path: root/drivers
2007-03-14pwc-uncompress.c shouldn't #include <asm/current.h>Hugh Dickins
Fix a compile error on powerpc. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-11Fix buffer overflow in Omnikey CardMan 4040 driver (CVE-2007-0005)Marcel Holtmann
Based on a patch from Don Howard <dhoward@redhat.com> When calling write() with a buffer larger than 512 bytes, the driver's write buffer overflows, allowing to overwrite the EIP and execute arbitrary code with kernel privileges. In read(), there exists a similar problem, but coming from the device. A malicous or buggy device sending more than 512 bytes can overflow of the driver's read buffer, with the same effects as above. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-11IB/mthca: Fix off-by-one in FMR handling on memfreeMichael S. Tsirkin
From: Michael S. Tsirkin <mst@mellanox.co.il> mthca_table_find() will return the wrong address when the table entry being searched for is exactly at the beginning of a sglist entry (other than the first), because it uses >= when it should use >. Example: assume we have 2 entries in scatterlist, 4K each, offset is 4K. The current code will return first entry + 4K when we really want the second entry. In particular this means mapping an FMR on a memfree HCA may end up writing the page table into the wrong place, leading to memory corruption and also causing the HCA to use an incorrect address translation table. Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-11IPoIB: Rejoin all multicast groups after a port eventEli Cohen
When ipoib_ib_dev_flush() is called because of a port event, the driver needs to rejoin all multicast groups, since the flush will call ipoib_mcast_dev_flush() (via ipoib_ib_dev_down()). Otherwise no (non-broadcast) multicast groups will be rejoined until the networking core calls ->set_multicast_list again, and so multicast reception will be broken for potentially a long time. Signed-off-by: Eli Cohen <eli@mellanox.co.il> Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-11IB/mthca: Use mmiowb after doorbell ringArthur Kepner
We discovered a problem when running IPoIB applications on multiple CPUs on an Altix system. Many messages such as: ib_mthca 0002:01:00.0: SQ 000014 full (19941644 head, 19941707 tail, 64 max, 0 nreq) appear in syslog, and the driver wedges up. Apparently this is because writes to the doorbells from different CPUs reach the device out of order. The following patch adds mmiowb() calls after doorbell rings to ensure the doorbell writes are ordered. Signed-off-by: Arthur Kepner <akepner@sgi.com> Signed-off-by: Roland Dreier <rolandd@cisco.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-09dvb-core: fix bug in CRC-32 checking on 64-bit systemsAng Way Chuang
CRC-32 checking during ULE decapsulation always failed on x86_64 systems due to the size of a variable used to store CRC. This bug was discovered on Fedora Core 6 with kernel-2.6.18-1.2849. The i386 counterpart has no such problem. This patch has been tested on 64-bit system as well as 32-bit system. Signed-off-by: Ang Way Chuang <wcang@nrg.cs.usm.my> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-08DVB: cxusb: fix firmware patch for big endian systemsJin-Bong lee
Without this patch, the device will not be detected after firmware download on big endian systems. Signed-off-by: Jin-Bong lee <jinbong.lee@samsung.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-08[SPARC64] bbc_i2c: Fix kenvctrld eating %100 cpu.David S. Miller
Based almost entirely upon a patch by Joerg Friedrich Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-08video/aty/mach64_ct.c: fix bogus delay loopDavid S. Miller
CT based mach64 cards were reported to hang on sparc64 boxes when compiled with gcc-4.1.x and later. Looking at this piece of code, it's no surprise. A critical delay was implemented as an empty for() loop, and gcc 4.0.x and previous did not optimize it away, so we did get a delay. But gcc-4.1.x and later can optimize it away, and we get crashes. Use a real udelay() to fix this. Fix verified on SunBlade100. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-08modify 3c589_cs to be SMP safeKomuro
1. EL3WINDOW is always 1 when lock is not held. 2. The second argument of el3_interrupt is 'void *dev_id', not 'struct el3_private *lp'. Adrian Bunk: backported to 2.6.16 Signed-off-by: Komuro <komurojun-mbn@nifty.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-08Input: psmouse - fix attribute access on 64-bit systemsSergey Vlasov
psmouse_show_int_attr() and psmouse_set_int_attr() were accessing unsigned int fields as unsigned long, which gave garbage on x86_64. Signed-off-by: Sergey Vlasov <vsu@altlinux.ru> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-27i2c-isa: Restore driver ownerJean Delvare
Commit 2b48716d1d2f2edb1e7cbc5ecf1cb2cb39373e33 back in January 2006 was a bit overzealous. It removed .owner from all i2c drivers, including i2c-isa ones, while they still need it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-26sis190: failure to set the MAC address from EEPROMFrancois Romieu
Fix from http://bugzilla.kernel.org/show_bug.cgi?id=7747 Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-26sky2: email and version change.Stephen Hemminger
Put in new email address. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-26sky2: add more pci idsStephen Hemminger
Update the pci device id table to match 2.6.20 (except for new 88e807x that is still experimental). Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-26sky2: more statsStephen Hemminger
This is a simple enhancement to dump more device statistics with ethtool. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-26sky2: fix for use on big endianStephen Hemminger
Ben added this for 2.6.18, it allows sky2 to run on big endian. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-26sky2: allow multicast pause framesStephen Hemminger
The 802 standard allows pause frames to be either unicast or multicast. Switches seem to send unicast frames, but on a direct link, other boards send multicast pause. Unless the filter bit is set, these pause frames get dropped. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-26sky2: fix ram buffer allocation settingsStephen Hemminger
Different chipsets have different amount of ram buffer (some have none), so need to make sure that driver does proper setup for all cases from 0 on to 48K, in units of 1K. This is a backport of the code from 2.6.19 or later Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-26hwmon: Add support for the Winbond W83687THFJean Delvare
Add support for the Winbond W83687THF chip to the w83627hf hardware monitoring driver. This new chip is almost similar to the already supported W83627THF chip, except for VID and a few other minor changes. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-26w83791d: Documentation updateCharles Spirakis
The alarm bits and the beep enable bits are in different positions in the hardware. Document the problem and leave it to the user-space code to handle the situation. When this driver is updated to the standardized sysfs alarm/beep methodology, this won't be a problem. This is a documentation only change. Signed-off by: Charles Spirakis <bezaur@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-26HWMON: w83791d: New hardware monitoring driver for the Winbond W83791DCharles Spirakis
Add support for the w83791d sensor chip. The w83791d hardware is somewhere between the w83781d and the w83792d and this driver code is derived from the code that supports those chips. Signed-off-by: Charles Spirakis <bezaur@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-26smsc47m192: New hwmon driver for SMSC LPC47M192/997Hartmut Rick
New driver (smsc47m192) which supports voltage and temperature measurement features of SMSC LPC47M192 and LPC47M997 chips. Signed-off-by: Hartmut Rick <linux@rick.claranet.de> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-26hwmon: New PC87427 hardware monitoring driverJean Delvare
This is a new hardware monitoring driver for the National Semiconductor PC87427 Super-I/O chip. It only supports fan speed monitoring for now, while the chip can do much more. Thanks to Amir Habibi at Candelis for setting up a test system, and to Michael Kress for testing several iterations of this driver. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-26hwmon lm83: Add LM82 supportJordan Crouse
Add LM82 temperature sensor support (similar to the LM83, but less featureful). Signed-off-by: Jordan Crouse <jordan.crouse@amd.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-26i2c-piix4: Add ATI IXP200/300/400 supportRudolf Marek
This patch adds the ATI IXP southbridges support to i2c-piix4, as it turned out those chips are compatible with it. Signed-off-by: Rudolf Marek <r.marek@sh.cvut.cz> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-26I2C: i2c-piix4: Add Broadcom HT-1000 supportMartin Devera
Add Broadcom HT-1000 south bridge's PCI ID to i2c-piix driver. Note that at least on Supermicro H8SSL it uses non-standard SMBHSTCFG = 3 and standard values like 0 or 9 causes hangup. Signed-off-by: Martin Devera <devik@cdi.cz> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-26V4L/DVB: Dvbdev: fix illegal re-usage of fileoperations structMarcel Siegert
Arjan van de Ven <arjan@infradead.org> reported an illegal re-usage of the fileoperations struct if more than one dvb device (e.g. frontend) is present. This patch fixes this issue. It allocates a new fileoperations struct each time a device is registered and copies the default template fileops. Signed-off-by: Marcel Siegert <mws@linuxtv.org> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-22USB: rtl8150 new device idPetko Manolov
This one adds another vendor ID to rtl8150 driver. Signed-off-by: Petko Manolov <petkan@nucleusys.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-22USB: add ZyXEL vendor/product ID to rtl8150 driverDan Streetman
I just got a "ZyXEL Prestige USB Adapter" that is actually RTL8150 adapter. Here is the relevant /proc/bus/usb/devices output (after adding the vendor/product IDs to the driver): T: Bus=01 Lev=02 Prnt=02 Port=02 Cnt=02 Dev#=119 Spd=12 MxCh= 0 D: Ver= 1.10 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1 P: Vendor=0586 ProdID=401a Rev= 1.00 S: Manufacturer=ZyXEL S: Product=Prestige USB Adapter S: SerialNumber=1027 C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=120mA I: If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=ff Driver=rtl8150 E: Ad=81(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms E: Ad=83(I) Atr=03(Int.) MxPS= 8 Ivl=1ms This patch adds the ZyXEL vendor ID to the rtl8150.c driver. The device has absolutely no identifying marks on the outside for model type, just a serial number, and I can't find anything on ZyXEL's website, so I called the product ID PRODUCT_ID_PRESTIGE to match the product string. Signed-off-by: Dan Streetman <ddstreet@ieee.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-22sky2: dual-port pci-x checksum fixStephen Hemminger
Add a workaround for dual port PCI-X card that returns status out of order sometimes because of split transactions. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-22sky2: fix for NAPI with dual port boardsStephen Hemminger
This driver uses port 0 to handle receives on both ports. So the netif_poll_disable call in dev_close would end up stopping the second port on dual port cards. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-21fix rtl8150Al Viro
That code doesn't do what its author apparently thought it would do... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-21[ATM] ambassador, firestream: "-1 >>" is implementation definedAlexey Dobriyan
6.5.7(5): The result of E1 >> E2 is E1 right-shifted E2 bit positions. ... If E1 has a signed type and a negative value, the resulting value is implementation defined. So, cast -1 to unsigned type to make result well-defined. [ Modified to use ~0U based upon recommendation from Al Viro. -DaveM ] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-21[ATM] firestream: handle thrown errorJeff Garzik
gcc emits the following warning: drivers/atm/firestream.c: In function ‘fs_open’: drivers/atm/firestream.c:870: warning: ‘tmc0’ may be used uninitialized in this function This indicates a real bug. We should check make_rate() return value for potential errors. Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-21[ATM] horizon: read_bia() needs to be __devinitDavid S. Miller
Thanks to Randy Dunlap. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-21ATM horizon.c: missing __devinitAl Viro
2007-02-20V4L/DVB: Buf_qbuf: fix: videobuf_queue->stream corruption and lockupOleg Nesterov
We are doing ->buf_prepare(buf) before adding buf to q->stream list. This means that videobuf_qbuf() should not try to re-add a STATE_PREPARED buffer. Adrian Bunk: Backported to 2.6.16. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-03[libata] use kmap_atomic(KM_IRQ0) in SCSI simulatorJeff Garzik
We are inside spin_lock_irqsave(). quoth akpm's debug facility: [ 231.948000] SCSI device sda: 195371568 512-byte hdwr sectors (100030 MB) [ 232.232000] ata1.00: configured for UDMA/33 [ 232.404000] WARNING (1) at arch/i386/mm/highmem.c:47 kmap_atomic() [ 232.404000] [<c01162e6>] kmap_atomic+0xa9/0x1ab [ 232.404000] [<c0242c81>] ata_scsi_rbuf_get+0x1c/0x30 [ 232.404000] [<c0242caf>] ata_scsi_rbuf_fill+0x1a/0x87 [ 232.404000] [<c0243ab2>] ata_scsiop_mode_sense+0x0/0x309 [ 232.404000] [<c01729d5>] end_bio_bh_io_sync+0x0/0x37 [ 232.404000] [<c02311c6>] scsi_done+0x0/0x16 [ 232.404000] [<c02311c6>] scsi_done+0x0/0x16 [ 232.404000] [<c0242dcc>] ata_scsi_simulate+0xb0/0x13f [...] Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-03hwmon: Update Rudolf Marek's e-mail addressRudolf Marek
The Silicon Hill club is not what it used to be. Signed-off-by: Rudolf Marek <r.marek@assembler.cz> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-03k8temp: Documentation updateRudolf Marek
Update the documentation for the k8temp driver. Signed-off-by: Rudolf Marek <r.marek@assembler.cz> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-03Make 'repair' actually work for raid1.Neil Brown
When 'repair' finds a block that is different one the various parts of the mirror. it is meant to write a chosen good version to the others. However it currently writes out the original data to each. The memcpy to make all the data the same is missing. Also correct a test so that 'repair' causes a repair, rather than anything other then 'repair'. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-30hwmon: New driver k8tempRudolf Marek
Add support for the temperature sensor(s) found in AMD K8 CPUs. Signed-off-by: Rudolf Marek <r.marek@sh.cvut.cz> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-30[SCSI] arcmsr: fix up sysfs valuesJames Bottomley
The sysfs files in arcmsr are non-standard in that they aren't simple filename value pairs, the values actually contain preceeding text which would have to be parsed. The idea of sysfs files is that the file name is the description and the contents is a simple value. Fix up arcmsr to conform to this standard. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-30[SCSI] areca sysfs fixAndrew Morton
Remove sysfs_remove_bin_file() return-value checking from the areca driver. There's nothing a driver can do if sysfs file removal fails, so we'll soon be changing sysfs_remove_bin_file() to internally print a diagnostic and to return void. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-30[SCSI] arcmsr: initial driver, version 1.20.00.13Erich Chen
arcmsr is a driver for the Areca Raid controller, a host based RAID subsystem that speaks SCSI at the firmware level. This patch is quite a clean up over the initial submission with contributions from: Randy Dunlap <rdunlap@xenotime.net> Christoph Hellwig <hch@lst.de> Matthew Wilcox <matthew@wil.cx> Adrian Bunk <bunk@stusta.de> Signed-off-by: Erich Chen <erich@areca.com.tw> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-25V4L/DVB: Missing statement in drivers/media/dvb/frontends/cx22700.cEric Sesterhenn
Stumbled over this because of coverity (id #492), seems like we are missing a return statement here and fail to do proper bounds checking. If this assumption is false we should at least change the identation to make it clear Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-24V4L/DVB: Flexcop-usb: fix debug printkAlexey Dobriyan
.. fix debug printk. Why, oh why, one would want to do (u16 & 0xff) << 8 and print it with %02x format? Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-24V4L/DVB: Fix uninitialised variable in dvb_frontend_swzigzagAndrew de Quincey
Spotted by coverity/Adrian Bunk. Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-01-23read_zero_pagealigned() locking fixHugh Dickins
Ramiro Voicu hits the BUG_ON(!pte_none(*pte)) in zeromap_pte_range: kernel bugzilla 7645. Right: read_zero_pagealigned uses down_read of mmap_sem, but another thread's racing read of /dev/zero, or a normal fault, can easily set that pte again, in between zap_page_range and zeromap_page_range getting there. It's been wrong ever since 2.4.3. The simple fix is to use down_write instead, but that would serialize reads of /dev/zero more than at present: perhaps some app would be badly affected. So instead let zeromap_page_range return the error instead of BUG_ON, and read_zero_pagealigned break to the slower clear_user loop in that case - there's no need to optimize for it. Use -EEXIST for when a pte is found: BUG_ON in mmap_zero (the other user of zeromap_page_range), though it really isn't interesting there. And since mmap_zero wants -EAGAIN for out-of-memory, the zeromaps better return that than -ENOMEM. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
