At i.mx6q sabrelite, there is a usb hub on board. After several
suspend suspend/resume iterations, the usb host will be broken.
It is IC limitation, and similar with:
574b9641d5846e58273dac6bf80fcf1ff312c5c9
Signed-off-by: Peter Chen <peter.chen@freescale.com>
Signed-off-by: make shi <b15407@freescale.com>
Add OV5642 csi camera support for i.mx6 sabre-lite board
Signed-off-by: Yi Li <R80015@freescale.com>
There are two couples register for HDMI PHY interrupt/mask:
HDMI_FC_INT2, HDMI_FC_MASK2 and HDMI_IH_FC_STAT2, HDMI_IH_MUTE_FC_STAT2.
The register can not mixed use it, otherwise the interrupt will missing
and not clean.
Mask interrupt with HDMI_IH_MUTE_FC_STAT2 so check interrupt
should use register HDMI_IH_FC_STAT2.
Signed-off-by: Sandor Yu <R01008@freescale.com>
- Add adv7180 driver to ARM2 support
- Add adv7180 configure
- Chenge CSI configure for BT656 support
Signed-off-by: Even Xu <b21019@freescale.com>
System will hang at PHY PLL lock wating loop, if HDMI PHY is down.
Added timeout check for HDMI PHY PLL lock waiting.
Kconfig and Makefile was modified in order to
enable adv7180 driver for mx6q architecture.
adv7180.c mutex was changed to semaphore as is described in
"https://lwn.net/Articles/304725/ ".
sensor data structure is added in fsl_devices.h.
mxc_v4l2_capture.c condition in mxc_v4l2_sparam
was removed because is going to be always true
capture mode only have 1 possible value as is described in
"https://lwn.net/Articles/235023/".
ipu_capture.c clock divisor setup was added at init the csi.
Signed-off-by: B37753 <B37753@freescale.com>
Avoid necessary clk_disable operation
Signed-off-by: Larry Li <b20787@freescale.com>
Flexcan can use the self wakeup function to wakeup system in system
suspend state.
Signed-off-by: Dong Aisheng <b29396@freescale.com>
The reason is it does not call usb_ep_disable at gadget disable routine.
The asrc_audio_clock in MX5 is different from MX6.Thus the divider
value set can not be used in the MX6. Part of noise of ASRC output
is caused by this.
Add the function to calculate the divider and prescaler value
according to the sample rate and asrc_audio_clock.
Signed-off-by: Chen Liangjun <b36089@freescale.com>
issue:
in the reverted patch, sdhc driver will claim host on its
entering suspend state. and the wifi driver will hold host on
its loading. so once system is about to enter suspend state,
system will be pended on claiming host.
fix:
- Revert "ENGR00170944 [MX6Q MMC]suspend/resume crash"
This reverts commit 3b2e3729dc57a5ff532552cde49de7ace4c5792c.
Signed-off-by: Ryan QIAN <b32804@freescale.com>
Too much printk make the dmesg mess.
Change it to dynamic print mode.
Signed-off-by: Huang Shijie <b32955@freescale.com>
- Fix OV3640 XGA cannot work, XGA can be supported
- Add OV3640 720P, 1080P at 15fps support
- Fix a MXC_V4L2_CAPTURE driver bug, when setting param,
only when current mode and framerate are the same
with param, then not change current setting again
This issue will happen only when suspend bit is set but phcd is not set
The root cause of this issue is the IC defect.
- If the suspend bit is set without phcd bit set, host controller
can't resume normally
- The workaround is after set suspend bit, we need set the following
bit in USB PHY at once:
HW_USBPHY_PWD_RXPWDRX
HW_USBPHY_PWD_RXPWDDIFF
HW_USBPHY_PWD_RXPWD1PT1
HW_USBPHY_PWD_RXPWDENV
HW_USBPHY_PWD_TXPWDv2I
HW_USBPHY_PWD_TXPWDIBIAS
HW_USBPHY_PWD_TXPWDFS
- Furthermore, after resume, we must clear these bits during the K state
- IC has no plan to fix this issue
- This issue only happen on MX6Q/MX28
core part
Signed-off-by: Tony LIU <junjie.liu@freescale.com>
driver part
Change sensor configuration to fix this issue.
Add ioctl support to complete RTC feature.
Signed-off-by: Anson Huang <b20788@freescale.com>
Move HDMI csc clock setting to fucntion mxc_hdmi_enable_video_path.
Exposure calculate function was not used and this produce build
warning, enable this function not only remove this warning, but
also get a better image quality when take picture.
Signed-off-by: Yuxi Sun <b36102@freescale.com>
fix build warnings on pfuze driver:
arch/arm/mach-mx6/mx6q_sabreauto_pmic_pfuze100.c:388:
warning: initialization from incompatible pointer type
drivers/mfd/pfuze-core.c:523:
drivers/mfd/pfuze-core.c:412:
warning: 'pfuze_add_subdevice' defined but not used
Signed-off-by: Robin Gong <B38343@freescale.com>
Remove build warnings in MLB driver.
Signed-off-by: Terry Lv <r65388@freescale.com>
fix following build warning:
drivers/mmc/host/sdhci.c: In function 'sdhci_clk_worker':
drivers/mmc/host/sdhci.c:53: warning: unused variable 'flags'
drivers/mmc/host/sdhci.c: In function 'sdhci_resume_host':
drivers/mmc/host/sdhci.c:1751:
warning: 'ret' may be used uninitialized in this function
Signed-off-by: Tony Lin <tony.lin@freescale.com>
The original FEC_MII_TIMEOUT was set to 1ms, which is too low when
passed to the usecs_to_jiffies macro.
On ARM one jiffy is 10ms, so use msecs_to_jiffies instead and use
a timeout of 30ms, which corresponds to 3 jiffies.
After running 3 hours NFS boots, the MDIO timeout do not occur
anymore.
Signed-off-by: Rogerio Pimentel <rogerio.pimentel@freescale.com>
Enable HDMI output CSC.
Enable HDMI under scan.
fix gpu kernel module can not be removed issue
Signed-off-by: Wu Guoxing <b39297@freescale.com>
Acked-by: Lily Zhang
Add MLB main driver for mx6q.
if the system suspend in the process of data transfer, current request
is broken by the suspend request, thus there're sd/mmc requests error logs.
to prevent this error, add a claim host in suspend function and release it
in resume function to make sure the request is finished before entering suspend
and next request could be started after resuming.
Enable "CONFIG_DMA_API_DEBUG" in kernel, and system print:
DMA-API: device driver tries to free DMA memory it has not
allocated [device address=0x0000000046688020]...[<80222494>]
(debug_dma_unmap_page+0x8c/0x98) from [<802a36a0>]
(fec_enet_interrupt+0x430/0x5ac)
Correct the usage of "dma_map_single" function.
Signed-off-by: Fugang Duan <B38611@freescale.com>
call clk_enable/clk_disable in atomic is forbidden.
move all the calls out of atomic context.
-Correct gc355 initial power state to poweroff.
-Separate clock gating operation in function gckOS_SetGPUPower().
-Turn on clock while suspend GPU cores.
-Remove clock switch in drv_open().
Signed-off-by: Loren Huang <b02279@freescale.com>
- Only 44.1Khz audio are supported at i.MX6q, since only 44.1Khz
local playback are supported at i.MX6q.
- Since there is no feedback at current usb audio framework,
it may have pop noise/no sound after play some minutes.
- About how to test: please refer Documentation/arm/imx/udc.txt
The DMA RX thread may run on another CPU, while the application
runs on one CPU.
The application will close the uart when it finishes the required reading.
But the DMA RX thread maybe still running in this situation.
So add a wait queue to synchronize the __TWO__ sides in the SMP.
This reverts commit 7e5181cd28ac3d786d0760f405fa5a1e3407a7a9.
ssh://sw-git01-tx30.am.freescale.net/git/sw_git/repos/linux-2.6-imx into imx_2.6.38
- After auto suspend, attach device to hub will cause host can't work any more
- after system suspend, attach device to hub will cause host can't work any more
- HSDISCONNECTDEC logic error
- Set RUNSTOP in bus suspend, if no short delay, host can't work any more
Add all non-interlaced CEA mode to default modelist
Add XGA and SXGA video mode to default modelist
Configure register 33&40&47 to set standby voltage of SW1A/1B/1C
Most of them are from community
- Using correct dequeue method
- Fix the ISOC_XFER condition judgement
- Need to wmb before prime
- Fix some conditions of udc->max_ep judgement
add new regulator driver for pfuze100 based on mfd structure
add pfuze core driver for mx6
Allow UART to be a source from wakeup from low power mode.
Tested on a mx6sabrelite (where ttymxc1 is the console) by doing:
echo enabled > /sys/devices/platform/imx-uart.1/tty/ttymxc1/power/wakeup
echo mem > /sys/power/state
and then pressing a key in the console will wakeup the system.
1. create sys node for fb name, cable state, edid data
2. call kobject_uevent_env pass cable state
Enlarge the RX FIFO threthold from 1 to 16 when the DMA is enabled.
This will give us better performance.
This commit intends to implement the flowchart and details
documented in the HDMI Transmitter Controller User Guide
section entitled "Programming Model".
Some input is also from the Synopsys API code.
The HDMI specification requires HDMI to set itself to VGA DVI mode
before reading the EDID.
So follow this sequence when HDMI is hotplugged:
1. Hdmi connector is plugged in, HDMI video gets an interrupt.
2. Clear out video mode list. Add only VGA DVI mode to list.
3. Request VGA DVI mode (call fb_set_var())
4. HDMI video driver will get FB_EVENT_MODE_CHANGE callback and
call mxc_hdmi_setup() to set up HDMI.
5. Read the edid and add video modes from edid. Select the video
mode that is similar to the command line default.
6. Request VGA DVI mode (call fb_set_var())
7. HDMI video driver will get FB_EVENT_MODE_CHANGE callback and
do mxc_hdmi_setup().
Also included is a workaround for an overflow condition in the HDMI.
The frame composer has an arithmetic unit that gets updated every time
we write to one of the FC registers. But sometimes, depending on the
relation between the tmds and sfr clocks, it may happen that this unit
doesn't get updated, even though the registers are holding correct
values. The workaround for this is, after completing the controller
configuration, to rewrite one of the FC registers (i.e. FC_INVIDCONF)
three or four times with the same value, and then follow it up by a SW
reset to the TMDS clock domain (MC_SWRSTZ).
We clear the overflow condition as described above every time we
change video mode. Also an overflow interupt handler will clear the
overflow condition if it happens again. This overflow condition is
expected (and not a problem) when we are in DVI (non-HDMI) mode, so
we do not worry about it in that case.
Signed-off-by: Alan Tull <alan.tull@freescale.com>
This reverts commit 6565023ad182d3347972aad3f1a13ba57266e81a.
Allow UART to be a source for wakeup from low power mode.
and then pressing a key in the console will wakeup the sytem.
While checking valid interface number we should compare MAX_CONFIG_INTERFACES
with the variable 'intf' (which holds the lower 8bits of w_index) rather than
'w_index'
Signed-off-by: Jassi Brar <jassi.brar@samsung.com>
On Audio class, the wLength field of the Setup
packet, contains the data payload size of the
following Data phase. Instead of harcoding values,
use wLength.
This also fixes a bug where Gadget driver had to
receive 3 bytes, but it was queueing a ZLP.
Signed-off-by: Felipe Balbi <balbi@ti.com>
While testing g_audio with HighSpeed UDC on a
FS Hub, we had no configurations to present to
the host. That's because both speeds where
mutually exclusive.
as_out_ep_desc contines to be used during gadget enumeration and thus
should not be marked as __initdata
Signed-off-by: Martin Jackson <mjackson220.list@gmail.com>
