq. Rename the lock to make that
obvious.
We'll also add a lock around the c_ovq in the next commit, so there's no
ambiguity.
- Adjust context
- Drop change to virtcons_restore()]
commit 482b0b5d82bd916cc0c55a2abf65bdc69023b843 upstream.
It enhances the driver for FTDI-based USB serial adapters
to recognize Mitsubishi Electric Corp. USB/RS422 Converters
as FT232BM chips and support them.
https://search.meau.com/?q=FX-USB-AW
Signed-off-by: Konstantin Holoborodko <klh.kernel@gmail.com>
Tested-by: Konstantin Holoborodko <klh.kernel@gmail.com>
commit 715230a44310a8cf66fbfb5a46f9a62a9b2de424 upstream.
Commit 184b89044fb6e2a74611dafa69b1dce0d98612c6 ("tg3: Use VPD fw version
when present") introduced VPD parsing that contained a potential length
overflow.
Limit the hardware's reported firmware string length (max 255 bytes) to
stay inside the driver's firmware string length (32 bytes). On overflow,
truncate the formatted firmware string instead of potentially overwriting
portions of the tg3 struct.
http://cansecwest.com/slides/2013/PrivateCore%20CSW%202013.pdf
Reported-by: Oded Horovitz <oded@privatecore.com>
Reported-by: Brad Spengler <spender@grsecurity.net>
Cc: Matt Carlson <mcarlson@broadcom.com>
commit b251412db99ccd4495ce372fec7daee27bf06923 upstream.
Intermittently, b43 will report "Out of order TX status report on DMA ring".
When this happens, the driver must be reset before communication can resume.
The cause of the problem is believed to be an error in the closed-source
firmware; however, all versions of the firmware are affected.
This change uses the observation that the expected status is always 2 less
than the observed value, and supplies a fake status report to skip one
header/data pair.
Not all devices suffer from this problem, but it can occur several times
per second under heavy load. As each occurence kills the unmodified driver,
this patch makes if possible for the affected devices to function. The patch
logs only the first instance of the reset operation to prevent spamming
the logs.
Tested-by: Chris Vine <chris@cvine.freeserve.co.uk>
commit f901b6bc404b67d96eca739857c097e022727b71 upstream.
Thias patch fixes a define conflict between the SH architecture and the sja1000
driver:
drivers/net/can/sja1000/sja1000.h:59:0: warning:
"REG_SR" redefined [enabled by default]
arch/sh/include/asm/ptrace_32.h:25:0: note:
this is the location of the previous definition
A SJA1000_ prefix is added to the offending sja1000 define only, to make a
minimal patch suited for stable. A later patch will add a SJA1000_ prefix to
all defines in sja1000.h.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit c2a2876e863356b092967ea62bebdb4dd663af80 upstream.
There is a bug introduced with commit 27c2127 that causes
devices which are hot unplugged and then hot-replugged to
not have per-device dma_ops set. This causes these devices
to not function correctly. Fixed with this patch.
Reported-by: Andreas Degert <andreas.degert@googlemail.com>
Signed-off-by: Joerg Roedel <joro@8bytes.org>
commit e8cd81693bbbb15db57d3c9aa7dd90eda4842874 upstream.
vcs_poll_data_free() calls unregister_vt_notifier(), which calls
atomic_notifier_chain_unregister(), which calls synchronize_rcu().
Do it *after* we'd dropped ->f_lock.
commit e4317ce877a31dbb9d96375391c1c4ad2210d637 upstream.
For the s626 driver, there is a bug in the handling of asynchronous
commands on the AI subdevice when the stop source is `TRIG_NONE`. The
command should run continuously until cancelled, but the interrupt
handler stops the command running after the first scan.
The command set-up function `s626_ai_cmd()` contains this code:
switch (cmd->stop_src) {
case TRIG_COUNT:
/* data arrives as one packet */
devpriv->ai_sample_count = cmd->stop_arg;
devpriv->ai_continous = 0;
break;
case TRIG_NONE:
/* continous acquisition */
devpriv->ai_continous = 1;
devpriv->ai_sample_count = 0;
break;
The interrupt handler `s626_irq_handler()` contains this code:
if (!(devpriv->ai_continous))
devpriv->ai_sample_count--;
if (devpriv->ai_sample_count <= 0) {
devpriv->ai_cmd_running = 0;
So `devpriv->ai_sample_count` is only decremented for the `TRIG_COUNT`
case, but `devpriv->ai_cmd_running` is set to 0 (and the command
stopped) regardless.
Fix this in `s626_ai_cmd()` by setting `devpriv->ai_sample_count = 1`
for the `TRIG_NONE` case. The interrupt handler will not decrement it
so it will remain greater than 0 and the check for stopping the
acquisition will fail.
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
commit 1c11a172cb30492f5f6a82c6e118fdcd9946c34f upstream.
Use proper macro while extracting TRB transfer length from
Transfer event TRBs. Adding a macro EVENT_TRB_LEN (bits 0:23)
for the same, and use it instead of TRB_LEN (bits 0:16) in
case of event TRBs.
This patch should be backported to kernels as old as 2.6.31, that
contain the commit b10de142119a676552df3f0d2e3a9d647036c26a "USB: xhci:
Bulk transfer support". This patch will have issues applying to older
kernels.
Signed-off-by: Vivek gautam <gautam.vivek@samsung.com>
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
commit 1ee9e2aa7b31427303466776f455d43e5e3c9275 upstream.
Commit f0dc117abdfa ("IPoIB: Fix TX queue lockup with mixed UD/CM
traffic") attempts to solve an issue where unprocessed UD send
completions can deadlock the netdev.
The patch doesn't fully resolve the issue because if more than half
the tx_outstanding's were UD and all of the destinations are RC
reachable, arming the CQ doesn't solve the issue.
This patch uses the IB_CQ_REPORT_MISSED_EVENTS on the
ib_req_notify_cq(). If the rc is above 0, the UD send cq completion
callback is called directly to re-arm the send completion timer.
This issue is seen in very large parallel filesystem deployments
and the patch has been shown to correct the issue.
Reviewed-by: Dean Luick <dean.luick@intel.com>
Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
commit 0e5e098ac22dae38f957e951b70d3cf73beff0f7 upstream.
Commit 7708992 ("xen/blkback: Seperate the bio allocation and the bio
submission") consolidated the pendcnt updates to just a single write,
neglecting the fact that the error path relied on it getting set to 1
up front (such that the decrement in __end_block_io_op() would actually
drop the count to zero, triggering the necessary cleanup actions).
Also remove a misleading and a stale (after said commit) comment.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 36ef0b473fbf43d5db23eea4616cc1d18cec245f upstream.
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi>
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
commit 74632d11a133b5baf6b9d622dd19d2f944d93d94 upstream.
The commit 'ath9k_hw: fix calibration issues on chainmask that don't
include chain 0' changed the hardware chainmask to the chip chainmask
for the duration of the calibration, but the revert to user
configuration in the reset path runs too early.
That causes some issues with limiting the number of antennas (including
spurious failure in hardware-generated packets).
Fix this by reverting the chainmask after the essential parts of the
calibration that need the workaround, and before NF calibration is run.
Reported-by: Wojciech Dubowik <Wojciech.Dubowik@neratec.com>
Tested-by: Wojciech Dubowik <Wojciech.Dubowik@neratec.com>
commit ebaf5795ef57a70a042ea259448a465024e2821d upstream.
Add support for the AR9462 chip
T: Bus=03 Lev=01 Prnt=01 Port=08 Cnt=01 Dev#= 5 Spd=12 MxCh= 0
D: Ver= 1.10 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=0cf3 ProdID=817a Rev= 0.02
C:* #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=100mA
I:* If#= 0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=81(I) Atr=03(Int.) MxPS= 16 Ivl=1ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
I:* If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 0 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 0 Ivl=1ms
I: If#= 1 Alt= 1 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 9 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 9 Ivl=1ms
I: If#= 1 Alt= 2 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 17 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 17 Ivl=1ms
I: If#= 1 Alt= 3 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 25 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 25 Ivl=1ms
I: If#= 1 Alt= 4 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 33 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 33 Ivl=1ms
I: If#= 1 Alt= 5 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 49 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 49 Ivl=1ms
Cc: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
Signed-off-by: Ming Lei <ming.lei@canonical.com>
Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
commit 570637dc8eeb2faba06228d497ff40bb019bcc93 upstream.
Fix build problem caused by typo introduced by 620ae90ed8
("HID: usbhid: quirk for MSI GX680R led panel").
Reported-by: fengguang.wu@intel.com
commit 620ae90ed8ca8b6e40cb9e10279b4f5ef9f0ab81 upstream.
This keyboard backlight device causes a 10 second delay to boot. Add it
to the quirk list with HID_QUIRK_NO_INIT_REPORTS.
This fixes Red Hat bugzilla https://bugzilla.redhat.com/show_bug.cgi?id=907221
Signed-off-by: Josh Boyer <jwboyer@redhat.com>
commit 3d464d9b71ef2f2b40a4bc9dcf06794fd1be9d12 upstream.
This device needs to be added to the quirks list with HID_QUIRK_NO_INIT_REPORTS,
otherwise it causes 10 seconds timeout during report initialization.
This fixes Red Hat bugzilla https://bugzilla.redhat.com/show_bug.cgi?id=806587
commit 503bded92da283b2f31d87e054c4c6d30c3c2340 upstream.
Index of atmel_ports[ATMEL_MAX_UART] should be smaller
than ATMEL_MAX_UART.
Signed-off-by: Pawel Wieczorkiewicz <wpawel@gmail.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
commit d66629c1325399cf080ba8b2fb086c10e5439cdd upstream.
T: Bus=03 Lev=01 Prnt=01 Port=01 Cnt=01 Dev#= 3 Spd=12 MxCh= 0
P: Vendor=0cf3 ProdID=0036 Rev= 0.02
A: FirstIf#= 0 IfCount= 2 Cls=e0(wlcon) Sub=01 Prot=01
commit 94a32d10f47b637ae24b78b1ddc7ef0e8396fda4 upstream.
T: Bus=01 Lev=02 Prnt=02 Port=00 Cnt=01 Dev#= 3 Spd=12 MxCh= 0
P: Vendor=0cf3 ProdID=3008 Rev= 0.01
S: Manufacturer=Atheros Communications
S: Product=Bluetooth USB Host Controller
S: SerialNumber=Alaska Day 2006
Signed-off-by: Sunguk Lee <d3m3vilurr@gmail.com>
commit 3f63c340a72f2872a9362245cb2e03f3d2bb73a6 upstream.
Yet another version of the atheros bluetooth chipset
T: Bus=01 Lev=02 Prnt=02 Port=03 Cnt=01 Dev#= 3 Spd=12 MxCh= 0
P: Vendor=04ca ProdID=3004 Rev=00.01
C: #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=100mA
I: If#= 0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
I: If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
This resolves https://bugzilla.redhat.com/show_bug.cgi?id=844750
Reported-by: niktr@mail.ru
commit f4d6f7dce71a5da93da50272ff1670bf2f1146b1 upstream.
Output of /sys/kernel/debug/usb/devices
T: Bus=03 Lev=02 Prnt=02 Port=00 Cnt=01 Dev#= 6 Spd=12 MxCh= 0
P: Vendor=04ca ProdID=3008 Rev= 0.02
Signed-off-by: Sergio Cambra <sergio@programatica.es>
commit 2582d529c44d12502a700f1c3db062b9f44679bc upstream.
T: Bus=01 Lev=02 Prnt=02 Port=05 Cnt=01 Dev#= 4 Spd=12 MxCh= 0
P: Vendor=0489 ProdID=e056 Rev=00.01
Signed-off-by: AceLan Kao <acelan.kao@canonical.com>
commit 3a61eda81ebcfc006ebb1496764299d53e5bf67f upstream.
T: Bus=01 Lev=02 Prnt=02 Port=00 Cnt=01 Dev#= 5 Spd=12 MxCh= 0
P: Vendor=0489 ProdID=e04e Rev=00.02
commit 2c262b2a5235b7f5b18d4d58394511f76371d7cb upstream.
T: Bus=02 Lev=02 Prnt=02 Port=06 Cnt=01 Dev#= 4 Spd=12 MxCh= 0
P: Vendor=04ca ProdID=3006 Rev= 0.02
Signed-off-by: Daniel Schaal <farbing@web.de>
commit eed307e290b96636def331375e065aca43f9069a upstream.
T: Bus=02 Lev=02 Prnt=02 Port=04 Cnt=01 Dev#= 3 Spd=12 MxCh= 0
P: Vendor=13d3 ProdID=3393 Rev=00.01
In 3.2, unlike mainline, efi_pstore_erase() calls efi_pstore_write()
with a size of 0, as the underlying EFI interface treats a size of 0
as meaning deletion.
This was not taken into account in my backport of commit d80a361d779a
'efi_pstore: Check remaining space with QueryVariableInfo() before
writing data'. The size check should be omitted when erasing.
commit c19b3b0f6eed552952845e4ad908dba2113d67b4 upstream.
When KMS has parsed an EDID "detailed timing", it leaves the frame rate
zeroed. Consecutive (debug-) output of that mode thus yields 0 for
vsync. This simple fix also speeds up future invocations of
drm_mode_vrefresh().
While it is debatable whether this qualifies as a -stable fix I'd apply
it for consistency's sake; drm_helper_probe_single_connector_modes()
does the same thing already for all probed modes.
Signed-off-by: Torsten Duwe <duwe@lst.de>
commit 16dad1d743d31a104a849c8944e6b9eb479f6cd7 upstream.
EDID spreads some values across multiple bytes; bit-fiddling is needed
to retrieve these. The current code to parse "detailed timings" has a
cut&paste error that results in a vsync offset of at most 15 lines
instead of 63.
See
http://en.wikipedia.org/wiki/EDID
and in the "EDID Detailed Timing Descriptor" see bytes 10+11 show why
that needs to be a left shift.
commit 132c803f7b70b17322579f6f4f3f65cf68e55135 upstream.
NVIDIA's Tegra SoC allows read/write of controller register only
if controller clock is enabled. System hangs if read/write happens
to registers without enabling clock.
clk_prepare_enable() can be fail due to unknown reason and hence
adding check for return value of this function. If this function
success then only access register otherwise return to caller with
error.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
- Adjust context
- Keep calling clk_enable() directly]
