path: root/drivers
2013-10-18Merge tag 'pm+acpi-3.12-rc6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management fixes from Rafael Wysocki: - intel_pstate fix for misbehavior after system resume if sysfs attributes are set in a specific way before the corresponding suspend from Dirk Brandewie. - A recent intel_pstate fix has no effect if unsigned long is 32-bit, so fix it up to cover that case as well. - The s3c64xx cpufreq driver was not updated when the index field of struct cpufreq_frequency_table was replaced with driver_data, so update it now. From Charles Keepax. - The Kconfig help text for ACPI_BUTTON still refers to /proc/acpi/event that has been dropped recently, so modify it to remove that reference. From Krzysztof Mazur. - A Lan Tianyu's change adds a missing mutex unlock to an error code path in acpi_resume_power_resources(). - Some code related to ACPI power resources, whose very purpose is questionable to put it lightly, turns out to cause problems to happen during testing on real systems, so remove it completely (we may revisit that in the future if there's a compelling enough reason). From Rafael J Wysocki and Aaron Lu. * tag 'pm+acpi-3.12-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: ACPI / PM: Drop two functions that are not used any more ATA / ACPI: remove power dependent device handling cpufreq: s3c64xx: Rename index to driver_data ACPI / power: Drop automaitc resume of power resource dependent devices intel_pstate: Fix type mismatch warning cpufreq / intel_pstate: Fix max_perf_pct on resume ACPI: remove /proc/acpi/event from ACPI_BUTTON help ACPI / power: Release resource_lock after acpi_power_get_state() return error
2013-10-18Merge branch 'acpi-fixes'Rafael J. Wysocki
* acpi-fixes: ACPI / PM: Drop two functions that are not used any more ATA / ACPI: remove power dependent device handling ACPI / power: Drop automaitc resume of power resource dependent devices ACPI: remove /proc/acpi/event from ACPI_BUTTON help ACPI / power: Release resource_lock after acpi_power_get_state() return error
2013-10-17Merge tag 'driver-core-3.12-rc6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core fix from Greg KH: "Here is one fix for the hotplug memory path that resolves a regression when removing memory that showed up in 3.12-rc1" * tag 'driver-core-3.12-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: driver core: Release device_hotplug_lock when store_mem_state returns EINVAL
2013-10-17Merge tag 'usb-3.12-rc6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB fixes from Greg KH: "Here are some USB fixes and new device ids for 3.12-rc6 The largest change here is a bunch of new device ids for the option USB serial driver for new Huawei devices. Other than that, just some small bug fixes for issues that people have reported (run-time and build-time), nothing major" * tag 'usb-3.12-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: usb: usb_phy_gen: refine conditional declaration of usb_nop_xceiv_register usb: misc: usb3503: Fix compile error due to incorrect regmap depedency usb/chipidea: fix oops on memory allocation failure usb-storage: add quirk for mandatory READ_CAPACITY_16 usb: serial: option: blacklist Olivetti Olicard200 USB: quirks: add touchscreen that is dazzeled by remote wakeup Revert "usb: musb: gadget: fix otg active status flag" USB: quirks.c: add one device that cannot deal with suspension USB: serial: option: add support for Inovia SEW858 device USB: serial: ti_usb_3410_5052: add Abbott strip port ID to combined table as well. USB: support new huawei devices in option.c usb: musb: start musb on the udc side, too xhci: Fix spurious wakeups after S5 on Haswell xhci: fix write to USB3_PSSEN and XUSB2PRM pci config registers xhci: quirk for extra long delay for S4 xhci: Don't enable/disable RWE on bus suspend/resume.
2013-10-17Merge tag 'tty-3.12-rc6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull serial driver fixes from Greg KH: "Here are two serial driver fixes for your tree. One is a revert of a patch that causes a build error, the other is a fix to provide the correct brace placement which resolves a bug where the driver was not working properly" * tag 'tty-3.12-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: serial: vt8500: add missing braces Revert "serial: i.MX: evaluate linux,stdout-path property"
2013-10-17Merge tag 'char-misc-3.12-rc6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver fixes from Greg KH: "Here are some small iio and w1 driver fixes for 3.12-rc6. There is also a hyper-v fix in here, which turned out to be incorrect, so it was reverted. That will probably have to wait unto 3.13-rc1 to get accepted as it's still being discussed" * tag 'char-misc-3.12-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: Revert "Drivers: hv: vmbus: Fix a bug in channel rescind code" Drivers: hv: vmbus: Fix a bug in channel rescind code iio:buffer: Free active scan mask in iio_disable_all_buffers() iio: frequency: adf4350: add missing clk_disable_unprepare() on error in adf4350_probe() w1 - call request_module with w1 master mutex unlocked w1 - fix fops in w1_bus_notify
2013-10-17Merge tag 'iio-fixes-for-3.12c' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into char-misc-linus Jonathan writes: Third set of IIO fixes for the 3.12 cycle. Two little ones this time: 1) A missing clk_unprepare in adf4350. 2) A missing free of the active_scan_mask when iio_disable_all_buffers is called during an unexpected device removal. This leak was introduced by the fix a87c82e454f184a9473f8cdfd4d304205f585f65 iio: Stop sampling when the device is removed and hence is a regression fix.
2013-10-17Revert "Drivers: hv: vmbus: Fix a bug in channel rescind code"Greg Kroah-Hartman
This reverts commit 90d33f3ec519db19d785216299a4ee85ef58ec97 as it's not the correct fix for this issue, and it causes a build warning to be added to the kernel tree. Cc: K. Y. Srinivasan <kys@microsoft.com> Cc: <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-17ACPI / PM: Drop two functions that are not used any moreRafael J. Wysocki
Two functions defined in device_pm.c, acpi_dev_pm_add_dependent() and acpi_dev_pm_remove_dependent(), have no callers and may be dropped, so drop them. Moreover, they are the only functions adding entries to and removing entries from the power_dependent list in struct acpi_device, so drop that list too. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-17ATA / ACPI: remove power dependent device handlingAaron Lu
Previously, we wanted SCSI devices corrsponding to ATA devices to be runtime resumed when the power resource for those ATA device was turned on by some other device, so we added the SCSI device to the dependent device list of the ATA device's ACPI node. However, this code has no effect after commit 41863fc (ACPI / power: Drop automaitc resume of power resource dependent devices) and the mechanism it was supposed to implement is regarded as a bad idea now, so drop it. [rjw: Changelog] Signed-off-by: Aaron Lu <aaron.lu@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-16driver core: Release device_hotplug_lock when store_mem_state returns EINVALYasuaki Ishimatsu
When inserting a wrong value to /sys/devices/system/memory/memoryX/state file, following messages are shown. And device_hotplug_lock is never released. ================================================ [ BUG: lock held when returning to user space! ] 3.12.0-rc4-debug+ #3 Tainted: G W ------------------------------------------------ bash/6442 is leaving the kernel with locks still held! 1 lock held by bash/6442: #0: (device_hotplug_lock){+.+.+.}, at: [<ffffffff8146cbb5>] lock_device_hotplug_sysfs+0x15/0x50 This issue was introdued by commit fa2be40 (drivers: base: use standard device online/offline for state change). This patch releases device_hotplug_lcok when store_mem_state returns EINVAL. Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Reviewed-by: Toshi Kani <toshi.kani@hp.com> CC: Seth Jennings <sjenning@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-16Merge tag 'dm-3.12-fix-cve' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm Pull device-mapper fix from Alasdair Kergon: "A patch to avoid data corruption in a device-mapper snapshot. This is primarily a data corruption bug that all users of device-mapper snapshots will want to fix. The CVE is due to a data leak under specific circumstances if, for example, the snapshot is presented to a virtual machine: a block written as data inside the VM can get interpreted incorrectly on the host outside the VM as metadata, causing the host to provide the VM with access to blocks it would not otherwise see. This is likely to affect few, if any, people" * tag 'dm-3.12-fix-cve' of git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm: dm snapshot: fix data corruption
2013-10-16Merge tag 'gpio-v3.12-3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull gpio fixes from Linus Walleij: "Three GPIO fixes for the v3.12 series: - A fix to the Lynxpoint IRQ handler - Two late fixes to fallout from the gpiod refactoring" * tag 'gpio-v3.12-3' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: gpiolib: let gpiod_request() return -EPROBE_DEFER gpiolib: safer implementation of desc_to_gpio() gpio/lynxpoint: check if the interrupt is enabled in IRQ handler
2013-10-16cpufreq: s3c64xx: Rename index to driver_dataCharles Keepax
The index field of cpufreq_frequency_table has been renamed to driver_data by commit 5070158 (cpufreq: rename index as driver_data in cpufreq_frequency_table). This patch updates the s3c64xx driver to match. Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Cc: 3.11+ <stable@vger.kernel.org> # 3.11+ Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-16ACPI / power: Drop automaitc resume of power resource dependent devicesRafael J. Wysocki
The mechanism causing devices depending on a given power resource (that is, devices that can be in D0 only if that power resource is on) to be resumed automatically when the power resource is turned on (and their "inferred" power state becomes D0 as a result) is inherently racy and in fact unnecessary. It is racy, because if the power resource is turned on and then immediately off, the device resume triggered by the first transition to "on" may still happen, causing the power resource to be turned on again. That again will trigger the "resume of dependent devices" mechanism, but if the devices in question are not in use, they will be suspended in the meantime causing the power resource to be turned off. However, the "resume of dependent devices" will next resume them again and so on. In some cases (USB port PM in particular) that leads to an endless busy loop of flipping the resource on and off continuously. It is needless, because whoever turns a power resource on will most likely turn it off at some point and the devices that go into "D0" as a result of turning it on will then go back into D3cold (generally, the state they were in before). Moreover, turning on all power resources a device needs to go into D0 is not sufficient for a full transition into D0 in general. Namely, _PS0 may need to be executed in addition to that in some cases. This means that the whole rationale of the "resume of dependent devices" mechanism was incorrect to begin with and it's best to remove it entirely. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-16intel_pstate: Fix type mismatch warningRafael J. Wysocki
The expression in line 398 of intel_pstate.c causes the following warning to be emitted: drivers/cpufreq/intel_pstate.c:398:3: warning: left shift count >= width of type which happens because unsigned long is 32-bit on some architectures. Fix that by using a helper u64 variable and simplify the code slightly. Tested-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-16Drivers: hv: vmbus: Fix a bug in channel rescind codeK. Y. Srinivasan
Rescind of subchannels were not being correctly handled. Fix the bug. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Cc: <stable@vger.kernel.org> [3.11+] Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-16usb: misc: usb3503: Fix compile error due to incorrect regmap depedencyMatthew Dawson
The USB3503 driver had an incorrect depedency on REGMAP, instead of REGMAP_I2C. This caused the build to fail since the necessary regmap i2c pieces were not available. Signed-off-by: Matthew Dawson <matthew@mjdsystems.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-16usb/chipidea: fix oops on memory allocation failureRussell King - ARM Linux
When CMA fails to initialize in v3.12-rc4, the chipidea driver oopses the kernel while trying to remove and put the HCD which doesn't exist: WARNING: CPU: 0 PID: 6 at /home/rmk/git/linux-rmk/arch/arm/mm/dma-mapping.c:511 __dma_alloc+0x200/0x240() coherent pool not initialised! Modules linked in: CPU: 0 PID: 6 Comm: kworker/u2:0 Tainted: G W 3.12.0-rc4+ #56 Workqueue: deferwq deferred_probe_work_func Backtrace: [<c001218c>] (dump_backtrace+0x0/0x10c) from [<c0012328>] (show_stack+0x18/0x1c) r6:c05fd9cc r5:000001ff r4:00000000 r3:df86ad00 [<c0012310>] (show_stack+0x0/0x1c) from [<c05f3a4c>] (dump_stack+0x70/0x8c) [<c05f39dc>] (dump_stack+0x0/0x8c) from [<c00230a8>] (warn_slowpath_common+0x6c/0x8c) r4:df883a60 r3:df86ad00 [<c002303c>] (warn_slowpath_common+0x0/0x8c) from [<c002316c>] (warn_slowpath_fmt+0x38/0x40) r8:ffffffff r7:00001000 r6:c083b808 r5:00000000 r4:df2efe80 [<c0023134>] (warn_slowpath_fmt+0x0/0x40) from [<c00196bc>] (__dma_alloc+0x200/0x240) r3:00000000 r2:c05fda00 [<c00194bc>] (__dma_alloc+0x0/0x240) from [<c001982c>] (arm_dma_alloc+0x88/0xa0) [<c00197a4>] (arm_dma_alloc+0x0/0xa0) from [<c03e2904>] (ehci_setup+0x1f4/0x438) [<c03e2710>] (ehci_setup+0x0/0x438) from [<c03cbd60>] (usb_add_hcd+0x18c/0x664) [<c03cbbd4>] (usb_add_hcd+0x0/0x664) from [<c03e89f4>] (host_start+0xf0/0x180) [<c03e8904>] (host_start+0x0/0x180) from [<c03e7c34>] (ci_hdrc_probe+0x360/0x670 ) r6:df2ef410 r5:00000000 r4:df2c3010 r3:c03e8904 [<c03e78d4>] (ci_hdrc_probe+0x0/0x670) from [<c0311044>] (platform_drv_probe+0x20/0x24) [<c0311024>] (platform_drv_probe+0x0/0x24) from [<c030fcac>] (driver_probe_device+0x9c/0x234) ... ---[ end trace c88ccaf3969e8422 ]--- Unable to handle kernel NULL pointer dereference at virtual address 00000028 pgd = c0004000 [00000028] *pgd=00000000 Internal error: Oops: 17 [#1] SMP ARM Modules linked in: CPU: 0 PID: 6 Comm: kworker/u2:0 Tainted: G W 3.12.0-rc4+ #56 Workqueue: deferwq deferred_probe_work_func task: df86ad00 ti: df882000 task.ti: df882000 PC is at usb_remove_hcd+0x10/0x150 LR is at host_stop+0x1c/0x3c pc : [<c03cacec>] lr : [<c03e88e4>] psr: 60000013 sp : df883b50 ip : df883b78 fp : df883b74 r10: c11f4c54 r9 : c0836450 r8 : df30c400 r7 : fffffff4 r6 : df2ef410 r5 : 00000000 r4 : df2c3010 r3 : 00000000 r2 : 00000000 r1 : df86b0a0 r0 : 00000000 Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel Control: 10c53c7d Table: 2f29404a DAC: 00000015 Process kworker/u2:0 (pid: 6, stack limit = 0xdf882240) Stack: (0xdf883b50 to 0xdf884000) ... Backtrace: [<c03cacdc>] (usb_remove_hcd+0x0/0x150) from [<c03e88e4>] (host_stop+0x1c/0x3c) r6:df2ef410 r5:00000000 r4:df2c3010 [<c03e88c8>] (host_stop+0x0/0x3c) from [<c03e8aa0>] (ci_hdrc_host_destroy+0x1c/0x20) r5:00000000 r4:df2c3010 [<c03e8a84>] (ci_hdrc_host_destroy+0x0/0x20) from [<c03e7c80>] (ci_hdrc_probe+0x3ac/0x670) [<c03e78d4>] (ci_hdrc_probe+0x0/0x670) from [<c0311044>] (platform_drv_probe+0x20/0x24) [<c0311024>] (platform_drv_probe+0x0/0x24) from [<c030fcac>] (driver_probe_device+0x9c/0x234) [<c030fc10>] (driver_probe_device+0x0/0x234) from [<c030ff28>] (__device_attach+0x44/0x48) ... ---[ end trace c88ccaf3969e8423 ]--- Fix this so at least we can continue booting and get to a shell prompt. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Tested-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-16usb-storage: add quirk for mandatory READ_CAPACITY_16Oliver Neukum
Some USB drive enclosures do not correctly report an overflow condition if they hold a drive with a capacity over 2TB and are confronted with a READ_CAPACITY_10. They answer with their capacity modulo 2TB. The generic layer cannot cope with that. It must be told to use READ_CAPACITY_16 from the beginning. Signed-off-by: Oliver Neukum <oneukum@suse.de> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-16usb: serial: option: blacklist Olivetti Olicard200Enrico Mioso
Interface 6 of this device speaks QMI as per tests done by us. Credits go to Antonella for providing the hardware. Signed-off-by: Enrico Mioso <mrkiko.rs@gmail.com> Signed-off-by: Antonella Pellizzari <anto.pellizzari83@gmail.com> Tested-by: Dan Williams <dcbw@redhat.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-16serial: vt8500: add missing bracesRoel Kluin
Due to missing braces on an if statement, in presence of a device_node a port was always assigned -1, regardless of any alias entries in the device tree. Conversely, if device_node was NULL, an unitialized port ended up being used. This patch adds the missing braces, fixing the issues. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Acked-by: Tony Prisk <linux@prisktech.co.nz> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-16USB: quirks: add touchscreen that is dazzeled by remote wakeupOliver Neukum
The device descriptors are messed up after remote wakeup Signed-off-by: Oliver Neukum <oneukum@suse.de> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-16dm snapshot: fix data corruptionMikulas Patocka
This patch fixes a particular type of data corruption that has been encountered when loading a snapshot's metadata from disk. When we allocate a new chunk in persistent_prepare, we increment ps->next_free and we make sure that it doesn't point to a metadata area by further incrementing it if necessary. When we load metadata from disk on device activation, ps->next_free is positioned after the last used data chunk. However, if this last used data chunk is followed by a metadata area, ps->next_free is positioned erroneously to the metadata area. A newly-allocated chunk is placed at the same location as the metadata area, resulting in data or metadata corruption. This patch changes the code so that ps->next_free skips the metadata area when metadata are loaded in function read_exceptions. The patch also moves a piece of code from persistent_prepare_exception to a separate function skip_metadata to avoid code duplication. CVE-2013-4299 Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Cc: stable@vger.kernel.org Cc: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2013-10-15Merge tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linuxLinus Torvalds
Pull device tree fixes and reverts from Grant Likely: "One bug fix and three reverts. The reverts back out the slightly controversial feeding the entire device tree into the random pool and the reserved-memory binding which isn't fully baked yet. Expect the reserved-memory patches at least to resurface for v3.13. The bug fixes removes a scary but harmless warning on SPARC that was introduced in the v3.12 merge window. v3.13 will contain a proper fix that makes the new code work on SPARC. On the plus side, the diffstat looks *awesome*. I love removing lines of code" * tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux: Revert "drivers: of: add initialization code for dma reserved memory" Revert "ARM: init: add support for reserved memory defined by device tree" Revert "of: Feed entire flattened device tree into the random pool" of: fix unnecessary warning on missing /cpus node
2013-10-16cpufreq / intel_pstate: Fix max_perf_pct on resumeDirk Brandewie
If the system is suspended while max_perf_pct is less than 100 percent or no_turbo set policy->{min,max} will be set incorrectly with scaled values which turn the scaled values into hard limits. References: https://bugzilla.kernel.org/show_bug.cgi?id=61241 Reported-by: Patrick Bartels <petzicus@googlemail.com> Signed-off-by: Dirk Brandewie <dirk.j.brandewie@intel.com> Cc: 3.9+ <stable@vger.kernel.org> # 3.9+ Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-15Merge tag 'stable/for-linus-3.12-rc4-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull Xen fixes from Stefano Stabellini: "A small fix for Xen on x86_32 and a build fix for xen-tpmfront on arm64" * tag 'stable/for-linus-3.12-rc4-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: xen: Fix possible user space selector corruption tpm: xen-tpmfront: fix missing declaration of xen_domain
2013-10-16ACPI: remove /proc/acpi/event from ACPI_BUTTON helpKrzysztof Mazur
Commit 1696d9d (ACPI: Remove the old /proc/acpi/event interface) left /proc/acpi/event in the ACPI_BUTTON help in Kconfig, so remove it from there. [rjw: Changelog] Signed-off-by: Krzysztof Mazur <krzysiek@podlesie.net> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-16ACPI / power: Release resource_lock after acpi_power_get_state() return errorLan Tianyu
In acpi_resume_power_resources() resource_lock should be released when acpi_power_get_state() fails and before passing to next power resource on the list. Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-15iio:buffer: Free active scan mask in iio_disable_all_buffers()iio-fixes-for-3.12cLars-Peter Clausen
Usually the active scan mask is freed in __iio_update_buffers() when the buffer is disabled. But when the device is still sampling when it is removed we'll end up disabling the buffers in iio_disable_all_buffers(). So we also need to free the active scan mask here, otherwise it will be leaked. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-10-15Revert "drivers: of: add initialization code for dma reserved memory"Marek Szyprowski
This reverts commit 9d8eab7af79cb4ce2de5de39f82c455b1f796963. There is still no consensus on the bindings for the reserved memory and various drawbacks of the proposed solution has been shown, so the best now is to revert it completely and start again from scratch later. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-10-14Merge tag 'vfio-v3.12-rc5' of git://github.com/awilliam/linux-vfioLinus Torvalds
Pull vfio fix from Alex Williamson: "Fix an incorrect break out of nested loop in iommu mapping code" * tag 'vfio-v3.12-rc5' of git://github.com/awilliam/linux-vfio: VFIO: vfio_iommu_type1: fix bug caused by break in nested loop
2013-10-14Merge tag 'rdma-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband Pull infiniband updates from Roland Dreier: "Last batch of IB changes for 3.12: many mlx5 hardware driver fixes plus one trivial semicolon cleanup" * tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: IB: Remove unnecessary semicolons IB/mlx5: Ensure proper synchronization accessing memory IB/mlx5: Fix alignment of reg umr gather buffers IB/mlx5: Fix eq names to display nicely in /proc/interrupts mlx5: Fix error code translation from firmware to driver IB/mlx5: Fix opt param mask according to firmware spec mlx5: Fix opt param mask for sq err to rts transition IB/mlx5: Disable atomic operations mlx5: Fix layout of struct mlx5_init_seg mlx5: Keep polling to reclaim pages while any returned IB/mlx5: Avoid async events on invalid port number IB/mlx5: Decrease memory consumption of mr caches mlx5: Remove checksum on command interface commands IB/mlx5: Fix memory leak in mlx5_ib_create_srq IB/mlx5: Flush cache workqueue before destroying it IB/mlx5: Fix send work queue size calculation
2013-10-14Revert "usb: musb: gadget: fix otg active status flag"Greg Kroah-Hartman
This reverts commit 9b0a1de3c85d99d881c86a29b3d52da7b9c7bd61. Aaro writes: With v3.12-rc4 I can no longer connect to N800 (OMAP2) with USB (peripheral, g_ether). According to git bisect this is caused by: 9b0a1de3c85d99d881c86a29b3d52da7b9c7bd61 is the first bad commit So revert this patch, as Felipe says: It's unfortunate that tusb6010 is so messed up Reported-by: Aaro Koskinen <aaro.koskinen@iki.fi> Acked-by: Felipe Balbi <balbi@ti.com> Cc: Bin Liu <b-liu@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-14USB: quirks.c: add one device that cannot deal with suspensionOliver Neukum
The device is not responsive when resumed, unless it is reset. Signed-off-by: Oliver Neukum <oneukum@suse.de> CC: stable@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-14Merge branch 'misc' into for-nextRoland Dreier
2013-10-14IB: Remove unnecessary semicolonsJoe Perches
These aren't necessary after switch blocks. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2013-10-14Merge tag 'pm+acpi-3.12-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management fixes from Rafael Wysocki: "These fix two recent bugs in ACPIPHP (ACPI-based PCI hotplug) and update a bunch of web links and e-mail addresses in MAINTAINERS, docs and Kconfig that either are stale or will expire soon. Specifics: - The WARN_ON() in acpiphp_enumerate_slots() triggers as a false positive in some cases, so drop it. - Add a missing pci_dev_put() to an error code path in acpiphp_enumerate_slots(). - Replace my old e-mail address that's going to expire with a new one. - Update ACPI web links and git tree information in MAINTAINERS. - Update links to the Linux-ACPI project's page in MAINTAINERS. - Update some stale links and e-mail addresses under Documentation and in the ACPI Kconfig file" * tag 'pm+acpi-3.12-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: ACPI / hotplug / PCI: Drop WARN_ON() from acpiphp_enumerate_slots() ACPI / hotplug / PCI: Fix error code path in acpiphp_enumerate_slots() ACPI / PM / Documentation: Replace outdated project links and addresses MAINTAINERS / ACPI: Update links to the Linux-ACPI project web page MAINTAINERS / ACPI: Update links and git tree information MAINTAINERS / Documentation: Update Rafael's e-mail address
2013-10-14Revert "of: Feed entire flattened device tree into the random pool"Grant Likely
This reverts commit 109b6236294b53d8eaa50be7d9e9ad37079f5f7e. Tim Bird expressed concern that this will have a bad effect on boot time, and while simple tests have shown it to be okay with simple tree, a device tree blob can potentially be quite large and add_device_randomness() is not a fast function. Rather than do this for all platforms unconditionally, I'm reverting this patch and would like to see it revisited. Instead of feeding the entire tree into the random pool, it would probably be appropriate to hash the tree and feed the hash result into the pool. There really isn't a lot of randomness in a device tree anyway. In the majority of cases only a handful of properties are going to be different between machines with the same baseboard. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2013-10-14of: fix unnecessary warning on missing /cpus nodeGrant Likely
Not all DT platforms have all the cpus collected under a /cpus node. That just happens to be a details of FDT, ePAPR and PowerPC platforms. Sparc does something different, but unfortunately the current code complains with a warning if /cpus isn't there. This became a problem with commit f86e4718, "driver/core cpu: initialize of_node in cpu's device structure", which caused the function to get called for all architectures. This commit is a temporary fix to fail silently if the cpus node isn't present. A proper fix will come later to allow arch code to provide a custom mechanism for decoding the CPU hwid if the 'reg' property isn't appropriate. Signed-off-by: Grant Likely <grant.likely@linaro.org> Cc: David Miller <davem@davemloft.net> Cc: Sudeep KarkadaNagesha <Sudeep.KarkadaNagesha@arm.com> Cc: Rob Herring <rob.herring@calxeda.com>
2013-10-13Merge git://www.linux-watchdog.org/linux-watchdogLinus Torvalds
Pull watchdog fixes from Wim Van Sebroeck: "This will fix a deadlock on the ts72xx_wdt driver, fix bitmasks in the kempld_wdt driver and fix a section mismatch in the sunxi_wdt driver" * git://www.linux-watchdog.org/linux-watchdog: watchdog: sunxi: Fix section mismatch watchdog: kempld_wdt: Fix bit mask definition watchdog: ts72xx_wdt: locking bug in ioctl
2013-10-13watchdog: sunxi: Fix section mismatchMaxime Ripard
This driver has a section mismatch, for probe and remove functions, leading to the following warning during the compilation. WARNING: drivers/watchdog/built-in.o(.data+0x24): Section mismatch in reference from the variable sunxi_wdt_driver to the function .init.text:sunxi_wdt_probe() The variable sunxi_wdt_driver references the function __init sunxi_wdt_probe() Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2013-10-13watchdog: kempld_wdt: Fix bit mask definitionJingoo Han
STAGE_CFG bits are defined as [5:4] bits. However, '(((x) & 0x30) << 4)' handles [9:8] bits. Thus, it should be fixed in order to handle [5:4] bits. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2013-10-13watchdog: ts72xx_wdt: locking bug in ioctlDan Carpenter
Calling the WDIOC_GETSTATUS & WDIOC_GETBOOTSTATUS and twice will cause a interruptible deadlock. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2013-10-13Merge branch 'fixes' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine fixes from Vinod Koul: "Another week, time to send another fixes request taking time out of extended weekend for the festivities in this part of the world. We have two fixes from Sergei for rcar driver and one fixing memory leak of edma driver by Geyslan" * 'fixes' of git://git.infradead.org/users/vkoul/slave-dma: dma: edma.c: remove edma_desc leakage rcar-hpbdma: add parameter to set_slave() method rcar-hpbdma: remove shdma_free_irq() calls
2013-10-12Merge branch 'i2c/for-current' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c fixes from Wolfram Sang: "We had various reports of problems with deferred probing in the I2C subsystem, so this pull requst is a little bigger than usual. Most issues should be addressed now so devices will be found correctly. A few ususal driver bugfixes are in here, too" * 'i2c/for-current' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: i2c: i2c-mux-pinctrl: use deferred probe when adapter not found i2c: i2c-arb-gpio-challenge: use deferred probe when adapter not found i2c: i2c-mux-gpio: use deferred probing i2c: i2c-mux-gpio: don't ignore of_get_named_gpio errors i2c: omap: Clear ARDY bit twice i2c: Not all adapters have a parent i2c: i2c-stu300: replace platform_driver_probe to support deferred probing i2c: i2c-mxs: replace platform_driver_probe to support deferred probing i2c: i2c-imx: replace platform_driver_probe to support deferred probing i2c: i2c-designware-platdrv: replace platform_driver_probe to support deferred probing
2013-10-12Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Ingo Molnar: "A build fix and a reboot quirk" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/reboot: Add reboot quirk for Dell Latitude E5410 x86, build, pci: Fix PCI_MSI build on !SMP
2013-10-12Merge branch 'acpi-pci-hotplug'Rafael J. Wysocki
* acpi-pci-hotplug: ACPI / hotplug / PCI: Drop WARN_ON() from acpiphp_enumerate_slots() ACPI / hotplug / PCI: Fix error code path in acpiphp_enumerate_slots()
2013-10-12iio: frequency: adf4350: add missing clk_disable_unprepare() on error in ↵Wei Yongjun
adf4350_probe() Add the missing clk_disable_unprepare() before return from adf4350_probe() in the error handling case. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Reviewed-by: Lars-Peter CLausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-10-12ACPI / hotplug / PCI: Drop WARN_ON() from acpiphp_enumerate_slots()Rafael J. Wysocki
The WARN_ON() in acpiphp_enumerate_slots() triggers unnecessarily for devices whose bridges are going to be handled by native PCIe hotplug (pciehp) and the simplest way to prevent that from happening is to drop the WARN_ON(). References: https://bugzilla.kernel.org/show_bug.cgi?id=62831 Reported-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
