Pull timer fixes from Thomas Gleixner:
"The last round of minimalistic fixes for clocksource drivers:
- Prevent multiple shutdown of the sh_mtu2 clocksource
- Annotate a bunch of clocksource/schedclock functions with notrace
to prevent an annoying ftrace recursion issue"
* 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
clocksource/drivers/sh_mtu2: Fix multiple shutdown call issue
clocksource/drivers/digicolor: Prevent ftrace recursion
clocksource/drivers/fsl_ftm_timer: Prevent ftrace recursion
clocksource/drivers/vf_pit_timer: Prevent ftrace recursion
clocksource/drivers/prima2: Prevent ftrace recursion
clocksource/drivers/samsung_pwm_timer: Prevent ftrace recursion
clocksource/drivers/pistachio: Prevent ftrace recursion
clocksource/drivers/arm_global_timer: Prevent ftrace recursion
Pull irq fixes from Thomas Gleixner:
"The last two one-liners for 4.3 from the irqchip space:
- Regression fix for armada SoC which addresses the fallout from the
set_irq_flags() cleanup
- Add the missing propagation of the irq_set_type() callback to the
parent interrupt controller of the tegra interrupt chip"
* 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
irqchip/tegra: Propagate IRQ type setting to parent
irqchip/armada-370-xp: Fix regression by clearing IRQ_NOAUTOEN
Pull ARM SoC fixes from Olof Johansson:
"This should be our final batch of fixes for 4.3:
- A patch from Sudeep Holla that fixes annotation of wakeup sources
properly, old unused format seems to have spread through copying.
- Two patches from Tony for OMAP. One dealing with MUSB setup
problems due to runtime PM being enabled too early on the parent
device. The other fixes IRQ numbering for OMAP1"
* tag 'armsoc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
usb: musb: omap2430: Fix regression caused by driver core change
ARM: OMAP1: fix incorrect INT_DMA_LCD
ARM: dts: fix gpio-keys wakeup-source property
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi
Pull SCSI fixes from James Bottomley:
"This is three essential bug fixes for various SCSI parts.
The only affected users are SCSI multi-path via device handler
(basically all the enterprise) and mvsas users. The dh bugs are an
async entanglement in boot resulting in a serious WARN_ON trip and a
use after free on remove leading to a crash with strict memory
accounting. The mvsas bug manifests as a null deref oops but only on
abort sequences; however, these can commonly occur with SATA attached
devices, hence the fix"
* tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi:
scsi_dh: don't try to load a device handler during async probing
scsi_dh: fix use-after-free when removing scsi device
mvsas: Fix NULL pointer dereference in mvs_slot_task_free
Pull md bug fixes from Neil Brown:
"Two more bug fixes for md.
One bugfix for a list corruption in raid5 because of incorrect
locking.
Other for possible data corruption when a recovering device is failed,
removed, and re-added.
Both tagged for -stable"
* tag 'md/4.3-rc7-fixes' of git://neil.brown.name/md:
Revert "md: allow a partially recovered device to be hot-added to an array."
md/raid5: fix locking in handle_stripe_clean_event()
Pull drm fixes from Dave Airlie:
"Two drm atomic core fixes.
And two radeon patches needed to fix a backlight regression on some
older hardware"
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux:
drm: Correct arguments to list_tail_add in create blob ioctl
drm: crtc: integer overflow in drm_property_create_blob()
drm/radeon: fix dpms when driver backlight control is disabled
drm/radeon: move bl encoder assignment into bl init
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
Pull Ceph fix from Sage Weil:
"This sets the stable pages flag on the RBD block device when we have
CRCs enabled. (This is necessary since the default assumption for
block devices changed in 3.9)"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client:
rbd: require stable pages if message data CRCs are enabled
Pull networking fixes from David Miller:
1) Fix two regressions in ipv6 route lookups, particularly wrt output
interface specifications in the lookup key. From David Ahern.
2) Fix checks in ipv6 IPSEC tunnel pre-encap fragmentation, from
Herbert Xu.
3) Fix mis-advertisement of 1000BASE-T on bcm63xx_enet, from Simon
Arlott.
4) Some smsc phys misbehave with energy detect mode enabled, so add a
DT property and disable it on such switches. From Heiko Schocher.
5) Fix TSO corruption on TX in mv643xx_eth, from Philipp Kirchhofer.
6) Fix regression added by removal of openvswitch vport stats, from
James Morse.
7) Vendor Kconfig options should be bool, not tristate, from Andreas
Schwab.
8) Use non-_BH() net stats bump in tcp_xmit_probe_skb(), otherwise we
barf during TCP REPAIR operations.
9) Fix various bugs in openvswitch conntrack support, from Joe
Stringer.
10) Fix NETLINK_LIST_MEMBERSHIPS locking, from David Herrmann.
11) Don't have VSOCK do sock_put() in interrupt context, from Jorgen
Hansen.
12) Fix skb_realloc_headroom() failures properly in ISDN, from Karsten
Keil.
13) Add some device IDs to qmi_wwan, from Bjorn Mork.
14) Fix ovs egress tunnel information when using lwtunnel devices, from
Pravin B Shelar.
15) Add missing NETIF_F_FRAGLIST to macvtab feature list, from Jason
Wang.
16) Fix incorrect handling of throw routes when the result of the throw
cannot find a match, from Xin Long.
17) Protect ipv6 MTU calculations from wrap-around, from Hannes Frederic
Sowa.
18) Fix failed autonegotiation on KSZ9031 micrel PHYs, from Nathan
Sullivan.
19) Add missing memory barries in descriptor accesses or xgbe driver,
from Thomas Lendacky.
20) Fix release conditon test in pppoe_release(), from Guillaume Nault.
21) Fix gianfar bugs wrt filter configuration, from Claudiu Manoil.
22) Fix violations of RX buffer alignment in sh_eth driver, from Sergei
Shtylyov.
23) Fixing missing of_node_put() calls in various places around the
networking, from Julia Lawall.
24) Fix incorrect leaf now walking in ipv4 routing tree, from Alexander
Duyck.
25) RDS doesn't check pskb_pull()/pskb_trim() return values, from
Sowmini Varadhan.
26) Fix VLAN configuration in mlx4 driver, from Jack Morgenstein.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (79 commits)
ipv6: protect mtu calculation of wrap-around and infinite loop by rounding issues
Revert "Merge branch 'ipv6-overflow-arith'"
net/mlx4: Copy/set only sizeof struct mlx4_eqe bytes
net/mlx4_en: Explicitly set no vlan tags in WQE ctrl segment when no vlan is present
vhost: fix performance on LE hosts
bpf: sample: define aarch64 specific registers
amd-xgbe: Fix race between access of desc and desc index
RDS-TCP: Recover correctly from pskb_pull()/pksb_trim() failure in rds_tcp_data_recv
forcedeth: fix unilateral interrupt disabling in netpoll path
openvswitch: Fix skb leak using IPv6 defrag
ipv6: Export nf_ct_frag6_consume_orig()
openvswitch: Fix double-free on ip_defrag() errors
fib_trie: leaf_walk_rcu should not compute key if key is less than pn->key
net: mv643xx_eth: add missing of_node_put
ath6kl: add missing of_node_put
net: phy: mdio: add missing of_node_put
netdev/phy: add missing of_node_put
net: netcp: add missing of_node_put
net: thunderx: add missing of_node_put
ipv6: gre: support SIT encapsulation
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input layer fixes from Dmitry Torokhov:
- a change to the ALPS driver where we had limit the quirk for
trackstick handling from being active on all Dells to just a few
models
- a fix for a build dependency issue in the sur40 driver
- a small clock handling fixup in the LPC32xx touchscreen driver
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: alps - only the Dell Latitude D420/430/620/630 have separate stick button bits
Input: sur40 - add dependency on VIDEO_V4L2
Input: lpc32xx_ts - fix warnings caused by enabling unprepared clock
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI fix from Bjorn Helgaas:
"Sorry for this last-minute update; it's been in -next for quite a
while, but I forgot about it until I started getting ready for the
merge window.
It's small and fixes a way a user could cause a panic via sysfs, so I
think it's worth getting it in v4.3.
NUMA:
- Prevent out of bounds access in sysfs numa_node override (Sasha Levin)"
* tag 'pci-v4.3-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
PCI: Prevent out of bounds access in numa_node override
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes
Two omap regression fixes:
- Fix omap3 MUSB with DMA caused by driver core changes
- Fix LCD DMA interrupt number for omap1 that did not
get changed for sparse IRQ changes
* tag 'omap-for-v4.3/fixes-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
Arguments passed to list_add_tail were reversed resulting in deletion
of old blob property everytime the new one is added.
Fixes
commit e2f5d2ea479b9b2619965d43db70939589afe43a
Author: Daniel Stone <daniels@collabora.com>
Date: Fri May 22 13:34:51 2015 +0100
drm/mode: Add user blob-creation ioctl
Signed-off-by: Maneet Singh <mmaneetsingh@nvidia.com>
[seanpaul tweaked commit subject a little]
Signed-off-by: Sean Paul <seanpaul@chromium.org>
Cc: stable@kernel.org # v4.2
Reviewed-by: Daniel Stone <daniels@collabora.com>
Reviewed-by: Jani Nikula <jani.nikula@intel.com>
Signed-off-by: Dave Airlie <airlied@gmail.com>
This reverts commit 7eb418851f3278de67126ea0c427641ab4792c57.
This commit is poorly justified, I can find not discusison in email,
and it clearly causes a problem.
If a device which is being recovered fails and is subsequently
re-added to an array, there could easily have been changes to the
array *before* the point where the recovery was up to. So the
recovery must start again from the beginning.
If a spare is being recovered and fails, then when it is re-added we
really should do a bitmap-based recovery up to the recovery-offset,
and then a full recovery from there. Before this reversion, we only
did the "full recovery from there" which is not corect. After this
reversion with will do a full recovery from the start, which is safer
but not ideal.
It will be left to a future patch to arrange the two different styles
of recovery.
Reported-and-tested-by: Nate Dailey <nate.dailey@stratus.com>
Signed-off-by: NeilBrown <neilb@suse.com>
Cc: stable@vger.kernel.org (3.14+)
Fixes: 7eb418851f32 ("md: allow a partially recovered device to be hot-added to an array.")
The size here comes from the user via the ioctl, it is a number between
1-u32max so the addition here could overflow on 32 bit systems.
Fixes: f453ba046074 ('DRM: add mode setting support')
After commit 566c09c53455 ("raid5: relieve lock contention in get_active_stripe()")
__find_stripe() is called under conf->hash_locks + hash.
But handle_stripe_clean_event() calls remove_hash() under
conf->device_lock.
Under some cirscumstances the hash chain can be circuited,
and we get an infinite loop with disabled interrupts and locked hash
lock in __find_stripe(). This leads to hard lockup on multiple CPUs
and following system crash.
I was able to reproduce this behavior on raid6 over 6 ssd disks.
The devices_handle_discard_safely option should be set to enable trim
support. The following script was used:
for i in `seq 1 32`; do
dd if=/dev/zero of=large$i bs=10M count=100 &
done
neilb: original was against a 3.x kernel. I forward-ported
to 4.3-rc. This verison is suitable for any kernel since
Commit: 59fc630b8b5f ("RAID5: batch adjacent full stripe write")
(v4.1+). I'll post a version for earlier kernels to stable.
Signed-off-by: Roman Gushchin <klamm@yandex-team.ru>
Fixes: 566c09c53455 ("raid5: relieve lock contention in get_active_stripe()")
Cc: Shaohua Li <shli@kernel.org>
Cc: <stable@vger.kernel.org> # 3.13 - 4.2
rbd requires stable pages, as it performs a crc of the page data before
they are send to the OSDs.
But since kernel 3.9 (patch 1d1d1a767206fbe5d4c69493b7e6d2a8d08cc0a0
"mm: only enforce stable page writes if the backing device requires
it") it is not assumed anymore that block devices require stable pages.
This patch sets the necessary flag to get stable pages back for rbd.
In a ceph installation that provides multiple ext4 formatted rbd
devices "bad crc" messages appeared regularly (ca 1 message every 1-2
minutes on every OSD that provided the data for the rbd) in the
OSD-logs before this patch. After this patch this messages are pretty
much gone (only ca 1-2 / month / OSD).
Cc: stable@vger.kernel.org # 3.9+, needs backporting
Signed-off-by: Ronny Hegewald <Ronny.Hegewald@online.de>
[idryomov@gmail.com: require stable pages only in crc case, changelog]
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
into drm-fixes
regression fix for backlight on old laptops.
* 'drm-fixes-4.3' of git://people.freedesktop.org/~agd5f/linux:
If driver backlight control is disabled, either by driver
parameter or default per-asic setting, revert to the old behavior.
Fixes a regression in commit:
4281f46ef839050d2ef60348f661eb463c21cc2e
Reviewed-by: Michel Dänzer <michel.daenzer@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
So that the bl encoder will be null if the GPU does not
control the backlight.
Commit ddef08dd00f5 ("Driver core: wakeup the parent device before trying
probe") started automatically ensuring the parent device is enabled when
the child gets probed.
This however caused a regression for MUSB omap2430 interface as the
runtime PM for the parent device needs the child initialized to access
the MUSB hardware registers.
Let's delay the enabling of PM runtime for the parent until the child
has been properly initialized as suggested in an earlier patch by
Grygorii Strashko <grygorii.strashko@ti.com>.
In addition to delaying pm_runtime_enable, we now also need to make sure
the parent is enabled during omap2430_musb_init. We also want to propagate
an error from omap2430_runtime_resume if struct musb is not initialized.
Note that we use pm_runtime_put_noidle here for both the child and parent
to prevent an extra runtime_suspend/resume cycle.
Let's also add some comments to avoid confusion between the
two different devices.
Fixes: ddef08dd00f5 ("Driver core: wakeup the parent device before
trying probe")
Suggested-by: Grygorii Strashko <grygorii.strashko@ti.com>
Reviewed-by: Grygorii Strashko <grygorii.strashko@ti.com>
Acked-by: Felipe Balbi <balbi@ti.com>
On the r7s72100 Genmai board the MTU2 driver currently triggers a common
clock framework WARN_ON(enable_count) when disabling the clock due to
the MTU2 driver after recent callback rework may call ->set_state_shutdown()
multiple times. A similar issue was spotted for the TMU driver and fixed in:
452b132 clocksource/drivers/sh_tmu: Fix traceback spotted in -next
On r7s72100 Genmai v4.3-rc7 built with shmobile_defconfig spits out the
following during boot:
sh_mtu2 fcff0000.timer: ch0: used for clock events
WARNING: CPU: 0 PID: 1 at drivers/clk/clk.c:675 clk_core_disable+0x2c/0x6c()
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.3.0-rc7 #1
Hardware name: Generic R7S72100 (Flattened Device Tree)
Backtrace:
[<c00133d4>] (dump_backtrace) from [<c0013570>] (show_stack+0x18/0x1c)
[<c0013558>] (show_stack) from [<c01c7aac>] (dump_stack+0x74/0x90)
[<c01c7a38>] (dump_stack) from [<c00272fc>] (warn_slowpath_common+0x88/0xb4)
[<c0027274>] (warn_slowpath_common) from [<c0027400>] (warn_slowpath_null+0x24/0x2c)
[<c00273dc>] (warn_slowpath_null) from [<c03a9320>] (clk_core_disable+0x2c/0x6c)
[<c03a92f4>] (clk_core_disable) from [<c03aa0a0>] (clk_disable+0x40/0x4c)
[<c03aa060>] (clk_disable) from [<c0395d2c>] (sh_mtu2_disable+0x24/0x50)
[<c0395d08>] (sh_mtu2_disable) from [<c0395d6c>] (sh_mtu2_clock_event_shutdown+0x14/0x1c)
[<c0395d58>] (sh_mtu2_clock_event_shutdown) from [<c007d7d0>] (clockevents_switch_state+0xc8/0x114)
[<c007d708>] (clockevents_switch_state) from [<c007d834>] (clockevents_shutdown+0x18/0x28)
[<c007d81c>] (clockevents_shutdown) from [<c007dd58>] (clockevents_exchange_device+0x70/0x78)
[<c007dce8>] (clockevents_exchange_device) from [<c007e578>] (tick_check_new_device+0x88/0xe0)
[<c007e4f0>] (tick_check_new_device) from [<c007daf0>] (clockevents_register_device+0xac/0x120)
[<c007da44>] (clockevents_register_device) from [<c0395be8>] (sh_mtu2_probe+0x230/0x350)
[<c03959b8>] (sh_mtu2_probe) from [<c028b6f0>] (platform_drv_probe+0x50/0x98)
Reported-by: Chris Brandt <chris.brandt@renesas.com>
Fixes: 19a9ffb ("clockevents/drivers/sh_mtu2: Migrate to new 'set-state' interface")
Cc: Viresh Kumar <viresh.kumar@linaro.org>
Cc: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Signed-off-by: Magnus Damm <damm+renesas@opensource.se>
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org>
When doing memcpy/memset of EQEs, we should use sizeof struct
mlx4_eqe as the base size and not caps.eqe_size which could be bigger.
If caps.eqe_size is bigger than the struct mlx4_eqe then we corrupt
data in the master context.
When using a 64 byte stride, the memcpy copied over 63 bytes to the
slave_eq structure. This resulted in copying over the entire eqe of
interest, including its ownership bit -- and also 31 bytes of garbage
into the next WQE in the slave EQ -- which did NOT include the ownership
bit (and therefore had no impact).
However, once the stride is increased to 128, we are overwriting the
ownership bits of *three* eqes in the slave_eq struct. This results
in an incorrect ownership bit for those eqes, which causes the eq to
seem to be full. The issue therefore surfaced only once 128-byte EQEs
started being used in SRIOV and (overarchitectures that have 128/256
byte cache-lines such as PPC) - e.g after commit 77507aa249ae
"net/mlx4_core: Enable CQE/EQE stride support".
Fixes: 08ff32352d6f ('mlx4: 64-byte CQE/EQE support')
Signed-off-by: Carol L Soto <clsoto@linux.vnet.ibm.com>
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
present
We do not set the ins_vlan field to zero when no vlan id is present in the packet.
Since WQEs in the TX ring are not zeroed out between uses, this oversight
could result in having vlan flags present in the WQE ctrl segment when no
vlan is preset.
Fixes: e38af4faf01d ('net/mlx4_en: Add support for hardware accelerated 802.1ad vlan')
Reported-by: Gideon Naim <gideonn@mellanox.com>
commit 2751c9882b947292fcfb084c4f604e01724af804 ("vhost: cross-endian
support for legacy devices") introduced a minor regression: even with
cross-endian disabled, and even on LE host, vhost_is_little_endian is
checking is_le flag so there's always a branch.
To fix, simply check virtio_legacy_is_little_endian first.
Cc: Greg Kurz <gkurz@linux.vnet.ibm.com>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Reviewed-by: Greg Kurz <gkurz@linux.vnet.ibm.com>
During Tx cleanup it's still possible for the descriptor data to be
read ahead of the descriptor index. A memory barrier is required between
the read of the descriptor index and the start of the Tx cleanup loop.
This allows a change to a lighter-weight barrier in the Tx transmit
routine just before updating the current descriptor index.
Since the memory barrier does result in extra overhead on arm64, keep
the previous change to not chase the current descriptor value. This
prevents the execution of the barrier for each loop performed.
Suggested-by: Alexander Duyck <alexander.duyck@gmail.com>
Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com>
Forcedeth currently uses disable_irq_lockdep and enable_irq_lockdep, which in
some configurations simply calls local_irq_disable. This causes errant warnings
in the netpoll path as in netpoll_send_skb_on_dev, where we disable irqs using
local_irq_save, leading to the following warning:
WARNING: at net/core/netpoll.c:352 netpoll_send_skb_on_dev+0x243/0x250() (Not
tainted)
Hardware name:
netpoll_send_skb_on_dev(): eth0 enabled interrupts in poll
(nv_start_xmit_optimized+0x0/0x860 [forcedeth])
Modules linked in: netconsole(+) configfs ipv6 iptable_filter ip_tables ppdev
parport_pc parport sg microcode serio_raw edac_core edac_mce_amd k8temp
snd_hda_codec_realtek snd_hda_codec_generic forcedeth snd_hda_intel
snd_hda_codec snd_hwdep snd_seq snd_seq_device snd_pcm snd_timer snd soundcore
snd_page_alloc i2c_nforce2 i2c_core shpchp ext4 jbd2 mbcache sr_mod cdrom sd_mod
crc_t10dif pata_amd ata_generic pata_acpi sata_nv dm_mirror dm_region_hash
dm_log dm_mod [last unloaded: scsi_wait_scan]
Pid: 1940, comm: modprobe Not tainted 2.6.32-573.7.1.el6.x86_64.debug #1
Call Trace:
[<ffffffff8107bbc1>] ? warn_slowpath_common+0x91/0xe0
[<ffffffff8107bcc6>] ? warn_slowpath_fmt+0x46/0x60
[<ffffffffa00fe5b0>] ? nv_start_xmit_optimized+0x0/0x860 [forcedeth]
[<ffffffff814b3593>] ? netpoll_send_skb_on_dev+0x243/0x250
[<ffffffff814b37c9>] ? netpoll_send_udp+0x229/0x270
[<ffffffffa02e3299>] ? write_msg+0x39/0x110 [netconsole]
[<ffffffffa02e331b>] ? write_msg+0xbb/0x110 [netconsole]
[<ffffffff8107bd55>] ? __call_console_drivers+0x75/0x90
[<ffffffff8107bdba>] ? _call_console_drivers+0x4a/0x80
[<ffffffff8107c445>] ? release_console_sem+0xe5/0x250
[<ffffffff8107d200>] ? register_console+0x190/0x3e0
[<ffffffffa02e71a6>] ? init_netconsole+0x1a6/0x216 [netconsole]
[<ffffffffa02e7000>] ? init_netconsole+0x0/0x216 [netconsole]
[<ffffffff810020d0>] ? do_one_initcall+0xc0/0x280
[<ffffffff810d4933>] ? sys_init_module+0xe3/0x260
[<ffffffff8100b0d2>] ? system_call_fastpath+0x16/0x1b
---[ end trace f349c7af88e6a6d5 ]---
console [netcon0] enabled
netconsole: network logging started
Fix it by modifying the forcedeth code to use
disable_irq_nosync_lockdep_irqsavedisable_irq_nosync_lockdep_irqsave instead,
which saves and restores irq state properly. This also saves us a little code
in the process
Tested by the reporter, with successful restuls
Patch applies to the head of the net tree
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
CC: "David S. Miller" <davem@davemloft.net>
Reported-by: Vasily Averin <vvs@sw.ru>
Pull ARM fixes from Russell King:
"Two fixes for ARM and one for clkdev:
- Fix another build issue with vdsomunge on non-glibc systems
- Fix a randconfig build error caused by an invalid configuration
- Fix a clkdev problem causing the Nokia n700 to no longer boot"
* 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-arm:
clkdev: fix clk_add_alias() with a NULL alias device name
ARM: 8445/1: fix vdsomunge not to depend on glibc specific byteswap.h
ARM: make RiscPC depend on MMU
Request_module gets really unhappy when called from async probing, so
revert to not auto load device handler modules during the SCSI bus
scan. While autoloading would be really useful we never did this
until 4.3-rc and it turns out that functionality doesn't actually
work.
Fixes: 566079 ("dm-mpath, scsi_dh: request scsi_dh modules in scsi_dh, not dm-mpath")
Reported-by: Paul Mackerras <paulus@ozlabs.org>
Tested-by: Paul Mackerras <paulus@ozlabs.org>
Signed-off-by: James Bottomley <JBottomley@Odin.com>
for_each_available_child_of_node performs an of_node_get on each iteration, so
a break out of the loop requires an of_node_put.
A simplified version of the semantic patch that fixes this problem is as
follows (http://coccinelle.lip6.fr):
// <smpl>
expression root,e;
local idexpression child;
for_each_available_child_of_node(root, child) {
... when != of_node_put(child)
when != e = child
return child;
+ of_node_put(child);
? return ...;
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
for_each_compatible_node performs an of_node_get on each iteration, so
// <smpl>
expression e;
local idexpression n;
for_each_compatible_node(n,...) {
... when != of_node_put(n)
when != e = n
return n;
+ of_node_put(n);
? return ...;
// </smpl>
// <smpl>
expression root,e;
when != e = child
return child;
? return ...;
// </smpl>
// <smpl>
local idexpression r.n;
expression r,e;
for_each_available_child_of_node(r,n) {
of_node_put(n);
e = n
+ of_node_put(n);
? break;
... when != n
// </smpl>
for_each_child_of_node performs an of_node_get on each iteration, so
// <smpl>
expression r,e;
for_each_child_of_node(r,n) {
of_node_put(n);
e = n
+ of_node_put(n);
? break;
... when != n
// </smpl>
// <smpl>
expression r,e;
of_node_put(n);
e = n
+ of_node_put(n);
? break;
... when != n
// </smpl>
The commit 1bab0de0274f ("dm-mpath, scsi_dh: don't let dm detach device
handlers") removed reference counting of attached scsi device handler.
As a result, handler data is freed immediately via scsi_dh->detach()
in the context of scsi_remove_device() where activation request can be
still in flight.
This patch moves scsi_dh_handler_detach() to sdev releasing function,
scsi_device_dev_release_usercontext(), at that point the device
is already in quiesced state.
Fixes: 1bab0de0274f ("dm-mpath, scsi_dh: don't let dm detach device handlers")
Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com>
Acked-by: Christoph Hellwig <hch@lst.de>
When pci_pool_alloc fails in mvs_task_prep then task->lldd_task stays
NULL but it's later used in mvs_abort_task as slot which is passed
to mvs_slot_task_free causing NULL pointer dereference.
Just return from mvs_slot_task_free when passed with NULL slot.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=101891
Signed-off-by: Dāvis Mosāns <davispuh@gmail.com>
Reviewed-by: Tomas Henzl <thenzl@redhat.com>
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
The RX buffer size calulation failed to account for the length granularity
(which is now 32 bytes)...
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
Both Renesas R-Car and RZ/A1 manuals state that RX buffer length must be
a multiple of 32 bytes, while the driver only uses 16 byte granularity...
Having a traceable function in the sched_clock() path leads to a recursion
within ftrace and a kernel crash.
We should not trace digicolor_timer_sched_read() function. Fix this by adding
the notrace attribute to this function.
Signed-off-by: Jisheng Zhang <jszhang@marvell.com>
Acked-by: Baruch Siach <baruch@tkos.co.il>
We should not trace the ftm_read_sched_clock() function.
Fix this by adding the notrace attribute to this function.
We should not trace the pit_read_sched_clock() function. Fix this by adding a
Currently prima2 timer can be used as a scheduler clock. We properly
marked sirfsoc_read_sched_clock() as notrace but we then call another
function sirfsoc_timer_read() that _wasn't_ notrace.
Fix this by adding notrace attribute to the sirfsoc_timer_read() function.
Currently samsung_pwm_timer can be used as a scheduler clock. We properly
marked samsung_read_sched_clock() as notrace but we then call another
function samsung_clocksource_read() that _wasn't_ notrace.
Fix this by adding notrace attribute to the samsung_clocksource_read()
function.
Currently pistachio can be used as a scheduler clock. We properly marked
pistachio_read_sched_clock() as notrace but we then call another function
pistachio_clocksource_read_cycles() that _wasn't_ notrace.
Fix this by adding notrace attribute to the pistachio_clocksource_read_cycles()
function.
Currently arm_global_timer can be used as a scheduler clock. We properly
marked gt_sched_clock_read() as notrace but we then call another function
gt_counter_read() that _wasn't_ notrace.
Fix this by adding an extra notrace function to keep other users of
gt_counter_read() traceable.
button bits
commit 92bac83dd79e ("Input: alps - non interleaved V2 dualpoint has
separate stick button bits") assumes that all alps v2 non-interleaved
dual point setups have the separate stick button bits.
Later we limited this to Dell laptops only because of reports that this
broke things on non Dell laptops. Now it turns out that this breaks things
on the Dell Latitude D600 too. So it seems that only the Dell Latitude
D420/430/620/630, which all share the same touchpad / stick combo,
have these separate bits.
This patch limits the checking of the separate bits to only these models
fixing regressions with other models.
Reported-and-tested-by: Larry Finger <Larry.Finger@lwfinger.net>
Tested-by: Hans de Goede <hdegoede@redhat.com>
Acked-By: Pali Rohár <pali.rohar@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
Pull iommu fixes from Joerg Roedel:
"Two late fixes for the AMD IOMMU driver:
- add an additional check to the io page-fault handler to avoid a
BUG_ON being hit in handle_mm_fault()
- fix a problem with devices writing to the system management area
and were blocked by the IOMMU because the driver wrongly cleared
out the DTE flags allowing that access"
* tag 'iommu-fixes-v4.3-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu:
iommu/amd: Don't clear DTE flags when modifying it
iommu/amd: Fix BUG when faulting a PROT_NONE VMA
Pull md fixes from Neil Brown:
"Some raid1/raid10 fixes.
I meant to get this to you before -rc7, but what with all the travel
plans..
Two fixes for bugs that are in both raid1 and raid10. Both related to
bad-block-lists and at least one needs to be back ported to 3.1.
Also a revision for the "new" layout in raid10. This "new" code
(which aims to improve robustness) actually reduces robustness in some
cases. It probably isn't in use at all as not public user-space code
makes use of these new layouts. However just in case someone has
their own code, it would be good to get the WARNing out for them
sooner"
* tag 'md/4.3-rc6-fixes' of git://neil.brown.name/md:
md/raid10: fix the 'new' raid10 layout to work correctly.
md/raid10: don't clear bitmap bit when bad-block-list write fails.
md/raid1: don't clear bitmap bit when bad-block-list write fails.
md/raid10: submit_bio_wait() returns 0 on success
md/raid1: submit_bio_wait() returns 0 on success
"Last fixes from me: one amdgpu/radeon suspend resume and one leak fix,
along with one vmware fix for some issues when command submission
fails"
drm/amdgpu: don't try to recreate sysfs entries on resume
drm/radeon: don't try to recreate sysfs entries on resume
drm/amdgpu: stop leaking page flip fence
drm/vmwgfx: Stabilize the command buffer submission code
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c fixes from Wolfram Sang:
"Two driver bugfixes for the I2C subsystem"
* 'i2c/for-current' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux:
i2c: pnx: fix runtime warnings caused by enabling unprepared clock
i2c: mv64xxx: really allow I2C offloading
