That update broke build of pata_atiixp as it requires some PCI IDs
and other updates which have not been merged. Better remove it
from 2.6.20.
This reverts commit f327bcd16db3128a6c1885e03109361e167d1a56.
Signed-off-by: Willy Tarreau <w@1wt.eu>
Due to rounding and inexact jiffy accounting, idle_ticks can sometimes
be higher than total_ticks. Make sure those cases are handled as
zero load case.
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Signed-off-by: Dave Jones <davej@redhat.com>
With tickless kernel and software coordination os P-states, ondemand
can look at wrong idle statistics. This can happen when ondemand sampling
is happening on CPU 0 and due to software coordination sampling also looks at
utilization of CPU 1. If CPU 1 is in tickless state at that moment, its idle
statistics will not be uptodate and CPU 0 thinks CPU 1 is idle for less
amount of time than it actually is.
This can be resolved by looking at all the busy times of CPUs, which is
accurate, even with tickless, and use that to determine idle time in a
round about way (total time - busy time).
Thanks to Arjan for originally reporting the ondemand bug on
Lenovo T61.
[libata] pata_atiixp: add SB700 PCI ID
From AMD.
Signed-off-by: Jeff Garzik <jeff@garzik.org>
Cc: Chuck Ebbert <cebbert@redhat.com>
Visualize-EG, Graffiti and A4450A graphics cards on PARISC can
be configured in double-buffer and standard mode, but the stifb
driver supports standard mode only.
This patch detects double-buffered cards more reliable.
It is a real bugfix for a very nasty problem for all parisc users which have
wrongly configured their graphic card. The problem: The stifb graphics driver
will not detect that the card is wrongly configured and then nevertheless just
enables the graphics mode, which it shouldn't. In the end, the user will see
no further updates / boot messages on the screen.
We had documented this problem already on our FAQ
(http://parisc-linux.org/faq/index.html#viseg "Why do I get corrupted graphics
with my Vis-EG/Graffiti/A4450A card?") but people still run into this problem.
So having this fix in as early as possible can help us.
Signed-off-by: Helge Deller <deller@gmx.de>
Signed-off-by: Antonino Daplas <adaplas@gmail.com>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Fix map entry 10b for ich8. It's [P0 P2 IDE IDE] like ich6 / ich6m.
Signed-off-by: Tejun Heo <htejun@gmail.com>
Acked-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com>
Cc: Jeff Garzik <jeff@garzik.org>
If root raised the default wakeup threshold over the size of the
output pool, the pool transfer function could overflow the stack with
RNG bytes, causing a DoS or potential privilege escalation.
(Bug reported by the PaX Team <pageexec@freemail.hu>)
Cc: Theodore Tso <tytso@mit.edu>
Cc: Willy Tarreau <w@1wt.eu>
Signed-off-by: Matt Mackall <mpm@selenic.com>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
sx.c is failing to locate Graham's card.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Cc: Graham Murray <gmurray@webwayone.co.uk>
This patch causes device-mapper to reject any barrier requests. This is done
since most of the targets won't handle this correctly anyway. So until the
situation improves it is better to reject these requests at the first place.
Since barrier requests won't get to the targets, the checks there can be
removed.
Signed-off-by: Stefan Bader <shbader@de.ibm.com>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
Allow invalid snapshots to be activated instead of failing.
This allows userspace to reinstate any given snapshot state - for
example after an unscheduled reboot - and clean up the invalid snapshot
at its leisure.
Signed-off-by: Milan Broz <mbroz@redhat.com>
If it's EXPORT_SYMBOL'ed it can't be __devinit.
Reported by Mikael Pettersson.
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Cc: Michal Piotrowski <michal.k.k.piotrowski@gmail.com>
This patch contains errata fixes for the vitesse phy. It only renamed the
defines to be phy specific.
Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com>
This patch contains errata fixes for the cicada phy. It only renamed the
Flush workqueue before releasing bioset and mopools in dm-crypt. There can
be finished but not yet released request.
Call chain causing oops:
run workqueue
dec_pending
bio_endio(...);
<remove device request - remove mempool>
mempool_free(io, cc->io_pool);
This usually happens when cryptsetup create temporary
luks mapping in the beggining of crypt device activation.
When dm-core calls destructor crypt_dtr, no new request
are possible.
Cc: Patrick McHardy <kaber@trash.net>
Acked-by: Alasdair G Kergon <agk@redhat.com>
Cc: Christophe Saout <christophe@saout.de>
Give sockets up to 100ms of additional time to power down. otherwise we
might generate false warnings with KERN_ERR priority (like in bug #8262).
Signed-off-by: Daniel Ritz <daniel.ritz@gmx.ch>
Cc: Nils Neumann <nils.neumann@rwth-aachen.de>
In case of read errors raid10d tries to print a nice error message,
unfortunately using data from an already put bio.
Signed-off-by: Maik Hampel <m.hampel@gmx.de>
Acked-By: NeilBrown <neilb@suse.de>
When writing to a broken array, raid10 currently happily emits empty bio
lists. IOW, the master bio will never be completed, sending writers to
UNINTERRUPTIBLE_SLEEP forever.
Signed-off-by: Arne Redlich <agr@powerkom-dd.de>
Acked-by: Neil Brown <neilb@suse.de>
Is there a reason why the "online" file in the subdirectories for the CPUs
in /sys/devices/system isn't world-readable? I cannot imagine it to be
security relevant especially now that a getcpu() syscall can be used to
determine what CPUa thread runs on.
The file is useful to correctly implement the sysconf() function to return
the number of online CPUs. In the presence of hotplug we currently cannot
provide this information. The patch below should to it.
Signed-off-by: Ulrich Drepper <drepper@redhat.com>
This 965G and above chipsets moved the batch buffer non-secure bits to
another place. This means that previous drm's allowed in-secure batchbuffers
to be submitted to the hardware from non-privileged users who are logged
into X and and have access to direct rendering.
State struct was never freed.
(cherry picked from commit 1b2232ab879993fcf5b9391c3febf6ab5d78201e)
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
If v4l2_ctrl_next is called without the V4L2_CTRL_FLAG_NEXT_CTRL then it
should check whether the passed control ID is valid and return 0 if it
isn't. Otherwise a for-loop over the control IDs will never end.
(cherry picked from commit a46c5fbc6912c4e34cb7ded314249b639dc244a6)
On the SCSI layer ioctl path there is no implicit permissions check for
ioctls (and indeed other drivers implement unprivileged ioctls). aacraid
however allows all sorts of very admin only things to be done so should
check.
Signed-off-by: Alan Cox <alan@redhat.com>
Acked-by: Mark Salyzyn <mark_salyzyn@adaptec.com>
This patch (as937) fixes a minor bug in the autosuspend usage-counting
code. Each hub's usage counter keeps track of the number of
unsuspended children. However the current driver increments the
counter after registering a new child, by which time the child may
already have been suspended and caused the counter to go negative.
The obvious solution is to increment the counter before registering
the child.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
This patch adds an implementation to the svm is_disabled function to
detect reliably if the BIOS disabled the SVM feature in the CPU. This
fixes the issues with kernel panics when loading the kvm-amd module on
machines where SVM is available but disabled.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
Signed-off-by: Avi Kivity <avi@qumranet.com>
This patch restores a couple of workarounds from 2.6.16:
* restart transmit moderation timer in case it expires during IRQ routine
* default to having 10 HZ watchdog timer.
At this point it more important not to hang than to worry about the
power cost.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
The interrupt clearing code in mpsc_sdma_intr_ack() mistakenly clears the
interrupt for both controllers instead of just the one its supposed to.
This can result in the other controller appearing to hang because its
interrupt was effectively lost.
So, don't clear the interrupt cause bits for both MPSC controllers when
clearing the interrupt for one of them. Just clear the one that is
supposed to be cleared.
Signed-off-by: Jay Lubomirski <jaylubo@motorola.com>
Acked-by: Mark A. Greer <mgreer@mvista.com>
This patch changes the test for the thread pid from >= 0 to > 0.
When the saa7134 driver initialization fails after a certain point, it goes
through the complete shutdown process for the driver. Part of shutting it
down includes tearing down the thread for tv audio.
The test for tearing down the thread tests for >= 0. Since the dev
structure is kzalloc'd, the test will always be true if we haven't tried to
start the thread yet. We end up waiting on pid 0 to complete, which will
never happen, so we lock up.
This bug was observed in Novell Bugzilla 284718, when request_irq() failed.
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Get rid of first_clone in dm-crypt
This gets rid of first_clone, which is not really needed. Apparently, cloned
bios used to share their bvec some time way in the past - this is no longer
the case. Contrarily, this even hurts us if we try to create a clone off
first_clone after it has completed, and crypt_endio has destroyed its bvec.
Signed-off-by: Olaf Kirch <olaf.kirch@oracle.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
Do not access the bio after generic_make_request
We should never access a bio after generic_make_request - there's no guarantee
it still exists.
Call clone_init early
We need to call clone_init as early as possible - at least before call
bio_put(clone) in any error path. Otherwise, the destructor will try to
dereference bi_private, which may still be NULL.
Disable barriers in dm-crypt because of current workqueue processing can
reorder requests.
This must be addresed later but for now disabling barriers is needed to
prevent data corruption.
If raid1/repair (which reads all block and fixes any differences
it finds) hits a read error, it doesn't reset the bio for writing
before writing correct data back, so the read error isn't fixed,
and the device probably gets a zero-length write which it might
complain about.
Signed-off-by: Neil Brown <neilb@suse.de>
1/ When resyncing a degraded raid10 which has more than 2 copies of each block,
garbage can get synced on top of good data.
2/ We round the wrong way in part of the device size calculation, which
can cause confusion.
To assure the symmetry of poll enable/disable in up/down, we should
initialize the netdevice to be poll_disabled at load time. Doing
this after register_netdevice leaves us open to another race, so
lets move all the netif_* calls above register_netdevice so the
stack starts out how we expect it to be.
Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Doug Chapman <doug.chapman@hp.com>
An omitted unlock.
It is possible that real data or metadata follows the bitmap
without full page alignment.
So limit the last write to be only the required number of bytes,
rounded up to the hard sector size of the device.
If a raid0 has a component device larger than 4TB, and is accessed on
a 32bit machines, then as 'chunk' is unsigned lock,
chunk << chunksize_bits
can overflow (this can be as high as the size of the device in KB).
chunk itself will not overflow (without triggering a BUG).
So change 'chunk' to be 'sector_t, and get rid of the 'BUG' as it becomes
impossible to hit.
Cc: "Jeff Zheng" <Jeff.Zheng@endace.com>
The i8042 driver fails detection of the AUX port with some chips,
because they apparently do not change the I8042_CTR_AUXDIS bit
immediately. This is known to affect at least HP500/HP510 notebooks,
consequently the built-in touchpad will not work. The patch will simply
reread the value until it gets the expected value or a retry limit is
hit, without touching other workaround code in the same area.
Signed-off-by: Roland Scheidegger <sroland@tungstengraphics.com>
The Linux kernel ignored the PROM's serial settings (115200,n,8,1 in
my case). This was because mode_prop remained "ttyX-mode" (expected:
"ttya-mode") due to the constness of string literals when used with
"char *". Since there is no "ttyX-mode" property in the PROM, Linux
always used the default 9600.
[ Investigation of the suncore.s assembler reveals that gcc optimizied
away the stores, yet did not emit a warning, which is a pretty
anti-social thing to do and is the only reason this bug lived for
so long -DaveM ]
Signed-off-by: Jan Engelhardt <jengelh@gmx.de>
Revert changeset
http://linuxtv.org/hg/v4l-dvb?cmd=changeset;node=e7c424bbf9aa;style=gitweb
Petri Helin found that this changeset broke tuning:
'Well, after going through the changes that might have had effect on
tuning, I found out the one which had caused this problem. I do not know
the actual reason behind the change, but the changelog says that it
was meant to "Fix TD1316 tuner for DVBC". But at least in my case it
seams to have broken the tuner instead.'
Signed-off-by: Oliver Endriss <o.endriss@gmx.de>
Thanks-to: Petri Helin <phelin@googlemail.com>
Acked-by: e9hack <e9hack@googlemail.com>
Acked-by: Thomas Kaiser <linux-dvb@kaiser-linux.li>
Acked-by: Michael Krufky <mkrufky@linuxtv.org>
Use relative time, not absolute. Discovered by Jung-Ik (John) Lee
<jilee@google.com>.
Cc: Jung-Ik (John) Lee <jilee@google.com>
Acked-by: Len Brown <lenb@kernel.org>
Currently, devt_attr for the "dev" file is freed immediately on device
removal, but if the "dev" sysfs file is open when a device is removed,
sysfs will access its attribute structure for further access including
close resulting in jumping to garbled address. Fix it by postponing
freeing devt_attr to device release time.
Note that devt_attr for class_device is already freed on release.
This bug is reported by Chris Rankin as bugzilla bug#8198.
Cc: Chris Rankin <rankincj@yahoo.com>
For some reason, sata_via is missing PM hooks. Add them. Spotted by
Jeroen Janssen <jeroen.janssen@gmail.com>.
Cc: Jeroen Janssen <jeroen.janssen@gmail.com>
the patch below fixes compilation breakage of smc911x driver when ENABLE_SMC_DEBUG_PKTS equals to 1.
Signed-off-by: Vitaly Wool <vitalywool@gmail.com>
Add data from zero-entropy random_writes directly to output pools to
avoid accounting difficulties on machines without entropy sources.
Tested on lguest with all entropy sources disabled.
Acked-by: "Theodore Ts'o" <tytso@mit.edu>
Fix cast error in entropy extraction.
Add comments explaining the magic 16.
Remove extra confusing loop variable.
Allow in-place crypto operations. Also remove the coherent user flag
(we use it automagically now), and by default use the user written
key rather then the HW hidden key - this makes crypto just work without
any special considerations, and thats OK, since its our only usage
model.
Signed-off-by: Jordan Crouse <jordan.crouse@amd.com>
Revert "adjust legacy IDE resource setting (v2)"
This reverts commit ed8ccee0918ad063a4741c0656fda783e02df627.
It causes hang on boot for some users and we don't yet know why:
http://bugzilla.kernel.org/show_bug.cgi?id=7562
http://lkml.org/lkml/2007/4/20/404
http://lkml.org/lkml/2007/3/25/113
Just reverse it for 2.6.21-final, having broken X server is somehow
better than unbootable system.
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
[AGPGART] intel_agp: fix G965 GTT size detect
On G965, I810_PGETBL_CTL is a mmio offset, but we wrongly take it
as pci config space offset in detecting GTT size. This one line patch
fixs this.
Signed-off-by: Wang Zhenyu <zhenyu.z.wang@intel.com>
Users have been complaining about the w83627ehf driver flooding their
logs with debug messages like:
w83627ehf 9191-0a10: Increasing fan 4 clock divider from 64 to 128
or:
w83627ehf 9191-0290: Increasing fan 4 clock divider from 4 to 8
The reason is that we failed to actually write the LSB of the encoded
clock divider value for that fan, causing the next read to report the
same old value again and again.
Additionally, the fan number was improperly reported, making the bug
harder to find.
