commit ed4ec814e45ae8b1596aea0a29b92f6c3614acaa upstream
data->max_duty_at_overheat is not updated in adt7473_update_device,
so it might be used before it is initialized (if the user reads from
sysfs file max_duty_at_crit before writing to it.)
Acked-by: Darrick J. Wong <djwong@us.ibm.com>
Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
Function RANGE_TO_REG() is broken. For a requested range of 2000 (2
degrees C), it will return an index value of 15, i.e. 80.0 degrees C,
instead of the expected index value of 0. All other values are handled
properly, just 2000 isn't.
The bug was introduced back in November 2004 by this patch:
http://git.kernel.org/?p=linux/kernel/git/tglx/history.git;a=commit;h=1c28d80f1992240373099d863e4996cdd5d646d0
In Linus' kernel I decided to rewrite the whole function in a way
which was more obviously correct. But for -stable let's just do the
minimal fix.
commit 1f6ef2342972dc7fd623f360f84006e2304eb935 upstream
The inline assembly in drivers/watchdog/hpwdt.c was incredibly broken,
and included all the function prologue and epilogue stuff, even though
it was itself then inside a C function where the compiler would add its
own prologue and epilogue on top of it all.
This then just _happened_ to work if you had exactly the right compiler
version and exactly the right compiler flags, so that gcc just happened
to not create any prologue at all (the gcc-generated epilogue wouldn't
matter, since it would never be reached).
But the more proper way to fix it is to simply not do this. Move the
inline asm to the top level, with no surrounding function at all (the
better alternative would be to remove the prologue and make it actually
use proper description of the arguments to the inline asm, but that's a
bigger change than the one I'm willing to make right now).
Tested-by: S.Çağlar Onur <caglar@pardus.org.tr>
Acked-by: Thomas Mingarelli <Thomas.Mingarelli@hp.com>
upstream commit: 58c7821c4264a7ddd6f0c31c5caaf393b3897f10
The atl1 driver tries to determine the MAC address thusly:
- If an EEPROM exists, read the MAC address from EEPROM and
validate it.
- If an EEPROM doesn't exist, try to read a MAC address from
SPI flash.
- If that fails, try to read a MAC address directly from the
MAC Station Address register.
- If that fails, assign a random MAC address provided by the
kernel.
We now have a report of a system fitted with an EEPROM containing all
zeros where we expect the MAC address to be, and we currently handle
this as an error condition. Turns out, on this system the BIOS writes
a valid MAC address to the NIC's MAC Station Address register, but we
never try to read it because we return an error when we find the all-
zeros address in EEPROM.
This patch relaxes the error check and continues looking for a MAC
address even if it finds an illegal one in EEPROM.
http://ubuntuforums.org/showthread.php?t=562617
[jacliburn@bellsouth.net: backport to 2.6.25.7]
Signed-off-by: Radu Cristescu <advantis@gmx.net>
Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net>
commit: d1daeabf0da5bfa1943272ce508e2ba785730bf0 upstream
Reported-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
If you delay 30s or more before mounting a CD after inserting it then
the kernel has the wrong value for the CD size.
http://marc.info/?t=121276133000001
The problem is in sr_test_unit_ready(): the function eats unit
attentions without adjusting the sdev->changed status. This means
that when the CD signals changed media via unit attention, we can
ignore it. Fix by making sr_test_unit_ready() adjust the changed
status.
Tested-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
upstream bc45b1d39a925b56796bebf8a397a0491489d85c
Without this patch booting with acpi_osi="!Windows 2006" is required
for several machines to function properly with cpufreq
due to failure to load a Vista specific table with a bad signature.
Only "SSDT" is acceptable to the ACPI spec, but tables are
seen with OEMx and null sigs. Therefore, signature validation
is worthless. Apparently MS ACPI accepts such signatures, ACPICA
must be compatible.
http://bugzilla.kernel.org/show_bug.cgi?id=9919
http://bugzilla.kernel.org/show_bug.cgi?id=10383
http://bugzilla.kernel.org/show_bug.cgi?id=10454
https://bugzilla.novell.com/show_bug.cgi?id=396311
Signed-off-by: Bob Moore <robert.moore@intel.com>
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
The patch is upstream as commit 3ed7897242b7efe977f3a8d06d4e5a4ebe28b10e
A different backport is necessary because of the class_device to device
conversion post 2.6.25.
commit 9c7701088a61cc0cf8a6e1c68d1e74e3cc2ee0b7
Author: Dave Young <hidave.darkstar@gmail.com>
Date: Tue Jan 22 14:01:34 2008 +0800
scsi: use class iteration api
Isn't a correct replacement for the original hand rolled host
lookup. The problem is that class_find_child would get a reference to
the host's class device which is never released. Since the host class
device holds a reference to the host gendev, the host can never be
freed.
In 2.6.25 we started using class_find_device, and this function also
gets a reference to the device, so we end up with an extra ref
and the host will not get released.
This patch adds a class_put_device to balance the class_find_device()
get. I kept the scsi_host_get in scsi_host_lookup, because the target
layer is using scsi_host_lookup and it looks like it needs the SHOST_DEL
check.
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
a cut-down version of commit 028118a5f09a9c807e6b43e2231efdff9f224c74 upstream
This fixes a possible NULL pointer dereference in an error path of the
DMA allocation error checking code. In case the DMA allocation address is invalid,
the dev pointer is dereferenced for unmapping of the buffer.
Reported-by: Miles Lane <miles.lane@gmail.com>
Signed-off-by: Michael Buesch <mb@bu3sch.de>
commit 98a3b2fe435ae76170936c14f5c9e6a87548e3ef upstream.
This removes a WARN_ON that is responsible for the following koops:
http://www.kerneloops.org/searchweek.php?search=b43_generate_noise_sample
The comment in the patch describes why it's safe to simply remove
the check.
commit 23cde76d801246a702e7a84c3fe3d655b35c89a1 upstream.
hdr->csum_start is the offset from the start of the ethernet
header to the transport layer checksum field. skb->csum_start
is the offset from skb->head.
skb_partial_csum_set() assumes that skb->data points to the
ethernet header - i.e. it computes skb->csum_start by adding
the headroom to hdr->csum_start.
Since eth_type_trans() skb_pull()s the ethernet header,
skb_partial_csum_set() should be called before
eth_type_trans().
(Without this patch, GSO packets from a guest to the world outside the
host are corrupted).
Signed-off-by: Mark McLoughlin <markmc@redhat.com>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
commit f361037631ba547ea88adf8d2359d810c1b2605a upstream
These controllers don't support DMA.
Based on a bugreport from Juergen Kosel & inspired by pata_opti.c code.
Tested-by: Juergen Kosel <juergen.kosel@gmx.de>
Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com>
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
commit 62128b2ca812c1266f4ff7bac068bf0b626c6179 upstream
This fixes 2.6.25 regression (kernel.org bugzilla bug #10723) caused by:
commit 912fb29a36a7269ac1c4a4df45bc0ac1d2637972
Author: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Date: Fri Oct 19 00:30:11 2007 +0200
opti621: always tune PIO
Bisected-by: Juergen Kosel <juergen.kosel@gmx.de>
commit e991a2bd4fa0b2f475b67dfe8f33e8ecbdcbb40b upstream.
We try and write the correct speed back but the serial midlayer already
mangles the speed on us and that means if we request B0 we report back B9600
when we should not. For now we'll hack around this in the drivers and serial
code, pending a better long term solution.
Signed-off-by: Alan Cox <alan@redhat.com>
commit 81b2dbcad86732ffc02bad87aa25c4651199fc77 in mainline.
vidiocgmbuf() does this:
mutex_lock(&fh->cap.vb_lock);
retval = videobuf_mmap_setup(&fh->cap, gbuffers, gbufsize,
V4L2_MEMORY_MMAP);
and videobuf_mmap_setup() then just does
mutex_lock(&q->vb_lock);
ret = __videobuf_mmap_setup(q, bcount, bsize, memory);
mutex_unlock(&q->vb_lock);
which is an obvious double-take deadlock.
This patch fixes this by having vidiocgmbuf() just call the
__videobuf_mmap_setup function instead.
Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Reported-by: Koos Vriezen <koos.vriezen@gmail.com>
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
commit 03a74dcc7eebe6edd778317e82fafdf71e68488c in mainline.
enable_irq_wake() and disable_irq_wake() need to be balanced. However,
serial_core.c calls these for different conditions during the suspend and
resume functions...
This is causing a regular WARN_ON() as found at
http://www.kerneloops.org/search.php?search=set_irq_wake
This patch makes the conditions for triggering the _wake enable/disable
sequence identical.
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
commit 326f6a5c9c9e1a62aec37bdc0c3f8d53adabe77b upstream
Format string bug. Not exploitable, as this is only writable by root,
but worth fixing all the same.
Spotted-by: Ilja van Sprundel <ilja@netric.org>
Signed-off-by: Dave Jones <davej@redhat.com>
commit 8079ffa0e18baaf2940e52e0c118eef420a473a4 upstream
On a 64-bit architecture, if ib_umem_get() is called with a size value
that is so big that npages is negative when cast to int, then the
length of the page list passed to get_user_pages(), namely
min_t(int, npages, PAGE_SIZE / sizeof (struct page *))
will be negative, and get_user_pages() will immediately return 0 (at
least since 900cf086, "Be more robust about bad arguments in
get_user_pages()"). This leads to an infinite loop in ib_umem_get(),
since the code boils down to:
while (npages) {
ret = get_user_pages(...);
npages -= ret;
Fix this by taking the minimum as unsigned longs, so that the value of
npages is never truncated.
The impact of this bug isn't too severe, since the value of npages is
checked against RLIMIT_MEMLOCK, so a process would need to have an
astronomical limit or have CAP_IPC_LOCK to be able to trigger this,
and such a process could already cause lots of mischief. But it does
let buggy userspace code cause a kernel lock-up; for example I hit
this with code that passes a negative value into a memory registartion
function where it is promoted to a huge u64 value.
Signed-off-by: Roland Dreier <rolandd@cisco.com>
commit 4db0ee176e256444695ee2d7b004552e82fec987 upstream
Add a workaround for lost MSI interrupts. There is a race condition in
the HW in which future interrupts could be missed. The workaround is to
toggle the MSI irq mask.
Added cleanup based on comments from Andrew Morton.
Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com>
Cc: Manfred Spraul <manfred@colorfullife.com>
Cc: Jeff Garzik <jeff@garzik.org>
commit 630c270183133ac25bef8c8d726ac448df9b169a upstream
Date: Thu, 12 Jun 2008 15:21:29 -0700
Subject: hgafb: resource management fix
Release ports which are requested during detection which are not freed if
there is no hga card. Otherwise there is a crash during cat /proc/ioports
command.
Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl>
commit 24aac480e76c6f5d1391ac05c5e9c0eb9b0cd302 upstream
Date: Thu, 12 Jun 2008 15:21:34 -0700
Subject: cciss: add new hardware support
Add support for the next generation of HP Smart Array SAS/SATA
controllers. Shipping date is late Fall 2008.
Bump the driver version to 3.6.20 to reflect the new hardware support from
patch 1 of this set.
Signed-off-by: Mike Miller <mike.miller@hp.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
commit cef33400d0349fb24b6f8b7dea79b66e3144fd8b upstream
With CONFIG_DEBUG_SHIRQ set we will get an interrupt as soon as we
allocate one. Tasklets may be scheduled in the interrupt handler but they
will be initialized after the handler returns, causing a BUG() in
kernel/softirq.c when they run.
Should fix this Fedora bug report:
https://bugzilla.redhat.com/show_bug.cgi?id=449817
Signed-off-by: Chuck Ebbert <cebbert@redhat.com>
Acked-by: Pierre Ossman <drzeus@drzeus.cx>
[ upstream commit: 24b95685ffcdb3dc28f64b9e8af6ea3e8360fbc5 ]
Some problems have been experienced in the field which cause an oops
in the pppol2tp driver if L2TP tunnels fail while passing data.
The pppol2tp driver uses private data that is referenced via the
sk->sk_user_data of its UDP and PPPoL2TP sockets. This patch makes
sure that the driver uses sock_hold() when it holds a reference to the
sk pointer. This affects its sendmsg(), recvmsg(), getname(),
[gs]etsockopt() and ioctl() handlers.
Tested by ISP where problem was seen. System has been up 10 days with
no oops since running this patch. Without the patch, an oops would
occur every 1-2 days.
Signed-off-by: James Chapman <jchapman@katalix.com>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
[ upstream commit: 199f7d24ae59894243687a234a909f44a8724506 ]
If an L2TP daemon closes a tunnel socket while packets are queued in
the tunnel's reorder queue, a kernel warning is logged because the
socket is closed while skbs are still referencing it. The fix is to
purge the queue in the socket's release handler.
WARNING: at include/net/sock.h:351 udp_lib_unhash+0x41/0x68()
Pid: 12998, comm: openl2tpd Not tainted 2.6.25 #8
[<c0423c58>] warn_on_slowpath+0x41/0x51
[<c05d33a7>] udp_lib_unhash+0x41/0x68
[<c059424d>] sk_common_release+0x23/0x90
[<c05d16be>] udp_lib_close+0x8/0xa
[<c05d8684>] inet_release+0x42/0x48
[<c0592599>] sock_release+0x14/0x60
[<c059299f>] sock_close+0x29/0x30
[<c046ef52>] __fput+0xad/0x15b
[<c046f1d9>] fput+0x17/0x19
[<c046c8c4>] filp_close+0x50/0x5a
[<c046da06>] sys_close+0x69/0x9f
[<c04048ce>] syscall_call+0x7/0xb
[ upstream commit: 090c48d3dd5ea90b37350334aaed9a93b0c1e0a1 ]
A user reported seeing occasional bugs such as the following when
using the L2TP driver.
SKB BUG: Invalid truesize (272) len=72, sizeof(sk_buff)=208
When L2TP adds its header in the transmit path, it might need to
increase the headroom of the skb. In some cases, the increased
headroom trips a kernel bug when the skb is freed because the skb has
grown beyond its truesize value. The fix is to increase the truesize
by the amount of headroom added, after orphaning the skb.
While here, fix a misleading comment.
Thanks to Iouri Kharon <bc-info@styx.cabel.net> for the initial
report and testing the fix.
[ upstream commit: b1443e2f6501f06930a162ff1ff08382a98bf23e ]
According to David Monro, at least with Natsemi Saturn chips the
cassini driver has some trouble with ipv6 checksums.
Until we have more information about what's going on here, only
use the chip checksums for ipv4.
This workaround was suggested and tested by David.
Update version and release date.
[ upstream commit: 3651751fff44ede58f65cbb1e39242139ead251b ]
This causes the lock to be taken twice, thus resulting in
a deadlock.
upstream commit: 659179b28f15ab1b1db5f8767090f5e728f115a1
Frame buffer and mode setting drivers can be built as modules,
so fb_mode_option needs to be exported to support these.
Prevents this error:
ERROR: "fb_mode_option" [drivers/ps3/ps3av_mod.ko] undefined!
Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com>
Acked-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
Cc: Krzysztof Helt <krzysztof.h1@poczta.fm>
upstream commit: a3bafeedfff2ac5fa0a316bea4570e27900b6fcc
This fixes a context assertion in ssb that makes b44 print
out warnings on resume.
This fixes the following kernel oops:
http://www.kerneloops.org/oops.php?number=12732
http://www.kerneloops.org/oops.php?number=11410
upstream commit: efedf51c866130945b5db755cb58670e60205d83
Alias brd to rd in the hope of helping legacy users. Suggested by Jan.
Signed-off-by: Nick Piggin <npiggin@suse.de>
upstream commit: eb4e545d4ac82d9018487edb4419b33b9930c857
Packet sending is driven by two flags, tx_ready and tx_queued.
It was possible, that there were queued data for sending and
hardware was flagged as blocked but in fact it was not.
The tx_queued was indicator but should be really a counter else
first fragmented packet resets tx_queued flag, but there may be
pending packets which do not get sent.
New semantics:
tx_ready - set, if hw is ready to send packet, no packet is being
transferred right now
set the flag right at the place where data are copied
into hw memory and not earlier without checking if it
was succesful
tx_queued - count of enqueued packets, including fragments
Tested-by: Michal Rokos <michal.rokos@gmail.com>
Signed-off-by: David Sterba <dsterba@suse.cz>
upstream commit: 3bf0a32e22fedc0b46443699db2d61ac2a883ac4
This fixes a kernel crash on rmmod, in the case where the controller
was restarted before doing the rmmod.
upstream commit: 879000f94442860e72c934f9e568989bc7fb8ec4
If cpu specific cpufreq driver(i.e. longrun) has "setpolicy" function,
governor object isn't set into cpufreq_policy object at "__cpufreq_set_policy"
function in driver/cpufreq/cpufreq.c .
This causes a null object access at "store_scaling_setspeed" and
"show_scaling_setspeed" function in driver/cpufreq/cpufreq.c when reading or
writing through /sys interface (ex. cat
/sys/devices/system/cpu/cpu0/cpufreq/scaling_setspeed)
Addresses:
http://bugzilla.kernel.org/show_bug.cgi?id=10654
https://bugzilla.redhat.com/show_bug.cgi?id=443354
Signed-off-by: CHIKAMA Masaki <masaki.chikama@gmail.com>
Cc: Dave Jones <davej@codemonkey.org.uk>
Cc: Chuck Ebbert <cebbert@redhat.com>
Acked-by: Dominik Brodowski <linux@dominikbrodowski.net>
Cc: <stable@kernel.org>
upstream commit: e0a115e5aa554b93150a8dc1c3fe15467708abb2
During the initial array synchronization process there is a window between
when a prexor operation is scheduled to a specific stripe and when it
completes for a sync_request to be scheduled to the same stripe. When
this happens the prexor completes and the stripe is unconditionally marked
"insync", effectively canceling the sync_request for the stripe. Prior to
2.6.23 this was not a problem because the prexor operation was done under
sh->lock. The effect in older kernels being that the prexor would still
erroneously mark the stripe "insync", but sync_request would be held off
and re-mark the stripe as "!in_sync".
Change the write completion logic to not mark the stripe "in_sync" if a
prexor was performed. The effect of the change is to sometimes not set
STRIPE_INSYNC. The worst this can do is cause the resync to stall waiting
for STRIPE_INSYNC to be set. If this were happening, then STRIPE_SYNCING
would be set and handle_issuing_new_read_requests would cause all
available blocks to eventually be read, at which point prexor would never
be used on that stripe any more and STRIPE_INSYNC would eventually be set.
echo repair > /sys/block/mdN/md/sync_action will correct arrays that may
have lost this race.
Signed-off-by: Neil Brown <neilb@suse.de>
[chrisw: backport to 2.6.25.5]
upstream commit: a6d8113a986c66aeb379a26b6e0062488b3e59e1
If an array was created with --assume-clean we will oops when trying to
set ->resync_max.
Fix this by initializing ->recovery_wait in mddev_find.
upstream commit: c337869d95011495fa181536786e74aa2d7ff031
If a block is computed (rather than read) then a check/repair operation
may be lead to believe that the data on disk is correct, when infact it
isn't. So only compute blocks for failed devices.
This issue has been around since at least 2.6.12, but has become harder to
hit in recent kernels since most reads bypass the cache.
echo repair > /sys/block/mdN/md/sync_action will set the parity blocks to the
correct state.
upstream commit: aefdbf1a3b832a580a50cf3d1dcbb717be7cbdbe
When using 4+ GB RAM and SWIOTLB is active, the driver corrupts
memory by writing an skb after the relevant DMA page has been
unmapped. Although this doesn't happen when *not* using bounce
buffers, clearing the pointer to the DMA page after unmapping
it fixes the problem.
http://marc.info/?t=120861317000005&r=2&w=2
[jacliburn@bellsouth.net: backport to 2.6.25.4]
upstream commit: 6e7045990f35ef9250804b3fd85e855b8c2aaeb6.
[jkosina@suse.cz: Needed to fix apple aluminium keyboard regression]
Since 2.6.25 the HID_QUIRK_APPLE_HAS_FN quirk is enabled even for
non-laptop Apple keyboards of the Aluminium series. The USB version of
these don't need Numlock emulation, like the laptop (and Aluminium
Wireless) do, as they have a proper keypad.
This patch splits the Numlock emulation for Apple keyboards in a
different quirk flag, so that it can be enabled for all the keyboards
but the Aluminium USB ones.
If the Numlock emulation is enabled for Aluminium USB keyboards, the
JKL and UIO keys become the numeric pad, and the rest of the keyboard
is disabled, included the key used to disable Numlock.
Additionally, these keyboard should not have a Numlock at all, as the
Numlock key is instead replaced by the 'Clear' key as usual for Apple
USB keyboards.
Signed-off-by: Diego 'Flameeyes' Petteno <flameeyes@gmail.com>
upstream commit: 6fc7431dc0775f21ad7a7a39c2ad0290291a56ea
This fixes the bug that the I/O buffer is not freed at the driver removal.
Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp>
upstream commit: e1d50dce5af77cb6d33555af70e2b8748dd84009
We saw a kernel oops in our regression testing when a multicast "join
finish" occurred just after the interface was -- this is
<https://bugs.openfabrics.org/show_bug.cgi?id=1040>. The test
randomly causes the HCA physical port to go down then up.
The cause of this is that ipoib_mcast_join_finish() processing happen
just after ipoib_mcast_dev_flush() was invoked (in which case the
broadcast pointer is NULL). This patch tests for and handles the case
where priv->broadcast is NULL.
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
upstream commit: 26ab705396b65a469233a8327ecb51b8aebb6be0
This patch reverts 57833ea6b95a3995149f1f6d1a8d8862ab7a0ba2
("usb-serial: pl2303: add support for RATOC REX-USB60F") and adds
support for the device to ftdi_sio driver.
Cc: Akira Tsukamoto <akirat@rd.scei.sony.co.jp>
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
upstream commit: ee53b0ca0153b4f944cb142b5e65c96a1860d765
This adds the Telit UC864-E HDSPA modem support to the option driver.
This lets their customers comply with the GPL instead of having to use a
binary driver from the manufacturer.
Cc: Simon Kissel <kissel@viprinet.com>
Cc: Nico Erfurth <ne@nicoerfurth.de>
Cc: Andrea Ghezzo <TS-EMEA@telit.com>
Cc: Dietmar Staps <Dietmar.Staps@telit.com>
commit 70455e790391dac85d9b483a9e286a40df1ecc7f in upstream
i2c-core takes care of the possible corruption of 24RF08 chips for
quite some times, so device drivers no longer need to do it. And they
really should not, as applying the prevention twice voids it.
I thought that I had fixed all drivers long ago but apparently I had
missed that one.
Cc: Ben Gardner <bgardner@wabtec.com>
commit 08851d6eb4eeb0894f4d095dfdf8ab61c435ad57 in upstream
There is a strange chip at 0x2e on the second SMBus channel of the
DFI Lanparty NF4 Expert motherboard. Accessing the chip reboots the
system. As there's nothing interesting on this SMBus channel, the
easiest and safest thing to do is to disable it on that board.
This is a better fix to bug #5889 than the it87 driver update that was
done originally:
http://bugzilla.kernel.org/show_bug.cgi?id=5889
This fixes the build errors previously caused by
45fa78357eab3287b5c39f2d983b91150b3f4bd8
This makes the code mirror what went into Linus's tree previously.
Reported-by: Randy Dunlap <rdunlap@xenotime.net>
Cc: Alan Stern <stern@rowland.harvard.edu>
Inhibiting link PM mode doesn't bring the link back online if it's
already in powersave mode. If SRST is used in these cases, libata EH
thinks that the link is offline and fails detection. Force hardreset
if link is in powersave mode.
Signed-off-by: Tejun Heo <htejun@gmail.com>
commit 23cacd65f65956426bbca25964a68c174db83a31 upstream
As reported by Magnus Boman <captain.magnus@opensuse.org>
Cc: Magnus Boman <captain.magnus@opensuse.org>
commit cdafc37a7b727b75ced65e31e47dafbd8b70f97f upstream
This device is not a serial port, but a virtual CD-ROM device. For
example with my Novatel MC950D:
lsusb -v -d 1410:5010 | grep InterfaceClass
bInterfaceClass 8 Mass Storage
After some time (ca. 5min) or if virtual CD is ejected, device id
changes to 1410:4400:
% lsusb -v -d 1410:4400 | grep InterfaceClass
bInterfaceClass 255 Vendor Specific Class
Variable name says that 0x5010 is a Novatel U727, but searching in
internet shows, that this device also provides virtual CD that should be
ejected before use. Product id for serial port in this case is 0x4100.
Signed-off-by: Eugeniy Meshcheryakov <eugen@debian.org>
commit 6149ed5e3a6207595bd7362af7724d64f44af216 upstream
The patch below is a necessary workaround to support the Zoom Telephonics Model 3095F V.92 USB Mini External modem, which fails to initialise properly during normal probing thus:
May 3 22:53:00 imcfarla kernel: drivers/usb/class/cdc-acm.c: Zero length descriptor references
May 3 22:53:00 imcfarla kernel: cdc_acm: probe of 5-2:1.0 failed with error -22
Adding the patch below causes the probing section to be skipped, and the modem
then initialises correctly.
Signed-off-by: Iain McFarlane <iain@imcfarla.homelinux.net>
Acked-by: Oliver Neukum <oneukum@suse.de>
commit 96cb15cf977356d9d3117dd88f3fe187d6024f4b upstream
New variant of the 5520 found by Luke Sheldrick.
Signed-off-by: Dan Williams <dcbw@redhat.com>
commit e7c6f80fd733218aa1e79efa5d9ece9f76966160 upstream
Enables the SD-Card interface on the GI 0401 HSUPA card from Option.
The unusual_devs.h entry is necessary because the device descriptor is
vendor-specific. That prevents usb-storage from binding to it as an
interface driver.
This revised patch adds a small comment explaining why and reduces the
rev range.
T: Bus=02 Lev=01 Prnt=01 Port=06 Cnt=01 Dev#= 3 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=ff(vend.) Sub=ff Prot=ff MxPS=64 #Cfgs= 1
P: Vendor=0af0 ProdID=7401 Rev= 0.00
S: Manufacturer=Option N.V.
S: Product=Globetrotter HSUPA Modem
C:* #Ifs=10 Cfg#= 1 Atr=80 MxPwr=500mA
I:* If#= 0 Alt= 0 #EPs= 0 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
I: If#= 0 Alt= 1 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 1 Alt= 0 #EPs= 0 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
I: If#= 1 Alt= 1 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 2 Alt= 0 #EPs= 0 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
I: If#= 2 Alt= 1 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=83(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 3 Alt= 0 #EPs= 0 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
I: If#= 3 Alt= 1 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=84(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 4 Alt= 0 #EPs= 0 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
I: If#= 4 Alt= 1 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=85(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=05(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 5 Alt= 0 #EPs= 0 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
I: If#= 5 Alt= 1 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=86(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=06(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 6 Alt= 0 #EPs= 0 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
I: If#= 6 Alt= 1 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=87(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=07(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 7 Alt= 0 #EPs= 0 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
I: If#= 7 Alt= 1 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=88(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=08(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 8 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=89(I) Atr=03(Int.) MxPS= 64 Ivl=2ms
E: Ad=8a(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=09(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 9 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
E: Ad=0a(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=8b(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
Signed-off-by: Filip Aben <f.aben@option.com>
Signed-off-by: Phil Dibowitz <phil@ipom.com>
