path: root/drivers
2012-04-11kconfig-disable-a-few-options-rt.patchThomas Gleixner
Disable stuff which is known to have issues on RT Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-11dm: Make rt awareThomas Gleixner
Use the BUG_ON_NORT variant for the irq_disabled() checks. RT has interrupts legitimately enabled here as we cant deadlock against the irq thread due to the "sleeping spinlocks" conversion. Reported-by: Luis Claudio R. Goncalves <lclaudio@uudg.org> Cc: stable-rt@vger.kernel.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-11scsi-fcoe-rt-aware.patchThomas Gleixner
2012-04-11sysrq: Allow immediate Magic SysRq output for PREEMPT_RT_FULLFrank Rowand
Add a CONFIG option to allow the output from Magic SysRq to be output immediately, even if this causes large latencies. If PREEMPT_RT_FULL, printk() will not try to acquire the console lock when interrupts or preemption are disabled. If the console lock is not acquired the printk() output will be buffered, but will not be output immediately. Some drivers call into the Magic SysRq code with interrupts or preemption disabled, so the output of Magic SysRq will be buffered instead of printing immediately if this option is not selected. Even with this option selected, Magic SysRq output will be delayed if the attempt to acquire the console lock fails. Signed-off-by: Frank Rowand <frank.rowand@am.sony.com> Link: http://lkml.kernel.org/r/4E7CEF60.5020508@am.sony.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-11kgdb/serial: Short term workaroundJason Wessel
On 07/27/2011 04:37 PM, Thomas Gleixner wrote: > - KGDB (not yet disabled) is reportedly unusable on -rt right now due > to missing hacks in the console locking which I dropped on purpose. > To work around this in the short term you can use this patch, in addition to the clocksource watchdog patch that Thomas brewed up. Comments are welcome of course. Ultimately the right solution is to change separation between the console and the HW to have a polled mode + work queue so as not to introduce any kind of latency. Thanks, Jason.
2012-04-11ARM: at91: tclib: Default to tclib timer for RTThomas Gleixner
RT is not too happy about the shared timer interrupt in AT91 devices. Default to tclib timer for RT. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-11rt: Improve the serial console PASS_LIMITIngo Molnar
Beyond the warning: drivers/tty/serial/8250/8250.c:1613:6: warning: unused variable ‘pass_counter’ [-Wunused-variable] the solution of just looping infinitely was ugly - up it to 1 million to give it a chance to continue in some really ugly situation. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-11drivers-tty-fix-omap-lock-crap.patchThomas Gleixner
2012-04-11serial: 8250: Call flush_to_ldisc when the irq is threadedIngo Molnar
2012-04-11serial: 8250: Clean up the locking for -rtIngo Molnar
2012-04-11md: raid5: Make raid5_percpu handling RT awareThomas Gleixner
__raid_run_ops() disables preemption with get_cpu() around the access to the raid5_percpu variables. That causes scheduling while atomic spews on RT. Serialize the access to the percpu data with a lock and keep the code preemptible. Reported-by: Udo van den Heuvel <udovdh@xs4all.nl> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Udo van den Heuvel <udovdh@xs4all.nl>
2012-04-11USB: Fix the mouse problem when copying large amounts of dataWu Zhangjin
When copying large amounts of data between the USB storage devices and the hard disk, the USB mouse will not work, this patch fixes it. [NOTE: This problem have been found in the Loongson family machines, not sure whether it is producible on other platforms] Signed-off-by: Hu Hongbing <huhb@lemote.com> Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com>
2012-04-11drivers: net: gianfar: Make RT awareThomas Gleixner
The adjust_link() disables interrupts before taking the queue locks. On RT those locks are converted to "sleeping" locks and therefor the local_irq_save/restore must be converted to local_irq_save/restore_nort. Reported-by: Xianghua Xiao <xiaoxianghua@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Xianghua Xiao <xiaoxianghua@gmail.com>
2012-04-11drivers/net: vortex fix locking issuesSteven Rostedt
Argh, cut and paste wasn't enough... Use this patch instead. It needs an irq disable. But, believe it or not, on SMP this is actually better. If the irq is shared (as it is in Mark's case), we don't stop the irq of other devices from being handled on another CPU (unfortunately for Mark, he pinned all interrupts to one CPU). Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> drivers/net/ethernet/3com/3c59x.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-04-11drivers/net: fix livelock issuesThomas Gleixner
Preempt-RT runs into a live lock issue with the NETDEV_TX_LOCKED micro optimization. The reason is that the softirq thread is rescheduling itself on that return value. Depending on priorities it starts to monoplize the CPU and livelock on UP systems. Remove it. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-11tty: Do not disable interrupts in put_ldisc on -rtThomas Gleixner
Fixes the following on PREEMPT_RT: BUG: sleeping function called from invalid context at kernel/rtmutex.c:684 in_atomic(): 0, irqs_disabled(): 1, pid: 9116, name: sshd Pid: 9116, comm: sshd Not tainted 2.6.31-rc6-rt2 #6 Call Trace: [<ffffffff81034a4f>] __might_sleep+0xec/0xee [<ffffffff812fbc6d>] rt_spin_lock+0x34/0x75 [ffffffff81064a83>] atomic_dec_and_spin_lock+0x36/0x54 [<ffffffff811df7c7>] put_ldisc+0x57/0xa6 [<ffffffff811dfb87>] tty_ldisc_hangup+0xe7/0x19f [<ffffffff811d9224>] do_tty_hangup+0xff/0x319 [<ffffffff811d9453>] tty_vhangup+0x15/0x17 [<ffffffff811e1263>] pty_close+0x127/0x12b [<ffffffff811dac41>] tty_release_dev+0x1ad/0x4c0 .... Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-11usb: Use local_irq_*_nort() variantsSteven Rostedt
[ tglx: Now that irqf_disabled is dead we should kill that ] Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-11input: gameport: Do not disable interrupts on PREEMPT_RTIngo Molnar
Use the _nort() primitives. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-11infiniband: Mellanox IB driver patch use _nort() primitivesSven-Thorsten Dietrich
Fixes in_atomic stack-dump, when Mellanox module is loaded into the RT Kernel. Michael S. Tsirkin <mst@dev.mellanox.co.il> sayeth: "Basically, if you just make spin_lock_irqsave (and spin_lock_irq) not disable interrupts for non-raw spinlocks, I think all of infiniband will be fine without changes." Signed-off-by: Sven-Thorsten Dietrich <sven@thebigcorporation.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-11ide: Do not disable interrupts for PREEMPT-RTIngo Molnar
Use the local_irq_*_nort variants. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-11ata: Do not disable interrupts in ide code for preempt-rtSteven Rostedt
Use the local_irq_*_nort variants. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-11hwlatdetect.patchCarsten Emde
Jon Masters developed this wonderful SMI detector. For details please consult Documentation/hwlat_detector.txt. It could be ported to Linux 3.0 RT without any major change. Signed-off-by: Carsten Emde <C.Emde@osadl.org>
2012-04-11pci: Use __wake_up_all_locked pci_unblock_user_cfg_access()Thomas Gleixner
The waitqueue is protected by the pci_lock, so we can just avoid to lock the waitqueue lock itself. That prevents the might_sleep()/scheduling while atomic problem on RT Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: stable-rt@vger.kernel.org
2012-04-11locking-various-init-fixes.patchThomas Gleixner
2012-04-11of-convert-devtree-lock.patchThomas Gleixner
2012-04-11OF: Fixup resursive locking code pathsThomas Gleixner
There is no real reason to use a rwlock for devtree_lock. It even could be a mutex, but unfortunately it's locked from cpu hotplug pathes which can't schedule :( So it needs to become a raw lock on rt as well. devtree_lock would be the only user of a raw_rw_lock, so we are better of cleaning the recursive locking pathes which allows us to convert devtree_lock to a read_lock. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-11drivers: net: at91_ether: Make mdio protection -rt safeThomas Gleixner
Neither the phy interrupt nor the timer callback which updates the link status in absense of a phy interrupt are taking lp->lock which serializes the MDIO access. This works on mainline as at91 is an UP machine. On preempt-rt the timer callback can run even in the spin_lock_irq(&lp->lock) protected code pathes because spin_lock_irq is neither disabling interrupts nor disabling preemption. Fix this by adding proper locking to at91ether_phy_interrupt() and at91_check_ether() which serializes the access on -rt. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-11drivers: net: ehea: Make rx irq handler non-threaded (IRQF_NO_THREAD)Darren Hart
The underlying hardware is edge triggered but presented by XICS as level triggered. The edge triggered interrupts are not reissued after masking. This is not a problem in mainline which does not mask the interrupt (relying on the EOI mechanism instead). The threaded interrupts in PREEMPT_RT do mask the interrupt, and can lose interrupts that occurred while masked, resulting in a hung ethernet interface. The receive handler simply calls napi_schedule(), as such, there is no significant additional overhead in making this non-threaded, since we either wakeup the threaded irq handler to call napi_schedule(), or just call napi_schedule() directly to wakeup the softirqs. As the receive handler is lockless, there is no need to convert any of the ehea spinlock_t's to raw_spinlock_t's. Without this patch, a simple scp file copy loop would fail quickly (usually seconds). We have over two hours of sustained scp activity with the patch applied. Credit goes to Will Schmidt for lots of instrumentation and tracing which clarified the scenario and to Thomas Gleixner for the incredibly simple solution. Signed-off-by: Darren Hart <dvhltc@us.ibm.com> Acked-by: Will Schmidt <will_schmidt@vnet.ibm.com> Cc: Jan-Bernd Themann <themann@de.ibm.com> Cc: Nivedita Singhvi <niv@us.ibm.com> Cc: Brian King <bjking1@us.ibm.com> Cc: Michael Ellerman <ellerman@au1.ibm.com> Cc: Doug Maxey <doug.maxey@us.ibm.com> LKML-Reference: <4BF30793.5070300@us.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-11drivers/net: Use disable_irq_nosync() in 8139tooIngo Molnar
Use disable_irq_nosync() instead of disable_irq() as this might be called in atomic context with netpoll. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-11drivers/net: tulip_remove_one needs to call pci_disable_device()Ingo Molnar
Otherwise the device is not completely shut down. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-11clocksource: TCLIB: Allow higher clock rates for clock eventsBenedikt Spranger
As default the TCLIB uses the 32KiHz base clock rate for clock events. Add a compile time selection to allow higher clock resulution. Signed-off-by: Benedikt Spranger <b.spranger@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-11drivers: random: Reduce preempt disabled regionIngo Molnar
No need to keep preemption disabled across the whole function. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-11intel_idle: Convert i7300_idle_lock to raw spinlockMike Galbraith
24 core Intel box's first exposure to 3.0.12-rt30-rc3 didn't go well. [ 27.104159] i7300_idle: loaded v1.55 [ 27.104192] BUG: scheduling while atomic: swapper/2/0/0x00000002 [ 27.104309] Pid: 0, comm: swapper/2 Tainted: G N 3.0.12-rt30-rc3-rt #1 [ 27.104317] Call Trace: [ 27.104338] [<ffffffff810046a5>] dump_trace+0x85/0x2e0 [ 27.104372] [<ffffffff8144eb00>] thread_return+0x12b/0x30b [ 27.104381] [<ffffffff8144f1b9>] schedule+0x29/0xb0 [ 27.104389] [<ffffffff814506e5>] rt_spin_lock_slowlock+0xc5/0x240 [ 27.104401] [<ffffffffa01f818f>] i7300_idle_notifier+0x3f/0x360 [i7300_idle] [ 27.104415] [<ffffffff814546c7>] notifier_call_chain+0x37/0x70 [ 27.104426] [<ffffffff81454748>] __atomic_notifier_call_chain+0x48/0x70 [ 27.104439] [<ffffffff81001a39>] cpu_idle+0x89/0xb0 [ 27.104449] bad: scheduling from the idle thread! Signed-off-by: Mike Galbraith <efault@gmx.de> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1323258522.5057.73.camel@marge.simson.net Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-07Merge tag 'regmap-3.4-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap Pull two more small regmap fixes from Mark Brown: - Now we have users for it that aren't running Android it turns out that regcache_sync_region() is much more useful to drivers if it's exported for use by modules. Who knew? - Make sure we don't divide by zero when doing debugfs dumps of rbtrees, not visible up until now because everything was providing at least some cache on startup. * tag 'regmap-3.4-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap: regmap: prevent division by zero in rbtree_show regmap: Export regcache_sync_region()
2012-04-07Merge tag 'sh-for-linus' of git://github.com/pmundt/linux-shLinus Torvalds
Pull SuperH fixes from Paul Mundt. * tag 'sh-for-linus' of git://github.com/pmundt/linux-sh: sh: fix clock-sh7757 for the latest sh_mobile_sdhi driver serial: sh-sci: use serial_port_in/out vs sci_in/out. sh: vsyscall: Fix up .eh_frame generation. sh: dma: Fix up device attribute mismatch from sysdev fallout. sh: dwarf unwinder depends on SHcompact. sh: fix up fallout from system.h disintegration.
2012-04-06Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux Pull ACPI & Power Management patches from Len Brown: "Two fixes for cpuidle merge-window changes, plus a URL fix in MAINTAINERS" * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: MAINTAINERS: Update git url for ACPI cpuidle: Fix panic in CPU off-lining with no idle driver ACPI processor: Use safe_halt() rather than halt() in acpi_idle_play_dead()
2012-04-06Merge branch '3.4-rc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending Pull target fixes from Nicholas Bellinger: "Pull two tcm_fc fabric related fixes for -rc2: Note that both have been CC'ed to stable, and patch #1 is the important one that addresses a memory corruption bug related to FC exchange timeouts + command abort. Thanks again to MDR for tracking down this issue!" * '3.4-rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: tcm_fc: Do not free tpg structure during wq allocation failure tcm_fc: Add abort flag for gracefully handling exchange timeout
2012-04-06tcm_fc: Do not free tpg structure during wq allocation failureMark Rustad
Avoid freeing a registered tpg structure if an alloc_workqueue call fails. This fixes a bug where the failure was leaking memory associated with se_portal_group setup during the original core_tpg_register() call. Signed-off-by: Mark Rustad <mark.d.rustad@intel.com> Acked-by: Kiran Patil <Kiran.patil@intel.com> Cc: <stable@vger.kernel.org> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-04-06tcm_fc: Add abort flag for gracefully handling exchange timeoutMark Rustad
Add abort flag and use it to terminate processing when an exchange is timed out or is reset. The abort flag is used in place of the transport_generic_free_cmd function call in the reset and timeout cases, because calling that function in that context would free memory that was in use. The aborted flag allows the lifetime to be managed in a more normal way, while truncating the processing. This change eliminates a source of memory corruption which manifested in a variety of ugly ways. (nab: Drop unused struct fc_exch *ep in ft_recv_seq) Signed-off-by: Mark Rustad <mark.d.rustad@intel.com> Acked-by: Kiran Patil <Kiran.patil@intel.com> Cc: <stable@vger.kernel.org> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-04-06Merge branches 'idle-fix' and 'misc' into releaseLen Brown
2012-04-06Merge branch 'stable' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile Pull arch/tile bug fixes from Chris Metcalf: "This includes Paul Gortmaker's change to fix the <asm/system.h> disintegration issues on tile, a fix to unbreak the tilepro ethernet driver, and a backlog of bugfix-only changes from internal Tilera development over the last few months. They have all been to LKML and on linux-next for the last few days. The EDAC change to MAINTAINERS is an oddity but discussion on the linux-edac list suggested I ask you to pull that change through my tree since they don't have a tree to pull edac changes from at the moment." * 'stable' of git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: (39 commits) drivers/net/ethernet/tile: fix netdev_alloc_skb() bombing MAINTAINERS: update EDAC information tilepro ethernet driver: fix a few minor issues tile-srom.c driver: minor code cleanup edac: say "TILEGx" not "TILEPro" for the tilegx edac driver arch/tile: avoid accidentally unmasking NMI-type interrupt accidentally arch/tile: remove bogus performance optimization arch/tile: return SIGBUS for addresses that are unaligned AND invalid arch/tile: fix finv_buffer_remote() for tilegx arch/tile: use atomic exchange in arch_write_unlock() arch/tile: stop mentioning the "kvm" subdirectory arch/tile: export the page_home() function. arch/tile: fix pointer cast in cacheflush.c arch/tile: fix single-stepping over swint1 instructions on tilegx arch/tile: implement panic_smp_self_stop() arch/tile: add "nop" after "nap" to help GX idle power draw arch/tile: use proper memparse() for "maxmem" options arch/tile: fix up locking in pgtable.c slightly arch/tile: don't leak kernel memory when we unload modules arch/tile: fix bug in delay_backoff() ...
2012-04-06Merge tag 'stable/for-linus-3.4-rc1-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen Pull xen fixes from Konrad Rzeszutek Wilk: "Two fixes for regressions: * one is a workaround that will be removed in v3.5 with proper fix in the tip/x86 tree, * the other is to fix drivers to load on PV (a previous patch made them only load in PVonHVM mode). The rest are just minor fixes in the various drivers and some cleanup in the core code." * tag 'stable/for-linus-3.4-rc1-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/pcifront: avoid pci_frontend_enable_msix() falsely returning success xen/pciback: fix XEN_PCI_OP_enable_msix result xen/smp: Remove unnecessary call to smp_processor_id() xen/x86: Workaround 'x86/ioapic: Add register level checks to detect bogus io-apic entries' xen: only check xen_platform_pci_unplug if hvm
2012-04-06Merge tag 'mmc-fixes-for-3.4-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc Pull MMC fixes from Chris Ball: - Disable use of MSI in sdhci-pci, which caused multiple chipsets to stop working in 3.4-rc1. I'll wait to turn this on again until we have a chipset whitelist for it. - Fix a libertas SDIO powered-resume regression introduced in 3.3; thanks to Neil Brown and Rafael Wysocki for this fix. - Fix module reloading on omap_hsmmc. - Stop trusting the spec/card's specified maximum data timeout length, and use three seconds instead. Previously we used 300ms. Also cleanups and fixes for s3c, atmel, sh_mmcif and omap_hsmmc. * tag 'mmc-fixes-for-3.4-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (28 commits) mmc: use really long write timeout to deal with crappy cards mmc: sdhci-dove: Fix compile error by including module.h mmc: Prevent 1.8V switch for SD hosts that don't support UHS modes. Revert "mmc: sdhci-pci: Add MSI support" Revert "mmc: sdhci-pci: add quirks for broken MSI on O2Micro controllers" mmc: core: fix power class selection mmc: omap_hsmmc: fix module re-insertion mmc: omap_hsmmc: convert to module_platform_driver mmc: omap_hsmmc: make it behave well as a module mmc: omap_hsmmc: trivial cleanups mmc: omap_hsmmc: context save after enabling runtime pm mmc: omap_hsmmc: use runtime put sync in probe error patch mmc: sdio: Use empty system suspend/resume callbacks at the bus level mmc: bus: print bus speed mode of UHS-I card mmc: sdhci-pci: add quirks for broken MSI on O2Micro controllers mmc: sh_mmcif: Simplify calculation of mmc->f_min mmc: sh_mmcif: mmc->f_max should be half of the bus clock mmc: sh_mmcif: double clock speed mmc: block: Remove use of mmc_blk_set_blksize mmc: atmel-mci: add support for odd clock dividers ...
2012-04-06cpuidle: Fix panic in CPU off-lining with no idle driverToshi Kani
Fix a NULL pointer dereference panic in cpuidle_play_dead() during CPU off-lining when no cpuidle driver is registered. A cpuidle driver may be registered at boot-time based on CPU type. This patch allows an off-lined CPU to enter HLT-based idle in this condition. Signed-off-by: Toshi Kani <toshi.kani@hp.com> Cc: Boris Ostrovsky <boris.ostrovsky@amd.com> Reviewed-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Tested-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-04-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking updates from David Miller: 1) Fix inaccuracies in network driver interface documentation, from Ben Hutchings. 2) Fix handling of negative offsets in BPF JITs, from Jan Seiffert. 3) Compile warning, locking, and refcounting fixes in netfilter's xt_CT, from Pablo Neira Ayuso. 4) phonet sendmsg needs to validate user length just like any other datagram protocol, fix from Sasha Levin. 5) Ipv6 multicast code uses wrong loop index, from RongQing Li. 6) Link handling and firmware fixes in bnx2x driver from Yaniv Rosner and Yuval Mintz. 7) mlx4 erroneously allocates 4 pages at a time, regardless of page size, fix from Thadeu Lima de Souza Cascardo. 8) SCTP socket option wasn't extended in a backwards compatible way, fix from Thomas Graf. 9) Add missing address change event emissions to bonding, from Shlomo Pongratz. 10) /proc/net/dev regressed because it uses a private offset to track where we are in the hash table, but this doesn't track the offset pullback that the seq_file code does resulting in some entries being missed in large dumps. Fix from Eric Dumazet. 11) do_tcp_sendpage() unloads the send queue way too fast, because it invokes tcp_push() when it shouldn't. Let the natural sequence generated by the splice paths, and the assosciated MSG_MORE settings, guide the tcp_push() calls. Otherwise what goes out of TCP is spaghetti and doesn't batch effectively into GSO/TSO clusters. From Eric Dumazet. 12) Once we put a SKB into either the netlink receiver's queue or a socket error queue, it can be consumed and freed up, therefore we cannot touch it after queueing it like that. Fixes from Eric Dumazet. 13) PPP has this annoying behavior in that for every transmit call it immediately stops the TX queue, then calls down into the next layer to transmit the PPP frame. But if that next layer can take it immediately, it just un-stops the TX queue right before returning from the transmit method. Besides being useless work, it makes several facilities unusable, in particular things like the equalizers. Well behaved devices should only stop the TX queue when they really are full, and in PPP's case when it gets backlogged to the downstream device. David Woodhouse therefore fixed PPP to not stop the TX queue until it's downstream can't take data any more. 14) IFF_UNICAST_FLT got accidently lost in some recent stmmac driver changes, re-add. From Marc Kleine-Budde. 15) Fix link flaps in ixgbe, from Eric W. Multanen. 16) Descriptor writeback fixes in e1000e from Matthew Vick. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (47 commits) net: fix a race in sock_queue_err_skb() netlink: fix races after skb queueing doc, net: Update ndo_start_xmit return type and values doc, net: Remove instruction to set net_device::trans_start doc, net: Update netdev operation names doc, net: Update documentation of synchronisation for TX multiqueue doc, net: Remove obsolete reference to dev->poll ethtool: Remove exception to the requirement of holding RTNL lock MAINTAINERS: update for Marvell Ethernet drivers bonding: properly unset current_arp_slave on slave link up phonet: Check input from user before allocating tcp: tcp_sendpages() should call tcp_push() once ipv6: fix array index in ip6_mc_add_src() mlx4: allocate just enough pages instead of always 4 pages stmmac: re-add IFF_UNICAST_FLT for dwmac1000 bnx2x: Clear MDC/MDIO warning message bnx2x: Fix BCM57711+BCM84823 link issue bnx2x: Clear BCM84833 LED after fan failure bnx2x: Fix BCM84833 PHY FW version presentation bnx2x: Fix link issue for BCM8727 boards. ...
2012-04-06xen/pcifront: avoid pci_frontend_enable_msix() falsely returning successJan Beulich
The original XenoLinux code has always had things this way, and for compatibility reasons (in particular with a subsequent pciback adjustment) upstream Linux should behave the same way (allowing for two distinct error indications to be returned by the backend). Signed-off-by: Jan Beulich <jbeulich@suse.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-04-06xen/pciback: fix XEN_PCI_OP_enable_msix resultJan Beulich
Prior to 2.6.19 and as of 2.6.31, pci_enable_msix() can return a positive value to indicate the number of vectors (less than the amount requested) that can be set up for a given device. Returning this as an operation value (secondary result) is fine, but (primary) operation results are expected to be negative (error) or zero (success) according to the protocol. With the frontend fixed to match the XenoLinux behavior, the backend can now validly return zero (success) here, passing the upper limit on the number of vectors in op->value. Signed-off-by: Jan Beulich <jbeulich@suse.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-04-06xen: only check xen_platform_pci_unplug if hvmIgor Mammedov
commit b9136d207f08 xen: initialize platform-pci even if xen_emul_unplug=never breaks blkfront/netfront by not loading them because of xen_platform_pci_unplug=0 and it is never set for PV guest. Signed-off-by: Andrew Jones <drjones@redhat.com> Signed-off-by: Igor Mammedov <imammedo@redhat.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-04-05Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull "ARM: SoC fixes: from Olof Johansson: "A bunch of fixes for regressions (and a few other problems) in 3.4-rc1: - Fix for regression of mach/io.h cleanup on platforms with PCI or PCMCIA (adding back the include file on those for now) - AT91 fixes for usb and spi - smsc911x ethernet fixes for i.MX - smsc911x fixes for OMAP - gpio fixes for Tegra - A handful of build error and warning fixes for various platforms - cpufreq kconfig dependencies, build and lowlevel debug fixes for Samsung platforms In other words, more or less the regular collection of -rc1/2 type material. A few of them, in particular the smsc911x for OMAP series, aren't technically regressions for 3.4, but they're valid fixes and we're still relatively early in the rc cycle so it seems appropriate to include them." * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (60 commits) ARM: fix __io macro for PCMCIA ARM: EXYNOS: Fix compiler warning in dma.c file ARM: EXYNOS: fix ISO C90 warning ARM: OMAP2+: hwmod: Fix wrong SYSC_TYPE1_XXX_MASK bit definitions ARM: OMAP2+: hwmod: Make omap_hwmod_softreset wait for reset status ARM: OMAP2+: hwmod: Restore sysc after a reset ARM: OMAP2+: omap_hwmod: Allow io_ring wakeup configuration for all modules ARM: OMAP3: clock data: fill in some missing clockdomains ARM: OMAP4: clock data: Force a DPLL clkdm/pwrdm ON before a relock ARM: OMAP4: clock data: fix mult and div mask for USB_DPLL ARM: OMAP2+: powerdomain: Wait for powerdomain transition in pwrdm_state_switch() gpio: tegra: Iterate over the correct number of banks gpio: tegra: fix register address calculations for Tegra30 EXYNOS: fix dependency for EXYNOS_CPUFREQ ARM: at91: dt: remove unit-address part for memory nodes ARM: at91: fix check of valid GPIO for SPI and USB USB: ehci-atmel: add needed of.h header file ARM: at91/NAND DT bindings: add comments ARM: at91/at91sam9x5.dtsi: fix NAND ale/cle in DT file USB: ohci-at91: trivial return code name change ...
2012-04-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/apm Pull an APM fix from Jiri Kosina: "One deadlock/race fix from Niel that got introduced when we were moving away from freezer_*_count() to wait_event_freezable()." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/apm: APM: fix deadlock in APM_IOC_SUSPEND ioctl
