path: root/drivers
2015-03-06samsung-laptop: Add use_native_backlight quirk, and enable it on some modelsHans de Goede
commit 4690555e13c48fef07f2762f6b0cd6b181e326d0 upstream. Since kernel 3.14 the backlight control has been broken on various Samsung Atom based netbooks. This has been bisected and this problem happens since commit b35684b8fa94 ("drm/i915: do full backlight setup at enable time") This has been reported and discussed in detail here: http://lists.freedesktop.org/archives/intel-gfx/2014-July/049395.html Unfortunately no-one has been able to fix this. This only affects Samsung Atom netbooks, and the Linux kernel and the BIOS of those laptops have never worked well together. All affected laptops already have a quirk to avoid using the standard acpi-video interface and instead use the samsung specific SABI interface which samsung-laptop uses. It seems that recent fixes to the i915 driver have also broken backlight control through the SABI interface. The intel_backlight driver OTOH works fine, and also allows for finer grained backlight control. So add a new use_native_backlight quirk, and replace the broken_acpi_video quirk with this quirk for affected models. This new quirk disables acpi-video as before and also stops samsung-laptop from registering the SABI based samsung_laptop backlight interface, leaving only the working intel_backlight interface. This commit enables this new quirk for 3 models which are known to be affected, chances are that it needs to be used on other models too. BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1094948 # N145P BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1115713 # N250P Reported-by: Bertrik Sikken <bertrik@sikken.nl> # N150P Cc: stable@vger.kernel.org # 3.16 Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Darren Hart <dvhart@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06EDAC, amd64_edac: Prevent OOPS with >16 memory controllersDaniel J Blueman
commit 0c510cc83bdbaac8406f4f7caef34f4da0ba35ea upstream. When DRAM errors occur on memory controllers after EDAC_MAX_MCS (16), the kernel fatally dereferences unallocated structures, see splat below; this occurs on at least NumaConnect systems. Fix by checking if a memory controller info structure was found. BUG: unable to handle kernel NULL pointer dereference at 0000000000000320 IP: [<ffffffff819f714f>] decode_bus_error+0x2f/0x2b0 PGD 2f8b5a3067 PUD 2f8b5a2067 PMD 0 Oops: 0000 [#2] SMP Modules linked in: CPU: 224 PID: 11930 Comm: stream_c.exe.gn Tainted: G D 3.19.0 #1 Hardware name: Supermicro H8QGL/H8QGL, BIOS 3.5b 01/28/2015 task: ffff8807dbfb8c00 ti: ffff8807dd16c000 task.ti: ffff8807dd16c000 RIP: 0010:[<ffffffff819f714f>] [<ffffffff819f714f>] decode_bus_error+0x2f/0x2b0 RSP: 0000:ffff8907dfc03c48 EFLAGS: 00010297 RAX: 0000000000000001 RBX: 9c67400010080a13 RCX: 0000000000001dc6 RDX: 000000001dc61dc6 RSI: ffff8907dfc03df0 RDI: 000000000000001c RBP: ffff8907dfc03ce8 R08: 0000000000000000 R09: 0000000000000022 R10: ffff891fffa30380 R11: 00000000001cfc90 R12: 0000000000000008 R13: 0000000000000000 R14: 000000000000001c R15: 00009c6740001000 FS: 00007fa97ee18700(0000) GS:ffff8907dfc00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000320 CR3: 0000003f889b8000 CR4: 00000000000407e0 Stack: 0000000000000000 ffff8907dfc03df0 0000000000000008 9c67400010080a13 000000000000001c 00009c6740001000 ffff8907dfc03c88 ffffffff810e4f9a ffff8907dfc03ce8 ffffffff81b375b9 0000000000000000 0000000000000010 Call Trace: <IRQ> ? vprintk_default ? printk amd_decode_mce notifier_call_chain atomic_notifier_call_chain mce_log machine_check_poll mce_timer_fn ? mce_cpu_restart call_timer_fn.isra.29 run_timer_softirq __do_softirq irq_exit smp_apic_timer_interrupt apic_timer_interrupt <EOI> ? down_read_trylock __do_page_fault ? __schedule do_page_fault page_fault Signed-off-by: Daniel J Blueman <daniel@numascale.com> Link: http://lkml.kernel.org/r/1424144078-24589-1-git-send-email-daniel@numascale.com [ Boris: massage commit message ] Signed-off-by: Borislav Petkov <bp@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06sb_edac: Fix detection on SNB machinesBorislav Petkov
commit 11249e73992981e31fd50e7231da24fad68e3320 upstream. d0585cd815fa ("sb_edac: Claim a different PCI device") changed the probing of sb_edac to look for PCI device 0x3ca0: 3f:0e.0 System peripheral: Intel Corporation Xeon E5/Core i7 Processor Home Agent (rev 07) 00: 86 80 a0 3c 00 00 00 00 07 00 80 08 00 00 80 00 ... but we're matching for 0x3ca8, i.e. PCI_DEVICE_ID_INTEL_SBRIDGE_IMC_TA in sbridge_probe() therefore the probing fails. Changing it to probe for 0x3ca0 (PCI_DEVICE_ID_INTEL_SBRIDGE_IMC_HA0), .i.e., the 14.0 device, fixes the issue and driver loads successfully again: [ 2449.013120] EDAC DEBUG: sbridge_init: [ 2449.017029] EDAC sbridge: Seeking for: PCI ID 8086:3ca0 [ 2449.022368] EDAC DEBUG: sbridge_get_onedevice: Detected 8086:3ca0 [ 2449.028498] EDAC sbridge: Seeking for: PCI ID 8086:3ca0 [ 2449.033768] EDAC sbridge: Seeking for: PCI ID 8086:3ca8 [ 2449.039028] EDAC DEBUG: sbridge_get_onedevice: Detected 8086:3ca8 [ 2449.045155] EDAC sbridge: Seeking for: PCI ID 8086:3ca8 ... Add a debug printk while at it to be able to catch the failure in the future and dump driver version on successful load. Fixes: d0585cd815fa ("sb_edac: Claim a different PCI device") Acked-by: Aristeu Rozanski <aris@redhat.com> Cc: Tony Luck <tony.luck@intel.com> Acked-by: Andy Lutomirski <luto@amacapital.net> Acked-by: Mauro Carvalho Chehab <m.chehab@samsung.com> Signed-off-by: Borislav Petkov <bp@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06md/raid1: fix read balance when a drive is write-mostly.Tomáš Hodek
commit d1901ef099c38afd11add4cfb3312c02ef21ec4a upstream. When a drive is marked write-mostly it should only be the target of reads if there is no other option. This behaviour was broken by commit 9dedf60313fa4dddfd5b9b226a0ef12a512bf9dc md/raid1: read balance chooses idlest disk for SSD which causes a write-mostly device to be *preferred* is some cases. Restore correct behaviour by checking and setting best_dist_disk and best_pending_disk rather than best_disk. We only need to test one of these as they are both changed from -1 or >=0 at the same time. As we leave min_pending and best_dist unchanged, any non-write-mostly device will appear better than the write-mostly device. Reported-by: Tomáš Hodek <tomas.hodek@volny.cz> Reported-by: Dark Penguin <darkpenguin@yandex.ru> Signed-off-by: NeilBrown <neilb@suse.de> Link: http://marc.info/?l=linux-raid&m=135982797322422 Fixes: 9dedf60313fa4dddfd5b9b226a0ef12a512bf9dc Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06md/raid5: Fix livelock when array is both resyncing and degraded.NeilBrown
commit 26ac107378c4742978216be1005b7291b799c7b2 upstream. Commit a7854487cd7128a30a7f4f5259de9f67d5efb95f: md: When RAID5 is dirty, force reconstruct-write instead of read-modify-write. Causes an RCW cycle to be forced even when the array is degraded. A degraded array cannot support RCW as that requires reading all data blocks, and one may be missing. Forcing an RCW when it is not possible causes a live-lock and the code spins, repeatedly deciding to do something that cannot succeed. So change the condition to only force RCW on non-degraded arrays. Reported-by: Manibalan P <pmanibalan@amiindia.co.in> Bisected-by: Jes Sorensen <Jes.Sorensen@redhat.com> Tested-by: Jes Sorensen <Jes.Sorensen@redhat.com> Signed-off-by: NeilBrown <neilb@suse.de> Fixes: a7854487cd7128a30a7f4f5259de9f67d5efb95f Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06clocksource: mtk: Fix race conditions in probe codeMatthias Brugger
commit d4a19eb3b15a4ba98f627182f48d5bc0cffae670 upstream. We have two race conditions in the probe code which could lead to a null pointer dereference in the interrupt handler. The interrupt handler accesses the clockevent device, which may not yet be registered. First race condition happens when the interrupt handler gets registered before the interrupts get disabled. The second race condition happens when the interrupts get enabled, but the clockevent device is not yet registered. Fix that by disabling the interrupts before we register the interrupt and enable the interrupts after the clockevent device got registered. Reported-by: Gongbae Park <yongbae2@gmail.com> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com> Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06gpio: tps65912: fix wrong container_of argumentsNicolas Saenz Julienne
commit 2f97c20e5f7c3582c7310f65a04465bfb0fd0e85 upstream. The gpio_chip operations receive a pointer the gpio_chip struct which is contained in the driver's private struct, yet the container_of call in those functions point to the mfd struct defined in include/linux/mfd/tps65912.h. Signed-off-by: Nicolas Saenz Julienne <nicolassaenzj@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06gpiolib: of: allow of_gpiochip_find_and_xlate to find more than one chip per ↵Hans Holmberg
node commit 9cf75e9e4ddd587ac12e88e8751c358b7b27e95f upstream. The change: 7b8792bbdffdff3abda704f89c6a45ea97afdc62 gpiolib: of: Correct error handling in of_get_named_gpiod_flags assumed that only one gpio-chip is registred per of-node. Some drivers register more than one chip per of-node, so adjust the matching function of_gpiochip_find_and_xlate to not stop looking for chips if a node-match is found and the translation fails. Fixes: 7b8792bbdffd ("gpiolib: of: Correct error handling in of_get_named_gpiod_flags") Signed-off-by: Hans Holmberg <hans.holmberg@intel.com> Acked-by: Alexandre Courbot <acourbot@nvidia.com> Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Tested-by: Tyler Hall <tylerwhall@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06serial: fsl_lpuart: avoid new transfer while DMA is runningStefan Agner
commit 5f1437f61a0b351d25b528c159360da3d5e8c77b upstream. When the UART is in DMA receive mode (RDMAS set) and one character just arrived while another interrupt is handled (e.g. TX), the RDRF (receiver data register full flag) is set due to the water level of 1. But since the DMA will take care of this character, there is no need to handle it by calling lpuart_prepare_rx. Handling it leads to adding the RX timeout timer twice: [ 74.336698] Kernel BUG at 80053070 [verbose debug info unavailable] [ 74.342999] Internal error: Oops - BUG: 0 [#1] ARM0:00.00 khungtaskd [ 74.347817] Modules linked in: 0 S 0.0 0.0 0:00.00 writeback [ 74.350926] CPU: 0 PID: 0 Comm: swapper Not tainted 3.19.0-rc3-00001-g39d78e2 #1788 [ 74.358617] Hardware name: Freescale Vybrid VF610 (Device Tree)t [ 74.364563] task: 807a7678 ti: 8079c000 task.ti: 8079c000 kblockd [ 74.370002] PC is at add_timer+0x24/0x28.0 0.0 0:00.09 kworker/u2:1 [ 74.373960] LR is at lpuart_int+0x15c/0x3d8 [ 74.378171] pc : [<80053070>] lr : [<802e0d88>] psr: a0010193 [ 74.378171] sp : 8079de10 ip : 8079de20 fp : 8079de1c [ 74.389694] r10: 807d44c0 r9 : 8688c300 r8 : 00000013 [ 74.394943] r7 : 20010193 r6 : 00000000 r5 : 000000a0 r4 : 86997210 [ 74.401498] r3 : ffffa7da r2 : 80817868 r1 : 86997210 r0 : 86997344 [ 74.408052] Flags: NzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel [ 74.415489] Control: 10c5387d Table: 8611c059 DAC: 00000015 [ 74.421265] Process swapper (pid: 0, stack limit = 0x8079c230) ... Solve this by only execute the receiver path (lpuart_prepare_rx) if the DMA receive mode (RDMAS) is not set. Also, make sure the flag is cleared on initialization, in case it has been left set. This can be best reproduced using UART as a serial console, then running top while dd'ing data into the terminal. Signed-off-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06serial: fsl_lpuart: delete timer on shutdownStefan Agner
commit 4a8588a1cf867333187d9ff071e6fbdab587d194 upstream. If the serial port gets closed while a RX transfer is in progress, the timer might fire after the serial port shutdown finished. This leads in a NULL pointer dereference: [ 7.508324] Unable to handle kernel NULL pointer dereference at virtual address 00000000 [ 7.516590] pgd = 86348000 [ 7.519445] [00000000] *pgd=86179831, *pte=00000000, *ppte=00000000 [ 7.526145] Internal error: Oops: 17 [#1] ARM [ 7.530611] Modules linked in: [ 7.533876] CPU: 0 PID: 123 Comm: systemd Not tainted 3.19.0-rc3-00004-g5b11ea7 #1778 [ 7.541827] Hardware name: Freescale Vybrid VF610 (Device Tree) [ 7.547862] task: 861c3400 ti: 86ac8000 task.ti: 86ac8000 [ 7.553392] PC is at lpuart_timer_func+0x24/0xf8 [ 7.558127] LR is at lpuart_timer_func+0x20/0xf8 [ 7.562857] pc : [<802df99c>] lr : [<802df998>] psr: 600b0113 [ 7.562857] sp : 86ac9b90 ip : 86ac9b90 fp : 86ac9bbc [ 7.574467] r10: 80817180 r9 : 80817b98 r8 : 80817998 [ 7.579803] r7 : 807acee0 r6 : 86989000 r5 : 00000100 r4 : 86997210 [ 7.586444] r3 : 86ac8000 r2 : 86ac9bc0 r1 : 86997210 r0 : 00000000 [ 7.593085] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user [ 7.600341] Control: 10c5387d Table: 86348059 DAC: 00000015 [ 7.606203] Process systemd (pid: 123, stack limit = 0x86ac8230) Setup the timer on UART startup which allows to delete the timer unconditionally on shutdown. This also saves the initialization on each transfer. Signed-off-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06vt: provide notifications on selection changesNicolas Pitre
commit 19e3ae6b4f07a87822c1c9e7ed99d31860e701af upstream. The vcs device's poll/fasync support relies on the vt notifier to signal changes to the screen content. Notifier invocations were missing for changes that comes through the selection interface though. Fix that. Tested with BRLTTY 5.2. Signed-off-by: Nicolas Pitre <nico@linaro.org> Cc: Dave Mielke <dave@mielke.cc> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06cdc-acm: add sanity checksOliver Neukum
commit 7e860a6e7aa62b337a61110430cd633db5b0d2dd upstream. Check the special CDC headers for a plausible minimum length. Another big operating systems ignores such garbage. Signed-off-by: Oliver Neukum <oneukum@suse.de> Reviewed-by: Adam Lee <adam8157@gmail.com> Tested-by: Adam Lee <adam8157@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06USB: add flag for HCDs that can't receive wakeup requests (isp1760-hcd)Alan Stern
commit 074f9dd55f9cab1b82690ed7e44bcf38b9616ce0 upstream. Currently the USB stack assumes that all host controller drivers are capable of receiving wakeup requests from downstream devices. However, this isn't true for the isp1760-hcd driver, which means that it isn't safe to do a runtime suspend of any device attached to a root-hub port if the device requires wakeup. This patch adds a "cant_recv_wakeups" flag to the usb_hcd structure and sets the flag in isp1760-hcd. The core is modified to prevent a direct child of the root hub from being put into runtime suspend with wakeup enabled if the flag is set. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Tested-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Greg Kroah-Hartman <greg@kroah.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06USB: don't cancel queued resets when unbinding driversAlan Stern
commit 524134d422316a59d5464ccbc12036bbe90c5563 upstream. The USB stack provides a mechanism for drivers to request an asynchronous device reset (usb_queue_reset_device()). The mechanism uses a work item (reset_ws) embedded in the usb_interface structure used by the driver, and the reset is carried out by a work queue routine. The asynchronous reset can race with driver unbinding. When this happens, we try to cancel the queued reset before unbinding the driver, on the theory that the driver won't care about any resets once it is unbound. However, thanks to the fact that lockdep now tracks work queue accesses, this can provoke a lockdep warning in situations where the device reset causes another interface's driver to be unbound; see http://marc.info/?l=linux-usb&m=141893165203776&w=2 for an example. The reason is that the work routine for reset_ws in one interface calls cancel_queued_work() for the reset_ws in another interface. Lockdep thinks this might lead to a work routine trying to cancel itself. The simplest solution is not to cancel queued resets when unbinding drivers. This means we now need to acquire a reference to the usb_interface when queuing a reset_ws work item and to drop the reference when the work routine finishes. We also need to make sure that the usb_interface structure doesn't outlive its parent usb_device; this means acquiring and dropping a reference when the interface is created and destroyed. In addition, cancelling a queued reset can fail (if the device is in the middle of an earlier reset), and this can cause usb_reset_device() to try to rebind an interface that has been deallocated (see http://marc.info/?l=linux-usb&m=142175717016628&w=2 for details). Acquiring the extra references prevents this failure. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Reported-by: Russell King - ARM Linux <linux@arm.linux.org.uk> Reported-by: Olivier Sobrie <olivier@sobrie.be> Tested-by: Olivier Sobrie <olivier@sobrie.be> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06usb: core: buffer: smallest buffer should start at ARCH_DMA_MINALIGNSebastian Andrzej Siewior
commit 5efd2ea8c9f4f12916ffc8ba636792ce052f6911 upstream. the following error pops up during "testusb -a -t 10" | musb-hdrc musb-hdrc.1.auto: dma_pool_free buffer-128, f134e000/be842000 (bad dma) hcd_buffer_create() creates a few buffers, the smallest has 32 bytes of size. ARCH_KMALLOC_MINALIGN is set to 64 bytes. This combo results in hcd_buffer_alloc() returning memory which is 32 bytes aligned and it might by identified by buffer_offset() as another buffer. This means the buffer which is on a 32 byte boundary will not get freed, instead it tries to free another buffer with the error message. This patch fixes the issue by creating the smallest DMA buffer with the size of ARCH_KMALLOC_MINALIGN (or 32 in case ARCH_KMALLOC_MINALIGN is smaller). This might be 32, 64 or even 128 bytes. The next three pools will have the size 128, 512 and 2048. In case the smallest pool is 128 bytes then we have only three pools instead of four (and zero the first entry in the array). The last pool size is always 2048 bytes which is the assumed PAGE_SIZE / 2 of 4096. I doubt it makes sense to continue using PAGE_SIZE / 2 where we would end up with 8KiB buffer in case we have 16KiB pages. Instead I think it makes sense to have a common size(s) and extend them if there is need to. There is a BUILD_BUG_ON() now in case someone has a minalign of more than 128 bytes. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06usb: dwc3: gadget: add missing spin_lock()Felipe Balbi
commit 5c7b3b02de766a8634708953e805399e3544a290 upstream. commit 8e74475b0e0a (usb: dwc3: gadget: use udc-core's reset notifier) added support for the new UDC core's reset notifier to dwc3 but while at it, it removed a spin_lock() from dwc3_reset_gadget() which might cause an unbalanced spin_unlock() further down the line Fixes: 8e74475b0e0a (usb: dwc3: gadget: use udc-core's reset notifier) Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06USB: fix use-after-free bug in usb_hcd_unlink_urb()Alan Stern
commit c99197902da284b4b723451c1471c45b18537cde upstream. The usb_hcd_unlink_urb() routine in hcd.c contains two possible use-after-free errors. The dev_dbg() statement at the end of the routine dereferences urb and urb->dev even though both structures may have been deallocated. This patch fixes the problem by storing urb->dev in a local variable (avoiding the dereference of urb) and moving the dev_dbg() up before the usb_put_dev() call. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Reported-by: Joe Lawrence <joe.lawrence@stratus.com> Tested-by: Joe Lawrence <joe.lawrence@stratus.com> Signed-off-by: Greg Kroah-Hartman <greg@kroah.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06USB: cp210x: add ID for RUGGEDCOM USB Serial ConsoleLennart Sorensen
commit a6f0331236fa75afba14bbcf6668d42cebb55c43 upstream. Added the USB serial console device ID for Siemens Ruggedcom devices which have a USB port for their serial console. Signed-off-by: Len Sorensen <lsorense@csclub.uwaterloo.ca> Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06mei: me: release hw from reset only during the reset flowAlexander Usyskin
commit 663b7ee9517eec6deea9a48c7a1392a9a34f7809 upstream. We might enter the interrupt handler with hw_ready already set, but prior we actually started the reset flow. To soleve this we move the reset release from the interrupt handler to the HW start wait function which is part of the reset sequence. Signed-off-by: Alexander Usyskin <alexander.usyskin@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06mei: mask interrupt set bit on clean reset bitAlexander Usyskin
commit 1ab1e79b9fd4b01331490bbe2e630a0fc0b25449 upstream. We should mask interrupt set bit when writing back hcsr value in reset bit clean-up. This is refinement for mei: clean reset bit before reset commit b13a65ef190e488e2761d65bdd2e1fe8a3a125f5 Signed-off-by: Alexander Usyskin <alexander.usyskin@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06tty/serial: at91: fix error handling in atmel_serial_probe()Cyrille Pitchen
commit 6fbb9bdf0f3fbe23aeff806489791aa876adaffb upstream. -EDEFER error wasn't handle properly by atmel_serial_probe(). As an example, when atmel_serial_probe() is called for the first time, we pass the test_and_set_bit() test to check whether the port has already been initalized. Then we call atmel_init_port(), which may return -EDEFER, possibly returned before by clk_get(). Consequently atmel_serial_probe() used to return this error code WITHOUT clearing the port bit in the "atmel_ports_in_use" mask. When atmel_serial_probe() was called for the second time, it used to fail on the test_and_set_bit() function then returning -EBUSY. When atmel_serial_probe() fails, this patch make it clear the port bit in the "atmel_ports_in_use" mask, if needed, before returning the error code. Signed-off-by: Cyrille Pitchen <cyrille.pitchen@atmel.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06tty/serial: at91: enable peripheral clock before accessing I/O registersCyrille Pitchen
commit d4f641876a68d1961e30c202709cc2d484f69f6f upstream. atmel_serial_probe() calls atmel_init_port(). In turn, atmel_init_port() calls clk_disable_unprepare() to disable the peripheral clock before returning. Later atmel_serial_probe() accesses some I/O registers such as the Mode and Control registers for RS485 support then the Name and Version registers, through a call to atmel_get_ip_name(), but at that moment the peripheral clock was still disabled. Signed-off-by: Cyrille Pitchen <cyrille.pitchen@atmel.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06tty/serial: at91: use correct type for dma_sync_*_for_cpu() and ↵Cyrille Pitchen
dma_sync_*_for_device() commit 485819b5b9ed82372dacae775998f3c33717f7fe upstream. dma_sync_*_for_cpu() and dma_sync_*_for_device() use 'enum dma_data_direction', not 'enum dma_transfer_direction' Signed-off-by: Cyrille Pitchen <cyrille.pitchen@atmel.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06tty: Prevent untrappable signals from malicious programPeter Hurley
commit 37480a05685ed5b8e1b9bf5e5c53b5810258b149 upstream. Commit 26df6d13406d1a5 ("tty: Add EXTPROC support for LINEMODE") allows a process which has opened a pty master to send _any_ signal to the process group of the pty slave. Although potentially exploitable by a malicious program running a setuid program on a pty slave, it's unknown if this exploit currently exists. Limit to signals actually used. Cc: Theodore Ts'o <tytso@mit.edu> Cc: Howard Chu <hyc@symas.com> Cc: One Thousand Gnomes <gnomes@lxorguk.ukuu.org.uk> Cc: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06tty: Remove warning in tty_lock_slave()Peter Hurley
commit eef15e2a54fad4c2ce3f0a81485dc591ce678f4f upstream. Commit 2aff5e2bc62db43e05c814461a08aff0fc2b7fe5 ('tty: Change tty lock order to master->slave') added a warning which is broken and unnecessary now that the tty lock has fixed lock subclasses, added in commit 2febdb632bb96235b94b8fccaf882a78f8f4b2bb ('tty: Preset lock subclass for nested tty locks'). Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06iscsi-target: Drop problematic active_ts_list usageNicholas Bellinger
commit 3fd7b60f2c7418239d586e359e0c6d8503e10646 upstream. This patch drops legacy active_ts_list usage within iscsi_target_tq.c code. It was originally used to track the active thread sets during iscsi-target shutdown, and is no longer used by modern upstream code. Two people have reported list corruption using traditional iscsi-target and iser-target with the following backtrace, that appears to be related to iscsi_thread_set->ts_list being used across both active_ts_list and inactive_ts_list. [ 60.782534] ------------[ cut here ]------------ [ 60.782543] WARNING: CPU: 0 PID: 9430 at lib/list_debug.c:53 __list_del_entry+0x63/0xd0() [ 60.782545] list_del corruption, ffff88045b00d180->next is LIST_POISON1 (dead000000100100) [ 60.782546] Modules linked in: ib_srpt tcm_qla2xxx qla2xxx tcm_loop tcm_fc libfc scsi_transport_fc scsi_tgt ib_isert rdma_cm iw_cm ib_addr iscsi_target_mod target_core_pscsi target_core_file target_core_iblock target_core_mod configfs ebtable_nat ebtables ipt_MASQUERADE iptable_nat nf_nat_ipv4 nf_nat nf_conntrack_ipv4 nf_defrag_ipv4 ipt_REJECT xt_CHECKSUM iptable_mangle iptable_filter ip_tables bridge stp llc autofs4 sunrpc ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 xt_state nf_conntrack ip6table_filter ip6_tables ipv6 ib_ipoib ib_cm ib_uverbs ib_umad mlx4_en mlx4_ib ib_sa ib_mad ib_core mlx4_core dm_mirror dm_region_hash dm_log dm_mod vhost_net macvtap macvlan vhost tun kvm_intel kvm uinput iTCO_wdt iTCO_vendor_support microcode serio_raw pcspkr sb_edac edac_core sg i2c_i801 lpc_ich mfd_core mtip32xx igb i2c_algo_bit i2c_core ptp pps_core ioatdma dca wmi ext3(F) jbd(F) mbcache(F) sd_mod(F) crc_t10dif(F) crct10dif_common(F) ahci(F) libahci(F) isci(F) libsas(F) scsi_transport_sas(F) [last unloaded: speedstep_lib] [ 60.782597] CPU: 0 PID: 9430 Comm: iscsi_ttx Tainted: GF 3.12.19+ #2 [ 60.782598] Hardware name: Supermicro X9DRX+-F/X9DRX+-F, BIOS 3.00 07/09/2013 [ 60.782599] 0000000000000035 ffff88044de31d08 ffffffff81553ae7 0000000000000035 [ 60.782602] ffff88044de31d58 ffff88044de31d48 ffffffff8104d1cc 0000000000000002 [ 60.782605] ffff88045b00d180 ffff88045b00d0c0 ffff88045b00d0c0 ffff88044de31e58 [ 60.782607] Call Trace: [ 60.782611] [<ffffffff81553ae7>] dump_stack+0x49/0x62 [ 60.782615] [<ffffffff8104d1cc>] warn_slowpath_common+0x8c/0xc0 [ 60.782618] [<ffffffff8104d2b6>] warn_slowpath_fmt+0x46/0x50 [ 60.782620] [<ffffffff81280933>] __list_del_entry+0x63/0xd0 [ 60.782622] [<ffffffff812809b1>] list_del+0x11/0x40 [ 60.782630] [<ffffffffa06e7cf9>] iscsi_del_ts_from_active_list+0x29/0x50 [iscsi_target_mod] [ 60.782635] [<ffffffffa06e87b1>] iscsi_tx_thread_pre_handler+0xa1/0x180 [iscsi_target_mod] [ 60.782642] [<ffffffffa06fb9ae>] iscsi_target_tx_thread+0x4e/0x220 [iscsi_target_mod] [ 60.782647] [<ffffffffa06fb960>] ? iscsit_handle_snack+0x190/0x190 [iscsi_target_mod] [ 60.782652] [<ffffffffa06fb960>] ? iscsit_handle_snack+0x190/0x190 [iscsi_target_mod] [ 60.782655] [<ffffffff8106f99e>] kthread+0xce/0xe0 [ 60.782657] [<ffffffff8106f8d0>] ? kthread_freezable_should_stop+0x70/0x70 [ 60.782660] [<ffffffff8156026c>] ret_from_fork+0x7c/0xb0 [ 60.782662] [<ffffffff8106f8d0>] ? kthread_freezable_should_stop+0x70/0x70 [ 60.782663] ---[ end trace 9662f4a661d33965 ]--- Since this code is no longer used, go ahead and drop the problematic usage all-together. Reported-by: Gavin Guo <gavin.guo@canonical.com> Reported-by: Moussa Ba <moussaba@micron.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06sg: fix EWOULDBLOCK errors with scsi-mqTony Battersby
commit 7772855a996ec6e16944b120ab5ce21050279821 upstream. With scsi-mq enabled, userspace programs can get unexpected EWOULDBLOCK (a.k.a. EAGAIN) errors when submitting commands to the SCSI generic driver. Fix by calling blk_get_request() with GFP_KERNEL instead of GFP_ATOMIC. Note: to avoid introducing a potential deadlock, this patch should be applied after the patch titled "sg: fix unkillable I/O wait deadlock with scsi-mq". Signed-off-by: Tony Battersby <tonyb@cybernetics.com> Acked-by: Douglas Gilbert <dgilbert@interlog.com> Tested-by: Douglas Gilbert <dgilbert@interlog.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06sg: fix unkillable I/O wait deadlock with scsi-mqTony Battersby
commit 7568615c1054907ea8c7701ab86dad51aa099888 upstream. When using the write()/read() interface for submitting commands, the SCSI generic driver does not call blk_put_request() on a completed SCSI command until userspace calls read() to get the command completion. Since scsi-mq uses a fixed number of preallocated requests, this makes it possible for userspace to exhaust the entire preallocated supply of requests. For places in the kernel that call blk_get_request() with GFP_KERNEL, this can cause the calling process to deadlock in a permanent unkillable I/O wait in blk_get_request() -> ... -> bt_get(). For places in the kernel that call blk_get_request() with GFP_ATOMIC, this can cause blk_get_request() always to return -EWOULDBLOCK. Note that these problems happen only if scsi-mq is enabled. Prevent the problems by calling blk_put_request() as soon as the SCSI command completes instead of waiting for userspace to call read(). Signed-off-by: Tony Battersby <tonyb@cybernetics.com> Acked-by: Douglas Gilbert <dgilbert@interlog.com> Tested-by: Douglas Gilbert <dgilbert@interlog.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06Added Little Endian support to vtpm modulehonclo
commit eb71f8a5e33fa1066fb92f0111ab366a341e1f6c upstream. The tpm_ibmvtpm module is affected by an unaligned access problem. ibmvtpm_crq_get_version failed with rc=-4 during boot when vTPM is enabled in Power partition, which supports both little endian and big endian modes. We added little endian support to fix this problem: 1) added cpu_to_be64 calls to ensure BE data is sent from an LE OS. 2) added be16_to_cpu and be32_to_cpu calls to make sure data received is in LE format on a LE OS. Signed-off-by: Hon Ching(Vicky) Lo <honclo@linux.vnet.ibm.com> Signed-off-by: Joy Latten <jmlatten@linux.vnet.ibm.com> [phuewe: manually applied the patch :( ] Reviewed-by: Ashley Lai <ashley@ahsleylai.com> Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06tpm/tpm_i2c_stm_st33: Fix potential bug in tpm_stm_i2c_sendChristophe Ricard
commit 1ba3b0b6f218072afe8372d12f1b6bf26a26008e upstream. When sending data in tpm_stm_i2c_send, each loop iteration send buf. Send buf + i instead as the goal of this for loop is to send a number of byte from buf that fit in burstcnt. Once those byte are sent, we are supposed to send the next ones. The driver was working because the burstcount value returns always the maximum size for a TPM command or response. (0x800 for a command and 0x400 for a response). Reviewed-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06tpm: Fix NULL return in tpm_ibmvtpm_get_desired_dmaHon Ching (Vicky) Lo
commit 84eb186bc37c0900b53077ca21cf6dd15823a232 upstream. There was an oops in tpm_ibmvtpm_get_desired_dma, which caused kernel panic during boot when vTPM is enabled in Power partition configured in AMS mode. vio_bus_probe calls vio_cmo_bus_probe which calls tpm_ibmvtpm_get_desired_dma to get the size needed for DMA allocation. The problem is, vio_cmo_bus_probe is called before calling probe, which for vtpm is tpm_ibmvtpm_probe and it's this function that initializes and sets up vtpm's CRQ and gets required data values. Therefore, since this has not yet been done, NULL is returned in attempt to get the size for DMA allocation. We added a NULL check. In addition, a default buffer size will be set when NULL is returned. Signed-off-by: Hon Ching (Vicky) Lo <honclo@linux.vnet.ibm.com> Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06char: tpm: Add missing error check for devm_kzallocKiran Padwal
commit bb95cd34ba4c9467114acc78eeddd53ab1c10085 upstream. Currently these driver are missing a check on the return value of devm_kzalloc, which would cause a NULL pointer dereference in a OOM situation. This patch adds a missing check for tpm_i2c_atmel.c and tpm_i2c_nuvoton.c Signed-off-by: Kiran Padwal <kiran.padwal@smartplayin.com> Reviewed-By: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06TPM: Add new TPMs to the tail of the list to prevent inadvertent change of devDavid Howells
commit 398a1e71dc827b994b7f2f56c7c2186fea7f8d75 upstream. Add newly registered TPMs to the tail of the list, not the beginning, so that things that are specifying TPM_ANY_NUM don't find that the device they're using has inadvertently changed. Adding a second device would break IMA, for instance. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06tpm_tis: verify interrupt during initScot Doyle
commit 448e9c55c12d6bd4fa90a7e31d802e045666d7c8 upstream. Some machines, such as the Acer C720 and Toshiba CB35, have TPMs that do not send IRQs while also having an ACPI TPM entry indicating that they will be sent. These machines freeze on resume while the tpm_tis module waits for an IRQ, eventually timing out. When in interrupt mode, the tpm_tis module should receive an IRQ during module init. Fall back to polling mode if none is received when expected. Signed-off-by: Scot Doyle <lkml14@scotdoyle.com> Tested-by: Michael Mullin <masmullin@gmail.com> Reviewed-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> [phuewe: minor checkpatch fixed] Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06mmc: sdhci-pxav3: Fix Armada 38x controller's caps according to erratum ↵Marcin Wojtas
ERR-7878951 commit a39128bcd6f1e56c6514abf489b40b67d226093b upstream. According to erratum 'ERR-7878951' Armada 38x SDHCI controller has different capabilities than the ones shown in its registers: - it doesn't support the voltage switching: it can work either with 3.3V or 1.8V supply - it doesn't support the SDR104 mode - SDR50 mode doesn't need tuning The SDHCI_QUIRK_MISSING_CAPS quirk is used for updating the capabilities accordingly. [gregory.clement@free-electrons.com: port from 3.10] Fixes: 5491ce3f79ee ("mmc: sdhci-pxav3: add support for the Armada 38x SDHCI controller") Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06mmc: sdhci-pxav3: Fix SDR50 and DDR50 capabilities for the Armada 38x flavorGregory CLEMENT
commit d4b803c559843e3774736e5108cf6331cf75f64c upstream. According to erratum 'FE-2946959' both SDR50 and DDR50 modes require specific clock adjustments in SDIO3 Configuration register. However, this register was not part of the device tree binding. Even if the binding can (and will) be extended we still need handling the case where this register was not available. In this case we use the SDHCI_QUIRK_MISSING_CAPS quirk remove them from the capabilities. This commit is based on the work done by Marcin Wojtas<mw@semihalf.com> Fixes: 5491ce3f79ee ("mmc: sdhci-pxav3: add support for the Armada 38x SDHCI controller") Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Marcin Wojtas <mw@semihalf.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06mmc: sdhci-pxav3: fix setting of pdata->clk_delay_cyclesJisheng Zhang
commit 14460dbaf7a5a0488963fdb8232ad5c8a8cca7b7 upstream. Current code checks "clk_delay_cycles > 0" to know whether the optional "mrvl,clk_delay_cycles" is set or not. But of_property_read_u32() doesn't touch clk_delay_cycles if the property is not set. And type of clk_delay_cycles is u32, so we may always set pdata->clk_delay_cycles as a random value. This patch fix this problem by check the return value of of_property_read_u32() to know whether the optional clk-delay-cycles is set or not. Signed-off-by: Jisheng Zhang <jszhang@marvell.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06mmc: sdhci-pxav3: fix race between runtime pm and irqJisheng Zhang
commit 3bb10f60933e84abfe2be69f60b3486f9b96348b upstream. This patch is to fix a race condition that may cause an unhandled irq, which results in big sdhci interrupt numbers and endless "mmc1: got irq while runtime suspended" msgs before v3.15. Consider following scenario: CPU0 CPU1 sdhci_pxav3_runtime_suspend() spin_lock_irqsave(&host->lock, flags); sdhci_irq() spining on the &host->lock host->runtime_suspended = true; spin_unlock_irqrestore(&host->lock, flags); get the &host->lock runtime_suspended is true now return IRQ_NONE; Fix this race by using the core sdhci.c supplied sdhci_runtime_suspend_host() in runtime suspend hook which will disable card interrupts. We also use the sdhci_runtime_resume_host() in the runtime resume hook accordingly. Signed-off-by: Jisheng Zhang <jszhang@marvell.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06mmc: sdhci-pxav3: fix unbalanced clock issues during probeJisheng Zhang
commit 62cf983ad84275f8580c807e5e596216c46773cf upstream. Commit 0dcaa2499b7d ("sdhci-pxav3: Fix runtime PM initialization") tries to fix one hang issue caused by calling sdhci_add_host() on a suspended device. The fix enables the clock twice, once by clk_prepare_enable() and another by pm_runtime_get_sync(), meaning that the clock will never be gated at runtime PM suspend. I observed the power consumption regression on Marvell BG2Q SoCs. In fact, the fix is not correct. There still be a very small window during which a runtime suspend might somehow occur after pm_runtime_enable() but before pm_runtime_get_sync(). This patch fixes all of the two problems by just incrementing the usage counter before pm_runtime_enable(). It also adjust the order of disabling runtime pm and storing the usage count in the error path to handle clock gating properly. Signed-off-by: Jisheng Zhang <jszhang@marvell.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06em28xx-audio: fix missing newlines, againRussell King
commit fbaa48d1853002c2e7bcf12c1fdc0f6fb16d1525 upstream. Inspection shows that newlines are missing from several kernel messages in em28xx-audio. Fix these. Fixes: 6d746f91f230 ("[media] em28xx-audio: implement em28xx_ops: suspend/resume hooks") Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Reviewed-by: Frank Schäfer <fschaefer.oss@googlemail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06em28xx-dvb: fix missing newlinesRussell King
commit a084c57fc1ccd24ef8e6ca41e75afa745d5dbb98 upstream. Inspection shows that newlines are missing from several kernel messages in em28xx-dvb. Fix these. Fixes: ca2b46dacbf5 ("[media] em28xx-dvb: implement em28xx_ops: suspend/resume hooks") Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Reviewed-by: Frank Schäfer <fschaefer.oss@googlemail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06em28xx-video: fix missing newlinesRussell King
commit 32e63f0368ed16e5ac417dc0bc2a5f8acbfb1511 upstream. Inspection shows that newlines are missing from several kernel messages in em28xx-video. Fix these. Fixes: a61f68119af3 ("[media] em28xx-video: implement em28xx_ops: suspend/resume hooks") Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Reviewed-by: Frank Schäfer <fschaefer.oss@googlemail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06em28xx-core: fix missing newlinesRussell King
commit 522adc7c1f70d302155bb07f7fdf5a7fe4ff9094 upstream. Inspection shows that newlines are missing from several kernel messages in em28xx-core. Fix these. Fixes: 9c669b731470 ("[media] em28xx: add suspend/resume to em28xx_ops") Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Reviewed-by: Frank Schäfer <fschaefer.oss@googlemail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06em28xx-audio: fix missing newlinesRussell King
commit 7818b0aab87b680fb10f68eccebeeb6cd8283c73 upstream. Inspection shows that newlines are missing from several kernel messages in em28xx-audio. Fix these. Fixes: 1b3fd2d34266 ("[media] em28xx-audio: don't hardcode audio URB calculus") Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Reviewed-by: Frank Schäfer <fschaefer.oss@googlemail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06em28xx-input: fix missing newlinesRussell King
commit ebfd59cf549899a166d595bf1eab7eec3299ebe7 upstream. Inspection shows that newlines are missing from several kernel messages in em28xx-input. Fix these. Fixes: 5025076aadfe ("[media] em28xx-input: implement em28xx_ops: suspend/resume hooks") Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Reviewed-by: Frank Schäfer <fschaefer.oss@googlemail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06em28xx: ensure "closing" messages terminate with a newlineRussell King
commit 0418ca6073478f54f1da2e4013fa50d36838de75 upstream. The lockdep splat addressed in a previous commit revealed that at least one message in em28xx-input.c was missing a new line: em28178 #0: Closing input extensionINFO: trying to register non-static key. Further inspection shows several other messages also miss a new line. These will be fixed in a subsequent patch. Fixes: aa929ad783c0 ("[media] em28xx: print a message at disconnect") Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Reviewed-by: Frank Schäfer <fschaefer.oss@googlemail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06em28xx: fix em28xx-input removalRussell King
commit bbfebeea7640973613c484f0281bdd15d68fd873 upstream. Removing the em28xx-rc module results in the following lockdep splat, which is caused by trying to call cancel_delayed_work_sync() on an uninitialised delayed work. Fix this by ensuring we always initialise the work. INFO: trying to register non-static key. the code is fine but needs lockdep annotation. turning off the locking correctness validator. CPU: 0 PID: 2183 Comm: rmmod Not tainted 3.18.0+ #1464 Hardware name: Freescale i.MX6 Quad/DualLite (Device Tree) Backtrace: [<c0012228>] (dump_backtrace) from [<c00123c0>] (show_stack+0x18/0x1c) r6:c1419d2c r5:00000000 r4:00000000 r3:00000000 [<c00123a8>] (show_stack) from [<c06e2550>] (dump_stack+0x7c/0x98) [<c06e24d4>] (dump_stack) from [<c0061c94>] (__lock_acquire+0x16d4/0x1bb0) r4:edf19f74 r3:df049380 [<c00605c0>] (__lock_acquire) from [<c00626d4>] (lock_acquire+0xb0/0x124) r10:00000000 r9:c003ba90 r8:00000000 r7:00000000 r6:00000000 r5:edf19f74 r4:00000000 [<c0062624>] (lock_acquire) from [<c003bad4>] (flush_work+0x44/0x264) r10:00000000 r9:eaa86000 r8:edf190b0 r7:edf19f74 r6:00000001 r5:edf19f64 r4:00000000 [<c003ba90>] (flush_work) from [<c003d8f0>] (__cancel_work_timer+0x8c/0x124) r7:00000000 r6:00000001 r5:00000000 r4:edf19f64 [<c003d864>] (__cancel_work_timer) from [<c003d99c>] (cancel_delayed_work_sync+0x14/0x18) r7:00000000 r6:eccc3600 r5:00000000 r4:edf19000 [<c003d988>] (cancel_delayed_work_sync) from [<bf0b5c10>] (em28xx_ir_fini+0x48/0xd8 [em28xx_rc]) [<bf0b5bc8>] (em28xx_ir_fini [em28xx_rc]) from [<bf08a0a8>] (em28xx_unregister_extension+0x40/0x94 [em28xx]) r8:c000edc4 r7:00000081 r6:bf092bf4 r5:bf0b6a2c r4:edf19000 r3:bf0b5bc8 [<bf08a068>] (em28xx_unregister_extension [em28xx]) from [<bf0b64dc>] (em28xx_rc_unregister+0x14/0x1c [em28xx_rc]) r6:00000800 r5:00000000 r4:bf0b6a50 r3:bf0b64c8 [<bf0b64c8>] (em28xx_rc_unregister [em28xx_rc]) from [<c0096710>] (SyS_delete_module+0x11c/0x180) [<c00965f4>] (SyS_delete_module) from [<c000ec00>] (ret_fast_syscall+0x0/0x48) r6:00000001 r5:beb0f813 r4:b8b17d00 Fixes: f52226099382 ("[media] em28xx: extend the support for device buttons") Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Reviewed-by: Frank Schäfer <fschaefer.oss@googlemail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06timberdale: do not select TIMB_DMAArnd Bergmann
commit 244829226f47ffb4d6009a2ccd2771cd149d8114 upstream. The timberdale media driver requires the use of the respective dma engine driver, but that may not be enabled, causing a Kconfig warning: warning: (VIDEO_TIMBERDALE) selects TIMB_DMA which has unmet direct dependencies (DMADEVICES && MFD_TIMBERDALE) This fixes the dependency by removing the inappropriate 'select' statement and replacing it with a direct dependency on the drivers that provide the services this needs. Fixes: 7155043c2d027 ("[media] enable COMPILE_TEST for media drivers") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06rc-main: Re-apply filter for no-op protocol changeJames Hogan
commit 983c5bd26b86ba1c0d79b770e596bb8b77e42f32 upstream. Since commit da6e162d6a46 ("[media] rc-core: simplify sysfs code"), when the IR protocol is set using the sysfs interface to the same set of protocols that are already set, store_protocols() does not refresh the scancode filter with the new protocol, even if it has already called the change_protocol() callback successfully. This results in the filter being disabled in the hardware and not re-enabled until the filter is set again using sysfs. Fix in store_protocols() by still re-applying the filter whenever the change_protocol() driver callback succeeded. The problem can be reproduced with the img-ir driver by setting a filter, and then setting the protocol to the same protocol that is already set: $ echo nec > protocols $ echo 0xffff > filter_mask $ echo nec > protocols After this, messages which don't match the filter were still being received. Fixes: da6e162d6a46 ("[media] rc-core: simplify sysfs code") Reported-by: Sifan Naeem <sifan.naeem@imgtec.com> Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: David Härdeman <david@hardeman.nu> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-06megaraid_sas: complete outstanding IOCTLs before killing adapterSumit.Saxena@avagotech.com
commit c8dd61eff2780c481fcf919c1572e16e397c714e upstream. Driver calls megasas_complete_cmd() to call wake_up() for each MFI frame that was issued through the ioctl() interface prior to the kill adapter. This ensures userspace ioctl() system calls issued just before a kill adapter don't get stuck in wait state and IOCTLs are returned to the application. Signed-off-by: Sumit Saxena <sumit.saxena@avagotech.com> Signed-off-by: Chaitra Basappa <chaitra.basappa@avagotech.com> Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
