The gpio binding document says that new code should always use named
gpios. Patch 40b73183 added support to parse a list of gpios from child
nodes, but does not make it possible to use named gpios. This patch adds
the con_id property and implements it is done in gpiolib.c, where the
old-style of using unnamed gpios still works.
Signed-off-by: Olliver Schinagl <oliver@schinagl.nl>
Acked-by: Bryan Wu <cooloney@gmail.com>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Reviewed-by: Alexandre Courbot <acourbot@nvidia.com>
(cherry picked from commit 1feb57a245a4910b03202a814ffc51a900bd4aca)
Commit a43f2cbbb009f9 ("leds: leds-gpio: Make use of device property API")
caused a regression by reading the incorrect string for the "default-state"
property.
Fix the property string check to restore the original behaviour.
Fixes: a43f2cbbb009 (leds: leds-gpio: Make use of device property API)
Reported-by: Jean-Michel Hautbois <jean-michel.hautbois@vodalys.com>
(cherry picked from commit d735d25e60fffeffc256fa5d59551dc92dc07e36)
Since commit a43f2cbbb009f96 ("leds: leds-gpio: Make use of device property
API") it is no longer possible to register multiple gpio leds without passing
the 'label' property.
According to Documentation/devicetree/bindings/leds/common.txt:
"Optional properties for child nodes:
- label : The label for this LED. If omitted, the label is
taken from the node name (excluding the unit address)."
So retrieve the node name when the 'label' property is absent to keep the old
behaviour and fix this regression.
Acked-by: Grant Likely <grant.likely@linaro.org>
(cherry picked from commit 29470ea8d828e4dec74e94f7f17b7479ff5ef276)
In the legacy case, led_dat->gpiod is initialized correctly, but
overwritten later by template->gpiod, which is NULL, causing leds-gpio
to fail with:
gpiod_direction_output: invalid GPIO
leds-gpio: probe of leds-gpio failed with error -22
Move the initialization of led_dat->gpiod from template->gpiod up, and
always use led_dat->gpiod later, to fix this.
Fixes: 5c51277a9ababfa4 (leds: leds-gpio: Add support for GPIO descriptors)
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com>
(cherry picked from commit ec98a4975e66a3aa366cd227edab027b01adea37)
Device tree nodes are already treated as objects, and we already want to
expose them to userspace which is done using the /proc filesystem today.
Right now the kernel has to do a lot of work to keep the /proc view in
sync with the in-kernel representation. If device_nodes are switched to
be kobjects then the device tree code can be a whole lot simpler. It
also turns out that switching to using /sysfs from /proc results in
smaller code and data size, and the userspace ABI won't change if
/proc/device-tree symlinks to /sys/firmware/devicetree/base.
v7: Add missing sysfs_bin_attr_init()
v6: Add __of_add_property() early init fixes from Pantelis
v5: Rename firmware/ofw to firmware/devicetree
Fix updating property values in sysfs
v4: Fixed build error on Powerpc
Fixed handling of dynamic nodes on powerpc
v3: Fixed handling of duplicate attribute and child node names
v2: switch to using sysfs bin_attributes which solve the problem of
reporting incorrect property size.
Tested-by: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Nathan Fontenot <nfont@linux.vnet.ibm.com>
Cc: Pantelis Antoniou <panto@antoniou-consulting.com>
(cherry picked from commit 75b57ecf9d1d1e17d099ab13b8f48e6e038676be)
Add new generic routines are provided for retrieving properties from
device description objects in the platform firmware in case there are
no struct device objects for them (either those objects have not been
created yet or they do not exist at all).
The following functions are provided:
fwnode_property_present()
fwnode_property_read_u8()
fwnode_property_read_u16()
fwnode_property_read_u32()
fwnode_property_read_u64()
fwnode_property_read_string()
fwnode_property_read_u8_array()
fwnode_property_read_u16_array()
fwnode_property_read_u32_array()
fwnode_property_read_u64_array()
fwnode_property_read_string_array()
in analogy with the corresponding functions for struct device added
previously. For all of them, the first argument is a pointer to struct
fwnode_handle (new type) that allows a device description object
(depending on what platform firmware interface is in use) to be
obtained.
Add a new macro device_for_each_child_node() for iterating over the
children of the device description object associated with a given
device and a new function device_get_child_node_count() returning the
number of a given device's child nodes.
The interface covers both ACPI and Device Trees.
Suggested-by: Grant Likely <grant.likely@linaro.org>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
(cherry picked from commit 8a0662d9ed2968e1186208336a8e1fab3fdfea63)
Add a uniform interface by which device drivers can request device
properties from the platform firmware by providing a property name
and the corresponding data type. The purpose of it is to help to
write portable code that won't depend on any particular platform
firmware interface.
The following general helper functions are added:
device_property_present()
device_property_read_u8()
device_property_read_u16()
device_property_read_u32()
device_property_read_u64()
device_property_read_string()
device_property_read_u8_array()
device_property_read_u16_array()
device_property_read_u32_array()
device_property_read_u64_array()
device_property_read_string_array()
The first one allows the caller to check if the given property is
present. The next 5 of them allow single-valued properties of
various types to be retrieved in a uniform way. The remaining 5 are
for reading properties with multiple values (arrays of either numbers
or strings).
This change set includes material from Mika Westerberg and Aaron Lu.
Signed-off-by: Aaron Lu <aaron.lu@intel.com>
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
(cherry picked from commit b31384fa5de37a100507751dfb5c0a49d06cee67)
Commit 21f2aae91e902aad ("leds: leds-gpio: Add support for GPIO
descriptors") already converted most of the driver to use GPIO descriptors.
What is still missing is the platform specific hook gpio_blink_set() and
board files which pass legacy GPIO numbers to this driver in platform data.
In this patch we handle the former and convert gpio_blink_set() to take
GPIO descriptor instead. In order to do this we convert the existing four
users to accept GPIO descriptor and translate it to legacy GPIO number in
the platform code. This effectively "pushes" legacy GPIO number usage from
the driver to platforms.
Also add comment to the remaining block describing that it is legacy code
path and we are getting rid of it eventually.
Suggested-by: Linus Walleij <linus.walleij@linaro.org>
Acked-by: Andrew Lunn <andrew@lunn.ch>
Acked-by: Alexandre Courbot <acourbot@nvidia.com>
(cherry picked from commit c673a2b4008103525a3cf21bedf15ffac37bfef0)
With release of ACPI 5.1 and _DSD method we can finally name GPIOs (and
other things as well) returned by _CRS. Previously we were only able to
use integer index to find the corresponding GPIO, which is pretty error
prone if the order changes.
With _DSD we can now query GPIOs using name instead of an integer index,
like the below example shows:
// Bluetooth device with reset and shutdown GPIOs
Device (BTH)
Name (_HID, ...)
Name (_CRS, ResourceTemplate ()
GpioIo (Exclusive, PullUp, 0, 0, IoRestrictionInputOnly,
"\\_SB.GPO0", 0, ResourceConsumer) {15}
"\\_SB.GPO0", 0, ResourceConsumer) {27, 31}
Name (_DSD, Package ()
ToUUID("daffd814-6eba-4d8c-8a91-bc9bbf4aa301"),
Package ()
Package () {"reset-gpio", Package() {^BTH, 1, 1, 0 }},
Package () {"shutdown-gpio", Package() {^BTH, 0, 0, 0 }},
The format of the supported GPIO property is:
Package () { "name", Package () { ref, index, pin, active_low }}
ref - The device that has _CRS containing GpioIo()/GpioInt() resources,
typically this is the device itself (BTH in our case).
index - Index of the GpioIo()/GpioInt() resource in _CRS starting from zero.
pin - Pin in the GpioIo()/GpioInt() resource. Typically this is zero.
active_low - If 1 the GPIO is marked as active_low.
Since ACPI GpioIo() resource does not have field saying whether it is
active low or high, the "active_low" argument can be used here. Setting
it to 1 marks the GPIO as active low.
In our Bluetooth example the "reset-gpio" refers to the second GpioIo()
resource, second pin in that resource with the GPIO number of 31.
This patch implements necessary support to gpiolib for extracting GPIOs
using _DSD device properties.
(cherry picked from commit 0d9a693cc8619b28f0eeb689a554647d42848fde)
Make use of device property API in this driver so that both OF and ACPI
based system can use the same driver.
This change contains material from Max Eliaser and Mika Westerberg.
(cherry picked from commit a43f2cbbb009f96231bbbe24ad4f824215dedb81)
GPIO descriptors are the preferred way over legacy GPIO numbers
nowadays. Convert the driver to use GPIO descriptors internally but
still allow passing legacy GPIO numbers from platform data to support
existing platforms.
(cherry picked from commit 5c51277a9ababfa44a7f944100bdc9fbda139905)
Make use of device property API in this driver so that both OF based
system and ACPI based system can use this driver.
(cherry picked from commit b26d4e2283b6d9b65bfe14b99c9c3a560e390a00)
Some drivers need to deal with only firmware representation of its
GPIOs. An example would be a GPIO button array driver where each button
is described as a separate firmware node in device tree. Typically these
child nodes do not have physical representation in the Linux device
model.
In order to help device drivers to handle such firmware child nodes we
add dev[m]_get_named_gpiod_from_child() that takes a child firmware
node pointer as its second argument (the first one is the parent device
itself), finds the GPIO using whatever is the underlying firmware
method, and requests the GPIO properly.
(cherry picked from commit 40b7318319281b1bdec804f6435f26cadd329c13)
Device Tree is used in many embedded systems to describe the system
configuration to the OS. It supports attaching properties or name-value
pairs to the devices it describe. With these properties one can pass
additional information to the drivers that would not be available
otherwise.
ACPI is another configuration mechanism (among other things) typically
seen, but not limited to, x86 machines. ACPI allows passing arbitrary
data from methods but there has not been mechanism equivalent to Device
Tree until the introduction of _DSD in the recent publication of the
ACPI 5.1 specification.
In order to facilitate ACPI usage in systems where Device Tree is
typically used, it would be beneficial to standardize a way to retrieve
Device Tree style properties from ACPI devices, which is what we do in
this patch.
If a given device described in ACPI namespace wants to export properties it
must implement _DSD method (Device Specific Data, introduced with ACPI 5.1)
that returns the properties in a package of packages. For example:
Name (_DSD, Package () {
Package () {
Package () {"name1", <VALUE1>},
Package () {"name2", <VALUE2>},
The UUID reserved for properties is daffd814-6eba-4d8c-8a91-bc9bbf4aa301
and is documented in the ACPI 5.1 companion document called "_DSD
Implementation Guide" [1], [2].
We add several helper functions that can be used to extract these
properties and convert them to different Linux data types.
The ultimate goal is that we only have one device property API that
retrieves the requested properties from Device Tree or from ACPI
transparent to the caller.
[1] http://www.uefi.org/sites/default/files/resources/_DSD-implementation-guide-toplevel.htm
[2] http://www.uefi.org/sites/default/files/resources/_DSD-device-properties-UUID.pdf
Reviewed-by: Hanjun Guo <hanjun.guo@linaro.org>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Reviewed-by: Grant Likely <grant.likely@linaro.org>
Signed-off-by: Darren Hart <dvhart@linux.intel.com>
(cherry picked from commit ffdcd955c3078af3ce117edcfce80fde1a512bed)
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
(cherry picked from commit 81902d5f658f5c8c0fbdff7c598fe24d4d521c05)
Platform bus is not the only way to have extcon devices, so current
implementation of of_extcon_get_extcon_dev() is broken. Also using
parent device node only to get device name is quite ugly.
This patch reimplements of_extcon_get_extcon_dev() to do exactly the
same as extcon_get_extcon_dev() but instead of comparing names, compare
node pointers.
Signed-off-by: Tomasz Figa <tomasz.figa@gmail.com>
[mszyprow: simplified the code]
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
(cherry picked from commit f841afb17476f485900bb6213cf93a64a7dc303f)
Remove stray blank line and space.
Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com>
Signed-off-by: Bryan Wu <cooloney@gmail.com>
(cherry picked from commit a4c84e6aafda0ddd8cb004c464cd11e47e211049)
If the inlcude headers aren't sorted alphabetically, then the
logical choice is to append new ones, however that creates a
lot of potential for conflicts or duplicates because every change
will then add new includes in the same location.
(cherry picked from commit 4cc72346f05ef549403d997d66fd517109e59d24)
Correct typo in the name of the type given to sizeof. Because it is the
size of a pointer that is wanted, the typo has no impact on compilation or
execution.
This problem was found using Coccinelle (http://coccinelle.lip6.fr/). The
semantic patch used can be found in message 0 of this patch series.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
(cherry picked from commit 0f05a3ae45f09c20240c8b47152e0333d4d3f717)
The huge majority of GPIOs have their direction and initial value set
right after being obtained by one of the gpiod_get() functions. The
integer GPIO API had gpio_request_one() that took a convenience flags
parameter allowing to specify an direction and value applied to the
returned GPIO. This feature greatly simplifies client code and ensures
errors are always handled properly.
A similar feature has been requested for the gpiod API. Since setting
the direction of a GPIO is so often the very next action done after
obtaining its descriptor, we prefer to extend the existing functions
instead of introducing new functions that would raise the
number of gpiod getters to 16 (!).
The drawback of this approach is that all gpiod clients need to be
updated. To limit the pain, temporary macros are introduced that allow
gpiod_get*() to be called with or without the extra flags argument. They
will be removed once all consumer code has been updated.
Signed-off-by: Alexandre Courbot <acourbot@nvidia.com>
Reviewed-by: Mark Brown <broonie@linaro.org>
(cherry picked from commit 39b2bbe3d715cf5013b5c48695ccdd25bd3bf120)
devm_extcon_dev_allocate
This patch set the parent device of extcon device using first parameter of
devm_extco_dev_allocate() to remove duplicate code on all of extcon provider
drivers.
Reported-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
Tested-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
Cc: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
Cc: Mark Brown <broonie@kernel.org>
Cc: Graeme Gregory <gg@slimlogic.co.uk>
Cc: Kishon Vijay Abraham I <kishon@ti.com>
Cc: Krzysztof Kozlowski <k.kozlowski@samsung.com>
(cherry picked from commit ac65a625a0961e7a96f2e5e182073691d0474c04)
Replace existing resource handling in the driver with managed device
resources, this ensures more consistent error values and simplifies error
handling paths:
kzalloc -> devm_kzalloc
gpio_request_one -> devm_gpio_request_one
input_allocate_polled_device -> devm_input_allocate_polled_device
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
(cherry picked from commit 68252638c8d03a39e5055f823f842c6886d3f83b)
Introduce gpiod_get_optional() and gpiod_get_index_optional() helpers
that make it easier for drivers to handle optional GPIOs.
Currently in order to handle optional GPIOs, a driver needs to special
case error handling for -ENOENT, such as this:
gpio = gpiod_get(dev, "foo");
if (IS_ERR(gpio)) {
if (PTR_ERR(gpio) != -ENOENT)
return PTR_ERR(gpio);
gpio = NULL;
if (gpio) {
/* set up GPIO */
With these new helpers the above is reduced to:
gpio = gpiod_get_optional(dev, "foo");
if (IS_ERR(gpio))
if (gpio) {
/* set up GPIO */
While at it, device-managed variants of these functions are also
provided.
Signed-off-by: Thierry Reding <treding@nvidia.com>
(cherry picked from commit 29a1f2333e07bbbecb920cc78fd035fe8f53207a)
device
This patch add device managed devm_extcon_dev_{allocate,free} to automatically
free the memory of extcon_dev structure without handling free operation.
Reviewed-by: Felipe Balbi <balbi@ti.com>
(cherry picked from commit 739ba1bfdb15e773999aafddbd6c59b5737797a0)
Many bindings use the -gpio suffix in property names. Support this in
addition to the -gpios suffix when requesting GPIOs using the new
descriptor-based API.
(cherry picked from commit dd34c37aa3e81715a1ed8da61fa438072428e188)
This patch move simply OF helper function to extcon core and change function
name as following:
- of_extcon_get_extcon_dev() -> extcon_get_edev_by_phandle()
Acked-by: Felipe Balbi <balbi@ti.com>
(cherry picked from commit 1ad94ffef22c0a6e2ee6ba90a800c32fd29ffa1f)
Enable autoloading of leds-gpio module when a corresponing DT entry is present.
Signed-off-by: Paolo Pisati <paolo.pisati@canonical.com>
(cherry picked from commit 472b854bbc0b55de850faa802250fc1aa7692e45)
This change cleans up the entire global variable mechaninism including
the related macros. Also reduces warnings from the "sparse" utility
in the Linux environment. Lv Zheng.
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
Signed-off-by: Bob Moore <robert.moore@intel.com>
(cherry picked from commit 3aa0b085f62f771072dca7ad7f5554a11a83cf7e)
The need to know the number of array elements in a property is
a common pattern. To prevent duplication of open-coded implementations
add a helper static function that also centralises strict sanity
checking and DTB format details, as well as a set of wrapper functions
for u8, u16, u32 and u64.
Suggested-by: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Heiko Stuebner <heiko.stuebner@bqreaders.com>
Acked-by: Rob Herring <robh@kernel.org>
Acked-by: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Mark Brown <broonie@linaro.org>
(cherry picked from commit ad54a0cfbeb4bd4033d09017557ccbc423f9d5ff)
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
Cc: Bryan Wu <cooloney@gmail.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: linux-leds@vger.kernel.org
(cherry picked from commit 7c7d2a26dbb336ddabe53818750f4c32e2b45ddd)
copy/paste error in pixelclock frequency
(cherry picked from commit c9419af618e4e7944b56f65dce29f2f409681997)
drivers/media/platform/mxc/capture/mxc_v4l2_capture.c
MXC_CSI_CAMERA links to the following functions provided by
VIDEOBUF2_DMA_CONTIG, so select it explicitely to prevent
link errors:
ERROR: "vb2_dma_contig_cleanup_ctx" [drivers/media/platform/mxc/subdev/mx6s_capture.ko] undefined!
ERROR: "vb2_dma_contig_memops" [drivers/media/platform/mxc/subdev/mx6s_capture.ko] undefined!
ERROR: "vb2_dma_contig_init_ctx" [drivers/media/platform/mxc/subdev/mx6s_capture.ko] undefined!
After the system has been shutdown with PMIC_ON_REQ and VCC_BATT is supplied
from a battery it will never restart either by RESET or power cycle.
So use the PMIC_STBY_REQ after shutdown to switch of power rails.
arch/arm/mach-imx/pm-imx6.c
drivers/regulator/pfuze100-regulator.c
There is a hack to use the global pm_power_off callback to switch of power
with the i.MX 6 PMIC_ON_REQ signal.
If one uses another power off driver the callback was already taken by the
rtc-snvs driver.
include/linux/moduleparam.h:338:45: warning: return from incompatible pointer type
(cherry picked from commit 3e33d8ba495ac44791061324704308d908ee8588)
The keepalive module variable allows to not go into a disconnected
state. Fix the case when keepalive is set to go to disconnect.
Add a precompiler directive which allows to only evaluate the HPD signal
for HDMI monitor detection. Default is to react on the status bits for
HPD and the TMDS signal line detection to detect an attached monitor.
While at it cleanup parameter documentation and whitespace.
(cherry picked from commit b15fed911e022b383295cb5443872d427e756677)
gst-inspect mfw_v4lsrc
gst-launch mfw_v4lsrc capture-mode=5 device=/dev/video2 ! mfw_v4lsink
If the I2C is disturbed by other signals sometimes the i2c-imx bus gets stuck
with SDA being low.
This adds a recovery function to the bus driver.
When e.g. a device driver detects a stuck bus
int i2c_recover_bus(struct i2c_adapter *adap)
can be called to try to recover the bus.
(cherry picked from commit 88731dc0e8b6ba244e097b412b302acf3b9cc889)
arch/arm/boot/dts/imx6qdl-apalis.dtsi
drivers/i2c/busses/i2c-imx.c
If the reset gpio for a PCIe switch is invalid, but a gpio for
reseting downstream EP devices is valid no reset pulse for the EP devices is
generated.
(i.e. in the device tree reset-gpio is not defined but reset-ep-gpio is defined)
The patch fixes this.
Original patch from Juha Kokkonen, Huoltamoeletroniikka Ky
(cherry picked from commit f593ebc9921013a992c1d096bf4cbad17c1af01b)
drivers/pci/host/pci-imx6.c
With the following dtb node one can define a gpio to reset
downstream endpoints.
reset-ep-gpio = <...>;
Currently the logic is 1 for reset asserted
and 0 for reset deasserted.
Some pcie switches require their downstream endpoints to be kept in reset
for an additonal millisecond after their reset has been deasserted.
(cherry picked from commit 94a60e7f645965b1e422e4e80aa8ccb9e0ec845c)
Evaluate the ranges property of the weim node to setup the chip select
memory map in IOMUXC_GPR1.
Note that the implementation assumes the ranges property to be sorted from CS0
to the last CS used.
e.g. for CS0, CS1, CS2 used, each having a range of 32MB:
ranges = <0 0 0x08000000 0x02000000
1 0 0x0a000000 0x02000000
2 0 0x0c000000 0x02000000>;
(cherry picked from commit 8a4f50a4658f8406ede0f21e643e21deff6b6c3e)
drivers/bus/imx-weim.c
Add device tree integration and add the device to the dtb.
i2c device, interrupt and reset GPIO can be specified in the dts as follows:
Note that additionally you may have to set the pinmuxing for the pins to
be GPIO.
&i2c1 {
status = "okay";
pcap@10 {
/* TouchRevolution Fusion 7 and 10 multi-touch controller */
compatible = "touchrevolution,fusion-f0710a";
reg = <0x10>;
gpios = <&gpio6 10 0 /* MXM-11, Pen down interrupt */
&gpio6 9 0 /* MXM-13, Reset interrupt */
(cherry picked from commit 6b5ba243c21e60706806c4ea56124a0749b21c5b)
arch/arm/boot/dts/imx6q-apalis-eval.dts
Use platform independent description for requested GPIOs.
Fix chip reset by sleeping long enought after reset. Do proper error
handling (free GPIO on failure). Use dev_* for message logging to get
similar messages for all fusion driver related errors and warnings.
To avoid warnings use the new I2C power management function for
suspend and resume.
Added platform data struct to define interrupt and reset GPIO. This
allows to initialize the touchscreen controller inside the driver
rather then in each platform and use the driver as a module.
When the next interrupt request apeares between the confirmation of
the previous (a write via I2C, fusion_F0710A_write_complete) and
the reenable of the GPIO interrupt, the driver hangs and no more
touch inputs are reported.
This patch moves the confirmation after the reenabling of the GPIO
interrupt.
Recent evdev X-Server input driver implementation complain when
only multitouch axes have been reported ("found only multitouch-axes.
That shouldn't happen."). Therefor also report the primary touch
detection with default axis.
(cherry picked from commit dda7a631ac901e4d140e8a6612c5c6b5506b6a91)
For Android use ICS variant of Fusion 7 and 10 multi-touch driver (See
Fusion 7 and 10 drivers for Linux.pdf and Linux Drivers Fusion 10.zip).
Tested to be working both with Android 4.0.4 for Colibri T20 as well as
Android 4.2.1 for Colibri T30.
(cherry picked from commit 0fc73eb175a82dc11f6c1cc8e03f1d311d3180de)
(cherry picked from commit 25be04f0f83263dac2c356065f756f0d51a3d62b)
