[ Upstream commit 6bac9bc273cdab6157ad7a2ead09400aabfc445b ]
There are two problems with dev_err() here. One: It is not ratelimited.
Two: We don't see which driver tried to transfer something with a
suspended adapter. Switch to dev_WARN_ONCE to fix both issues. Drawback
is that we don't see if multiple drivers are trying to transfer while
suspended. They need to be discovered one after the other now. This is
better than a high CPU load because a really broken driver might try to
resend endlessly.
Link: https://bugs.archlinux.org/task/62391
Fixes: 275154155538 ("i2c: designware: Do not allow i2c_dw_xfer() calls while suspended")
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Reported-by: skidnik <skidnik@gmail.com>
Acked-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Tested-by: skidnik <skidnik@gmail.com>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
[ Upstream commit de1887c064b9996ac03120d90d0a909a3f678f98 ]
We don't check for the validity of the lengths in the packet received
from the firmware. If the MPDU length received in the rx descriptor
is too short to contain the header length and the crypt length
together, we may end up trying to copy a negative number of bytes
(headlen - hdrlen < 0) which will underflow and cause us to try to
copy a huge amount of data. This causes oopses such as this one:
BUG: unable to handle kernel paging request at ffff896be2970000
PGD 5e201067 P4D 5e201067 PUD 5e205067 PMD 16110d063 PTE 8000000162970161
Oops: 0003 [#1] PREEMPT SMP NOPTI
CPU: 2 PID: 1824 Comm: irq/134-iwlwifi Not tainted 4.19.33-04308-geea41cf4930f #1
Hardware name: [...]
RIP: 0010:memcpy_erms+0x6/0x10
Code: 90 90 90 90 eb 1e 0f 1f 00 48 89 f8 48 89 d1 48 c1 e9 03 83 e2 07 f3 48 a5 89 d1 f3 a4 c3 66 0f 1f 44 00 00 48 89 f8 48 89 d1 <f3> a4 c3
0f 1f 80 00 00 00 00 48 89 f8 48 83 fa 20 72 7e 40 38 fe
RSP: 0018:ffffa4630196fc60 EFLAGS: 00010287
RAX: ffff896be2924618 RBX: ffff896bc8ecc600 RCX: 00000000fffb4610
RDX: 00000000fffffff8 RSI: ffff896a835e2a38 RDI: ffff896be2970000
RBP: ffffa4630196fd30 R08: ffff896bc8ecc600 R09: ffff896a83597000
R10: ffff896bd6998400 R11: 000000000200407f R12: ffff896a83597050
R13: 00000000fffffff8 R14: 0000000000000010 R15: ffff896a83597038
FS: 0000000000000000(0000) GS:ffff896be8280000(0000) knlGS:0000000000000000
CR2: ffff896be2970000 CR3: 000000005dc12002 CR4: 00000000003606e0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
iwl_mvm_rx_mpdu_mq+0xb51/0x121b [iwlmvm]
iwl_pcie_rx_handle+0x58c/0xa89 [iwlwifi]
iwl_pcie_irq_rx_msix_handler+0xd9/0x12a [iwlwifi]
irq_thread_fn+0x24/0x49
irq_thread+0xb0/0x122
kthread+0x138/0x140
ret_from_fork+0x1f/0x40
Fix that by checking the lengths for correctness and trigger a warning
to show that we have received wrong data.
Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
[ Upstream commit 88ef66a28391ea7b624bfb7508a5b015c13b28f3 ]
Adding device entries found in vendor modified versions of this
driver. Function maps for some of the devices follow:
WNC D16Q1, D16Q5, D18Q1 LTE CAT3 module (1435:0918)
MI_00 Qualcomm HS-USB Diagnostics
MI_01 Android Debug interface
MI_02 Qualcomm HS-USB Modem
MI_03 Qualcomm Wireless HS-USB Ethernet Adapter
MI_04 Qualcomm Wireless HS-USB Ethernet Adapter
MI_05 Qualcomm Wireless HS-USB Ethernet Adapter
MI_06 USB Mass Storage Device
T: Bus=02 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=1435 ProdID=0918 Rev= 2.32
S: Manufacturer=Android
S: Product=Android
S: SerialNumber=0123456789ABCDEF
C:* #Ifs= 7 Cfg#= 1 Atr=80 MxPwr=500mA
I:* If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=option
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=42 Prot=01 Driver=(none)
E: Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=84(I) Atr=03(Int.) MxPS= 64 Ivl=32ms
E: Ad=83(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 3 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=qmi_wwan
E: Ad=86(I) Atr=03(Int.) MxPS= 64 Ivl=32ms
E: Ad=85(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 4 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=qmi_wwan
E: Ad=88(I) Atr=03(Int.) MxPS= 64 Ivl=32ms
E: Ad=87(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 5 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=qmi_wwan
E: Ad=8a(I) Atr=03(Int.) MxPS= 64 Ivl=32ms
E: Ad=89(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=06(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
WNC D18 LTE CAT3 module (1435:d182)
MI_01 Androd Debug interface
MI_03 Qualcomm HS-USB NMEA
ZM8510/ZM8620/ME3960 (19d2:0396)
MI_00 ZTE Mobile Broadband Diagnostics Port
MI_01 ZTE Mobile Broadband AT Port
MI_02 ZTE Mobile Broadband Modem
MI_03 ZTE Mobile Broadband NDIS Port (qmi_wwan)
MI_04 ZTE Mobile Broadband ADB Port
ME3620_X (19d2:1432)
MI_00 ZTE Diagnostics Device
MI_01 ZTE UI AT Interface
MI_02 ZTE Modem Device
MI_03 ZTE Mobile Broadband Network Adapter
MI_04 ZTE Composite ADB Interface
Reported-by: Lars Melin <larsm17@gmail.com>
Signed-off-by: Bjørn Mork <bjorn@mork.no>
[ Upstream commit 349ced9984ff540ce74ca8a0b2e9b03dc434b9dd ]
Fix a similar endless event loop as was done in commit
8dcf32175b4e ("i2c: prevent endless uevent loop with
CONFIG_I2C_DEBUG_CORE"):
The culprit is the dev_dbg printk in the i2c uevent handler. If
this is activated (for instance by CONFIG_I2C_DEBUG_CORE) it results
in an endless loop with systemd-journald.
This happens if user-space scans the system log and reads the uevent
file to get information about a newly created device, which seems
fair use to me. Unfortunately reading the "uevent" file uses the
same function that runs for creating the uevent for a new device,
generating the next syslog entry
Both CONFIG_I2C_DEBUG_CORE and CONFIG_POWER_SUPPLY_DEBUG were reported
in https://bugs.freedesktop.org/show_bug.cgi?id=76886 but only former
seems to have been fixed. Drop debug prints as it was done in I2C
subsystem to resolve the issue.
Signed-off-by: Andrey Smirnov <andrew.smirnov@gmail.com>
Cc: Chris Healy <cphealy@gmail.com>
Cc: linux-pm@vger.kernel.org
Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.com>
[ Upstream commit 22e8860cf8f777fbf6a83f2fb7127f682a8e9de4 ]
regmap_update_bits could fail and deserves a check.
The patch adds the checks and if it fails, returns its error
code upstream.
Signed-off-by: Kangjie Lu <kjlu@umn.edu>
Reviewed-by: Mukesh Ojha <mojha@codeaurora.org>
Signed-off-by: Stefan Schmidt <stefan@datenfreihafen.org>
[ Upstream commit d5bc73f34cc97c4b4b9202cc93182c2515076edf ]
In most cases, kmalloc() will not be available early in boot when
pci_setup() is called. Thus, the kstrdup() call that was added to fix the
__initdata bug with the disable_acs_redir parameter usually returns NULL,
so the parameter is discarded and has no effect.
To fix this, store the string that's in initdata until an initcall function
can allocate the memory appropriately. This way we don't need any
additional static memory.
Fixes: d2fd6e81912a ("PCI: Fix __initdata issue with "pci=disable_acs_redir" parameter")
Signed-off-by: Logan Gunthorpe <logang@deltatee.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
[ Upstream commit dbe7208c6c4aec083571f2ec742870a0d0edbea3 ]
If called fast enough so samples do not increment, we can get
division by zero in kernel:
__div0
cpcap_battery_cc_raw_div
cpcap_battery_get_property
power_supply_get_property.part.1
power_supply_show_property
power_supply_uevent
Fixes: 874b2adbed12 ("power: supply: cpcap-battery: Add a battery driver")
Acked-by: Pavel Machek <pavel@ucw.cz>
[ Upstream commit 2abc330c514fe56c570bb1a6318b054b06a4f72e ]
Sometimes one of the nkmp factors is unused. This means that one of the
factors shift and width values are set to 0. Current nkmp clock code
generates a mask for each factor with GENMASK(width + shift - 1, shift).
For unused factor this translates to GENMASK(-1, 0). This code is
further expanded by C preprocessor to final version:
(((~0UL) - (1UL << (0)) + 1) & (~0UL >> (BITS_PER_LONG - 1 - (-1))))
or a bit simplified:
(~0UL & (~0UL >> BITS_PER_LONG))
It turns out that result of the second part (~0UL >> BITS_PER_LONG) is
actually undefined by C standard, which clearly specifies:
"If the value of the right operand is negative or is greater than or
equal to the width of the promoted left operand, the behavior is
undefined."
Additionally, compiling kernel with aarch64-linux-gnu-gcc 8.3.0 gave
different results whether literals or variables with same values as
literals were used. GENMASK with literals -1 and 0 gives zero and with
variables gives 0xFFFFFFFFFFFFFFF (~0UL). Because nkmp driver uses
GENMASK with variables as parameter, expression calculates mask as ~0UL
instead of 0. This has further consequences that LSB in register is
always set to 1 (1 is neutral value for a factor and shift is 0).
For example, H6 pll-de clock is set to 600 MHz by sun4i-drm driver, but
due to this bug ends up being 300 MHz. Additionally, 300 MHz seems to be
too low because following warning can be found in dmesg:
[ 1.752763] WARNING: CPU: 2 PID: 41 at drivers/clk/sunxi-ng/ccu_common.c:41 ccu_helper_wait_for_lock.part.0+0x6c/0x90
[ 1.763378] Modules linked in:
[ 1.766441] CPU: 2 PID: 41 Comm: kworker/2:1 Not tainted 5.1.0-rc2-next-20190401 #138
[ 1.774269] Hardware name: Pine H64 (DT)
[ 1.778200] Workqueue: events deferred_probe_work_func
[ 1.783341] pstate: 40000005 (nZcv daif -PAN -UAO)
[ 1.788135] pc : ccu_helper_wait_for_lock.part.0+0x6c/0x90
[ 1.793623] lr : ccu_helper_wait_for_lock.part.0+0x48/0x90
[ 1.799107] sp : ffff000010f93840
[ 1.802422] x29: ffff000010f93840 x28: 0000000000000000
[ 1.807735] x27: ffff800073ce9d80 x26: ffff000010afd1b8
[ 1.813049] x25: ffffffffffffffff x24: 00000000ffffffff
[ 1.818362] x23: 0000000000000001 x22: ffff000010abd5c8
[ 1.823675] x21: 0000000010000000 x20: 00000000685f367e
[ 1.828987] x19: 0000000000001801 x18: 0000000000000001
[ 1.834300] x17: 0000000000000001 x16: 0000000000000000
[ 1.839613] x15: 0000000000000000 x14: ffff000010789858
[ 1.844926] x13: 0000000000000000 x12: 0000000000000001
[ 1.850239] x11: 0000000000000000 x10: 0000000000000970
[ 1.855551] x9 : ffff000010f936c0 x8 : ffff800074cec0d0
[ 1.860864] x7 : 0000800067117000 x6 : 0000000115c30b41
[ 1.866177] x5 : 00ffffffffffffff x4 : 002c959300bfe500
[ 1.871490] x3 : 0000000000000018 x2 : 0000000029aaaaab
[ 1.876802] x1 : 00000000000002e6 x0 : 00000000686072bc
[ 1.882114] Call trace:
[ 1.884565] ccu_helper_wait_for_lock.part.0+0x6c/0x90
[ 1.889705] ccu_helper_wait_for_lock+0x10/0x20
[ 1.894236] ccu_nkmp_set_rate+0x244/0x2a8
[ 1.898334] clk_change_rate+0x144/0x290
[ 1.902258] clk_core_set_rate_nolock+0x180/0x1b8
[ 1.906963] clk_set_rate+0x34/0xa0
[ 1.910455] sun8i_mixer_bind+0x484/0x558
[ 1.914466] component_bind_all+0x10c/0x230
[ 1.918651] sun4i_drv_bind+0xc4/0x1a0
[ 1.922401] try_to_bring_up_master+0x164/0x1c0
[ 1.926932] __component_add+0xa0/0x168
[ 1.930769] component_add+0x10/0x18
[ 1.934346] sun8i_dw_hdmi_probe+0x18/0x20
[ 1.938443] platform_drv_probe+0x50/0xa0
[ 1.942455] really_probe+0xcc/0x280
[ 1.946032] driver_probe_device+0x54/0xe8
[ 1.950130] __device_attach_driver+0x80/0xb8
[ 1.954488] bus_for_each_drv+0x78/0xc8
[ 1.958326] __device_attach+0xd4/0x130
[ 1.962163] device_initial_probe+0x10/0x18
[ 1.966348] bus_probe_device+0x90/0x98
[ 1.970185] deferred_probe_work_func+0x6c/0xa0
[ 1.974720] process_one_work+0x1e0/0x320
[ 1.978732] worker_thread+0x228/0x428
[ 1.982484] kthread+0x120/0x128
[ 1.985714] ret_from_fork+0x10/0x18
[ 1.989290] ---[ end trace 9babd42e1ca4b84f ]---
This commit solves the issue by first checking value of the factor
width. If it is equal to 0 (unused factor), mask is set to 0, otherwise
GENMASK() macro is used as before.
Fixes: d897ef56faf9 ("clk: sunxi-ng: Mask nkmp factors when setting register")
Signed-off-by: Jernej Skrabec <jernej.skrabec@siol.net>
Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com>
commit 940bc471780b004a5277c1931f52af363c2fc9da upstream.
Commit b592211c33f7 ("dm mpath: fix attached_handler_name leak and
dangling hw_handler_name pointer") fixed a memory leak for the case
where setup_scsi_dh() returns failure. But setup_scsi_dh may return
success and not "use" attached_handler_name if the
retain_attached_hwhandler flag is not set on the map. As setup_scsi_sh
properly "steals" the pointer by nullifying it, freeing it
unconditionally in parse_path() is safe.
Fixes: b592211c33f7 ("dm mpath: fix attached_handler_name leak and dangling hw_handler_name pointer")
Cc: stable@vger.kernel.org
Reported-by: Yufen Yu <yuyufen@huawei.com>
Signed-off-by: Martin Wilck <mwilck@suse.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
commit 30bba430ddf737978e40561198693ba91386dac1 upstream.
When we use separate devices for data and metadata, dm-integrity would
incorrectly calculate the size of the metadata device as if it had
512-byte block size - and it would refuse activation with larger block
size and smaller metadata device.
Fix this so that it takes actual block size into account, which fixes
the following reported issue:
https://gitlab.com/cryptsetup/cryptsetup/issues/450
Fixes: 356d9d52e122 ("dm integrity: allow separate metadata device")
Cc: stable@vger.kernel.org # v4.19+
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
commit 7a1cd7238fde6ab367384a4a2998cba48330c398 upstream.
The information about tag size should not be printed without debug info
set. Also print device major:minor in the error message to identify the
device instance.
Also use rate limiting and debug level for info about used crypto API
implementaton. This is important because during online reencryption
the existing message saturates syslog (because we are moving hotzone
across the whole device).
Signed-off-by: Milan Broz <gmazyland@gmail.com>
commit 81bc6d150ace6250503b825d9d0c10f7bbd24095 upstream.
When the target line contains an invalid device, delay_ctr() will call
delay_dtr() with NULL workqueue. Attempting to destroy the NULL
workqueue causes a crash.
commit 7aedf75ff740a98f3683439449cd91c8662d03b2 upstream.
The function blkdev_report_zones() returns success even if no zone
information is reported (empty report). Empty zone reports can only
happen if the report start sector passed exceeds the device capacity.
The conditions for this to happen are either a bug in the caller code,
or, a change in the device that forced the low level driver to change
the device capacity to a value that is lower than the report start
sector. This situation includes a failed disk revalidation resulting in
the disk capacity being changed to 0.
If this change happens while dm-zoned is in its initialization phase
executing dmz_init_zones(), this function may enter an infinite loop
and hang the system. To avoid this, add a check to disallow empty zone
reports and bail out early. Also fix the function dmz_update_zone() to
make sure that the report for the requested zone was correctly obtained.
Fixes: 3b1a94c88b79 ("dm zoned: drive-managed zoned block device target")
Signed-off-by: Damien Le Moal <damien.lemoal@wdc.com>
Reviewed-by: Shaun Tancheff <shaun@tancheff.com>
commit e28adc3bf34e434b30e8d063df4823ba0f3e0529 upstream.
Add missing dm_bitset_cursor_next() to properly advance the bitset
cursor.
Otherwise, the discarded state of all blocks is set according to the
discarded state of the first block.
Fixes: ae4a46a1f6 ("dm cache metadata: use bitset cursor api to load discard bitset")
Signed-off-by: Nikos Tsironis <ntsironis@arrikto.com>
commit 4ec73791a64bab25cabf16a6067ee478692e506d upstream.
Due to an erratum in some Pericom PCIe-to-PCI bridges in reverse mode
(conventional PCI on primary side, PCIe on downstream side), the Retrain
Link bit needs to be cleared manually to allow the link training to
complete successfully.
If it is not cleared manually, the link training is continuously restarted
and no devices below the PCI-to-PCIe bridge can be accessed. That means
drivers for devices below the bridge will be loaded but won't work and may
even crash because the driver is only reading 0xffff.
See the Pericom Errata Sheet PI7C9X111SLB_errata_rev1.2_102711.pdf for
details. Devices known as affected so far are: PI7C9X110, PI7C9X111SL,
PI7C9X130.
Add a new flag, clear_retrain_link, in struct pci_dev. Quirks for affected
devices set this bit.
Note that pcie_retrain_link() lives in aspm.c because that's currently the
only place we use it, but this erratum is not specific to ASPM, and we may
retrain links for other reasons in the future.
Signed-off-by: Stefan Mätje <stefan.maetje@esd.eu>
[bhelgaas: apply regardless of CONFIG_PCIEASPM]
CC: stable@vger.kernel.org
commit 86fa6a344209d9414ea962b1f1ac6ade9dd7563a upstream.
Factor out pcie_retrain_link() to use for Pericom Retrain Link quirk. No
functional change intended.
commit be20bbcb0a8cb5597cc62b3e28d275919f3431df upstream.
Reestablish the PCIe link very early in the resume process in case it
went down to prevent PCI accesses from hanging the bus. Such accesses
can happen early in the PCI resume process, as early as the
SUSPEND_RESUME_NOIRQ step, thus the link must be reestablished in the
driver resume_noirq() callback.
Fixes: e015f88c368d ("PCI: rcar: Add support for R-Car H3 to pcie-rcar")
Signed-off-by: Kazufumi Ikeda <kaz-ikeda@xc.jp.nec.com>
Signed-off-by: Gaku Inami <gaku.inami.xw@bp.renesas.com>
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
[lorenzo.pieralisi@arm.com: reformatted commit log]
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Reviewed-by: Simon Horman <horms+renesas@verge.net.au>
Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be>
Acked-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Cc: Geert Uytterhoeven <geert+renesas@glider.be>
Cc: Phil Edworthy <phil.edworthy@renesas.com>
Cc: Simon Horman <horms+renesas@verge.net.au>
Cc: Wolfram Sang <wsa@the-dreams.de>
Cc: linux-renesas-soc@vger.kernel.org
commit 31f996efbd5a7825f4d30150469e9d110aea00e8 upstream.
Commit 60ed982a4e78 ("PCI/AER: Move internal declarations to
drivers/pci/pci.h") changed pci_aer_init() to return "void", but didn't
change the stub for when CONFIG_PCIEAER isn't enabled. Change the stub to
match.
Fixes: 60ed982a4e78 ("PCI/AER: Move internal declarations to drivers/pci/pci.h")
Signed-off-by: Jisheng Zhang <Jisheng.Zhang@synaptics.com>
CC: stable@vger.kernel.org # v4.19+
commit 6302bf3ef78dd210b5ff4a922afcb7d8eff8a211 upstream.
Two functions allocate a host bridge: devm_pci_alloc_host_bridge() and
pci_alloc_host_bridge(). At the moment, only the unmanaged one initializes
the PCIe feature bits, which prevents from using features such as hotplug
or AER on some systems, when booting with device tree. Make the
initialization code common.
Fixes: 02bfeb484230 ("PCI/portdrv: Simplify PCIe feature permission checking")
Signed-off-by: Jean-Philippe Brucker <jean-philippe.brucker@arm.com>
CC: stable@vger.kernel.org # v4.17+
commit e0547c81bfcfad01cbbfa93a5e66bb98ab932f80 upstream.
On ThinkPad P50 SKUs with an Nvidia Quadro M1000M instead of the M2000M
variant, the BIOS does not always reset the secondary Nvidia GPU during
reboot if the laptop is configured in Hybrid Graphics mode. The reason is
unknown, but the following steps and possibly a good bit of patience will
reproduce the issue:
1. Boot up the laptop normally in Hybrid Graphics mode
2. Make sure nouveau is loaded and that the GPU is awake
3. Allow the Nvidia GPU to runtime suspend itself after being idle
4. Reboot the machine, the more sudden the better (e.g. sysrq-b may help)
5. If nouveau loads up properly, reboot the machine again and go back to
step 2 until you reproduce the issue
This results in some very strange behavior: the GPU will be left in exactly
the same state it was in when the previously booted kernel started the
reboot. This has all sorts of bad side effects: for starters, this
completely breaks nouveau starting with a mysterious EVO channel failure
that happens well before we've actually used the EVO channel for anything:
nouveau 0000:01:00.0: disp: chid 0 mthd 0000 data 00000400 00001000 00000002
This causes a timeout trying to bring up the GR ctx:
nouveau 0000:01:00.0: timeout
WARNING: CPU: 0 PID: 12 at drivers/gpu/drm/nouveau/nvkm/engine/gr/ctxgf100.c:1547 gf100_grctx_generate+0x7b2/0x850 [nouveau]
Hardware name: LENOVO 20EQS64N0B/20EQS64N0B, BIOS N1EET82W (1.55 ) 12/18/2018
Workqueue: events_long drm_dp_mst_link_probe_work [drm_kms_helper]
nouveau 0000:01:00.0: gr: wait for idle timeout (en: 1, ctxsw: 0, busy: 1)
nouveau 0000:01:00.0: fifo: fault 01 [WRITE] at 0000000000008000 engine 00 [GR] client 15 [HUB/SCC_NB] reason c4 [] on channel -1 [0000000000 unknown]
The GPU never manages to recover. Booting without loading nouveau causes
issues as well, since the GPU starts sending spurious interrupts that cause
other device's IRQs to get disabled by the kernel:
irq 16: nobody cared (try booting with the "irqpoll" option)
handlers:
[<000000007faa9e99>] i801_isr [i2c_i801]
Disabling IRQ #16
serio: RMI4 PS/2 pass-through port at rmi4-00.fn03
i801_smbus 0000:00:1f.4: Timeout waiting for interrupt!
i801_smbus 0000:00:1f.4: Transaction timeout
rmi4_f03 rmi4-00.fn03: rmi_f03_pt_write: Failed to write to F03 TX register (-110).
rmi4_physical rmi4-00: rmi_driver_set_irq_bits: Failed to change enabled interrupts!
This causes the touchpad and sometimes other things to get disabled.
Since this happens without nouveau, we can't fix this problem from nouveau
itself.
Add a PCI quirk for the specific P50 variant of this GPU. Make sure the
GPU is advertising NoReset- so we don't reset the GPU when the machine is
in Dedicated graphics mode (where the GPU being initialized by the BIOS is
normal and expected). Map the GPU MMIO space and read the magic 0x2240c
register, which will have bit 1 set if the device was POSTed during a
previous boot. Once we've confirmed all of this, reset the GPU and
re-disable it - bringing it back to a healthy state.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=203003
Link: https://lore.kernel.org/lkml/20190212220230.1568-1-lyude@redhat.com
Signed-off-by: Lyude Paul <lyude@redhat.com>
Cc: nouveau@lists.freedesktop.org
Cc: dri-devel@lists.freedesktop.org
Cc: Karol Herbst <kherbst@redhat.com>
Cc: Ben Skeggs <skeggsb@gmail.com>
commit 6afb7e26978da5e86e57e540fdce65c8b04f398a upstream.
When using PCI passthrough with this device, the host machine locks up
completely when starting the VM, requiring a hard reboot. Add a quirk to
avoid bus resets on this device.
Fixes: c3e59ee4e766 ("PCI: Mark Atheros AR93xx to avoid bus reset")
Link: https://lore.kernel.org/linux-pci/20190107213248.3034-1-james.prestwood@linux.intel.com
Signed-off-by: James Prestwood <james.prestwood@linux.intel.com>
CC: stable@vger.kernel.org # v3.14+
commit d28ca864c493637f3c957f4ed9348a94fca6de60 upstream.
ATS is broken on the Radeon R7 GPU (at least for Stoney Ridge based laptop)
and causes IOMMU stalls and system failure. Disable ATS on these devices
to make them usable again with IOMMU enabled.
Thanks to Joerg Roedel <jroedel@suse.de> for help.
[bhelgaas: In the email thread mentioned below, Alex suspects the real
problem is in sbios or iommu, so it may affect only certain systems, and it
may affect other devices in those systems as well. However, per Joerg we
lack the ability to debug further, so this quirk is the best we can do for
now.]
Link: https://bugzilla.kernel.org/show_bug.cgi?id=194521
Link: https://lore.kernel.org/lkml/20190408103725.30426-1-nickel@altlinux.org
Fixes: 9b44b0b09dec ("PCI: Mark AMD Stoney GPU ATS as broken")
Signed-off-by: Nikolai Kostrigin <nickel@altlinux.org>
Acked-by: Joerg Roedel <jroedel@suse.de>
commit f627caf55b8e735dcec8fa6538e9668632b55276 upstream.
On a Thinkpad s30 (Pentium III / i440MX, Lynx3DM), blanking the display
or starting the X server will crash and freeze the system, or garble the
display.
Experiments showed this problem can mostly be solved by adjusting the
order of register writes. Also, sm712fb failed to consider the difference
of clock frequency when unblanking the display, and programs the clock for
SM712 to SM720.
Fix them by adjusting the order of register writes, and adding an
additional check for SM720 for programming the clock frequency.
Signed-off-by: Yifeng Li <tomli@tomli.me>
Tested-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
Cc: Teddy Wang <teddy.wang@siliconmotion.com>
Cc: <stable@vger.kernel.org> # v4.4+
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
commit 4ed7d2ccb7684510ec5f7a8f7ef534bc6a3d55b2 upstream.
Loongson MIPS netbooks use 1024x600 LCD panels, which is the original
target platform of this driver, but nearly all old x86 laptops have
1024x768. Lighting 768 panels using 600's timings would partially
garble the display. Since it's not possible to distinguish them reliably,
we change the default to 768, but keep 600 as-is on MIPS.
Further, earlier laptops, such as IBM Thinkpad 240X, has a 800x600 LCD
panel, this driver would probably garbled those display. As we don't
have one for testing, the original behavior of the driver is kept as-is,
but the problem has been documented is the comments.
commit 6053d3a4793e5bde6299ac5388e76a3bf679ff65 upstream.
In order to support the 1024x600 panel on Yeeloong Loongson MIPS
laptop, the original 1024x768-16 table was modified to 1024x600-16,
without leaving the original. It causes problem on x86 laptop as
the 1024x768-16 support was still claimed but not working.
Fix it by introducing the 1024x768-16 mode.
commit 9e0e59993df0601cddb95c4f6c61aa3d5e753c00 upstream.
On a Thinkpad s30 (Pentium III / i440MX, Lynx3DM), running fbtest or X
will crash the machine instantly, because the VRAM/framebuffer is not
mapped correctly.
On SM712, the framebuffer starts at the beginning of address space, but
SM720's framebuffer starts at the 1 MiB offset from the beginning. However,
sm712fb fails to take this into account, as a result, writing to the
framebuffer will destroy all the registers and kill the system immediately.
Another problem is the driver assumes 8 MiB of VRAM for SM720, but some
SM720 system, such as this IBM Thinkpad, only has 4 MiB of VRAM.
Fix this problem by removing the hardcoded VRAM size, adding a function to
query the amount of VRAM from register MCR76 on SM720, and adding proper
framebuffer offset.
Please note that the memory map may have additional problems on Big-Endian
system, which is not available for testing by myself. But I highly suspect
that the original code is also broken on Big-Endian machines for SM720, so
at least we are not making the problem worse. More, the driver also assumed
SM710/SM712 has 4 MiB of VRAM, but it has a 2 MiB version as well, and used
in earlier laptops, such as IBM Thinkpad 240X, the driver would probably
crash on them. I've never seen one of those machines and cannot fix it, but
I have documented these problems in the comments.
commit ec1587d5073f29820e358f3a383850d61601d981 upstream.
When the machine is booted in VGA mode, loading sm712fb would cause
a glitch of random pixels shown on the screen. To prevent it from
happening, we first clear the entire framebuffer, and we also need
to stop calling smtcfb_setmode() during initialization, the fbdev
layer will call it for us later when it's ready.
commit 8069053880e0ee3a75fd6d7e0a30293265fe3de4 upstream.
On a Thinkpad s30 (Pentium III / i440MX, Lynx3DM), rebooting with
sm712fb framebuffer driver would cause a white screen of death on
the next POST, presumably the proper timings for the LCD panel was
not reprogrammed properly by the BIOS.
Experiments showed a few CRTC Scratch Registers, including CRT3D,
CRT3E and CRT3F may be used internally by BIOS as some flags. CRT3B is
a hardware testing register, we shouldn't mess with it. CRT3C has
blanking signal and line compare control, which is not needed for this
driver.
Stop writing to CR3B-CR3F (a.k.a CRT3B-CRT3F) registers. Even if these
registers don't have side-effect on other systems, writing to them is
also highly questionable.
commit dcf9070595e100942c539e229dde4770aaeaa4e9 upstream.
On a Thinkpad s30 (Pentium III / i440MX, Lynx3DM), the amount of Video
RAM is not detected correctly by the xf86-video-siliconmotion driver.
This is because sm712fb overwrites the GPR71 Scratch Pad Register, which
is set by BIOS on x86 and used to indicate amount of VRAM.
Other Scratch Pad Registers, including GPR70/74/75, don't have the same
side-effect, but overwriting to them is still questionable, as they are
not related to modesetting.
Stop writing to SR70/71/74/75 (a.k.a GPR70/71/74/75).
commit 5481115e25e42b9215f2619452aa99c95f08492f upstream.
sm712fb framebuffer driver would cause the role of brightness up/down
button to swap.
Experiments showed the FPR30 register caused this behavior. Moreover,
even if this register don't have side-effect on other systems, over-
writing it is also highly questionable, since it was originally
configurated by the motherboard manufacturer by hardwiring pull-down
resistors to indicate the type of LCD panel. We should not mess with
it.
Stop writing to the SR30 (a.k.a FPR30) register.
commit f8585539df0a1527c78b5d760665c89fe1c105a9 upstream.
The following commit:
38ac0287b7f4 ("fbdev/efifb: Honour UEFI memory map attributes when mapping the FB")
updated the EFI framebuffer code to use memory mappings for the linear
framebuffer that are permitted by the memory attributes described by the
EFI memory map for the particular region, if the framebuffer happens to
be covered by the EFI memory map (which is typically only the case for
framebuffers in shared memory). This is required since non-x86 systems
may require cacheable attributes for memory mappings that are shared
with other masters (such as GPUs), and this information cannot be
described by the Graphics Output Protocol (GOP) EFI protocol itself,
and so we rely on the EFI memory map for this.
As reported by James, this breaks some x86 systems:
[ 1.173368] efifb: probing for efifb
[ 1.173386] efifb: abort, cannot remap video memory 0x1d5000 @ 0xcf800000
[ 1.173395] Trying to free nonexistent resource <00000000cf800000-00000000cf9d4bff>
[ 1.173413] efi-framebuffer: probe of efi-framebuffer.0 failed with error -5
The problem turns out to be that the memory map entry that describes the
framebuffer has no memory attributes listed at all, and so we end up with
a mem_flags value of 0x0.
So work around this by ensuring that the memory map entry's attribute field
has a sane value before using it to mask the set of usable attributes.
Reported-by: James Hilliard <james.hilliard1@gmail.com>
Tested-by: James Hilliard <james.hilliard1@gmail.com>
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: <stable@vger.kernel.org> # v4.19+
Cc: James Morse <james.morse@arm.com>
Cc: Matt Fleming <matt@codeblueprint.co.uk>
Cc: Peter Jones <pjones@redhat.com>
Cc: linux-efi@vger.kernel.org
Fixes: 38ac0287b7f4 ("fbdev/efifb: Honour UEFI memory map attributes when ...")
Link: http://lkml.kernel.org/r/20190516213159.3530-2-ard.biesheuvel@linaro.org
commit b906c056b6023c390f18347169071193fda57dde upstream.
Multiplying the Memory Controller clock rate by the tick count results
in an integer overflow and in result the truncated tick value is being
programmed into hardware, such that the GR3D memory client performance is
reduced by two times.
Cc: stable <stable@vger.kernel.org>
Signed-off-by: Dmitry Osipenko <digetx@gmail.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
commit 43a0541e312f7136e081e6bf58f6c8a2e9672688 upstream.
Both Tegra30 and Tegra114 have 4 ASID's and the corresponding bitfield of
the TLB_FLUSH register differs from later Tegra generations that have 128
ASID's.
In a result the PTE's are now flushed correctly from TLB and this fixes
problems with graphics (randomly failing tests) on Tegra30.
Acked-by: Thierry Reding <treding@nvidia.com>
Signed-off-by: Joerg Roedel <jroedel@suse.de>
commit babc250e278eac7b0e671bdaedf833759b43bb78 upstream.
Rendering calls may be done simultaneously from the workqueue,
dlfb_ops_write, dlfb_ops_ioctl, dlfb_ops_set_par and dlfb_dpy_deferred_io.
The code is robust enough so that it won't crash on concurrent rendering.
However, concurrent rendering may cause display corruption if the same
pixel is simultaneously being rendered. In order to avoid this corruption,
this patch adds a mutex around the rendering calls.
Cc: Bernie Thompson <bernie@plugable.com>
Cc: Ladislav Michl <ladis@linux-mips.org>
[b.zolnierkie: replace "dlfb:" with "uldfb:" in the patch summary]
commit 6b11f9d8433b471fdd3ebed232b43a4b723be6ff upstream.
If a framebuffer device is used as a console, the rendering calls
(copyarea, fillrect, imageblit) may be done with the console spinlock
held. On udlfb, these function call dlfb_handle_damage that takes a
blocking semaphore before acquiring an URB.
In order to fix the bug, this patch changes the calls copyarea, fillrect
and imageblit to offload USB work to a workqueue.
A side effect of this patch is 3x improvement in console scrolling speed
because the device doesn't have to be updated after each copyarea call.
commit bd86b6c5c60711dbd4fa21bdb497a188ecb6cf63 upstream.
Remove the unused parameter "data" and unused variable "ret".
commit fb903392131a324a243c7731389277db1cd9f8df upstream.
This patch fixes definition of several clock gate and select register
that is wrong for rk3328 referring to the TRM and vendor kernel.
Also use correct number of softrst registers.
Fix clock definition for:
- clk_crypto
- aclk_h265
- pclk_h265
- aclk_h264
- hclk_h264
- aclk_axisram
- aclk_gmac
- aclk_usb3otg
Fixes: fe3511ad8a1c ("clk: rockchip: add clock controller for rk3328")
Signed-off-by: Jonas Karlman <jonas@kwiboo.se>
Tested-by: Peter Geis <pgwipeout@gmail.com>
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
commit be17ca6ac76a5cfd07cc3a0397dd05d6929fcbbb upstream.
PLLs with tuner_en bit, such as APLL1, need to disable
tuner_en before apply new frequency settings, or the new frequency
settings (pcw) will not be applied.
The tuner_en bit will be disabled during changing PLL rate
and be restored after new settings applied.
Fixes: e2f744a82d725 (clk: mediatek: Add MT2712 clock support)
Signed-off-by: Owen Chen <owen.chen@mediatek.com>
Signed-off-by: Weiyi Lu <weiyi.lu@mediatek.com>
Reviewed-by: James Liao <jamesjj.liao@mediatek.com>
Reviewed-by: Matthias Brugger <matthias.bgg@gmail.com>
Signed-off-by: Stephen Boyd <sboyd@kernel.org>
commit 40db569d6769ffa3864fd1b89616b1a7323568a8 upstream.
There are wrongly set parenthesis in the code that are resulting in a
wrong configuration being programmed for PLLM. The original fix was made
by Danny Huang in the downstream kernel. The patch was tested on Nyan Big
Tegra124 chromebook, PLLM rate changing works correctly now and system
doesn't lock up after changing the PLLM rate due to EMC scaling.
Tested-by: Steev Klimaszewski <steev@kali.org>
Acked-By: Peter De Schrijver <pdeschrijver@nvidia.com>
commit 9f77a60669d13ed4ddfa6cd7374c9d88da378ffa upstream.
clk_gate_ufs_subsys is a system bus clock, turning off it will
introduce lockup issue during system suspend flow. Let's mark
clk_gate_ufs_subsys as critical clock, thus keeps it on during
system suspend and resume.
Fixes: d374e6fd5088 ("clk: hisilicon: Add clock driver for hi3660 SoC")
Cc: Zhong Kaihua <zhongkaihua@huawei.com>
Cc: John Stultz <john.stultz@linaro.org>
Cc: Zhangfei Gao <zhangfei.gao@linaro.org>
Suggested-by: Dong Zhang <zhangdong46@hisilicon.com>
Signed-off-by: Leo Yan <leo.yan@linaro.org>
commit b79656ed44c6865e17bcd93472ec39488bcc4984 upstream.
Systemd triggers the following warning during IPoIB device load:
mlx5_core 0000:00:0c.0 ib0: "systemd-udevd" wants to know my dev_id.
Should it look at dev_port instead?
See Documentation/ABI/testing/sysfs-class-net for more info.
This is caused due to user space attempt to differentiate old systems
without dev_port and new systems with dev_port. In case dev_port will be
zero, the systemd will try to read dev_id instead.
There is no need to print a warning in such case, because it is valid
situation and it is needed to ensure systemd compatibility with old
kernels.
Link: https://github.com/systemd/systemd/blob/master/src/udev/udev-builtin-net_id.c#L358
Cc: <stable@vger.kernel.org> # 4.19
Fixes: f6350da41dc7 ("IB/ipoib: Log sysfs 'dev_id' accesses from userspace")
Signed-off-by: Leon Romanovsky <leonro@mellanox.com>
Signed-off-by: Jason Gunthorpe <jgg@mellanox.com>
commit ddcdc368b1033e19fd3a5f750752e10e28a87826 upstream.
get_zeroed_page() returns a virtual address for the page which is better
than allocating a struct page and doing a permanent kmap on it.
Reviewed-by: Haggai Eran <haggaie@mellanox.com>
commit 107927fa597c99eaeee4f51865ca0956ec71b6a2 upstream.
In imx_media_create_csi_of_links(), the 'struct v4l2_fwnode_link' must
be cleared for each endpoint iteration, otherwise if the remote port
has no "reg" property, link.remote_port will not be reset to zero.
This was discovered on the i.MX53 SMD board, since the OV5642 connects
directly to ipu1_csi0 and has a single source port with no "reg"
property.
Fixes: 621b08eabcddb ("media: staging/imx: remove static media link arrays")
Signed-off-by: Steve Longerbeam <slongerbeam@gmail.com>
Signed-off-by: Hans Verkuil <hverkuil-cisco@xs4all.nl>
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
commit 904371f90b2c0c749a5ab75478c129a4682ac3d8 upstream.
On i.MX6, the nearest upstream entity to the CSI can only be the
CSI video muxes or the Synopsys DW MIPI CSI-2 receiver.
However the i.MX53 has no CSI video muxes or a MIPI CSI-2 receiver.
So allow for the nearest upstream entity to the CSI to be something
other than those.
Fixes: bf3cfaa712e5c ("media: staging/imx: get CSI bus type from nearest
upstream entity")
commit 933c1320847f5ed6b61a7d10f0a948aa98ccd7b0 upstream.
After removal of clock_start() from before soc_camera_init_i2c() in
soc_camera_probe() by commit 9aea470b399d ("[media] soc-camera: switch
I2C subdevice drivers to use v4l2-clk") introduced in v3.11, the ov6650
driver could no longer probe the sensor successfully because its clock
was no longer turned on in advance. The issue was initially worked
around by adding that missing clock_start() equivalent to OMAP1 camera
interface driver - the only user of this sensor - but a propoer fix
should be rather implemented in the sensor driver code itself.
Fix the issue by inserting a delay between the clock is turned on and
the sensor I2C registers are read for the first time.
Tested on Amstrad Delta with now out of tree but still locally
maintained omap1_camera host driver.
Fixes: 9aea470b399d ("[media] soc-camera: switch I2C subdevice drivers to use v4l2-clk")
Signed-off-by: Janusz Krzysztofik <jmkrzyszt@gmail.com>
Signed-off-by: Sakari Ailus <sakari.ailus@linux.intel.com>
commit e6577cb5103b7ca7c0204c0c86ef4af8aa6288f6 upstream.
There seems to be a missing bit-wise or operator when setting val,
fix this by adding it in.
Fixes: 2796ceb0c18a ("phy: ti-pipe3: Update pcie phy settings")
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
commit b1a0ba8f772d7a6dcb5aa3e856f5bd8274989ebe upstream.
The ACEPC T8 and T11 mini PCs contain quite generic names in the sys_vendor
and product_name DMI strings, without this patch brcmfmac will try to load:
"brcmfmac43455-sdio.Default string-Default string.txt" as nvram file which
is way too generic.
The DMI strings on which we are matching are somewhat generic too, but
"To be filled by O.E.M." is less common then "Default string" and the
system-sku and bios-version strings are pretty unique. Beside the DMI
strings we also check the wifi-module chip-id and revision. I'm confident
that the combination of all this is unique.
Both the T8 and T11 use the same wifi-module, this commit adds DMI
quirks for both mini PCs pointing to brcmfmac43455-sdio.acepc-t8.txt .
BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1690852
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
commit 8149069db81853570a665f5e5648c0e526dc0e43 upstream.
The function p54p_probe takes an extra reference count of the PCI
device. However, the extra reference count is not dropped when it fails
to enable the PCI device. This patch fixes the bug.
Signed-off-by: Pan Bian <bianpan2016@163.com>
Acked-by: Christian Lamparter <chunkeey@gmail.com>
commit 4e0eaf239fb33ebc671303e2b736fa043462e2f4 upstream.
Currently, the pages that are allocated for the single mode of MSC are not
mapped into the device's dma space and the code is incorrectly using
*_to_phys() in place of a dma address. This fails with IOMMU enabled and
is otherwise bad practice.
Fix the single mode buffer allocation to map the pages into the device's
DMA space.
Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Fixes: ba82664c134e ("intel_th: Add Memory Storage Unit driver")
Cc: stable@vger.kernel.org # v4.4+
commit ed4d0a4ea11e19863952ac6a7cea3bbb27ccd452 upstream.
The on-disk value is little endian and we need to convert it to
native endian before storing the value in the in-core structure.
Fixes: 7564beda19b36 ("md-cluster/raid10: support add disk under grow mode")
Cc: <stable@vger.kernel.org> # 4.20+
Acked-by: Guoqing Jiang <gqjiang@suse.com>
Signed-off-by: Song Liu <songliubraving@fb.com>
