commit a09d431f344d854e4fe9cfac44f78cb8202f3eb7 upstream.
When the force changes went in back in 3.3.0, we ended up returning
disconnected in the !force case, and the connected in when forced,
as it hit the hardcoded check.
Fix it so all exits go via the hardcoded check and stop spurious
modesets on platforms with hardcoded EDIDs.
Reported-by: Evan McNabb (Red Hat)
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
commit 16a5e32b83fd946312b9b13590c75d20c95c5202 upstream.
My rv515 card is very flaky with msi enabled. Every so often it loses a rearm
and never comes back, manually banging the rearm brings it back.
commit e36325071832f1ba96ac54fb8ba1459f08b05dd8 upstream.
The check of the encoder type in the commit [e00e8b5e: drm/radeon/kms:
fix analog load detection on DVI-I connectors] is obviously wrong, and
it's the culprit of the regression on my workstation with DVI-analog
connection resulting in the blank output.
Fixed the typo now.
commit c291be9dba370ba696a0d482249a212cf5c15f45 upstream.
Upon lastclose(), we switch back to the fbcon configuration. This
requires taking the mode_config lock in order to serialise the change
with output probing elsewhere.
Reported-by: Oleksij Rempel <bug-track@fisher-privat.net>
References: https://bugs.freedesktop.org/show_bug.cgi?id=48652
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 07c0ea874d43c299d185948452945a361052b6e3 upstream.
Add Atheros maryann 0cf3:311d PIDVID support
This module is AR3012 Series.
Include /sys/kernel/debug/usb/devices output here for reference
before:
T: Bus=04 Lev=01 Prnt=01 Port=01 Cnt=01 Dev#= 2 Spd=12 MxCh= 0
D: Ver= 1.10 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=0cf3 ProdID=311d Rev= 0.01
S: Manufacturer=Atheros Communications
S: Product=Bluetooth USB Host Controller
S: SerialNumber=Alaska Day 2006
C:* #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=100mA
I:* If#= 0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=81(I) Atr=03(Int.) MxPS= 16 Ivl=1ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
I:* If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 0 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 0 Ivl=1ms
I: If#= 1 Alt= 1 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 9 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 9 Ivl=1ms
I: If#= 1 Alt= 2 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 17 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 17 Ivl=1ms
I: If#= 1 Alt= 3 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 25 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 25 Ivl=1ms
I: If#= 1 Alt= 4 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 33 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 33 Ivl=1ms
I: If#= 1 Alt= 5 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 49 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 49 Ivl=1ms
after:
P: Vendor=0cf3 ProdID=311d Rev= 0.02
Signed-off-by: Cho, Yu-Chen <acho@suse.com>
cked-by: Marcel Holtmann <marcel@holtmann.org>
Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
Cc: Jonathan Nieder <jrnieder@gmail.com>
commit 9498ba7a1d38d42eef4ef6d906ab1743c9f0fd6f upstream.
The bluetooth module in the Asus UX31/UX21 is based on Atheros AR3012
and requires a firmware to be uploaded before it's usable.
output of usb-devices for this module:
T: Bus=01 Lev=02 Prnt=02 Port=07 Cnt=03 Dev#= 6 Spd=12 MxCh= 0
P: Vendor=13d3 ProdID=3375 Rev=00.02
C: #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=100mA
I: If#= 0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
I: If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
Signed-off-by: Eran <eran@over-here.org>
Tested-by: Michal Labedzki <michal.labedzki@tieto.com>
Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
commit de3bd7e6de25141c466773c2e0fa319b2fa93655 upstream.
Fix for:
drivers/spi/spi-topcliff-pch.c: In function ‘pch_spi_handler_sub’:
drivers/spi/spi-topcliff-pch.c:325:17: warning: ‘bpw_len’ may be
used uninitialized in this function [-Wuninitialized]
drivers/spi/spi-topcliff-pch.c:325:42: warning: ‘rx_index’ may be
drivers/spi/spi-topcliff-pch.c:325:42: warning: ‘tx_index’ may be
Move usage of tx_index, rx_index and bpw_len into the same
block as where they are set to prevent uninitialized usage.
v2: instead of init variables with 0 move the whole block
[This patch title "warnings" makes you think "This patch is not
for bug fix". However, this patch surely patch for bug fix.]
Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de>
Signed-off-by: Tomoya MORINAGA <tomoya.rohm@gmail.com>
commit 833310402c54ad9b676b465fc53ad276b13d36be upstream.
ISSUE:
USB Suspend interrupts occur frequently.
CAUSE:
When it is called pch_udc_reconnect() in USB Suspend, it repeats reset and
Suspend.
SOLUTION:
pch_udc_reconnect() does not enable all interrupts. When an enumeration event
occurred the driver enables all interrupts.
Signed-off-by: Felipe Balbi <balbi@ti.com>
connect/disconnect issue
commit 1c575d2d2e3ff2a7cb3c2e2165064199cfd8ad32 upstream.
ISSUE:
After a USB cable is connect/disconnected, the system rarely freezes.
CAUSE:
Since the USB device controller cannot know to disconnect the USB cable, when
it is used without detecting VBUS by GPIO, the UDC driver does not notify to
USB Gadget.
Since USB Gadget cannot know to disconnect, a false setting occurred when the
USB cable is connected/disconnect repeatedly.
commit 84566abba058b2aae8d603dfa90b5a3778a6714f upstream.
ISSUE:
After USB Suspend, a system rarely freezes.
CAUSE:
When USB Suspend occurred, the driver is not notifying
a gadget of the event.
commit c802672cd36cd063bfd54d54c8c34825ab5b2357 upstream.
ISSUE:
If the return value of pch_udc_pcd_init() is False, the return value of
this function is unsettled.
Since pch_udc_pcd_init() always returns 0, there is not actually the issue.
CAUSE:
If pch_udc_pcd_init() is True, the variable, retval, is not set for an
appropriate value.
commit c50a3bff0edb0acd49d8033a12ea4668e09a31ad upstream.
ISSUE:
When the driver notifies a gadget of a disconnect event, a system
rarely freezes.
CAUSE:
When the driver calls dev->driver->disconnect(), it is not calling
spin_unlock().
commit c7713e736526d8c9f6f87716fb90562a8ffaff2c upstream.
The xHCI 1.0 spec errata released on June 13, 2011, changes the ordering
that the xHCI registers are saved and restored in. It moves the
interrupt pending (IMAN) and interrupt control (IMOD) registers to be
saved and restored last. I believe that's because the host controller
may attempt to fetch the event ring table when interrupts are
re-enabled. Therefore we need to restore the event ring registers
before we re-enable interrupts.
This should be backported to kernels as old as 2.6.37, that contain the
commit 5535b1d5f8885695c6ded783c692e3c0d0eda8ca "USB: xHCI: PCI power
management implementation"
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Tested-by: Elric Fu <elricfu1@gmail.com>
Cc: Andiry Xu <andiry.xu@amd.com>
commit c3d8b76f61586714cdc5f219ba45592a54caaa55 upstream.
Commit 360f748b204275229f8398cb2f9f53955db1503b
"serial: PL011: clear pending interrupts"
attempts to clear interrupts by writing to a
yet-unassigned memory address. This fixes the issue.
The breaking patch is marked for stable so should be
carried along with the other patch.
Cc: Shreshtha Kumar Sahu <shreshthakumar.sahu@stericsson.com>
Cc: Nicolas Pitre <nico@fluxnic.net>
Reported-by: Viresh Kumar <viresh.kumar@st.com>
Tested-by: Grant Likely <grant.likely@secretlab.ca>
commit 9b96fbacda34079dea0638ee1e92c56286f6114a upstream.
Chanho Min reported that when the boot loader transfers
control to the kernel, there may be pending interrupts
causing the UART to lock up in an eternal loop trying to
pick tokens from the FIFO (since the RX interrupt flag
indicates there are tokens) while in practice there are
no tokens - in fact there is only a pending IRQ flag.
This patch address the issue with a combination of two
patches suggested by Russell King that clears and mask
all interrupts at probe() and clears any pending error
and RX interrupts at port startup time.
We suspect the spurious interrupts are a side-effect of
switching the UART from FIFO to non-FIFO mode.
Reported-by: Chanho Min <chanho0207@gmail.com>
Suggested-by: Russell King <linux@arm.linux.org.uk>
Reviewed-by: Jong-Sung Kim <neidhard.kim@lge.com>
commit 95018a53f7653e791bba1f54c8d75d9cb700d1bd upstream.
Re-define XHCI_LEGACY_DISABLE_SMI and used it in right way. All SMI enable
bits will be cleared to zero and flag bits 29:31 are also cleared to zero.
Other bits should be presvered as Table 146.
This patch should be backported to kernels as old as 2.6.31.
Signed-off-by: Alex He <alex.he@amd.com>
commit 457a4f61f9bfc3ae76e5b49f30f25d86bb696f67 upstream.
The suspend operation of VIA xHCI host have some issues and
hibernate operation works fine, so The XHCI_RESET_ON_RESUME
quirk is added for it.
This patch should base on "xHCI: Don't write zeroed pointer
to xHC registers" that is released by Sarah. Otherwise, the
host system error will ocurr in the hibernate operation
process.
This should be backported to stable kernels as old as 2.6.37,
that contain the commit c877b3b2ad5cb9d4fe523c5496185cc328ff3ae9
"xhci: Add reset on resume quirk for asrock p67 host".
Signed-off-by: Elric Fu <elricfu1@gmail.com>
commit d8aec3dbdfd02627e198e7956ab4aaeba2a349fa upstream.
When the Seagate Goflex USB3.0 device is attached to VIA xHCI
host, sometimes the device will downgrade mode to high speed.
By the USB analyzer, I found the device finished the link
training process and worked at superspeed mode. But the device
descriptor got from the device shows the device works at 2.1.
It is very strange and seems like the device controller of
Seagate Goflex has a little confusion.
The first 8 bytes of device descriptor should be:
12 01 00 03 00 00 00 09
But the first 8 bytes of wrong device descriptor are:
12 01 10 02 00 00 00 40
The wrong device descriptor caused the initialization of mass
storage failed. After a while, the device would be recognized
as a high speed device and works fine.
This patch will warm reset the device to fix the issue after
finding the bcdUSB field of device descriptor isn't 0x0300
but the speed mode of device is superspeed.
This patch should be backported to kernels as old as 3.2, or ones that
contain the commit 75d7cf72ab9fa01dc70877aa5c68e8ef477229dc "usbcore:
refine warm reset logic".
Acked-by: Andiry Xu <Andiry.Xu@amd.com>
Acked-by: Sergei Shtylyov <sshtylyov@mvista.com>
commit fb3d85bc7193f23c9a564502df95564c49a32c91 upstream.
The xhci_save_registers() function saved the event ring dequeue pointer
in the s3 register structure, but xhci_restore_registers() never
restored it. No other code in the xHCI successful resume path would
ever restore it either. Fix that.
management implementation".
commit 159e1fcc9a60fc7daba23ee8fcdb99799de3fe84 upstream.
When xhci_mem_cleanup() is called, we can't be sure if the xHC is
actually halted. We can ask the xHC to halt by writing to the RUN bit
in the command register, but that might timeout due to a HW hang.
If the host controller is still running, we should not write zeroed
values to the event ring dequeue pointers or base tables, the DCBAA
pointers, or the command ring pointers. Eric Fu reports his VIA VL800
host accesses the event ring pointers after a failed register restore on
resume from suspend. The hypothesis is that the host never actually
halted before the register write to change the event ring pointer to
zero.
Remove all writes of zeroed values to pointer registers in
xhci_mem_cleanup(). Instead, make all callers of the function reset the
host controller first, which will reset those registers to zero.
xhci_mem_init() is the only caller that doesn't first halt and reset the
host controller before calling xhci_mem_cleanup().
This should be backported to kernels as old as 2.6.32.
commit 4e833c0b87a30798e67f06120cecebef6ee9644c upstream.
While we're at that, define IMAN bitfield to aid readability.
The interrupt enable bit should be set once on driver init, and we
shouldn't need to continually re-enable it. Commit c21599a3 introduced
a read of the irq_pending register, and that allows us to preserve the
state of the IE bit. Before that commit, we were blindly writing 0x3 to
the register.
This patch should be backported to kernels as old as 2.6.36, or ones
that contain the commit c21599a36165dbc78b380846b254017a548b9de5 "USB:
xhci: Reduce reads and writes of interrupter registers".
commit cd4376e23a59a2adf3084cb5f4a523e6d5fd4e49 upstream.
This patch (as1532) fixes a mistake in the USB suspend code. When the
system is going to sleep, we should ignore errors in powering down USB
devices, because they don't really matter. The devices will go to low
power anyway when the entire USB bus gets suspended (except for
SuperSpeed devices; maybe they will need special treatment later).
However we should not ignore errors in suspending root hubs,
especially if the error indicates that the suspend raced with a wakeup
request. Doing so might leave the bus powered on while the system was
supposed to be asleep, or it might cause the suspend of the root hub's
parent controller device to fail, or it might cause a wakeup request
to be ignored.
The patch fixes the problem by ignoring errors only when the device in
question is not a root hub.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Reported-by: Chen Peter <B29397@freescale.com>
Tested-by: Chen Peter <peter.chen@freescale.com>
commit bcf398537630bf20b4dbe59ba855b69f404c93cf upstream.
This patch (as1517b) fixes an error in the USB scatter-gather library.
The library code uses urb->dev to determine whether or nor an URB is
currently active; the completion handler sets urb->dev to NULL.
However the core unlinking routines need to use urb->dev. Since
unlinking always racing with completion, the completion handler must
not clear urb->dev -- it can lead to invalid memory accesses when a
transfer has to be cancelled.
This patch fixes the problem by getting rid of the lines that clear
urb->dev after urb has been submitted. As a result we may end up
trying to unlink an URB that failed in submission or that has already
completed, so an extra check is added after each unlink to avoid
printing an error message when this happens. The checks are updated
in both sg_complete() and sg_cancel(), and the second is updated to
match the first (currently it prints out unnecessary warning messages
if a device is unplugged while a transfer is in progress).
Reported-and-tested-by: Illia Zaitsev <I.Zaitsev@adbglobal.com>
CC: Ming Lei <tom.leiming@gmail.com>
commit c5d703dcc776cb542b41665f2b7e2ba054efb4a7 upstream.
Just add new device id. 3G works fine, LTE not tested.
Signed-off-by: Anton Samokhvalov <pg83@yandex.ru>
when the device is removed
commit 876ae50d94b02f3f523aa451b45ec5fb9c25d221 upstream.
There are two issues here, one is that the device is generating
spurious very fast modem status line changes somewhere:
CTS becomes high then low 18µs later:
[121226.924373] ftdi_process_packet: prev rng=0 dsr=10 dcd=0 cts=6
[121226.924378] ftdi_process_packet: status=10 prev=00 diff=10
[121226.924382] ftdi_process_packet: now rng=0 dsr=10 dcd=0 cts=7
(wake_up_interruptible is called)
[121226.924391] ftdi_process_packet: prev rng=0 dsr=10 dcd=0 cts=7
[121226.924394] ftdi_process_packet: status=00 prev=10 diff=10
[121226.924397] ftdi_process_packet: now rng=0 dsr=10 dcd=0 cts=8
This wakes up the task in TIOCMIWAIT:
[121226.924405] ftdi_ioctl: 19451 rng=0->0 dsr=10->10 dcd=0->0 cts=6->8
(wait from 20:51:46 returns and observes both changes)
Which then calls TIOCMIWAIT again:
20:51:46.400239 ioctl(3, TIOCMIWAIT, 0x20) = 0
22:11:09.441818 ioctl(3, TIOCMGET, [TIOCM_DTR|TIOCM_RTS]) = 0
22:11:09.442812 ioctl(3, TIOCMIWAIT, 0x20) = -1 EIO (Input/output error)
(the second wake_up_interruptible takes effect and an I/O error occurs)
The other issue is that TIOCMIWAIT will wait forever (unless the task is
interrupted) if the device is removed.
This change removes the -EIO return that occurs if the counts don't
appear to have changed. Multiple counts may have been processed as
one or the waiting task may have started waiting after recording the
current count.
It adds a bool to indicate that the device has been removed so that
TIOCMIWAIT doesn't wait forever, and wakes up any tasks so that they can
return -EIO.
Signed-off-by: Simon Arlott <simon@fire.lp0.eu>
commit fca5430d48d53eaf103498c33fd0d1984b9f448b upstream.
Handling of TIOCMIWAIT was changed by commit 1d749f9afa657f6ee9336b2bc1fcd750a647d157
USB: ftdi_sio.c: Use ftdi async_icount structure for TIOCMIWAIT, as in other drivers
FTDI_STATUS_B0_MASK does not indicate the changed modem status lines,
it indicates the value of the current modem status lines. An xor is
still required to determine which lines have changed.
The count was only being incremented if the line was high. The only
reason TIOCMIWAIT still worked was because the status packet is
repeated every 1ms, so the count was always changing. The wakeup
itself still ran based on the status lines changing.
This change fixes handling of updates to the modem status lines and
allows multiple processes to use TIOCMIWAIT concurrently.
Tested with two processes waiting on different status lines being
toggled independently.
Cc: Uwe Bonnes <bon@elektron.ikp.physik.tu-darmstadt.de>
commit 9ac2feb22b5b821d81463bef92698ef7682a3145 upstream.
Re-add NOVATELWIRELESS_PRODUCT_HSPA_HIGHSPEED to option_id array
Signed-off-by: Santiago Garcia Mantinan <manty@debian.org>
commit ce5c9851855bab190c9a142761d54ba583ab094c upstream.
DTR/RTS should only be raised when changing baudrate from B0 and not on
any baud rate change (> B0).
Reported-by: Søren Holm <sgh@sgh.dk>
Signed-off-by: Johan Hovold <jhovold@gmail.com>
commit a65a6f14dc24a90bde3f5d0073ba2364476200bf upstream.
Fix race between probe and open by making sure that the disconnected
flag is not cleared until all ports have been registered.
A call to tty_open while probe is running may get a reference to the
serial structure in serial_install before its ports have been
registered. This may lead to usb_serial_core calling driver open before
port is fully initialised.
With ftdi_sio this result in the following NULL-pointer dereference as
the private data has not been initialised at open:
[ 199.698286] IP: [<f811a089>] ftdi_open+0x59/0xe0 [ftdi_sio]
[ 199.698297] *pde = 00000000
[ 199.698303] Oops: 0000 [#1] PREEMPT SMP
[ 199.698313] Modules linked in: ftdi_sio usbserial
[ 199.698323]
[ 199.698327] Pid: 1146, comm: ftdi_open Not tainted 3.2.11 #70 Dell Inc. Vostro 1520/0T816J
[ 199.698339] EIP: 0060:[<f811a089>] EFLAGS: 00010286 CPU: 0
[ 199.698344] EIP is at ftdi_open+0x59/0xe0 [ftdi_sio]
[ 199.698348] EAX: 0000003e EBX: f5067000 ECX: 00000000 EDX: 80000600
[ 199.698352] ESI: f48d8800 EDI: 00000001 EBP: f515dd54 ESP: f515dcfc
[ 199.698356] DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068
[ 199.698361] Process ftdi_open (pid: 1146, ti=f515c000 task=f481e040 task.ti=f515c000)
[ 199.698364] Stack:
[ 199.698368] f811a9fe f811a9e0 f811b3ef 00000000 00000000 00001388 00000000 f4a86800
[ 199.698387] 00000002 00000000 f806e68e 00000000 f532765c f481e040 00000246 22222222
[ 199.698479] 22222222 22222222 22222222 f5067004 f5327600 f5327638 f515dd74 f806e6ab
[ 199.698496] Call Trace:
[ 199.698504] [<f806e68e>] ? serial_activate+0x2e/0x70 [usbserial]
[ 199.698511] [<f806e6ab>] serial_activate+0x4b/0x70 [usbserial]
[ 199.698521] [<c126380c>] tty_port_open+0x7c/0xd0
[ 199.698527] [<f806e660>] ? serial_set_termios+0xa0/0xa0 [usbserial]
[ 199.698534] [<f806e76f>] serial_open+0x2f/0x70 [usbserial]
[ 199.698540] [<c125d07c>] tty_open+0x20c/0x510
[ 199.698546] [<c10e9eb7>] chrdev_open+0xe7/0x230
[ 199.698553] [<c10e48f2>] __dentry_open+0x1f2/0x390
[ 199.698559] [<c144bfec>] ? _raw_spin_unlock+0x2c/0x50
[ 199.698565] [<c10e4b76>] nameidata_to_filp+0x66/0x80
[ 199.698570] [<c10e9dd0>] ? cdev_put+0x20/0x20
[ 199.698576] [<c10f3e08>] do_last+0x198/0x730
[ 199.698581] [<c10f4440>] path_openat+0xa0/0x350
[ 199.698587] [<c10f47d5>] do_filp_open+0x35/0x80
[ 199.698593] [<c144bfec>] ? _raw_spin_unlock+0x2c/0x50
[ 199.698599] [<c10ff110>] ? alloc_fd+0xc0/0x100
[ 199.698605] [<c10f0b72>] ? getname_flags+0x72/0x120
[ 199.698611] [<c10e4450>] do_sys_open+0xf0/0x1c0
[ 199.698617] [<c11fcc08>] ? trace_hardirqs_on_thunk+0xc/0x10
[ 199.698623] [<c10e458e>] sys_open+0x2e/0x40
[ 199.698628] [<c144c990>] sysenter_do_call+0x12/0x36
[ 199.698632] Code: 85 89 00 00 00 8b 16 8b 4d c0 c1 e2 08 c7 44 24 14 88 13 00 00 81 ca 00 00 00 80 c7 44 24 10 00 00 00 00 c7 44 24 0c 00 00 00 00 <0f> b7 41 78 31 c9 89 44 24 08 c7 44 24 04 00 00 00 00 c7 04 24
[ 199.698884] EIP: [<f811a089>] ftdi_open+0x59/0xe0 [ftdi_sio] SS:ESP 0068:f515dcfc
[ 199.698893] CR2: 0000000000000078
[ 199.698925] ---[ end trace 77c43ec023940cff ]---
Reported-and-tested-by: Ken Huang <csuhgw@gmail.com>
commit 867c902e07d5677e2a5b54c0435e589513abde48 upstream.
The following patch (MSI setting) is not enough.
commit e463595fd9c752fa4bf06b47df93ef9ade3c7cf0
Author: Alexander Stein <alexander.stein@systec-electronic.com>
Date: Mon Jul 4 08:58:31 2011 +0200
pch_uart: Add MSI support
Signed-off-by: Alexander Stein <alexander.stein@systec-electronic.com>
To enable MSI mode, PCI bus-mastering must be enabled.
This patch enables the setting.
cc: Alexander Stein <alexander.stein@systec-electronic.com>
commit 6f3603367b8f7c34598fdfc1058622e0e1951e98 upstream.
Since commit 96104eda0169 ("RDMA/core: Add SRQ type field"), kernel
users of SRQs need to specify srq_type = IB_SRQT_BASIC in struct
ib_srq_init_attr, or else most low-level drivers will fail in
when srpt_add_one() calls ib_create_srq() and gets -ENOSYS.
(mlx4_ib works OK nearly all of the time, because it just needs
srq_type != IB_SRQT_XRC. And apparently nearly everyone using
ib_srpt is using mlx4 hardware)
Reported-by: Alexey Shvetsov <alexxy@gentoo.org>
Signed-off-by: Roland Dreier <roland@purestorage.com>
commit b78f29ca0516266431688c5eb42d39ce42ec039a upstream.
This patch fix the oops below that catched in my machine
[ 81.560602] uvesafb: NVIDIA Corporation, GT216 Board - 0696a290, Chip Rev , OEM: NVIDIA, VBE v3.0
[ 81.609384] uvesafb: protected mode interface info at c000:d350
[ 81.609388] uvesafb: pmi: set display start = c00cd3b3, set palette = c00cd40e
[ 81.609390] uvesafb: pmi: ports = 3b4 3b5 3ba 3c0 3c1 3c4 3c5 3c6 3c7 3c8 3c9 3cc 3ce 3cf 3d0 3d1 3d2 3d3 3d4 3d5 3da
[ 81.614558] uvesafb: VBIOS/hardware doesn't support DDC transfers
[ 81.614562] uvesafb: no monitor limits have been set, default refresh rate will be used
[ 81.614994] uvesafb: scrolling: ypan using protected mode interface, yres_virtual=4915
[ 81.744147] kernel tried to execute NX-protected page - exploit attempt? (uid: 0)
[ 81.744153] BUG: unable to handle kernel paging request at c00cd3b3
[ 81.744159] IP: [<c00cd3b3>] 0xc00cd3b2
[ 81.744167] *pdpt = 00000000016d6001 *pde = 0000000001c7b067 *pte = 80000000000cd163
[ 81.744171] Oops: 0011 [#1] SMP
[ 81.744174] Modules linked in: uvesafb(+) cfbcopyarea cfbimgblt cfbfillrect
[ 81.744178]
[ 81.744181] Pid: 3497, comm: modprobe Not tainted 3.3.0-rc4NX+ #71 Acer Aspire 4741 /Aspire 4741
[ 81.744185] EIP: 0060:[<c00cd3b3>] EFLAGS: 00010246 CPU: 0
[ 81.744187] EIP is at 0xc00cd3b3
[ 81.744189] EAX: 00004f07 EBX: 00000000 ECX: 00000000 EDX: 00000000
[ 81.744191] ESI: f763f000 EDI: f763f6e8 EBP: f57f3a0c ESP: f57f3a00
[ 81.744192] DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068
[ 81.744195] Process modprobe (pid: 3497, ti=f57f2000 task=f748c600 task.ti=f57f2000)
[ 81.744196] Stack:
[ 81.744197] f82512c5 f759341c 00000000 f57f3a30 c124a9bc 00000001 00000001 000001e0
[ 81.744202] f8251280 f763f000 f7593400 00000000 f57f3a40 c12598dd f5c0c000 00000000
[ 81.744206] f57f3b10 c1255efe c125a21a 00000006 f763f09c 00000000 c1c6cb60 f7593400
[ 81.744210] Call Trace:
[ 81.744215] [<f82512c5>] ? uvesafb_pan_display+0x45/0x60 [uvesafb]
[ 81.744222] [<c124a9bc>] fb_pan_display+0x10c/0x160
[ 81.744226] [<f8251280>] ? uvesafb_vbe_find_mode+0x180/0x180 [uvesafb]
[ 81.744230] [<c12598dd>] bit_update_start+0x1d/0x50
[ 81.744232] [<c1255efe>] fbcon_switch+0x39e/0x550
[ 81.744235] [<c125a21a>] ? bit_cursor+0x4ea/0x560
[ 81.744240] [<c129b6cb>] redraw_screen+0x12b/0x220
[ 81.744245] [<c128843b>] ? tty_do_resize+0x3b/0xc0
[ 81.744247] [<c129ef42>] vc_do_resize+0x3d2/0x3e0
[ 81.744250] [<c129efb4>] vc_resize+0x14/0x20
[ 81.744253] [<c12586bd>] fbcon_init+0x29d/0x500
[ 81.744255] [<c12984c4>] ? set_inverse_trans_unicode+0xe4/0x110
[ 81.744258] [<c129b378>] visual_init+0xb8/0x150
[ 81.744261] [<c129c16c>] bind_con_driver+0x16c/0x360
[ 81.744264] [<c129b47e>] ? register_con_driver+0x6e/0x190
[ 81.744267] [<c129c3a1>] take_over_console+0x41/0x50
[ 81.744269] [<c1257b7a>] fbcon_takeover+0x6a/0xd0
[ 81.744272] [<c12594b8>] fbcon_event_notify+0x758/0x790
[ 81.744277] [<c10929e2>] notifier_call_chain+0x42/0xb0
[ 81.744280] [<c1092d30>] __blocking_notifier_call_chain+0x60/0x90
[ 81.744283] [<c1092d7a>] blocking_notifier_call_chain+0x1a/0x20
[ 81.744285] [<c124a5a1>] fb_notifier_call_chain+0x11/0x20
[ 81.744288] [<c124b759>] register_framebuffer+0x1d9/0x2b0
[ 81.744293] [<c1061c73>] ? ioremap_wc+0x33/0x40
[ 81.744298] [<f82537c6>] uvesafb_probe+0xaba/0xc40 [uvesafb]
[ 81.744302] [<c12bb81f>] platform_drv_probe+0xf/0x20
[ 81.744306] [<c12ba558>] driver_probe_device+0x68/0x170
[ 81.744309] [<c12ba731>] __device_attach+0x41/0x50
[ 81.744313] [<c12b9088>] bus_for_each_drv+0x48/0x70
[ 81.744316] [<c12ba7f3>] device_attach+0x83/0xa0
[ 81.744319] [<c12ba6f0>] ? __driver_attach+0x90/0x90
[ 81.744321] [<c12b991f>] bus_probe_device+0x6f/0x90
[ 81.744324] [<c12b8a45>] device_add+0x5e5/0x680
[ 81.744329] [<c122a1a3>] ? kvasprintf+0x43/0x60
[ 81.744332] [<c121e6e4>] ? kobject_set_name_vargs+0x64/0x70
[ 81.744335] [<c121e6e4>] ? kobject_set_name_vargs+0x64/0x70
[ 81.744339] [<c12bbe9f>] platform_device_add+0xff/0x1b0
[ 81.744343] [<f8252906>] uvesafb_init+0x50/0x9b [uvesafb]
[ 81.744346] [<c100111f>] do_one_initcall+0x2f/0x170
[ 81.744350] [<f82528b6>] ? uvesafb_is_valid_mode+0x66/0x66 [uvesafb]
[ 81.744355] [<c10c6994>] sys_init_module+0xf4/0x1410
[ 81.744359] [<c1157fc0>] ? vfsmount_lock_local_unlock_cpu+0x30/0x30
[ 81.744363] [<c144cb10>] sysenter_do_call+0x12/0x36
[ 81.744365] Code: f5 00 00 00 32 f6 66 8b da 66 d1 e3 66 ba d4 03 8a e3 b0 1c 66 ef b0 1e 66 ef 8a e7 b0 1d 66 ef b0 1f 66 ef e8 fa 00 00 00 61 c3 <60> e8 c8 00 00 00 66 8b f3 66 8b da 66 ba d4 03 b0 0c 8a e5 66
[ 81.744388] EIP: [<c00cd3b3>] 0xc00cd3b3 SS:ESP 0068:f57f3a00
[ 81.744391] CR2: 00000000c00cd3b3
[ 81.744393] ---[ end trace 18b2c87c925b54d6 ]---
Signed-off-by: Wang YanQing <udknight@gmail.com>
Cc: Michal Januszewski <spock@gentoo.org>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
commit bc67f63650fad6b3478d9ddfd5406d45a95987c9 upstream.
The total number of scatter gather elements in the CISS command
used by the scsi tape code was being cast to a u8, which can hold
at most 255 scatter gather elements. It should have been cast to
a u16. Without this patch the command gets rejected by the controller
since the total scatter gather count did not add up to the right
value resulting in an i/o error.
Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com>
commit 395d287526bb60411ff37b19ad9dd38b58ba8732 upstream.
The default is too small (1024 blocks), use h->cciss_max_sectors (8192 blocks)
Without this change, if you try to set the block size of a tape drive above
512*1024, via "mt -f /dev/st0 setblk nnn" where nnn is greater than 524288,
it won't work right.
commit acede70d6561f2d042d9dbb153d9a3469479c0ed upstream.
Follow altera_jtag_uart. This fixes a crash if there is a mistake in the DTS.
Signed-off-by: Yuriy Kozlov <ykozlov@ptcusa.com>
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
serial port
commit bc02d15a3452fdf9276e8fb89c5e504a88df888a upstream.
Workaround dropped notifications in the iir register. Register reads
coincident with new interrupt notifications sometimes result in this
device clearing the interrupt event without reporting it in the read
data.
The serial core already has a heuristic for determining when a device
has an untrustworthy iir register. In this case when we apriori know
that the iir is faulty use a flag (UPF_BUG_THRE) to bypass the test and
force usage of the background timer.
Acked-by: Alan Cox <alan@linux.intel.com>
Reported-by: Nhan H Mai <nhan.h.mai@intel.com>
Reported-by: Sudhakar Mamillapalli <sudhakar@fb.com>
Tested-by: Nhan H Mai <nhan.h.mai@intel.com>
Tested-by: Sudhakar Mamillapalli <sudhakar@fb.com>
commit 49b532f96fda23663f8be35593d1c1372c0f91e0 upstream.
This reverts commit 448ac154c957c4580531fa0c8f2045816fe2f0e7.
The semantic of UPF_IIR_ONCE is only guaranteed to workaround the race
condition in the kt serial's iir register if the only source of
interrupts is THRE (fifo-empty) events. An modem status event at the
wrong time can again cause an iir read to drop the 'empty' status
leading to a hang. So, revert this in preparation for using the
existing "I don't trust my iir register" workaround in the 8250 core
(UART_BUG_THRE).
Cc: Sudhakar Mamillapalli <sudhakar@fb.com>
commit 7b246a1d0dfe75346a22bf6589b858a0389e6df1 upstream.
Fix omission initialize ulcon in s3c24xx_serial_resetport(),
reset port function in drivers/tty/serial/samsung.c. It has
been happened from commit 0dfb3b41("serial: samsung: merge
all SoC specific port reset functions")
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
commit 3579812373aba92b2f3b632bdf99329bc3c05d62 upstream.
This reverts commit e86ff4a63c9fdd875ba8492577cd1ad2252f525c.
This tried to enforce the semantics of one interrupt per iir read of the
THRE (transmit-hold empty) status, but events from other sources
(particularly modem status) defeat this guarantee.
This change also broke 8250_pci suspend/resume support as
pciserial_resume_ports() re-runs .init() quirks, but does not run
.exit() quirks in pciserial_suspend_ports() leading to reports like:
sysfs: cannot create duplicate filename '/devices/pci0000:00/0000:00:16.3/msi_irqs'
...and a subsequent crash. The mismatch of init/exit at suspend/resume
seems like a bug in its own right.
commit 62d2feb9803f18c4e3c8a1a2c7e30a54df8a1d72 upstream.
Fix crash after issuing:
echo hmc5843 0x1e > /sys/class/i2c-dev/i2c-2/device/new_device
[ 37.180999] device: '2-001e': device_add
[ 37.188293] bus: 'i2c': add device 2-001e
[ 37.194549] PM: Adding info for i2c:2-001e
[ 37.200958] bus: 'i2c': driver_probe_device: matched device 2-001e with driver hmc5843
[ 37.210815] bus: 'i2c': really_probe: probing driver hmc5843 with device 2-001e
[ 37.224884] HMC5843 initialized
[ 37.228759] ------------[ cut here ]------------
[ 37.233612] kernel BUG at mm/slab.c:505!
[ 37.237701] Internal error: Oops - BUG: 0 [#1] PREEMPT
[ 37.243103] Modules linked in:
[ 37.246337] CPU: 0 Not tainted (3.3.1-gta04+ #28)
[ 37.251647] PC is at kfree+0x84/0x144
[ 37.255493] LR is at kfree+0x20/0x144
[ 37.259338] pc : [<c00b408c>] lr : [<c00b4028>] psr: 40000093
[ 37.259368] sp : de249cd8 ip : 0000000c fp : 00000090
[ 37.271362] r10: 0000000a r9 : de229eac r8 : c0236274
[ 37.276855] r7 : c09d6490 r6 : a0000013 r5 : de229c00 r4 : de229c10
[ 37.283691] r3 : c0f00218 r2 : 00000400 r1 : c0eea000 r0 : c00b4028
[ 37.290527] Flags: nZcv IRQs off FIQs on Mode SVC_32 ISA ARM Segment user
[ 37.298095] Control: 10c5387d Table: 9e1d0019 DAC: 00000015
[ 37.304107] Process sh (pid: 91, stack limit = 0xde2482f0)
[ 37.309844] Stack: (0xde249cd8 to 0xde24a000)
[ 37.314422] 9cc0: de229c10 de229c00
[ 37.322998] 9ce0: de229c10 ffffffea 00000005 c0236274 de140a80 c00b4798 dec00080 de140a80
[ 37.331573] 9d00: c032f37c dec00080 000080d0 00000001 de229c00 de229c10 c048d578 00000005
[ 37.340148] 9d20: de229eac 0000000a 00000090 c032fa40 00000001 00000000 00000001 de229c10
[ 37.348724] 9d40: de229eac 00000029 c075b558 00000001 00000003 00000004 de229c10 c048d594
[ 37.357299] 9d60: 00000000 60000013 00000018 205b0007 37332020 3432322e 5d343838 c0060020
[ 37.365905] 9d80: de251600 00000001 00000000 de251600 00000001 c0065a84 de229c00 de229c48
[ 37.374481] 9da0: 00000006 0048d62c de229c38 de229c00 de229c00 de1f6c00 de1f6c20 00000001
[ 37.383056] 9dc0: 00000000 c048d62c 00000000 de229c00 de229c00 de1f6c00 de1f6c20 00000001
[ 37.391632] 9de0: 00000000 c048d62c 00000000 c0330164 00000000 de1f6c20 c048d62c de1f6c00
[ 37.400207] 9e00: c0330078 de1f6c04 c078d714 de189b58 00000000 c02ccfd8 de1f6c20 c0795f40
[ 37.408782] 9e20: c0238330 00000000 00000000 c02381a8 de1b9fc0 de1f6c20 de1f6c20 de249e48
[ 37.417358] 9e40: c0238330 c0236bb0 decdbed8 de7d0f14 de1f6c20 de1f6c20 de1f6c54 de1f6c20
[ 37.425933] 9e60: 00000000 c0238030 de1f6c20 c078d7bc de1f6c20 c02377ec de1f6c20 de1f6c28
[ 37.434509] 9e80: dee64cb0 c0236138 c047c554 de189b58 00000000 c004b45c de1f6c20 de1f6cd8
[ 37.443084] 9ea0: c0edfa6c de1f6c00 dee64c68 de1f6c04 de1f6c20 dee64cb8 c047c554 de189b58
[ 37.451690] 9ec0: 00000000 c02cd634 dee64c68 de249ef4 de23b008 dee64cb0 0000000d de23b000
[ 37.460266] 9ee0: de23b007 c02cd78c 00000002 00000000 00000000 35636d68 00333438 00000000
[ 37.468841] 9f00: 00000000 00000000 001e0000 00000000 00000000 00000000 00000000 0a10cec0
[ 37.477416] 9f20: 00000002 de249f80 0000000d dee62990 de189b40 c0234d88 0000000d c010c354
[ 37.485992] 9f40: 0000000d de210f28 000acc88 de249f80 0000000d de248000 00000000 c00b7bf8
[ 37.494567] 9f60: de210f28 000acc88 de210f28 000acc88 00000000 00000000 0000000d c00b7ed8
[ 37.503143] 9f80: 00000000 00000000 0000000d 00000000 0007fa28 0000000d 000acc88 00000004
[ 37.511718] 9fa0: c000e544 c000e380 0007fa28 0000000d 00000001 000acc88 0000000d 00000000
[ 37.520294] 9fc0: 0007fa28 0000000d 000acc88 00000004 00000001 00000020 00000002 00000000
[ 37.528869] 9fe0: 00000000 beab8624 0000ea05 b6eaebac 600d0010 00000001 00000000 00000000
[ 37.537475] [<c00b408c>] (kfree+0x84/0x144) from [<c0236274>] (device_add+0x530/0x57c)
[ 37.545806] [<c0236274>] (device_add+0x530/0x57c) from [<c032fa40>] (iio_device_register+0x8c8/0x990)
[ 37.555480] [<c032fa40>] (iio_device_register+0x8c8/0x990) from [<c0330164>] (hmc5843_probe+0xec/0x114)
[ 37.565338] [<c0330164>] (hmc5843_probe+0xec/0x114) from [<c02ccfd8>] (i2c_device_probe+0xc4/0xf8)
[ 37.574737] [<c02ccfd8>] (i2c_device_probe+0xc4/0xf8) from [<c02381a8>] (driver_probe_device+0x118/0x218)
[ 37.584777] [<c02381a8>] (driver_probe_device+0x118/0x218) from [<c0236bb0>] (bus_for_each_drv+0x4c/0x84)
[ 37.594818] [<c0236bb0>] (bus_for_each_drv+0x4c/0x84) from [<c0238030>] (device_attach+0x78/0xa4)
[ 37.604125] [<c0238030>] (device_attach+0x78/0xa4) from [<c02377ec>] (bus_probe_device+0x28/0x9c)
[ 37.613433] [<c02377ec>] (bus_probe_device+0x28/0x9c) from [<c0236138>] (device_add+0x3f4/0x57c)
[ 37.622650] [<c0236138>] (device_add+0x3f4/0x57c) from [<c02cd634>] (i2c_new_device+0xf8/0x19c)
[ 37.631805] [<c02cd634>] (i2c_new_device+0xf8/0x19c) from [<c02cd78c>] (i2c_sysfs_new_device+0xb4/0x130)
[ 37.641754] [<c02cd78c>] (i2c_sysfs_new_device+0xb4/0x130) from [<c0234d88>] (dev_attr_store+0x18/0x24)
[ 37.651611] [<c0234d88>] (dev_attr_store+0x18/0x24) from [<c010c354>] (sysfs_write_file+0x10c/0x140)
[ 37.661193] [<c010c354>] (sysfs_write_file+0x10c/0x140) from [<c00b7bf8>] (vfs_write+0xb0/0x178)
[ 37.670410] [<c00b7bf8>] (vfs_write+0xb0/0x178) from [<c00b7ed8>] (sys_write+0x3c/0x68)
[ 37.678833] [<c00b7ed8>] (sys_write+0x3c/0x68) from [<c000e380>] (ret_fast_syscall+0x0/0x3c)
[ 37.687683] Code: 1593301c e5932000 e3120080 1a000000 (e7f001f2)
[ 37.700775] ---[ end trace aaf805debdb69390 ]---
Client data was assigned to iio_dev structure in probe but in
hmc5843_init_client function casted to private driver data structure which
is wrong. Possibly calling mutex_init(&data->lock); corrupt data
which the lead to above crash.
Signed-off-by: Marek Belisko <marek.belisko@open-nandra.com>
Acked-by: Jonathan Cameron <jic23@kernel.org>
commit 2f3972168353d355854d6381f1f360ce83b723e5 upstream.
The ST variants of the PL031 all require bit 26 in the control register
to be set before they work properly. Discovered this when testing on
the Nomadik board where it would suprisingly just stand still.
Cc: Mian Yousaf Kaukab <mian.yousaf.kaukab@stericsson.com>
Cc: Alessandro Rubini <rubini@unipv.it>
commit 33b69bf80a3704d45341928e4ff68b6ebd470686 upstream.
Do not close protocol driver until device has been unregistered.
This fixes a race between tty_close and hci_dev_open which can result in
a NULL-pointer dereference.
The line discipline closes the protocol driver while we may still have
hci_dev_open sleeping on the req_lock mutex resulting in a NULL-pointer
dereference when lock is acquired and hci_init_req called.
Bug is 100% reproducible using hciattach and a disconnected serial port:
0. # hciattach -n ttyO1 any noflow
1. hci_dev_open called from hci_power_on grabs req lock
2. hci_init_req executes but device fails to initialise (times out
eventually)
3. hci_dev_open is called from hci_sock_ioctl and sleeps on req lock
4. hci_uart_tty_close detaches protocol driver and cancels init req
5. hci_dev_open (1) releases req lock
6. hci_dev_open (3) grabs req lock, calls hci_init_req, which triggers oops
when request is prepared in hci_uart_send_frame
[ 137.201263] Unable to handle kernel NULL pointer dereference at virtual address 00000028
[ 137.209838] pgd = c0004000
[ 137.212677] [00000028] *pgd=00000000
[ 137.216430] Internal error: Oops: 17 [#1]
[ 137.220642] Modules linked in:
[ 137.223846] CPU: 0 Tainted: G W (3.3.0-rc6-dirty #406)
[ 137.230529] PC is at __lock_acquire+0x5c/0x1ab0
[ 137.235290] LR is at lock_acquire+0x9c/0x128
[ 137.239776] pc : [<c0071490>] lr : [<c00733f8>] psr: 20000093
[ 137.239776] sp : cf869dd8 ip : c0529554 fp : c051c730
[ 137.251800] r10: 00000000 r9 : cf8673c0 r8 : 00000080
[ 137.257293] r7 : 00000028 r6 : 00000002 r5 : 00000000 r4 : c053fd70
[ 137.264129] r3 : 00000000 r2 : 00000000 r1 : 00000000 r0 : 00000001
[ 137.270965] Flags: nzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel
[ 137.278717] Control: 10c5387d Table: 8f0f4019 DAC: 00000015
[ 137.284729] Process kworker/u:1 (pid: 7, stack limit = 0xcf8682e8)
[ 137.291229] Stack: (0xcf869dd8 to 0xcf86a000)
[ 137.295776] 9dc0: c0529554 00000000
[ 137.304351] 9de0: cf8673c0 cf868000 d03ea1ef cf868000 000001ef 00000470 00000000 00000002
[ 137.312927] 9e00: cf8673c0 00000001 c051c730 c00716ec 0000000c 00000440 c0529554 00000001
[ 137.321533] 9e20: c051c730 cf868000 d03ea1f3 00000000 c053b978 00000000 00000028 cf868000
[ 137.330078] 9e40: 00000000 00000000 00000002 00000000 00000000 c00733f8 00000002 00000080
[ 137.338684] 9e60: 00000000 c02a1d50 00000000 00000001 60000013 c0969a1c 60000093 c053b96c
[ 137.347259] 9e80: 00000002 00000018 20000013 c02a1d50 cf0ac000 00000000 00000002 cf868000
[ 137.355834] 9ea0: 00000089 c0374130 00000002 00000000 c02a1d50 cf0ac000 0000000c cf0fc540
[ 137.364410] 9ec0: 00000018 c02a1d50 cf0fc540 00000000 cf0fc540 c0282238 c028220c cf178d80
[ 137.372985] 9ee0: 127525d8 c02821cc 9a1fa451 c032727c 9a1fa451 127525d8 cf0fc540 cf0ac4ec
[ 137.381561] 9f00: cf0ac000 cf0fc540 cf0ac584 c03285f4 c0328580 cf0ac4ec cf85c740 c05510cc
[ 137.390136] 9f20: ce825400 c004c914 00000002 00000000 c004c884 ce8254f5 cf869f48 00000000
[ 137.398712] 9f40: c0328580 ce825415 c0a7f914 c061af64 00000000 c048cf3c cf8673c0 cf85c740
[ 137.407287] 9f60: c05510cc c051a66c c05510ec c05510c4 cf85c750 cf868000 00000089 c004d6ac
[ 137.415863] 9f80: 00000000 c0073d14 00000001 cf853ed8 cf85c740 c004d558 00000013 00000000
[ 137.424438] 9fa0: 00000000 00000000 00000000 c00516b0 00000000 00000000 cf85c740 00000000
[ 137.433013] 9fc0: 00000001 dead4ead ffffffff ffffffff c0551674 00000000 00000000 c0450aa4
[ 137.441589] 9fe0: cf869fe0 cf869fe0 cf853ed8 c005162c c0013b30 c0013b30 00ffff00 00ffff00
[ 137.450164] [<c0071490>] (__lock_acquire+0x5c/0x1ab0) from [<c00733f8>] (lock_acquire+0x9c/0x128)
[ 137.459503] [<c00733f8>] (lock_acquire+0x9c/0x128) from [<c0374130>] (_raw_spin_lock_irqsave+0x44/0x58)
[ 137.469360] [<c0374130>] (_raw_spin_lock_irqsave+0x44/0x58) from [<c02a1d50>] (skb_queue_tail+0x18/0x48)
[ 137.479339] [<c02a1d50>] (skb_queue_tail+0x18/0x48) from [<c0282238>] (h4_enqueue+0x2c/0x34)
[ 137.488189] [<c0282238>] (h4_enqueue+0x2c/0x34) from [<c02821cc>] (hci_uart_send_frame+0x34/0x68)
[ 137.497497] [<c02821cc>] (hci_uart_send_frame+0x34/0x68) from [<c032727c>] (hci_send_frame+0x50/0x88)
[ 137.507171] [<c032727c>] (hci_send_frame+0x50/0x88) from [<c03285f4>] (hci_cmd_work+0x74/0xd4)
[ 137.516204] [<c03285f4>] (hci_cmd_work+0x74/0xd4) from [<c004c914>] (process_one_work+0x1a0/0x4ec)
[ 137.525604] [<c004c914>] (process_one_work+0x1a0/0x4ec) from [<c004d6ac>] (worker_thread+0x154/0x344)
[ 137.535278] [<c004d6ac>] (worker_thread+0x154/0x344) from [<c00516b0>] (kthread+0x84/0x90)
[ 137.543975] [<c00516b0>] (kthread+0x84/0x90) from [<c0013b30>] (kernel_thread_exit+0x0/0x8)
[ 137.552734] Code: e59f4e5c e5941000 e3510000 0a000031 (e5971000)
[ 137.559234] ---[ end trace 1b75b31a2719ed1e ]---
Acked-by: Marcel Holtmann <marcel@holtmann.org>
This is a partial, self-contained, minimal backport of commit
797fe796c4335b35d95d5326824513befdb5d1e9 upstream which fixes the memory
leak:
Bluetooth: uart-ldisc: Fix memory leak and remove destruct cb
We currently leak the hci_uart object if HCI_UART_PROTO_SET is never set
because the hci-destruct callback will then never be called. This fix
removes the hci-destruct callback and frees the driver internal private
hci_uart object directly on tty-close. We call hci_unregister_dev() here
so the hci-core will never call our callbacks again (except destruct).
Therefore, we can safely free the driver internal data right away and
set the destruct callback to NULL.
Signed-off-by: David Herrmann <dh.herrmann@googlemail.com>
commit afbaa90b80b1ec66e5137cc3824746bfdf559b18 upstream.
If a bitmap is added while the array is active, it is possible
for bitmap_daemon_work to run while the bitmap is being
initialised.
This is particularly a problem if bitmap_daemon_work sees
bitmap->filemap as non-NULL before it has been filled in properly.
So hold bitmap_info.mutex while filling in ->filemap
to prevent problems.
This patch is suitable for any -stable kernel, though it might not
apply cleanly before about 3.1.
Signed-off-by: NeilBrown <neilb@suse.de>
commit f4380a915823dbed0bf8e3cf502ebcf2b7c7f833 upstream.
If r1bio->sectors % 8 != 0,then the memcmp and a later
memcpy will omit the last bio_vec.
This is suitable for any stable kernel since 3.1 when bad-block
management was introduced.
Signed-off-by: majianpeng <majianpeng@gmail.com>
commit 673f7786e205c87b5d978c62827b9a66d097bebb upstream.
In https://bugzilla.kernel.org/show_bug.cgi?id=42976, a system with driver
rtl8192se used as an AP suffers from "Out of SW-IOMMU space" errors. These
are caused by the DMA buffers used for beacons never being unmapped.
This bug was also reported at
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/961618
Reported-and-Tested-by: Da Xue <da@lessconfused.com>
commit a7959c1394d4126a70a53b914ce4105f5173d0aa upstream.
The current version of rtlwifi for USB operations uses kmalloc to
acquire a 32-bit buffer for each read of the device. When
_usb_read_sync() is called with the rcu_lock held, the result is
a "sleeping function called from invalid context" BUG. This is
reported for two cases in https://bugzilla.kernel.org/show_bug.cgi?id=42775.
The first case has the lock originating from within rtlwifi and could
be fixed by rearranging the locking; however, the second originates from
within mac80211. The kmalloc() call is removed from _usb_read_sync()
by creating a ring buffer pointer in the private area and
allocating the buffer data in the probe routine.
commit f57f9c167af7cb3fd315e6a8ebe194a8aea0832a upstream.
People have been getting confused and thinking this is a runtime control.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit c4867936474183332db4c19791a65fdad6474fd5 upstream.
We've only computed whether we need to fall back to 6bpc due to dp
link bandwidth constrains in mode_valid, but not mode_fixup. Under
various circumstances X likes to create new modes which then lack
proper 6bpc flags (if required), resulting in mode_fixup failures and
ultimately black screens.
Chris Wilson pointed out that we still get things wrong for bpp > 24,
but that should be fixed in another patch (and it'll be easier because
this patch consolidates the logic).
The likely culprit for this regression is
commit 3d794f87238f74d80e78a7611c7fbde8a54c85c2
Author: Keith Packard <keithp@keithp.com>
Date: Wed Jan 25 08:16:25 2012 -0800
drm/i915: Force explicit bpp selection for intel_dp_link_required
v2: Fix indentation and tune down the too bold claim that this should
fix the world. Both noticed by Chris Wilson.
v3: Try to really git add things.
Reported-and-tested-by: Brice Goglin <Brice.Goglin@ens-lyon.org>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=48170
Cc: stable@kernel.org
Reviewed-by: Adam Jackson <ajax@redhat.com>
commit 46783150a6552f9513f08e62cfcc07125d6e502b upstream.
It seems it can corrupt the monitor EDID in certain cases on certain
boards when running sensors detect. It's rarely used anyway outside
of AIW boards.
http://lists.lm-sensors.org/pipermail/lm-sensors/2012-April/035847.html
http://lists.freedesktop.org/archives/xorg/2011-January/052239.html
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Acked-by: Jean Delvare <khali@linux-fr.org>
